root/radiance/ray/src/common/calexpr.c
Revision: 2.17
Committed: Mon Aug 17 17:57:30 1998 UTC (25 years, 8 months ago) by gwlarson
Changes since 2.16: +8 -4 lines
added more careful typing of numbers
1 /* Copyright (c) 1998 Silicon Graphics, Inc. */
2
3 #ifndef lint
4 static char SCCSid[] = "$SunId$ SGI";
5 #endif
6
7 /*
8 * Compute data values using expression parser
9 *
10 * 7/1/85 Greg Ward
11 *
12 * 11/11/85 Made channel input conditional with (INCHAN) compiles.
13 *
14 * 4/2/86 Added conditional compiles for function definitions (FUNCTION).
15 *
16 * 1/29/87 Made variables conditional (VARIABLE)
17 *
18 * 5/19/88 Added constant subexpression elimination (RCONST)
19 */
20
21 #include <stdio.h>
22
23 #include <ctype.h>
24
25 #include <errno.h>
26
27 #include <math.h>
28
29 #include "calcomp.h"
30
31 #define MAXLINE 256 /* maximum line length */
32
33 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
34
35 #define isdecimal(c) (isdigit(c) || (c) == '.')
36
37 extern char *savestr();
38 extern char *emalloc(), *ecalloc();
39 extern EPNODE *curfunc;
40 extern double efunc(), evariable();
41 static double euminus(), eargument(), enumber();
42 #ifdef INCHAN
43 static double echannel();
44 #endif
45 static double eadd(), esubtr(), emult(), edivi(), epow();
46 static double ebotch();
47
48 #ifdef DCL_ATOF
49 extern double atof();
50 #endif
51
52 int nextc; /* lookahead character */
53
54 double (*eoper[])() = { /* expression operations */
55 ebotch,
56 #ifdef VARIABLE
57 evariable,
58 #else
59 ebotch,
60 #endif
61 enumber,
62 euminus,
63 #ifdef INCHAN
64 echannel,
65 #else
66 ebotch,
67 #endif
68 #ifdef FUNCTION
69 efunc,
70 eargument,
71 #else
72 ebotch,
73 ebotch,
74 #endif
75 ebotch,
76 ebotch,
77 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
78 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
79 emult,
80 eadd,
81 0,
82 esubtr,
83 0,
84 edivi,
85 0,0,0,0,0,0,0,0,0,0,
86 ebotch,
87 0,0,
88 ebotch,
89 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
90 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
91 epow,
92 };
93
94 static FILE *infp; /* input file pointer */
95 static char *linbuf; /* line buffer */
96 static char *infile; /* input file name */
97 static int lineno; /* input line number */
98 static int linepos; /* position in buffer */
99
100
101 EPNODE *
102 eparse(expr) /* parse an expression string */
103 char *expr;
104 {
105 EPNODE *ep;
106
107 initstr(expr, NULL, 0);
108 #if defined(VARIABLE) && defined(FUNCTION)
109 curfunc = NULL;
110 #endif
111 ep = getE1();
112 if (nextc != EOF)
113 syntax("unexpected character");
114 return(ep);
115 }
116
117
118 double
119 eval(expr) /* evaluate an expression string */
120 char *expr;
121 {
122 register EPNODE *ep;
123 double rval;
124
125 ep = eparse(expr);
126 rval = evalue(ep);
127 epfree(ep);
128 return(rval);
129 }
130
131
132 epcmp(ep1, ep2) /* compare two expressions for equivalence */
133 register EPNODE *ep1, *ep2;
134 {
135 double d;
136
137 if (ep1->type != ep2->type)
138 return(1);
139
140 switch (ep1->type) {
141
142 case VAR:
143 return(ep1->v.ln != ep2->v.ln);
144
145 case NUM:
146 if (ep2->v.num == 0)
147 return(ep1->v.num != 0);
148 d = ep1->v.num / ep2->v.num;
149 return(d > 1.000000000001 | d < 0.999999999999);
150
151 case CHAN:
152 case ARG:
153 return(ep1->v.chan != ep2->v.chan);
154
155 case '=':
156 case ':':
157 return(epcmp(ep1->v.kid->sibling, ep2->v.kid->sibling));
158
159 case TICK:
160 case SYM: /* should never get this one */
161 return(0);
162
163 default:
164 ep1 = ep1->v.kid;
165 ep2 = ep2->v.kid;
166 while (ep1 != NULL) {
167 if (ep2 == NULL)
168 return(1);
169 if (epcmp(ep1, ep2))
170 return(1);
171 ep1 = ep1->sibling;
172 ep2 = ep2->sibling;
173 }
174 return(ep2 != NULL);
175 }
176 }
177
178
179 epfree(epar) /* free a parse tree */
180 register EPNODE *epar;
181 {
182 register EPNODE *ep;
183
184 switch (epar->type) {
185
186 #if defined(VARIABLE) || defined(FUNCTION)
187 case VAR:
188 varfree(epar->v.ln);
189 break;
190
191 case SYM:
192 freestr(epar->v.name);
193 break;
194 #endif
195
196 case NUM:
197 case CHAN:
198 case ARG:
199 case TICK:
200 break;
201
202 default:
203 while ((ep = epar->v.kid) != NULL) {
204 epar->v.kid = ep->sibling;
205 epfree(ep);
206 }
207 break;
208
209 }
210
211 efree((char *)epar);
212 }
213
214 /* the following used to be a switch */
215 #ifdef FUNCTION
216 static double
217 eargument(ep)
218 EPNODE *ep;
219 {
220 return(argument(ep->v.chan));
221 }
222 #endif
223
224 static double
225 enumber(ep)
226 EPNODE *ep;
227 {
228 return(ep->v.num);
229 }
230
231 static double
232 euminus(ep)
233 EPNODE *ep;
234 {
235 register EPNODE *ep1 = ep->v.kid;
236
237 return(-evalue(ep1));
238 }
239
240 #ifdef INCHAN
241 static double
242 echannel(ep)
243 EPNODE *ep;
244 {
245 return(chanvalue(ep->v.chan));
246 }
247 #endif
248
249 static double
250 eadd(ep)
251 EPNODE *ep;
252 {
253 register EPNODE *ep1 = ep->v.kid;
254
255 return(evalue(ep1) + evalue(ep1->sibling));
256 }
257
258 static double
259 esubtr(ep)
260 EPNODE *ep;
261 {
262 register EPNODE *ep1 = ep->v.kid;
263
264 return(evalue(ep1) - evalue(ep1->sibling));
265 }
266
267 static double
268 emult(ep)
269 EPNODE *ep;
270 {
271 register EPNODE *ep1 = ep->v.kid;
272
273 return(evalue(ep1) * evalue(ep1->sibling));
274 }
275
276 static double
277 edivi(ep)
278 EPNODE *ep;
279 {
280 register EPNODE *ep1 = ep->v.kid;
281 double d;
282
283 d = evalue(ep1->sibling);
284 if (d == 0.0) {
285 wputs("Division by zero\n");
286 errno = ERANGE;
287 return(0.0);
288 }
289 return(evalue(ep1) / d);
290 }
291
292 static double
293 epow(ep)
294 EPNODE *ep;
295 {
296 register EPNODE *ep1 = ep->v.kid;
297 double d;
298 int lasterrno;
299
300 lasterrno = errno;
301 errno = 0;
302 d = pow(evalue(ep1), evalue(ep1->sibling));
303 #ifdef IEEE
304 if (!finite(d))
305 errno = EDOM;
306 #endif
307 if (errno) {
308 wputs("Illegal power\n");
309 return(0.0);
310 }
311 errno = lasterrno;
312 return(d);
313 }
314
315 static double
316 ebotch(ep)
317 EPNODE *ep;
318 {
319 eputs("Bad expression!\n");
320 quit(1);
321 }
322
323
324 EPNODE *
325 ekid(ep, n) /* return pointer to a node's nth kid */
326 register EPNODE *ep;
327 register int n;
328 {
329
330 for (ep = ep->v.kid; ep != NULL; ep = ep->sibling)
331 if (--n < 0)
332 break;
333
334 return(ep);
335 }
336
337
338 int
339 nekids(ep) /* return # of kids for node ep */
340 register EPNODE *ep;
341 {
342 register int n = 0;
343
344 for (ep = ep->v.kid; ep != NULL; ep = ep->sibling)
345 n++;
346
347 return(n);
348 }
349
350
351 initfile(fp, fn, ln) /* prepare input file */
352 FILE *fp;
353 char *fn;
354 int ln;
355 {
356 static char inpbuf[MAXLINE];
357
358 infp = fp;
359 linbuf = inpbuf;
360 infile = fn;
361 lineno = ln;
362 linepos = 0;
363 inpbuf[0] = '\0';
364 scan();
365 }
366
367
368 initstr(s, fn, ln) /* prepare input string */
369 char *s;
370 char *fn;
371 int ln;
372 {
373 infp = NULL;
374 infile = fn;
375 lineno = ln;
376 linbuf = s;
377 linepos = 0;
378 scan();
379 }
380
381
382 getscanpos(fnp, lnp, spp, fpp) /* return current scan position */
383 char **fnp;
384 int *lnp;
385 char **spp;
386 FILE **fpp;
387 {
388 if (fnp != NULL) *fnp = infile;
389 if (lnp != NULL) *lnp = lineno;
390 if (spp != NULL) *spp = linbuf+linepos;
391 if (fpp != NULL) *fpp = infp;
392 }
393
394
395 int
396 scan() /* scan next character, return literal next */
397 {
398 register int lnext = 0;
399
400 do {
401 if (linbuf[linepos] == '\0')
402 if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL)
403 nextc = EOF;
404 else {
405 nextc = linbuf[0];
406 lineno++;
407 linepos = 1;
408 }
409 else
410 nextc = linbuf[linepos++];
411 if (!lnext)
412 lnext = nextc;
413 if (nextc == '{') {
414 scan();
415 while (nextc != '}')
416 if (nextc == EOF)
417 syntax("'}' expected");
418 else
419 scan();
420 scan();
421 }
422 } while (isspace(nextc));
423 return(lnext);
424 }
425
426
427 char *
428 long2ascii(l) /* convert long to ascii */
429 long l;
430 {
431 static char buf[16];
432 register char *cp;
433 int neg = 0;
434
435 if (l == 0)
436 return("0");
437 if (l < 0) {
438 l = -l;
439 neg++;
440 }
441 cp = buf + sizeof(buf);
442 *--cp = '\0';
443 while (l) {
444 *--cp = l % 10 + '0';
445 l /= 10;
446 }
447 if (neg)
448 *--cp = '-';
449 return(cp);
450 }
451
452
453 syntax(err) /* report syntax error and quit */
454 char *err;
455 {
456 register int i;
457
458 if (infile != NULL || lineno != 0) {
459 if (infile != NULL) eputs(infile);
460 if (lineno != 0) {
461 eputs(infile != NULL ? ", line " : "line ");
462 eputs(long2ascii((long)lineno));
463 }
464 eputs(":\n");
465 }
466 eputs(linbuf);
467 if (linbuf[strlen(linbuf)-1] != '\n')
468 eputs("\n");
469 for (i = 0; i < linepos-1; i++)
470 eputs(linbuf[i] == '\t' ? "\t" : " ");
471 eputs("^ ");
472 eputs(err);
473 eputs("\n");
474 quit(1);
475 }
476
477
478 addekid(ep, ekid) /* add a child to ep */
479 register EPNODE *ep;
480 EPNODE *ekid;
481 {
482 if (ep->v.kid == NULL)
483 ep->v.kid = ekid;
484 else {
485 for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling)
486 ;
487 ep->sibling = ekid;
488 }
489 ekid->sibling = NULL;
490 }
491
492
493 #if defined(VARIABLE) || defined(FUNCTION)
494 char *
495 getname() /* scan an identifier */
496 {
497 static char str[MAXWORD+1];
498 register int i, lnext;
499
500 lnext = nextc;
501 for (i = 0; i < MAXWORD && isid(lnext); i++, lnext = scan())
502 str[i] = lnext;
503 str[i] = '\0';
504 while (isid(lnext)) /* skip rest of name */
505 lnext = scan();
506
507 return(str);
508 }
509 #endif
510
511
512 int
513 getinum() /* scan a positive integer */
514 {
515 register int n, lnext;
516
517 n = 0;
518 lnext = nextc;
519 while (isdigit(lnext)) {
520 n = n * 10 + lnext - '0';
521 lnext = scan();
522 }
523 return(n);
524 }
525
526
527 double
528 getnum() /* scan a positive float */
529 {
530 register int i, lnext;
531 char str[MAXWORD+1];
532
533 i = 0;
534 lnext = nextc;
535 while (isdigit(lnext) && i < MAXWORD) {
536 str[i++] = lnext;
537 lnext = scan();
538 }
539 if (lnext == '.' && i < MAXWORD) {
540 str[i++] = lnext;
541 lnext = scan();
542 if (i == 1 && !isdigit(lnext))
543 syntax("badly formed number");
544 while (isdigit(lnext) && i < MAXWORD) {
545 str[i++] = lnext;
546 lnext = scan();
547 }
548 }
549 if ((lnext == 'e' | lnext == 'E') && i < MAXWORD) {
550 str[i++] = lnext;
551 lnext = scan();
552 if ((lnext == '-' | lnext == '+') && i < MAXWORD) {
553 str[i++] = lnext;
554 lnext = scan();
555 }
556 if (!isdigit(lnext))
557 syntax("missing exponent");
558 while (isdigit(lnext) && i < MAXWORD) {
559 str[i++] = lnext;
560 lnext = scan();
561 }
562 }
563 str[i] = '\0';
564
565 return(atof(str));
566 }
567
568
569 EPNODE *
570 getE1() /* E1 -> E1 ADDOP E2 */
571 /* E2 */
572 {
573 register EPNODE *ep1, *ep2;
574
575 ep1 = getE2();
576 while (nextc == '+' || nextc == '-') {
577 ep2 = newnode();
578 ep2->type = nextc;
579 scan();
580 addekid(ep2, ep1);
581 addekid(ep2, getE2());
582 #ifdef RCONST
583 if (ep1->type == NUM && ep1->sibling->type == NUM)
584 ep2 = rconst(ep2);
585 #endif
586 ep1 = ep2;
587 }
588 return(ep1);
589 }
590
591
592 EPNODE *
593 getE2() /* E2 -> E2 MULOP E3 */
594 /* E3 */
595 {
596 register EPNODE *ep1, *ep2;
597
598 ep1 = getE3();
599 while (nextc == '*' || nextc == '/') {
600 ep2 = newnode();
601 ep2->type = nextc;
602 scan();
603 addekid(ep2, ep1);
604 addekid(ep2, getE3());
605 #ifdef RCONST
606 if (ep1->type == NUM && ep1->sibling->type == NUM)
607 ep2 = rconst(ep2);
608 #endif
609 ep1 = ep2;
610 }
611 return(ep1);
612 }
613
614
615 EPNODE *
616 getE3() /* E3 -> E4 ^ E3 */
617 /* E4 */
618 {
619 register EPNODE *ep1, *ep2;
620
621 ep1 = getE4();
622 if (nextc == '^') {
623 ep2 = newnode();
624 ep2->type = nextc;
625 scan();
626 addekid(ep2, ep1);
627 addekid(ep2, getE3());
628 #ifdef RCONST
629 if (ep1->type == NUM && ep1->sibling->type == NUM)
630 ep2 = rconst(ep2);
631 #endif
632 return(ep2);
633 }
634 return(ep1);
635 }
636
637
638 EPNODE *
639 getE4() /* E4 -> ADDOP E5 */
640 /* E5 */
641 {
642 register EPNODE *ep1, *ep2;
643
644 if (nextc == '-') {
645 scan();
646 ep2 = getE5();
647 if (ep2->type == NUM) {
648 ep2->v.num = -ep2->v.num;
649 return(ep2);
650 }
651 if (ep2->type == UMINUS) { /* don't generate -(-E5) */
652 efree((char *)ep2);
653 return(ep2->v.kid);
654 }
655 ep1 = newnode();
656 ep1->type = UMINUS;
657 addekid(ep1, ep2);
658 return(ep1);
659 }
660 if (nextc == '+')
661 scan();
662 return(getE5());
663 }
664
665
666 EPNODE *
667 getE5() /* E5 -> (E1) */
668 /* VAR */
669 /* NUM */
670 /* $N */
671 /* FUNC(E1,..) */
672 /* ARG */
673 {
674 int i;
675 char *nam;
676 register EPNODE *ep1, *ep2;
677
678 if (nextc == '(') {
679 scan();
680 ep1 = getE1();
681 if (nextc != ')')
682 syntax("')' expected");
683 scan();
684 return(ep1);
685 }
686
687 #ifdef INCHAN
688 if (nextc == '$') {
689 scan();
690 ep1 = newnode();
691 ep1->type = CHAN;
692 ep1->v.chan = getinum();
693 return(ep1);
694 }
695 #endif
696
697 #if defined(VARIABLE) || defined(FUNCTION)
698 if (isalpha(nextc) || nextc == CNTXMARK) {
699 nam = getname();
700 #if defined(VARIABLE) && defined(FUNCTION)
701 ep1 = NULL;
702 if (curfunc != NULL)
703 for (i = 1, ep2 = curfunc->v.kid->sibling;
704 ep2 != NULL; i++, ep2 = ep2->sibling)
705 if (!strcmp(ep2->v.name, nam)) {
706 ep1 = newnode();
707 ep1->type = ARG;
708 ep1->v.chan = i;
709 break;
710 }
711 if (ep1 == NULL)
712 #endif
713 {
714 ep1 = newnode();
715 ep1->type = VAR;
716 ep1->v.ln = varinsert(nam);
717 }
718 #ifdef FUNCTION
719 if (nextc == '(') {
720 ep2 = newnode();
721 ep2->type = FUNC;
722 addekid(ep2, ep1);
723 ep1 = ep2;
724 do {
725 scan();
726 addekid(ep1, getE1());
727 } while (nextc == ',');
728 if (nextc != ')')
729 syntax("')' expected");
730 scan();
731 }
732 #ifndef VARIABLE
733 else
734 syntax("'(' expected");
735 #endif
736 #endif
737 #ifdef RCONST
738 if (isconstvar(ep1))
739 ep1 = rconst(ep1);
740 #endif
741 return(ep1);
742 }
743 #endif
744
745 if (isdecimal(nextc)) {
746 ep1 = newnode();
747 ep1->type = NUM;
748 ep1->v.num = getnum();
749 return(ep1);
750 }
751 syntax("unexpected character");
752 }
753
754
755 #ifdef RCONST
756 EPNODE *
757 rconst(epar) /* reduce a constant expression */
758 register EPNODE *epar;
759 {
760 register EPNODE *ep;
761
762 ep = newnode();
763 ep->type = NUM;
764 errno = 0;
765 ep->v.num = evalue(epar);
766 if (errno)
767 syntax("bad constant expression");
768 epfree(epar);
769
770 return(ep);
771 }
772
773
774 isconstvar(ep) /* is ep linked to a constant expression? */
775 register EPNODE *ep;
776 {
777 #ifdef VARIABLE
778 register EPNODE *ep1;
779 #ifdef FUNCTION
780
781 if (ep->type == FUNC) {
782 if (!isconstfun(ep->v.kid))
783 return(0);
784 for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling)
785 if (ep1->type != NUM && !isconstfun(ep1))
786 return(0);
787 return(1);
788 }
789 #endif
790 if (ep->type != VAR)
791 return(0);
792 ep1 = ep->v.ln->def;
793 if (ep1 == NULL || ep1->type != ':')
794 return(0);
795 #ifdef FUNCTION
796 if (ep1->v.kid->type != SYM)
797 return(0);
798 #endif
799 return(1);
800 #else
801 return(ep->type == FUNC);
802 #endif
803 }
804
805
806 #if defined(FUNCTION) && defined(VARIABLE)
807 isconstfun(ep) /* is ep linked to a constant function? */
808 register EPNODE *ep;
809 {
810 register EPNODE *dp;
811 register LIBR *lp;
812
813 if (ep->type != VAR)
814 return(0);
815 if ((dp = ep->v.ln->def) != NULL && dp->v.kid->type == FUNC)
816 return(dp->type == ':');
817 if ((lp = ep->v.ln->lib) != NULL)
818 return(lp->atyp == ':');
819 return(0);
820 }
821 #endif
822 #endif
