| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: calexpr.c,v 2.34 2010/07/25 05:50:27 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Compute data values using expression parser
| 6 |
| 7 |
* 7/1/85 Greg Ward
| 8 |
| 9 |
* 11/11/85 Made channel input conditional with (INCHAN) compiles.
| 10 |
| 11 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION).
| 12 |
| 13 |
* 1/29/87 Made variables conditional (VARIABLE)
| 14 |
| 15 |
* 5/19/88 Added constant subexpression elimination (RCONST)
| 16 |
| 17 |
* 2/19/03 Eliminated conditional compiles in favor of esupport extern.
| 18 |
| 19 |
| 20 |
#include "copyright.h"
| 21 |
| 22 |
#include <stdio.h>
| 23 |
#include <string.h>
| 24 |
#include <ctype.h>
| 25 |
#include <errno.h>
| 26 |
#include <math.h>
| 27 |
#include <stdlib.h>
| 28 |
| 29 |
#include "rtmisc.h"
| 30 |
#include "rtio.h"
| 31 |
#include "rterror.h"
| 32 |
#include "calcomp.h"
| 33 |
| 34 |
#define MAXLINE 256 /* maximum line length */
| 35 |
| 36 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
| 37 |
| 38 |
#define isdecimal(c) (isdigit(c) || (c) == '.')
| 39 |
| 40 |
static double euminus(EPNODE *), eargument(EPNODE *), enumber(EPNODE *);
| 41 |
static double echannel(EPNODE *);
| 42 |
static double eadd(EPNODE *), esubtr(EPNODE *),
| 43 |
emult(EPNODE *), edivi(EPNODE *),
| 44 |
epow(EPNODE *);
| 45 |
static double ebotch(EPNODE *);
| 46 |
| 47 |
unsigned int esupport = /* what to support */
| 48 |
E_VARIABLE | E_FUNCTION ;
| 49 |
| 50 |
int eofc = 0; /* optional end-of-file character */
| 51 |
int nextc; /* lookahead character */
| 52 |
| 53 |
double (*eoper[])(EPNODE *) = { /* expression operations */
| 54 |
ebotch,
| 55 |
evariable,
| 56 |
enumber,
| 57 |
euminus,
| 58 |
echannel,
| 59 |
efunc,
| 60 |
eargument,
| 61 |
ebotch,
| 62 |
ebotch,
| 63 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
| 64 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
| 65 |
emult,
| 66 |
eadd,
| 67 |
0,
| 68 |
esubtr,
| 69 |
0,
| 70 |
edivi,
| 71 |
| 72 |
ebotch,
| 73 |
0,0,
| 74 |
ebotch,
| 75 |
| 76 |
| 77 |
epow,
| 78 |
| 79 |
| 80 |
static FILE *infp; /* input file pointer */
| 81 |
static char *linbuf; /* line buffer */
| 82 |
static char *infile; /* input file name */
| 83 |
static int lineno; /* input line number */
| 84 |
static int linepos; /* position in buffer */
| 85 |
| 86 |
| 87 |
EPNODE *
| 88 |
eparse( /* parse an expression string */
| 89 |
char *expr
| 90 |
| 91 |
| 92 |
EPNODE *ep;
| 93 |
| 94 |
initstr(expr, NULL, 0);
| 95 |
curfunc = NULL;
| 96 |
ep = getE1();
| 97 |
if (nextc != EOF)
| 98 |
syntax("unexpected character");
| 99 |
return(ep);
| 100 |
| 101 |
| 102 |
| 103 |
double
| 104 |
eval( /* evaluate an expression string */
| 105 |
char *expr
| 106 |
| 107 |
| 108 |
register EPNODE *ep;
| 109 |
double rval;
| 110 |
| 111 |
ep = eparse(expr);
| 112 |
rval = evalue(ep);
| 113 |
epfree(ep);
| 114 |
return(rval);
| 115 |
| 116 |
| 117 |
| 118 |
int
| 119 |
epcmp( /* compare two expressions for equivalence */
| 120 |
register EPNODE *ep1,
| 121 |
register EPNODE *ep2
| 122 |
| 123 |
| 124 |
double d;
| 125 |
| 126 |
if (ep1->type != ep2->type)
| 127 |
return(1);
| 128 |
| 129 |
switch (ep1->type) {
| 130 |
| 131 |
case VAR:
| 132 |
return(ep1->v.ln != ep2->v.ln);
| 133 |
| 134 |
case NUM:
| 135 |
if (ep2->v.num == 0)
| 136 |
return(ep1->v.num != 0);
| 137 |
d = ep1->v.num / ep2->v.num;
| 138 |
return((d > 1.000000000001) | (d < 0.999999999999));
| 139 |
| 140 |
case CHAN:
| 141 |
case ARG:
| 142 |
return(ep1->v.chan != ep2->v.chan);
| 143 |
| 144 |
case '=':
| 145 |
case ':':
| 146 |
return(epcmp(ep1->v.kid->sibling, ep2->v.kid->sibling));
| 147 |
| 148 |
case CLKT:
| 149 |
case SYM: /* should never get this one */
| 150 |
return(0);
| 151 |
| 152 |
default:
| 153 |
ep1 = ep1->v.kid;
| 154 |
ep2 = ep2->v.kid;
| 155 |
while (ep1 != NULL) {
| 156 |
if (ep2 == NULL)
| 157 |
return(1);
| 158 |
if (epcmp(ep1, ep2))
| 159 |
return(1);
| 160 |
ep1 = ep1->sibling;
| 161 |
ep2 = ep2->sibling;
| 162 |
| 163 |
return(ep2 != NULL);
| 164 |
| 165 |
| 166 |
| 167 |
| 168 |
void
| 169 |
epfree( /* free a parse tree */
| 170 |
register EPNODE *epar
| 171 |
| 172 |
| 173 |
| 174 |
| 175 |
switch (epar->type) {
| 176 |
| 177 |
case VAR:
| 178 |
varfree(epar->v.ln);
| 179 |
break;
| 180 |
| 181 |
case SYM:
| 182 |
freestr(epar->v.name);
| 183 |
break;
| 184 |
| 185 |
case NUM:
| 186 |
case CHAN:
| 187 |
case ARG:
| 188 |
case CLKT:
| 189 |
break;
| 190 |
| 191 |
default:
| 192 |
while ((ep = epar->v.kid) != NULL) {
| 193 |
epar->v.kid = ep->sibling;
| 194 |
epfree(ep);
| 195 |
| 196 |
break;
| 197 |
| 198 |
| 199 |
| 200 |
efree((char *)epar);
| 201 |
| 202 |
| 203 |
/* the following used to be a switch */
| 204 |
static double
| 205 |
eargument(
| 206 |
EPNODE *ep
| 207 |
| 208 |
| 209 |
return(argument(ep->v.chan));
| 210 |
| 211 |
| 212 |
static double
| 213 |
enumber(
| 214 |
EPNODE *ep
| 215 |
| 216 |
| 217 |
return(ep->v.num);
| 218 |
| 219 |
| 220 |
static double
| 221 |
euminus(
| 222 |
EPNODE *ep
| 223 |
| 224 |
| 225 |
register EPNODE *ep1 = ep->v.kid;
| 226 |
| 227 |
return(-evalue(ep1));
| 228 |
| 229 |
| 230 |
static double
| 231 |
echannel(
| 232 |
EPNODE *ep
| 233 |
| 234 |
| 235 |
return(chanvalue(ep->v.chan));
| 236 |
| 237 |
| 238 |
static double
| 239 |
eadd(
| 240 |
EPNODE *ep
| 241 |
| 242 |
| 243 |
| 244 |
| 245 |
return(evalue(ep1) + evalue(ep1->sibling));
| 246 |
| 247 |
| 248 |
static double
| 249 |
esubtr(
| 250 |
EPNODE *ep
| 251 |
| 252 |
| 253 |
| 254 |
| 255 |
return(evalue(ep1) - evalue(ep1->sibling));
| 256 |
| 257 |
| 258 |
static double
| 259 |
emult(
| 260 |
EPNODE *ep
| 261 |
| 262 |
| 263 |
| 264 |
| 265 |
return(evalue(ep1) * evalue(ep1->sibling));
| 266 |
| 267 |
| 268 |
static double
| 269 |
edivi(
| 270 |
EPNODE *ep
| 271 |
| 272 |
| 273 |
| 274 |
double d;
| 275 |
| 276 |
d = evalue(ep1->sibling);
| 277 |
if (d == 0.0) {
| 278 |
wputs("Division by zero\n");
| 279 |
errno = ERANGE;
| 280 |
return(0.0);
| 281 |
| 282 |
return(evalue(ep1) / d);
| 283 |
| 284 |
| 285 |
static double
| 286 |
epow(
| 287 |
EPNODE *ep
| 288 |
| 289 |
| 290 |
| 291 |
double d;
| 292 |
int lasterrno;
| 293 |
| 294 |
lasterrno = errno;
| 295 |
errno = 0;
| 296 |
d = pow(evalue(ep1), evalue(ep1->sibling));
| 297 |
#ifdef isnan
| 298 |
if (errno == 0)
| 299 |
if (isnan(d))
| 300 |
errno = EDOM;
| 301 |
else if (isinf(d))
| 302 |
errno = ERANGE;
| 303 |
#endif
| 304 |
if (errno == EDOM || errno == ERANGE) {
| 305 |
wputs("Illegal power\n");
| 306 |
return(0.0);
| 307 |
| 308 |
errno = lasterrno;
| 309 |
return(d);
| 310 |
| 311 |
| 312 |
static double
| 313 |
ebotch(
| 314 |
EPNODE *ep
| 315 |
| 316 |
| 317 |
eputs("Bad expression!\n");
| 318 |
quit(1);
| 319 |
return 0.0; /* pro forma return */
| 320 |
| 321 |
| 322 |
| 323 |
EPNODE *
| 324 |
ekid( /* return pointer to a node's nth kid */
| 325 |
register EPNODE *ep,
| 326 |
register int n
| 327 |
| 328 |
| 329 |
| 330 |
for (ep = ep->v.kid; ep != NULL; ep = ep->sibling)
| 331 |
if (--n < 0)
| 332 |
break;
| 333 |
| 334 |
return(ep);
| 335 |
| 336 |
| 337 |
| 338 |
int
| 339 |
nekids( /* return # of kids for node ep */
| 340 |
register EPNODE *ep
| 341 |
| 342 |
| 343 |
register int n = 0;
| 344 |
| 345 |
| 346 |
n++;
| 347 |
| 348 |
return(n);
| 349 |
| 350 |
| 351 |
| 352 |
void
| 353 |
initfile( /* prepare input file */
| 354 |
FILE *fp,
| 355 |
char *fn,
| 356 |
int ln
| 357 |
| 358 |
| 359 |
static char inpbuf[MAXLINE];
| 360 |
| 361 |
infp = fp;
| 362 |
linbuf = inpbuf;
| 363 |
infile = fn;
| 364 |
lineno = ln;
| 365 |
linepos = 0;
| 366 |
inpbuf[0] = '\0';
| 367 |
scan();
| 368 |
| 369 |
| 370 |
| 371 |
void
| 372 |
initstr( /* prepare input string */
| 373 |
char *s,
| 374 |
char *fn,
| 375 |
int ln
| 376 |
| 377 |
| 378 |
infp = NULL;
| 379 |
infile = fn;
| 380 |
lineno = ln;
| 381 |
linbuf = s;
| 382 |
linepos = 0;
| 383 |
scan();
| 384 |
| 385 |
| 386 |
| 387 |
void
| 388 |
getscanpos( /* return current scan position */
| 389 |
char **fnp,
| 390 |
int *lnp,
| 391 |
char **spp,
| 392 |
FILE **fpp
| 393 |
| 394 |
| 395 |
if (fnp != NULL) *fnp = infile;
| 396 |
if (lnp != NULL) *lnp = lineno;
| 397 |
if (spp != NULL) *spp = linbuf+linepos;
| 398 |
if (fpp != NULL) *fpp = infp;
| 399 |
| 400 |
| 401 |
| 402 |
int
| 403 |
scan(void) /* scan next character, return literal next */
| 404 |
| 405 |
register int lnext = 0;
| 406 |
| 407 |
do {
| 408 |
if (linbuf[linepos] == '\0')
| 409 |
if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL)
| 410 |
nextc = EOF;
| 411 |
else {
| 412 |
nextc = linbuf[0];
| 413 |
lineno++;
| 414 |
linepos = 1;
| 415 |
| 416 |
else
| 417 |
nextc = linbuf[linepos++];
| 418 |
if (!lnext)
| 419 |
lnext = nextc;
| 420 |
if (nextc == eofc) {
| 421 |
nextc = EOF;
| 422 |
break;
| 423 |
| 424 |
if (nextc == '{') {
| 425 |
scan();
| 426 |
while (nextc != '}')
| 427 |
if (nextc == EOF)
| 428 |
syntax("'}' expected");
| 429 |
else
| 430 |
scan();
| 431 |
scan();
| 432 |
| 433 |
} while (isspace(nextc));
| 434 |
return(lnext);
| 435 |
| 436 |
| 437 |
| 438 |
char *
| 439 |
long2ascii( /* convert long to ascii */
| 440 |
long l
| 441 |
| 442 |
| 443 |
static char buf[16];
| 444 |
register char *cp;
| 445 |
int neg = 0;
| 446 |
| 447 |
if (l == 0)
| 448 |
return("0");
| 449 |
if (l < 0) {
| 450 |
l = -l;
| 451 |
neg++;
| 452 |
| 453 |
cp = buf + sizeof(buf);
| 454 |
*--cp = '\0';
| 455 |
while (l) {
| 456 |
*--cp = l % 10 + '0';
| 457 |
l /= 10;
| 458 |
| 459 |
if (neg)
| 460 |
*--cp = '-';
| 461 |
return(cp);
| 462 |
| 463 |
| 464 |
| 465 |
void
| 466 |
syntax( /* report syntax error and quit */
| 467 |
char *err
| 468 |
| 469 |
| 470 |
register int i;
| 471 |
| 472 |
if (infile != NULL || lineno != 0) {
| 473 |
if (infile != NULL) eputs(infile);
| 474 |
if (lineno != 0) {
| 475 |
eputs(infile != NULL ? ", line " : "line ");
| 476 |
eputs(long2ascii((long)lineno));
| 477 |
| 478 |
eputs(":\n");
| 479 |
| 480 |
eputs(linbuf);
| 481 |
if (linbuf[strlen(linbuf)-1] != '\n')
| 482 |
eputs("\n");
| 483 |
for (i = 0; i < linepos-1; i++)
| 484 |
eputs(linbuf[i] == '\t' ? "\t" : " ");
| 485 |
eputs("^ ");
| 486 |
eputs(err);
| 487 |
eputs("\n");
| 488 |
quit(1);
| 489 |
| 490 |
| 491 |
| 492 |
void
| 493 |
addekid( /* add a child to ep */
| 494 |
| 495 |
EPNODE *ekid
| 496 |
| 497 |
| 498 |
if (ep->v.kid == NULL)
| 499 |
ep->v.kid = ekid;
| 500 |
else {
| 501 |
for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling)
| 502 |
| 503 |
ep->sibling = ekid;
| 504 |
| 505 |
ekid->sibling = NULL;
| 506 |
| 507 |
| 508 |
| 509 |
char *
| 510 |
getname(void) /* scan an identifier */
| 511 |
| 512 |
static char str[RMAXWORD+1];
| 513 |
register int i, lnext;
| 514 |
| 515 |
lnext = nextc;
| 516 |
for (i = 0; i < RMAXWORD && isid(lnext); i++, lnext = scan())
| 517 |
str[i] = lnext;
| 518 |
str[i] = '\0';
| 519 |
while (isid(lnext)) /* skip rest of name */
| 520 |
lnext = scan();
| 521 |
| 522 |
return(str);
| 523 |
| 524 |
| 525 |
| 526 |
int
| 527 |
getinum(void) /* scan a positive integer */
| 528 |
| 529 |
register int n, lnext;
| 530 |
| 531 |
n = 0;
| 532 |
lnext = nextc;
| 533 |
while (isdigit(lnext)) {
| 534 |
n = n * 10 + lnext - '0';
| 535 |
lnext = scan();
| 536 |
| 537 |
return(n);
| 538 |
| 539 |
| 540 |
| 541 |
double
| 542 |
getnum(void) /* scan a positive float */
| 543 |
| 544 |
| 545 |
| 546 |
| 547 |
i = 0;
| 548 |
lnext = nextc;
| 549 |
while (isdigit(lnext) && i < RMAXWORD) {
| 550 |
str[i++] = lnext;
| 551 |
lnext = scan();
| 552 |
| 553 |
if (lnext == '.' && i < RMAXWORD) {
| 554 |
str[i++] = lnext;
| 555 |
lnext = scan();
| 556 |
if (i == 1 && !isdigit(lnext))
| 557 |
syntax("badly formed number");
| 558 |
| 559 |
str[i++] = lnext;
| 560 |
lnext = scan();
| 561 |
| 562 |
| 563 |
if ((lnext == 'e') | (lnext == 'E') && i < RMAXWORD) {
| 564 |
str[i++] = lnext;
| 565 |
lnext = scan();
| 566 |
if ((lnext == '-') | (lnext == '+') && i < RMAXWORD) {
| 567 |
str[i++] = lnext;
| 568 |
lnext = scan();
| 569 |
| 570 |
if (!isdigit(lnext))
| 571 |
syntax("missing exponent");
| 572 |
| 573 |
str[i++] = lnext;
| 574 |
lnext = scan();
| 575 |
| 576 |
| 577 |
str[i] = '\0';
| 578 |
| 579 |
return(atof(str));
| 580 |
| 581 |
| 582 |
| 583 |
EPNODE *
| 584 |
getE1(void) /* E1 -> E1 ADDOP E2 */
| 585 |
/* E2 */
| 586 |
| 587 |
register EPNODE *ep1, *ep2;
| 588 |
| 589 |
ep1 = getE2();
| 590 |
while (nextc == '+' || nextc == '-') {
| 591 |
ep2 = newnode();
| 592 |
ep2->type = nextc;
| 593 |
scan();
| 594 |
addekid(ep2, ep1);
| 595 |
addekid(ep2, getE2());
| 596 |
if (esupport&E_RCONST &&
| 597 |
ep1->type == NUM && ep1->sibling->type == NUM)
| 598 |
ep2 = rconst(ep2);
| 599 |
ep1 = ep2;
| 600 |
| 601 |
return(ep1);
| 602 |
| 603 |
| 604 |
| 605 |
EPNODE *
| 606 |
getE2(void) /* E2 -> E2 MULOP E3 */
| 607 |
/* E3 */
| 608 |
| 609 |
| 610 |
| 611 |
ep1 = getE3();
| 612 |
while (nextc == '*' || nextc == '/') {
| 613 |
ep2 = newnode();
| 614 |
ep2->type = nextc;
| 615 |
scan();
| 616 |
addekid(ep2, ep1);
| 617 |
addekid(ep2, getE3());
| 618 |
if (esupport&E_RCONST) {
| 619 |
EPNODE *ep3 = ep1->sibling;
| 620 |
if (ep1->type == NUM && ep3->type == NUM) {
| 621 |
ep2 = rconst(ep2);
| 622 |
} else if (ep3->type == NUM) {
| 623 |
if (ep2->type == '/') {
| 624 |
if (ep3->v.num == 0)
| 625 |
syntax("divide by zero constant");
| 626 |
ep2->type = '*'; /* for speed */
| 627 |
ep3->v.num = 1./ep3->v.num;
| 628 |
} else if (ep3->v.num == 0) {
| 629 |
ep1->sibling = NULL; /* (E2 * 0) */
| 630 |
epfree(ep2);
| 631 |
ep2 = ep3;
| 632 |
| 633 |
} else if (ep1->type == NUM && ep1->v.num == 0) {
| 634 |
epfree(ep3); /* (0 * E3) or (0 / E3) */
| 635 |
| 636 |
efree((char *)ep2);
| 637 |
ep2 = ep1;
| 638 |
| 639 |
| 640 |
ep1 = ep2;
| 641 |
| 642 |
return(ep1);
| 643 |
| 644 |
| 645 |
| 646 |
EPNODE *
| 647 |
getE3(void) /* E3 -> E4 ^ E3 */
| 648 |
/* E4 */
| 649 |
| 650 |
| 651 |
| 652 |
ep1 = getE4();
| 653 |
if (nextc != '^')
| 654 |
return(ep1);
| 655 |
ep2 = newnode();
| 656 |
ep2->type = nextc;
| 657 |
scan();
| 658 |
addekid(ep2, ep1);
| 659 |
| 660 |
| 661 |
| 662 |
| 663 |
ep2 = rconst(ep2);
| 664 |
| 665 |
epfree(ep3); /* (0 ^ E3) */
| 666 |
| 667 |
efree((char *)ep2);
| 668 |
ep2 = ep1;
| 669 |
} else if ((ep3->type == NUM && ep3->v.num == 0) ||
| 670 |
(ep1->type == NUM && ep1->v.num == 1)) {
| 671 |
epfree(ep2); /* (E4 ^ 0) or (1 ^ E3) */
| 672 |
ep2 = newnode();
| 673 |
ep2->type = NUM;
| 674 |
ep2->v.num = 1;
| 675 |
| 676 |
| 677 |
return(ep2);
| 678 |
| 679 |
| 680 |
| 681 |
EPNODE *
| 682 |
getE4(void) /* E4 -> ADDOP E5 */
| 683 |
/* E5 */
| 684 |
| 685 |
| 686 |
| 687 |
if (nextc == '-') {
| 688 |
scan();
| 689 |
ep2 = getE5();
| 690 |
if (ep2->type == NUM) {
| 691 |
ep2->v.num = -ep2->v.num;
| 692 |
return(ep2);
| 693 |
| 694 |
if (ep2->type == UMINUS) { /* don't generate -(-E5) */
| 695 |
ep1 = ep2->v.kid;
| 696 |
efree((char *)ep2);
| 697 |
return(ep1);
| 698 |
| 699 |
ep1 = newnode();
| 700 |
ep1->type = UMINUS;
| 701 |
addekid(ep1, ep2);
| 702 |
return(ep1);
| 703 |
| 704 |
if (nextc == '+')
| 705 |
scan();
| 706 |
return(getE5());
| 707 |
| 708 |
| 709 |
| 710 |
EPNODE *
| 711 |
getE5(void) /* E5 -> (E1) */
| 712 |
/* VAR */
| 713 |
/* NUM */
| 714 |
/* $N */
| 715 |
/* FUNC(E1,..) */
| 716 |
/* ARG */
| 717 |
| 718 |
int i;
| 719 |
char *nam;
| 720 |
| 721 |
| 722 |
if (nextc == '(') {
| 723 |
scan();
| 724 |
ep1 = getE1();
| 725 |
if (nextc != ')')
| 726 |
syntax("')' expected");
| 727 |
scan();
| 728 |
return(ep1);
| 729 |
| 730 |
| 731 |
if (esupport&E_INCHAN && nextc == '$') {
| 732 |
scan();
| 733 |
ep1 = newnode();
| 734 |
ep1->type = CHAN;
| 735 |
ep1->v.chan = getinum();
| 736 |
return(ep1);
| 737 |
| 738 |
| 739 |
if (esupport&(E_VARIABLE|E_FUNCTION) &&
| 740 |
(isalpha(nextc) || nextc == CNTXMARK)) {
| 741 |
nam = getname();
| 742 |
ep1 = NULL;
| 743 |
if ((esupport&(E_VARIABLE|E_FUNCTION)) == (E_VARIABLE|E_FUNCTION)
| 744 |
&& curfunc != NULL)
| 745 |
for (i = 1, ep2 = curfunc->v.kid->sibling;
| 746 |
ep2 != NULL; i++, ep2 = ep2->sibling)
| 747 |
if (!strcmp(ep2->v.name, nam)) {
| 748 |
ep1 = newnode();
| 749 |
ep1->type = ARG;
| 750 |
ep1->v.chan = i;
| 751 |
break;
| 752 |
| 753 |
if (ep1 == NULL) {
| 754 |
ep1 = newnode();
| 755 |
ep1->type = VAR;
| 756 |
ep1->v.ln = varinsert(nam);
| 757 |
| 758 |
if (esupport&E_FUNCTION && nextc == '(') {
| 759 |
ep2 = newnode();
| 760 |
ep2->type = FUNC;
| 761 |
addekid(ep2, ep1);
| 762 |
ep1 = ep2;
| 763 |
do {
| 764 |
scan();
| 765 |
addekid(ep1, getE1());
| 766 |
} while (nextc == ',');
| 767 |
if (nextc != ')')
| 768 |
| 769 |
scan();
| 770 |
} else if (!(esupport&E_VARIABLE))
| 771 |
syntax("'(' expected");
| 772 |
if (esupport&E_RCONST && isconstvar(ep1))
| 773 |
ep1 = rconst(ep1);
| 774 |
return(ep1);
| 775 |
| 776 |
| 777 |
if (isdecimal(nextc)) {
| 778 |
ep1 = newnode();
| 779 |
ep1->type = NUM;
| 780 |
ep1->v.num = getnum();
| 781 |
return(ep1);
| 782 |
| 783 |
| 784 |
return NULL; /* pro forma return */
| 785 |
| 786 |
| 787 |
| 788 |
EPNODE *
| 789 |
rconst( /* reduce a constant expression */
| 790 |
| 791 |
| 792 |
| 793 |
| 794 |
| 795 |
ep = newnode();
| 796 |
ep->type = NUM;
| 797 |
errno = 0;
| 798 |
ep->v.num = evalue(epar);
| 799 |
| 800 |
syntax("bad constant expression");
| 801 |
epfree(epar);
| 802 |
| 803 |
return(ep);
| 804 |
| 805 |
| 806 |
| 807 |
int
| 808 |
isconstvar( /* is ep linked to a constant expression? */
| 809 |
register EPNODE *ep
| 810 |
| 811 |
| 812 |
register EPNODE *ep1;
| 813 |
| 814 |
if (esupport&E_FUNCTION && ep->type == FUNC) {
| 815 |
if (!isconstfun(ep->v.kid))
| 816 |
return(0);
| 817 |
for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling)
| 818 |
if (ep1->type != NUM && !isconstfun(ep1))
| 819 |
return(0);
| 820 |
return(1);
| 821 |
| 822 |
if (ep->type != VAR)
| 823 |
return(0);
| 824 |
ep1 = ep->v.ln->def;
| 825 |
if (ep1 == NULL || ep1->type != ':')
| 826 |
return(0);
| 827 |
if (esupport&E_FUNCTION && ep1->v.kid->type != SYM)
| 828 |
return(0);
| 829 |
return(1);
| 830 |
| 831 |
| 832 |
| 833 |
int
| 834 |
isconstfun( /* is ep linked to a constant function? */
| 835 |
register EPNODE *ep
| 836 |
| 837 |
| 838 |
register EPNODE *dp;
| 839 |
register LIBR *lp;
| 840 |
| 841 |
| 842 |
return(0);
| 843 |
if ((dp = ep->v.ln->def) != NULL) {
| 844 |
if (dp->v.kid->type == FUNC)
| 845 |
return(dp->type == ':');
| 846 |
else
| 847 |
return(0); /* don't identify masked library functions */
| 848 |
| 849 |
if ((lp = ep->v.ln->lib) != NULL)
| 850 |
return(lp->atyp == ':');
| 851 |
return(0);
| 852 |
