1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: calexpr.c,v 2.22 2003/06/07 12:50:20 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* Compute data values using expression parser |
6 |
7 |
* 7/1/85 Greg Ward |
8 |
9 |
* 11/11/85 Made channel input conditional with (INCHAN) compiles. |
10 |
11 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION). |
12 |
13 |
* 1/29/87 Made variables conditional (VARIABLE) |
14 |
15 |
* 5/19/88 Added constant subexpression elimination (RCONST) |
16 |
17 |
* 2/19/03 Eliminated conditional compiles in favor of esupport extern. |
18 |
19 |
20 |
#include "copyright.h" |
21 |
22 |
#include <stdio.h> |
23 |
#include <string.h> |
24 |
#include <ctype.h> |
25 |
#include <errno.h> |
26 |
#include <math.h> |
27 |
#include <stdlib.h> |
28 |
29 |
#include "calcomp.h" |
30 |
31 |
#define MAXLINE 256 /* maximum line length */ |
32 |
33 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) |
34 |
35 |
#define isdecimal(c) (isdigit(c) || (c) == '.') |
36 |
37 |
static double euminus(), eargument(), enumber(); |
38 |
static double echannel(); |
39 |
static double eadd(), esubtr(), emult(), edivi(), epow(); |
40 |
static double ebotch(); |
41 |
42 |
unsigned int esupport = /* what to support */ |
43 |
E_VARIABLE | E_FUNCTION ; |
44 |
45 |
int nextc; /* lookahead character */ |
46 |
47 |
double (*eoper[])() = { /* expression operations */ |
48 |
ebotch, |
49 |
evariable, |
50 |
enumber, |
51 |
euminus, |
52 |
echannel, |
53 |
efunc, |
54 |
eargument, |
55 |
ebotch, |
56 |
ebotch, |
57 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
58 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
59 |
emult, |
60 |
eadd, |
61 |
0, |
62 |
esubtr, |
63 |
0, |
64 |
edivi, |
65 |
66 |
ebotch, |
67 |
0,0, |
68 |
ebotch, |
69 |
70 |
71 |
epow, |
72 |
73 |
74 |
static FILE *infp; /* input file pointer */ |
75 |
static char *linbuf; /* line buffer */ |
76 |
static char *infile; /* input file name */ |
77 |
static int lineno; /* input line number */ |
78 |
static int linepos; /* position in buffer */ |
79 |
80 |
81 |
EPNODE * |
82 |
eparse(expr) /* parse an expression string */ |
83 |
char *expr; |
84 |
85 |
EPNODE *ep; |
86 |
87 |
initstr(expr, NULL, 0); |
88 |
curfunc = NULL; |
89 |
ep = getE1(); |
90 |
if (nextc != EOF) |
91 |
syntax("unexpected character"); |
92 |
return(ep); |
93 |
94 |
95 |
96 |
double |
97 |
eval(expr) /* evaluate an expression string */ |
98 |
char *expr; |
99 |
100 |
register EPNODE *ep; |
101 |
double rval; |
102 |
103 |
ep = eparse(expr); |
104 |
rval = evalue(ep); |
105 |
epfree(ep); |
106 |
return(rval); |
107 |
108 |
109 |
110 |
int |
111 |
epcmp(ep1, ep2) /* compare two expressions for equivalence */ |
112 |
register EPNODE *ep1, *ep2; |
113 |
114 |
double d; |
115 |
116 |
if (ep1->type != ep2->type) |
117 |
return(1); |
118 |
119 |
switch (ep1->type) { |
120 |
121 |
case VAR: |
122 |
return(ep1->v.ln != ep2->v.ln); |
123 |
124 |
case NUM: |
125 |
if (ep2->v.num == 0) |
126 |
return(ep1->v.num != 0); |
127 |
d = ep1->v.num / ep2->v.num; |
128 |
return(d > 1.000000000001 | d < 0.999999999999); |
129 |
130 |
case CHAN: |
131 |
case ARG: |
132 |
return(ep1->v.chan != ep2->v.chan); |
133 |
134 |
case '=': |
135 |
case ':': |
136 |
return(epcmp(ep1->v.kid->sibling, ep2->v.kid->sibling)); |
137 |
138 |
case TICK: |
139 |
case SYM: /* should never get this one */ |
140 |
return(0); |
141 |
142 |
default: |
143 |
ep1 = ep1->v.kid; |
144 |
ep2 = ep2->v.kid; |
145 |
while (ep1 != NULL) { |
146 |
if (ep2 == NULL) |
147 |
return(1); |
148 |
if (epcmp(ep1, ep2)) |
149 |
return(1); |
150 |
ep1 = ep1->sibling; |
151 |
ep2 = ep2->sibling; |
152 |
153 |
return(ep2 != NULL); |
154 |
155 |
156 |
157 |
158 |
void |
159 |
epfree(epar) /* free a parse tree */ |
160 |
register EPNODE *epar; |
161 |
162 |
163 |
164 |
switch (epar->type) { |
165 |
166 |
case VAR: |
167 |
varfree(epar->v.ln); |
168 |
break; |
169 |
170 |
case SYM: |
171 |
freestr(epar->v.name); |
172 |
break; |
173 |
174 |
case NUM: |
175 |
case CHAN: |
176 |
case ARG: |
177 |
case TICK: |
178 |
break; |
179 |
180 |
default: |
181 |
while ((ep = epar->v.kid) != NULL) { |
182 |
epar->v.kid = ep->sibling; |
183 |
epfree(ep); |
184 |
185 |
break; |
186 |
187 |
188 |
189 |
efree((char *)epar); |
190 |
191 |
192 |
/* the following used to be a switch */ |
193 |
static double |
194 |
eargument(ep) |
195 |
EPNODE *ep; |
196 |
197 |
return(argument(ep->v.chan)); |
198 |
199 |
200 |
static double |
201 |
enumber(ep) |
202 |
EPNODE *ep; |
203 |
204 |
return(ep->v.num); |
205 |
206 |
207 |
static double |
208 |
euminus(ep) |
209 |
EPNODE *ep; |
210 |
211 |
register EPNODE *ep1 = ep->v.kid; |
212 |
213 |
return(-evalue(ep1)); |
214 |
215 |
216 |
static double |
217 |
echannel(ep) |
218 |
EPNODE *ep; |
219 |
220 |
return(chanvalue(ep->v.chan)); |
221 |
222 |
223 |
static double |
224 |
eadd(ep) |
225 |
EPNODE *ep; |
226 |
227 |
228 |
229 |
return(evalue(ep1) + evalue(ep1->sibling)); |
230 |
231 |
232 |
static double |
233 |
esubtr(ep) |
234 |
EPNODE *ep; |
235 |
236 |
237 |
238 |
return(evalue(ep1) - evalue(ep1->sibling)); |
239 |
240 |
241 |
static double |
242 |
emult(ep) |
243 |
EPNODE *ep; |
244 |
245 |
246 |
247 |
return(evalue(ep1) * evalue(ep1->sibling)); |
248 |
249 |
250 |
static double |
251 |
edivi(ep) |
252 |
EPNODE *ep; |
253 |
254 |
255 |
double d; |
256 |
257 |
d = evalue(ep1->sibling); |
258 |
if (d == 0.0) { |
259 |
wputs("Division by zero\n"); |
260 |
errno = ERANGE; |
261 |
return(0.0); |
262 |
263 |
return(evalue(ep1) / d); |
264 |
265 |
266 |
static double |
267 |
epow(ep) |
268 |
EPNODE *ep; |
269 |
270 |
271 |
double d; |
272 |
int lasterrno; |
273 |
274 |
lasterrno = errno; |
275 |
errno = 0; |
276 |
d = pow(evalue(ep1), evalue(ep1->sibling)); |
277 |
#ifdef IEEE |
278 |
if (!finite(d)) |
279 |
errno = EDOM; |
280 |
#endif |
281 |
if (errno == EDOM || errno == ERANGE) { |
282 |
wputs("Illegal power\n"); |
283 |
return(0.0); |
284 |
285 |
errno = lasterrno; |
286 |
return(d); |
287 |
288 |
289 |
static double |
290 |
ebotch(ep) |
291 |
EPNODE *ep; |
292 |
293 |
eputs("Bad expression!\n"); |
294 |
quit(1); |
295 |
return 0.0; /* pro forma return */ |
296 |
297 |
298 |
299 |
EPNODE * |
300 |
ekid(ep, n) /* return pointer to a node's nth kid */ |
301 |
302 |
register int n; |
303 |
304 |
305 |
for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) |
306 |
if (--n < 0) |
307 |
break; |
308 |
309 |
return(ep); |
310 |
311 |
312 |
313 |
int |
314 |
nekids(ep) /* return # of kids for node ep */ |
315 |
316 |
317 |
register int n = 0; |
318 |
319 |
320 |
n++; |
321 |
322 |
return(n); |
323 |
324 |
325 |
326 |
void |
327 |
initfile(fp, fn, ln) /* prepare input file */ |
328 |
FILE *fp; |
329 |
char *fn; |
330 |
int ln; |
331 |
332 |
static char inpbuf[MAXLINE]; |
333 |
334 |
infp = fp; |
335 |
linbuf = inpbuf; |
336 |
infile = fn; |
337 |
lineno = ln; |
338 |
linepos = 0; |
339 |
inpbuf[0] = '\0'; |
340 |
scan(); |
341 |
342 |
343 |
344 |
void |
345 |
initstr(s, fn, ln) /* prepare input string */ |
346 |
char *s; |
347 |
char *fn; |
348 |
int ln; |
349 |
350 |
infp = NULL; |
351 |
infile = fn; |
352 |
lineno = ln; |
353 |
linbuf = s; |
354 |
linepos = 0; |
355 |
scan(); |
356 |
357 |
358 |
359 |
void |
360 |
getscanpos(fnp, lnp, spp, fpp) /* return current scan position */ |
361 |
char **fnp; |
362 |
int *lnp; |
363 |
char **spp; |
364 |
FILE **fpp; |
365 |
366 |
if (fnp != NULL) *fnp = infile; |
367 |
if (lnp != NULL) *lnp = lineno; |
368 |
if (spp != NULL) *spp = linbuf+linepos; |
369 |
if (fpp != NULL) *fpp = infp; |
370 |
371 |
372 |
373 |
int |
374 |
scan() /* scan next character, return literal next */ |
375 |
376 |
register int lnext = 0; |
377 |
378 |
do { |
379 |
if (linbuf[linepos] == '\0') |
380 |
if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL) |
381 |
nextc = EOF; |
382 |
else { |
383 |
nextc = linbuf[0]; |
384 |
lineno++; |
385 |
linepos = 1; |
386 |
387 |
else |
388 |
nextc = linbuf[linepos++]; |
389 |
if (!lnext) |
390 |
lnext = nextc; |
391 |
if (nextc == '{') { |
392 |
scan(); |
393 |
while (nextc != '}') |
394 |
if (nextc == EOF) |
395 |
syntax("'}' expected"); |
396 |
else |
397 |
scan(); |
398 |
scan(); |
399 |
400 |
} while (isspace(nextc)); |
401 |
return(lnext); |
402 |
403 |
404 |
405 |
char * |
406 |
long2ascii(l) /* convert long to ascii */ |
407 |
long l; |
408 |
409 |
static char buf[16]; |
410 |
register char *cp; |
411 |
int neg = 0; |
412 |
413 |
if (l == 0) |
414 |
return("0"); |
415 |
if (l < 0) { |
416 |
l = -l; |
417 |
neg++; |
418 |
419 |
cp = buf + sizeof(buf); |
420 |
*--cp = '\0'; |
421 |
while (l) { |
422 |
*--cp = l % 10 + '0'; |
423 |
l /= 10; |
424 |
425 |
if (neg) |
426 |
*--cp = '-'; |
427 |
return(cp); |
428 |
429 |
430 |
431 |
void |
432 |
syntax(err) /* report syntax error and quit */ |
433 |
char *err; |
434 |
435 |
register int i; |
436 |
437 |
if (infile != NULL || lineno != 0) { |
438 |
if (infile != NULL) eputs(infile); |
439 |
if (lineno != 0) { |
440 |
eputs(infile != NULL ? ", line " : "line "); |
441 |
eputs(long2ascii((long)lineno)); |
442 |
443 |
eputs(":\n"); |
444 |
445 |
eputs(linbuf); |
446 |
if (linbuf[strlen(linbuf)-1] != '\n') |
447 |
eputs("\n"); |
448 |
for (i = 0; i < linepos-1; i++) |
449 |
eputs(linbuf[i] == '\t' ? "\t" : " "); |
450 |
eputs("^ "); |
451 |
eputs(err); |
452 |
eputs("\n"); |
453 |
quit(1); |
454 |
455 |
456 |
457 |
void |
458 |
addekid(ep, ekid) /* add a child to ep */ |
459 |
460 |
EPNODE *ekid; |
461 |
462 |
if (ep->v.kid == NULL) |
463 |
ep->v.kid = ekid; |
464 |
else { |
465 |
for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling) |
466 |
467 |
ep->sibling = ekid; |
468 |
469 |
ekid->sibling = NULL; |
470 |
471 |
472 |
473 |
char * |
474 |
getname() /* scan an identifier */ |
475 |
476 |
static char str[RMAXWORD+1]; |
477 |
register int i, lnext; |
478 |
479 |
lnext = nextc; |
480 |
for (i = 0; i < RMAXWORD && isid(lnext); i++, lnext = scan()) |
481 |
str[i] = lnext; |
482 |
str[i] = '\0'; |
483 |
while (isid(lnext)) /* skip rest of name */ |
484 |
lnext = scan(); |
485 |
486 |
return(str); |
487 |
488 |
489 |
490 |
int |
491 |
getinum() /* scan a positive integer */ |
492 |
493 |
register int n, lnext; |
494 |
495 |
n = 0; |
496 |
lnext = nextc; |
497 |
while (isdigit(lnext)) { |
498 |
n = n * 10 + lnext - '0'; |
499 |
lnext = scan(); |
500 |
501 |
return(n); |
502 |
503 |
504 |
505 |
double |
506 |
getnum() /* scan a positive float */ |
507 |
508 |
509 |
510 |
511 |
i = 0; |
512 |
lnext = nextc; |
513 |
while (isdigit(lnext) && i < RMAXWORD) { |
514 |
str[i++] = lnext; |
515 |
lnext = scan(); |
516 |
517 |
if (lnext == '.' && i < RMAXWORD) { |
518 |
str[i++] = lnext; |
519 |
lnext = scan(); |
520 |
if (i == 1 && !isdigit(lnext)) |
521 |
syntax("badly formed number"); |
522 |
523 |
str[i++] = lnext; |
524 |
lnext = scan(); |
525 |
526 |
527 |
if ((lnext == 'e' | lnext == 'E') && i < RMAXWORD) { |
528 |
str[i++] = lnext; |
529 |
lnext = scan(); |
530 |
if ((lnext == '-' | lnext == '+') && i < RMAXWORD) { |
531 |
str[i++] = lnext; |
532 |
lnext = scan(); |
533 |
534 |
if (!isdigit(lnext)) |
535 |
syntax("missing exponent"); |
536 |
537 |
str[i++] = lnext; |
538 |
lnext = scan(); |
539 |
540 |
541 |
str[i] = '\0'; |
542 |
543 |
return(atof(str)); |
544 |
545 |
546 |
547 |
EPNODE * |
548 |
getE1() /* E1 -> E1 ADDOP E2 */ |
549 |
/* E2 */ |
550 |
551 |
552 |
553 |
ep1 = getE2(); |
554 |
while (nextc == '+' || nextc == '-') { |
555 |
ep2 = newnode(); |
556 |
ep2->type = nextc; |
557 |
scan(); |
558 |
addekid(ep2, ep1); |
559 |
addekid(ep2, getE2()); |
560 |
if (esupport&E_RCONST && |
561 |
ep1->type == NUM && ep1->sibling->type == NUM) |
562 |
ep2 = rconst(ep2); |
563 |
ep1 = ep2; |
564 |
565 |
return(ep1); |
566 |
567 |
568 |
569 |
EPNODE * |
570 |
getE2() /* E2 -> E2 MULOP E3 */ |
571 |
/* E3 */ |
572 |
573 |
574 |
575 |
ep1 = getE3(); |
576 |
while (nextc == '*' || nextc == '/') { |
577 |
ep2 = newnode(); |
578 |
579 |
scan(); |
580 |
581 |
addekid(ep2, getE3()); |
582 |
583 |
584 |
585 |
ep1 = ep2; |
586 |
587 |
return(ep1); |
588 |
589 |
590 |
591 |
EPNODE * |
592 |
getE3() /* E3 -> E4 ^ E3 */ |
593 |
/* E4 */ |
594 |
595 |
596 |
597 |
ep1 = getE4(); |
598 |
if (nextc == '^') { |
599 |
ep2 = newnode(); |
600 |
601 |
scan(); |
602 |
603 |
604 |
605 |
606 |
607 |
return(ep2); |
608 |
609 |
return(ep1); |
610 |
611 |
612 |
613 |
EPNODE * |
614 |
getE4() /* E4 -> ADDOP E5 */ |
615 |
/* E5 */ |
616 |
617 |
618 |
619 |
if (nextc == '-') { |
620 |
scan(); |
621 |
ep2 = getE5(); |
622 |
if (ep2->type == NUM) { |
623 |
ep2->v.num = -ep2->v.num; |
624 |
return(ep2); |
625 |
626 |
if (ep2->type == UMINUS) { /* don't generate -(-E5) */ |
627 |
efree((char *)ep2); |
628 |
return(ep2->v.kid); |
629 |
630 |
ep1 = newnode(); |
631 |
ep1->type = UMINUS; |
632 |
addekid(ep1, ep2); |
633 |
return(ep1); |
634 |
635 |
if (nextc == '+') |
636 |
scan(); |
637 |
return(getE5()); |
638 |
639 |
640 |
641 |
EPNODE * |
642 |
getE5() /* E5 -> (E1) */ |
643 |
/* VAR */ |
644 |
/* NUM */ |
645 |
/* $N */ |
646 |
/* FUNC(E1,..) */ |
647 |
/* ARG */ |
648 |
649 |
int i; |
650 |
char *nam; |
651 |
652 |
653 |
if (nextc == '(') { |
654 |
scan(); |
655 |
ep1 = getE1(); |
656 |
if (nextc != ')') |
657 |
syntax("')' expected"); |
658 |
scan(); |
659 |
return(ep1); |
660 |
661 |
662 |
if (esupport&E_INCHAN && nextc == '$') { |
663 |
scan(); |
664 |
ep1 = newnode(); |
665 |
ep1->type = CHAN; |
666 |
ep1->v.chan = getinum(); |
667 |
return(ep1); |
668 |
669 |
670 |
if (esupport&(E_VARIABLE|E_FUNCTION) && |
671 |
(isalpha(nextc) || nextc == CNTXMARK)) { |
672 |
nam = getname(); |
673 |
ep1 = NULL; |
674 |
if ((esupport&(E_VARIABLE|E_FUNCTION)) == (E_VARIABLE|E_FUNCTION) |
675 |
&& curfunc != NULL) |
676 |
for (i = 1, ep2 = curfunc->v.kid->sibling; |
677 |
ep2 != NULL; i++, ep2 = ep2->sibling) |
678 |
if (!strcmp(ep2->v.name, nam)) { |
679 |
ep1 = newnode(); |
680 |
ep1->type = ARG; |
681 |
ep1->v.chan = i; |
682 |
break; |
683 |
684 |
if (ep1 == NULL) { |
685 |
ep1 = newnode(); |
686 |
ep1->type = VAR; |
687 |
ep1->v.ln = varinsert(nam); |
688 |
689 |
if (esupport&E_FUNCTION && nextc == '(') { |
690 |
ep2 = newnode(); |
691 |
ep2->type = FUNC; |
692 |
693 |
ep1 = ep2; |
694 |
do { |
695 |
scan(); |
696 |
addekid(ep1, getE1()); |
697 |
} while (nextc == ','); |
698 |
if (nextc != ')') |
699 |
700 |
scan(); |
701 |
} else if (!(esupport&E_VARIABLE)) |
702 |
syntax("'(' expected"); |
703 |
if (esupport&E_RCONST && isconstvar(ep1)) |
704 |
ep1 = rconst(ep1); |
705 |
return(ep1); |
706 |
707 |
708 |
if (isdecimal(nextc)) { |
709 |
ep1 = newnode(); |
710 |
ep1->type = NUM; |
711 |
ep1->v.num = getnum(); |
712 |
return(ep1); |
713 |
714 |
715 |
return NULL; /* pro forma return */ |
716 |
717 |
718 |
719 |
EPNODE * |
720 |
rconst(epar) /* reduce a constant expression */ |
721 |
722 |
723 |
724 |
725 |
ep = newnode(); |
726 |
ep->type = NUM; |
727 |
errno = 0; |
728 |
ep->v.num = evalue(epar); |
729 |
if (errno == EDOM || errno == ERANGE) |
730 |
syntax("bad constant expression"); |
731 |
epfree(epar); |
732 |
733 |
return(ep); |
734 |
735 |
736 |
737 |
int |
738 |
isconstvar(ep) /* is ep linked to a constant expression? */ |
739 |
740 |
741 |
register EPNODE *ep1; |
742 |
743 |
if (esupport&E_FUNCTION && ep->type == FUNC) { |
744 |
if (!isconstfun(ep->v.kid)) |
745 |
return(0); |
746 |
for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling) |
747 |
if (ep1->type != NUM && !isconstfun(ep1)) |
748 |
return(0); |
749 |
return(1); |
750 |
751 |
if (ep->type != VAR) |
752 |
return(0); |
753 |
ep1 = ep->v.ln->def; |
754 |
if (ep1 == NULL || ep1->type != ':') |
755 |
return(0); |
756 |
if (esupport&E_FUNCTION && ep1->v.kid->type != SYM) |
757 |
return(0); |
758 |
return(1); |
759 |
760 |
761 |
762 |
int |
763 |
isconstfun(ep) /* is ep linked to a constant function? */ |
764 |
765 |
766 |
register EPNODE *dp; |
767 |
register LIBR *lp; |
768 |
769 |
770 |
return(0); |
771 |
if ((dp = ep->v.ln->def) != NULL) |
772 |
if (dp->v.kid->type == FUNC) |
773 |
return(dp->type == ':'); |
774 |
else |
775 |
return(0); /* don't identify masked library functions */ |
776 |
if ((lp = ep->v.ln->lib) != NULL) |
777 |
return(lp->atyp == ':'); |
778 |
return(0); |
779 |
