--- ray/src/common/calexpr.c 2010/07/25 05:50:27 2.34 +++ ray/src/common/calexpr.c 2010/09/04 19:04:35 2.35 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: calexpr.c,v 2.34 2010/07/25 05:50:27 greg Exp $"; +static const char RCSid[] = "$Id: calexpr.c,v 2.35 2010/09/04 19:04:35 greg Exp $"; #endif /* * Compute data values using expression parser @@ -619,12 +619,17 @@ getE2(void) /* E2 -> E2 MULOP E3 */ EPNODE *ep3 = ep1->sibling; if (ep1->type == NUM && ep3->type == NUM) { ep2 = rconst(ep2); - } else if (ep3->type == NUM && ep3->v.num == 0) { - if (ep2->type == '/') - syntax("divide by zero constant"); - ep1->sibling = NULL; /* (E2 * 0) */ - epfree(ep2); - ep2 = ep3; + } else if (ep3->type == NUM) { + if (ep2->type == '/') { + if (ep3->v.num == 0) + syntax("divide by zero constant"); + ep2->type = '*'; /* for speed */ + ep3->v.num = 1./ep3->v.num; + } else if (ep3->v.num == 0) { + ep1->sibling = NULL; /* (E2 * 0) */ + epfree(ep2); + ep2 = ep3; + } } else if (ep1->type == NUM && ep1->v.num == 0) { epfree(ep3); /* (0 * E3) or (0 / E3) */ ep1->sibling = NULL;
