root/radiance/ray/src/common/calfunc.c
Revision: 1.8
Committed: Tue Jul 16 14:26:18 1991 UTC (34 years ago) by greg
improved specificity of warning for bad function call
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * calfunc.c - routines for calcomp using functions.
9 *
10 * The define BIGLIB pulls in a large number of the
11 * available math routines.
12 *
13 * If VARIABLE is not defined, only library functions
14 * can be accessed.
15 *
16 * 4/2/86
17 */
18
19 #include <stdio.h>
20
21 #include <errno.h>
22
23 #include "calcomp.h"
24
25 /* bits in argument flag (better be right!) */
26 #define AFLAGSIZ (8*sizeof(unsigned long))
27 #define ALISTSIZ 6 /* maximum saved argument list */
28
29 typedef struct activation {
30 char *name; /* function name */
31 struct activation *prev; /* previous activation */
32 double *ap; /* argument list */
33 unsigned long an; /* computed argument flags */
34 EPNODE *fun; /* argument function */
35 } ACTIVATION; /* an activation record */
36
37 static ACTIVATION *curact = NULL;
38
39 static double libfunc();
40
41 #define MAXLIB 64 /* maximum number of library functions */
42
43 static double l_if(), l_select(), l_rand();
44 static double l_floor(), l_ceil();
45 #ifdef BIGLIB
46 static double l_sqrt();
47 static double l_sin(), l_cos(), l_tan();
48 static double l_asin(), l_acos(), l_atan(), l_atan2();
49 static double l_exp(), l_log(), l_log10();
50 #endif
51
52 #ifdef BIGLIB
53 /* functions must be listed alphabetically */
54 static LIBR library[MAXLIB] = {
55 { "acos", 1, ':', l_acos },
56 { "asin", 1, ':', l_asin },
57 { "atan", 1, ':', l_atan },
58 { "atan2", 2, ':', l_atan2 },
59 { "ceil", 1, ':', l_ceil },
60 { "cos", 1, ':', l_cos },
61 { "exp", 1, ':', l_exp },
62 { "floor", 1, ':', l_floor },
63 { "if", 3, ':', l_if },
64 { "log", 1, ':', l_log },
65 { "log10", 1, ':', l_log10 },
66 { "rand", 1, ':', l_rand },
67 { "select", 1, ':', l_select },
68 { "sin", 1, ':', l_sin },
69 { "sqrt", 1, ':', l_sqrt },
70 { "tan", 1, ':', l_tan },
71 };
72
73 static int libsize = 16;
74
75 #else
76 /* functions must be listed alphabetically */
77 static LIBR library[MAXLIB] = {
78 { "ceil", 1, ':', l_ceil },
79 { "floor", 1, ':', l_floor },
80 { "if", 3, ':', l_if },
81 { "rand", 1, ':', l_rand },
82 { "select", 1, ':', l_select },
83 };
84
85 static int libsize = 5;
86
87 #endif
88
89 extern char *savestr(), *emalloc();
90
91 extern LIBR *liblookup();
92
93 extern VARDEF *argf();
94
95 #ifdef VARIABLE
96 #define resolve(ep) ((ep)->type==VAR?(ep)->v.ln:argf((ep)->v.chan))
97 #else
98 #define resolve(ep) ((ep)->v.ln)
99 #define varlookup(name) NULL
100 #endif
101
102
103 int
104 fundefined(fname) /* return # of arguments for function */
105 char *fname;
106 {
107 LIBR *lp;
108 register VARDEF *vp;
109
110 if ((vp = varlookup(fname)) == NULL || vp->def == NULL
111 || vp->def->v.kid->type != FUNC)
112 if ((lp = liblookup(fname)) == NULL)
113 return(0);
114 else
115 return(lp->nargs);
116 else
117 return(nekids(vp->def->v.kid) - 1);
118 }
119
120
121 double
122 funvalue(fname, n, a) /* return a function value to the user */
123 char *fname;
124 int n;
125 double *a;
126 {
127 ACTIVATION act;
128 register VARDEF *vp;
129 double rval;
130 /* push environment */
131 act.name = fname;
132 act.prev = curact;
133 act.ap = a;
134 if (n >= AFLAGSIZ)
135 act.an = ~0;
136 else
137 act.an = (1L<<n)-1;
138 act.fun = NULL;
139 curact = &act;
140
141 if ((vp = varlookup(fname)) == NULL || vp->def == NULL
142 || vp->def->v.kid->type != FUNC)
143 rval = libfunc(fname, vp);
144 else
145 rval = evalue(vp->def->v.kid->sibling);
146
147 curact = act.prev; /* pop environment */
148 return(rval);
149 }
150
151
152 funset(fname, nargs, assign, fptr) /* set a library function */
153 char *fname;
154 int nargs;
155 int assign;
156 double (*fptr)();
157 {
158 register LIBR *lp;
159
160 if ((lp = liblookup(fname)) == NULL) {
161 if (libsize >= MAXLIB) {
162 eputs("Too many library functons!\n");
163 quit(1);
164 }
165 for (lp = &library[libsize]; lp > library; lp--)
166 if (strcmp(lp[-1].fname, fname) > 0) {
167 lp[0].fname = lp[-1].fname;
168 lp[0].nargs = lp[-1].nargs;
169 lp[0].atyp = lp[-1].atyp;
170 lp[0].f = lp[-1].f;
171 } else
172 break;
173 libsize++;
174 }
175 lp[0].fname = fname; /* must be static! */
176 lp[0].nargs = nargs;
177 lp[0].atyp = assign;
178 lp[0].f = fptr;
179 }
180
181
182 int
183 nargum() /* return number of available arguments */
184 {
185 register int n;
186
187 if (curact == NULL)
188 return(0);
189 if (curact->fun == NULL) {
190 for (n = 0; (1L<<n) & curact->an; n++)
191 ;
192 return(n);
193 }
194 return(nekids(curact->fun) - 1);
195 }
196
197
198 double
199 argument(n) /* return nth argument for active function */
200 register int n;
201 {
202 register ACTIVATION *actp = curact;
203 register EPNODE *ep;
204 double aval;
205
206 if (actp == NULL || --n < 0) {
207 eputs("Bad call to argument!\n");
208 quit(1);
209 }
210 /* already computed? */
211 if (n < AFLAGSIZ && 1L<<n & actp->an)
212 return(actp->ap[n]);
213
214 if (actp->fun == NULL || (ep = ekid(actp->fun, n+1)) == NULL) {
215 eputs(actp->name);
216 eputs(": too few arguments\n");
217 quit(1);
218 }
219 curact = actp->prev; /* pop environment */
220 aval = evalue(ep); /* compute argument */
221 curact = actp; /* push back environment */
222 if (n < ALISTSIZ) { /* save value */
223 actp->ap[n] = aval;
224 actp->an |= 1L<<n;
225 }
226 return(aval);
227 }
228
229
230 #ifdef VARIABLE
231 VARDEF *
232 argf(n) /* return function def for nth argument */
233 int n;
234 {
235 register ACTIVATION *actp;
236 register EPNODE *ep;
237
238 for (actp = curact; actp != NULL; actp = actp->prev) {
239
240 if (n <= 0)
241 break;
242
243 if (actp->fun == NULL)
244 goto badarg;
245
246 if ((ep = ekid(actp->fun, n)) == NULL) {
247 eputs(actp->name);
248 eputs(": too few arguments\n");
249 quit(1);
250 }
251 if (ep->type == VAR)
252 return(ep->v.ln); /* found it */
253
254 if (ep->type != ARG)
255 goto badarg;
256
257 n = ep->v.chan; /* try previous context */
258 }
259 eputs("Bad call to argf!\n");
260 quit(1);
261
262 badarg:
263 eputs(actp->name);
264 eputs(": argument not a function\n");
265 quit(1);
266 }
267
268
269 char *
270 argfun(n) /* return function name for nth argument */
271 int n;
272 {
273 return(argf(n)->name);
274 }
275 #endif
276
277
278 double
279 efunc(ep) /* evaluate a function */
280 register EPNODE *ep;
281 {
282 ACTIVATION act;
283 double alist[ALISTSIZ];
284 double rval;
285 register VARDEF *dp;
286 /* push environment */
287 dp = resolve(ep->v.kid);
288 act.name = dp->name;
289 act.prev = curact;
290 act.ap = alist;
291 act.an = 0;
292 act.fun = ep;
293 curact = &act;
294
295 if (dp->def == NULL || dp->def->v.kid->type != FUNC)
296 rval = libfunc(act.name, dp);
297 else
298 rval = evalue(dp->def->v.kid->sibling);
299
300 curact = act.prev; /* pop environment */
301 return(rval);
302 }
303
304
305 LIBR *
306 liblookup(fname) /* look up a library function */
307 char *fname;
308 {
309 int upper, lower;
310 register int cm, i;
311
312 lower = 0;
313 upper = cm = libsize;
314
315 while ((i = (lower + upper) >> 1) != cm) {
316 cm = strcmp(fname, library[i].fname);
317 if (cm > 0)
318 lower = i;
319 else if (cm < 0)
320 upper = i;
321 else
322 return(&library[i]);
323 cm = i;
324 }
325 return(NULL);
326 }
327
328
329 #ifndef VARIABLE
330 VARDEF *
331 varinsert(vname) /* dummy variable insert */
332 char *vname;
333 {
334 register VARDEF *vp;
335
336 vp = (VARDEF *)emalloc(sizeof(VARDEF));
337 vp->name = savestr(vname);
338 vp->nlinks = 1;
339 vp->def = NULL;
340 vp->lib = NULL;
341 vp->next = NULL;
342 return(vp);
343 }
344
345
346 varfree(vp) /* free dummy variable */
347 register VARDEF *vp;
348 {
349 freestr(vp->name);
350 efree((char *)vp);
351 }
352 #endif
353
354
355
356 /*
357 * The following routines are for internal use:
358 */
359
360
361 static double
362 libfunc(fname, vp) /* execute library function */
363 char *fname;
364 register VARDEF *vp;
365 {
366 VARDEF dumdef;
367 double d;
368 int lasterrno;
369
370 if (vp == NULL) {
371 vp = &dumdef;
372 vp->lib = NULL;
373 }
374 if (((vp->lib == NULL || strcmp(fname, vp->lib->fname)) &&
375 (vp->lib = liblookup(fname)) == NULL) ||
376 vp->lib->f == NULL) {
377 eputs(fname);
378 eputs(": undefined function\n");
379 quit(1);
380 }
381 lasterrno = errno;
382 errno = 0;
383 d = (*vp->lib->f)(vp->lib->fname);
384 #ifdef IEEE
385 if (!finite(d))
386 errno = EDOM;
387 #endif
388 if (errno) {
389 wputs(fname);
390 if (errno == EDOM)
391 wputs(": domain error\n");
392 else if (errno == ERANGE)
393 wputs(": range error\n");
394 else
395 wputs(": error in call\n");
396 return(0.0);
397 }
398 errno = lasterrno;
399 return(d);
400 }
401
402
403 /*
404 * Library functions:
405 */
406
407
408 static double
409 l_if() /* if(cond, then, else) conditional expression */
410 /* cond evaluates true if greater than zero */
411 {
412 if (argument(1) > 0.0)
413 return(argument(2));
414 else
415 return(argument(3));
416 }
417
418
419 static double
420 l_select() /* return argument #(A1+1) */
421 {
422 register int n;
423
424 n = argument(1) + .5;
425 if (n == 0)
426 return(nargum()-1);
427 if (n < 1 || n > nargum()-1) {
428 errno = EDOM;
429 return(0.0);
430 }
431 return(argument(n+1));
432 }
433
434
435 static double
436 l_rand() /* random function between 0 and 1 */
437 {
438 extern double floor();
439 double x;
440
441 x = argument(1);
442 x *= 1.0/(1.0 + x*x) + 2.71828182845904;
443 x += .785398163397447 - floor(x);
444 x = 1e5 / x;
445 return(x - floor(x));
446 }
447
448
449 static double
450 l_floor() /* return largest integer not greater than arg1 */
451 {
452 extern double floor();
453
454 return(floor(argument(1)));
455 }
456
457
458 static double
459 l_ceil() /* return smallest integer not less than arg1 */
460 {
461 extern double ceil();
462
463 return(ceil(argument(1)));
464 }
465
466
467 #ifdef BIGLIB
468 static double
469 l_sqrt()
470 {
471 extern double sqrt();
472
473 return(sqrt(argument(1)));
474 }
475
476
477 static double
478 l_sin()
479 {
480 extern double sin();
481
482 return(sin(argument(1)));
483 }
484
485
486 static double
487 l_cos()
488 {
489 extern double cos();
490
491 return(cos(argument(1)));
492 }
493
494
495 static double
496 l_tan()
497 {
498 extern double tan();
499
500 return(tan(argument(1)));
501 }
502
503
504 static double
505 l_asin()
506 {
507 extern double asin();
508
509 return(asin(argument(1)));
510 }
511
512
513 static double
514 l_acos()
515 {
516 extern double acos();
517
518 return(acos(argument(1)));
519 }
520
521
522 static double
523 l_atan()
524 {
525 extern double atan();
526
527 return(atan(argument(1)));
528 }
529
530
531 static double
532 l_atan2()
533 {
534 extern double atan2();
535
536 return(atan2(argument(1), argument(2)));
537 }
538
539
540 static double
541 l_exp()
542 {
543 extern double exp();
544
545 return(exp(argument(1)));
546 }
547
548
549 static double
550 l_log()
551 {
552 extern double log();
553
554 return(log(argument(1)));
555 }
556
557
558 static double
559 l_log10()
560 {
561 extern double log10();
562
563 return(log10(argument(1)));
564 }
565 #endif
