1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: calexpr.c,v 2.27 2003/08/04 19:20:26 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Compute data values using expression parser |
6 |
7 |
* 7/1/85 Greg Ward |
8 |
9 |
* 11/11/85 Made channel input conditional with (INCHAN) compiles. |
10 |
11 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION). |
12 |
13 |
* 1/29/87 Made variables conditional (VARIABLE) |
14 |
15 |
* 5/19/88 Added constant subexpression elimination (RCONST) |
16 |
17 |
* 2/19/03 Eliminated conditional compiles in favor of esupport extern. |
18 |
19 |
20 |
#include "copyright.h" |
21 |
22 |
#include <stdio.h> |
23 |
#include <string.h> |
24 |
#include <ctype.h> |
25 |
#include <errno.h> |
26 |
#include <math.h> |
27 |
#include <stdlib.h> |
28 |
29 |
#include "rterror.h" |
30 |
#include "calcomp.h" |
31 |
32 |
#define MAXLINE 256 /* maximum line length */ |
33 |
34 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) |
35 |
36 |
#define isdecimal(c) (isdigit(c) || (c) == '.') |
37 |
38 |
static double euminus(EPNODE *), eargument(EPNODE *), enumber(EPNODE *); |
39 |
static double echannel(EPNODE *); |
40 |
static double eadd(EPNODE *), esubtr(EPNODE *), |
41 |
emult(EPNODE *), edivi(EPNODE *), |
42 |
epow(EPNODE *); |
43 |
static double ebotch(EPNODE *); |
44 |
45 |
unsigned int esupport = /* what to support */ |
46 |
E_VARIABLE | E_FUNCTION ; |
47 |
48 |
int nextc; /* lookahead character */ |
49 |
50 |
double (*eoper[])(EPNODE *) = { /* expression operations */ |
51 |
ebotch, |
52 |
evariable, |
53 |
enumber, |
54 |
euminus, |
55 |
echannel, |
56 |
efunc, |
57 |
eargument, |
58 |
ebotch, |
59 |
ebotch, |
60 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
61 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
62 |
emult, |
63 |
eadd, |
64 |
0, |
65 |
esubtr, |
66 |
0, |
67 |
edivi, |
68 |
69 |
ebotch, |
70 |
0,0, |
71 |
ebotch, |
72 |
73 |
74 |
epow, |
75 |
76 |
77 |
static FILE *infp; /* input file pointer */ |
78 |
static char *linbuf; /* line buffer */ |
79 |
static char *infile; /* input file name */ |
80 |
static int lineno; /* input line number */ |
81 |
static int linepos; /* position in buffer */ |
82 |
83 |
84 |
EPNODE * |
85 |
eparse( /* parse an expression string */ |
86 |
char *expr |
87 |
88 |
89 |
EPNODE *ep; |
90 |
91 |
initstr(expr, NULL, 0); |
92 |
curfunc = NULL; |
93 |
ep = getE1(); |
94 |
if (nextc != EOF) |
95 |
syntax("unexpected character"); |
96 |
return(ep); |
97 |
98 |
99 |
100 |
double |
101 |
eval( /* evaluate an expression string */ |
102 |
char *expr |
103 |
104 |
105 |
register EPNODE *ep; |
106 |
double rval; |
107 |
108 |
ep = eparse(expr); |
109 |
rval = evalue(ep); |
110 |
epfree(ep); |
111 |
return(rval); |
112 |
113 |
114 |
115 |
int |
116 |
epcmp( /* compare two expressions for equivalence */ |
117 |
register EPNODE *ep1, |
118 |
register EPNODE *ep2 |
119 |
120 |
121 |
double d; |
122 |
123 |
if (ep1->type != ep2->type) |
124 |
return(1); |
125 |
126 |
switch (ep1->type) { |
127 |
128 |
case VAR: |
129 |
return(ep1->v.ln != ep2->v.ln); |
130 |
131 |
case NUM: |
132 |
if (ep2->v.num == 0) |
133 |
return(ep1->v.num != 0); |
134 |
d = ep1->v.num / ep2->v.num; |
135 |
return((d > 1.000000000001) | (d < 0.999999999999)); |
136 |
137 |
case CHAN: |
138 |
case ARG: |
139 |
return(ep1->v.chan != ep2->v.chan); |
140 |
141 |
case '=': |
142 |
case ':': |
143 |
return(epcmp(ep1->v.kid->sibling, ep2->v.kid->sibling)); |
144 |
145 |
case TICK: |
146 |
case SYM: /* should never get this one */ |
147 |
return(0); |
148 |
149 |
default: |
150 |
ep1 = ep1->v.kid; |
151 |
ep2 = ep2->v.kid; |
152 |
while (ep1 != NULL) { |
153 |
if (ep2 == NULL) |
154 |
return(1); |
155 |
if (epcmp(ep1, ep2)) |
156 |
return(1); |
157 |
ep1 = ep1->sibling; |
158 |
ep2 = ep2->sibling; |
159 |
160 |
return(ep2 != NULL); |
161 |
162 |
163 |
164 |
165 |
void |
166 |
epfree( /* free a parse tree */ |
167 |
register EPNODE *epar |
168 |
169 |
170 |
171 |
172 |
switch (epar->type) { |
173 |
174 |
case VAR: |
175 |
varfree(epar->v.ln); |
176 |
break; |
177 |
178 |
case SYM: |
179 |
freestr(epar->v.name); |
180 |
break; |
181 |
182 |
case NUM: |
183 |
case CHAN: |
184 |
case ARG: |
185 |
case TICK: |
186 |
break; |
187 |
188 |
default: |
189 |
while ((ep = epar->v.kid) != NULL) { |
190 |
epar->v.kid = ep->sibling; |
191 |
epfree(ep); |
192 |
193 |
break; |
194 |
195 |
196 |
197 |
efree((char *)epar); |
198 |
199 |
200 |
/* the following used to be a switch */ |
201 |
static double |
202 |
eargument( |
203 |
EPNODE *ep |
204 |
205 |
206 |
return(argument(ep->v.chan)); |
207 |
208 |
209 |
static double |
210 |
enumber( |
211 |
EPNODE *ep |
212 |
213 |
214 |
return(ep->v.num); |
215 |
216 |
217 |
static double |
218 |
euminus( |
219 |
EPNODE *ep |
220 |
221 |
222 |
register EPNODE *ep1 = ep->v.kid; |
223 |
224 |
return(-evalue(ep1)); |
225 |
226 |
227 |
static double |
228 |
echannel( |
229 |
EPNODE *ep |
230 |
231 |
232 |
return(chanvalue(ep->v.chan)); |
233 |
234 |
235 |
static double |
236 |
eadd( |
237 |
EPNODE *ep |
238 |
239 |
240 |
241 |
242 |
return(evalue(ep1) + evalue(ep1->sibling)); |
243 |
244 |
245 |
static double |
246 |
esubtr( |
247 |
EPNODE *ep |
248 |
249 |
250 |
251 |
252 |
return(evalue(ep1) - evalue(ep1->sibling)); |
253 |
254 |
255 |
static double |
256 |
emult( |
257 |
EPNODE *ep |
258 |
259 |
260 |
261 |
262 |
return(evalue(ep1) * evalue(ep1->sibling)); |
263 |
264 |
265 |
static double |
266 |
edivi( |
267 |
EPNODE *ep |
268 |
269 |
270 |
271 |
double d; |
272 |
273 |
d = evalue(ep1->sibling); |
274 |
if (d == 0.0) { |
275 |
wputs("Division by zero\n"); |
276 |
errno = ERANGE; |
277 |
return(0.0); |
278 |
279 |
return(evalue(ep1) / d); |
280 |
281 |
282 |
static double |
283 |
epow( |
284 |
EPNODE *ep |
285 |
286 |
287 |
288 |
double d; |
289 |
int lasterrno; |
290 |
291 |
lasterrno = errno; |
292 |
errno = 0; |
293 |
d = pow(evalue(ep1), evalue(ep1->sibling)); |
294 |
#ifdef IEEE |
295 |
if (!finite(d)) |
296 |
errno = EDOM; |
297 |
#endif |
298 |
if (errno == EDOM || errno == ERANGE) { |
299 |
wputs("Illegal power\n"); |
300 |
return(0.0); |
301 |
302 |
errno = lasterrno; |
303 |
return(d); |
304 |
305 |
306 |
static double |
307 |
ebotch( |
308 |
EPNODE *ep |
309 |
310 |
311 |
eputs("Bad expression!\n"); |
312 |
quit(1); |
313 |
return 0.0; /* pro forma return */ |
314 |
315 |
316 |
317 |
EPNODE * |
318 |
ekid( /* return pointer to a node's nth kid */ |
319 |
register EPNODE *ep, |
320 |
register int n |
321 |
322 |
323 |
324 |
for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) |
325 |
if (--n < 0) |
326 |
break; |
327 |
328 |
return(ep); |
329 |
330 |
331 |
332 |
int |
333 |
nekids( /* return # of kids for node ep */ |
334 |
register EPNODE *ep |
335 |
336 |
337 |
register int n = 0; |
338 |
339 |
340 |
n++; |
341 |
342 |
return(n); |
343 |
344 |
345 |
346 |
void |
347 |
initfile( /* prepare input file */ |
348 |
FILE *fp, |
349 |
char *fn, |
350 |
int ln |
351 |
352 |
353 |
static char inpbuf[MAXLINE]; |
354 |
355 |
infp = fp; |
356 |
linbuf = inpbuf; |
357 |
infile = fn; |
358 |
lineno = ln; |
359 |
linepos = 0; |
360 |
inpbuf[0] = '\0'; |
361 |
scan(); |
362 |
363 |
364 |
365 |
void |
366 |
initstr( /* prepare input string */ |
367 |
char *s, |
368 |
char *fn, |
369 |
int ln |
370 |
371 |
372 |
infp = NULL; |
373 |
infile = fn; |
374 |
lineno = ln; |
375 |
linbuf = s; |
376 |
linepos = 0; |
377 |
scan(); |
378 |
379 |
380 |
381 |
void |
382 |
getscanpos( /* return current scan position */ |
383 |
char **fnp, |
384 |
int *lnp, |
385 |
char **spp, |
386 |
FILE **fpp |
387 |
388 |
389 |
if (fnp != NULL) *fnp = infile; |
390 |
if (lnp != NULL) *lnp = lineno; |
391 |
if (spp != NULL) *spp = linbuf+linepos; |
392 |
if (fpp != NULL) *fpp = infp; |
393 |
394 |
395 |
396 |
int |
397 |
scan(void) /* scan next character, return literal next */ |
398 |
399 |
register int lnext = 0; |
400 |
401 |
do { |
402 |
if (linbuf[linepos] == '\0') |
403 |
if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL) |
404 |
nextc = EOF; |
405 |
else { |
406 |
nextc = linbuf[0]; |
407 |
lineno++; |
408 |
linepos = 1; |
409 |
410 |
else |
411 |
nextc = linbuf[linepos++]; |
412 |
if (!lnext) |
413 |
lnext = nextc; |
414 |
if (nextc == '{') { |
415 |
scan(); |
416 |
while (nextc != '}') |
417 |
if (nextc == EOF) |
418 |
syntax("'}' expected"); |
419 |
else |
420 |
scan(); |
421 |
scan(); |
422 |
423 |
} while (isspace(nextc)); |
424 |
return(lnext); |
425 |
426 |
427 |
428 |
char * |
429 |
long2ascii( /* convert long to ascii */ |
430 |
long l |
431 |
432 |
433 |
static char buf[16]; |
434 |
register char *cp; |
435 |
int neg = 0; |
436 |
437 |
if (l == 0) |
438 |
return("0"); |
439 |
if (l < 0) { |
440 |
l = -l; |
441 |
neg++; |
442 |
443 |
cp = buf + sizeof(buf); |
444 |
*--cp = '\0'; |
445 |
while (l) { |
446 |
*--cp = l % 10 + '0'; |
447 |
l /= 10; |
448 |
449 |
if (neg) |
450 |
*--cp = '-'; |
451 |
return(cp); |
452 |
453 |
454 |
455 |
void |
456 |
syntax( /* report syntax error and quit */ |
457 |
char *err |
458 |
459 |
460 |
register int i; |
461 |
462 |
if (infile != NULL || lineno != 0) { |
463 |
if (infile != NULL) eputs(infile); |
464 |
if (lineno != 0) { |
465 |
eputs(infile != NULL ? ", line " : "line "); |
466 |
eputs(long2ascii((long)lineno)); |
467 |
468 |
eputs(":\n"); |
469 |
470 |
eputs(linbuf); |
471 |
if (linbuf[strlen(linbuf)-1] != '\n') |
472 |
eputs("\n"); |
473 |
for (i = 0; i < linepos-1; i++) |
474 |
eputs(linbuf[i] == '\t' ? "\t" : " "); |
475 |
eputs("^ "); |
476 |
eputs(err); |
477 |
eputs("\n"); |
478 |
quit(1); |
479 |
480 |
481 |
482 |
void |
483 |
addekid( /* add a child to ep */ |
484 |
485 |
EPNODE *ekid |
486 |
487 |
488 |
if (ep->v.kid == NULL) |
489 |
ep->v.kid = ekid; |
490 |
else { |
491 |
for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling) |
492 |
493 |
ep->sibling = ekid; |
494 |
495 |
ekid->sibling = NULL; |
496 |
497 |
498 |
499 |
char * |
500 |
getname(void) /* scan an identifier */ |
501 |
502 |
static char str[RMAXWORD+1]; |
503 |
register int i, lnext; |
504 |
505 |
lnext = nextc; |
506 |
for (i = 0; i < RMAXWORD && isid(lnext); i++, lnext = scan()) |
507 |
str[i] = lnext; |
508 |
str[i] = '\0'; |
509 |
while (isid(lnext)) /* skip rest of name */ |
510 |
lnext = scan(); |
511 |
512 |
return(str); |
513 |
514 |
515 |
516 |
int |
517 |
getinum(void) /* scan a positive integer */ |
518 |
519 |
register int n, lnext; |
520 |
521 |
n = 0; |
522 |
lnext = nextc; |
523 |
while (isdigit(lnext)) { |
524 |
n = n * 10 + lnext - '0'; |
525 |
lnext = scan(); |
526 |
527 |
return(n); |
528 |
529 |
530 |
531 |
double |
532 |
getnum(void) /* scan a positive float */ |
533 |
534 |
535 |
536 |
537 |
i = 0; |
538 |
lnext = nextc; |
539 |
while (isdigit(lnext) && i < RMAXWORD) { |
540 |
str[i++] = lnext; |
541 |
lnext = scan(); |
542 |
543 |
if (lnext == '.' && i < RMAXWORD) { |
544 |
str[i++] = lnext; |
545 |
lnext = scan(); |
546 |
if (i == 1 && !isdigit(lnext)) |
547 |
syntax("badly formed number"); |
548 |
549 |
str[i++] = lnext; |
550 |
lnext = scan(); |
551 |
552 |
553 |
if ((lnext == 'e') | (lnext == 'E') && i < RMAXWORD) { |
554 |
str[i++] = lnext; |
555 |
lnext = scan(); |
556 |
if ((lnext == '-') | (lnext == '+') && i < RMAXWORD) { |
557 |
str[i++] = lnext; |
558 |
lnext = scan(); |
559 |
560 |
if (!isdigit(lnext)) |
561 |
syntax("missing exponent"); |
562 |
563 |
str[i++] = lnext; |
564 |
lnext = scan(); |
565 |
566 |
567 |
str[i] = '\0'; |
568 |
569 |
return(atof(str)); |
570 |
571 |
572 |
573 |
EPNODE * |
574 |
getE1(void) /* E1 -> E1 ADDOP E2 */ |
575 |
/* E2 */ |
576 |
577 |
register EPNODE *ep1, *ep2; |
578 |
579 |
ep1 = getE2(); |
580 |
while (nextc == '+' || nextc == '-') { |
581 |
ep2 = newnode(); |
582 |
ep2->type = nextc; |
583 |
scan(); |
584 |
addekid(ep2, ep1); |
585 |
addekid(ep2, getE2()); |
586 |
if (esupport&E_RCONST && |
587 |
ep1->type == NUM && ep1->sibling->type == NUM) |
588 |
ep2 = rconst(ep2); |
589 |
ep1 = ep2; |
590 |
591 |
return(ep1); |
592 |
593 |
594 |
595 |
EPNODE * |
596 |
getE2(void) /* E2 -> E2 MULOP E3 */ |
597 |
/* E3 */ |
598 |
599 |
600 |
601 |
ep1 = getE3(); |
602 |
while (nextc == '*' || nextc == '/') { |
603 |
ep2 = newnode(); |
604 |
605 |
scan(); |
606 |
607 |
addekid(ep2, getE3()); |
608 |
609 |
610 |
611 |
ep1 = ep2; |
612 |
613 |
return(ep1); |
614 |
615 |
616 |
617 |
EPNODE * |
618 |
getE3(void) /* E3 -> E4 ^ E3 */ |
619 |
/* E4 */ |
620 |
621 |
622 |
623 |
ep1 = getE4(); |
624 |
if (nextc == '^') { |
625 |
ep2 = newnode(); |
626 |
627 |
scan(); |
628 |
629 |
630 |
631 |
632 |
633 |
return(ep2); |
634 |
635 |
return(ep1); |
636 |
637 |
638 |
639 |
EPNODE * |
640 |
getE4(void) /* E4 -> ADDOP E5 */ |
641 |
/* E5 */ |
642 |
643 |
644 |
645 |
if (nextc == '-') { |
646 |
scan(); |
647 |
ep2 = getE5(); |
648 |
if (ep2->type == NUM) { |
649 |
ep2->v.num = -ep2->v.num; |
650 |
return(ep2); |
651 |
652 |
if (ep2->type == UMINUS) { /* don't generate -(-E5) */ |
653 |
efree((char *)ep2); |
654 |
return(ep2->v.kid); |
655 |
656 |
ep1 = newnode(); |
657 |
ep1->type = UMINUS; |
658 |
addekid(ep1, ep2); |
659 |
return(ep1); |
660 |
661 |
if (nextc == '+') |
662 |
scan(); |
663 |
return(getE5()); |
664 |
665 |
666 |
667 |
EPNODE * |
668 |
getE5(void) /* E5 -> (E1) */ |
669 |
/* VAR */ |
670 |
/* NUM */ |
671 |
/* $N */ |
672 |
/* FUNC(E1,..) */ |
673 |
/* ARG */ |
674 |
675 |
int i; |
676 |
char *nam; |
677 |
678 |
679 |
if (nextc == '(') { |
680 |
scan(); |
681 |
ep1 = getE1(); |
682 |
if (nextc != ')') |
683 |
syntax("')' expected"); |
684 |
scan(); |
685 |
return(ep1); |
686 |
687 |
688 |
if (esupport&E_INCHAN && nextc == '$') { |
689 |
scan(); |
690 |
ep1 = newnode(); |
691 |
ep1->type = CHAN; |
692 |
ep1->v.chan = getinum(); |
693 |
return(ep1); |
694 |
695 |
696 |
if (esupport&(E_VARIABLE|E_FUNCTION) && |
697 |
(isalpha(nextc) || nextc == CNTXMARK)) { |
698 |
nam = getname(); |
699 |
ep1 = NULL; |
700 |
if ((esupport&(E_VARIABLE|E_FUNCTION)) == (E_VARIABLE|E_FUNCTION) |
701 |
&& curfunc != NULL) |
702 |
for (i = 1, ep2 = curfunc->v.kid->sibling; |
703 |
ep2 != NULL; i++, ep2 = ep2->sibling) |
704 |
if (!strcmp(ep2->v.name, nam)) { |
705 |
ep1 = newnode(); |
706 |
ep1->type = ARG; |
707 |
ep1->v.chan = i; |
708 |
break; |
709 |
710 |
if (ep1 == NULL) { |
711 |
ep1 = newnode(); |
712 |
ep1->type = VAR; |
713 |
ep1->v.ln = varinsert(nam); |
714 |
715 |
if (esupport&E_FUNCTION && nextc == '(') { |
716 |
ep2 = newnode(); |
717 |
ep2->type = FUNC; |
718 |
719 |
ep1 = ep2; |
720 |
do { |
721 |
scan(); |
722 |
addekid(ep1, getE1()); |
723 |
} while (nextc == ','); |
724 |
if (nextc != ')') |
725 |
726 |
scan(); |
727 |
} else if (!(esupport&E_VARIABLE)) |
728 |
syntax("'(' expected"); |
729 |
if (esupport&E_RCONST && isconstvar(ep1)) |
730 |
ep1 = rconst(ep1); |
731 |
return(ep1); |
732 |
733 |
734 |
if (isdecimal(nextc)) { |
735 |
ep1 = newnode(); |
736 |
ep1->type = NUM; |
737 |
ep1->v.num = getnum(); |
738 |
return(ep1); |
739 |
740 |
741 |
return NULL; /* pro forma return */ |
742 |
743 |
744 |
745 |
EPNODE * |
746 |
rconst( /* reduce a constant expression */ |
747 |
748 |
749 |
750 |
751 |
752 |
ep = newnode(); |
753 |
ep->type = NUM; |
754 |
errno = 0; |
755 |
ep->v.num = evalue(epar); |
756 |
if (errno == EDOM || errno == ERANGE) |
757 |
syntax("bad constant expression"); |
758 |
epfree(epar); |
759 |
760 |
return(ep); |
761 |
762 |
763 |
764 |
int |
765 |
isconstvar( /* is ep linked to a constant expression? */ |
766 |
767 |
768 |
769 |
register EPNODE *ep1; |
770 |
771 |
if (esupport&E_FUNCTION && ep->type == FUNC) { |
772 |
if (!isconstfun(ep->v.kid)) |
773 |
return(0); |
774 |
for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling) |
775 |
if (ep1->type != NUM && !isconstfun(ep1)) |
776 |
return(0); |
777 |
return(1); |
778 |
779 |
if (ep->type != VAR) |
780 |
return(0); |
781 |
ep1 = ep->v.ln->def; |
782 |
if (ep1 == NULL || ep1->type != ':') |
783 |
return(0); |
784 |
if (esupport&E_FUNCTION && ep1->v.kid->type != SYM) |
785 |
return(0); |
786 |
return(1); |
787 |
788 |
789 |
790 |
int |
791 |
isconstfun( /* is ep linked to a constant function? */ |
792 |
793 |
794 |
795 |
register EPNODE *dp; |
796 |
register LIBR *lp; |
797 |
798 |
799 |
return(0); |
800 |
if ((dp = ep->v.ln->def) != NULL) { |
801 |
if (dp->v.kid->type == FUNC) |
802 |
return(dp->type == ':'); |
803 |
else |
804 |
return(0); /* don't identify masked library functions */ |
805 |
806 |
if ((lp = ep->v.ln->lib) != NULL) |
807 |
return(lp->atyp == ':'); |
808 |
return(0); |
809 |
