--- ray/src/common/calexpr.c 2003/07/03 22:41:44 2.23 +++ ray/src/common/calexpr.c 2019/03/04 18:16:18 2.37 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: calexpr.c,v 2.23 2003/07/03 22:41:44 schorsch Exp $"; +static const char RCSid[] = "$Id: calexpr.c,v 2.37 2019/03/04 18:16:18 greg Exp $"; #endif /* * Compute data values using expression parser @@ -26,6 +26,9 @@ static const char RCSid[] = "$Id: calexpr.c,v 2.23 200 #include #include +#include "rtmisc.h" +#include "rtio.h" +#include "rterror.h" #include "calcomp.h" #define MAXLINE 256 /* maximum line length */ @@ -34,17 +37,20 @@ static const char RCSid[] = "$Id: calexpr.c,v 2.23 200 #define isdecimal(c) (isdigit(c) || (c) == '.') -static double euminus(), eargument(), enumber(); -static double echannel(); -static double eadd(), esubtr(), emult(), edivi(), epow(); -static double ebotch(); +static double euminus(EPNODE *), eargument(EPNODE *), enumber(EPNODE *); +static double echannel(EPNODE *); +static double eadd(EPNODE *), esubtr(EPNODE *), + emult(EPNODE *), edivi(EPNODE *), + epow(EPNODE *); +static double ebotch(EPNODE *); unsigned int esupport = /* what to support */ E_VARIABLE | E_FUNCTION ; +int eofc = 0; /* optional end-of-file character */ int nextc; /* lookahead character */ -double (*eoper[])() = { /* expression operations */ +double (*eoper[])(EPNODE *) = { /* expression operations */ ebotch, evariable, enumber, @@ -79,8 +85,9 @@ static int linepos; /* position in buffer */ EPNODE * -eparse(expr) /* parse an expression string */ -char *expr; +eparse( /* parse an expression string */ + char *expr +) { EPNODE *ep; @@ -94,10 +101,11 @@ char *expr; double -eval(expr) /* evaluate an expression string */ -char *expr; +eval( /* evaluate an expression string */ + char *expr +) { - register EPNODE *ep; + EPNODE *ep; double rval; ep = eparse(expr); @@ -108,8 +116,10 @@ char *expr; int -epcmp(ep1, ep2) /* compare two expressions for equivalence */ -register EPNODE *ep1, *ep2; +epcmp( /* compare two expressions for equivalence */ + EPNODE *ep1, + EPNODE *ep2 +) { double d; @@ -125,7 +135,7 @@ register EPNODE *ep1, *ep2; if (ep2->v.num == 0) return(ep1->v.num != 0); d = ep1->v.num / ep2->v.num; - return(d > 1.000000000001 | d < 0.999999999999); + return((d > 1.000000000001) | (d < 0.999999999999)); case CHAN: case ARG: @@ -135,7 +145,7 @@ register EPNODE *ep1, *ep2; case ':': return(epcmp(ep1->v.kid->sibling, ep2->v.kid->sibling)); - case TICK: + case CLKT: case SYM: /* should never get this one */ return(0); @@ -156,10 +166,11 @@ register EPNODE *ep1, *ep2; void -epfree(epar) /* free a parse tree */ -register EPNODE *epar; +epfree( /* free a parse tree */ + EPNODE *epar +) { - register EPNODE *ep; + EPNODE *ep; switch (epar->type) { @@ -174,7 +185,7 @@ register EPNODE *epar; case NUM: case CHAN: case ARG: - case TICK: + case CLKT: break; default: @@ -191,67 +202,75 @@ register EPNODE *epar; /* the following used to be a switch */ static double -eargument(ep) -EPNODE *ep; +eargument( + EPNODE *ep +) { return(argument(ep->v.chan)); } static double -enumber(ep) -EPNODE *ep; +enumber( + EPNODE *ep +) { return(ep->v.num); } static double -euminus(ep) -EPNODE *ep; +euminus( + EPNODE *ep +) { - register EPNODE *ep1 = ep->v.kid; + EPNODE *ep1 = ep->v.kid; return(-evalue(ep1)); } static double -echannel(ep) -EPNODE *ep; +echannel( + EPNODE *ep +) { return(chanvalue(ep->v.chan)); } static double -eadd(ep) -EPNODE *ep; +eadd( + EPNODE *ep +) { - register EPNODE *ep1 = ep->v.kid; + EPNODE *ep1 = ep->v.kid; return(evalue(ep1) + evalue(ep1->sibling)); } static double -esubtr(ep) -EPNODE *ep; +esubtr( + EPNODE *ep +) { - register EPNODE *ep1 = ep->v.kid; + EPNODE *ep1 = ep->v.kid; return(evalue(ep1) - evalue(ep1->sibling)); } static double -emult(ep) -EPNODE *ep; +emult( + EPNODE *ep +) { - register EPNODE *ep1 = ep->v.kid; + EPNODE *ep1 = ep->v.kid; return(evalue(ep1) * evalue(ep1->sibling)); } static double -edivi(ep) -EPNODE *ep; +edivi( + EPNODE *ep +) { - register EPNODE *ep1 = ep->v.kid; + EPNODE *ep1 = ep->v.kid; double d; d = evalue(ep1->sibling); @@ -264,19 +283,24 @@ EPNODE *ep; } static double -epow(ep) -EPNODE *ep; +epow( + EPNODE *ep +) { - register EPNODE *ep1 = ep->v.kid; + EPNODE *ep1 = ep->v.kid; double d; int lasterrno; lasterrno = errno; errno = 0; d = pow(evalue(ep1), evalue(ep1->sibling)); -#ifdef IEEE - if (!finite(d)) - errno = EDOM; +#ifdef isnan + if (errno == 0) { + if (isnan(d)) + errno = EDOM; + else if (isinf(d)) + errno = ERANGE; + } #endif if (errno == EDOM || errno == ERANGE) { wputs("Illegal power\n"); @@ -287,8 +311,9 @@ EPNODE *ep; } static double -ebotch(ep) -EPNODE *ep; +ebotch( + EPNODE *ep +) { eputs("Bad expression!\n"); quit(1); @@ -297,9 +322,10 @@ EPNODE *ep; EPNODE * -ekid(ep, n) /* return pointer to a node's nth kid */ -register EPNODE *ep; -register int n; +ekid( /* return pointer to a node's nth kid */ + EPNODE *ep, + int n +) { for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) @@ -311,10 +337,11 @@ register int n; int -nekids(ep) /* return # of kids for node ep */ -register EPNODE *ep; +nekids( /* return # of kids for node ep */ + EPNODE *ep +) { - register int n = 0; + int n = 0; for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) n++; @@ -324,10 +351,11 @@ register EPNODE *ep; void -initfile(fp, fn, ln) /* prepare input file */ -FILE *fp; -char *fn; -int ln; +initfile( /* prepare input file */ + FILE *fp, + char *fn, + int ln +) { static char inpbuf[MAXLINE]; @@ -342,10 +370,11 @@ int ln; void -initstr(s, fn, ln) /* prepare input string */ -char *s; -char *fn; -int ln; +initstr( /* prepare input string */ + char *s, + char *fn, + int ln +) { infp = NULL; infile = fn; @@ -357,11 +386,12 @@ int ln; void -getscanpos(fnp, lnp, spp, fpp) /* return current scan position */ -char **fnp; -int *lnp; -char **spp; -FILE **fpp; +getscanpos( /* return current scan position */ + char **fnp, + int *lnp, + char **spp, + FILE **fpp +) { if (fnp != NULL) *fnp = infile; if (lnp != NULL) *lnp = lineno; @@ -371,9 +401,9 @@ FILE **fpp; int -scan() /* scan next character, return literal next */ +scan(void) /* scan next character, return literal next */ { - register int lnext = 0; + int lnext = 0; do { if (linbuf[linepos] == '\0') @@ -388,6 +418,10 @@ scan() /* scan next character, return literal next nextc = linbuf[linepos++]; if (!lnext) lnext = nextc; + if (nextc == eofc) { + nextc = EOF; + break; + } if (nextc == '{') { scan(); while (nextc != '}') @@ -403,11 +437,12 @@ scan() /* scan next character, return literal next char * -long2ascii(l) /* convert long to ascii */ -long l; +long2ascii( /* convert long to ascii */ + long l +) { static char buf[16]; - register char *cp; + char *cp; int neg = 0; if (l == 0) @@ -429,10 +464,11 @@ long l; void -syntax(err) /* report syntax error and quit */ -char *err; +syntax( /* report syntax error and quit */ + char *err +) { - register int i; + int i; if (infile != NULL || lineno != 0) { if (infile != NULL) eputs(infile); @@ -455,9 +491,10 @@ char *err; void -addekid(ep, ekid) /* add a child to ep */ -register EPNODE *ep; -EPNODE *ekid; +addekid( /* add a child to ep */ + EPNODE *ep, + EPNODE *ekid +) { if (ep->v.kid == NULL) ep->v.kid = ekid; @@ -471,10 +508,10 @@ EPNODE *ekid; char * -getname() /* scan an identifier */ +getname(void) /* scan an identifier */ { static char str[RMAXWORD+1]; - register int i, lnext; + int i, lnext; lnext = nextc; for (i = 0; i < RMAXWORD && isid(lnext); i++, lnext = scan()) @@ -488,9 +525,9 @@ getname() /* scan an identifier */ int -getinum() /* scan a positive integer */ +getinum(void) /* scan a positive integer */ { - register int n, lnext; + int n, lnext; n = 0; lnext = nextc; @@ -503,9 +540,9 @@ getinum() /* scan a positive integer */ double -getnum() /* scan a positive float */ +getnum(void) /* scan a positive float */ { - register int i, lnext; + int i, lnext; char str[RMAXWORD+1]; i = 0; @@ -524,10 +561,10 @@ getnum() /* scan a positive float */ lnext = scan(); } } - if ((lnext == 'e' | lnext == 'E') && i < RMAXWORD) { + if ((lnext == 'e') | (lnext == 'E') && i < RMAXWORD) { str[i++] = lnext; lnext = scan(); - if ((lnext == '-' | lnext == '+') && i < RMAXWORD) { + if ((lnext == '-') | (lnext == '+') && i < RMAXWORD) { str[i++] = lnext; lnext = scan(); } @@ -545,10 +582,10 @@ getnum() /* scan a positive float */ EPNODE * -getE1() /* E1 -> E1 ADDOP E2 */ +getE1(void) /* E1 -> E1 ADDOP E2 */ /* E2 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; ep1 = getE2(); while (nextc == '+' || nextc == '-') { @@ -567,10 +604,10 @@ getE1() /* E1 -> E1 ADDOP E2 */ EPNODE * -getE2() /* E2 -> E2 MULOP E3 */ +getE2(void) /* E2 -> E2 MULOP E3 */ /* E3 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; ep1 = getE3(); while (nextc == '*' || nextc == '/') { @@ -579,9 +616,28 @@ getE2() /* E2 -> E2 MULOP E3 */ scan(); addekid(ep2, ep1); addekid(ep2, getE3()); - if (esupport&E_RCONST && - ep1->type == NUM && ep1->sibling->type == NUM) - ep2 = rconst(ep2); + if (esupport&E_RCONST) { + EPNODE *ep3 = ep1->sibling; + if (ep1->type == NUM && ep3->type == NUM) { + ep2 = rconst(ep2); + } else if (ep3->type == NUM) { + if (ep2->type == '/') { + if (ep3->v.num == 0) + syntax("divide by zero constant"); + ep2->type = '*'; /* for speed */ + ep3->v.num = 1./ep3->v.num; + } else if (ep3->v.num == 0) { + ep1->sibling = NULL; /* (E2 * 0) */ + epfree(ep2); + ep2 = ep3; + } + } else if (ep1->type == NUM && ep1->v.num == 0) { + epfree(ep3); /* (0 * E3) or (0 / E3) */ + ep1->sibling = NULL; + efree((char *)ep2); + ep2 = ep1; + } + } ep1 = ep2; } return(ep1); @@ -589,32 +645,45 @@ getE2() /* E2 -> E2 MULOP E3 */ EPNODE * -getE3() /* E3 -> E4 ^ E3 */ +getE3(void) /* E3 -> E4 ^ E3 */ /* E4 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; - ep1 = getE4(); - if (nextc == '^') { + ep1 = getE4(); + if (nextc != '^') + return(ep1); ep2 = newnode(); ep2->type = nextc; scan(); addekid(ep2, ep1); addekid(ep2, getE3()); - if (esupport&E_RCONST && - ep1->type == NUM && ep1->sibling->type == NUM) - ep2 = rconst(ep2); + if (esupport&E_RCONST) { + EPNODE *ep3 = ep1->sibling; + if (ep1->type == NUM && ep3->type == NUM) { + ep2 = rconst(ep2); + } else if (ep1->type == NUM && ep1->v.num == 0) { + epfree(ep3); /* (0 ^ E3) */ + ep1->sibling = NULL; + efree((char *)ep2); + ep2 = ep1; + } else if ((ep3->type == NUM && ep3->v.num == 0) || + (ep1->type == NUM && ep1->v.num == 1)) { + epfree(ep2); /* (E4 ^ 0) or (1 ^ E3) */ + ep2 = newnode(); + ep2->type = NUM; + ep2->v.num = 1; + } + } return(ep2); - } - return(ep1); } EPNODE * -getE4() /* E4 -> ADDOP E5 */ +getE4(void) /* E4 -> ADDOP E5 */ /* E5 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; if (nextc == '-') { scan(); @@ -624,8 +693,9 @@ getE4() /* E4 -> ADDOP E5 */ return(ep2); } if (ep2->type == UMINUS) { /* don't generate -(-E5) */ + ep1 = ep2->v.kid; efree((char *)ep2); - return(ep2->v.kid); + return(ep1); } ep1 = newnode(); ep1->type = UMINUS; @@ -639,7 +709,7 @@ getE4() /* E4 -> ADDOP E5 */ EPNODE * -getE5() /* E5 -> (E1) */ +getE5(void) /* E5 -> (E1) */ /* VAR */ /* NUM */ /* $N */ @@ -648,7 +718,7 @@ getE5() /* E5 -> (E1) */ { int i; char *nam; - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; if (nextc == '(') { scan(); @@ -717,10 +787,11 @@ getE5() /* E5 -> (E1) */ EPNODE * -rconst(epar) /* reduce a constant expression */ -register EPNODE *epar; +rconst( /* reduce a constant expression */ + EPNODE *epar +) { - register EPNODE *ep; + EPNODE *ep; ep = newnode(); ep->type = NUM; @@ -735,10 +806,11 @@ register EPNODE *epar; int -isconstvar(ep) /* is ep linked to a constant expression? */ -register EPNODE *ep; +isconstvar( /* is ep linked to a constant expression? */ + EPNODE *ep +) { - register EPNODE *ep1; + EPNODE *ep1; if (esupport&E_FUNCTION && ep->type == FUNC) { if (!isconstfun(ep->v.kid)) @@ -760,19 +832,21 @@ register EPNODE *ep; int -isconstfun(ep) /* is ep linked to a constant function? */ -register EPNODE *ep; +isconstfun( /* is ep linked to a constant function? */ + EPNODE *ep +) { - register EPNODE *dp; - register LIBR *lp; + EPNODE *dp; + LIBR *lp; if (ep->type != VAR) return(0); - if ((dp = ep->v.ln->def) != NULL) + if ((dp = ep->v.ln->def) != NULL) { if (dp->v.kid->type == FUNC) return(dp->type == ':'); else return(0); /* don't identify masked library functions */ + } if ((lp = ep->v.ln->lib) != NULL) return(lp->atyp == ':'); return(0);
