--- ray/src/common/calexpr.c 1989/02/02 10:34:27 1.1 +++ ray/src/common/calexpr.c 1990/06/26 09:15:11 1.5 @@ -39,9 +39,10 @@ extern double atof(), pow(); extern char *fgets(), *savestr(); extern char *emalloc(), *ecalloc(); extern EPNODE *curfunc; -extern double efunc(), evariable(), enumber(), euminus(), echannel(); -extern double eargument(), eadd(), esubtr(), emult(), edivi(), epow(); -extern double ebotch(); +extern double efunc(), evariable(); +static double euminus(), echannel(), eargument(), enumber(); +static double eadd(), esubtr(), emult(), edivi(), epow(); +static double ebotch(); extern int errno; int nextc; /* lookahead character */ @@ -128,9 +129,11 @@ register EPNODE *epar; switch (epar->type) { +#if defined(VARIABLE) || defined(FUNCTION) case VAR: varfree(epar->v.ln); break; +#endif case SYM: freestr(epar->v.name); @@ -347,7 +350,7 @@ char *err; register int i; eputs(linbuf); - if (linbuf[0] == '\0' || linbuf[strlen(linbuf)-1] != '\n') + if (linbuf[strlen(linbuf)-1] != '\n') eputs("\n"); for (i = 0; i < linepos-1; i++) eputs(linbuf[i] == '\t' ? "\t" : " "); @@ -515,24 +518,18 @@ EPNODE * getE4() /* E4 -> ADDOP E5 */ /* E5 */ { - register EPNODE *ep1; + register EPNODE *ep1, *ep2; if (nextc == '-') { scan(); - ep1 = newnode(); -#ifndef RCONST - if (isdecimal(nextc)) { - ep1->type = NUM; - ep1->v.num = -getnum(); - return(ep1); + ep2 = getE5(); + if (ep2->type == NUM) { + ep2->v.num = -ep2->v.num; + return(ep2); } -#endif + ep1 = newnode(); ep1->type = UMINUS; - addekid(ep1, getE5()); -#ifdef RCONST - if (ep1->v.kid->type == NUM) - ep1 = rconst(ep1); -#endif + addekid(ep1, ep2); return(ep1); } if (nextc == '+')
