| 1 |
/* Copyright (c) 1992 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Compute data values using expression parser
| 9 |
| 10 |
* 7/1/85 Greg Ward
| 11 |
| 12 |
* 11/11/85 Made channel input conditional with (INCHAN) compiles.
| 13 |
| 14 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION).
| 15 |
| 16 |
* 1/29/87 Made variables conditional (VARIABLE)
| 17 |
| 18 |
* 5/19/88 Added constant subexpression elimination (RCONST)
| 19 |
| 20 |
| 21 |
#include <stdio.h>
| 22 |
| 23 |
#include <ctype.h>
| 24 |
| 25 |
#include <errno.h>
| 26 |
| 27 |
#include <math.h>
| 28 |
| 29 |
#include "calcomp.h"
| 30 |
| 31 |
#define MAXLINE 256 /* maximum line length */
| 32 |
| 33 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
| 34 |
| 35 |
#define isdecimal(c) (isdigit(c) || (c) == '.')
| 36 |
| 37 |
#ifndef atof
| 38 |
extern double atof();
| 39 |
#endif
| 40 |
extern char *fgets(), *savestr();
| 41 |
extern char *emalloc(), *ecalloc();
| 42 |
extern EPNODE *curfunc;
| 43 |
extern double efunc(), evariable();
| 44 |
static double euminus(), echannel(), eargument(), enumber();
| 45 |
static double eadd(), esubtr(), emult(), edivi(), epow();
| 46 |
static double ebotch();
| 47 |
| 48 |
int nextc; /* lookahead character */
| 49 |
| 50 |
double (*eoper[])() = { /* expression operations */
| 51 |
ebotch,
| 52 |
#ifdef VARIABLE
| 53 |
evariable,
| 54 |
#else
| 55 |
ebotch,
| 56 |
#endif
| 57 |
enumber,
| 58 |
euminus,
| 59 |
#ifdef INCHAN
| 60 |
echannel,
| 61 |
#else
| 62 |
ebotch,
| 63 |
#endif
| 64 |
#ifdef FUNCTION
| 65 |
efunc,
| 66 |
eargument,
| 67 |
#else
| 68 |
ebotch,
| 69 |
ebotch,
| 70 |
#endif
| 71 |
ebotch,
| 72 |
ebotch,
| 73 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
| 74 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
| 75 |
emult,
| 76 |
eadd,
| 77 |
0,
| 78 |
esubtr,
| 79 |
0,
| 80 |
edivi,
| 81 |
| 82 |
ebotch,
| 83 |
0,0,
| 84 |
ebotch,
| 85 |
| 86 |
| 87 |
epow,
| 88 |
| 89 |
| 90 |
static FILE *infp; /* input file pointer */
| 91 |
static char *linbuf; /* line buffer */
| 92 |
static char *infile; /* input file name */
| 93 |
static int lineno; /* input line number */
| 94 |
static int linepos; /* position in buffer */
| 95 |
| 96 |
| 97 |
EPNODE *
| 98 |
eparse(expr) /* parse an expression string */
| 99 |
char *expr;
| 100 |
| 101 |
EPNODE *ep;
| 102 |
| 103 |
initstr(expr, NULL, 0);
| 104 |
#if defined(VARIABLE) && defined(FUNCTION)
| 105 |
curfunc = NULL;
| 106 |
#endif
| 107 |
ep = getE1();
| 108 |
if (nextc != EOF)
| 109 |
syntax("unexpected character");
| 110 |
return(ep);
| 111 |
| 112 |
| 113 |
| 114 |
double
| 115 |
eval(expr) /* evaluate an expression string */
| 116 |
char *expr;
| 117 |
| 118 |
register EPNODE *ep;
| 119 |
double rval;
| 120 |
| 121 |
ep = eparse(expr);
| 122 |
rval = evalue(ep);
| 123 |
epfree(ep);
| 124 |
return(rval);
| 125 |
| 126 |
| 127 |
| 128 |
epfree(epar) /* free a parse tree */
| 129 |
register EPNODE *epar;
| 130 |
| 131 |
| 132 |
| 133 |
switch (epar->type) {
| 134 |
| 135 |
#if defined(VARIABLE) || defined(FUNCTION)
| 136 |
case VAR:
| 137 |
varfree(epar->v.ln);
| 138 |
break;
| 139 |
| 140 |
case SYM:
| 141 |
freestr(epar->v.name);
| 142 |
break;
| 143 |
#endif
| 144 |
| 145 |
case NUM:
| 146 |
case CHAN:
| 147 |
case ARG:
| 148 |
case TICK:
| 149 |
break;
| 150 |
| 151 |
default:
| 152 |
for (ep = epar->v.kid; ep != NULL; ep = ep->sibling)
| 153 |
epfree(ep);
| 154 |
break;
| 155 |
| 156 |
| 157 |
| 158 |
efree((char *)epar);
| 159 |
| 160 |
| 161 |
/* the following used to be a switch */
| 162 |
#ifdef FUNCTION
| 163 |
static double
| 164 |
eargument(ep)
| 165 |
EPNODE *ep;
| 166 |
| 167 |
return(argument(ep->v.chan));
| 168 |
| 169 |
#endif
| 170 |
| 171 |
static double
| 172 |
enumber(ep)
| 173 |
EPNODE *ep;
| 174 |
| 175 |
return(ep->v.num);
| 176 |
| 177 |
| 178 |
static double
| 179 |
euminus(ep)
| 180 |
EPNODE *ep;
| 181 |
| 182 |
register EPNODE *ep1 = ep->v.kid;
| 183 |
| 184 |
return(-evalue(ep1));
| 185 |
| 186 |
| 187 |
#ifdef INCHAN
| 188 |
static double
| 189 |
echannel(ep)
| 190 |
EPNODE *ep;
| 191 |
| 192 |
return(chanvalue(ep->v.chan));
| 193 |
| 194 |
#endif
| 195 |
| 196 |
static double
| 197 |
eadd(ep)
| 198 |
EPNODE *ep;
| 199 |
| 200 |
| 201 |
| 202 |
return(evalue(ep1) + evalue(ep1->sibling));
| 203 |
| 204 |
| 205 |
static double
| 206 |
esubtr(ep)
| 207 |
EPNODE *ep;
| 208 |
| 209 |
| 210 |
| 211 |
return(evalue(ep1) - evalue(ep1->sibling));
| 212 |
| 213 |
| 214 |
static double
| 215 |
emult(ep)
| 216 |
EPNODE *ep;
| 217 |
| 218 |
| 219 |
| 220 |
return(evalue(ep1) * evalue(ep1->sibling));
| 221 |
| 222 |
| 223 |
static double
| 224 |
edivi(ep)
| 225 |
EPNODE *ep;
| 226 |
| 227 |
| 228 |
double d;
| 229 |
| 230 |
d = evalue(ep1->sibling);
| 231 |
if (d == 0.0) {
| 232 |
wputs("Division by zero\n");
| 233 |
errno = ERANGE;
| 234 |
return(0.0);
| 235 |
| 236 |
return(evalue(ep1) / d);
| 237 |
| 238 |
| 239 |
static double
| 240 |
epow(ep)
| 241 |
EPNODE *ep;
| 242 |
| 243 |
| 244 |
double d;
| 245 |
int lasterrno;
| 246 |
| 247 |
lasterrno = errno;
| 248 |
errno = 0;
| 249 |
d = pow(evalue(ep1), evalue(ep1->sibling));
| 250 |
#ifdef IEEE
| 251 |
if (!finite(d))
| 252 |
errno = EDOM;
| 253 |
#endif
| 254 |
if (errno) {
| 255 |
wputs("Illegal power\n");
| 256 |
return(0.0);
| 257 |
| 258 |
errno = lasterrno;
| 259 |
return(d);
| 260 |
| 261 |
| 262 |
static double
| 263 |
ebotch(ep)
| 264 |
EPNODE *ep;
| 265 |
| 266 |
eputs("Bad expression!\n");
| 267 |
quit(1);
| 268 |
| 269 |
| 270 |
| 271 |
EPNODE *
| 272 |
ekid(ep, n) /* return pointer to a node's nth kid */
| 273 |
| 274 |
register int n;
| 275 |
| 276 |
| 277 |
for (ep = ep->v.kid; ep != NULL; ep = ep->sibling)
| 278 |
if (--n < 0)
| 279 |
break;
| 280 |
| 281 |
return(ep);
| 282 |
| 283 |
| 284 |
| 285 |
int
| 286 |
nekids(ep) /* return # of kids for node ep */
| 287 |
| 288 |
| 289 |
register int n = 0;
| 290 |
| 291 |
| 292 |
n++;
| 293 |
| 294 |
return(n);
| 295 |
| 296 |
| 297 |
| 298 |
initfile(fp, fn, ln) /* prepare input file */
| 299 |
FILE *fp;
| 300 |
char *fn;
| 301 |
int ln;
| 302 |
| 303 |
static char inpbuf[MAXLINE];
| 304 |
| 305 |
infp = fp;
| 306 |
linbuf = inpbuf;
| 307 |
infile = fn;
| 308 |
lineno = ln;
| 309 |
linepos = 0;
| 310 |
inpbuf[0] = '\0';
| 311 |
scan();
| 312 |
| 313 |
| 314 |
| 315 |
initstr(s, fn, ln) /* prepare input string */
| 316 |
char *s;
| 317 |
char *fn;
| 318 |
int ln;
| 319 |
| 320 |
infp = NULL;
| 321 |
infile = fn;
| 322 |
lineno = ln;
| 323 |
linbuf = s;
| 324 |
linepos = 0;
| 325 |
scan();
| 326 |
| 327 |
| 328 |
| 329 |
getscanpos(fnp, lnp, spp, fpp) /* return current scan position */
| 330 |
char **fnp;
| 331 |
int *lnp;
| 332 |
char **spp;
| 333 |
FILE **fpp;
| 334 |
| 335 |
if (fnp != NULL) *fnp = infile;
| 336 |
if (lnp != NULL) *lnp = lineno;
| 337 |
if (spp != NULL) *spp = linbuf+linepos;
| 338 |
if (fpp != NULL) *fpp = infp;
| 339 |
| 340 |
| 341 |
| 342 |
int
| 343 |
scan() /* scan next character, return literal next */
| 344 |
| 345 |
register int lnext = 0;
| 346 |
| 347 |
do {
| 348 |
if (linbuf[linepos] == '\0')
| 349 |
if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL)
| 350 |
nextc = EOF;
| 351 |
else {
| 352 |
nextc = linbuf[0];
| 353 |
lineno++;
| 354 |
linepos = 1;
| 355 |
| 356 |
else
| 357 |
nextc = linbuf[linepos++];
| 358 |
if (!lnext)
| 359 |
lnext = nextc;
| 360 |
if (nextc == '{') {
| 361 |
scan();
| 362 |
while (nextc != '}')
| 363 |
if (nextc == EOF)
| 364 |
syntax("'}' expected");
| 365 |
else
| 366 |
scan();
| 367 |
scan();
| 368 |
| 369 |
} while (isspace(nextc));
| 370 |
return(lnext);
| 371 |
| 372 |
| 373 |
| 374 |
char *
| 375 |
ltoa(l) /* convert long to ascii */
| 376 |
long l;
| 377 |
| 378 |
static char buf[16];
| 379 |
register char *cp;
| 380 |
int neg = 0;
| 381 |
| 382 |
if (l == 0)
| 383 |
return("0");
| 384 |
if (l < 0) {
| 385 |
l = -l;
| 386 |
neg++;
| 387 |
| 388 |
cp = buf + sizeof(buf);
| 389 |
*--cp = '\0';
| 390 |
while (l) {
| 391 |
*--cp = l % 10 + '0';
| 392 |
l /= 10;
| 393 |
| 394 |
if (neg)
| 395 |
*--cp = '-';
| 396 |
return(cp);
| 397 |
| 398 |
| 399 |
| 400 |
syntax(err) /* report syntax error and quit */
| 401 |
char *err;
| 402 |
| 403 |
register int i;
| 404 |
| 405 |
if (infile != NULL || lineno != 0) {
| 406 |
if (infile != NULL) eputs(infile);
| 407 |
if (lineno != 0) {
| 408 |
eputs(infile != NULL ? ", line " : "line ");
| 409 |
eputs(ltoa((long)lineno));
| 410 |
| 411 |
eputs(":\n");
| 412 |
| 413 |
eputs(linbuf);
| 414 |
if (linbuf[strlen(linbuf)-1] != '\n')
| 415 |
eputs("\n");
| 416 |
for (i = 0; i < linepos-1; i++)
| 417 |
eputs(linbuf[i] == '\t' ? "\t" : " ");
| 418 |
eputs("^ ");
| 419 |
eputs(err);
| 420 |
eputs("\n");
| 421 |
quit(1);
| 422 |
| 423 |
| 424 |
| 425 |
addekid(ep, ekid) /* add a child to ep */
| 426 |
| 427 |
EPNODE *ekid;
| 428 |
| 429 |
if (ep->v.kid == NULL)
| 430 |
ep->v.kid = ekid;
| 431 |
else {
| 432 |
for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling)
| 433 |
| 434 |
ep->sibling = ekid;
| 435 |
| 436 |
ekid->sibling = NULL;
| 437 |
| 438 |
| 439 |
| 440 |
| 441 |
char *
| 442 |
getname() /* scan an identifier */
| 443 |
| 444 |
static char str[MAXWORD+1];
| 445 |
register int i, lnext;
| 446 |
| 447 |
lnext = nextc;
| 448 |
for (i = 0; i < MAXWORD && isid(lnext); i++, lnext = scan())
| 449 |
str[i] = lnext;
| 450 |
str[i] = '\0';
| 451 |
while (isid(lnext)) /* skip rest of name */
| 452 |
lnext = scan();
| 453 |
| 454 |
return(str);
| 455 |
| 456 |
#endif
| 457 |
| 458 |
| 459 |
int
| 460 |
getinum() /* scan a positive integer */
| 461 |
| 462 |
register int n, lnext;
| 463 |
| 464 |
n = 0;
| 465 |
lnext = nextc;
| 466 |
while (isdigit(lnext)) {
| 467 |
n = n * 10 + lnext - '0';
| 468 |
lnext = scan();
| 469 |
| 470 |
return(n);
| 471 |
| 472 |
| 473 |
| 474 |
double
| 475 |
getnum() /* scan a positive float */
| 476 |
| 477 |
| 478 |
| 479 |
| 480 |
i = 0;
| 481 |
lnext = nextc;
| 482 |
while (isdigit(lnext) && i < MAXWORD) {
| 483 |
str[i++] = lnext;
| 484 |
lnext = scan();
| 485 |
| 486 |
if (lnext == '.' && i < MAXWORD) {
| 487 |
str[i++] = lnext;
| 488 |
lnext = scan();
| 489 |
| 490 |
str[i++] = lnext;
| 491 |
lnext = scan();
| 492 |
| 493 |
| 494 |
if ((lnext == 'e' || lnext == 'E') && i < MAXWORD) {
| 495 |
str[i++] = lnext;
| 496 |
lnext = scan();
| 497 |
if ((lnext == '-' || lnext == '+') && i < MAXWORD) {
| 498 |
str[i++] = lnext;
| 499 |
lnext = scan();
| 500 |
| 501 |
| 502 |
str[i++] = lnext;
| 503 |
lnext = scan();
| 504 |
| 505 |
| 506 |
str[i] = '\0';
| 507 |
| 508 |
return(atof(str));
| 509 |
| 510 |
| 511 |
| 512 |
EPNODE *
| 513 |
getE1() /* E1 -> E1 ADDOP E2 */
| 514 |
/* E2 */
| 515 |
| 516 |
register EPNODE *ep1, *ep2;
| 517 |
| 518 |
ep1 = getE2();
| 519 |
while (nextc == '+' || nextc == '-') {
| 520 |
ep2 = newnode();
| 521 |
ep2->type = nextc;
| 522 |
scan();
| 523 |
addekid(ep2, ep1);
| 524 |
addekid(ep2, getE2());
| 525 |
#ifdef RCONST
| 526 |
if (ep1->type == NUM && ep1->sibling->type == NUM)
| 527 |
ep2 = rconst(ep2);
| 528 |
#endif
| 529 |
ep1 = ep2;
| 530 |
| 531 |
return(ep1);
| 532 |
| 533 |
| 534 |
| 535 |
EPNODE *
| 536 |
getE2() /* E2 -> E2 MULOP E3 */
| 537 |
/* E3 */
| 538 |
| 539 |
| 540 |
| 541 |
ep1 = getE3();
| 542 |
while (nextc == '*' || nextc == '/') {
| 543 |
ep2 = newnode();
| 544 |
ep2->type = nextc;
| 545 |
scan();
| 546 |
addekid(ep2, ep1);
| 547 |
addekid(ep2, getE3());
| 548 |
#ifdef RCONST
| 549 |
| 550 |
ep2 = rconst(ep2);
| 551 |
#endif
| 552 |
ep1 = ep2;
| 553 |
| 554 |
return(ep1);
| 555 |
| 556 |
| 557 |
| 558 |
EPNODE *
| 559 |
getE3() /* E3 -> E4 ^ E3 */
| 560 |
/* E4 */
| 561 |
| 562 |
| 563 |
| 564 |
ep1 = getE4();
| 565 |
if (nextc == '^') {
| 566 |
ep2 = newnode();
| 567 |
ep2->type = nextc;
| 568 |
scan();
| 569 |
addekid(ep2, ep1);
| 570 |
| 571 |
#ifdef RCONST
| 572 |
| 573 |
ep2 = rconst(ep2);
| 574 |
#endif
| 575 |
return(ep2);
| 576 |
| 577 |
return(ep1);
| 578 |
| 579 |
| 580 |
| 581 |
EPNODE *
| 582 |
getE4() /* E4 -> ADDOP E5 */
| 583 |
/* E5 */
| 584 |
| 585 |
| 586 |
| 587 |
if (nextc == '-') {
| 588 |
scan();
| 589 |
ep2 = getE5();
| 590 |
if (ep2->type == NUM) {
| 591 |
ep2->v.num = -ep2->v.num;
| 592 |
return(ep2);
| 593 |
| 594 |
if (ep2->type == UMINUS) { /* don't generate -(-E5) */
| 595 |
efree((char *)ep2);
| 596 |
return(ep2->v.kid);
| 597 |
| 598 |
ep1 = newnode();
| 599 |
ep1->type = UMINUS;
| 600 |
addekid(ep1, ep2);
| 601 |
return(ep1);
| 602 |
| 603 |
if (nextc == '+')
| 604 |
scan();
| 605 |
return(getE5());
| 606 |
| 607 |
| 608 |
| 609 |
EPNODE *
| 610 |
getE5() /* E5 -> (E1) */
| 611 |
/* VAR */
| 612 |
/* NUM */
| 613 |
/* $N */
| 614 |
/* FUNC(E1,..) */
| 615 |
/* ARG */
| 616 |
| 617 |
int i;
| 618 |
char *nam;
| 619 |
| 620 |
| 621 |
if (nextc == '(') {
| 622 |
scan();
| 623 |
ep1 = getE1();
| 624 |
if (nextc != ')')
| 625 |
syntax("')' expected");
| 626 |
scan();
| 627 |
return(ep1);
| 628 |
| 629 |
| 630 |
#ifdef INCHAN
| 631 |
if (nextc == '$') {
| 632 |
scan();
| 633 |
ep1 = newnode();
| 634 |
ep1->type = CHAN;
| 635 |
ep1->v.chan = getinum();
| 636 |
return(ep1);
| 637 |
| 638 |
#endif
| 639 |
| 640 |
| 641 |
if (isalpha(nextc) || nextc == CNTXMARK) {
| 642 |
nam = getname();
| 643 |
| 644 |
ep1 = NULL;
| 645 |
if (curfunc != NULL)
| 646 |
for (i = 1, ep2 = curfunc->v.kid->sibling;
| 647 |
ep2 != NULL; i++, ep2 = ep2->sibling)
| 648 |
if (!strcmp(ep2->v.name, nam)) {
| 649 |
ep1 = newnode();
| 650 |
ep1->type = ARG;
| 651 |
ep1->v.chan = i;
| 652 |
break;
| 653 |
| 654 |
if (ep1 == NULL)
| 655 |
#endif
| 656 |
| 657 |
ep1 = newnode();
| 658 |
ep1->type = VAR;
| 659 |
ep1->v.ln = varinsert(nam);
| 660 |
| 661 |
#ifdef FUNCTION
| 662 |
if (nextc == '(') {
| 663 |
ep2 = newnode();
| 664 |
ep2->type = FUNC;
| 665 |
addekid(ep2, ep1);
| 666 |
ep1 = ep2;
| 667 |
do {
| 668 |
scan();
| 669 |
addekid(ep1, getE1());
| 670 |
} while (nextc == ',');
| 671 |
if (nextc != ')')
| 672 |
| 673 |
scan();
| 674 |
| 675 |
#ifndef VARIABLE
| 676 |
else
| 677 |
syntax("'(' expected");
| 678 |
#endif
| 679 |
#endif
| 680 |
#ifdef RCONST
| 681 |
if (isconstvar(ep1))
| 682 |
ep1 = rconst(ep1);
| 683 |
#endif
| 684 |
return(ep1);
| 685 |
| 686 |
#endif
| 687 |
| 688 |
if (isdecimal(nextc)) {
| 689 |
ep1 = newnode();
| 690 |
ep1->type = NUM;
| 691 |
ep1->v.num = getnum();
| 692 |
return(ep1);
| 693 |
| 694 |
| 695 |
| 696 |
| 697 |
| 698 |
#ifdef RCONST
| 699 |
EPNODE *
| 700 |
rconst(epar) /* reduce a constant expression */
| 701 |
| 702 |
| 703 |
| 704 |
| 705 |
ep = newnode();
| 706 |
ep->type = NUM;
| 707 |
errno = 0;
| 708 |
ep->v.num = evalue(epar);
| 709 |
if (errno)
| 710 |
syntax("bad constant expression");
| 711 |
epfree(epar);
| 712 |
| 713 |
return(ep);
| 714 |
| 715 |
| 716 |
| 717 |
isconstvar(ep) /* is ep linked to a constant expression? */
| 718 |
| 719 |
| 720 |
#ifdef VARIABLE
| 721 |
register EPNODE *ep1;
| 722 |
#ifdef FUNCTION
| 723 |
| 724 |
if (ep->type == FUNC) {
| 725 |
if (!isconstfun(ep->v.kid))
| 726 |
return(0);
| 727 |
for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling)
| 728 |
if (ep1->type != NUM && !isconstfun(ep1))
| 729 |
return(0);
| 730 |
return(1);
| 731 |
| 732 |
#endif
| 733 |
if (ep->type != VAR)
| 734 |
return(0);
| 735 |
ep1 = ep->v.ln->def;
| 736 |
if (ep1 == NULL || ep1->type != ':')
| 737 |
return(0);
| 738 |
#ifdef FUNCTION
| 739 |
if (ep1->v.kid->type != SYM)
| 740 |
return(0);
| 741 |
#endif
| 742 |
return(1);
| 743 |
#else
| 744 |
return(ep->type == FUNC);
| 745 |
#endif
| 746 |
| 747 |
| 748 |
| 749 |
#if defined(FUNCTION) && defined(VARIABLE)
| 750 |
isconstfun(ep) /* is ep linked to a constant function? */
| 751 |
| 752 |
| 753 |
register EPNODE *dp;
| 754 |
register LIBR *lp;
| 755 |
| 756 |
| 757 |
return(0);
| 758 |
if ((dp = ep->v.ln->def) != NULL && dp->v.kid->type == FUNC)
| 759 |
return(dp->type == ':');
| 760 |
if ((lp = ep->v.ln->lib) != NULL)
| 761 |
return(lp->atyp == ':');
| 762 |
return(0);
| 763 |
| 764 |
#endif
| 765 |
#endif
