1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Compute data values using expression parser |
9 |
10 |
* 7/1/85 Greg Ward |
11 |
12 |
* 11/11/85 Made channel input conditional with (INCHAN) compiles. |
13 |
14 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION). |
15 |
16 |
* 1/29/87 Made variables conditional (VARIABLE) |
17 |
18 |
* 5/19/88 Added constant subexpression elimination (RCONST) |
19 |
20 |
21 |
#include <stdio.h> |
22 |
23 |
#include <ctype.h> |
24 |
25 |
#include <errno.h> |
26 |
27 |
#include <math.h> |
28 |
29 |
#include "calcomp.h" |
30 |
31 |
#define MAXLINE 256 /* maximum line length */ |
32 |
33 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) |
34 |
35 |
#define isdecimal(c) (isdigit(c) || (c) == '.') |
36 |
37 |
extern char *fgets(), *savestr(); |
38 |
extern char *emalloc(), *ecalloc(); |
39 |
extern EPNODE *curfunc; |
40 |
extern double efunc(), evariable(); |
41 |
static double euminus(), eargument(), enumber(); |
42 |
#ifdef INCHAN |
43 |
static double echannel(); |
44 |
#endif |
45 |
static double eadd(), esubtr(), emult(), edivi(), epow(); |
46 |
static double ebotch(); |
47 |
48 |
int nextc; /* lookahead character */ |
49 |
50 |
double (*eoper[])() = { /* expression operations */ |
51 |
ebotch, |
52 |
#ifdef VARIABLE |
53 |
evariable, |
54 |
#else |
55 |
ebotch, |
56 |
#endif |
57 |
enumber, |
58 |
euminus, |
59 |
#ifdef INCHAN |
60 |
echannel, |
61 |
#else |
62 |
ebotch, |
63 |
#endif |
64 |
#ifdef FUNCTION |
65 |
efunc, |
66 |
eargument, |
67 |
#else |
68 |
ebotch, |
69 |
ebotch, |
70 |
#endif |
71 |
ebotch, |
72 |
ebotch, |
73 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
74 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
75 |
emult, |
76 |
eadd, |
77 |
0, |
78 |
esubtr, |
79 |
0, |
80 |
edivi, |
81 |
82 |
ebotch, |
83 |
0,0, |
84 |
ebotch, |
85 |
86 |
87 |
epow, |
88 |
89 |
90 |
static FILE *infp; /* input file pointer */ |
91 |
static char *linbuf; /* line buffer */ |
92 |
static char *infile; /* input file name */ |
93 |
static int lineno; /* input line number */ |
94 |
static int linepos; /* position in buffer */ |
95 |
96 |
97 |
EPNODE * |
98 |
eparse(expr) /* parse an expression string */ |
99 |
char *expr; |
100 |
101 |
EPNODE *ep; |
102 |
103 |
initstr(expr, NULL, 0); |
104 |
#if defined(VARIABLE) && defined(FUNCTION) |
105 |
curfunc = NULL; |
106 |
#endif |
107 |
ep = getE1(); |
108 |
if (nextc != EOF) |
109 |
syntax("unexpected character"); |
110 |
return(ep); |
111 |
112 |
113 |
114 |
double |
115 |
eval(expr) /* evaluate an expression string */ |
116 |
char *expr; |
117 |
118 |
register EPNODE *ep; |
119 |
double rval; |
120 |
121 |
ep = eparse(expr); |
122 |
rval = evalue(ep); |
123 |
epfree(ep); |
124 |
return(rval); |
125 |
126 |
127 |
128 |
epfree(epar) /* free a parse tree */ |
129 |
register EPNODE *epar; |
130 |
131 |
132 |
133 |
switch (epar->type) { |
134 |
135 |
#if defined(VARIABLE) || defined(FUNCTION) |
136 |
case VAR: |
137 |
varfree(epar->v.ln); |
138 |
break; |
139 |
140 |
case SYM: |
141 |
freestr(epar->v.name); |
142 |
break; |
143 |
#endif |
144 |
145 |
case NUM: |
146 |
case CHAN: |
147 |
case ARG: |
148 |
case TICK: |
149 |
break; |
150 |
151 |
default: |
152 |
while ((ep = epar->v.kid) != NULL) { |
153 |
epar->v.kid = ep->sibling; |
154 |
epfree(ep); |
155 |
156 |
break; |
157 |
158 |
159 |
160 |
efree((char *)epar); |
161 |
162 |
163 |
/* the following used to be a switch */ |
164 |
#ifdef FUNCTION |
165 |
static double |
166 |
eargument(ep) |
167 |
EPNODE *ep; |
168 |
169 |
return(argument(ep->v.chan)); |
170 |
171 |
#endif |
172 |
173 |
static double |
174 |
enumber(ep) |
175 |
EPNODE *ep; |
176 |
177 |
return(ep->v.num); |
178 |
179 |
180 |
static double |
181 |
euminus(ep) |
182 |
EPNODE *ep; |
183 |
184 |
register EPNODE *ep1 = ep->v.kid; |
185 |
186 |
return(-evalue(ep1)); |
187 |
188 |
189 |
#ifdef INCHAN |
190 |
static double |
191 |
echannel(ep) |
192 |
EPNODE *ep; |
193 |
194 |
return(chanvalue(ep->v.chan)); |
195 |
196 |
#endif |
197 |
198 |
static double |
199 |
eadd(ep) |
200 |
EPNODE *ep; |
201 |
202 |
203 |
204 |
return(evalue(ep1) + evalue(ep1->sibling)); |
205 |
206 |
207 |
static double |
208 |
esubtr(ep) |
209 |
EPNODE *ep; |
210 |
211 |
212 |
213 |
return(evalue(ep1) - evalue(ep1->sibling)); |
214 |
215 |
216 |
static double |
217 |
emult(ep) |
218 |
EPNODE *ep; |
219 |
220 |
221 |
222 |
return(evalue(ep1) * evalue(ep1->sibling)); |
223 |
224 |
225 |
static double |
226 |
edivi(ep) |
227 |
EPNODE *ep; |
228 |
229 |
230 |
double d; |
231 |
232 |
d = evalue(ep1->sibling); |
233 |
if (d == 0.0) { |
234 |
wputs("Division by zero\n"); |
235 |
errno = ERANGE; |
236 |
return(0.0); |
237 |
238 |
return(evalue(ep1) / d); |
239 |
240 |
241 |
static double |
242 |
epow(ep) |
243 |
EPNODE *ep; |
244 |
245 |
246 |
double d; |
247 |
int lasterrno; |
248 |
249 |
lasterrno = errno; |
250 |
errno = 0; |
251 |
d = pow(evalue(ep1), evalue(ep1->sibling)); |
252 |
#ifdef IEEE |
253 |
if (!finite(d)) |
254 |
errno = EDOM; |
255 |
#endif |
256 |
if (errno) { |
257 |
wputs("Illegal power\n"); |
258 |
return(0.0); |
259 |
260 |
errno = lasterrno; |
261 |
return(d); |
262 |
263 |
264 |
static double |
265 |
ebotch(ep) |
266 |
EPNODE *ep; |
267 |
268 |
eputs("Bad expression!\n"); |
269 |
quit(1); |
270 |
271 |
272 |
273 |
EPNODE * |
274 |
ekid(ep, n) /* return pointer to a node's nth kid */ |
275 |
276 |
register int n; |
277 |
278 |
279 |
for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) |
280 |
if (--n < 0) |
281 |
break; |
282 |
283 |
return(ep); |
284 |
285 |
286 |
287 |
int |
288 |
nekids(ep) /* return # of kids for node ep */ |
289 |
290 |
291 |
register int n = 0; |
292 |
293 |
294 |
n++; |
295 |
296 |
return(n); |
297 |
298 |
299 |
300 |
initfile(fp, fn, ln) /* prepare input file */ |
301 |
FILE *fp; |
302 |
char *fn; |
303 |
int ln; |
304 |
305 |
static char inpbuf[MAXLINE]; |
306 |
307 |
infp = fp; |
308 |
linbuf = inpbuf; |
309 |
infile = fn; |
310 |
lineno = ln; |
311 |
linepos = 0; |
312 |
inpbuf[0] = '\0'; |
313 |
scan(); |
314 |
315 |
316 |
317 |
initstr(s, fn, ln) /* prepare input string */ |
318 |
char *s; |
319 |
char *fn; |
320 |
int ln; |
321 |
322 |
infp = NULL; |
323 |
infile = fn; |
324 |
lineno = ln; |
325 |
linbuf = s; |
326 |
linepos = 0; |
327 |
scan(); |
328 |
329 |
330 |
331 |
getscanpos(fnp, lnp, spp, fpp) /* return current scan position */ |
332 |
char **fnp; |
333 |
int *lnp; |
334 |
char **spp; |
335 |
FILE **fpp; |
336 |
337 |
if (fnp != NULL) *fnp = infile; |
338 |
if (lnp != NULL) *lnp = lineno; |
339 |
if (spp != NULL) *spp = linbuf+linepos; |
340 |
if (fpp != NULL) *fpp = infp; |
341 |
342 |
343 |
344 |
int |
345 |
scan() /* scan next character, return literal next */ |
346 |
347 |
register int lnext = 0; |
348 |
349 |
do { |
350 |
if (linbuf[linepos] == '\0') |
351 |
if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL) |
352 |
nextc = EOF; |
353 |
else { |
354 |
nextc = linbuf[0]; |
355 |
lineno++; |
356 |
linepos = 1; |
357 |
358 |
else |
359 |
nextc = linbuf[linepos++]; |
360 |
if (!lnext) |
361 |
lnext = nextc; |
362 |
if (nextc == '{') { |
363 |
scan(); |
364 |
while (nextc != '}') |
365 |
if (nextc == EOF) |
366 |
syntax("'}' expected"); |
367 |
else |
368 |
scan(); |
369 |
scan(); |
370 |
371 |
} while (isspace(nextc)); |
372 |
return(lnext); |
373 |
374 |
375 |
376 |
char * |
377 |
long2ascii(l) /* convert long to ascii */ |
378 |
long l; |
379 |
380 |
static char buf[16]; |
381 |
register char *cp; |
382 |
int neg = 0; |
383 |
384 |
if (l == 0) |
385 |
return("0"); |
386 |
if (l < 0) { |
387 |
l = -l; |
388 |
neg++; |
389 |
390 |
cp = buf + sizeof(buf); |
391 |
*--cp = '\0'; |
392 |
while (l) { |
393 |
*--cp = l % 10 + '0'; |
394 |
l /= 10; |
395 |
396 |
if (neg) |
397 |
*--cp = '-'; |
398 |
return(cp); |
399 |
400 |
401 |
402 |
syntax(err) /* report syntax error and quit */ |
403 |
char *err; |
404 |
405 |
register int i; |
406 |
407 |
if (infile != NULL || lineno != 0) { |
408 |
if (infile != NULL) eputs(infile); |
409 |
if (lineno != 0) { |
410 |
eputs(infile != NULL ? ", line " : "line "); |
411 |
eputs(long2ascii((long)lineno)); |
412 |
413 |
eputs(":\n"); |
414 |
415 |
eputs(linbuf); |
416 |
if (linbuf[strlen(linbuf)-1] != '\n') |
417 |
eputs("\n"); |
418 |
for (i = 0; i < linepos-1; i++) |
419 |
eputs(linbuf[i] == '\t' ? "\t" : " "); |
420 |
eputs("^ "); |
421 |
eputs(err); |
422 |
eputs("\n"); |
423 |
quit(1); |
424 |
425 |
426 |
427 |
addekid(ep, ekid) /* add a child to ep */ |
428 |
429 |
EPNODE *ekid; |
430 |
431 |
if (ep->v.kid == NULL) |
432 |
ep->v.kid = ekid; |
433 |
else { |
434 |
for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling) |
435 |
436 |
ep->sibling = ekid; |
437 |
438 |
ekid->sibling = NULL; |
439 |
440 |
441 |
442 |
443 |
char * |
444 |
getname() /* scan an identifier */ |
445 |
446 |
static char str[MAXWORD+1]; |
447 |
register int i, lnext; |
448 |
449 |
lnext = nextc; |
450 |
for (i = 0; i < MAXWORD && isid(lnext); i++, lnext = scan()) |
451 |
str[i] = lnext; |
452 |
str[i] = '\0'; |
453 |
while (isid(lnext)) /* skip rest of name */ |
454 |
lnext = scan(); |
455 |
456 |
return(str); |
457 |
458 |
#endif |
459 |
460 |
461 |
int |
462 |
getinum() /* scan a positive integer */ |
463 |
464 |
register int n, lnext; |
465 |
466 |
n = 0; |
467 |
lnext = nextc; |
468 |
while (isdigit(lnext)) { |
469 |
n = n * 10 + lnext - '0'; |
470 |
lnext = scan(); |
471 |
472 |
return(n); |
473 |
474 |
475 |
476 |
double |
477 |
getnum() /* scan a positive float */ |
478 |
479 |
480 |
481 |
482 |
i = 0; |
483 |
lnext = nextc; |
484 |
while (isdigit(lnext) && i < MAXWORD) { |
485 |
str[i++] = lnext; |
486 |
lnext = scan(); |
487 |
488 |
if (lnext == '.' && i < MAXWORD) { |
489 |
str[i++] = lnext; |
490 |
lnext = scan(); |
491 |
492 |
str[i++] = lnext; |
493 |
lnext = scan(); |
494 |
495 |
496 |
if ((lnext == 'e' || lnext == 'E') && i < MAXWORD) { |
497 |
str[i++] = lnext; |
498 |
lnext = scan(); |
499 |
if ((lnext == '-' || lnext == '+') && i < MAXWORD) { |
500 |
str[i++] = lnext; |
501 |
lnext = scan(); |
502 |
503 |
504 |
str[i++] = lnext; |
505 |
lnext = scan(); |
506 |
507 |
508 |
str[i] = '\0'; |
509 |
510 |
return(atof(str)); |
511 |
512 |
513 |
514 |
EPNODE * |
515 |
getE1() /* E1 -> E1 ADDOP E2 */ |
516 |
/* E2 */ |
517 |
518 |
register EPNODE *ep1, *ep2; |
519 |
520 |
ep1 = getE2(); |
521 |
while (nextc == '+' || nextc == '-') { |
522 |
ep2 = newnode(); |
523 |
ep2->type = nextc; |
524 |
scan(); |
525 |
addekid(ep2, ep1); |
526 |
addekid(ep2, getE2()); |
527 |
#ifdef RCONST |
528 |
if (ep1->type == NUM && ep1->sibling->type == NUM) |
529 |
ep2 = rconst(ep2); |
530 |
#endif |
531 |
ep1 = ep2; |
532 |
533 |
return(ep1); |
534 |
535 |
536 |
537 |
EPNODE * |
538 |
getE2() /* E2 -> E2 MULOP E3 */ |
539 |
/* E3 */ |
540 |
541 |
542 |
543 |
ep1 = getE3(); |
544 |
while (nextc == '*' || nextc == '/') { |
545 |
ep2 = newnode(); |
546 |
547 |
scan(); |
548 |
549 |
addekid(ep2, getE3()); |
550 |
#ifdef RCONST |
551 |
552 |
553 |
#endif |
554 |
ep1 = ep2; |
555 |
556 |
return(ep1); |
557 |
558 |
559 |
560 |
EPNODE * |
561 |
getE3() /* E3 -> E4 ^ E3 */ |
562 |
/* E4 */ |
563 |
564 |
565 |
566 |
ep1 = getE4(); |
567 |
if (nextc == '^') { |
568 |
ep2 = newnode(); |
569 |
570 |
scan(); |
571 |
572 |
573 |
#ifdef RCONST |
574 |
575 |
576 |
#endif |
577 |
return(ep2); |
578 |
579 |
return(ep1); |
580 |
581 |
582 |
583 |
EPNODE * |
584 |
getE4() /* E4 -> ADDOP E5 */ |
585 |
/* E5 */ |
586 |
587 |
588 |
589 |
if (nextc == '-') { |
590 |
scan(); |
591 |
ep2 = getE5(); |
592 |
if (ep2->type == NUM) { |
593 |
ep2->v.num = -ep2->v.num; |
594 |
return(ep2); |
595 |
596 |
if (ep2->type == UMINUS) { /* don't generate -(-E5) */ |
597 |
efree((char *)ep2); |
598 |
return(ep2->v.kid); |
599 |
600 |
ep1 = newnode(); |
601 |
ep1->type = UMINUS; |
602 |
addekid(ep1, ep2); |
603 |
return(ep1); |
604 |
605 |
if (nextc == '+') |
606 |
scan(); |
607 |
return(getE5()); |
608 |
609 |
610 |
611 |
EPNODE * |
612 |
getE5() /* E5 -> (E1) */ |
613 |
/* VAR */ |
614 |
/* NUM */ |
615 |
/* $N */ |
616 |
/* FUNC(E1,..) */ |
617 |
/* ARG */ |
618 |
619 |
int i; |
620 |
char *nam; |
621 |
622 |
623 |
if (nextc == '(') { |
624 |
scan(); |
625 |
ep1 = getE1(); |
626 |
if (nextc != ')') |
627 |
syntax("')' expected"); |
628 |
scan(); |
629 |
return(ep1); |
630 |
631 |
632 |
#ifdef INCHAN |
633 |
if (nextc == '$') { |
634 |
scan(); |
635 |
ep1 = newnode(); |
636 |
ep1->type = CHAN; |
637 |
ep1->v.chan = getinum(); |
638 |
return(ep1); |
639 |
640 |
#endif |
641 |
642 |
643 |
if (isalpha(nextc) || nextc == CNTXMARK) { |
644 |
nam = getname(); |
645 |
646 |
ep1 = NULL; |
647 |
if (curfunc != NULL) |
648 |
for (i = 1, ep2 = curfunc->v.kid->sibling; |
649 |
ep2 != NULL; i++, ep2 = ep2->sibling) |
650 |
if (!strcmp(ep2->v.name, nam)) { |
651 |
ep1 = newnode(); |
652 |
ep1->type = ARG; |
653 |
ep1->v.chan = i; |
654 |
break; |
655 |
656 |
if (ep1 == NULL) |
657 |
#endif |
658 |
659 |
ep1 = newnode(); |
660 |
ep1->type = VAR; |
661 |
ep1->v.ln = varinsert(nam); |
662 |
663 |
#ifdef FUNCTION |
664 |
665 |
ep2 = newnode(); |
666 |
ep2->type = FUNC; |
667 |
668 |
ep1 = ep2; |
669 |
do { |
670 |
scan(); |
671 |
addekid(ep1, getE1()); |
672 |
} while (nextc == ','); |
673 |
if (nextc != ')') |
674 |
675 |
scan(); |
676 |
677 |
#ifndef VARIABLE |
678 |
else |
679 |
syntax("'(' expected"); |
680 |
#endif |
681 |
#endif |
682 |
#ifdef RCONST |
683 |
if (isconstvar(ep1)) |
684 |
ep1 = rconst(ep1); |
685 |
#endif |
686 |
return(ep1); |
687 |
688 |
#endif |
689 |
690 |
if (isdecimal(nextc)) { |
691 |
ep1 = newnode(); |
692 |
ep1->type = NUM; |
693 |
ep1->v.num = getnum(); |
694 |
return(ep1); |
695 |
696 |
697 |
698 |
699 |
700 |
#ifdef RCONST |
701 |
EPNODE * |
702 |
rconst(epar) /* reduce a constant expression */ |
703 |
704 |
705 |
706 |
707 |
ep = newnode(); |
708 |
ep->type = NUM; |
709 |
errno = 0; |
710 |
ep->v.num = evalue(epar); |
711 |
if (errno) |
712 |
syntax("bad constant expression"); |
713 |
epfree(epar); |
714 |
715 |
return(ep); |
716 |
717 |
718 |
719 |
isconstvar(ep) /* is ep linked to a constant expression? */ |
720 |
721 |
722 |
#ifdef VARIABLE |
723 |
register EPNODE *ep1; |
724 |
#ifdef FUNCTION |
725 |
726 |
if (ep->type == FUNC) { |
727 |
if (!isconstfun(ep->v.kid)) |
728 |
return(0); |
729 |
for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling) |
730 |
if (ep1->type != NUM && !isconstfun(ep1)) |
731 |
return(0); |
732 |
return(1); |
733 |
734 |
#endif |
735 |
if (ep->type != VAR) |
736 |
return(0); |
737 |
ep1 = ep->v.ln->def; |
738 |
if (ep1 == NULL || ep1->type != ':') |
739 |
return(0); |
740 |
#ifdef FUNCTION |
741 |
if (ep1->v.kid->type != SYM) |
742 |
return(0); |
743 |
#endif |
744 |
return(1); |
745 |
#else |
746 |
return(ep->type == FUNC); |
747 |
#endif |
748 |
749 |
750 |
751 |
#if defined(FUNCTION) && defined(VARIABLE) |
752 |
isconstfun(ep) /* is ep linked to a constant function? */ |
753 |
754 |
755 |
register EPNODE *dp; |
756 |
register LIBR *lp; |
757 |
758 |
759 |
return(0); |
760 |
if ((dp = ep->v.ln->def) != NULL && dp->v.kid->type == FUNC) |
761 |
return(dp->type == ':'); |
762 |
if ((lp = ep->v.ln->lib) != NULL) |
763 |
return(lp->atyp == ':'); |
764 |
return(0); |
765 |
766 |
#endif |
767 |
#endif |
