root/radiance/ray/src/common/calexpr.c
Revision: 2.18
Committed: Sat Feb 22 02:07:21 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.17: +97 -84 lines
5 * Compute data values using expression parser
6 *
7 * 7/1/85 Greg Ward
8 *
9 * 11/11/85 Made channel input conditional with (INCHAN) compiles.
10 *
11 * 4/2/86 Added conditional compiles for function definitions (FUNCTION).
12 *
13 * 1/29/87 Made variables conditional (VARIABLE)
14 *
15 * 5/19/88 Added constant subexpression elimination (RCONST)
16 *
17 * 2/19/03 Eliminated conditional compiles in favor of esupport extern.
18 */
19
20 /* ====================================================================
21 * The Radiance Software License, Version 1.0
22 *
23 * Copyright (c) 1990 - 2002 The Regents of the University of California,
24 * through Lawrence Berkeley National Laboratory. All rights reserved.
25 *
26 * Redistribution and use in source and binary forms, with or without
27 * modification, are permitted provided that the following conditions
28 * are met:
29 *
30 * 1. Redistributions of source code must retain the above copyright
31 * notice, this list of conditions and the following disclaimer.
32 *
33 * 2. Redistributions in binary form must reproduce the above copyright
34 * notice, this list of conditions and the following disclaimer in
35 * the documentation and/or other materials provided with the
36 * distribution.
37 *
38 * 3. The end-user documentation included with the redistribution,
39 * if any, must include the following acknowledgment:
40 * "This product includes Radiance software
41 * (http://radsite.lbl.gov/)
42 * developed by the Lawrence Berkeley National Laboratory
43 * (http://www.lbl.gov/)."
44 * Alternately, this acknowledgment may appear in the software itself,
45 * if and wherever such third-party acknowledgments normally appear.
46 *
47 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
48 * and "The Regents of the University of California" must
49 * not be used to endorse or promote products derived from this
50 * software without prior written permission. For written
51 * permission, please contact [email protected].
52 *
53 * 5. Products derived from this software may not be called "Radiance",
54 * nor may "Radiance" appear in their name, without prior written
55 * permission of Lawrence Berkeley National Laboratory.
56 *
57 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
58 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
59 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
60 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
61 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
62 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
63 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
64 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
65 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
66 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
67 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
68 * SUCH DAMAGE.
69 * ====================================================================
70 *
71 * This software consists of voluntary contributions made by many
72 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
73 * information on Lawrence Berkeley National Laboratory, please see
74 * <http://www.lbl.gov/>.
75 */
76
77 #include <stdio.h>
78
79 #include <ctype.h>
80
81 #include <errno.h>
82
83 #include <math.h>
84
85 #include <stdlib.h>
86
87 #include "calcomp.h"
88
89 #define MAXLINE 256 /* maximum line length */
90
91 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
92
93 #define isdecimal(c) (isdigit(c) || (c) == '.')
94
95 static double euminus(), eargument(), enumber();
96 static double echannel();
97 static double eadd(), esubtr(), emult(), edivi(), epow();
98 static double ebotch();
99
100 unsigned int esupport = /* what to support */
101 E_VARIABLE | E_FUNCTION | E_REDEFW;
102
103 int nextc; /* lookahead character */
104
105 double (*eoper[])() = { /* expression operations */
106 ebotch,
107 evariable,
108 enumber,
109 euminus,
110 echannel,
111 efunc,
112 eargument,
113 ebotch,
114 ebotch,
115 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
116 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
117 emult,
118 eadd,
119 0,
120 esubtr,
121 0,
122 edivi,
123 0,0,0,0,0,0,0,0,0,0,
124 ebotch,
125 0,0,
126 ebotch,
127 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
128 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
129 epow,
130 };
131
132 static FILE *infp; /* input file pointer */
133 static char *linbuf; /* line buffer */
134 static char *infile; /* input file name */
135 static int lineno; /* input line number */
136 static int linepos; /* position in buffer */
137
138
139 EPNODE *
140 eparse(expr) /* parse an expression string */
141 char *expr;
142 {
143 EPNODE *ep;
144
145 initstr(expr, NULL, 0);
146 curfunc = NULL;
147 ep = getE1();
148 if (nextc != EOF)
149 syntax("unexpected character");
150 return(ep);
151 }
152
153
154 double
155 eval(expr) /* evaluate an expression string */
156 char *expr;
157 {
158 register EPNODE *ep;
159 double rval;
160
161 ep = eparse(expr);
162 rval = evalue(ep);
163 epfree(ep);
164 return(rval);
165 }
166
167
168 int
169 epcmp(ep1, ep2) /* compare two expressions for equivalence */
170 register EPNODE *ep1, *ep2;
171 {
172 double d;
173
174 if (ep1->type != ep2->type)
175 return(1);
176
177 switch (ep1->type) {
178
179 case VAR:
180 return(ep1->v.ln != ep2->v.ln);
181
182 case NUM:
183 if (ep2->v.num == 0)
184 return(ep1->v.num != 0);
185 d = ep1->v.num / ep2->v.num;
186 return(d > 1.000000000001 | d < 0.999999999999);
187
188 case CHAN:
189 case ARG:
190 return(ep1->v.chan != ep2->v.chan);
191
192 case '=':
193 case ':':
194 return(epcmp(ep1->v.kid->sibling, ep2->v.kid->sibling));
195
196 case TICK:
197 case SYM: /* should never get this one */
198 return(0);
199
200 default:
201 ep1 = ep1->v.kid;
202 ep2 = ep2->v.kid;
203 while (ep1 != NULL) {
204 if (ep2 == NULL)
205 return(1);
206 if (epcmp(ep1, ep2))
207 return(1);
208 ep1 = ep1->sibling;
209 ep2 = ep2->sibling;
210 }
211 return(ep2 != NULL);
212 }
213 }
214
215
216 void
217 epfree(epar) /* free a parse tree */
218 register EPNODE *epar;
219 {
220 register EPNODE *ep;
221
222 switch (epar->type) {
223
224 case VAR:
225 varfree(epar->v.ln);
226 break;
227
228 case SYM:
229 freestr(epar->v.name);
230 break;
231
232 case NUM:
233 case CHAN:
234 case ARG:
235 case TICK:
236 break;
237
238 default:
239 while ((ep = epar->v.kid) != NULL) {
240 epar->v.kid = ep->sibling;
241 epfree(ep);
242 }
243 break;
244
245 }
246
247 efree((char *)epar);
248 }
249
250 /* the following used to be a switch */
251 static double
252 eargument(ep)
253 EPNODE *ep;
254 {
255 return(argument(ep->v.chan));
256 }
257
258 static double
259 enumber(ep)
260 EPNODE *ep;
261 {
262 return(ep->v.num);
263 }
264
265 static double
266 euminus(ep)
267 EPNODE *ep;
268 {
269 register EPNODE *ep1 = ep->v.kid;
270
271 return(-evalue(ep1));
272 }
273
274 static double
275 echannel(ep)
276 EPNODE *ep;
277 {
278 return(chanvalue(ep->v.chan));
279 }
280
281 static double
282 eadd(ep)
283 EPNODE *ep;
284 {
285 register EPNODE *ep1 = ep->v.kid;
286
287 return(evalue(ep1) + evalue(ep1->sibling));
288 }
289
290 static double
291 esubtr(ep)
292 EPNODE *ep;
293 {
294 register EPNODE *ep1 = ep->v.kid;
295
296 return(evalue(ep1) - evalue(ep1->sibling));
297 }
298
299 static double
300 emult(ep)
301 EPNODE *ep;
302 {
303 register EPNODE *ep1 = ep->v.kid;
304
305 return(evalue(ep1) * evalue(ep1->sibling));
306 }
307
308 static double
309 edivi(ep)
310 EPNODE *ep;
311 {
312 register EPNODE *ep1 = ep->v.kid;
313 double d;
314
315 d = evalue(ep1->sibling);
316 if (d == 0.0) {
317 wputs("Division by zero\n");
318 errno = ERANGE;
319 return(0.0);
320 }
321 return(evalue(ep1) / d);
322 }
323
324 static double
325 epow(ep)
326 EPNODE *ep;
327 {
328 register EPNODE *ep1 = ep->v.kid;
329 double d;
330 int lasterrno;
331
332 lasterrno = errno;
333 errno = 0;
334 d = pow(evalue(ep1), evalue(ep1->sibling));
335 #ifdef IEEE
336 if (!finite(d))
337 errno = EDOM;
338 #endif
339 if (errno) {
340 wputs("Illegal power\n");
341 return(0.0);
342 }
343 errno = lasterrno;
344 return(d);
345 }
346
347 static double
348 ebotch(ep)
349 EPNODE *ep;
350 {
351 eputs("Bad expression!\n");
352 quit(1);
353 }
354
355
356 EPNODE *
357 ekid(ep, n) /* return pointer to a node's nth kid */
358 register EPNODE *ep;
359 register int n;
360 {
361
362 for (ep = ep->v.kid; ep != NULL; ep = ep->sibling)
363 if (--n < 0)
364 break;
365
366 return(ep);
367 }
368
369
370 int
371 nekids(ep) /* return # of kids for node ep */
372 register EPNODE *ep;
373 {
374 register int n = 0;
375
376 for (ep = ep->v.kid; ep != NULL; ep = ep->sibling)
377 n++;
378
379 return(n);
380 }
381
382
383 void
384 initfile(fp, fn, ln) /* prepare input file */
385 FILE *fp;
386 char *fn;
387 int ln;
388 {
389 static char inpbuf[MAXLINE];
390
391 infp = fp;
392 linbuf = inpbuf;
393 infile = fn;
394 lineno = ln;
395 linepos = 0;
396 inpbuf[0] = '\0';
397 scan();
398 }
399
400
401 void
402 initstr(s, fn, ln) /* prepare input string */
403 char *s;
404 char *fn;
405 int ln;
406 {
407 infp = NULL;
408 infile = fn;
409 lineno = ln;
410 linbuf = s;
411 linepos = 0;
412 scan();
413 }
414
415
416 void
417 getscanpos(fnp, lnp, spp, fpp) /* return current scan position */
418 char **fnp;
419 int *lnp;
420 char **spp;
421 FILE **fpp;
422 {
423 if (fnp != NULL) *fnp = infile;
424 if (lnp != NULL) *lnp = lineno;
425 if (spp != NULL) *spp = linbuf+linepos;
426 if (fpp != NULL) *fpp = infp;
427 }
428
429
430 int
431 scan() /* scan next character, return literal next */
432 {
433 register int lnext = 0;
434
435 do {
436 if (linbuf[linepos] == '\0')
437 if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL)
438 nextc = EOF;
439 else {
440 nextc = linbuf[0];
441 lineno++;
442 linepos = 1;
443 }
444 else
445 nextc = linbuf[linepos++];
446 if (!lnext)
447 lnext = nextc;
448 if (nextc == '{') {
449 scan();
450 while (nextc != '}')
451 if (nextc == EOF)
452 syntax("'}' expected");
453 else
454 scan();
455 scan();
456 }
457 } while (isspace(nextc));
458 return(lnext);
459 }
460
461
462 char *
463 long2ascii(l) /* convert long to ascii */
464 long l;
465 {
466 static char buf[16];
467 register char *cp;
468 int neg = 0;
469
470 if (l == 0)
471 return("0");
472 if (l < 0) {
473 l = -l;
474 neg++;
475 }
476 cp = buf + sizeof(buf);
477 *--cp = '\0';
478 while (l) {
479 *--cp = l % 10 + '0';
480 l /= 10;
481 }
482 if (neg)
483 *--cp = '-';
484 return(cp);
485 }
486
487
488 void
489 syntax(err) /* report syntax error and quit */
490 char *err;
491 {
492 register int i;
493
494 if (infile != NULL || lineno != 0) {
495 if (infile != NULL) eputs(infile);
496 if (lineno != 0) {
497 eputs(infile != NULL ? ", line " : "line ");
498 eputs(long2ascii((long)lineno));
499 }
500 eputs(":\n");
501 }
502 eputs(linbuf);
503 if (linbuf[strlen(linbuf)-1] != '\n')
504 eputs("\n");
505 for (i = 0; i < linepos-1; i++)
506 eputs(linbuf[i] == '\t' ? "\t" : " ");
507 eputs("^ ");
508 eputs(err);
509 eputs("\n");
510 quit(1);
511 }
512
513
514 void
515 addekid(ep, ekid) /* add a child to ep */
516 register EPNODE *ep;
517 EPNODE *ekid;
518 {
519 if (ep->v.kid == NULL)
520 ep->v.kid = ekid;
521 else {
522 for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling)
523 ;
524 ep->sibling = ekid;
525 }
526 ekid->sibling = NULL;
527 }
528
529
530 char *
531 getname() /* scan an identifier */
532 {
533 static char str[MAXWORD+1];
534 register int i, lnext;
535
536 lnext = nextc;
537 for (i = 0; i < MAXWORD && isid(lnext); i++, lnext = scan())
538 str[i] = lnext;
539 str[i] = '\0';
540 while (isid(lnext)) /* skip rest of name */
541 lnext = scan();
542
543 return(str);
544 }
545
546
547 int
548 getinum() /* scan a positive integer */
549 {
550 register int n, lnext;
551
552 n = 0;
553 lnext = nextc;
554 while (isdigit(lnext)) {
555 n = n * 10 + lnext - '0';
556 lnext = scan();
557 }
558 return(n);
559 }
560
561
562 double
563 getnum() /* scan a positive float */
564 {
565 register int i, lnext;
566 char str[MAXWORD+1];
567
568 i = 0;
569 lnext = nextc;
570 while (isdigit(lnext) && i < MAXWORD) {
571 str[i++] = lnext;
572 lnext = scan();
573 }
574 if (lnext == '.' && i < MAXWORD) {
575 str[i++] = lnext;
576 lnext = scan();
577 if (i == 1 && !isdigit(lnext))
578 syntax("badly formed number");
579 while (isdigit(lnext) && i < MAXWORD) {
580 str[i++] = lnext;
581 lnext = scan();
582 }
583 }
584 if ((lnext == 'e' | lnext == 'E') && i < MAXWORD) {
585 str[i++] = lnext;
586 lnext = scan();
587 if ((lnext == '-' | lnext == '+') && i < MAXWORD) {
588 str[i++] = lnext;
589 lnext = scan();
590 }
591 if (!isdigit(lnext))
592 syntax("missing exponent");
593 while (isdigit(lnext) && i < MAXWORD) {
594 str[i++] = lnext;
595 lnext = scan();
596 }
597 }
598 str[i] = '\0';
599
600 return(atof(str));
601 }
602
603
604 EPNODE *
605 getE1() /* E1 -> E1 ADDOP E2 */
606 /* E2 */
607 {
608 register EPNODE *ep1, *ep2;
609
610 ep1 = getE2();
611 while (nextc == '+' || nextc == '-') {
612 ep2 = newnode();
613 ep2->type = nextc;
614 scan();
615 addekid(ep2, ep1);
616 addekid(ep2, getE2());
617 if (esupport&E_RCONST &&
618 ep1->type == NUM && ep1->sibling->type == NUM)
619 ep2 = rconst(ep2);
620 ep1 = ep2;
621 }
622 return(ep1);
623 }
624
625
626 EPNODE *
627 getE2() /* E2 -> E2 MULOP E3 */
628 /* E3 */
629 {
630 register EPNODE *ep1, *ep2;
631
632 ep1 = getE3();
633 while (nextc == '*' || nextc == '/') {
634 ep2 = newnode();
635 ep2->type = nextc;
636 scan();
637 addekid(ep2, ep1);
638 addekid(ep2, getE3());
639 if (esupport&E_RCONST &&
640 ep1->type == NUM && ep1->sibling->type == NUM)
641 ep2 = rconst(ep2);
642 ep1 = ep2;
643 }
644 return(ep1);
645 }
646
647
648 EPNODE *
649 getE3() /* E3 -> E4 ^ E3 */
650 /* E4 */
651 {
652 register EPNODE *ep1, *ep2;
653
654 ep1 = getE4();
655 if (nextc == '^') {
656 ep2 = newnode();
657 ep2->type = nextc;
658 scan();
659 addekid(ep2, ep1);
660 addekid(ep2, getE3());
661 if (esupport&E_RCONST &&
662 ep1->type == NUM && ep1->sibling->type == NUM)
663 ep2 = rconst(ep2);
664 return(ep2);
665 }
666 return(ep1);
667 }
668
669
670 EPNODE *
671 getE4() /* E4 -> ADDOP E5 */
672 /* E5 */
673 {
674 register EPNODE *ep1, *ep2;
675
676 if (nextc == '-') {
677 scan();
678 ep2 = getE5();
679 if (ep2->type == NUM) {
680 ep2->v.num = -ep2->v.num;
681 return(ep2);
682 }
683 if (ep2->type == UMINUS) { /* don't generate -(-E5) */
684 efree((char *)ep2);
685 return(ep2->v.kid);
686 }
687 ep1 = newnode();
688 ep1->type = UMINUS;
689 addekid(ep1, ep2);
690 return(ep1);
691 }
692 if (nextc == '+')
693 scan();
694 return(getE5());
695 }
696
697
698 EPNODE *
699 getE5() /* E5 -> (E1) */
700 /* VAR */
701 /* NUM */
702 /* $N */
703 /* FUNC(E1,..) */
704 /* ARG */
705 {
706 int i;
707 char *nam;
708 register EPNODE *ep1, *ep2;
709
710 if (nextc == '(') {
711 scan();
712 ep1 = getE1();
713 if (nextc != ')')
714 syntax("')' expected");
715 scan();
716 return(ep1);
717 }
718
719 if (esupport&E_INCHAN && nextc == '$') {
720 scan();
721 ep1 = newnode();
722 ep1->type = CHAN;
723 ep1->v.chan = getinum();
724 return(ep1);
725 }
726
727 if (esupport&(E_VARIABLE|E_FUNCTION) &&
728 (isalpha(nextc) || nextc == CNTXMARK)) {
729 nam = getname();
730 ep1 = NULL;
731 if ((esupport&(E_VARIABLE|E_FUNCTION)) == (E_VARIABLE|E_FUNCTION)
732 && curfunc != NULL)
733 for (i = 1, ep2 = curfunc->v.kid->sibling;
734 ep2 != NULL; i++, ep2 = ep2->sibling)
735 if (!strcmp(ep2->v.name, nam)) {
736 ep1 = newnode();
737 ep1->type = ARG;
738 ep1->v.chan = i;
739 break;
740 }
741 if (ep1 == NULL) {
742 ep1 = newnode();
743 ep1->type = VAR;
744 ep1->v.ln = varinsert(nam);
745 }
746 if (esupport&E_FUNCTION && nextc == '(') {
747 ep2 = newnode();
748 ep2->type = FUNC;
749 addekid(ep2, ep1);
750 ep1 = ep2;
751 do {
752 scan();
753 addekid(ep1, getE1());
754 } while (nextc == ',');
755 if (nextc != ')')
756 syntax("')' expected");
757 scan();
758 } else if (!(esupport&E_VARIABLE))
759 syntax("'(' expected");
760 if (esupport&E_RCONST && isconstvar(ep1))
761 ep1 = rconst(ep1);
762 return(ep1);
763 }
764
765 if (isdecimal(nextc)) {
766 ep1 = newnode();
767 ep1->type = NUM;
768 ep1->v.num = getnum();
769 return(ep1);
770 }
771 syntax("unexpected character");
772 }
773
774
775 EPNODE *
776 rconst(epar) /* reduce a constant expression */
777 register EPNODE *epar;
778 {
779 register EPNODE *ep;
780
781 ep = newnode();
782 ep->type = NUM;
783 errno = 0;
784 ep->v.num = evalue(epar);
785 if (errno)
786 syntax("bad constant expression");
787 epfree(epar);
788
789 return(ep);
790 }
791
792
793 int
794 isconstvar(ep) /* is ep linked to a constant expression? */
795 register EPNODE *ep;
796 {
797 register EPNODE *ep1;
798
799 if (esupport&E_FUNCTION && ep->type == FUNC) {
800 if (!isconstfun(ep->v.kid))
801 return(0);
802 for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling)
803 if (ep1->type != NUM && !isconstfun(ep1))
804 return(0);
805 return(1);
806 }
807 if (ep->type != VAR)
808 return(0);
809 ep1 = ep->v.ln->def;
810 if (ep1 == NULL || ep1->type != ':')
811 return(0);
812 if (esupport&E_FUNCTION && ep1->v.kid->type != SYM)
813 return(0);
814 return(1);
815 }
816
817
818 int
819 isconstfun(ep) /* is ep linked to a constant function? */
820 register EPNODE *ep;
821 {
822 register EPNODE *dp;
823 register LIBR *lp;
824
825 if (ep->type != VAR)
826 return(0);
827 if ((dp = ep->v.ln->def) != NULL)
828 if (dp->v.kid->type == FUNC)
829 return(dp->type == ':');
830 else
831 return(0); /* don't identify masked library functions */
832 if ((lp = ep->v.ln->lib) != NULL)
833 return(lp->atyp == ':');
834 return(0);
835 }
