root/radiance/ray/src/common/calexpr.c
Revision: 1.12
Committed: Thu Aug 8 11:22:04 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.11: +36 -30 lines
added contexts to definition naming
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Compute data values using expression parser
9 *
10 * 7/1/85 Greg Ward
11 *
12 * 11/11/85 Made channel input conditional with (INCHAN) compiles.
13 *
14 * 4/2/86 Added conditional compiles for function definitions (FUNCTION).
15 *
16 * 1/29/87 Made variables conditional (VARIABLE)
17 *
18 * 5/19/88 Added constant subexpression elimination (RCONST)
19 */
20
21 #include <stdio.h>
22
23 #include <ctype.h>
24
25 #include <errno.h>
26
27 #include "calcomp.h"
28
29 #define MAXLINE 256 /* maximum line length */
30
31 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
32
33 #define isdecimal(c) (isdigit(c) || (c) == '.')
34
35 extern double atof(), pow();
36 extern char *fgets(), *savestr();
37 extern char *emalloc(), *ecalloc();
38 extern EPNODE *curfunc;
39 extern double efunc(), evariable();
40 static double euminus(), echannel(), eargument(), enumber();
41 static double eadd(), esubtr(), emult(), edivi(), epow();
42 static double ebotch();
43 extern int errno;
44
45 int nextc; /* lookahead character */
46
47 double (*eoper[])() = { /* expression operations */
48 ebotch,
49 #ifdef VARIABLE
50 evariable,
51 #else
52 ebotch,
53 #endif
54 enumber,
55 euminus,
56 #ifdef INCHAN
57 echannel,
58 #else
59 ebotch,
60 #endif
61 #ifdef FUNCTION
62 efunc,
63 eargument,
64 #else
65 ebotch,
66 ebotch,
67 #endif
68 ebotch,
69 ebotch,
70 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
71 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
72 emult,
73 eadd,
74 0,
75 esubtr,
76 0,
77 edivi,
78 0,0,0,0,0,0,0,0,0,0,
79 ebotch,
80 0,0,
81 ebotch,
82 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
83 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
84 epow,
85 };
86
87 static FILE *infp; /* input file pointer */
88 static char *linbuf; /* line buffer */
89 static char *infile; /* input file name */
90 static int lineno; /* input line number */
91 static int linepos; /* position in buffer */
92
93
94 EPNODE *
95 eparse(expr) /* parse an expression string */
96 char *expr;
97 {
98 EPNODE *ep;
99
100 initstr(expr, NULL, 0);
101 #if defined(VARIABLE) && defined(FUNCTION)
102 curfunc = NULL;
103 #endif
104 ep = getE1();
105 if (nextc != EOF)
106 syntax("unexpected character");
107 return(ep);
108 }
109
110
111 double
112 eval(expr) /* evaluate an expression string */
113 char *expr;
114 {
115 register EPNODE *ep;
116 double rval;
117
118 ep = eparse(expr);
119 rval = evalue(ep);
120 epfree(ep);
121 return(rval);
122 }
123
124
125 epfree(epar) /* free a parse tree */
126 register EPNODE *epar;
127 {
128 register EPNODE *ep;
129
130 switch (epar->type) {
131
132 #if defined(VARIABLE) || defined(FUNCTION)
133 case VAR:
134 varfree(epar->v.ln);
135 break;
136 #endif
137
138 case SYM:
139 freestr(epar->v.name);
140 break;
141
142 case NUM:
143 case CHAN:
144 case ARG:
145 case TICK:
146 break;
147
148 default:
149 for (ep = epar->v.kid; ep != NULL; ep = ep->sibling)
150 epfree(ep);
151 break;
152
153 }
154
155 efree((char *)epar);
156 }
157
158 /* the following used to be a switch */
159 #ifdef FUNCTION
160 static double
161 eargument(ep)
162 EPNODE *ep;
163 {
164 return(argument(ep->v.chan));
165 }
166 #endif
167
168 static double
169 enumber(ep)
170 EPNODE *ep;
171 {
172 return(ep->v.num);
173 }
174
175 static double
176 euminus(ep)
177 EPNODE *ep;
178 {
179 register EPNODE *ep1 = ep->v.kid;
180
181 return(-evalue(ep1));
182 }
183
184 #ifdef INCHAN
185 static double
186 echannel(ep)
187 EPNODE *ep;
188 {
189 return(chanvalue(ep->v.chan));
190 }
191 #endif
192
193 static double
194 eadd(ep)
195 EPNODE *ep;
196 {
197 register EPNODE *ep1 = ep->v.kid;
198
199 return(evalue(ep1) + evalue(ep1->sibling));
200 }
201
202 static double
203 esubtr(ep)
204 EPNODE *ep;
205 {
206 register EPNODE *ep1 = ep->v.kid;
207
208 return(evalue(ep1) - evalue(ep1->sibling));
209 }
210
211 static double
212 emult(ep)
213 EPNODE *ep;
214 {
215 register EPNODE *ep1 = ep->v.kid;
216
217 return(evalue(ep1) * evalue(ep1->sibling));
218 }
219
220 static double
221 edivi(ep)
222 EPNODE *ep;
223 {
224 register EPNODE *ep1 = ep->v.kid;
225 double d;
226
227 d = evalue(ep1->sibling);
228 if (d == 0.0) {
229 wputs("Division by zero\n");
230 errno = ERANGE;
231 return(0.0);
232 }
233 return(evalue(ep1) / d);
234 }
235
236 static double
237 epow(ep)
238 EPNODE *ep;
239 {
240 register EPNODE *ep1 = ep->v.kid;
241 double d;
242 int lasterrno;
243
244 lasterrno = errno;
245 errno = 0;
246 d = pow(evalue(ep1), evalue(ep1->sibling));
247 #ifdef IEEE
248 if (!finite(d))
249 errno = EDOM;
250 #endif
251 if (errno) {
252 wputs("Illegal power\n");
253 return(0.0);
254 }
255 errno = lasterrno;
256 return(d);
257 }
258
259 static double
260 ebotch(ep)
261 EPNODE *ep;
262 {
263 eputs("Bad expression!\n");
264 quit(1);
265 }
266
267
268 EPNODE *
269 ekid(ep, n) /* return pointer to a node's nth kid */
270 register EPNODE *ep;
271 register int n;
272 {
273
274 for (ep = ep->v.kid; ep != NULL; ep = ep->sibling)
275 if (--n < 0)
276 break;
277
278 return(ep);
279 }
280
281
282 int
283 nekids(ep) /* return # of kids for node ep */
284 register EPNODE *ep;
285 {
286 register int n = 0;
287
288 for (ep = ep->v.kid; ep != NULL; ep = ep->sibling)
289 n++;
290
291 return(n);
292 }
293
294
295 initfile(fp, fn, ln) /* prepare input file */
296 FILE *fp;
297 char *fn;
298 int ln;
299 {
300 static char inpbuf[MAXLINE];
301
302 infp = fp;
303 linbuf = inpbuf;
304 infile = fn;
305 lineno = ln;
306 linepos = 0;
307 inpbuf[0] = '\0';
308 scan();
309 }
310
311
312 initstr(s, fn, ln) /* prepare input string */
313 char *s;
314 char *fn;
315 int ln;
316 {
317 infp = NULL;
318 infile = fn;
319 lineno = ln;
320 linbuf = s;
321 linepos = 0;
322 scan();
323 }
324
325
326 int
327 scan() /* scan next character, return literal next */
328 {
329 register int lnext = 0;
330
331 do {
332 if (linbuf[linepos] == '\0')
333 if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL)
334 nextc = EOF;
335 else {
336 nextc = linbuf[0];
337 lineno++;
338 linepos = 1;
339 }
340 else
341 nextc = linbuf[linepos++];
342 if (!lnext)
343 lnext = nextc;
344 if (nextc == '{') {
345 scan();
346 while (nextc != '}')
347 if (nextc == EOF)
348 syntax("'}' expected");
349 else
350 scan();
351 scan();
352 }
353 } while (isspace(nextc));
354 return(lnext);
355 }
356
357
358 char *
359 ltoa(l) /* convert long to ascii */
360 long l;
361 {
362 static char buf[16];
363 register char *cp;
364 int neg = 0;
365
366 if (l == 0)
367 return("0");
368 if (l < 0) {
369 l = -l;
370 neg++;
371 }
372 cp = buf + sizeof(buf);
373 *--cp = '\0';
374 while (l) {
375 *--cp = l % 10 + '0';
376 l /= 10;
377 }
378 if (neg)
379 *--cp = '-';
380 return(cp);
381 }
382
383
384 syntax(err) /* report syntax error and quit */
385 char *err;
386 {
387 register int i;
388
389 if (infile != NULL || lineno != 0) {
390 if (infile != NULL) eputs(infile);
391 if (lineno != 0) {
392 eputs(infile != NULL ? ", line " : "line ");
393 eputs(ltoa((long)lineno));
394 }
395 eputs(": syntax error:\n");
396 }
397 eputs(linbuf);
398 if (linbuf[strlen(linbuf)-1] != '\n')
399 eputs("\n");
400 for (i = 0; i < linepos-1; i++)
401 eputs(linbuf[i] == '\t' ? "\t" : " ");
402 eputs("^ ");
403 eputs(err);
404 eputs("\n");
405 quit(1);
406 }
407
408
409 addekid(ep, ekid) /* add a child to ep */
410 register EPNODE *ep;
411 EPNODE *ekid;
412 {
413 if (ep->v.kid == NULL)
414 ep->v.kid = ekid;
415 else {
416 for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling)
417 ;
418 ep->sibling = ekid;
419 }
420 ekid->sibling = NULL;
421 }
422
423
424 char *
425 getname() /* scan an identifier */
426 {
427 static char str[MAXWORD+1];
428 register int i, lnext;
429
430 lnext = nextc;
431 for (i = 0; i < MAXWORD && isid(lnext); i++, lnext = scan())
432 str[i] = lnext;
433 str[i] = '\0';
434
435 return(str);
436 }
437
438
439 int
440 getinum() /* scan a positive integer */
441 {
442 register int n, lnext;
443
444 n = 0;
445 lnext = nextc;
446 while (isdigit(lnext)) {
447 n = n * 10 + lnext - '0';
448 lnext = scan();
449 }
450 return(n);
451 }
452
453
454 double
455 getnum() /* scan a positive float */
456 {
457 register int i, lnext;
458 char str[MAXWORD+1];
459
460 i = 0;
461 lnext = nextc;
462 while (isdigit(lnext) && i < MAXWORD) {
463 str[i++] = lnext;
464 lnext = scan();
465 }
466 if (lnext == '.' && i < MAXWORD) {
467 str[i++] = lnext;
468 lnext = scan();
469 while (isdigit(lnext) && i < MAXWORD) {
470 str[i++] = lnext;
471 lnext = scan();
472 }
473 }
474 if ((lnext == 'e' || lnext == 'E') && i < MAXWORD) {
475 str[i++] = lnext;
476 lnext = scan();
477 if ((lnext == '-' || lnext == '+') && i < MAXWORD) {
478 str[i++] = lnext;
479 lnext = scan();
480 }
481 while (isdigit(lnext) && i < MAXWORD) {
482 str[i++] = lnext;
483 lnext = scan();
484 }
485 }
486 str[i] = '\0';
487
488 return(atof(str));
489 }
490
491
492 EPNODE *
493 getE1() /* E1 -> E1 ADDOP E2 */
494 /* E2 */
495 {
496 register EPNODE *ep1, *ep2;
497
498 ep1 = getE2();
499 while (nextc == '+' || nextc == '-') {
500 ep2 = newnode();
501 ep2->type = nextc;
502 scan();
503 addekid(ep2, ep1);
504 addekid(ep2, getE2());
505 #ifdef RCONST
506 if (ep1->type == NUM && ep1->sibling->type == NUM)
507 ep2 = rconst(ep2);
508 #endif
509 ep1 = ep2;
510 }
511 return(ep1);
512 }
513
514
515 EPNODE *
516 getE2() /* E2 -> E2 MULOP E3 */
517 /* E3 */
518 {
519 register EPNODE *ep1, *ep2;
520
521 ep1 = getE3();
522 while (nextc == '*' || nextc == '/') {
523 ep2 = newnode();
524 ep2->type = nextc;
525 scan();
526 addekid(ep2, ep1);
527 addekid(ep2, getE3());
528 #ifdef RCONST
529 if (ep1->type == NUM && ep1->sibling->type == NUM)
530 ep2 = rconst(ep2);
531 #endif
532 ep1 = ep2;
533 }
534 return(ep1);
535 }
536
537
538 EPNODE *
539 getE3() /* E3 -> E4 ^ E3 */
540 /* E4 */
541 {
542 register EPNODE *ep1, *ep2;
543
544 ep1 = getE4();
545 if (nextc == '^') {
546 ep2 = newnode();
547 ep2->type = nextc;
548 scan();
549 addekid(ep2, ep1);
550 addekid(ep2, getE3());
551 #ifdef RCONST
552 if (ep1->type == NUM && ep1->sibling->type == NUM)
553 ep2 = rconst(ep2);
554 #endif
555 return(ep2);
556 }
557 return(ep1);
558 }
559
560
561 EPNODE *
562 getE4() /* E4 -> ADDOP E5 */
563 /* E5 */
564 {
565 register EPNODE *ep1, *ep2;
566
567 if (nextc == '-') {
568 scan();
569 ep2 = getE5();
570 if (ep2->type == NUM) {
571 ep2->v.num = -ep2->v.num;
572 return(ep2);
573 }
574 ep1 = newnode();
575 ep1->type = UMINUS;
576 addekid(ep1, ep2);
577 return(ep1);
578 }
579 if (nextc == '+')
580 scan();
581 return(getE5());
582 }
583
584
585 EPNODE *
586 getE5() /* E5 -> (E1) */
587 /* VAR */
588 /* NUM */
589 /* $N */
590 /* FUNC(E1,..) */
591 /* ARG */
592 {
593 int i;
594 register EPNODE *ep1, *ep2;
595
596 if (nextc == '(') {
597 scan();
598 ep1 = getE1();
599 if (nextc != ')')
600 syntax("')' expected");
601 scan();
602 return(ep1);
603 }
604
605 #ifdef INCHAN
606 if (nextc == '$') {
607 scan();
608 ep1 = newnode();
609 ep1->type = CHAN;
610 ep1->v.chan = getinum();
611 return(ep1);
612 }
613 #endif
614
615 #if defined(VARIABLE) || defined(FUNCTION)
616 if (isalpha(nextc)) {
617 ep1 = newnode();
618 ep1->type = VAR;
619 ep1->v.ln = varinsert(getname());
620
621 #if defined(VARIABLE) && defined(FUNCTION)
622 if (curfunc != NULL)
623 for (i = 1, ep2 = curfunc->v.kid->sibling;
624 ep2 != NULL; i++, ep2 = ep2->sibling)
625 if (!strcmp(ep2->v.name, ep1->v.ln->name)) {
626 epfree(ep1);
627 ep1 = newnode();
628 ep1->type = ARG;
629 ep1->v.chan = i;
630 break;
631 }
632 #endif
633 #ifdef FUNCTION
634 if (nextc == '(') {
635 ep2 = newnode();
636 ep2->type = FUNC;
637 addekid(ep2, ep1);
638 ep1 = ep2;
639 do {
640 scan();
641 addekid(ep1, getE1());
642 } while (nextc == ',');
643 if (nextc != ')')
644 syntax("')' expected");
645 scan();
646 }
647 #ifndef VARIABLE
648 else
649 syntax("'(' expected");
650 #endif
651 #endif
652 #ifdef RCONST
653 if (isconstvar(ep1))
654 ep1 = rconst(ep1);
655 #endif
656 return(ep1);
657 }
658 #endif
659
660 if (isdecimal(nextc)) {
661 ep1 = newnode();
662 ep1->type = NUM;
663 ep1->v.num = getnum();
664 return(ep1);
665 }
666 syntax("unexpected character");
667 }
668
669
670 #ifdef RCONST
671 EPNODE *
672 rconst(epar) /* reduce a constant expression */
673 register EPNODE *epar;
674 {
675 register EPNODE *ep;
676
677 ep = newnode();
678 ep->type = NUM;
679 errno = 0;
680 ep->v.num = evalue(epar);
681 if (errno)
682 syntax("bad constant expression");
683 epfree(epar);
684
685 return(ep);
686 }
687
688
689 isconstvar(ep) /* is ep linked to a constant expression? */
690 register EPNODE *ep;
691 {
692 #ifdef VARIABLE
693 register EPNODE *ep1;
694 #ifdef FUNCTION
695
696 if (ep->type == FUNC) {
697 if (!isconstfun(ep->v.kid))
698 return(0);
699 for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling)
700 if (ep1->type != NUM && !isconstfun(ep1))
701 return(0);
702 return(1);
703 }
704 #endif
705 if (ep->type != VAR)
706 return(0);
707 ep1 = ep->v.ln->def;
708 if (ep1 == NULL || ep1->type != ':')
709 return(0);
710 #ifdef FUNCTION
711 if (ep1->v.kid->type != SYM)
712 return(0);
713 #endif
714 return(1);
715 #else
716 return(ep->type == FUNC);
717 #endif
718 }
719
720
721 #if defined(FUNCTION) && defined(VARIABLE)
722 isconstfun(ep) /* is ep linked to a constant function? */
723 register EPNODE *ep;
724 {
725 register EPNODE *dp;
726 register LIBR *lp;
727
728 if (ep->type != VAR)
729 return(0);
730 dp = ep->v.ln->def;
731 if (dp != NULL && dp->type != ':')
732 return(0);
733 if ((dp == NULL || dp->v.kid->type != FUNC)
734 && ((lp = liblookup(ep->v.ln->name)) == NULL
735 || lp->atyp != ':'))
736 return(0);
737 return(1);
738 }
739 #endif
740 #endif
