--- ray/src/common/calexpr.c 1991/12/19 14:45:47 2.2 +++ ray/src/common/calexpr.c 1993/06/04 14:27:58 2.13 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -24,44 +24,44 @@ static char SCCSid[] = "$SunId$ LBL"; #include +#include + #include "calcomp.h" -#define MAXLINE 256 /* maximum line length */ +#define MAXLINE 256 /* maximum line length */ -#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) +#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) -#define isdecimal(c) (isdigit(c) || (c) == '.') +#define isdecimal(c) (isdigit(c) || (c) == '.') -#ifndef atof -extern double atof(); -#endif -extern double pow(); extern char *fgets(), *savestr(); extern char *emalloc(), *ecalloc(); extern EPNODE *curfunc; extern double efunc(), evariable(); -static double euminus(), echannel(), eargument(), enumber(); +static double euminus(), eargument(), enumber(); +#ifdef INCHAN +static double echannel(); +#endif static double eadd(), esubtr(), emult(), edivi(), epow(); static double ebotch(); -extern int errno; int nextc; /* lookahead character */ -double (*eoper[])() = { /* expression operations */ +double (*eoper[])() = { /* expression operations */ ebotch, -#ifdef VARIABLE +#ifdef VARIABLE evariable, #else ebotch, #endif enumber, euminus, -#ifdef INCHAN +#ifdef INCHAN echannel, #else ebotch, #endif -#ifdef FUNCTION +#ifdef FUNCTION efunc, eargument, #else @@ -126,7 +126,7 @@ char *expr; epfree(epar) /* free a parse tree */ -register EPNODE *epar; +register EPNODE *epar; { register EPNODE *ep; @@ -136,11 +136,11 @@ register EPNODE *epar; case VAR: varfree(epar->v.ln); break; -#endif case SYM: freestr(epar->v.name); break; +#endif case NUM: case CHAN: @@ -149,8 +149,10 @@ register EPNODE *epar; break; default: - for (ep = epar->v.kid; ep != NULL; ep = ep->sibling) + while ((ep = epar->v.kid) != NULL) { + epar->v.kid = ep->sibling; epfree(ep); + } break; } @@ -159,10 +161,10 @@ register EPNODE *epar; } /* the following used to be a switch */ -#ifdef FUNCTION +#ifdef FUNCTION static double eargument(ep) -EPNODE *ep; +EPNODE *ep; { return(argument(ep->v.chan)); } @@ -170,24 +172,24 @@ EPNODE *ep; static double enumber(ep) -EPNODE *ep; +EPNODE *ep; { return(ep->v.num); } static double euminus(ep) -EPNODE *ep; +EPNODE *ep; { register EPNODE *ep1 = ep->v.kid; return(-evalue(ep1)); } -#ifdef INCHAN +#ifdef INCHAN static double echannel(ep) -EPNODE *ep; +EPNODE *ep; { return(chanvalue(ep->v.chan)); } @@ -195,7 +197,7 @@ EPNODE *ep; static double eadd(ep) -EPNODE *ep; +EPNODE *ep; { register EPNODE *ep1 = ep->v.kid; @@ -204,7 +206,7 @@ EPNODE *ep; static double esubtr(ep) -EPNODE *ep; +EPNODE *ep; { register EPNODE *ep1 = ep->v.kid; @@ -213,7 +215,7 @@ EPNODE *ep; static double emult(ep) -EPNODE *ep; +EPNODE *ep; { register EPNODE *ep1 = ep->v.kid; @@ -222,7 +224,7 @@ EPNODE *ep; static double edivi(ep) -EPNODE *ep; +EPNODE *ep; { register EPNODE *ep1 = ep->v.kid; double d; @@ -238,16 +240,16 @@ EPNODE *ep; static double epow(ep) -EPNODE *ep; +EPNODE *ep; { register EPNODE *ep1 = ep->v.kid; double d; - int lasterrno; + int lasterrno; lasterrno = errno; errno = 0; d = pow(evalue(ep1), evalue(ep1->sibling)); -#ifdef IEEE +#ifdef IEEE if (!finite(d)) errno = EDOM; #endif @@ -261,7 +263,7 @@ EPNODE *ep; static double ebotch(ep) -EPNODE *ep; +EPNODE *ep; { eputs("Bad expression!\n"); quit(1); @@ -270,7 +272,7 @@ EPNODE *ep; EPNODE * ekid(ep, n) /* return pointer to a node's nth kid */ -register EPNODE *ep; +register EPNODE *ep; register int n; { @@ -284,7 +286,7 @@ register int n; int nekids(ep) /* return # of kids for node ep */ -register EPNODE *ep; +register EPNODE *ep; { register int n = 0; @@ -300,7 +302,7 @@ FILE *fp; char *fn; int ln; { - static char inpbuf[MAXLINE]; + static char inpbuf[MAXLINE]; infp = fp; linbuf = inpbuf; @@ -372,12 +374,12 @@ scan() /* scan next character, return literal next char * -ltoa(l) /* convert long to ascii */ +long2ascii(l) /* convert long to ascii */ long l; { - static char buf[16]; + static char buf[16]; register char *cp; - int neg = 0; + int neg = 0; if (l == 0) return("0"); @@ -406,9 +408,9 @@ char *err; if (infile != NULL) eputs(infile); if (lineno != 0) { eputs(infile != NULL ? ", line " : "line "); - eputs(ltoa((long)lineno)); + eputs(long2ascii((long)lineno)); } - eputs(": syntax error:\n"); + eputs(":\n"); } eputs(linbuf); if (linbuf[strlen(linbuf)-1] != '\n') @@ -423,8 +425,8 @@ char *err; addekid(ep, ekid) /* add a child to ep */ -register EPNODE *ep; -EPNODE *ekid; +register EPNODE *ep; +EPNODE *ekid; { if (ep->v.kid == NULL) ep->v.kid = ekid; @@ -437,10 +439,11 @@ EPNODE *ekid; } +#if defined(VARIABLE) || defined(FUNCTION) char * getname() /* scan an identifier */ { - static char str[MAXWORD+1]; + static char str[MAXWORD+1]; register int i, lnext; lnext = nextc; @@ -452,6 +455,7 @@ getname() /* scan an identifier */ return(str); } +#endif int @@ -482,16 +486,16 @@ getnum() /* scan a positive float */ lnext = scan(); } if (lnext == '.' && i < MAXWORD) { - str[i++] = lnext; - lnext = scan(); + str[i++] = lnext; + lnext = scan(); while (isdigit(lnext) && i < MAXWORD) { str[i++] = lnext; lnext = scan(); } } if ((lnext == 'e' || lnext == 'E') && i < MAXWORD) { - str[i++] = lnext; - lnext = scan(); + str[i++] = lnext; + lnext = scan(); if ((lnext == '-' || lnext == '+') && i < MAXWORD) { str[i++] = lnext; lnext = scan(); @@ -509,7 +513,7 @@ getnum() /* scan a positive float */ EPNODE * getE1() /* E1 -> E1 ADDOP E2 */ - /* E2 */ + /* E2 */ { register EPNODE *ep1, *ep2; @@ -520,7 +524,7 @@ getE1() /* E1 -> E1 ADDOP E2 */ scan(); addekid(ep2, ep1); addekid(ep2, getE2()); -#ifdef RCONST +#ifdef RCONST if (ep1->type == NUM && ep1->sibling->type == NUM) ep2 = rconst(ep2); #endif @@ -532,7 +536,7 @@ getE1() /* E1 -> E1 ADDOP E2 */ EPNODE * getE2() /* E2 -> E2 MULOP E3 */ - /* E3 */ + /* E3 */ { register EPNODE *ep1, *ep2; @@ -543,7 +547,7 @@ getE2() /* E2 -> E2 MULOP E3 */ scan(); addekid(ep2, ep1); addekid(ep2, getE3()); -#ifdef RCONST +#ifdef RCONST if (ep1->type == NUM && ep1->sibling->type == NUM) ep2 = rconst(ep2); #endif @@ -555,7 +559,7 @@ getE2() /* E2 -> E2 MULOP E3 */ EPNODE * getE3() /* E3 -> E4 ^ E3 */ - /* E4 */ + /* E4 */ { register EPNODE *ep1, *ep2; @@ -566,7 +570,7 @@ getE3() /* E3 -> E4 ^ E3 */ scan(); addekid(ep2, ep1); addekid(ep2, getE3()); -#ifdef RCONST +#ifdef RCONST if (ep1->type == NUM && ep1->sibling->type == NUM) ep2 = rconst(ep2); #endif @@ -578,7 +582,7 @@ getE3() /* E3 -> E4 ^ E3 */ EPNODE * getE4() /* E4 -> ADDOP E5 */ - /* E5 */ + /* E5 */ { register EPNODE *ep1, *ep2; @@ -606,13 +610,13 @@ getE4() /* E4 -> ADDOP E5 */ EPNODE * getE5() /* E5 -> (E1) */ - /* VAR */ - /* NUM */ - /* $N */ - /* FUNC(E1,..) */ - /* ARG */ + /* VAR */ + /* NUM */ + /* $N */ + /* FUNC(E1,..) */ + /* ARG */ { - int i; + int i; char *nam; register EPNODE *ep1, *ep2; @@ -625,7 +629,7 @@ getE5() /* E5 -> (E1) */ return(ep1); } -#ifdef INCHAN +#ifdef INCHAN if (nextc == '$') { scan(); ep1 = newnode(); @@ -642,7 +646,7 @@ getE5() /* E5 -> (E1) */ ep1 = NULL; if (curfunc != NULL) for (i = 1, ep2 = curfunc->v.kid->sibling; - ep2 != NULL; i++, ep2 = ep2->sibling) + ep2 != NULL; i++, ep2 = ep2->sibling) if (!strcmp(ep2->v.name, nam)) { ep1 = newnode(); ep1->type = ARG; @@ -656,7 +660,7 @@ getE5() /* E5 -> (E1) */ ep1->type = VAR; ep1->v.ln = varinsert(nam); } -#ifdef FUNCTION +#ifdef FUNCTION if (nextc == '(') { ep2 = newnode(); ep2->type = FUNC; @@ -670,12 +674,12 @@ getE5() /* E5 -> (E1) */ syntax("')' expected"); scan(); } -#ifndef VARIABLE +#ifndef VARIABLE else syntax("'(' expected"); #endif #endif -#ifdef RCONST +#ifdef RCONST if (isconstvar(ep1)) ep1 = rconst(ep1); #endif @@ -693,10 +697,10 @@ getE5() /* E5 -> (E1) */ } -#ifdef RCONST +#ifdef RCONST EPNODE * rconst(epar) /* reduce a constant expression */ -register EPNODE *epar; +register EPNODE *epar; { register EPNODE *ep; @@ -705,7 +709,7 @@ register EPNODE *epar; errno = 0; ep->v.num = evalue(epar); if (errno) - syntax("bad constant expression"); + syntax("bad constant expression"); epfree(epar); return(ep); @@ -713,11 +717,11 @@ register EPNODE *epar; isconstvar(ep) /* is ep linked to a constant expression? */ -register EPNODE *ep; +register EPNODE *ep; { -#ifdef VARIABLE +#ifdef VARIABLE register EPNODE *ep1; -#ifdef FUNCTION +#ifdef FUNCTION if (ep->type == FUNC) { if (!isconstfun(ep->v.kid)) @@ -733,7 +737,7 @@ register EPNODE *ep; ep1 = ep->v.ln->def; if (ep1 == NULL || ep1->type != ':') return(0); -#ifdef FUNCTION +#ifdef FUNCTION if (ep1->v.kid->type != SYM) return(0); #endif @@ -746,21 +750,18 @@ register EPNODE *ep; #if defined(FUNCTION) && defined(VARIABLE) isconstfun(ep) /* is ep linked to a constant function? */ -register EPNODE *ep; +register EPNODE *ep; { register EPNODE *dp; register LIBR *lp; if (ep->type != VAR) return(0); - dp = ep->v.ln->def; - if (dp != NULL && dp->type != ':') - return(0); - if ((dp == NULL || dp->v.kid->type != FUNC) - && ((lp = liblookup(ep->v.ln->name)) == NULL - || lp->atyp != ':')) - return(0); - return(1); + if ((dp = ep->v.ln->def) != NULL && dp->v.kid->type == FUNC) + return(dp->type == ':'); + if ((lp = ep->v.ln->lib) != NULL) + return(lp->atyp == ':'); + return(0); } #endif #endif
