--- ray/src/common/calexpr.c 1992/09/26 08:13:32 2.7 +++ ray/src/common/calexpr.c 2024/09/16 17:31:14 2.51 @@ -1,9 +1,6 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: calexpr.c,v 2.51 2024/09/16 17:31:14 greg Exp $"; #endif - /* * Compute data values using expression parser * @@ -16,59 +13,53 @@ static char SCCSid[] = "$SunId$ LBL"; * 1/29/87 Made variables conditional (VARIABLE) * * 5/19/88 Added constant subexpression elimination (RCONST) + * + * 2/19/03 Eliminated conditional compiles in favor of esupport extern. */ -#include +#include "copyright.h" #include - #include +#include +#include +#include "rtmisc.h" +#include "rtio.h" +#include "rterror.h" #include "calcomp.h" #define MAXLINE 256 /* maximum line length */ #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) -#define isdecimal(c) (isdigit(c) || (c) == '.') +#define isdecimal(c) (isdigit(c) | ((c) == '.')) -#ifndef atof -extern double atof(); -#endif -extern double pow(); -extern char *fgets(), *savestr(); -extern char *emalloc(), *ecalloc(); -extern EPNODE *curfunc; -extern double efunc(), evariable(); -static double euminus(), echannel(), eargument(), enumber(); -static double eadd(), esubtr(), emult(), edivi(), epow(); -static double ebotch(); +#define envalue(ep) ((ep)->type==NUM ? (ep)->v.num : evalue(ep)) +static double euminus(EPNODE *), enumber(EPNODE *); +static double echannel(EPNODE *); +static double eadd(EPNODE *), esubtr(EPNODE *), + emult(EPNODE *), edivi(EPNODE *), + epow(EPNODE *); +static double ebotch(EPNODE *); + +unsigned int esupport = /* what to support */ + E_VARIABLE | E_FUNCTION ; + +int eofc = 0; /* optional end-of-file character */ int nextc; /* lookahead character */ -double (*eoper[])() = { /* expression operations */ +double (*eoper[])(EPNODE *) = { /* expression operations */ ebotch, -#ifdef VARIABLE evariable, -#else - ebotch, -#endif enumber, euminus, -#ifdef INCHAN echannel, -#else - ebotch, -#endif -#ifdef FUNCTION efunc, eargument, -#else ebotch, ebotch, -#endif - ebotch, - ebotch, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, emult, @@ -94,44 +85,99 @@ static int linepos; /* position in buffer */ EPNODE * -eparse(expr) /* parse an expression string */ -char *expr; +eparse( /* parse an expression string */ + char *expr +) { EPNODE *ep; initstr(expr, NULL, 0); -#if defined(VARIABLE) && defined(FUNCTION) - curfunc = NULL; -#endif + ecurfunc = NULL; ep = getE1(); if (nextc != EOF) - syntax("unexpected character"); + esyntax("unexpected character"); return(ep); } double -eval(expr) /* evaluate an expression string */ -char *expr; +eval( /* evaluate an expression string */ + char *expr +) { - register EPNODE *ep; + int prev_support = esupport; + EPNODE *ep; double rval; + esupport &= ~E_RCONST; /* don't bother reducing constant expr */ ep = eparse(expr); + esupport = prev_support; /* as you were */ rval = evalue(ep); - epfree(ep); + epfree(ep,1); return(rval); } -epfree(epar) /* free a parse tree */ -register EPNODE *epar; +int +epcmp( /* compare two expressions for equivalence */ + EPNODE *ep1, + EPNODE *ep2 +) { - register EPNODE *ep; + double d; + if (ep1->type != ep2->type) + return(1); + + switch (ep1->type) { + + case VAR: + return(ep1->v.ln != ep2->v.ln); + + case NUM: + if (ep2->v.num == 0) + return(ep1->v.num != 0); + d = ep1->v.num / ep2->v.num; + return((d > 1.000000000001) | (d < 0.999999999999)); + + case CHAN: + case ARG: + return(ep1->v.chan != ep2->v.chan); + + case '=': + case ':': + return(epcmp(ep1->v.kid->sibling, ep2->v.kid->sibling)); + + case CLKT: + case SYM: /* should never get this one */ + return(0); + + default: + ep1 = ep1->v.kid; + ep2 = ep2->v.kid; + while (ep1 != NULL) { + if (ep2 == NULL) + return(1); + if (epcmp(ep1, ep2)) + return(1); + ep1 = ep1->sibling; + ep2 = ep2->sibling; + } + return(ep2 != NULL); + } +} + + +void +epfree( /* free a parse tree */ + EPNODE *epar, + int frep +) +{ + EPNODE *ep; + switch (epar->type) { -#if defined(VARIABLE) || defined(FUNCTION) case VAR: varfree(epar->v.ln); break; @@ -139,118 +185,192 @@ register EPNODE *epar; case SYM: freestr(epar->v.name); break; -#endif case NUM: case CHAN: case ARG: - case TICK: + case CLKT: break; default: - for (ep = epar->v.kid; ep != NULL; ep = ep->sibling) - epfree(ep); + if (epar->nkids < 0) { + ep = epar->v.kid - epar->nkids; + while (ep > epar->v.kid) + epfree(--ep, 0); + efree(ep); /* free array space */ + } else + while ((ep = epar->v.kid) != NULL) { + epar->v.kid = ep->sibling; + epfree(ep, 1); + } break; } + if (frep) + efree(epar); + else + memset(epar, 0, sizeof(EPNODE)); +} - efree((char *)epar); + +static void +epflatten( /* flatten hierarchies for '+', '*' */ + EPNODE *epar +) +{ + EPNODE *ep; + + if (epar->nkids < 0) /* can't handle array allocations */ + return; + + for (ep = epar->v.kid; ep != NULL; ep = ep->sibling) + while (ep->type == epar->type && ep->nkids > 0) { + EPNODE *ep1 = ep->v.kid; + while (ep1->sibling != NULL) + ep1 = ep1->sibling; + ep1->sibling = ep->sibling; + epar->nkids += ep->nkids - 1; + ep1 = ep->v.kid; + *ep = *ep1; + efree(ep1); /* not epfree()! */ + } } - /* the following used to be a switch */ -#ifdef FUNCTION -static double -eargument(ep) -EPNODE *ep; + +void +epoptimize( /* flatten operations, lists -> arrays */ + EPNODE *epar +) { - return(argument(ep->v.chan)); + EPNODE *ep; + + if ((epar->type == '+') | (epar->type == '*')) + epflatten(epar); /* flatten associative operations */ + + if (epar->nkids) /* do children if any */ + for (ep = epar->v.kid; ep != NULL; ep = ep->sibling) + epoptimize(ep); + + if (epar->nkids > 4) { /* make list into array if > 4 kids */ + int n = 1; + epar->v.kid = (EPNODE *)erealloc(epar->v.kid, + sizeof(EPNODE)*epar->nkids); + while (n < epar->nkids) { + ep = epar->v.kid[n-1].sibling; + epar->v.kid[n] = *ep; + efree(ep); /* not epfree()! */ + epar->v.kid[n-1].sibling = epar->v.kid + n; + n++; + } + epar->nkids = -n; + } } -#endif + /* the following used to be a switch */ static double -enumber(ep) -EPNODE *ep; +enumber( + EPNODE *ep +) { return(ep->v.num); } static double -euminus(ep) -EPNODE *ep; +euminus( + EPNODE *ep +) { - register EPNODE *ep1 = ep->v.kid; + EPNODE *ep1 = ep->v.kid; return(-evalue(ep1)); } -#ifdef INCHAN static double -echannel(ep) -EPNODE *ep; +echannel( + EPNODE *ep +) { return(chanvalue(ep->v.chan)); } -#endif static double -eadd(ep) -EPNODE *ep; +eadd( + EPNODE *ep +) { - register EPNODE *ep1 = ep->v.kid; + double sum = 0; + EPNODE *ep1 = ep->v.kid; - return(evalue(ep1) + evalue(ep1->sibling)); + do + sum += envalue(ep1); + while ((ep1 = ep1->sibling) != NULL); + + return(sum); } static double -esubtr(ep) -EPNODE *ep; +esubtr( + EPNODE *ep +) { - register EPNODE *ep1 = ep->v.kid; + EPNODE *ep1 = ep->v.kid; + EPNODE *ep2 = ep1->sibling; - return(evalue(ep1) - evalue(ep1->sibling)); + return(envalue(ep1) - envalue(ep2)); } static double -emult(ep) -EPNODE *ep; +emult( + EPNODE *ep +) { - register EPNODE *ep1 = ep->v.kid; + double prod = 1; + EPNODE *ep1 = ep->v.kid; - return(evalue(ep1) * evalue(ep1->sibling)); + do + prod *= envalue(ep1); + while ((ep1 = ep1->sibling) != NULL); + + return(prod); } static double -edivi(ep) -EPNODE *ep; +edivi( + EPNODE *ep +) { - register EPNODE *ep1 = ep->v.kid; - double d; + EPNODE *ep1 = ep->v.kid; + double den = evalue(ep1->sibling); - d = evalue(ep1->sibling); - if (d == 0.0) { + if (den == 0.0) { wputs("Division by zero\n"); errno = ERANGE; return(0.0); } - return(evalue(ep1) / d); + return(envalue(ep1) / den); } static double -epow(ep) -EPNODE *ep; +epow( + EPNODE *ep +) { - register EPNODE *ep1 = ep->v.kid; + EPNODE *ep1 = ep->v.kid; double d; int lasterrno; lasterrno = errno; errno = 0; d = pow(evalue(ep1), evalue(ep1->sibling)); -#ifdef IEEE - if (!finite(d)) - errno = EDOM; +#ifdef isnan + if (errno == 0) { + if (isnan(d)) + errno = EDOM; + else if (isinf(d)) + errno = ERANGE; + } #endif - if (errno) { + if ((errno == EDOM) | (errno == ERANGE)) { wputs("Illegal power\n"); return(0.0); } @@ -259,46 +379,42 @@ EPNODE *ep; } static double -ebotch(ep) -EPNODE *ep; +ebotch( + EPNODE *ep +) { eputs("Bad expression!\n"); quit(1); + return 0.0; /* pro forma return */ } EPNODE * -ekid(ep, n) /* return pointer to a node's nth kid */ -register EPNODE *ep; -register int n; +ekid( /* return pointer to a node's nth kid */ + EPNODE *ep, + int n +) { - - for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) - if (--n < 0) - break; - + if (ep->nkids < 0) { /* allocated array? */ + if (n >= -ep->nkids) + return(NULL); + return(ep->v.kid + n); + } + ep = ep->v.kid; /* else get from list */ + while (n-- > 0) + if ((ep = ep->sibling) == NULL) + break; return(ep); } -int -nekids(ep) /* return # of kids for node ep */ -register EPNODE *ep; +void +initfile( /* prepare input file */ + FILE *fp, + char *fn, + int ln +) { - register int n = 0; - - for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) - n++; - - return(n); -} - - -initfile(fp, fn, ln) /* prepare input file */ -FILE *fp; -char *fn; -int ln; -{ static char inpbuf[MAXLINE]; infp = fp; @@ -307,29 +423,33 @@ int ln; lineno = ln; linepos = 0; inpbuf[0] = '\0'; - scan(); + escan(); } -initstr(s, fn, ln) /* prepare input string */ -char *s; -char *fn; -int ln; +void +initstr( /* prepare input string */ + char *s, + char *fn, + int ln +) { infp = NULL; infile = fn; lineno = ln; linbuf = s; linepos = 0; - scan(); + escan(); } -getscanpos(fnp, lnp, spp, fpp) /* return current scan position */ -char **fnp; -int *lnp; -char **spp; -FILE **fpp; +void +getscanpos( /* return current scan position */ + char **fnp, + int *lnp, + char **spp, + FILE **fpp +) { if (fnp != NULL) *fnp = infile; if (lnp != NULL) *lnp = lineno; @@ -339,9 +459,9 @@ FILE **fpp; int -scan() /* scan next character, return literal next */ +escan(void) /* scan next character, return literal next */ { - register int lnext = 0; + int lnext = 0; do { if (linbuf[linepos] == '\0') @@ -356,14 +476,18 @@ scan() /* scan next character, return literal next nextc = linbuf[linepos++]; if (!lnext) lnext = nextc; + if (nextc == eofc) { + nextc = EOF; + break; + } if (nextc == '{') { - scan(); + escan(); while (nextc != '}') if (nextc == EOF) - syntax("'}' expected"); + esyntax("'}' expected"); else - scan(); - scan(); + escan(); + escan(); } } while (isspace(nextc)); return(lnext); @@ -371,11 +495,12 @@ scan() /* scan next character, return literal next char * -ltoa(l) /* convert long to ascii */ -long l; +long2ascii( /* convert long to ascii */ + long l +) { static char buf[16]; - register char *cp; + char *cp; int neg = 0; if (l == 0) @@ -396,16 +521,18 @@ long l; } -syntax(err) /* report syntax error and quit */ -char *err; +void +esyntax( /* report syntax error and quit */ + char *err +) { - register int i; + int i; - if (infile != NULL || lineno != 0) { + if ((infile != NULL) | (lineno != 0)) { if (infile != NULL) eputs(infile); if (lineno != 0) { eputs(infile != NULL ? ", line " : "line "); - eputs(ltoa((long)lineno)); + eputs(long2ascii((long)lineno)); } eputs(":\n"); } @@ -421,85 +548,94 @@ char *err; } -addekid(ep, ekid) /* add a child to ep */ -register EPNODE *ep; -EPNODE *ekid; +void +addekid( /* add a child to ep */ + EPNODE *ep, + EPNODE *ek +) { + if (ep->nkids < 0) { + eputs("Cannot add kid to EPNODE array\n"); + quit(1); + } + ep->nkids++; if (ep->v.kid == NULL) - ep->v.kid = ekid; + ep->v.kid = ek; else { for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling) ; - ep->sibling = ekid; + ep->sibling = ek; } - ekid->sibling = NULL; + ek->sibling = NULL; /* shouldn't be necessary */ } -#if defined(VARIABLE) || defined(FUNCTION) char * -getname() /* scan an identifier */ +getname(void) /* scan an identifier */ { - static char str[MAXWORD+1]; - register int i, lnext; + static char str[RMAXWORD+1]; + int i, lnext; lnext = nextc; - for (i = 0; i < MAXWORD && isid(lnext); i++, lnext = scan()) + for (i = 0; i < RMAXWORD && isid(lnext); i++, lnext = escan()) str[i] = lnext; str[i] = '\0'; while (isid(lnext)) /* skip rest of name */ - lnext = scan(); + lnext = escan(); return(str); } -#endif int -getinum() /* scan a positive integer */ +getinum(void) /* scan a positive integer */ { - register int n, lnext; + int n, lnext; n = 0; lnext = nextc; while (isdigit(lnext)) { n = n * 10 + lnext - '0'; - lnext = scan(); + lnext = escan(); } return(n); } double -getnum() /* scan a positive float */ +getnum(void) /* scan a positive float */ { - register int i, lnext; - char str[MAXWORD+1]; + int i, lnext; + char str[RMAXWORD+1]; i = 0; lnext = nextc; - while (isdigit(lnext) && i < MAXWORD) { + while (isdigit(lnext) && i < RMAXWORD) { str[i++] = lnext; - lnext = scan(); + lnext = escan(); } - if (lnext == '.' && i < MAXWORD) { + if ((lnext == '.') & (i < RMAXWORD)) { str[i++] = lnext; - lnext = scan(); - while (isdigit(lnext) && i < MAXWORD) { + lnext = escan(); + if (i == 1 && !isdigit(lnext)) + esyntax("badly formed number"); + while (isdigit(lnext) && i < RMAXWORD) { str[i++] = lnext; - lnext = scan(); + lnext = escan(); } } - if ((lnext == 'e' || lnext == 'E') && i < MAXWORD) { + if ((lnext == 'e') | (lnext == 'E') && i < RMAXWORD) { str[i++] = lnext; - lnext = scan(); - if ((lnext == '-' || lnext == '+') && i < MAXWORD) { + lnext = escan(); + if ((lnext == '-') | (lnext == '+') && i < RMAXWORD) { str[i++] = lnext; - lnext = scan(); + lnext = escan(); } - while (isdigit(lnext) && i < MAXWORD) { + if (!isdigit(lnext)) + esyntax("missing exponent"); + while (isdigit(lnext) && i < RMAXWORD) { str[i++] = lnext; - lnext = scan(); + lnext = escan(); } } str[i] = '\0'; @@ -509,22 +645,21 @@ getnum() /* scan a positive float */ EPNODE * -getE1() /* E1 -> E1 ADDOP E2 */ +getE1(void) /* E1 -> E1 ADDOP E2 */ /* E2 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; ep1 = getE2(); - while (nextc == '+' || nextc == '-') { + while ((nextc == '+') | (nextc == '-')) { ep2 = newnode(); ep2->type = nextc; - scan(); + escan(); addekid(ep2, ep1); addekid(ep2, getE2()); -#ifdef RCONST - if (ep1->type == NUM && ep1->sibling->type == NUM) + if (esupport&E_RCONST && + (ep1->type == NUM) & (ep1->sibling->type == NUM)) ep2 = rconst(ep2); -#endif ep1 = ep2; } return(ep1); @@ -532,22 +667,40 @@ getE1() /* E1 -> E1 ADDOP E2 */ EPNODE * -getE2() /* E2 -> E2 MULOP E3 */ +getE2(void) /* E2 -> E2 MULOP E3 */ /* E3 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; ep1 = getE3(); - while (nextc == '*' || nextc == '/') { + while ((nextc == '*') | (nextc == '/')) { ep2 = newnode(); ep2->type = nextc; - scan(); + escan(); addekid(ep2, ep1); addekid(ep2, getE3()); -#ifdef RCONST - if (ep1->type == NUM && ep1->sibling->type == NUM) - ep2 = rconst(ep2); -#endif + if (esupport&E_RCONST) { + EPNODE *ep3 = ep1->sibling; + if ((ep1->type == NUM) & (ep3->type == NUM)) { + ep2 = rconst(ep2); + } else if (ep3->type == NUM) { + if (ep2->type == '/') { + if (ep3->v.num == 0) + esyntax("divide by zero constant"); + ep2->type = '*'; /* for speed */ + ep3->v.num = 1./ep3->v.num; + } else if (ep3->v.num == 0) { + ep1->sibling = NULL; /* (E2 * 0) */ + epfree(ep2,1); + ep2 = ep3; + } + } else if (ep1->type == NUM && ep1->v.num == 0) { + epfree(ep3,1); /* (0 * E3) or (0 / E3) */ + ep1->sibling = NULL; + efree(ep2); + ep2 = ep1; + } + } ep1 = ep2; } return(ep1); @@ -555,44 +708,61 @@ getE2() /* E2 -> E2 MULOP E3 */ EPNODE * -getE3() /* E3 -> E4 ^ E3 */ +getE3(void) /* E3 -> E4 ^ E3 */ /* E4 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; - ep1 = getE4(); - if (nextc == '^') { + ep1 = getE4(); + if (nextc != '^') + return(ep1); ep2 = newnode(); ep2->type = nextc; - scan(); + escan(); addekid(ep2, ep1); addekid(ep2, getE3()); -#ifdef RCONST - if (ep1->type == NUM && ep1->sibling->type == NUM) - ep2 = rconst(ep2); -#endif + if (esupport&E_RCONST) { + EPNODE *ep3 = ep1->sibling; + if ((ep1->type == NUM) & (ep3->type == NUM)) { + ep2 = rconst(ep2); + } else if (ep1->type == NUM && ep1->v.num == 0) { + epfree(ep3,1); /* (0 ^ E3) */ + ep1->sibling = NULL; + efree(ep2); + ep2 = ep1; + } else if ((ep3->type == NUM && ep3->v.num == 0) | + (ep1->type == NUM && ep1->v.num == 1)) { + epfree(ep2,0); /* (E4 ^ 0) or (1 ^ E3) */ + ep2->type = NUM; + ep2->v.num = 1; + } else if (ep3->type == NUM && ep3->v.num == 1) { + efree(ep3); /* (E4 ^ 1) */ + ep1->sibling = NULL; + efree(ep2); + ep2 = ep1; + } + } return(ep2); - } - return(ep1); } EPNODE * -getE4() /* E4 -> ADDOP E5 */ +getE4(void) /* E4 -> ADDOP E5 */ /* E5 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; if (nextc == '-') { - scan(); + escan(); ep2 = getE5(); if (ep2->type == NUM) { ep2->v.num = -ep2->v.num; return(ep2); } if (ep2->type == UMINUS) { /* don't generate -(-E5) */ - efree((char *)ep2); - return(ep2->v.kid); + ep1 = ep2->v.kid; + efree(ep2); + return(ep1); } ep1 = newnode(); ep1->type = UMINUS; @@ -600,127 +770,113 @@ getE4() /* E4 -> ADDOP E5 */ return(ep1); } if (nextc == '+') - scan(); + escan(); return(getE5()); } EPNODE * -getE5() /* E5 -> (E1) */ +getE5(void) /* E5 -> (E1) */ /* VAR */ /* NUM */ /* $N */ /* FUNC(E1,..) */ /* ARG */ { - int i; - char *nam; - register EPNODE *ep1, *ep2; + int i; + char *nam; + EPNODE *ep1, *ep2; - if (nextc == '(') { - scan(); - ep1 = getE1(); - if (nextc != ')') - syntax("')' expected"); - scan(); - return(ep1); - } - -#ifdef INCHAN - if (nextc == '$') { - scan(); - ep1 = newnode(); - ep1->type = CHAN; - ep1->v.chan = getinum(); - return(ep1); - } -#endif - -#if defined(VARIABLE) || defined(FUNCTION) - if (isalpha(nextc) || nextc == CNTXMARK) { - nam = getname(); -#if defined(VARIABLE) && defined(FUNCTION) - ep1 = NULL; - if (curfunc != NULL) - for (i = 1, ep2 = curfunc->v.kid->sibling; - ep2 != NULL; i++, ep2 = ep2->sibling) - if (!strcmp(ep2->v.name, nam)) { - ep1 = newnode(); - ep1->type = ARG; - ep1->v.chan = i; - break; + if (nextc == '(') { + escan(); + ep1 = getE1(); + if (nextc != ')') + esyntax("')' expected"); + escan(); + return(ep1); + } + if (esupport&E_INCHAN && nextc == '$') { + escan(); + ep1 = newnode(); + ep1->type = CHAN; + ep1->v.chan = getinum(); + return(ep1); + } + if (esupport&(E_VARIABLE|E_FUNCTION) && + (isalpha(nextc) | (nextc == CNTXMARK))) { + nam = getname(); + ep1 = NULL; + if ((esupport&(E_VARIABLE|E_FUNCTION)) == (E_VARIABLE|E_FUNCTION) + && ecurfunc != NULL) + for (i = 1, ep2 = ecurfunc->v.kid->sibling; + ep2 != NULL; i++, ep2 = ep2->sibling) + if (!strcmp(ep2->v.name, nam)) { + ep1 = newnode(); + ep1->type = ARG; + ep1->v.chan = i; + break; + } + if (ep1 == NULL) { + ep1 = newnode(); + ep1->type = VAR; + ep1->v.ln = varinsert(nam); } - if (ep1 == NULL) -#endif - { - ep1 = newnode(); - ep1->type = VAR; - ep1->v.ln = varinsert(nam); + if (esupport&E_FUNCTION && nextc == '(') { + ep2 = newnode(); + ep2->type = FUNC; + addekid(ep2, ep1); + ep1 = ep2; + do { + escan(); + addekid(ep1, getE1()); + } while (nextc == ','); + if (nextc != ')') + esyntax("')' expected"); + escan(); + } else if (!(esupport&E_VARIABLE)) + esyntax("'(' expected"); + if (esupport&E_RCONST && isconstvar(ep1)) + ep1 = rconst(ep1); + return(ep1); } -#ifdef FUNCTION - if (nextc == '(') { - ep2 = newnode(); - ep2->type = FUNC; - addekid(ep2, ep1); - ep1 = ep2; - do { - scan(); - addekid(ep1, getE1()); - } while (nextc == ','); - if (nextc != ')') - syntax("')' expected"); - scan(); + if (isdecimal(nextc)) { + ep1 = newnode(); + ep1->type = NUM; + ep1->v.num = getnum(); + return(ep1); } -#ifndef VARIABLE - else - syntax("'(' expected"); -#endif -#endif -#ifdef RCONST - if (isconstvar(ep1)) - ep1 = rconst(ep1); -#endif - return(ep1); - } -#endif - - if (isdecimal(nextc)) { - ep1 = newnode(); - ep1->type = NUM; - ep1->v.num = getnum(); - return(ep1); - } - syntax("unexpected character"); + esyntax("unexpected character"); + return NULL; /* pro forma return */ } -#ifdef RCONST EPNODE * -rconst(epar) /* reduce a constant expression */ -register EPNODE *epar; +rconst( /* reduce a constant expression */ + EPNODE *epar +) { - register EPNODE *ep; + EPNODE *ep; ep = newnode(); ep->type = NUM; errno = 0; ep->v.num = evalue(epar); - if (errno) - syntax("bad constant expression"); - epfree(epar); + if ((errno == EDOM) | (errno == ERANGE)) + esyntax("bad constant expression"); + epfree(epar,1); return(ep); } -isconstvar(ep) /* is ep linked to a constant expression? */ -register EPNODE *ep; +int +isconstvar( /* is ep linked to a constant expression? */ + EPNODE *ep +) { -#ifdef VARIABLE - register EPNODE *ep1; -#ifdef FUNCTION + EPNODE *ep1; - if (ep->type == FUNC) { + if (esupport&E_FUNCTION && ep->type == FUNC) { if (!isconstfun(ep->v.kid)) return(0); for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling) @@ -728,37 +884,34 @@ register EPNODE *ep; return(0); return(1); } -#endif if (ep->type != VAR) return(0); ep1 = ep->v.ln->def; if (ep1 == NULL || ep1->type != ':') return(0); -#ifdef FUNCTION - if (ep1->v.kid->type != SYM) + if (esupport&E_FUNCTION && ep1->v.kid->type != SYM) return(0); -#endif return(1); -#else - return(ep->type == FUNC); -#endif } -#if defined(FUNCTION) && defined(VARIABLE) -isconstfun(ep) /* is ep linked to a constant function? */ -register EPNODE *ep; +int +isconstfun( /* is ep linked to a constant function? */ + EPNODE *ep +) { - register EPNODE *dp; - register LIBR *lp; + EPNODE *dp; + ELIBR *lp; if (ep->type != VAR) return(0); - if ((dp = ep->v.ln->def) != NULL && dp->v.kid->type == FUNC) - return(dp->type == ':'); + if ((dp = ep->v.ln->def) != NULL) { + if (dp->v.kid->type == FUNC) + return(dp->type == ':'); + else + return(0); /* don't identify masked library functions */ + } if ((lp = ep->v.ln->lib) != NULL) return(lp->atyp == ':'); return(0); } -#endif -#endif
