1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Compute data values using expression parser |
9 |
10 |
* 7/1/85 Greg Ward |
11 |
12 |
* 11/11/85 Made channel input conditional with (INCHAN) compiles. |
13 |
14 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION). |
15 |
16 |
* 1/29/87 Made variables conditional (VARIABLE) |
17 |
18 |
* 5/19/88 Added constant subexpression elimination (RCONST) |
19 |
20 |
21 |
#include <stdio.h> |
22 |
23 |
#include <ctype.h> |
24 |
25 |
#include <errno.h> |
26 |
27 |
#include "calcomp.h" |
28 |
29 |
#define MAXLINE 256 /* maximum line length */ |
30 |
#define MAXWORD 64 /* maximum word length */ |
31 |
32 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) |
33 |
34 |
#define isid(c) (isalnum(c) || (c) == '_' || (c) == '.') |
35 |
36 |
#define isdecimal(c) (isdigit(c) || (c) == '.') |
37 |
38 |
extern double atof(), pow(); |
39 |
extern char *fgets(), *savestr(); |
40 |
extern char *emalloc(), *ecalloc(); |
41 |
extern EPNODE *curfunc; |
42 |
extern double efunc(), evariable(); |
43 |
static double euminus(), echannel(), eargument(), enumber(); |
44 |
static double eadd(), esubtr(), emult(), edivi(), epow(); |
45 |
static double ebotch(); |
46 |
extern int errno; |
47 |
48 |
int nextc; /* lookahead character */ |
49 |
50 |
double (*eoper[])() = { /* expression operations */ |
51 |
ebotch, |
52 |
#ifdef VARIABLE |
53 |
evariable, |
54 |
#else |
55 |
ebotch, |
56 |
#endif |
57 |
enumber, |
58 |
euminus, |
59 |
#ifdef INCHAN |
60 |
echannel, |
61 |
#else |
62 |
ebotch, |
63 |
#endif |
64 |
#ifdef FUNCTION |
65 |
efunc, |
66 |
eargument, |
67 |
#else |
68 |
ebotch, |
69 |
ebotch, |
70 |
#endif |
71 |
ebotch, |
72 |
ebotch, |
73 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
74 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
75 |
emult, |
76 |
eadd, |
77 |
0, |
78 |
esubtr, |
79 |
0, |
80 |
edivi, |
81 |
82 |
ebotch, |
83 |
0,0, |
84 |
ebotch, |
85 |
86 |
87 |
epow, |
88 |
89 |
90 |
static FILE *infp; /* input file pointer */ |
91 |
static char *linbuf; /* line buffer */ |
92 |
static char *infile; /* input file name */ |
93 |
static int lineno; /* input line number */ |
94 |
static int linepos; /* position in buffer */ |
95 |
96 |
97 |
EPNODE * |
98 |
eparse(expr) /* parse an expression string */ |
99 |
char *expr; |
100 |
101 |
EPNODE *ep; |
102 |
103 |
initstr(expr, NULL, 0); |
104 |
#if defined(VARIABLE) && defined(FUNCTION) |
105 |
curfunc = NULL; |
106 |
#endif |
107 |
ep = getE1(); |
108 |
if (nextc != EOF) |
109 |
syntax("unexpected character"); |
110 |
return(ep); |
111 |
112 |
113 |
114 |
double |
115 |
eval(expr) /* evaluate an expression string */ |
116 |
char *expr; |
117 |
118 |
register EPNODE *ep; |
119 |
double rval; |
120 |
121 |
ep = eparse(expr); |
122 |
rval = evalue(ep); |
123 |
epfree(ep); |
124 |
return(rval); |
125 |
126 |
127 |
128 |
epfree(epar) /* free a parse tree */ |
129 |
register EPNODE *epar; |
130 |
131 |
132 |
133 |
switch (epar->type) { |
134 |
135 |
#if defined(VARIABLE) || defined(FUNCTION) |
136 |
case VAR: |
137 |
varfree(epar->v.ln); |
138 |
break; |
139 |
#endif |
140 |
141 |
case SYM: |
142 |
freestr(epar->v.name); |
143 |
break; |
144 |
145 |
case NUM: |
146 |
case CHAN: |
147 |
case ARG: |
148 |
case TICK: |
149 |
break; |
150 |
151 |
default: |
152 |
for (ep = epar->v.kid; ep != NULL; ep = ep->sibling) |
153 |
epfree(ep); |
154 |
break; |
155 |
156 |
157 |
158 |
efree((char *)epar); |
159 |
160 |
161 |
/* the following used to be a switch */ |
162 |
#ifdef FUNCTION |
163 |
static double |
164 |
eargument(ep) |
165 |
EPNODE *ep; |
166 |
167 |
return(argument(ep->v.chan)); |
168 |
169 |
#endif |
170 |
171 |
static double |
172 |
enumber(ep) |
173 |
EPNODE *ep; |
174 |
175 |
return(ep->v.num); |
176 |
177 |
178 |
static double |
179 |
euminus(ep) |
180 |
EPNODE *ep; |
181 |
182 |
register EPNODE *ep1 = ep->v.kid; |
183 |
184 |
return(-evalue(ep1)); |
185 |
186 |
187 |
#ifdef INCHAN |
188 |
static double |
189 |
echannel(ep) |
190 |
EPNODE *ep; |
191 |
192 |
return(chanvalue(ep->v.chan)); |
193 |
194 |
#endif |
195 |
196 |
static double |
197 |
eadd(ep) |
198 |
EPNODE *ep; |
199 |
200 |
201 |
202 |
return(evalue(ep1) + evalue(ep1->sibling)); |
203 |
204 |
205 |
static double |
206 |
esubtr(ep) |
207 |
EPNODE *ep; |
208 |
209 |
210 |
211 |
return(evalue(ep1) - evalue(ep1->sibling)); |
212 |
213 |
214 |
static double |
215 |
emult(ep) |
216 |
EPNODE *ep; |
217 |
218 |
219 |
220 |
return(evalue(ep1) * evalue(ep1->sibling)); |
221 |
222 |
223 |
static double |
224 |
edivi(ep) |
225 |
EPNODE *ep; |
226 |
227 |
228 |
double d; |
229 |
230 |
d = evalue(ep1->sibling); |
231 |
if (d == 0.0) { |
232 |
wputs("Division by zero\n"); |
233 |
errno = ERANGE; |
234 |
return(0.0); |
235 |
236 |
return(evalue(ep1) / d); |
237 |
238 |
239 |
static double |
240 |
epow(ep) |
241 |
EPNODE *ep; |
242 |
243 |
244 |
double d; |
245 |
int lasterrno; |
246 |
247 |
lasterrno = errno; |
248 |
errno = 0; |
249 |
d = pow(evalue(ep1), evalue(ep1->sibling)); |
250 |
#ifdef IEEE |
251 |
if (!finite(d)) |
252 |
errno = EDOM; |
253 |
#endif |
254 |
if (errno) { |
255 |
wputs("Illegal power\n"); |
256 |
return(0.0); |
257 |
258 |
errno = lasterrno; |
259 |
return(d); |
260 |
261 |
262 |
static double |
263 |
ebotch(ep) |
264 |
EPNODE *ep; |
265 |
266 |
eputs("Bad expression!\n"); |
267 |
quit(1); |
268 |
269 |
270 |
271 |
EPNODE * |
272 |
ekid(ep, n) /* return pointer to a node's nth kid */ |
273 |
274 |
register int n; |
275 |
276 |
277 |
for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) |
278 |
if (--n < 0) |
279 |
break; |
280 |
281 |
return(ep); |
282 |
283 |
284 |
285 |
int |
286 |
nekids(ep) /* return # of kids for node ep */ |
287 |
288 |
289 |
register int n = 0; |
290 |
291 |
292 |
n++; |
293 |
294 |
return(n); |
295 |
296 |
297 |
298 |
initfile(fp, fn, ln) /* prepare input file */ |
299 |
FILE *fp; |
300 |
char *fn; |
301 |
int ln; |
302 |
303 |
static char inpbuf[MAXLINE]; |
304 |
305 |
infp = fp; |
306 |
linbuf = inpbuf; |
307 |
infile = fn; |
308 |
lineno = ln; |
309 |
linepos = 0; |
310 |
inpbuf[0] = '\0'; |
311 |
scan(); |
312 |
313 |
314 |
315 |
initstr(s, fn, ln) /* prepare input string */ |
316 |
char *s; |
317 |
char *fn; |
318 |
int ln; |
319 |
320 |
infp = NULL; |
321 |
infile = fn; |
322 |
lineno = ln; |
323 |
linbuf = s; |
324 |
linepos = 0; |
325 |
scan(); |
326 |
327 |
328 |
329 |
scan() /* scan next character */ |
330 |
331 |
do { |
332 |
if (linbuf[linepos] == '\0') |
333 |
if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL) |
334 |
nextc = EOF; |
335 |
else { |
336 |
nextc = linbuf[0]; |
337 |
lineno++; |
338 |
linepos = 1; |
339 |
340 |
else |
341 |
nextc = linbuf[linepos++]; |
342 |
if (nextc == '{') { |
343 |
scan(); |
344 |
while (nextc != '}') |
345 |
if (nextc == EOF) |
346 |
syntax("'}' expected"); |
347 |
else |
348 |
scan(); |
349 |
scan(); |
350 |
351 |
} while (isspace(nextc)); |
352 |
353 |
354 |
355 |
char * |
356 |
ltoa(l) /* convert long to ascii */ |
357 |
long l; |
358 |
359 |
static char buf[16]; |
360 |
register char *cp; |
361 |
int neg = 0; |
362 |
363 |
if (l == 0) |
364 |
return("0"); |
365 |
if (l < 0) { |
366 |
l = -l; |
367 |
neg++; |
368 |
369 |
cp = buf + sizeof(buf); |
370 |
*--cp = '\0'; |
371 |
while (l) { |
372 |
*--cp = l % 10 + '0'; |
373 |
l /= 10; |
374 |
375 |
if (neg) |
376 |
*--cp = '-'; |
377 |
return(cp); |
378 |
379 |
380 |
381 |
syntax(err) /* report syntax error and quit */ |
382 |
char *err; |
383 |
384 |
register int i; |
385 |
386 |
if (infile != NULL || lineno != 0) { |
387 |
if (infile != NULL) eputs(infile); |
388 |
if (lineno != 0) { |
389 |
eputs(infile != NULL ? ", line " : "line "); |
390 |
eputs(ltoa((long)lineno)); |
391 |
392 |
eputs(": syntax error:\n"); |
393 |
394 |
eputs(linbuf); |
395 |
if (linbuf[strlen(linbuf)-1] != '\n') |
396 |
eputs("\n"); |
397 |
for (i = 0; i < linepos-1; i++) |
398 |
eputs(linbuf[i] == '\t' ? "\t" : " "); |
399 |
eputs("^ "); |
400 |
eputs(err); |
401 |
eputs("\n"); |
402 |
quit(1); |
403 |
404 |
405 |
406 |
addekid(ep, ekid) /* add a child to ep */ |
407 |
408 |
EPNODE *ekid; |
409 |
410 |
if (ep->v.kid == NULL) |
411 |
ep->v.kid = ekid; |
412 |
else { |
413 |
for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling) |
414 |
415 |
ep->sibling = ekid; |
416 |
417 |
ekid->sibling = NULL; |
418 |
419 |
420 |
421 |
char * |
422 |
getname() /* scan an identifier */ |
423 |
424 |
static char str[MAXWORD+1]; |
425 |
register int i; |
426 |
427 |
for (i = 0; i < MAXWORD && isid(nextc); i++, scan()) |
428 |
str[i] = nextc; |
429 |
str[i] = '\0'; |
430 |
431 |
return(str); |
432 |
433 |
434 |
435 |
int |
436 |
getinum() /* scan a positive integer */ |
437 |
438 |
register int n; |
439 |
440 |
n = 0; |
441 |
while (isdigit(nextc)) { |
442 |
n = n * 10 + nextc - '0'; |
443 |
scan(); |
444 |
445 |
return(n); |
446 |
447 |
448 |
449 |
double |
450 |
getnum() /* scan a positive float */ |
451 |
452 |
register int i; |
453 |
454 |
455 |
i = 0; |
456 |
while (isdigit(nextc) && i < MAXWORD) { |
457 |
str[i++] = nextc; |
458 |
scan(); |
459 |
460 |
if (nextc == '.' && i < MAXWORD) { |
461 |
str[i++] = nextc; |
462 |
scan(); |
463 |
464 |
str[i++] = nextc; |
465 |
scan(); |
466 |
467 |
468 |
if ((nextc == 'e' || nextc == 'E') && i < MAXWORD) { |
469 |
str[i++] = nextc; |
470 |
scan(); |
471 |
if ((nextc == '-' || nextc == '+') && i < MAXWORD) { |
472 |
str[i++] = nextc; |
473 |
scan(); |
474 |
475 |
476 |
str[i++] = nextc; |
477 |
scan(); |
478 |
479 |
480 |
str[i] = '\0'; |
481 |
482 |
return(atof(str)); |
483 |
484 |
485 |
486 |
EPNODE * |
487 |
getE1() /* E1 -> E1 ADDOP E2 */ |
488 |
/* E2 */ |
489 |
490 |
register EPNODE *ep1, *ep2; |
491 |
492 |
ep1 = getE2(); |
493 |
while (nextc == '+' || nextc == '-') { |
494 |
ep2 = newnode(); |
495 |
ep2->type = nextc; |
496 |
scan(); |
497 |
addekid(ep2, ep1); |
498 |
addekid(ep2, getE2()); |
499 |
#ifdef RCONST |
500 |
if (ep1->type == NUM && ep1->sibling->type == NUM) |
501 |
ep2 = rconst(ep2); |
502 |
#endif |
503 |
ep1 = ep2; |
504 |
505 |
return(ep1); |
506 |
507 |
508 |
509 |
EPNODE * |
510 |
getE2() /* E2 -> E2 MULOP E3 */ |
511 |
/* E3 */ |
512 |
513 |
514 |
515 |
ep1 = getE3(); |
516 |
while (nextc == '*' || nextc == '/') { |
517 |
ep2 = newnode(); |
518 |
519 |
scan(); |
520 |
521 |
addekid(ep2, getE3()); |
522 |
#ifdef RCONST |
523 |
524 |
525 |
#endif |
526 |
ep1 = ep2; |
527 |
528 |
return(ep1); |
529 |
530 |
531 |
532 |
EPNODE * |
533 |
getE3() /* E3 -> E4 ^ E3 */ |
534 |
/* E4 */ |
535 |
536 |
537 |
538 |
ep1 = getE4(); |
539 |
if (nextc == '^') { |
540 |
ep2 = newnode(); |
541 |
542 |
scan(); |
543 |
544 |
545 |
#ifdef RCONST |
546 |
547 |
548 |
#endif |
549 |
return(ep2); |
550 |
551 |
return(ep1); |
552 |
553 |
554 |
555 |
EPNODE * |
556 |
getE4() /* E4 -> ADDOP E5 */ |
557 |
/* E5 */ |
558 |
559 |
560 |
561 |
if (nextc == '-') { |
562 |
scan(); |
563 |
ep2 = getE5(); |
564 |
if (ep2->type == NUM) { |
565 |
ep2->v.num = -ep2->v.num; |
566 |
return(ep2); |
567 |
568 |
ep1 = newnode(); |
569 |
ep1->type = UMINUS; |
570 |
addekid(ep1, ep2); |
571 |
return(ep1); |
572 |
573 |
if (nextc == '+') |
574 |
scan(); |
575 |
return(getE5()); |
576 |
577 |
578 |
579 |
EPNODE * |
580 |
getE5() /* E5 -> (E1) */ |
581 |
/* VAR */ |
582 |
/* NUM */ |
583 |
/* $N */ |
584 |
/* FUNC(E1,..) */ |
585 |
/* ARG */ |
586 |
587 |
int i; |
588 |
589 |
590 |
if (nextc == '(') { |
591 |
scan(); |
592 |
ep1 = getE1(); |
593 |
if (nextc != ')') |
594 |
syntax("')' expected"); |
595 |
scan(); |
596 |
return(ep1); |
597 |
598 |
599 |
#ifdef INCHAN |
600 |
if (nextc == '$') { |
601 |
scan(); |
602 |
ep1 = newnode(); |
603 |
ep1->type = CHAN; |
604 |
ep1->v.chan = getinum(); |
605 |
return(ep1); |
606 |
607 |
#endif |
608 |
609 |
610 |
if (isalpha(nextc)) { |
611 |
ep1 = newnode(); |
612 |
ep1->type = VAR; |
613 |
ep1->v.ln = varinsert(getname()); |
614 |
615 |
616 |
if (curfunc != NULL) |
617 |
for (i = 1, ep2 = curfunc->v.kid->sibling; |
618 |
ep2 != NULL; i++, ep2 = ep2->sibling) |
619 |
if (!strcmp(ep2->v.name, ep1->v.ln->name)) { |
620 |
epfree(ep1); |
621 |
ep1 = newnode(); |
622 |
ep1->type = ARG; |
623 |
ep1->v.chan = i; |
624 |
break; |
625 |
626 |
#endif |
627 |
#ifdef FUNCTION |
628 |
629 |
ep2 = newnode(); |
630 |
ep2->type = FUNC; |
631 |
632 |
ep1 = ep2; |
633 |
do { |
634 |
scan(); |
635 |
addekid(ep1, getE1()); |
636 |
} while (nextc == ','); |
637 |
if (nextc != ')') |
638 |
639 |
scan(); |
640 |
641 |
#ifndef VARIABLE |
642 |
else |
643 |
syntax("'(' expected"); |
644 |
#endif |
645 |
#endif |
646 |
#ifdef RCONST |
647 |
if (isconstvar(ep1)) |
648 |
ep1 = rconst(ep1); |
649 |
#endif |
650 |
return(ep1); |
651 |
652 |
#endif |
653 |
654 |
if (isdecimal(nextc)) { |
655 |
ep1 = newnode(); |
656 |
ep1->type = NUM; |
657 |
ep1->v.num = getnum(); |
658 |
return(ep1); |
659 |
660 |
661 |
662 |
663 |
664 |
#ifdef RCONST |
665 |
EPNODE * |
666 |
rconst(epar) /* reduce a constant expression */ |
667 |
668 |
669 |
670 |
671 |
ep = newnode(); |
672 |
ep->type = NUM; |
673 |
errno = 0; |
674 |
ep->v.num = evalue(epar); |
675 |
if (errno) |
676 |
syntax("bad constant expression"); |
677 |
epfree(epar); |
678 |
679 |
return(ep); |
680 |
681 |
682 |
683 |
isconstvar(ep) /* is ep linked to a constant? */ |
684 |
685 |
686 |
#ifdef VARIABLE |
687 |
register EPNODE *ep1; |
688 |
#ifdef FUNCTION |
689 |
LIBR *lp; |
690 |
691 |
if (ep->type == FUNC) { |
692 |
if (ep->v.kid->type != VAR) |
693 |
return(0); |
694 |
ep1 = ep->v.kid->v.ln->def; |
695 |
if (ep1 != NULL && ep1->type != ':') |
696 |
return(0); |
697 |
if ((ep1 == NULL || ep1->v.kid->type != FUNC) |
698 |
&& ((lp = liblookup(ep->v.kid->v.ln->name)) == NULL |
699 |
|| lp->atyp != ':')) |
700 |
return(0); |
701 |
for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling) |
702 |
if (ep1->type != NUM) |
703 |
return(0); |
704 |
return(1); |
705 |
706 |
#endif |
707 |
if (ep->type != VAR) |
708 |
return(0); |
709 |
ep1 = ep->v.ln->def; |
710 |
if (ep1 == NULL || ep1->type != ':') |
711 |
return(0); |
712 |
#ifdef FUNCTION |
713 |
if (ep1->v.kid->type != SYM) |
714 |
return(0); |
715 |
#endif |
716 |
return(1); |
717 |
#else |
718 |
return(ep->type == FUNC); |
719 |
#endif |
720 |
721 |
#endif |
