root/radiance/ray/src/common/calexpr.c
Revision: 2.51
Committed: Mon Sep 16 17:31:14 2024 UTC (10 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.50: +41 -41 lines
refactor: Changed too-generic symbol names in calcomp.h
2 static const char RCSid[] = "$Id: calexpr.c,v 2.50 2024/02/27 01:24:10 greg Exp $";
5 * Compute data values using expression parser
6 *
7 * 7/1/85 Greg Ward
8 *
9 * 11/11/85 Made channel input conditional with (INCHAN) compiles.
10 *
11 * 4/2/86 Added conditional compiles for function definitions (FUNCTION).
12 *
13 * 1/29/87 Made variables conditional (VARIABLE)
14 *
15 * 5/19/88 Added constant subexpression elimination (RCONST)
16 *
17 * 2/19/03 Eliminated conditional compiles in favor of esupport extern.
18 */
19
20 #include "copyright.h"
21
22 #include <ctype.h>
23 #include <errno.h>
24 #include <math.h>
25 #include <stdlib.h>
26
27 #include "rtmisc.h"
28 #include "rtio.h"
29 #include "rterror.h"
30 #include "calcomp.h"
31
32 #define MAXLINE 256 /* maximum line length */
33
34 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
35
36 #define isdecimal(c) (isdigit(c) | ((c) == '.'))
37
38 #define envalue(ep) ((ep)->type==NUM ? (ep)->v.num : evalue(ep))
39
40 static double euminus(EPNODE *), enumber(EPNODE *);
41 static double echannel(EPNODE *);
42 static double eadd(EPNODE *), esubtr(EPNODE *),
43 emult(EPNODE *), edivi(EPNODE *),
44 epow(EPNODE *);
45 static double ebotch(EPNODE *);
46
47 unsigned int esupport = /* what to support */
48 E_VARIABLE | E_FUNCTION ;
49
50 int eofc = 0; /* optional end-of-file character */
51 int nextc; /* lookahead character */
52
53 double (*eoper[])(EPNODE *) = { /* expression operations */
54 ebotch,
55 evariable,
56 enumber,
57 euminus,
58 echannel,
59 efunc,
60 eargument,
61 ebotch,
62 ebotch,
63 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
64 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
65 emult,
66 eadd,
67 0,
68 esubtr,
69 0,
70 edivi,
71 0,0,0,0,0,0,0,0,0,0,
72 ebotch,
73 0,0,
74 ebotch,
75 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
76 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
77 epow,
78 };
79
80 static FILE *infp; /* input file pointer */
81 static char *linbuf; /* line buffer */
82 static char *infile; /* input file name */
83 static int lineno; /* input line number */
84 static int linepos; /* position in buffer */
85
86
87 EPNODE *
88 eparse( /* parse an expression string */
89 char *expr
90 )
91 {
92 EPNODE *ep;
93
94 initstr(expr, NULL, 0);
95 ecurfunc = NULL;
96 ep = getE1();
97 if (nextc != EOF)
98 esyntax("unexpected character");
99 return(ep);
100 }
101
102
103 double
104 eval( /* evaluate an expression string */
105 char *expr
106 )
107 {
108 int prev_support = esupport;
109 EPNODE *ep;
110 double rval;
111
112 esupport &= ~E_RCONST; /* don't bother reducing constant expr */
113 ep = eparse(expr);
114 esupport = prev_support; /* as you were */
115 rval = evalue(ep);
116 epfree(ep,1);
117 return(rval);
118 }
119
120
121 int
122 epcmp( /* compare two expressions for equivalence */
123 EPNODE *ep1,
124 EPNODE *ep2
125 )
126 {
127 double d;
128
129 if (ep1->type != ep2->type)
130 return(1);
131
132 switch (ep1->type) {
133
134 case VAR:
135 return(ep1->v.ln != ep2->v.ln);
136
137 case NUM:
138 if (ep2->v.num == 0)
139 return(ep1->v.num != 0);
140 d = ep1->v.num / ep2->v.num;
141 return((d > 1.000000000001) | (d < 0.999999999999));
142
143 case CHAN:
144 case ARG:
145 return(ep1->v.chan != ep2->v.chan);
146
147 case '=':
148 case ':':
149 return(epcmp(ep1->v.kid->sibling, ep2->v.kid->sibling));
150
151 case CLKT:
152 case SYM: /* should never get this one */
153 return(0);
154
155 default:
156 ep1 = ep1->v.kid;
157 ep2 = ep2->v.kid;
158 while (ep1 != NULL) {
159 if (ep2 == NULL)
160 return(1);
161 if (epcmp(ep1, ep2))
162 return(1);
163 ep1 = ep1->sibling;
164 ep2 = ep2->sibling;
165 }
166 return(ep2 != NULL);
167 }
168 }
169
170
171 void
172 epfree( /* free a parse tree */
173 EPNODE *epar,
174 int frep
175 )
176 {
177 EPNODE *ep;
178
179 switch (epar->type) {
180
181 case VAR:
182 varfree(epar->v.ln);
183 break;
184
185 case SYM:
186 freestr(epar->v.name);
187 break;
188
189 case NUM:
190 case CHAN:
191 case ARG:
192 case CLKT:
193 break;
194
195 default:
196 if (epar->nkids < 0) {
197 ep = epar->v.kid - epar->nkids;
198 while (ep > epar->v.kid)
199 epfree(--ep, 0);
200 efree(ep); /* free array space */
201 } else
202 while ((ep = epar->v.kid) != NULL) {
203 epar->v.kid = ep->sibling;
204 epfree(ep, 1);
205 }
206 break;
207
208 }
209 if (frep)
210 efree(epar);
211 else
212 memset(epar, 0, sizeof(EPNODE));
213 }
214
215
216 static void
217 epflatten( /* flatten hierarchies for '+', '*' */
218 EPNODE *epar
219 )
220 {
221 EPNODE *ep;
222
223 if (epar->nkids < 0) /* can't handle array allocations */
224 return;
225
226 for (ep = epar->v.kid; ep != NULL; ep = ep->sibling)
227 while (ep->type == epar->type && ep->nkids > 0) {
228 EPNODE *ep1 = ep->v.kid;
229 while (ep1->sibling != NULL)
230 ep1 = ep1->sibling;
231 ep1->sibling = ep->sibling;
232 epar->nkids += ep->nkids - 1;
233 ep1 = ep->v.kid;
234 *ep = *ep1;
235 efree(ep1); /* not epfree()! */
236 }
237 }
238
239
240 void
241 epoptimize( /* flatten operations, lists -> arrays */
242 EPNODE *epar
243 )
244 {
245 EPNODE *ep;
246
247 if ((epar->type == '+') | (epar->type == '*'))
248 epflatten(epar); /* flatten associative operations */
249
250 if (epar->nkids) /* do children if any */
251 for (ep = epar->v.kid; ep != NULL; ep = ep->sibling)
252 epoptimize(ep);
253
254 if (epar->nkids > 4) { /* make list into array if > 4 kids */
255 int n = 1;
256 epar->v.kid = (EPNODE *)erealloc(epar->v.kid,
257 sizeof(EPNODE)*epar->nkids);
258 while (n < epar->nkids) {
259 ep = epar->v.kid[n-1].sibling;
260 epar->v.kid[n] = *ep;
261 efree(ep); /* not epfree()! */
262 epar->v.kid[n-1].sibling = epar->v.kid + n;
263 n++;
264 }
265 epar->nkids = -n;
266 }
267 }
268
269 /* the following used to be a switch */
270 static double
271 enumber(
272 EPNODE *ep
273 )
274 {
275 return(ep->v.num);
276 }
277
278 static double
279 euminus(
280 EPNODE *ep
281 )
282 {
283 EPNODE *ep1 = ep->v.kid;
284
285 return(-evalue(ep1));
286 }
287
288 static double
289 echannel(
290 EPNODE *ep
291 )
292 {
293 return(chanvalue(ep->v.chan));
294 }
295
296 static double
297 eadd(
298 EPNODE *ep
299 )
300 {
301 double sum = 0;
302 EPNODE *ep1 = ep->v.kid;
303
304 do
305 sum += envalue(ep1);
306 while ((ep1 = ep1->sibling) != NULL);
307
308 return(sum);
309 }
310
311 static double
312 esubtr(
313 EPNODE *ep
314 )
315 {
316 EPNODE *ep1 = ep->v.kid;
317 EPNODE *ep2 = ep1->sibling;
318
319 return(envalue(ep1) - envalue(ep2));
320 }
321
322 static double
323 emult(
324 EPNODE *ep
325 )
326 {
327 double prod = 1;
328 EPNODE *ep1 = ep->v.kid;
329
330 do
331 prod *= envalue(ep1);
332 while ((ep1 = ep1->sibling) != NULL);
333
334 return(prod);
335 }
336
337 static double
338 edivi(
339 EPNODE *ep
340 )
341 {
342 EPNODE *ep1 = ep->v.kid;
343 double den = evalue(ep1->sibling);
344
345 if (den == 0.0) {
346 wputs("Division by zero\n");
347 errno = ERANGE;
348 return(0.0);
349 }
350 return(envalue(ep1) / den);
351 }
352
353 static double
354 epow(
355 EPNODE *ep
356 )
357 {
358 EPNODE *ep1 = ep->v.kid;
359 double d;
360 int lasterrno;
361
362 lasterrno = errno;
363 errno = 0;
364 d = pow(evalue(ep1), evalue(ep1->sibling));
365 #ifdef isnan
366 if (errno == 0) {
367 if (isnan(d))
368 errno = EDOM;
369 else if (isinf(d))
370 errno = ERANGE;
371 }
372 #endif
373 if ((errno == EDOM) | (errno == ERANGE)) {
374 wputs("Illegal power\n");
375 return(0.0);
376 }
377 errno = lasterrno;
378 return(d);
379 }
380
381 static double
382 ebotch(
383 EPNODE *ep
384 )
385 {
386 eputs("Bad expression!\n");
387 quit(1);
388 return 0.0; /* pro forma return */
389 }
390
391
392 EPNODE *
393 ekid( /* return pointer to a node's nth kid */
394 EPNODE *ep,
395 int n
396 )
397 {
398 if (ep->nkids < 0) { /* allocated array? */
399 if (n >= -ep->nkids)
400 return(NULL);
401 return(ep->v.kid + n);
402 }
403 ep = ep->v.kid; /* else get from list */
404 while (n-- > 0)
405 if ((ep = ep->sibling) == NULL)
406 break;
407 return(ep);
408 }
409
410
411 void
412 initfile( /* prepare input file */
413 FILE *fp,
414 char *fn,
415 int ln
416 )
417 {
418 static char inpbuf[MAXLINE];
419
420 infp = fp;
421 linbuf = inpbuf;
422 infile = fn;
423 lineno = ln;
424 linepos = 0;
425 inpbuf[0] = '\0';
426 escan();
427 }
428
429
430 void
431 initstr( /* prepare input string */
432 char *s,
433 char *fn,
434 int ln
435 )
436 {
437 infp = NULL;
438 infile = fn;
439 lineno = ln;
440 linbuf = s;
441 linepos = 0;
442 escan();
443 }
444
445
446 void
447 getscanpos( /* return current scan position */
448 char **fnp,
449 int *lnp,
450 char **spp,
451 FILE **fpp
452 )
453 {
454 if (fnp != NULL) *fnp = infile;
455 if (lnp != NULL) *lnp = lineno;
456 if (spp != NULL) *spp = linbuf+linepos;
457 if (fpp != NULL) *fpp = infp;
458 }
459
460
461 int
462 escan(void) /* scan next character, return literal next */
463 {
464 int lnext = 0;
465
466 do {
467 if (linbuf[linepos] == '\0')
468 if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL)
469 nextc = EOF;
470 else {
471 nextc = linbuf[0];
472 lineno++;
473 linepos = 1;
474 }
475 else
476 nextc = linbuf[linepos++];
477 if (!lnext)
478 lnext = nextc;
479 if (nextc == eofc) {
480 nextc = EOF;
481 break;
482 }
483 if (nextc == '{') {
484 escan();
485 while (nextc != '}')
486 if (nextc == EOF)
487 esyntax("'}' expected");
488 else
489 escan();
490 escan();
491 }
492 } while (isspace(nextc));
493 return(lnext);
494 }
495
496
497 char *
498 long2ascii( /* convert long to ascii */
499 long l
500 )
501 {
502 static char buf[16];
503 char *cp;
504 int neg = 0;
505
506 if (l == 0)
507 return("0");
508 if (l < 0) {
509 l = -l;
510 neg++;
511 }
512 cp = buf + sizeof(buf);
513 *--cp = '\0';
514 while (l) {
515 *--cp = l % 10 + '0';
516 l /= 10;
517 }
518 if (neg)
519 *--cp = '-';
520 return(cp);
521 }
522
523
524 void
525 esyntax( /* report syntax error and quit */
526 char *err
527 )
528 {
529 int i;
530
531 if ((infile != NULL) | (lineno != 0)) {
532 if (infile != NULL) eputs(infile);
533 if (lineno != 0) {
534 eputs(infile != NULL ? ", line " : "line ");
535 eputs(long2ascii((long)lineno));
536 }
537 eputs(":\n");
538 }
539 eputs(linbuf);
540 if (linbuf[strlen(linbuf)-1] != '\n')
541 eputs("\n");
542 for (i = 0; i < linepos-1; i++)
543 eputs(linbuf[i] == '\t' ? "\t" : " ");
544 eputs("^ ");
545 eputs(err);
546 eputs("\n");
547 quit(1);
548 }
549
550
551 void
552 addekid( /* add a child to ep */
553 EPNODE *ep,
554 EPNODE *ek
555 )
556 {
557 if (ep->nkids < 0) {
558 eputs("Cannot add kid to EPNODE array\n");
559 quit(1);
560 }
561 ep->nkids++;
562 if (ep->v.kid == NULL)
563 ep->v.kid = ek;
564 else {
565 for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling)
566 ;
567 ep->sibling = ek;
568 }
569 ek->sibling = NULL; /* shouldn't be necessary */
570 }
571
572
573 char *
574 getname(void) /* scan an identifier */
575 {
576 static char str[RMAXWORD+1];
577 int i, lnext;
578
579 lnext = nextc;
580 for (i = 0; i < RMAXWORD && isid(lnext); i++, lnext = escan())
581 str[i] = lnext;
582 str[i] = '\0';
583 while (isid(lnext)) /* skip rest of name */
584 lnext = escan();
585
586 return(str);
587 }
588
589
590 int
591 getinum(void) /* scan a positive integer */
592 {
593 int n, lnext;
594
595 n = 0;
596 lnext = nextc;
597 while (isdigit(lnext)) {
598 n = n * 10 + lnext - '0';
599 lnext = escan();
600 }
601 return(n);
602 }
603
604
605 double
606 getnum(void) /* scan a positive float */
607 {
608 int i, lnext;
609 char str[RMAXWORD+1];
610
611 i = 0;
612 lnext = nextc;
613 while (isdigit(lnext) && i < RMAXWORD) {
614 str[i++] = lnext;
615 lnext = escan();
616 }
617 if ((lnext == '.') & (i < RMAXWORD)) {
618 str[i++] = lnext;
619 lnext = escan();
620 if (i == 1 && !isdigit(lnext))
621 esyntax("badly formed number");
622 while (isdigit(lnext) && i < RMAXWORD) {
623 str[i++] = lnext;
624 lnext = escan();
625 }
626 }
627 if ((lnext == 'e') | (lnext == 'E') && i < RMAXWORD) {
628 str[i++] = lnext;
629 lnext = escan();
630 if ((lnext == '-') | (lnext == '+') && i < RMAXWORD) {
631 str[i++] = lnext;
632 lnext = escan();
633 }
634 if (!isdigit(lnext))
635 esyntax("missing exponent");
636 while (isdigit(lnext) && i < RMAXWORD) {
637 str[i++] = lnext;
638 lnext = escan();
639 }
640 }
641 str[i] = '\0';
642
643 return(atof(str));
644 }
645
646
647 EPNODE *
648 getE1(void) /* E1 -> E1 ADDOP E2 */
649 /* E2 */
650 {
651 EPNODE *ep1, *ep2;
652
653 ep1 = getE2();
654 while ((nextc == '+') | (nextc == '-')) {
655 ep2 = newnode();
656 ep2->type = nextc;
657 escan();
658 addekid(ep2, ep1);
659 addekid(ep2, getE2());
660 if (esupport&E_RCONST &&
661 (ep1->type == NUM) & (ep1->sibling->type == NUM))
662 ep2 = rconst(ep2);
663 ep1 = ep2;
664 }
665 return(ep1);
666 }
667
668
669 EPNODE *
670 getE2(void) /* E2 -> E2 MULOP E3 */
671 /* E3 */
672 {
673 EPNODE *ep1, *ep2;
674
675 ep1 = getE3();
676 while ((nextc == '*') | (nextc == '/')) {
677 ep2 = newnode();
678 ep2->type = nextc;
679 escan();
680 addekid(ep2, ep1);
681 addekid(ep2, getE3());
682 if (esupport&E_RCONST) {
683 EPNODE *ep3 = ep1->sibling;
684 if ((ep1->type == NUM) & (ep3->type == NUM)) {
685 ep2 = rconst(ep2);
686 } else if (ep3->type == NUM) {
687 if (ep2->type == '/') {
688 if (ep3->v.num == 0)
689 esyntax("divide by zero constant");
690 ep2->type = '*'; /* for speed */
691 ep3->v.num = 1./ep3->v.num;
692 } else if (ep3->v.num == 0) {
693 ep1->sibling = NULL; /* (E2 * 0) */
694 epfree(ep2,1);
695 ep2 = ep3;
696 }
697 } else if (ep1->type == NUM && ep1->v.num == 0) {
698 epfree(ep3,1); /* (0 * E3) or (0 / E3) */
699 ep1->sibling = NULL;
700 efree(ep2);
701 ep2 = ep1;
702 }
703 }
704 ep1 = ep2;
705 }
706 return(ep1);
707 }
708
709
710 EPNODE *
711 getE3(void) /* E3 -> E4 ^ E3 */
712 /* E4 */
713 {
714 EPNODE *ep1, *ep2;
715
716 ep1 = getE4();
717 if (nextc != '^')
718 return(ep1);
719 ep2 = newnode();
720 ep2->type = nextc;
721 escan();
722 addekid(ep2, ep1);
723 addekid(ep2, getE3());
724 if (esupport&E_RCONST) {
725 EPNODE *ep3 = ep1->sibling;
726 if ((ep1->type == NUM) & (ep3->type == NUM)) {
727 ep2 = rconst(ep2);
728 } else if (ep1->type == NUM && ep1->v.num == 0) {
729 epfree(ep3,1); /* (0 ^ E3) */
730 ep1->sibling = NULL;
731 efree(ep2);
732 ep2 = ep1;
733 } else if ((ep3->type == NUM && ep3->v.num == 0) |
734 (ep1->type == NUM && ep1->v.num == 1)) {
735 epfree(ep2,0); /* (E4 ^ 0) or (1 ^ E3) */
736 ep2->type = NUM;
737 ep2->v.num = 1;
738 } else if (ep3->type == NUM && ep3->v.num == 1) {
739 efree(ep3); /* (E4 ^ 1) */
740 ep1->sibling = NULL;
741 efree(ep2);
742 ep2 = ep1;
743 }
744 }
745 return(ep2);
746 }
747
748
749 EPNODE *
750 getE4(void) /* E4 -> ADDOP E5 */
751 /* E5 */
752 {
753 EPNODE *ep1, *ep2;
754
755 if (nextc == '-') {
756 escan();
757 ep2 = getE5();
758 if (ep2->type == NUM) {
759 ep2->v.num = -ep2->v.num;
760 return(ep2);
761 }
762 if (ep2->type == UMINUS) { /* don't generate -(-E5) */
763 ep1 = ep2->v.kid;
764 efree(ep2);
765 return(ep1);
766 }
767 ep1 = newnode();
768 ep1->type = UMINUS;
769 addekid(ep1, ep2);
770 return(ep1);
771 }
772 if (nextc == '+')
773 escan();
774 return(getE5());
775 }
776
777
778 EPNODE *
779 getE5(void) /* E5 -> (E1) */
780 /* VAR */
781 /* NUM */
782 /* $N */
783 /* FUNC(E1,..) */
784 /* ARG */
785 {
786 int i;
787 char *nam;
788 EPNODE *ep1, *ep2;
789
790 if (nextc == '(') {
791 escan();
792 ep1 = getE1();
793 if (nextc != ')')
794 esyntax("')' expected");
795 escan();
796 return(ep1);
797 }
798 if (esupport&E_INCHAN && nextc == '$') {
799 escan();
800 ep1 = newnode();
801 ep1->type = CHAN;
802 ep1->v.chan = getinum();
803 return(ep1);
804 }
805 if (esupport&(E_VARIABLE|E_FUNCTION) &&
806 (isalpha(nextc) | (nextc == CNTXMARK))) {
807 nam = getname();
808 ep1 = NULL;
809 if ((esupport&(E_VARIABLE|E_FUNCTION)) == (E_VARIABLE|E_FUNCTION)
810 && ecurfunc != NULL)
811 for (i = 1, ep2 = ecurfunc->v.kid->sibling;
812 ep2 != NULL; i++, ep2 = ep2->sibling)
813 if (!strcmp(ep2->v.name, nam)) {
814 ep1 = newnode();
815 ep1->type = ARG;
816 ep1->v.chan = i;
817 break;
818 }
819 if (ep1 == NULL) {
820 ep1 = newnode();
821 ep1->type = VAR;
822 ep1->v.ln = varinsert(nam);
823 }
824 if (esupport&E_FUNCTION && nextc == '(') {
825 ep2 = newnode();
826 ep2->type = FUNC;
827 addekid(ep2, ep1);
828 ep1 = ep2;
829 do {
830 escan();
831 addekid(ep1, getE1());
832 } while (nextc == ',');
833 if (nextc != ')')
834 esyntax("')' expected");
835 escan();
836 } else if (!(esupport&E_VARIABLE))
837 esyntax("'(' expected");
838 if (esupport&E_RCONST && isconstvar(ep1))
839 ep1 = rconst(ep1);
840 return(ep1);
841 }
842 if (isdecimal(nextc)) {
843 ep1 = newnode();
844 ep1->type = NUM;
845 ep1->v.num = getnum();
846 return(ep1);
847 }
848 esyntax("unexpected character");
849 return NULL; /* pro forma return */
850 }
851
852
853 EPNODE *
854 rconst( /* reduce a constant expression */
855 EPNODE *epar
856 )
857 {
858 EPNODE *ep;
859
860 ep = newnode();
861 ep->type = NUM;
862 errno = 0;
863 ep->v.num = evalue(epar);
864 if ((errno == EDOM) | (errno == ERANGE))
865 esyntax("bad constant expression");
866 epfree(epar,1);
867
868 return(ep);
869 }
870
871
872 int
873 isconstvar( /* is ep linked to a constant expression? */
874 EPNODE *ep
875 )
876 {
877 EPNODE *ep1;
878
879 if (esupport&E_FUNCTION && ep->type == FUNC) {
880 if (!isconstfun(ep->v.kid))
881 return(0);
882 for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling)
883 if (ep1->type != NUM && !isconstfun(ep1))
884 return(0);
885 return(1);
886 }
887 if (ep->type != VAR)
888 return(0);
889 ep1 = ep->v.ln->def;
890 if (ep1 == NULL || ep1->type != ':')
891 return(0);
892 if (esupport&E_FUNCTION && ep1->v.kid->type != SYM)
893 return(0);
894 return(1);
895 }
896
897
898 int
899 isconstfun( /* is ep linked to a constant function? */
900 EPNODE *ep
901 )
902 {
903 EPNODE *dp;
904 ELIBR *lp;
905
906 if (ep->type != VAR)
907 return(0);
908 if ((dp = ep->v.ln->def) != NULL) {
909 if (dp->v.kid->type == FUNC)
910 return(dp->type == ':');
911 else
912 return(0); /* don't identify masked library functions */
913 }
914 if ((lp = ep->v.ln->lib) != NULL)
915 return(lp->atyp == ':');
916 return(0);
917 }
