--- ray/src/common/calexpr.c 2008/05/01 16:42:05 2.32 +++ ray/src/common/calexpr.c 2024/02/25 04:11:10 2.47 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: calexpr.c,v 2.32 2008/05/01 16:42:05 greg Exp $"; +static const char RCSid[] = "$Id: calexpr.c,v 2.47 2024/02/25 04:11:10 greg Exp $"; #endif /* * Compute data values using expression parser @@ -19,8 +19,6 @@ static const char RCSid[] = "$Id: calexpr.c,v 2.32 200 #include "copyright.h" -#include -#include #include #include #include @@ -35,8 +33,10 @@ static const char RCSid[] = "$Id: calexpr.c,v 2.32 200 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) -#define isdecimal(c) (isdigit(c) || (c) == '.') +#define isdecimal(c) (isdigit(c) | ((c) == '.')) +#define envalue(ep) ((ep)->type==NUM ? (ep)->v.num : evalue(ep)) + static double euminus(EPNODE *), eargument(EPNODE *), enumber(EPNODE *); static double echannel(EPNODE *); static double eadd(EPNODE *), esubtr(EPNODE *), @@ -105,20 +105,23 @@ eval( /* evaluate an expression string */ char *expr ) { - register EPNODE *ep; + int prev_support = esupport; + EPNODE *ep; double rval; + esupport &= ~E_RCONST; /* don't bother reducing constant expr */ ep = eparse(expr); + esupport = prev_support; /* as you were */ rval = evalue(ep); - epfree(ep); + epfree(ep,1); return(rval); } int epcmp( /* compare two expressions for equivalence */ - register EPNODE *ep1, - register EPNODE *ep2 + EPNODE *ep1, + EPNODE *ep2 ) { double d; @@ -167,10 +170,11 @@ epcmp( /* compare two expressions for equivalence */ void epfree( /* free a parse tree */ - register EPNODE *epar + EPNODE *epar, + int frep ) { - register EPNODE *ep; + EPNODE *ep; switch (epar->type) { @@ -189,17 +193,78 @@ epfree( /* free a parse tree */ break; default: - while ((ep = epar->v.kid) != NULL) { - epar->v.kid = ep->sibling; - epfree(ep); - } + if (epar->nkids < 0) { + ep = epar->v.kid - epar->nkids; + while (ep > epar->v.kid) + epfree(--ep, 0); + efree(ep); /* free array space */ + } else + while ((ep = epar->v.kid) != NULL) { + epar->v.kid = ep->sibling; + epfree(ep, 1); + } break; } + if (frep) + efree(epar); +} - efree((char *)epar); + +static void +epflatten( /* flatten hierarchies for '+', '*' */ + EPNODE *epar +) +{ + EPNODE *ep; + + if (epar->nkids < 0) { + eputs("Cannot flatten EPNODE array\n"); + quit(1); + } + for (ep = epar->v.kid; ep != NULL; ep = ep->sibling) + while (ep->type == epar->type) { + EPNODE *ep1 = ep->v.kid; + while (ep1->sibling != NULL) + ep1 = ep1->sibling; + ep1->sibling = ep->sibling; + epar->nkids += nekids(ep) - 1; + ep1 = ep->v.kid; + *ep = *ep1; + efree(ep1); /* not epfree()! */ + } } + +void +epoptimize( /* flatten operations, lists -> arrays */ + EPNODE *epar +) +{ + EPNODE *ep; + + if ((epar->type == '+') | (epar->type == '*')) + epflatten(epar); /* flatten associative operations */ + + if (epar->nkids) /* do children if any */ + for (ep = epar->v.kid; ep != NULL; ep = ep->sibling) + epoptimize(ep); + + if (epar->nkids > 4) { /* make list into array if > 4 kids */ + int n = 1; + epar->v.kid = (EPNODE *)erealloc(epar->v.kid, + sizeof(EPNODE)*epar->nkids); + while (n < epar->nkids) { + ep = epar->v.kid[n-1].sibling; + epar->v.kid[n] = *ep; + efree(ep); /* not epfree()! */ + epar->v.kid[n-1].sibling = epar->v.kid + n; + n++; + } + epar->nkids = -n; + } +} + /* the following used to be a switch */ static double eargument( @@ -222,7 +287,7 @@ euminus( EPNODE *ep ) { - register EPNODE *ep1 = ep->v.kid; + EPNODE *ep1 = ep->v.kid; return(-evalue(ep1)); } @@ -240,9 +305,14 @@ eadd( EPNODE *ep ) { - register EPNODE *ep1 = ep->v.kid; + double sum = 0; + EPNODE *ep1 = ep->v.kid; - return(evalue(ep1) + evalue(ep1->sibling)); + do + sum += envalue(ep1); + while ((ep1 = ep1->sibling) != NULL); + + return(sum); } static double @@ -250,9 +320,10 @@ esubtr( EPNODE *ep ) { - register EPNODE *ep1 = ep->v.kid; + EPNODE *ep1 = ep->v.kid; + EPNODE *ep2 = ep1->sibling; - return(evalue(ep1) - evalue(ep1->sibling)); + return(envalue(ep1) - envalue(ep2)); } static double @@ -260,9 +331,14 @@ emult( EPNODE *ep ) { - register EPNODE *ep1 = ep->v.kid; + double prod = 1; + EPNODE *ep1 = ep->v.kid; - return(evalue(ep1) * evalue(ep1->sibling)); + do + prod *= envalue(ep1); + while ((ep1 = ep1->sibling) != NULL); + + return(prod); } static double @@ -270,16 +346,17 @@ edivi( EPNODE *ep ) { - register EPNODE *ep1 = ep->v.kid; + EPNODE *ep1 = ep->v.kid; + EPNODE *ep2 = ep1->sibling; double d; - d = evalue(ep1->sibling); + d = evalue(ep2); if (d == 0.0) { wputs("Division by zero\n"); errno = ERANGE; return(0.0); } - return(evalue(ep1) / d); + return(envalue(ep1) / d); } static double @@ -287,7 +364,7 @@ epow( EPNODE *ep ) { - register EPNODE *ep1 = ep->v.kid; + EPNODE *ep1 = ep->v.kid; double d; int lasterrno; @@ -295,13 +372,14 @@ epow( errno = 0; d = pow(evalue(ep1), evalue(ep1->sibling)); #ifdef isnan - if (errno == 0) + if (errno == 0) { if (isnan(d)) errno = EDOM; else if (isinf(d)) errno = ERANGE; + } #endif - if (errno == EDOM || errno == ERANGE) { + if ((errno == EDOM) | (errno == ERANGE)) { wputs("Illegal power\n"); return(0.0); } @@ -322,33 +400,23 @@ ebotch( EPNODE * ekid( /* return pointer to a node's nth kid */ - register EPNODE *ep, - register int n + EPNODE *ep, + int n ) { - - for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) - if (--n < 0) - break; - + if (ep->nkids < 0) { /* allocated array? */ + if (n >= -ep->nkids) + return(NULL); + return(ep->v.kid + n); + } + ep = ep->v.kid; /* else get from list */ + while (n-- > 0) + if ((ep = ep->sibling) == NULL) + break; return(ep); } -int -nekids( /* return # of kids for node ep */ - register EPNODE *ep -) -{ - register int n = 0; - - for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) - n++; - - return(n); -} - - void initfile( /* prepare input file */ FILE *fp, @@ -402,7 +470,7 @@ getscanpos( /* return current scan position */ int scan(void) /* scan next character, return literal next */ { - register int lnext = 0; + int lnext = 0; do { if (linbuf[linepos] == '\0') @@ -441,7 +509,7 @@ long2ascii( /* convert long to ascii */ ) { static char buf[16]; - register char *cp; + char *cp; int neg = 0; if (l == 0) @@ -467,9 +535,9 @@ syntax( /* report syntax error and quit */ char *err ) { - register int i; + int i; - if (infile != NULL || lineno != 0) { + if ((infile != NULL) | (lineno != 0)) { if (infile != NULL) eputs(infile); if (lineno != 0) { eputs(infile != NULL ? ", line " : "line "); @@ -491,18 +559,23 @@ syntax( /* report syntax error and quit */ void addekid( /* add a child to ep */ - register EPNODE *ep, - EPNODE *ekid + EPNODE *ep, + EPNODE *ek ) { + if (ep->nkids < 0) { + eputs("Cannot add kid to EPNODE array\n"); + quit(1); + } + ep->nkids++; if (ep->v.kid == NULL) - ep->v.kid = ekid; + ep->v.kid = ek; else { for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling) ; - ep->sibling = ekid; + ep->sibling = ek; } - ekid->sibling = NULL; + ek->sibling = NULL; /* shouldn't be necessary */ } @@ -510,7 +583,7 @@ char * getname(void) /* scan an identifier */ { static char str[RMAXWORD+1]; - register int i, lnext; + int i, lnext; lnext = nextc; for (i = 0; i < RMAXWORD && isid(lnext); i++, lnext = scan()) @@ -526,7 +599,7 @@ getname(void) /* scan an identifier */ int getinum(void) /* scan a positive integer */ { - register int n, lnext; + int n, lnext; n = 0; lnext = nextc; @@ -541,7 +614,7 @@ getinum(void) /* scan a positive integer */ double getnum(void) /* scan a positive float */ { - register int i, lnext; + int i, lnext; char str[RMAXWORD+1]; i = 0; @@ -550,7 +623,7 @@ getnum(void) /* scan a positive float */ str[i++] = lnext; lnext = scan(); } - if (lnext == '.' && i < RMAXWORD) { + if ((lnext == '.') & (i < RMAXWORD)) { str[i++] = lnext; lnext = scan(); if (i == 1 && !isdigit(lnext)) @@ -581,20 +654,20 @@ getnum(void) /* scan a positive float */ EPNODE * -getE1(void) /* E1 -> E1 ADDOP E2 */ +getE1(void) /* E1 -> E1 ADDOP E2 */ /* E2 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; ep1 = getE2(); - while (nextc == '+' || nextc == '-') { + while ((nextc == '+') | (nextc == '-')) { ep2 = newnode(); ep2->type = nextc; scan(); addekid(ep2, ep1); addekid(ep2, getE2()); if (esupport&E_RCONST && - ep1->type == NUM && ep1->sibling->type == NUM) + (ep1->type == NUM) & (ep1->sibling->type == NUM)) ep2 = rconst(ep2); ep1 = ep2; } @@ -603,21 +676,40 @@ getE1(void) /* E1 -> E1 ADDOP E2 */ EPNODE * -getE2(void) /* E2 -> E2 MULOP E3 */ +getE2(void) /* E2 -> E2 MULOP E3 */ /* E3 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; ep1 = getE3(); - while (nextc == '*' || nextc == '/') { + while ((nextc == '*') | (nextc == '/')) { ep2 = newnode(); ep2->type = nextc; scan(); addekid(ep2, ep1); addekid(ep2, getE3()); - if (esupport&E_RCONST && - ep1->type == NUM && ep1->sibling->type == NUM) - ep2 = rconst(ep2); + if (esupport&E_RCONST) { + EPNODE *ep3 = ep1->sibling; + if ((ep1->type == NUM) & (ep3->type == NUM)) { + ep2 = rconst(ep2); + } else if (ep3->type == NUM) { + if (ep2->type == '/') { + if (ep3->v.num == 0) + syntax("divide by zero constant"); + ep2->type = '*'; /* for speed */ + ep3->v.num = 1./ep3->v.num; + } else if (ep3->v.num == 0) { + ep1->sibling = NULL; /* (E2 * 0) */ + epfree(ep2,1); + ep2 = ep3; + } + } else if (ep1->type == NUM && ep1->v.num == 0) { + epfree(ep3,1); /* (0 * E3) or (0 / E3) */ + ep1->sibling = NULL; + efree(ep2); + ep2 = ep1; + } + } ep1 = ep2; } return(ep1); @@ -625,32 +717,50 @@ getE2(void) /* E2 -> E2 MULOP E3 */ EPNODE * -getE3(void) /* E3 -> E4 ^ E3 */ +getE3(void) /* E3 -> E4 ^ E3 */ /* E4 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; - ep1 = getE4(); - if (nextc == '^') { + ep1 = getE4(); + if (nextc != '^') + return(ep1); ep2 = newnode(); ep2->type = nextc; scan(); addekid(ep2, ep1); addekid(ep2, getE3()); - if (esupport&E_RCONST && - ep1->type == NUM && ep1->sibling->type == NUM) - ep2 = rconst(ep2); + if (esupport&E_RCONST) { + EPNODE *ep3 = ep1->sibling; + if ((ep1->type == NUM) & (ep3->type == NUM)) { + ep2 = rconst(ep2); + } else if (ep1->type == NUM && ep1->v.num == 0) { + epfree(ep3,1); /* (0 ^ E3) */ + ep1->sibling = NULL; + efree(ep2); + ep2 = ep1; + } else if ((ep3->type == NUM && ep3->v.num == 0) | + (ep1->type == NUM && ep1->v.num == 1)) { + epfree(ep2,1); /* (E4 ^ 0) or (1 ^ E3) */ + ep2 = newnode(); + ep2->type = NUM; + ep2->v.num = 1; + } else if (ep3->type == NUM && ep3->v.num == 1) { + efree(ep3); /* (E4 ^ 1) */ + ep1->sibling = NULL; + efree(ep2); + ep2 = ep1; + } + } return(ep2); - } - return(ep1); } EPNODE * -getE4(void) /* E4 -> ADDOP E5 */ +getE4(void) /* E4 -> ADDOP E5 */ /* E5 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; if (nextc == '-') { scan(); @@ -660,8 +770,9 @@ getE4(void) /* E4 -> ADDOP E5 */ return(ep2); } if (ep2->type == UMINUS) { /* don't generate -(-E5) */ - efree((char *)ep2); - return(ep2->v.kid); + ep1 = ep2->v.kid; + efree(ep2); + return(ep1); } ep1 = newnode(); ep1->type = UMINUS; @@ -684,7 +795,7 @@ getE5(void) /* E5 -> (E1) */ { int i; char *nam; - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; if (nextc == '(') { scan(); @@ -694,7 +805,6 @@ getE5(void) /* E5 -> (E1) */ scan(); return(ep1); } - if (esupport&E_INCHAN && nextc == '$') { scan(); ep1 = newnode(); @@ -702,9 +812,8 @@ getE5(void) /* E5 -> (E1) */ ep1->v.chan = getinum(); return(ep1); } - if (esupport&(E_VARIABLE|E_FUNCTION) && - (isalpha(nextc) || nextc == CNTXMARK)) { + (isalpha(nextc) | (nextc == CNTXMARK))) { nam = getname(); ep1 = NULL; if ((esupport&(E_VARIABLE|E_FUNCTION)) == (E_VARIABLE|E_FUNCTION) @@ -740,7 +849,6 @@ getE5(void) /* E5 -> (E1) */ ep1 = rconst(ep1); return(ep1); } - if (isdecimal(nextc)) { ep1 = newnode(); ep1->type = NUM; @@ -754,18 +862,18 @@ getE5(void) /* E5 -> (E1) */ EPNODE * rconst( /* reduce a constant expression */ - register EPNODE *epar + EPNODE *epar ) { - register EPNODE *ep; + EPNODE *ep; ep = newnode(); ep->type = NUM; errno = 0; ep->v.num = evalue(epar); - if (errno == EDOM || errno == ERANGE) + if ((errno == EDOM) | (errno == ERANGE)) syntax("bad constant expression"); - epfree(epar); + epfree(epar,1); return(ep); } @@ -773,10 +881,10 @@ rconst( /* reduce a constant expression */ int isconstvar( /* is ep linked to a constant expression? */ - register EPNODE *ep + EPNODE *ep ) { - register EPNODE *ep1; + EPNODE *ep1; if (esupport&E_FUNCTION && ep->type == FUNC) { if (!isconstfun(ep->v.kid)) @@ -799,11 +907,11 @@ isconstvar( /* is ep linked to a constant expression int isconstfun( /* is ep linked to a constant function? */ - register EPNODE *ep + EPNODE *ep ) { - register EPNODE *dp; - register LIBR *lp; + EPNODE *dp; + LIBR *lp; if (ep->type != VAR) return(0);
