1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Compute data values using expression parser |
6 |
7 |
* 7/1/85 Greg Ward |
8 |
9 |
* 11/11/85 Made channel input conditional with (INCHAN) compiles. |
10 |
11 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION). |
12 |
13 |
* 1/29/87 Made variables conditional (VARIABLE) |
14 |
15 |
* 5/19/88 Added constant subexpression elimination (RCONST) |
16 |
17 |
* 2/19/03 Eliminated conditional compiles in favor of esupport extern. |
18 |
19 |
20 |
21 |
* The Radiance Software License, Version 1.0 |
22 |
23 |
* Copyright (c) 1990 - 2002 The Regents of the University of California, |
24 |
* through Lawrence Berkeley National Laboratory. All rights reserved. |
25 |
26 |
* Redistribution and use in source and binary forms, with or without |
27 |
* modification, are permitted provided that the following conditions |
28 |
* are met: |
29 |
30 |
* 1. Redistributions of source code must retain the above copyright |
31 |
* notice, this list of conditions and the following disclaimer. |
32 |
33 |
* 2. Redistributions in binary form must reproduce the above copyright |
34 |
* notice, this list of conditions and the following disclaimer in |
35 |
* the documentation and/or other materials provided with the |
36 |
* distribution. |
37 |
38 |
* 3. The end-user documentation included with the redistribution, |
39 |
* if any, must include the following acknowledgment: |
40 |
* "This product includes Radiance software |
41 |
* (http://radsite.lbl.gov/) |
42 |
* developed by the Lawrence Berkeley National Laboratory |
43 |
* (http://www.lbl.gov/)." |
44 |
* Alternately, this acknowledgment may appear in the software itself, |
45 |
* if and wherever such third-party acknowledgments normally appear. |
46 |
47 |
* 4. The names "Radiance," "Lawrence Berkeley National Laboratory" |
48 |
* and "The Regents of the University of California" must |
49 |
* not be used to endorse or promote products derived from this |
50 |
* software without prior written permission. For written |
51 |
* permission, please contact [email protected]. |
52 |
53 |
* 5. Products derived from this software may not be called "Radiance", |
54 |
* nor may "Radiance" appear in their name, without prior written |
55 |
* permission of Lawrence Berkeley National Laboratory. |
56 |
57 |
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED |
58 |
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES |
59 |
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE |
60 |
* DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR |
61 |
* ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, |
62 |
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT |
63 |
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF |
64 |
* USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND |
65 |
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, |
66 |
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT |
67 |
* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF |
68 |
* SUCH DAMAGE. |
69 |
70 |
71 |
* This software consists of voluntary contributions made by many |
72 |
* individuals on behalf of Lawrence Berkeley National Laboratory. For more |
73 |
* information on Lawrence Berkeley National Laboratory, please see |
74 |
* <http://www.lbl.gov/>. |
75 |
76 |
77 |
#include <stdio.h> |
78 |
79 |
#include <ctype.h> |
80 |
81 |
#include <errno.h> |
82 |
83 |
#include <math.h> |
84 |
85 |
#include <stdlib.h> |
86 |
87 |
#include "calcomp.h" |
88 |
89 |
#define MAXLINE 256 /* maximum line length */ |
90 |
91 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) |
92 |
93 |
#define isdecimal(c) (isdigit(c) || (c) == '.') |
94 |
95 |
static double euminus(), eargument(), enumber(); |
96 |
static double echannel(); |
97 |
static double eadd(), esubtr(), emult(), edivi(), epow(); |
98 |
static double ebotch(); |
99 |
100 |
unsigned int esupport = /* what to support */ |
101 |
E_VARIABLE | E_FUNCTION | E_REDEFW; |
102 |
103 |
int nextc; /* lookahead character */ |
104 |
105 |
double (*eoper[])() = { /* expression operations */ |
106 |
ebotch, |
107 |
evariable, |
108 |
enumber, |
109 |
euminus, |
110 |
echannel, |
111 |
efunc, |
112 |
eargument, |
113 |
ebotch, |
114 |
ebotch, |
115 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
116 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
117 |
emult, |
118 |
eadd, |
119 |
0, |
120 |
esubtr, |
121 |
0, |
122 |
edivi, |
123 |
124 |
ebotch, |
125 |
0,0, |
126 |
ebotch, |
127 |
128 |
129 |
epow, |
130 |
131 |
132 |
static FILE *infp; /* input file pointer */ |
133 |
static char *linbuf; /* line buffer */ |
134 |
static char *infile; /* input file name */ |
135 |
static int lineno; /* input line number */ |
136 |
static int linepos; /* position in buffer */ |
137 |
138 |
139 |
EPNODE * |
140 |
eparse(expr) /* parse an expression string */ |
141 |
char *expr; |
142 |
143 |
EPNODE *ep; |
144 |
145 |
initstr(expr, NULL, 0); |
146 |
curfunc = NULL; |
147 |
ep = getE1(); |
148 |
if (nextc != EOF) |
149 |
syntax("unexpected character"); |
150 |
return(ep); |
151 |
152 |
153 |
154 |
double |
155 |
eval(expr) /* evaluate an expression string */ |
156 |
char *expr; |
157 |
158 |
register EPNODE *ep; |
159 |
double rval; |
160 |
161 |
ep = eparse(expr); |
162 |
rval = evalue(ep); |
163 |
epfree(ep); |
164 |
return(rval); |
165 |
166 |
167 |
168 |
int |
169 |
epcmp(ep1, ep2) /* compare two expressions for equivalence */ |
170 |
register EPNODE *ep1, *ep2; |
171 |
172 |
double d; |
173 |
174 |
if (ep1->type != ep2->type) |
175 |
return(1); |
176 |
177 |
switch (ep1->type) { |
178 |
179 |
case VAR: |
180 |
return(ep1->v.ln != ep2->v.ln); |
181 |
182 |
case NUM: |
183 |
if (ep2->v.num == 0) |
184 |
return(ep1->v.num != 0); |
185 |
d = ep1->v.num / ep2->v.num; |
186 |
return(d > 1.000000000001 | d < 0.999999999999); |
187 |
188 |
case CHAN: |
189 |
case ARG: |
190 |
return(ep1->v.chan != ep2->v.chan); |
191 |
192 |
case '=': |
193 |
case ':': |
194 |
return(epcmp(ep1->v.kid->sibling, ep2->v.kid->sibling)); |
195 |
196 |
case TICK: |
197 |
case SYM: /* should never get this one */ |
198 |
return(0); |
199 |
200 |
default: |
201 |
ep1 = ep1->v.kid; |
202 |
ep2 = ep2->v.kid; |
203 |
while (ep1 != NULL) { |
204 |
if (ep2 == NULL) |
205 |
return(1); |
206 |
if (epcmp(ep1, ep2)) |
207 |
return(1); |
208 |
ep1 = ep1->sibling; |
209 |
ep2 = ep2->sibling; |
210 |
211 |
return(ep2 != NULL); |
212 |
213 |
214 |
215 |
216 |
void |
217 |
epfree(epar) /* free a parse tree */ |
218 |
register EPNODE *epar; |
219 |
220 |
221 |
222 |
switch (epar->type) { |
223 |
224 |
case VAR: |
225 |
varfree(epar->v.ln); |
226 |
break; |
227 |
228 |
case SYM: |
229 |
freestr(epar->v.name); |
230 |
break; |
231 |
232 |
case NUM: |
233 |
case CHAN: |
234 |
case ARG: |
235 |
case TICK: |
236 |
break; |
237 |
238 |
default: |
239 |
while ((ep = epar->v.kid) != NULL) { |
240 |
epar->v.kid = ep->sibling; |
241 |
epfree(ep); |
242 |
243 |
break; |
244 |
245 |
246 |
247 |
efree((char *)epar); |
248 |
249 |
250 |
/* the following used to be a switch */ |
251 |
static double |
252 |
eargument(ep) |
253 |
EPNODE *ep; |
254 |
255 |
return(argument(ep->v.chan)); |
256 |
257 |
258 |
static double |
259 |
enumber(ep) |
260 |
EPNODE *ep; |
261 |
262 |
return(ep->v.num); |
263 |
264 |
265 |
static double |
266 |
euminus(ep) |
267 |
EPNODE *ep; |
268 |
269 |
register EPNODE *ep1 = ep->v.kid; |
270 |
271 |
return(-evalue(ep1)); |
272 |
273 |
274 |
static double |
275 |
echannel(ep) |
276 |
EPNODE *ep; |
277 |
278 |
return(chanvalue(ep->v.chan)); |
279 |
280 |
281 |
static double |
282 |
eadd(ep) |
283 |
EPNODE *ep; |
284 |
285 |
286 |
287 |
return(evalue(ep1) + evalue(ep1->sibling)); |
288 |
289 |
290 |
static double |
291 |
esubtr(ep) |
292 |
EPNODE *ep; |
293 |
294 |
295 |
296 |
return(evalue(ep1) - evalue(ep1->sibling)); |
297 |
298 |
299 |
static double |
300 |
emult(ep) |
301 |
EPNODE *ep; |
302 |
303 |
304 |
305 |
return(evalue(ep1) * evalue(ep1->sibling)); |
306 |
307 |
308 |
static double |
309 |
edivi(ep) |
310 |
EPNODE *ep; |
311 |
312 |
313 |
double d; |
314 |
315 |
d = evalue(ep1->sibling); |
316 |
if (d == 0.0) { |
317 |
wputs("Division by zero\n"); |
318 |
errno = ERANGE; |
319 |
return(0.0); |
320 |
321 |
return(evalue(ep1) / d); |
322 |
323 |
324 |
static double |
325 |
epow(ep) |
326 |
EPNODE *ep; |
327 |
328 |
329 |
double d; |
330 |
int lasterrno; |
331 |
332 |
lasterrno = errno; |
333 |
errno = 0; |
334 |
d = pow(evalue(ep1), evalue(ep1->sibling)); |
335 |
#ifdef IEEE |
336 |
if (!finite(d)) |
337 |
errno = EDOM; |
338 |
#endif |
339 |
if (errno) { |
340 |
wputs("Illegal power\n"); |
341 |
return(0.0); |
342 |
343 |
errno = lasterrno; |
344 |
return(d); |
345 |
346 |
347 |
static double |
348 |
ebotch(ep) |
349 |
EPNODE *ep; |
350 |
351 |
eputs("Bad expression!\n"); |
352 |
quit(1); |
353 |
354 |
355 |
356 |
EPNODE * |
357 |
ekid(ep, n) /* return pointer to a node's nth kid */ |
358 |
359 |
register int n; |
360 |
361 |
362 |
for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) |
363 |
if (--n < 0) |
364 |
break; |
365 |
366 |
return(ep); |
367 |
368 |
369 |
370 |
int |
371 |
nekids(ep) /* return # of kids for node ep */ |
372 |
373 |
374 |
register int n = 0; |
375 |
376 |
377 |
n++; |
378 |
379 |
return(n); |
380 |
381 |
382 |
383 |
void |
384 |
initfile(fp, fn, ln) /* prepare input file */ |
385 |
FILE *fp; |
386 |
char *fn; |
387 |
int ln; |
388 |
389 |
static char inpbuf[MAXLINE]; |
390 |
391 |
infp = fp; |
392 |
linbuf = inpbuf; |
393 |
infile = fn; |
394 |
lineno = ln; |
395 |
linepos = 0; |
396 |
inpbuf[0] = '\0'; |
397 |
scan(); |
398 |
399 |
400 |
401 |
void |
402 |
initstr(s, fn, ln) /* prepare input string */ |
403 |
char *s; |
404 |
char *fn; |
405 |
int ln; |
406 |
407 |
infp = NULL; |
408 |
infile = fn; |
409 |
lineno = ln; |
410 |
linbuf = s; |
411 |
linepos = 0; |
412 |
scan(); |
413 |
414 |
415 |
416 |
void |
417 |
getscanpos(fnp, lnp, spp, fpp) /* return current scan position */ |
418 |
char **fnp; |
419 |
int *lnp; |
420 |
char **spp; |
421 |
FILE **fpp; |
422 |
423 |
if (fnp != NULL) *fnp = infile; |
424 |
if (lnp != NULL) *lnp = lineno; |
425 |
if (spp != NULL) *spp = linbuf+linepos; |
426 |
if (fpp != NULL) *fpp = infp; |
427 |
428 |
429 |
430 |
int |
431 |
scan() /* scan next character, return literal next */ |
432 |
433 |
register int lnext = 0; |
434 |
435 |
do { |
436 |
if (linbuf[linepos] == '\0') |
437 |
if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL) |
438 |
nextc = EOF; |
439 |
else { |
440 |
nextc = linbuf[0]; |
441 |
lineno++; |
442 |
linepos = 1; |
443 |
444 |
else |
445 |
nextc = linbuf[linepos++]; |
446 |
if (!lnext) |
447 |
lnext = nextc; |
448 |
if (nextc == '{') { |
449 |
scan(); |
450 |
while (nextc != '}') |
451 |
if (nextc == EOF) |
452 |
syntax("'}' expected"); |
453 |
else |
454 |
scan(); |
455 |
scan(); |
456 |
457 |
} while (isspace(nextc)); |
458 |
return(lnext); |
459 |
460 |
461 |
462 |
char * |
463 |
long2ascii(l) /* convert long to ascii */ |
464 |
long l; |
465 |
466 |
static char buf[16]; |
467 |
register char *cp; |
468 |
int neg = 0; |
469 |
470 |
if (l == 0) |
471 |
return("0"); |
472 |
if (l < 0) { |
473 |
l = -l; |
474 |
neg++; |
475 |
476 |
cp = buf + sizeof(buf); |
477 |
*--cp = '\0'; |
478 |
while (l) { |
479 |
*--cp = l % 10 + '0'; |
480 |
l /= 10; |
481 |
482 |
if (neg) |
483 |
*--cp = '-'; |
484 |
return(cp); |
485 |
486 |
487 |
488 |
void |
489 |
syntax(err) /* report syntax error and quit */ |
490 |
char *err; |
491 |
492 |
register int i; |
493 |
494 |
if (infile != NULL || lineno != 0) { |
495 |
if (infile != NULL) eputs(infile); |
496 |
if (lineno != 0) { |
497 |
eputs(infile != NULL ? ", line " : "line "); |
498 |
eputs(long2ascii((long)lineno)); |
499 |
500 |
eputs(":\n"); |
501 |
502 |
eputs(linbuf); |
503 |
if (linbuf[strlen(linbuf)-1] != '\n') |
504 |
eputs("\n"); |
505 |
for (i = 0; i < linepos-1; i++) |
506 |
eputs(linbuf[i] == '\t' ? "\t" : " "); |
507 |
eputs("^ "); |
508 |
eputs(err); |
509 |
eputs("\n"); |
510 |
quit(1); |
511 |
512 |
513 |
514 |
void |
515 |
addekid(ep, ekid) /* add a child to ep */ |
516 |
517 |
EPNODE *ekid; |
518 |
519 |
if (ep->v.kid == NULL) |
520 |
ep->v.kid = ekid; |
521 |
else { |
522 |
for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling) |
523 |
524 |
ep->sibling = ekid; |
525 |
526 |
ekid->sibling = NULL; |
527 |
528 |
529 |
530 |
char * |
531 |
getname() /* scan an identifier */ |
532 |
533 |
static char str[MAXWORD+1]; |
534 |
register int i, lnext; |
535 |
536 |
lnext = nextc; |
537 |
for (i = 0; i < MAXWORD && isid(lnext); i++, lnext = scan()) |
538 |
str[i] = lnext; |
539 |
str[i] = '\0'; |
540 |
while (isid(lnext)) /* skip rest of name */ |
541 |
lnext = scan(); |
542 |
543 |
return(str); |
544 |
545 |
546 |
547 |
int |
548 |
getinum() /* scan a positive integer */ |
549 |
550 |
register int n, lnext; |
551 |
552 |
n = 0; |
553 |
lnext = nextc; |
554 |
while (isdigit(lnext)) { |
555 |
n = n * 10 + lnext - '0'; |
556 |
lnext = scan(); |
557 |
558 |
return(n); |
559 |
560 |
561 |
562 |
double |
563 |
getnum() /* scan a positive float */ |
564 |
565 |
566 |
567 |
568 |
i = 0; |
569 |
lnext = nextc; |
570 |
while (isdigit(lnext) && i < MAXWORD) { |
571 |
str[i++] = lnext; |
572 |
lnext = scan(); |
573 |
574 |
if (lnext == '.' && i < MAXWORD) { |
575 |
str[i++] = lnext; |
576 |
lnext = scan(); |
577 |
if (i == 1 && !isdigit(lnext)) |
578 |
syntax("badly formed number"); |
579 |
580 |
str[i++] = lnext; |
581 |
lnext = scan(); |
582 |
583 |
584 |
if ((lnext == 'e' | lnext == 'E') && i < MAXWORD) { |
585 |
str[i++] = lnext; |
586 |
lnext = scan(); |
587 |
if ((lnext == '-' | lnext == '+') && i < MAXWORD) { |
588 |
str[i++] = lnext; |
589 |
lnext = scan(); |
590 |
591 |
if (!isdigit(lnext)) |
592 |
syntax("missing exponent"); |
593 |
594 |
str[i++] = lnext; |
595 |
lnext = scan(); |
596 |
597 |
598 |
str[i] = '\0'; |
599 |
600 |
return(atof(str)); |
601 |
602 |
603 |
604 |
EPNODE * |
605 |
getE1() /* E1 -> E1 ADDOP E2 */ |
606 |
/* E2 */ |
607 |
608 |
609 |
610 |
ep1 = getE2(); |
611 |
while (nextc == '+' || nextc == '-') { |
612 |
ep2 = newnode(); |
613 |
ep2->type = nextc; |
614 |
scan(); |
615 |
addekid(ep2, ep1); |
616 |
addekid(ep2, getE2()); |
617 |
if (esupport&E_RCONST && |
618 |
ep1->type == NUM && ep1->sibling->type == NUM) |
619 |
ep2 = rconst(ep2); |
620 |
ep1 = ep2; |
621 |
622 |
return(ep1); |
623 |
624 |
625 |
626 |
EPNODE * |
627 |
getE2() /* E2 -> E2 MULOP E3 */ |
628 |
/* E3 */ |
629 |
630 |
631 |
632 |
ep1 = getE3(); |
633 |
while (nextc == '*' || nextc == '/') { |
634 |
ep2 = newnode(); |
635 |
636 |
scan(); |
637 |
638 |
addekid(ep2, getE3()); |
639 |
640 |
641 |
642 |
ep1 = ep2; |
643 |
644 |
return(ep1); |
645 |
646 |
647 |
648 |
EPNODE * |
649 |
getE3() /* E3 -> E4 ^ E3 */ |
650 |
/* E4 */ |
651 |
652 |
653 |
654 |
ep1 = getE4(); |
655 |
if (nextc == '^') { |
656 |
ep2 = newnode(); |
657 |
658 |
scan(); |
659 |
660 |
661 |
662 |
663 |
664 |
return(ep2); |
665 |
666 |
return(ep1); |
667 |
668 |
669 |
670 |
EPNODE * |
671 |
getE4() /* E4 -> ADDOP E5 */ |
672 |
/* E5 */ |
673 |
674 |
675 |
676 |
if (nextc == '-') { |
677 |
scan(); |
678 |
ep2 = getE5(); |
679 |
if (ep2->type == NUM) { |
680 |
ep2->v.num = -ep2->v.num; |
681 |
return(ep2); |
682 |
683 |
if (ep2->type == UMINUS) { /* don't generate -(-E5) */ |
684 |
efree((char *)ep2); |
685 |
return(ep2->v.kid); |
686 |
687 |
ep1 = newnode(); |
688 |
ep1->type = UMINUS; |
689 |
addekid(ep1, ep2); |
690 |
return(ep1); |
691 |
692 |
if (nextc == '+') |
693 |
scan(); |
694 |
return(getE5()); |
695 |
696 |
697 |
698 |
EPNODE * |
699 |
getE5() /* E5 -> (E1) */ |
700 |
/* VAR */ |
701 |
/* NUM */ |
702 |
/* $N */ |
703 |
/* FUNC(E1,..) */ |
704 |
/* ARG */ |
705 |
706 |
int i; |
707 |
char *nam; |
708 |
709 |
710 |
if (nextc == '(') { |
711 |
scan(); |
712 |
ep1 = getE1(); |
713 |
if (nextc != ')') |
714 |
syntax("')' expected"); |
715 |
scan(); |
716 |
return(ep1); |
717 |
718 |
719 |
if (esupport&E_INCHAN && nextc == '$') { |
720 |
scan(); |
721 |
ep1 = newnode(); |
722 |
ep1->type = CHAN; |
723 |
ep1->v.chan = getinum(); |
724 |
return(ep1); |
725 |
726 |
727 |
if (esupport&(E_VARIABLE|E_FUNCTION) && |
728 |
(isalpha(nextc) || nextc == CNTXMARK)) { |
729 |
nam = getname(); |
730 |
ep1 = NULL; |
731 |
if ((esupport&(E_VARIABLE|E_FUNCTION)) == (E_VARIABLE|E_FUNCTION) |
732 |
&& curfunc != NULL) |
733 |
for (i = 1, ep2 = curfunc->v.kid->sibling; |
734 |
ep2 != NULL; i++, ep2 = ep2->sibling) |
735 |
if (!strcmp(ep2->v.name, nam)) { |
736 |
ep1 = newnode(); |
737 |
ep1->type = ARG; |
738 |
ep1->v.chan = i; |
739 |
break; |
740 |
741 |
if (ep1 == NULL) { |
742 |
ep1 = newnode(); |
743 |
ep1->type = VAR; |
744 |
ep1->v.ln = varinsert(nam); |
745 |
746 |
if (esupport&E_FUNCTION && nextc == '(') { |
747 |
ep2 = newnode(); |
748 |
ep2->type = FUNC; |
749 |
750 |
ep1 = ep2; |
751 |
do { |
752 |
scan(); |
753 |
addekid(ep1, getE1()); |
754 |
} while (nextc == ','); |
755 |
if (nextc != ')') |
756 |
757 |
scan(); |
758 |
} else if (!(esupport&E_VARIABLE)) |
759 |
syntax("'(' expected"); |
760 |
if (esupport&E_RCONST && isconstvar(ep1)) |
761 |
ep1 = rconst(ep1); |
762 |
return(ep1); |
763 |
764 |
765 |
if (isdecimal(nextc)) { |
766 |
ep1 = newnode(); |
767 |
ep1->type = NUM; |
768 |
ep1->v.num = getnum(); |
769 |
return(ep1); |
770 |
771 |
772 |
773 |
774 |
775 |
EPNODE * |
776 |
rconst(epar) /* reduce a constant expression */ |
777 |
778 |
779 |
780 |
781 |
ep = newnode(); |
782 |
ep->type = NUM; |
783 |
errno = 0; |
784 |
ep->v.num = evalue(epar); |
785 |
if (errno) |
786 |
syntax("bad constant expression"); |
787 |
epfree(epar); |
788 |
789 |
return(ep); |
790 |
791 |
792 |
793 |
int |
794 |
isconstvar(ep) /* is ep linked to a constant expression? */ |
795 |
796 |
797 |
register EPNODE *ep1; |
798 |
799 |
if (esupport&E_FUNCTION && ep->type == FUNC) { |
800 |
if (!isconstfun(ep->v.kid)) |
801 |
return(0); |
802 |
for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling) |
803 |
if (ep1->type != NUM && !isconstfun(ep1)) |
804 |
return(0); |
805 |
return(1); |
806 |
807 |
if (ep->type != VAR) |
808 |
return(0); |
809 |
ep1 = ep->v.ln->def; |
810 |
if (ep1 == NULL || ep1->type != ':') |
811 |
return(0); |
812 |
if (esupport&E_FUNCTION && ep1->v.kid->type != SYM) |
813 |
return(0); |
814 |
return(1); |
815 |
816 |
817 |
818 |
int |
819 |
isconstfun(ep) /* is ep linked to a constant function? */ |
820 |
821 |
822 |
register EPNODE *dp; |
823 |
register LIBR *lp; |
824 |
825 |
826 |
return(0); |
827 |
if ((dp = ep->v.ln->def) != NULL) |
828 |
if (dp->v.kid->type == FUNC) |
829 |
return(dp->type == ':'); |
830 |
else |
831 |
return(0); /* don't identify masked library functions */ |
832 |
if ((lp = ep->v.ln->lib) != NULL) |
833 |
return(lp->atyp == ':'); |
834 |
return(0); |
835 |
