root/radiance/ray/src/common/calfunc.c
Revision: 2.17
Committed: Sat Apr 20 02:31:41 2013 UTC (12 years, 3 months ago) by greg
Changes since 2.16: +5 -11 lines
Changed from member copy to structure copy
2 static const char RCSid[] = "$Id: calfunc.c,v 2.16 2012/10/24 00:39:09 greg Exp $";
5 * calfunc.c - routines for calcomp using functions.
6 *
7 * If VARIABLE is not set, only library functions
8 * can be accessed.
9 *
10 * 2/19/03 Eliminated conditional compiles in favor of esupport extern.
11 */
12
13 #include "copyright.h"
14
15 #include <stdio.h>
16 #include <string.h>
17 #include <errno.h>
18 #include <math.h>
19
20 #include "rterror.h"
21 #include "calcomp.h"
22
23 /* bits in argument flag (better be right!) */
24 #define AFLAGSIZ (8*sizeof(unsigned long))
25 #define ALISTSIZ 6 /* maximum saved argument list */
26
27 typedef struct activation {
28 char *name; /* function name */
29 struct activation *prev; /* previous activation */
30 double *ap; /* argument list */
31 unsigned long an; /* computed argument flags */
32 EPNODE *fun; /* argument function */
33 } ACTIVATION; /* an activation record */
34
35 static ACTIVATION *curact = NULL;
36
37 static double libfunc(char *fname, VARDEF *vp);
38
39 #ifndef MAXLIB
40 #define MAXLIB 64 /* maximum number of library functions */
41 #endif
42
43 static double l_if(char *), l_select(char *), l_rand(char *);
44 static double l_floor(char *), l_ceil(char *);
45 static double l_sqrt(char *);
46 static double l_sin(char *), l_cos(char *), l_tan(char *);
47 static double l_asin(char *), l_acos(char *), l_atan(char *), l_atan2(char *);
48 static double l_exp(char *), l_log(char *), l_log10(char *);
49
50 /* functions must be listed alphabetically */
51 static LIBR library[MAXLIB] = {
52 { "acos", 1, ':', l_acos },
53 { "asin", 1, ':', l_asin },
54 { "atan", 1, ':', l_atan },
55 { "atan2", 2, ':', l_atan2 },
56 { "ceil", 1, ':', l_ceil },
57 { "cos", 1, ':', l_cos },
58 { "exp", 1, ':', l_exp },
59 { "floor", 1, ':', l_floor },
60 { "if", 3, ':', l_if },
61 { "log", 1, ':', l_log },
62 { "log10", 1, ':', l_log10 },
63 { "rand", 1, ':', l_rand },
64 { "select", 1, ':', l_select },
65 { "sin", 1, ':', l_sin },
66 { "sqrt", 1, ':', l_sqrt },
67 { "tan", 1, ':', l_tan },
68 };
69
70 static int libsize = 16;
71
72 #define resolve(ep) ((ep)->type==VAR?(ep)->v.ln:argf((ep)->v.chan))
73
74
75 int
76 fundefined( /* return # of arguments for function */
77 char *fname
78 )
79 {
80 LIBR *lp;
81 VARDEF *vp;
82
83 if ((vp = varlookup(fname)) != NULL && vp->def != NULL
84 && vp->def->v.kid->type == FUNC)
85 return(nekids(vp->def->v.kid) - 1);
86 lp = vp != NULL ? vp->lib : liblookup(fname);
87 if (lp == NULL)
88 return(0);
89 return(lp->nargs);
90 }
91
92
93 double
94 funvalue( /* return a function value to the user */
95 char *fname,
96 int n,
97 double *a
98 )
99 {
100 ACTIVATION act;
101 VARDEF *vp;
102 double rval;
103 /* push environment */
104 act.name = fname;
105 act.prev = curact;
106 act.ap = a;
107 if (n >= AFLAGSIZ)
108 act.an = ~0;
109 else
110 act.an = (1L<<n)-1;
111 act.fun = NULL;
112 curact = &act;
113
114 if ((vp = varlookup(fname)) == NULL || vp->def == NULL
115 || vp->def->v.kid->type != FUNC)
116 rval = libfunc(fname, vp);
117 else
118 rval = evalue(vp->def->v.kid->sibling);
119
120 curact = act.prev; /* pop environment */
121 return(rval);
122 }
123
124
125 void
126 funset( /* set a library function */
127 char *fname,
128 int nargs,
129 int assign,
130 double (*fptr)(char *)
131 )
132 {
133 int oldlibsize = libsize;
134 char *cp;
135 LIBR *lp;
136 /* check for context */
137 for (cp = fname; *cp; cp++)
138 ;
139 if (cp == fname)
140 return;
141 if (cp[-1] == CNTXMARK)
142 *--cp = '\0';
143 if ((lp = liblookup(fname)) == NULL) { /* insert */
144 if (libsize >= MAXLIB) {
145 eputs("Too many library functons!\n");
146 quit(1);
147 }
148 for (lp = &library[libsize]; lp > library; lp--)
149 if (strcmp(lp[-1].fname, fname) > 0)
150 lp[0] = lp[-1];
151 else
152 break;
153 libsize++;
154 }
155 if (fptr == NULL) { /* delete */
156 while (lp < &library[libsize-1]) {
157 lp[0] = lp[1];
158 lp++;
159 }
160 libsize--;
161 } else { /* or assign */
162 lp[0].fname = fname; /* string must be static! */
163 lp[0].nargs = nargs;
164 lp[0].atyp = assign;
165 lp[0].f = fptr;
166 }
167 if (libsize != oldlibsize)
168 libupdate(fname); /* relink library */
169 }
170
171
172 int
173 nargum(void) /* return number of available arguments */
174 {
175 int n;
176
177 if (curact == NULL)
178 return(0);
179 if (curact->fun == NULL) {
180 for (n = 0; (1L<<n) & curact->an; n++)
181 ;
182 return(n);
183 }
184 return(nekids(curact->fun) - 1);
185 }
186
187
188 double
189 argument(int n) /* return nth argument for active function */
190 {
191 ACTIVATION *actp = curact;
192 EPNODE *ep = NULL;
193 double aval;
194
195 if (actp == NULL || --n < 0) {
196 eputs("Bad call to argument!\n");
197 quit(1);
198 }
199 /* already computed? */
200 if (n < AFLAGSIZ && 1L<<n & actp->an)
201 return(actp->ap[n]);
202
203 if (actp->fun == NULL || (ep = ekid(actp->fun, n+1)) == NULL) {
204 eputs(actp->name);
205 eputs(": too few arguments\n");
206 quit(1);
207 }
208 curact = actp->prev; /* pop environment */
209 aval = evalue(ep); /* compute argument */
210 curact = actp; /* push back environment */
211 if (n < ALISTSIZ) { /* save value */
212 actp->ap[n] = aval;
213 actp->an |= 1L<<n;
214 }
215 return(aval);
216 }
217
218
219 VARDEF *
220 argf(int n) /* return function def for nth argument */
221 {
222 ACTIVATION *actp;
223 EPNODE *ep;
224
225 for (actp = curact; actp != NULL; actp = actp->prev) {
226
227 if (n <= 0)
228 break;
229
230 if (actp->fun == NULL)
231 goto badarg;
232
233 if ((ep = ekid(actp->fun, n)) == NULL) {
234 eputs(actp->name);
235 eputs(": too few arguments\n");
236 quit(1);
237 }
238 if (ep->type == VAR)
239 return(ep->v.ln); /* found it */
240
241 if (ep->type != ARG)
242 goto badarg;
243
244 n = ep->v.chan; /* try previous context */
245 }
246 eputs("Bad call to argf!\n");
247 quit(1);
248
249 badarg:
250 eputs(actp->name);
251 eputs(": argument not a function\n");
252 quit(1);
253 return NULL; /* pro forma return */
254 }
255
256
257 char *
258 argfun(int n) /* return function name for nth argument */
259 {
260 return(argf(n)->name);
261 }
262
263
264 double
265 efunc(EPNODE *ep) /* evaluate a function */
266 {
267 ACTIVATION act;
268 double alist[ALISTSIZ];
269 double rval;
270 VARDEF *dp;
271 /* push environment */
272 dp = resolve(ep->v.kid);
273 act.name = dp->name;
274 act.prev = curact;
275 act.ap = alist;
276 act.an = 0;
277 act.fun = ep;
278 curact = &act;
279
280 if (dp->def == NULL || dp->def->v.kid->type != FUNC)
281 rval = libfunc(act.name, dp);
282 else
283 rval = evalue(dp->def->v.kid->sibling);
284
285 curact = act.prev; /* pop environment */
286 return(rval);
287 }
288
289
290 LIBR *
291 liblookup(char *fname) /* look up a library function */
292 {
293 int upper, lower;
294 int cm, i;
295
296 lower = 0;
297 upper = cm = libsize;
298
299 while ((i = (lower + upper) >> 1) != cm) {
300 cm = strcmp(fname, library[i].fname);
301 if (cm > 0)
302 lower = i;
303 else if (cm < 0)
304 upper = i;
305 else
306 return(&library[i]);
307 cm = i;
308 }
309 return(NULL);
310 }
311
312
313 /*
314 * The following routines are for internal use:
315 */
316
317
318 static double
319 libfunc( /* execute library function */
320 char *fname,
321 VARDEF *vp
322 )
323 {
324 LIBR *lp;
325 double d;
326 int lasterrno;
327
328 if (vp != NULL)
329 lp = vp->lib;
330 else
331 lp = liblookup(fname);
332 if (lp == NULL) {
333 eputs(fname);
334 eputs(": undefined function\n");
335 quit(1);
336 }
337 lasterrno = errno;
338 errno = 0;
339 d = (*lp->f)(lp->fname);
340 #ifdef isnan
341 if (errno == 0)
342 if (isnan(d))
343 errno = EDOM;
344 else if (isinf(d))
345 errno = ERANGE;
346 #endif
347 if (errno == EDOM || errno == ERANGE) {
348 wputs(fname);
349 if (errno == EDOM)
350 wputs(": domain error\n");
351 else if (errno == ERANGE)
352 wputs(": range error\n");
353 else
354 wputs(": error in call\n");
355 return(0.0);
356 }
357 errno = lasterrno;
358 return(d);
359 }
360
361
362 /*
363 * Library functions:
364 */
365
366
367 static double
368 l_if(char *nm) /* if(cond, then, else) conditional expression */
369 /* cond evaluates true if greater than zero */
370 {
371 if (argument(1) > 0.0)
372 return(argument(2));
373 else
374 return(argument(3));
375 }
376
377
378 static double
379 l_select(char *nm) /* return argument #(A1+1) */
380 {
381 int n;
382
383 n = (int)(argument(1) + .5);
384 if (n == 0)
385 return(nargum()-1);
386 if (n < 1 || n > nargum()-1) {
387 errno = EDOM;
388 return(0.0);
389 }
390 return(argument(n+1));
391 }
392
393
394 static double
395 l_rand(char *nm) /* random function between 0 and 1 */
396 {
397 double x;
398
399 x = argument(1);
400 x *= 1.0/(1.0 + x*x) + 2.71828182845904;
401 x += .785398163397447 - floor(x);
402 x = 1e5 / x;
403 return(x - floor(x));
404 }
405
406
407 static double
408 l_floor(char *nm) /* return largest integer not greater than arg1 */
409 {
410 return(floor(argument(1)));
411 }
412
413
414 static double
415 l_ceil(char *nm) /* return smallest integer not less than arg1 */
416 {
417 return(ceil(argument(1)));
418 }
419
420
421 static double
422 l_sqrt(char *nm)
423 {
424 return(sqrt(argument(1)));
425 }
426
427
428 static double
429 l_sin(char *nm)
430 {
431 return(sin(argument(1)));
432 }
433
434
435 static double
436 l_cos(char *nm)
437 {
438 return(cos(argument(1)));
439 }
440
441
442 static double
443 l_tan(char *nm)
444 {
445 return(tan(argument(1)));
446 }
447
448
449 static double
450 l_asin(char *nm)
451 {
452 return(asin(argument(1)));
453 }
454
455
456 static double
457 l_acos(char *nm)
458 {
459 return(acos(argument(1)));
460 }
461
462
463 static double
464 l_atan(char *nm)
465 {
466 return(atan(argument(1)));
467 }
468
469
470 static double
471 l_atan2(char *nm)
472 {
473 return(atan2(argument(1), argument(2)));
474 }
475
476
477 static double
478 l_exp(char *nm)
479 {
480 return(exp(argument(1)));
481 }
482
483
484 static double
485 l_log(char *nm)
486 {
487 return(log(argument(1)));
488 }
489
490
491 static double
492 l_log10(char *nm)
493 {
494 return(log10(argument(1)));
495 }
