--- ray/src/common/calexpr.c 2003/07/03 22:41:44 2.23 +++ ray/src/common/calexpr.c 2003/08/04 19:20:26 2.27 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: calexpr.c,v 2.23 2003/07/03 22:41:44 schorsch Exp $"; +static const char RCSid[] = "$Id: calexpr.c,v 2.27 2003/08/04 19:20:26 greg Exp $"; #endif /* * Compute data values using expression parser @@ -26,6 +26,7 @@ static const char RCSid[] = "$Id: calexpr.c,v 2.23 200 #include #include +#include "rterror.h" #include "calcomp.h" #define MAXLINE 256 /* maximum line length */ @@ -34,17 +35,19 @@ static const char RCSid[] = "$Id: calexpr.c,v 2.23 200 #define isdecimal(c) (isdigit(c) || (c) == '.') -static double euminus(), eargument(), enumber(); -static double echannel(); -static double eadd(), esubtr(), emult(), edivi(), epow(); -static double ebotch(); +static double euminus(EPNODE *), eargument(EPNODE *), enumber(EPNODE *); +static double echannel(EPNODE *); +static double eadd(EPNODE *), esubtr(EPNODE *), + emult(EPNODE *), edivi(EPNODE *), + epow(EPNODE *); +static double ebotch(EPNODE *); unsigned int esupport = /* what to support */ E_VARIABLE | E_FUNCTION ; int nextc; /* lookahead character */ -double (*eoper[])() = { /* expression operations */ +double (*eoper[])(EPNODE *) = { /* expression operations */ ebotch, evariable, enumber, @@ -125,7 +128,7 @@ register EPNODE *ep1, *ep2; if (ep2->v.num == 0) return(ep1->v.num != 0); d = ep1->v.num / ep2->v.num; - return(d > 1.000000000001 | d < 0.999999999999); + return((d > 1.000000000001) | (d < 0.999999999999)); case CHAN: case ARG: @@ -524,10 +527,10 @@ getnum() /* scan a positive float */ lnext = scan(); } } - if ((lnext == 'e' | lnext == 'E') && i < RMAXWORD) { + if ((lnext == 'e') | (lnext == 'E') && i < RMAXWORD) { str[i++] = lnext; lnext = scan(); - if ((lnext == '-' | lnext == '+') && i < RMAXWORD) { + if ((lnext == '-') | (lnext == '+') && i < RMAXWORD) { str[i++] = lnext; lnext = scan(); } @@ -768,11 +771,12 @@ register EPNODE *ep; if (ep->type != VAR) return(0); - if ((dp = ep->v.ln->def) != NULL) + if ((dp = ep->v.ln->def) != NULL) { if (dp->v.kid->type == FUNC) return(dp->type == ':'); else return(0); /* don't identify masked library functions */ + } if ((lp = ep->v.ln->lib) != NULL) return(lp->atyp == ':'); return(0);
