| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: calexpr.c,v 2.55 2025/12/06 04:07:05 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Compute data values using expression parser
| 6 |
| 7 |
* 7/1/85 Greg Ward
| 8 |
| 9 |
* 11/11/85 Made channel input conditional with (INCHAN) compiles.
| 10 |
| 11 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION).
| 12 |
| 13 |
* 1/29/87 Made variables conditional (VARIABLE)
| 14 |
| 15 |
* 5/19/88 Added constant subexpression elimination (RCONST)
| 16 |
| 17 |
* 2/19/03 Eliminated conditional compiles in favor of esupport extern.
| 18 |
| 19 |
| 20 |
#include "copyright.h"
| 21 |
| 22 |
#include <ctype.h>
| 23 |
#include <errno.h>
| 24 |
#include <math.h>
| 25 |
#include <stdlib.h>
| 26 |
| 27 |
#include "rtmisc.h"
| 28 |
#include "rtio.h"
| 29 |
#include "rterror.h"
| 30 |
#include "calcomp.h"
| 31 |
| 32 |
#define MAXLINE 256 /* maximum line length */
| 33 |
| 34 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
| 35 |
| 36 |
#define isdecimal(c) (isdigit(c) | ((c) == '.'))
| 37 |
| 38 |
#define envalue(ep) ((ep)->type==NUM ? (ep)->v.num : evalue(ep))
| 39 |
| 40 |
static double euminus(EPNODE *), enumber(EPNODE *);
| 41 |
static double echannel(EPNODE *);
| 42 |
static double eadd(EPNODE *), esubtr(EPNODE *),
| 43 |
emult(EPNODE *), edivi(EPNODE *),
| 44 |
epow(EPNODE *);
| 45 |
static double ebotch(EPNODE *);
| 46 |
| 47 |
unsigned int esupport = /* what to support */
| 48 |
E_VARIABLE | E_FUNCTION ;
| 49 |
| 50 |
int eofc = 0; /* optional end-of-file character */
| 51 |
int nextc; /* lookahead character */
| 52 |
| 53 |
double (*eoper[])(EPNODE *) = { /* expression operations */
| 54 |
ebotch,
| 55 |
evariable,
| 56 |
enumber,
| 57 |
euminus,
| 58 |
echannel,
| 59 |
efunc,
| 60 |
eargument,
| 61 |
ebotch,
| 62 |
ebotch,
| 63 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
| 64 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
| 65 |
emult,
| 66 |
eadd,
| 67 |
0,
| 68 |
esubtr,
| 69 |
0,
| 70 |
edivi,
| 71 |
| 72 |
ebotch,
| 73 |
0,0,
| 74 |
ebotch,
| 75 |
| 76 |
| 77 |
epow,
| 78 |
| 79 |
| 80 |
static FILE *infp; /* input file pointer */
| 81 |
static char *linbuf; /* line buffer */
| 82 |
static char *infile; /* input file name */
| 83 |
static int lineno; /* input line number */
| 84 |
static int linepos; /* position in buffer */
| 85 |
| 86 |
| 87 |
EPNODE *
| 88 |
eparse( /* parse an expression string */
| 89 |
char *expr
| 90 |
| 91 |
| 92 |
EPNODE *ep;
| 93 |
| 94 |
initstr(expr, NULL, 0);
| 95 |
ecurfunc = NULL;
| 96 |
ep = getE1();
| 97 |
if (nextc != EOF)
| 98 |
esyntax("unexpected character");
| 99 |
return(ep);
| 100 |
| 101 |
| 102 |
| 103 |
double
| 104 |
eval( /* evaluate an expression string */
| 105 |
char *expr
| 106 |
| 107 |
| 108 |
int prev_support = esupport;
| 109 |
EPNODE *ep;
| 110 |
double rval;
| 111 |
| 112 |
esupport &= ~E_RCONST; /* don't bother reducing constant expr */
| 113 |
ep = eparse(expr);
| 114 |
esupport = prev_support; /* as you were */
| 115 |
rval = evalue(ep);
| 116 |
epfree(ep,1);
| 117 |
return(rval);
| 118 |
| 119 |
| 120 |
| 121 |
int
| 122 |
epcmp( /* compare two expressions for equivalence */
| 123 |
EPNODE *ep1,
| 124 |
EPNODE *ep2
| 125 |
| 126 |
| 127 |
double d;
| 128 |
| 129 |
if (ep1->type != ep2->type)
| 130 |
return(1);
| 131 |
| 132 |
switch (ep1->type) {
| 133 |
| 134 |
case VAR:
| 135 |
return(ep1->v.ln != ep2->v.ln);
| 136 |
| 137 |
case NUM:
| 138 |
if (ep2->v.num == 0)
| 139 |
return(ep1->v.num != 0);
| 140 |
d = ep1->v.num / ep2->v.num;
| 141 |
return((d > 1.000000000001) | (d < 0.999999999999));
| 142 |
| 143 |
case CHAN:
| 144 |
case ARG:
| 145 |
return(ep1->v.chan != ep2->v.chan);
| 146 |
| 147 |
case '=':
| 148 |
case ':':
| 149 |
return(epcmp(ep1->v.kid->sibling, ep2->v.kid->sibling));
| 150 |
| 151 |
case CLKT:
| 152 |
case SYM: /* should never get this one */
| 153 |
return(0);
| 154 |
| 155 |
default:
| 156 |
ep1 = ep1->v.kid;
| 157 |
ep2 = ep2->v.kid;
| 158 |
while (ep1 != NULL) {
| 159 |
if (ep2 == NULL)
| 160 |
return(1);
| 161 |
if (epcmp(ep1, ep2))
| 162 |
return(1);
| 163 |
ep1 = ep1->sibling;
| 164 |
ep2 = ep2->sibling;
| 165 |
| 166 |
return(ep2 != NULL);
| 167 |
| 168 |
| 169 |
| 170 |
| 171 |
void
| 172 |
epfree( /* free a parse tree */
| 173 |
EPNODE *epar,
| 174 |
int frep
| 175 |
| 176 |
| 177 |
EPNODE *ep;
| 178 |
| 179 |
switch (epar->type) {
| 180 |
| 181 |
case VAR:
| 182 |
varfree(epar->v.ln);
| 183 |
break;
| 184 |
| 185 |
case SYM:
| 186 |
freestr(epar->v.name);
| 187 |
break;
| 188 |
| 189 |
case NUM:
| 190 |
case CHAN:
| 191 |
case ARG:
| 192 |
case CLKT:
| 193 |
break;
| 194 |
| 195 |
default:
| 196 |
if (epar->nkids < 0) {
| 197 |
ep = epar->v.kid - epar->nkids;
| 198 |
while (ep > epar->v.kid)
| 199 |
epfree(--ep, 0);
| 200 |
efree(ep); /* free array space */
| 201 |
} else
| 202 |
while ((ep = epar->v.kid) != NULL) {
| 203 |
epar->v.kid = ep->sibling;
| 204 |
epfree(ep, 1);
| 205 |
| 206 |
break;
| 207 |
| 208 |
| 209 |
if (frep)
| 210 |
efree(epar);
| 211 |
else
| 212 |
memset(epar, 0, sizeof(EPNODE));
| 213 |
| 214 |
| 215 |
| 216 |
static void
| 217 |
epflatten( /* flatten hierarchies for '+', '*' */
| 218 |
EPNODE *epar
| 219 |
| 220 |
| 221 |
EPNODE *ep, *ep1;
| 222 |
double combined;
| 223 |
| 224 |
if (epar->nkids <= 0) /* can't handle array allocations */
| 225 |
return;
| 226 |
| 227 |
for (ep = epar->v.kid; ep != NULL; ep = ep->sibling)
| 228 |
while ((ep->type == epar->type) & (ep->nkids > 0)) {
| 229 |
ep1 = ep->v.kid;
| 230 |
while (ep1->sibling != NULL)
| 231 |
ep1 = ep1->sibling;
| 232 |
ep1->sibling = ep->sibling;
| 233 |
epar->nkids += ep->nkids - 1;
| 234 |
ep1 = ep->v.kid;
| 235 |
*ep = *ep1;
| 236 |
efree(ep1); /* not epfree()! */
| 237 |
| 238 |
if (!(esupport & E_RCONST))
| 239 |
return;
| 240 |
ep1 = NULL; /* combine constants in sum/product */
| 241 |
| 242 |
if (ep->type == NUM) {
| 243 |
if (ep1 == NULL) combined = (ep1 = ep)->v.num;
| 244 |
else if (epar->type == '+') combined += ep->v.num;
| 245 |
else /* epar->type=='*' */ combined *= ep->v.num;
| 246 |
| 247 |
if (ep1 == NULL)
| 248 |
return;
| 249 |
ep1->v.num = combined; /* assumes commutative property, also */
| 250 |
| 251 |
if (ep1->sibling->type == NUM) {
| 252 |
ep = ep1->sibling;
| 253 |
| 254 |
epar->nkids--;
| 255 |
efree(ep); /* drop subsumed constant */
| 256 |
} else
| 257 |
ep1 = ep1->sibling;
| 258 |
| 259 |
if (epar->nkids == 1) { /* late constant expression? */
| 260 |
ep = epar->v.kid;
| 261 |
*epar = *ep;
| 262 |
efree(ep);
| 263 |
| 264 |
| 265 |
| 266 |
| 267 |
void
| 268 |
epoptimize( /* flatten operations, lists -> arrays */
| 269 |
EPNODE *epar
| 270 |
| 271 |
| 272 |
EPNODE *ep;
| 273 |
| 274 |
if ((epar->type == '+') | (epar->type == '*'))
| 275 |
epflatten(epar); /* flatten associative operations */
| 276 |
| 277 |
if (epar->nkids) /* do children if any */
| 278 |
| 279 |
epoptimize(ep);
| 280 |
| 281 |
if (epar->nkids > 4) { /* make list into array if > 4 kids */
| 282 |
int n = 1;
| 283 |
epar->v.kid = (EPNODE *)erealloc(epar->v.kid,
| 284 |
sizeof(EPNODE)*epar->nkids);
| 285 |
while (n < epar->nkids) {
| 286 |
ep = epar->v.kid[n-1].sibling;
| 287 |
epar->v.kid[n] = *ep;
| 288 |
efree(ep); /* not epfree()! */
| 289 |
epar->v.kid[n-1].sibling = epar->v.kid + n;
| 290 |
n++;
| 291 |
| 292 |
epar->nkids = -n;
| 293 |
| 294 |
| 295 |
| 296 |
/* the following used to be a switch */
| 297 |
static double
| 298 |
enumber(
| 299 |
EPNODE *ep
| 300 |
| 301 |
| 302 |
return(ep->v.num);
| 303 |
| 304 |
| 305 |
static double
| 306 |
euminus(
| 307 |
EPNODE *ep
| 308 |
| 309 |
| 310 |
EPNODE *ep1 = ep->v.kid;
| 311 |
| 312 |
return(-evalue(ep1));
| 313 |
| 314 |
| 315 |
static double
| 316 |
echannel(
| 317 |
EPNODE *ep
| 318 |
| 319 |
| 320 |
return(chanvalue(ep->v.chan));
| 321 |
| 322 |
| 323 |
static double
| 324 |
eadd(
| 325 |
EPNODE *ep
| 326 |
| 327 |
| 328 |
double sum = 0;
| 329 |
| 330 |
| 331 |
do
| 332 |
sum += envalue(ep1);
| 333 |
while ((ep1 = ep1->sibling) != NULL);
| 334 |
| 335 |
return(sum);
| 336 |
| 337 |
| 338 |
static double
| 339 |
esubtr(
| 340 |
EPNODE *ep
| 341 |
| 342 |
| 343 |
| 344 |
EPNODE *ep2 = ep1->sibling;
| 345 |
| 346 |
return(envalue(ep1) - envalue(ep2));
| 347 |
| 348 |
| 349 |
static double
| 350 |
emult(
| 351 |
EPNODE *ep
| 352 |
| 353 |
| 354 |
double prod = 1;
| 355 |
| 356 |
| 357 |
do
| 358 |
prod *= envalue(ep1);
| 359 |
| 360 |
| 361 |
return(prod);
| 362 |
| 363 |
| 364 |
static double
| 365 |
edivi(
| 366 |
EPNODE *ep
| 367 |
| 368 |
| 369 |
| 370 |
double den = evalue(ep1->sibling);
| 371 |
| 372 |
if (den == 0.0) {
| 373 |
wputs("Division by zero\n");
| 374 |
errno = ERANGE;
| 375 |
return(0.0);
| 376 |
| 377 |
return(envalue(ep1) / den);
| 378 |
| 379 |
| 380 |
static double
| 381 |
epow(
| 382 |
EPNODE *ep
| 383 |
| 384 |
| 385 |
| 386 |
double d;
| 387 |
int lasterrno;
| 388 |
| 389 |
lasterrno = errno;
| 390 |
errno = 0;
| 391 |
d = pow(evalue(ep1), evalue(ep1->sibling));
| 392 |
#ifdef isnan
| 393 |
if (errno == 0) {
| 394 |
if (isnan(d))
| 395 |
errno = EDOM;
| 396 |
else if (isinf(d))
| 397 |
errno = ERANGE;
| 398 |
| 399 |
#endif
| 400 |
if ((errno == EDOM) | (errno == ERANGE)) {
| 401 |
wputs("Illegal power\n");
| 402 |
return(0.0);
| 403 |
| 404 |
errno = lasterrno;
| 405 |
return(d);
| 406 |
| 407 |
| 408 |
static double
| 409 |
ebotch(
| 410 |
EPNODE *ep
| 411 |
| 412 |
| 413 |
eputs("Bad expression!\n");
| 414 |
quit(1);
| 415 |
return 0.0; /* pro forma return */
| 416 |
| 417 |
| 418 |
| 419 |
EPNODE *
| 420 |
ekid( /* return pointer to a node's nth kid */
| 421 |
EPNODE *ep,
| 422 |
int n
| 423 |
| 424 |
| 425 |
if (ep->nkids < 0) { /* allocated array? */
| 426 |
if (n >= -ep->nkids)
| 427 |
return(NULL);
| 428 |
return(ep->v.kid + n);
| 429 |
| 430 |
ep = ep->v.kid; /* else get from list */
| 431 |
while (n-- > 0)
| 432 |
if ((ep = ep->sibling) == NULL)
| 433 |
break;
| 434 |
return(ep);
| 435 |
| 436 |
| 437 |
| 438 |
void
| 439 |
initfile( /* prepare input file */
| 440 |
FILE *fp,
| 441 |
char *fn,
| 442 |
int ln
| 443 |
| 444 |
| 445 |
static char inpbuf[MAXLINE];
| 446 |
| 447 |
infp = fp;
| 448 |
linbuf = inpbuf;
| 449 |
infile = fn;
| 450 |
lineno = ln;
| 451 |
linepos = 0;
| 452 |
inpbuf[0] = '\0';
| 453 |
escan();
| 454 |
| 455 |
| 456 |
| 457 |
void
| 458 |
initstr( /* prepare input string */
| 459 |
char *s,
| 460 |
char *fn,
| 461 |
int ln
| 462 |
| 463 |
| 464 |
infp = NULL;
| 465 |
infile = fn;
| 466 |
lineno = ln;
| 467 |
linbuf = s;
| 468 |
linepos = 0;
| 469 |
escan();
| 470 |
| 471 |
| 472 |
| 473 |
void
| 474 |
getscanpos( /* return current scan position */
| 475 |
char **fnp,
| 476 |
int *lnp,
| 477 |
char **spp,
| 478 |
FILE **fpp
| 479 |
| 480 |
| 481 |
if (fnp != NULL) *fnp = infile;
| 482 |
if (lnp != NULL) *lnp = lineno;
| 483 |
if (spp != NULL) *spp = linbuf+linepos;
| 484 |
if (fpp != NULL) *fpp = infp;
| 485 |
| 486 |
| 487 |
| 488 |
int
| 489 |
escan(void) /* scan next character, return literal next */
| 490 |
| 491 |
int lnext = 0;
| 492 |
| 493 |
do {
| 494 |
if (linbuf[linepos] == '\0')
| 495 |
if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL)
| 496 |
nextc = EOF;
| 497 |
else {
| 498 |
nextc = linbuf[0];
| 499 |
lineno++;
| 500 |
linepos = 1;
| 501 |
| 502 |
else
| 503 |
nextc = linbuf[linepos++];
| 504 |
if (!lnext)
| 505 |
lnext = nextc;
| 506 |
if (nextc == eofc) {
| 507 |
nextc = EOF;
| 508 |
break;
| 509 |
| 510 |
if (nextc == '{') {
| 511 |
escan();
| 512 |
while (nextc != '}')
| 513 |
if (nextc == EOF)
| 514 |
esyntax("'}' expected");
| 515 |
else
| 516 |
escan();
| 517 |
escan();
| 518 |
| 519 |
} while (isspace(nextc));
| 520 |
return(lnext);
| 521 |
| 522 |
| 523 |
| 524 |
char *
| 525 |
long2ascii( /* convert long to ascii */
| 526 |
long l
| 527 |
| 528 |
| 529 |
static char buf[16];
| 530 |
char *cp;
| 531 |
int neg = 0;
| 532 |
| 533 |
if (l == 0)
| 534 |
return("0");
| 535 |
if (l < 0) {
| 536 |
l = -l;
| 537 |
neg++;
| 538 |
| 539 |
cp = buf + sizeof(buf);
| 540 |
*--cp = '\0';
| 541 |
while (l) {
| 542 |
*--cp = l % 10 + '0';
| 543 |
l /= 10;
| 544 |
| 545 |
if (neg)
| 546 |
*--cp = '-';
| 547 |
return(cp);
| 548 |
| 549 |
| 550 |
| 551 |
void
| 552 |
esyntax( /* report syntax error and quit */
| 553 |
char *err
| 554 |
| 555 |
| 556 |
int i;
| 557 |
| 558 |
if ((infile != NULL) | (lineno != 0)) {
| 559 |
if (infile != NULL) eputs(infile);
| 560 |
if (lineno != 0) {
| 561 |
eputs(infile != NULL ? ", line " : "line ");
| 562 |
eputs(long2ascii((long)lineno));
| 563 |
| 564 |
eputs(":\n");
| 565 |
| 566 |
eputs(linbuf);
| 567 |
if (linbuf[strlen(linbuf)-1] != '\n')
| 568 |
eputs("\n");
| 569 |
for (i = 0; i < linepos-1; i++)
| 570 |
eputs(linbuf[i] == '\t' ? "\t" : " ");
| 571 |
eputs("^ ");
| 572 |
eputs(err);
| 573 |
eputs("\n");
| 574 |
quit(1);
| 575 |
| 576 |
| 577 |
| 578 |
void
| 579 |
addekid( /* add a child to ep */
| 580 |
EPNODE *ep,
| 581 |
EPNODE *ek
| 582 |
| 583 |
| 584 |
| 585 |
eputs("Cannot add kid to EPNODE array\n");
| 586 |
quit(1);
| 587 |
| 588 |
ep->nkids++;
| 589 |
if (ep->v.kid == NULL)
| 590 |
ep->v.kid = ek;
| 591 |
else {
| 592 |
for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling)
| 593 |
| 594 |
ep->sibling = ek;
| 595 |
| 596 |
ek->sibling = NULL; /* shouldn't be necessary */
| 597 |
| 598 |
| 599 |
| 600 |
char *
| 601 |
getname(void) /* scan an identifier */
| 602 |
| 603 |
static char str[RMAXWORD+1];
| 604 |
int i, lnext;
| 605 |
| 606 |
lnext = nextc;
| 607 |
for (i = 0; i < RMAXWORD && isid(lnext); i++, lnext = escan())
| 608 |
str[i] = lnext;
| 609 |
str[i] = '\0';
| 610 |
while (isid(lnext)) /* skip rest of name */
| 611 |
lnext = escan();
| 612 |
| 613 |
return(str);
| 614 |
| 615 |
| 616 |
| 617 |
int
| 618 |
getinum(void) /* scan a positive integer */
| 619 |
| 620 |
int n, lnext;
| 621 |
| 622 |
n = 0;
| 623 |
lnext = nextc;
| 624 |
while (isdigit(lnext)) {
| 625 |
n = n * 10 + lnext - '0';
| 626 |
lnext = escan();
| 627 |
| 628 |
return(n);
| 629 |
| 630 |
| 631 |
| 632 |
double
| 633 |
getnum(void) /* scan a positive float */
| 634 |
| 635 |
int i, lnext;
| 636 |
| 637 |
| 638 |
i = 0;
| 639 |
lnext = nextc;
| 640 |
while (isdigit(lnext) && i < RMAXWORD) {
| 641 |
str[i++] = lnext;
| 642 |
lnext = escan();
| 643 |
| 644 |
if ((lnext == '.') & (i < RMAXWORD)) {
| 645 |
str[i++] = lnext;
| 646 |
lnext = escan();
| 647 |
if (i == 1 && !isdigit(lnext))
| 648 |
esyntax("badly formed number");
| 649 |
| 650 |
str[i++] = lnext;
| 651 |
lnext = escan();
| 652 |
| 653 |
| 654 |
if ((lnext == 'e') | (lnext == 'E') && i < RMAXWORD) {
| 655 |
str[i++] = lnext;
| 656 |
lnext = escan();
| 657 |
if ((lnext == '-') | (lnext == '+') && i < RMAXWORD) {
| 658 |
str[i++] = lnext;
| 659 |
lnext = escan();
| 660 |
| 661 |
if (!isdigit(lnext))
| 662 |
esyntax("missing exponent");
| 663 |
| 664 |
str[i++] = lnext;
| 665 |
lnext = escan();
| 666 |
| 667 |
| 668 |
str[i] = '\0';
| 669 |
| 670 |
return(atof(str));
| 671 |
| 672 |
| 673 |
| 674 |
EPNODE *
| 675 |
getE1(void) /* E1 -> E1 ADDOP E2 */
| 676 |
/* E2 */
| 677 |
| 678 |
EPNODE *ep1, *ep2;
| 679 |
| 680 |
ep1 = getE2();
| 681 |
while ((nextc == '+') | (nextc == '-')) {
| 682 |
ep2 = newnode();
| 683 |
ep2->type = nextc;
| 684 |
escan();
| 685 |
addekid(ep2, ep1);
| 686 |
addekid(ep2, getE2());
| 687 |
if (esupport&E_RCONST && ep1->sibling->type == NUM) {
| 688 |
if (ep1->type == NUM) {
| 689 |
ep2 = rconst(ep2);
| 690 |
} else if (ep2->type == '-') {
| 691 |
ep1->sibling->v.num *= -1;
| 692 |
ep2->type = '+'; /* associative&commutative */
| 693 |
| 694 |
| 695 |
ep1 = ep2;
| 696 |
| 697 |
return(ep1);
| 698 |
| 699 |
| 700 |
| 701 |
EPNODE *
| 702 |
getE2(void) /* E2 -> E2 MULOP E3 */
| 703 |
/* E3 */
| 704 |
| 705 |
EPNODE *ep1, *ep2;
| 706 |
| 707 |
ep1 = getE3();
| 708 |
while ((nextc == '*') | (nextc == '/')) {
| 709 |
ep2 = newnode();
| 710 |
ep2->type = nextc;
| 711 |
escan();
| 712 |
addekid(ep2, ep1);
| 713 |
addekid(ep2, getE3());
| 714 |
if (esupport&E_RCONST) {
| 715 |
EPNODE *ep3 = ep1->sibling;
| 716 |
if ((ep1->type == NUM) & (ep3->type == NUM)) {
| 717 |
ep2 = rconst(ep2);
| 718 |
} else if (ep3->type == NUM) {
| 719 |
if (ep2->type == '/') {
| 720 |
if (ep3->v.num == 0)
| 721 |
esyntax("divide by zero constant");
| 722 |
ep2->type = '*'; /* for speed */
| 723 |
ep3->v.num = 1./ep3->v.num;
| 724 |
} else if (ep3->v.num == 0) {
| 725 |
ep1->sibling = NULL; /* (E2 * 0) */
| 726 |
epfree(ep2,1);
| 727 |
ep2 = ep3;
| 728 |
| 729 |
} else if (ep1->type == NUM && ep1->v.num == 0) {
| 730 |
epfree(ep3,1); /* (0 * E3) or (0 / E3) */
| 731 |
| 732 |
efree(ep2);
| 733 |
ep2 = ep1;
| 734 |
| 735 |
| 736 |
ep1 = ep2;
| 737 |
| 738 |
return(ep1);
| 739 |
| 740 |
| 741 |
| 742 |
EPNODE *
| 743 |
getE3(void) /* E3 -> E4 ^ E3 */
| 744 |
/* E4 */
| 745 |
| 746 |
EPNODE *ep1, *ep2;
| 747 |
| 748 |
ep1 = getE4();
| 749 |
if (nextc != '^')
| 750 |
return(ep1);
| 751 |
ep2 = newnode();
| 752 |
ep2->type = nextc;
| 753 |
escan();
| 754 |
addekid(ep2, ep1);
| 755 |
| 756 |
| 757 |
| 758 |
| 759 |
ep2 = rconst(ep2);
| 760 |
| 761 |
epfree(ep3,1); /* (0 ^ E3) */
| 762 |
| 763 |
efree(ep2);
| 764 |
ep2 = ep1;
| 765 |
} else if ((ep3->type == NUM && ep3->v.num == 0) |
| 766 |
(ep1->type == NUM && ep1->v.num == 1)) {
| 767 |
epfree(ep2,0); /* (E4 ^ 0) or (1 ^ E3) */
| 768 |
ep2->type = NUM;
| 769 |
ep2->v.num = 1;
| 770 |
} else if (ep3->type == NUM && ep3->v.num == 1) {
| 771 |
efree(ep3); /* (E4 ^ 1) */
| 772 |
| 773 |
efree(ep2);
| 774 |
ep2 = ep1;
| 775 |
| 776 |
| 777 |
return(ep2);
| 778 |
| 779 |
| 780 |
| 781 |
EPNODE *
| 782 |
getE4(void) /* E4 -> ADDOP E5 */
| 783 |
/* E5 */
| 784 |
| 785 |
EPNODE *ep1, *ep2;
| 786 |
| 787 |
if (nextc == '-') {
| 788 |
escan();
| 789 |
ep2 = getE5();
| 790 |
if (ep2->type == NUM) {
| 791 |
ep2->v.num = -ep2->v.num;
| 792 |
return(ep2);
| 793 |
| 794 |
if (ep2->type == UMINUS) { /* don't generate -(-E5) */
| 795 |
ep1 = ep2->v.kid;
| 796 |
efree(ep2);
| 797 |
return(ep1);
| 798 |
| 799 |
ep1 = newnode();
| 800 |
ep1->type = UMINUS;
| 801 |
addekid(ep1, ep2);
| 802 |
return(ep1);
| 803 |
| 804 |
if (nextc == '+')
| 805 |
escan();
| 806 |
return(getE5());
| 807 |
| 808 |
| 809 |
| 810 |
EPNODE *
| 811 |
getE5(void) /* E5 -> (E1) */
| 812 |
/* VAR */
| 813 |
/* NUM */
| 814 |
/* $N */
| 815 |
/* FUNC(E1,..) */
| 816 |
/* ARG */
| 817 |
| 818 |
int i;
| 819 |
char *nam;
| 820 |
EPNODE *ep1, *ep2;
| 821 |
| 822 |
if (nextc == '(') {
| 823 |
escan();
| 824 |
ep1 = getE1();
| 825 |
if (nextc != ')')
| 826 |
esyntax("')' expected");
| 827 |
escan();
| 828 |
return(ep1);
| 829 |
| 830 |
if (esupport&E_INCHAN && nextc == '$') {
| 831 |
escan();
| 832 |
ep1 = newnode();
| 833 |
ep1->type = CHAN;
| 834 |
ep1->v.chan = getinum();
| 835 |
return(ep1);
| 836 |
| 837 |
if (esupport&(E_VARIABLE|E_FUNCTION) &&
| 838 |
(isalpha(nextc) | (nextc == CNTXMARK))) {
| 839 |
nam = getname();
| 840 |
ep1 = NULL;
| 841 |
if ((esupport&(E_VARIABLE|E_FUNCTION)) == (E_VARIABLE|E_FUNCTION)
| 842 |
&& ecurfunc != NULL)
| 843 |
for (i = 1, ep2 = ecurfunc->v.kid->sibling;
| 844 |
ep2 != NULL; i++, ep2 = ep2->sibling)
| 845 |
if (!strcmp(ep2->v.name, nam)) {
| 846 |
ep1 = newnode();
| 847 |
ep1->type = ARG;
| 848 |
ep1->v.chan = i;
| 849 |
break;
| 850 |
| 851 |
if (ep1 == NULL) {
| 852 |
ep1 = newnode();
| 853 |
ep1->type = VAR;
| 854 |
ep1->v.ln = varinsert(nam);
| 855 |
| 856 |
if (esupport&E_FUNCTION && nextc == '(') {
| 857 |
ep2 = newnode();
| 858 |
ep2->type = FUNC;
| 859 |
addekid(ep2, ep1);
| 860 |
ep1 = ep2;
| 861 |
do {
| 862 |
escan();
| 863 |
addekid(ep1, getE1());
| 864 |
} while (nextc == ',');
| 865 |
if (nextc != ')')
| 866 |
| 867 |
escan();
| 868 |
} else if (!(esupport&E_VARIABLE))
| 869 |
esyntax("'(' expected");
| 870 |
if (esupport&E_RCONST && isconstvar(ep1))
| 871 |
ep1 = rconst(ep1);
| 872 |
return(ep1);
| 873 |
| 874 |
if (isdecimal(nextc)) {
| 875 |
ep1 = newnode();
| 876 |
ep1->type = NUM;
| 877 |
ep1->v.num = getnum();
| 878 |
return(ep1);
| 879 |
| 880 |
| 881 |
return NULL; /* pro forma return */
| 882 |
| 883 |
| 884 |
| 885 |
EPNODE *
| 886 |
rconst( /* reduce a constant expression */
| 887 |
EPNODE *epar
| 888 |
| 889 |
| 890 |
EPNODE *ep;
| 891 |
| 892 |
ep = newnode();
| 893 |
ep->type = NUM;
| 894 |
errno = 0;
| 895 |
ep->v.num = evalue(epar);
| 896 |
| 897 |
esyntax("bad constant expression");
| 898 |
epfree(epar,1);
| 899 |
| 900 |
return(ep);
| 901 |
| 902 |
| 903 |
| 904 |
int
| 905 |
isconstvar( /* is ep linked to a constant expression? */
| 906 |
EPNODE *ep
| 907 |
| 908 |
| 909 |
EPNODE *ep1;
| 910 |
| 911 |
if (esupport&E_FUNCTION && ep->type == FUNC) {
| 912 |
if (!isconstfun(ep->v.kid))
| 913 |
return(0);
| 914 |
for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling)
| 915 |
if (ep1->type != NUM && !isconstfun(ep1))
| 916 |
return(0);
| 917 |
return(1);
| 918 |
| 919 |
if (ep->type != VAR)
| 920 |
return(0);
| 921 |
ep1 = ep->v.ln->def;
| 922 |
if (ep1 == NULL || ep1->type != ':')
| 923 |
return(0);
| 924 |
if (esupport&E_FUNCTION && ep1->v.kid->type != SYM)
| 925 |
return(0);
| 926 |
return(1);
| 927 |
| 928 |
| 929 |
| 930 |
int
| 931 |
isconstfun( /* is ep linked to a constant function? */
| 932 |
EPNODE *ep
| 933 |
| 934 |
| 935 |
EPNODE *dp;
| 936 |
ELIBR *lp;
| 937 |
| 938 |
| 939 |
return(0);
| 940 |
if ((dp = ep->v.ln->def) != NULL) {
| 941 |
if (dp->v.kid->type == FUNC)
| 942 |
return(dp->type == ':');
| 943 |
else
| 944 |
return(0); /* don't identify masked library functions */
| 945 |
| 946 |
if ((lp = ep->v.ln->lib) != NULL)
| 947 |
return(lp->atyp == ':');
| 948 |
return(0);
| 949 |
