root/radiance/ray/src/common/calexpr.c
Sat Sep 4 19:04:35 2010 UTC (13 years, 9 months ago) by greg
Changes since 2.34: +12 -7 lines
Diff to previous 2.34 , to selected 2.27
Reduce (expr)/const to (expr)*(1/const)
Sun Jul 25 05:50:27 2010 UTC (13 years, 10 months ago) by greg
Changes since 2.33: +43 -16 lines
Diff to previous 2.33 , to selected 2.27
Added reduction of constant expressions (0*x), (x*0), (0/x), (1^x), (0^x), (x^0)
Sun Jun 14 18:21:58 2009 UTC (15 years ago) by greg
Changes since 2.32: +3 -2 lines
Diff to previous 2.32 , to selected 2.27
Added ability to specify constant name in rtcontrib -bn option
Thu May 1 16:42:05 2008 UTC (16 years, 1 month ago) by greg
Diff to previous 2.31 , to selected 2.27
Wed May 10 15:21:20 2006 UTC (18 years, 1 month ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 2.30: +7 -4 lines
Diff to previous 2.30 , to selected 2.27
Tue May 17 17:51:51 2005 UTC (19 years ago) by greg
Changes since 2.29: +6 -1 lines
Diff to previous 2.29 , to selected 2.27
Added "eofc" global for specifying an optional EOF character, such as '}'
Diff to previous 2.28 , to selected 2.27
Fri Nov 14 17:22:06 2003 UTC (20 years, 7 months ago) by schorsch
Changes since 2.27: +95 -69 lines
Diff to previous 2.27
Revision 2.27 - (view) (download) (annotate) - [selected]
Mon Aug 4 19:20:26 2003 UTC (20 years, 10 months ago) by greg
Diff to previous 2.26
Added prototype for eoper[] dispatch array
Changes since 2.25: +4 -4 lines
Diff to previous 2.25 , to selected 2.27
Mon Jul 21 22:30:17 2003 UTC (20 years, 10 months ago) by schorsch
Diff to previous 2.24 , to selected 2.27
Thu Jul 17 09:21:29 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.23: +8 -5 lines
Diff to previous 2.23 , to selected 2.27
Thu Jul 3 22:41:44 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.22: +10 -10 lines
Diff to previous 2.22 , to selected 2.27
Sat Jun 7 12:50:20 2003 UTC (21 years ago) by schorsch
Changes since 2.21: +65 -66 lines
Diff to previous 2.21 , to selected 2.27
Mon Jun 2 18:13:54 2003 UTC (21 years ago) by greg
Diff to previous 2.20 , to selected 2.27
Turned off E_REDEFW by default
Wed Mar 5 16:16:52 2003 UTC (21 years, 3 months ago) by greg
Diff to previous 2.19 , to selected 2.27
Changes since 2.18: +1 -56 lines
Diff to previous 2.18 , to selected 2.27
Changes since 2.17: +97 -84 lines
Diff to previous 2.17 , to selected 2.27
Mon Aug 17 17:57:30 1998 UTC (25 years, 10 months ago) by gwlarson
Changes since 2.16: +8 -4 lines
Diff to previous 2.16 , to selected 2.27
added more careful typing of numbers
Thu Feb 16 09:49:29 1995 UTC (29 years, 4 months ago) by greg
Changes since 2.15: +47 -0 lines
Diff to previous 2.15 , to selected 2.27
made redefinition warnings more intelligent --
won't report new definitions that are equivalent to old
Wed Sep 8 09:12:37 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.14: +4 -0 lines
Diff to previous 2.14 , to selected 2.27
added conditional declaration of atof()
Fri Jun 4 15:04:48 1993 UTC (31 years ago) by greg
Diff to previous 2.13 , to selected 2.27
removed conflicting gets() and puts() declarations
Fri Jun 4 14:27:58 1993 UTC (31 years ago) by greg
Changes since 2.12: +0 -3 lines
Diff to previous 2.12 , to selected 2.27
Removed unnecessary declaration of atof()
Fri Mar 5 15:14:00 1993 UTC (31 years, 3 months ago) by greg
Changes since 2.11: +4 -1 lines
Diff to previous 2.11 , to selected 2.27
portability improvements
Sun Nov 22 11:53:36 1992 UTC (31 years, 6 months ago) by greg
Diff to previous 2.10 , to selected 2.27
minor change to epfree()
Tue Nov 10 10:29:19 1992 UTC (31 years, 7 months ago) by greg
Diff to previous 2.9 , to selected 2.27
fixed bug for free() routines that touch contents
Tue Oct 6 12:29:36 1992 UTC (31 years, 8 months ago) by greg
Diff to previous 2.8 , to selected 2.27
Changes for 32-bit PC port
Fri Oct 2 15:57:29 1992 UTC (31 years, 8 months ago) by greg
Diff to previous 2.7 , to selected 2.27
Sat Sep 26 08:13:32 1992 UTC (31 years, 8 months ago) by greg
Diff to previous 2.6 , to selected 2.27
minor change to syntax error reporting
Mon Sep 21 12:01:54 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.5: +61 -62 lines
Diff to previous 2.5 , to selected 2.27
Changes for PC port
Tue May 19 20:21:58 1992 UTC (32 years, 1 month ago) by greg
Diff to previous 2.4 , to selected 2.27
removed a couple of unnecessary code segments
Fri May 15 16:38:52 1992 UTC (32 years, 1 month ago) by greg
Diff to previous 2.3 , to selected 2.27
Thu May 7 22:30:41 1992 UTC (32 years, 1 month ago) by greg
Changes since 2.2: +5 -8 lines
Diff to previous 2.2 , to selected 2.27
simplified and improved logic for testing of constant functions
Thu Dec 19 14:45:47 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 2.1 , to selected 2.27
Tue Nov 12 16:55:21 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.16 , to selected 2.27
Wed Aug 14 16:26:31 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.15: +4 -0 lines
Diff to previous 1.15 , to selected 2.27
eliminated possibility of generating -(-E5) parse tree
Wed Aug 14 08:18:14 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.14: +4 -2 lines
Diff to previous 1.14 , to selected 2.27
fixed code for long identifiers
Thu Aug 8 13:40:09 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.13: +10 -6 lines
Diff to previous 1.13 , to selected 2.27
added bug associated with context naming and function arguments
Thu Aug 8 12:11:19 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.12: +13 -0 lines
Diff to previous 1.12 , to selected 2.27
added getscanpos() function
Thu Aug 8 11:22:04 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.11: +36 -30 lines
Diff to previous 1.11 , to selected 2.27
added contexts to definition naming
Tue Apr 23 16:56:39 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.10: +25 -12 lines
Diff to previous 1.10 , to selected 2.27
added isconstfun() to find constant functions passed as arguments
Tue Apr 23 15:44:41 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.9 , to selected 2.27
Tue Apr 23 15:26:26 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.8: +45 -1 lines
Diff to previous 1.8 , to selected 2.27
added ':' definitions for constant expressions
Wed Apr 17 10:54:58 1991 UTC (33 years, 2 months ago) by greg
Diff to previous 1.7 , to selected 2.27
changed exponentiation to right-associative
Sat Aug 18 16:28:52 1990 UTC (33 years, 10 months ago) by greg
Changes since 1.6: +7 -8 lines
Diff to previous 1.6 , to selected 2.27
changed appearance of syntax error reports once more
Thu Jul 19 12:56:50 1990 UTC (33 years, 11 months ago) by greg
Changes since 1.5: +47 -10 lines
Diff to previous 1.5 , to selected 2.27
added line numbers to error reports
Tue Jun 26 09:15:11 1990 UTC (33 years, 11 months ago) by greg
Changes since 1.4: +4 -3 lines
Diff to previous 1.4 , to selected 2.27
Thu Jun 29 09:44:33 1989 UTC (34 years, 11 months ago) by greg
Diff to previous 1.3 , to selected 2.27
Deleted paranoid test that will never happen in syntax()
Wed Jun 14 22:29:01 1989 UTC (35 years ago) by greg
Changes since 1.2: +7 -13 lines
Diff to previous 1.2 , to selected 2.27
Minor modification of UMINUS compilation
Mon Apr 10 22:06:37 1989 UTC (35 years, 2 months ago) by greg
Diff to previous 1.1 , to selected 2.27
Fixed conditional compile error in epfree()
Thu Feb 2 10:34:27 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.27
