root/radiance/ray/src/common/calexpr.c
Revision: 2.10
Committed: Tue Nov 10 10:29:19 1992 UTC (31 years, 7 months ago) by greg
fixed bug for free() routines that touch contents
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Compute data values using expression parser
9 *
10 * 7/1/85 Greg Ward
11 *
12 * 11/11/85 Made channel input conditional with (INCHAN) compiles.
13 *
14 * 4/2/86 Added conditional compiles for function definitions (FUNCTION).
15 *
16 * 1/29/87 Made variables conditional (VARIABLE)
17 *
18 * 5/19/88 Added constant subexpression elimination (RCONST)
19 */
20
21 #include <stdio.h>
22
23 #include <ctype.h>
24
25 #include <errno.h>
26
27 #include <math.h>
28
29 #include "calcomp.h"
30
31 #define MAXLINE 256 /* maximum line length */
32
33 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
34
35 #define isdecimal(c) (isdigit(c) || (c) == '.')
36
37 #ifndef atof
38 extern double atof();
39 #endif
40 extern char *fgets(), *savestr();
41 extern char *emalloc(), *ecalloc();
42 extern EPNODE *curfunc;
43 extern double efunc(), evariable();
44 static double euminus(), echannel(), eargument(), enumber();
45 static double eadd(), esubtr(), emult(), edivi(), epow();
46 static double ebotch();
47
48 int nextc; /* lookahead character */
49
50 double (*eoper[])() = { /* expression operations */
51 ebotch,
52 #ifdef VARIABLE
53 evariable,
54 #else
55 ebotch,
56 #endif
57 enumber,
58 euminus,
59 #ifdef INCHAN
60 echannel,
61 #else
62 ebotch,
63 #endif
64 #ifdef FUNCTION
65 efunc,
66 eargument,
67 #else
68 ebotch,
69 ebotch,
70 #endif
71 ebotch,
72 ebotch,
73 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
74 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
75 emult,
76 eadd,
77 0,
78 esubtr,
79 0,
80 edivi,
81 0,0,0,0,0,0,0,0,0,0,
82 ebotch,
83 0,0,
84 ebotch,
85 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
86 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
87 epow,
88 };
89
90 static FILE *infp; /* input file pointer */
91 static char *linbuf; /* line buffer */
92 static char *infile; /* input file name */
93 static int lineno; /* input line number */
94 static int linepos; /* position in buffer */
95
96
97 EPNODE *
98 eparse(expr) /* parse an expression string */
99 char *expr;
100 {
101 EPNODE *ep;
102
103 initstr(expr, NULL, 0);
104 #if defined(VARIABLE) && defined(FUNCTION)
105 curfunc = NULL;
106 #endif
107 ep = getE1();
108 if (nextc != EOF)
109 syntax("unexpected character");
110 return(ep);
111 }
112
113
114 double
115 eval(expr) /* evaluate an expression string */
116 char *expr;
117 {
118 register EPNODE *ep;
119 double rval;
120
121 ep = eparse(expr);
122 rval = evalue(ep);
123 epfree(ep);
124 return(rval);
125 }
126
127
128 epfree(epar) /* free a parse tree */
129 register EPNODE *epar;
130 {
131 register EPNODE *ep, *epn;
132
133 switch (epar->type) {
134
135 #if defined(VARIABLE) || defined(FUNCTION)
136 case VAR:
137 varfree(epar->v.ln);
138 break;
139
140 case SYM:
141 freestr(epar->v.name);
142 break;
143 #endif
144
145 case NUM:
146 case CHAN:
147 case ARG:
148 case TICK:
149 break;
150
151 default:
152 for (ep = epar->v.kid; ep != NULL; ep = epn) {
153 epn = ep->sibling;
154 epfree(ep);
155 }
156 break;
157
158 }
159
160 efree((char *)epar);
161 }
162
163 /* the following used to be a switch */
164 #ifdef FUNCTION
165 static double
166 eargument(ep)
167 EPNODE *ep;
168 {
169 return(argument(ep->v.chan));
170 }
171 #endif
172
173 static double
174 enumber(ep)
175 EPNODE *ep;
176 {
177 return(ep->v.num);
178 }
179
180 static double
181 euminus(ep)
182 EPNODE *ep;
183 {
184 register EPNODE *ep1 = ep->v.kid;
185
186 return(-evalue(ep1));
187 }
188
189 #ifdef INCHAN
190 static double
191 echannel(ep)
192 EPNODE *ep;
193 {
194 return(chanvalue(ep->v.chan));
195 }
196 #endif
197
198 static double
199 eadd(ep)
200 EPNODE *ep;
201 {
202 register EPNODE *ep1 = ep->v.kid;
203
204 return(evalue(ep1) + evalue(ep1->sibling));
205 }
206
207 static double
208 esubtr(ep)
209 EPNODE *ep;
210 {
211 register EPNODE *ep1 = ep->v.kid;
212
213 return(evalue(ep1) - evalue(ep1->sibling));
214 }
215
216 static double
217 emult(ep)
218 EPNODE *ep;
219 {
220 register EPNODE *ep1 = ep->v.kid;
221
222 return(evalue(ep1) * evalue(ep1->sibling));
223 }
224
225 static double
226 edivi(ep)
227 EPNODE *ep;
228 {
229 register EPNODE *ep1 = ep->v.kid;
230 double d;
231
232 d = evalue(ep1->sibling);
233 if (d == 0.0) {
234 wputs("Division by zero\n");
235 errno = ERANGE;
236 return(0.0);
237 }
238 return(evalue(ep1) / d);
239 }
240
241 static double
242 epow(ep)
243 EPNODE *ep;
244 {
245 register EPNODE *ep1 = ep->v.kid;
246 double d;
247 int lasterrno;
248
249 lasterrno = errno;
250 errno = 0;
251 d = pow(evalue(ep1), evalue(ep1->sibling));
252 #ifdef IEEE
253 if (!finite(d))
254 errno = EDOM;
255 #endif
256 if (errno) {
257 wputs("Illegal power\n");
258 return(0.0);
259 }
260 errno = lasterrno;
261 return(d);
262 }
263
264 static double
265 ebotch(ep)
266 EPNODE *ep;
267 {
268 eputs("Bad expression!\n");
269 quit(1);
270 }
271
272
273 EPNODE *
274 ekid(ep, n) /* return pointer to a node's nth kid */
275 register EPNODE *ep;
276 register int n;
277 {
278
279 for (ep = ep->v.kid; ep != NULL; ep = ep->sibling)
280 if (--n < 0)
281 break;
282
283 return(ep);
284 }
285
286
287 int
288 nekids(ep) /* return # of kids for node ep */
289 register EPNODE *ep;
290 {
291 register int n = 0;
292
293 for (ep = ep->v.kid; ep != NULL; ep = ep->sibling)
294 n++;
295
296 return(n);
297 }
298
299
300 initfile(fp, fn, ln) /* prepare input file */
301 FILE *fp;
302 char *fn;
303 int ln;
304 {
305 static char inpbuf[MAXLINE];
306
307 infp = fp;
308 linbuf = inpbuf;
309 infile = fn;
310 lineno = ln;
311 linepos = 0;
312 inpbuf[0] = '\0';
313 scan();
314 }
315
316
317 initstr(s, fn, ln) /* prepare input string */
318 char *s;
319 char *fn;
320 int ln;
321 {
322 infp = NULL;
323 infile = fn;
324 lineno = ln;
325 linbuf = s;
326 linepos = 0;
327 scan();
328 }
329
330
331 getscanpos(fnp, lnp, spp, fpp) /* return current scan position */
332 char **fnp;
333 int *lnp;
334 char **spp;
335 FILE **fpp;
336 {
337 if (fnp != NULL) *fnp = infile;
338 if (lnp != NULL) *lnp = lineno;
339 if (spp != NULL) *spp = linbuf+linepos;
340 if (fpp != NULL) *fpp = infp;
341 }
342
343
344 int
345 scan() /* scan next character, return literal next */
346 {
347 register int lnext = 0;
348
349 do {
350 if (linbuf[linepos] == '\0')
351 if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL)
352 nextc = EOF;
353 else {
354 nextc = linbuf[0];
355 lineno++;
356 linepos = 1;
357 }
358 else
359 nextc = linbuf[linepos++];
360 if (!lnext)
361 lnext = nextc;
362 if (nextc == '{') {
363 scan();
364 while (nextc != '}')
365 if (nextc == EOF)
366 syntax("'}' expected");
367 else
368 scan();
369 scan();
370 }
371 } while (isspace(nextc));
372 return(lnext);
373 }
374
375
376 char *
377 long2ascii(l) /* convert long to ascii */
378 long l;
379 {
380 static char buf[16];
381 register char *cp;
382 int neg = 0;
383
384 if (l == 0)
385 return("0");
386 if (l < 0) {
387 l = -l;
388 neg++;
389 }
390 cp = buf + sizeof(buf);
391 *--cp = '\0';
392 while (l) {
393 *--cp = l % 10 + '0';
394 l /= 10;
395 }
396 if (neg)
397 *--cp = '-';
398 return(cp);
399 }
400
401
402 syntax(err) /* report syntax error and quit */
403 char *err;
404 {
405 register int i;
406
407 if (infile != NULL || lineno != 0) {
408 if (infile != NULL) eputs(infile);
409 if (lineno != 0) {
410 eputs(infile != NULL ? ", line " : "line ");
411 eputs(long2ascii((long)lineno));
412 }
413 eputs(":\n");
414 }
415 eputs(linbuf);
416 if (linbuf[strlen(linbuf)-1] != '\n')
417 eputs("\n");
418 for (i = 0; i < linepos-1; i++)
419 eputs(linbuf[i] == '\t' ? "\t" : " ");
420 eputs("^ ");
421 eputs(err);
422 eputs("\n");
423 quit(1);
424 }
425
426
427 addekid(ep, ekid) /* add a child to ep */
428 register EPNODE *ep;
429 EPNODE *ekid;
430 {
431 if (ep->v.kid == NULL)
432 ep->v.kid = ekid;
433 else {
434 for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling)
435 ;
436 ep->sibling = ekid;
437 }
438 ekid->sibling = NULL;
439 }
440
441
442 #if defined(VARIABLE) || defined(FUNCTION)
443 char *
444 getname() /* scan an identifier */
445 {
446 static char str[MAXWORD+1];
447 register int i, lnext;
448
449 lnext = nextc;
450 for (i = 0; i < MAXWORD && isid(lnext); i++, lnext = scan())
451 str[i] = lnext;
452 str[i] = '\0';
453 while (isid(lnext)) /* skip rest of name */
454 lnext = scan();
455
456 return(str);
457 }
458 #endif
459
460
461 int
462 getinum() /* scan a positive integer */
463 {
464 register int n, lnext;
465
466 n = 0;
467 lnext = nextc;
468 while (isdigit(lnext)) {
469 n = n * 10 + lnext - '0';
470 lnext = scan();
471 }
472 return(n);
473 }
474
475
476 double
477 getnum() /* scan a positive float */
478 {
479 register int i, lnext;
480 char str[MAXWORD+1];
481
482 i = 0;
483 lnext = nextc;
484 while (isdigit(lnext) && i < MAXWORD) {
485 str[i++] = lnext;
486 lnext = scan();
487 }
488 if (lnext == '.' && i < MAXWORD) {
489 str[i++] = lnext;
490 lnext = scan();
491 while (isdigit(lnext) && i < MAXWORD) {
492 str[i++] = lnext;
493 lnext = scan();
494 }
495 }
496 if ((lnext == 'e' || lnext == 'E') && i < MAXWORD) {
497 str[i++] = lnext;
498 lnext = scan();
499 if ((lnext == '-' || lnext == '+') && i < MAXWORD) {
500 str[i++] = lnext;
501 lnext = scan();
502 }
503 while (isdigit(lnext) && i < MAXWORD) {
504 str[i++] = lnext;
505 lnext = scan();
506 }
507 }
508 str[i] = '\0';
509
510 return(atof(str));
511 }
512
513
514 EPNODE *
515 getE1() /* E1 -> E1 ADDOP E2 */
516 /* E2 */
517 {
518 register EPNODE *ep1, *ep2;
519
520 ep1 = getE2();
521 while (nextc == '+' || nextc == '-') {
522 ep2 = newnode();
523 ep2->type = nextc;
524 scan();
525 addekid(ep2, ep1);
526 addekid(ep2, getE2());
527 #ifdef RCONST
528 if (ep1->type == NUM && ep1->sibling->type == NUM)
529 ep2 = rconst(ep2);
530 #endif
531 ep1 = ep2;
532 }
533 return(ep1);
534 }
535
536
537 EPNODE *
538 getE2() /* E2 -> E2 MULOP E3 */
539 /* E3 */
540 {
541 register EPNODE *ep1, *ep2;
542
543 ep1 = getE3();
544 while (nextc == '*' || nextc == '/') {
545 ep2 = newnode();
546 ep2->type = nextc;
547 scan();
548 addekid(ep2, ep1);
549 addekid(ep2, getE3());
550 #ifdef RCONST
551 if (ep1->type == NUM && ep1->sibling->type == NUM)
552 ep2 = rconst(ep2);
553 #endif
554 ep1 = ep2;
555 }
556 return(ep1);
557 }
558
559
560 EPNODE *
561 getE3() /* E3 -> E4 ^ E3 */
562 /* E4 */
563 {
564 register EPNODE *ep1, *ep2;
565
566 ep1 = getE4();
567 if (nextc == '^') {
568 ep2 = newnode();
569 ep2->type = nextc;
570 scan();
571 addekid(ep2, ep1);
572 addekid(ep2, getE3());
573 #ifdef RCONST
574 if (ep1->type == NUM && ep1->sibling->type == NUM)
575 ep2 = rconst(ep2);
576 #endif
577 return(ep2);
578 }
579 return(ep1);
580 }
581
582
583 EPNODE *
584 getE4() /* E4 -> ADDOP E5 */
585 /* E5 */
586 {
587 register EPNODE *ep1, *ep2;
588
589 if (nextc == '-') {
590 scan();
591 ep2 = getE5();
592 if (ep2->type == NUM) {
593 ep2->v.num = -ep2->v.num;
594 return(ep2);
595 }
596 if (ep2->type == UMINUS) { /* don't generate -(-E5) */
597 efree((char *)ep2);
598 return(ep2->v.kid);
599 }
600 ep1 = newnode();
601 ep1->type = UMINUS;
602 addekid(ep1, ep2);
603 return(ep1);
604 }
605 if (nextc == '+')
606 scan();
607 return(getE5());
608 }
609
610
611 EPNODE *
612 getE5() /* E5 -> (E1) */
613 /* VAR */
614 /* NUM */
615 /* $N */
616 /* FUNC(E1,..) */
617 /* ARG */
618 {
619 int i;
620 char *nam;
621 register EPNODE *ep1, *ep2;
622
623 if (nextc == '(') {
624 scan();
625 ep1 = getE1();
626 if (nextc != ')')
627 syntax("')' expected");
628 scan();
629 return(ep1);
630 }
631
632 #ifdef INCHAN
633 if (nextc == '$') {
634 scan();
635 ep1 = newnode();
636 ep1->type = CHAN;
637 ep1->v.chan = getinum();
638 return(ep1);
639 }
640 #endif
641
642 #if defined(VARIABLE) || defined(FUNCTION)
643 if (isalpha(nextc) || nextc == CNTXMARK) {
644 nam = getname();
645 #if defined(VARIABLE) && defined(FUNCTION)
646 ep1 = NULL;
647 if (curfunc != NULL)
648 for (i = 1, ep2 = curfunc->v.kid->sibling;
649 ep2 != NULL; i++, ep2 = ep2->sibling)
650 if (!strcmp(ep2->v.name, nam)) {
651 ep1 = newnode();
652 ep1->type = ARG;
653 ep1->v.chan = i;
654 break;
655 }
656 if (ep1 == NULL)
657 #endif
658 {
659 ep1 = newnode();
660 ep1->type = VAR;
661 ep1->v.ln = varinsert(nam);
662 }
663 #ifdef FUNCTION
664 if (nextc == '(') {
665 ep2 = newnode();
666 ep2->type = FUNC;
667 addekid(ep2, ep1);
668 ep1 = ep2;
669 do {
670 scan();
671 addekid(ep1, getE1());
672 } while (nextc == ',');
673 if (nextc != ')')
674 syntax("')' expected");
675 scan();
676 }
677 #ifndef VARIABLE
678 else
679 syntax("'(' expected");
680 #endif
681 #endif
682 #ifdef RCONST
683 if (isconstvar(ep1))
684 ep1 = rconst(ep1);
685 #endif
686 return(ep1);
687 }
688 #endif
689
690 if (isdecimal(nextc)) {
691 ep1 = newnode();
692 ep1->type = NUM;
693 ep1->v.num = getnum();
694 return(ep1);
695 }
696 syntax("unexpected character");
697 }
698
699
700 #ifdef RCONST
701 EPNODE *
702 rconst(epar) /* reduce a constant expression */
703 register EPNODE *epar;
704 {
705 register EPNODE *ep;
706
707 ep = newnode();
708 ep->type = NUM;
709 errno = 0;
710 ep->v.num = evalue(epar);
711 if (errno)
712 syntax("bad constant expression");
713 epfree(epar);
714
715 return(ep);
716 }
717
718
719 isconstvar(ep) /* is ep linked to a constant expression? */
720 register EPNODE *ep;
721 {
722 #ifdef VARIABLE
723 register EPNODE *ep1;
724 #ifdef FUNCTION
725
726 if (ep->type == FUNC) {
727 if (!isconstfun(ep->v.kid))
728 return(0);
729 for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling)
730 if (ep1->type != NUM && !isconstfun(ep1))
731 return(0);
732 return(1);
733 }
734 #endif
735 if (ep->type != VAR)
736 return(0);
737 ep1 = ep->v.ln->def;
738 if (ep1 == NULL || ep1->type != ':')
739 return(0);
740 #ifdef FUNCTION
741 if (ep1->v.kid->type != SYM)
742 return(0);
743 #endif
744 return(1);
745 #else
746 return(ep->type == FUNC);
747 #endif
748 }
749
750
751 #if defined(FUNCTION) && defined(VARIABLE)
752 isconstfun(ep) /* is ep linked to a constant function? */
753 register EPNODE *ep;
754 {
755 register EPNODE *dp;
756 register LIBR *lp;
757
758 if (ep->type != VAR)
759 return(0);
760 if ((dp = ep->v.ln->def) != NULL && dp->v.kid->type == FUNC)
761 return(dp->type == ':');
762 if ((lp = ep->v.ln->lib) != NULL)
763 return(lp->atyp == ':');
764 return(0);
765 }
766 #endif
767 #endif
