--- ray/src/common/calexpr.c 1989/02/02 10:34:27 1.1 +++ ray/src/common/calexpr.c 1992/09/21 12:01:54 2.6 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -26,41 +26,41 @@ static char SCCSid[] = "$SunId$ LBL"; #include "calcomp.h" -#define MAXLINE 256 /* maximum line length */ -#define MAXWORD 64 /* maximum word length */ +#define MAXLINE 256 /* maximum line length */ -#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) +#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) -#define isid(c) (isalnum(c) || (c) == '_' || (c) == '.') +#define isdecimal(c) (isdigit(c) || (c) == '.') -#define isdecimal(c) (isdigit(c) || (c) == '.') - -extern double atof(), pow(); +#ifndef atof +extern double atof(); +#endif +extern double pow(); extern char *fgets(), *savestr(); extern char *emalloc(), *ecalloc(); extern EPNODE *curfunc; -extern double efunc(), evariable(), enumber(), euminus(), echannel(); -extern double eargument(), eadd(), esubtr(), emult(), edivi(), epow(); -extern double ebotch(); -extern int errno; +extern double efunc(), evariable(); +static double euminus(), echannel(), eargument(), enumber(); +static double eadd(), esubtr(), emult(), edivi(), epow(); +static double ebotch(); int nextc; /* lookahead character */ -double (*eoper[])() = { /* expression operations */ +double (*eoper[])() = { /* expression operations */ ebotch, -#ifdef VARIABLE +#ifdef VARIABLE evariable, #else ebotch, #endif enumber, euminus, -#ifdef INCHAN +#ifdef INCHAN echannel, #else ebotch, #endif -#ifdef FUNCTION +#ifdef FUNCTION efunc, eargument, #else @@ -77,16 +77,19 @@ double (*eoper[])() = { /* expression operations */ esubtr, 0, edivi, - 0,0,0,0,0,0,0,0,0,0,0,0,0, + 0,0,0,0,0,0,0,0,0,0, ebotch, + 0,0, + ebotch, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, epow, }; -static char *infile; /* input file name */ static FILE *infp; /* input file pointer */ static char *linbuf; /* line buffer */ +static char *infile; /* input file name */ +static int lineno; /* input line number */ static int linepos; /* position in buffer */ @@ -96,7 +99,7 @@ char *expr; { EPNODE *ep; - initstr(NULL, expr); + initstr(expr, NULL, 0); #if defined(VARIABLE) && defined(FUNCTION) curfunc = NULL; #endif @@ -122,12 +125,13 @@ char *expr; epfree(epar) /* free a parse tree */ -register EPNODE *epar; +register EPNODE *epar; { register EPNODE *ep; switch (epar->type) { +#if defined(VARIABLE) || defined(FUNCTION) case VAR: varfree(epar->v.ln); break; @@ -135,6 +139,7 @@ register EPNODE *epar; case SYM: freestr(epar->v.name); break; +#endif case NUM: case CHAN: @@ -153,10 +158,10 @@ register EPNODE *epar; } /* the following used to be a switch */ -#ifdef FUNCTION +#ifdef FUNCTION static double eargument(ep) -EPNODE *ep; +EPNODE *ep; { return(argument(ep->v.chan)); } @@ -164,24 +169,24 @@ EPNODE *ep; static double enumber(ep) -EPNODE *ep; +EPNODE *ep; { return(ep->v.num); } static double euminus(ep) -EPNODE *ep; +EPNODE *ep; { register EPNODE *ep1 = ep->v.kid; return(-evalue(ep1)); } -#ifdef INCHAN +#ifdef INCHAN static double echannel(ep) -EPNODE *ep; +EPNODE *ep; { return(chanvalue(ep->v.chan)); } @@ -189,7 +194,7 @@ EPNODE *ep; static double eadd(ep) -EPNODE *ep; +EPNODE *ep; { register EPNODE *ep1 = ep->v.kid; @@ -198,7 +203,7 @@ EPNODE *ep; static double esubtr(ep) -EPNODE *ep; +EPNODE *ep; { register EPNODE *ep1 = ep->v.kid; @@ -207,7 +212,7 @@ EPNODE *ep; static double emult(ep) -EPNODE *ep; +EPNODE *ep; { register EPNODE *ep1 = ep->v.kid; @@ -216,7 +221,7 @@ EPNODE *ep; static double edivi(ep) -EPNODE *ep; +EPNODE *ep; { register EPNODE *ep1 = ep->v.kid; double d; @@ -232,16 +237,16 @@ EPNODE *ep; static double epow(ep) -EPNODE *ep; +EPNODE *ep; { register EPNODE *ep1 = ep->v.kid; double d; - int lasterrno; + int lasterrno; lasterrno = errno; errno = 0; d = pow(evalue(ep1), evalue(ep1->sibling)); -#ifdef IEEE +#ifdef IEEE if (!finite(d)) errno = EDOM; #endif @@ -255,7 +260,7 @@ EPNODE *ep; static double ebotch(ep) -EPNODE *ep; +EPNODE *ep; { eputs("Bad expression!\n"); quit(1); @@ -264,7 +269,7 @@ EPNODE *ep; EPNODE * ekid(ep, n) /* return pointer to a node's nth kid */ -register EPNODE *ep; +register EPNODE *ep; register int n; { @@ -278,7 +283,7 @@ register int n; int nekids(ep) /* return # of kids for node ep */ -register EPNODE *ep; +register EPNODE *ep; { register int n = 0; @@ -289,45 +294,68 @@ register EPNODE *ep; } -initfile(file, fp) /* prepare input file */ -char *file; +initfile(fp, fn, ln) /* prepare input file */ FILE *fp; +char *fn; +int ln; { - static char inpbuf[MAXLINE]; + static char inpbuf[MAXLINE]; - infile = file; infp = fp; linbuf = inpbuf; + infile = fn; + lineno = ln; linepos = 0; inpbuf[0] = '\0'; scan(); } -initstr(file, s) /* prepare input string */ -char *file; +initstr(s, fn, ln) /* prepare input string */ char *s; +char *fn; +int ln; { - infile = file; infp = NULL; + infile = fn; + lineno = ln; linbuf = s; linepos = 0; scan(); } -scan() /* scan next character */ +getscanpos(fnp, lnp, spp, fpp) /* return current scan position */ +char **fnp; +int *lnp; +char **spp; +FILE **fpp; { + if (fnp != NULL) *fnp = infile; + if (lnp != NULL) *lnp = lineno; + if (spp != NULL) *spp = linbuf+linepos; + if (fpp != NULL) *fpp = infp; +} + + +int +scan() /* scan next character, return literal next */ +{ + register int lnext = 0; + do { if (linbuf[linepos] == '\0') if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL) nextc = EOF; else { nextc = linbuf[0]; + lineno++; linepos = 1; } else nextc = linbuf[linepos++]; + if (!lnext) + lnext = nextc; if (nextc == '{') { scan(); while (nextc != '}') @@ -338,24 +366,55 @@ scan() /* scan next character */ scan(); } } while (isspace(nextc)); + return(lnext); } +char * +ltoa(l) /* convert long to ascii */ +long l; +{ + static char buf[16]; + register char *cp; + int neg = 0; + + if (l == 0) + return("0"); + if (l < 0) { + l = -l; + neg++; + } + cp = buf + sizeof(buf); + *--cp = '\0'; + while (l) { + *--cp = l % 10 + '0'; + l /= 10; + } + if (neg) + *--cp = '-'; + return(cp); +} + + syntax(err) /* report syntax error and quit */ char *err; { register int i; + if (infile != NULL || lineno != 0) { + if (infile != NULL) eputs(infile); + if (lineno != 0) { + eputs(infile != NULL ? ", line " : "line "); + eputs(ltoa((long)lineno)); + } + eputs(": syntax error:\n"); + } eputs(linbuf); - if (linbuf[0] == '\0' || linbuf[strlen(linbuf)-1] != '\n') + if (linbuf[strlen(linbuf)-1] != '\n') eputs("\n"); for (i = 0; i < linepos-1; i++) eputs(linbuf[i] == '\t' ? "\t" : " "); eputs("^ "); - if (infile != NULL) { - eputs(infile); - eputs(": "); - } eputs(err); eputs("\n"); quit(1); @@ -363,8 +422,8 @@ char *err; addekid(ep, ekid) /* add a child to ep */ -register EPNODE *ep; -EPNODE *ekid; +register EPNODE *ep; +EPNODE *ekid; { if (ep->v.kid == NULL) ep->v.kid = ekid; @@ -377,29 +436,35 @@ EPNODE *ekid; } +#if defined(VARIABLE) || defined(FUNCTION) char * getname() /* scan an identifier */ { - static char str[MAXWORD+1]; - register int i; + static char str[MAXWORD+1]; + register int i, lnext; - for (i = 0; i < MAXWORD && isid(nextc); i++, scan()) - str[i] = nextc; + lnext = nextc; + for (i = 0; i < MAXWORD && isid(lnext); i++, lnext = scan()) + str[i] = lnext; str[i] = '\0'; + while (isid(lnext)) /* skip rest of name */ + lnext = scan(); return(str); } +#endif int getinum() /* scan a positive integer */ { - register int n; + register int n, lnext; n = 0; - while (isdigit(nextc)) { - n = n * 10 + nextc - '0'; - scan(); + lnext = nextc; + while (isdigit(lnext)) { + n = n * 10 + lnext - '0'; + lnext = scan(); } return(n); } @@ -408,32 +473,33 @@ getinum() /* scan a positive integer */ double getnum() /* scan a positive float */ { - register int i; + register int i, lnext; char str[MAXWORD+1]; i = 0; - while (isdigit(nextc) && i < MAXWORD) { - str[i++] = nextc; - scan(); + lnext = nextc; + while (isdigit(lnext) && i < MAXWORD) { + str[i++] = lnext; + lnext = scan(); } - if (nextc == '.' && i < MAXWORD) { - str[i++] = nextc; - scan(); - while (isdigit(nextc) && i < MAXWORD) { - str[i++] = nextc; - scan(); + if (lnext == '.' && i < MAXWORD) { + str[i++] = lnext; + lnext = scan(); + while (isdigit(lnext) && i < MAXWORD) { + str[i++] = lnext; + lnext = scan(); } } - if ((nextc == 'e' || nextc == 'E') && i < MAXWORD) { - str[i++] = nextc; - scan(); - if ((nextc == '-' || nextc == '+') && i < MAXWORD) { - str[i++] = nextc; - scan(); + if ((lnext == 'e' || lnext == 'E') && i < MAXWORD) { + str[i++] = lnext; + lnext = scan(); + if ((lnext == '-' || lnext == '+') && i < MAXWORD) { + str[i++] = lnext; + lnext = scan(); } - while (isdigit(nextc) && i < MAXWORD) { - str[i++] = nextc; - scan(); + while (isdigit(lnext) && i < MAXWORD) { + str[i++] = lnext; + lnext = scan(); } } str[i] = '\0'; @@ -444,7 +510,7 @@ getnum() /* scan a positive float */ EPNODE * getE1() /* E1 -> E1 ADDOP E2 */ - /* E2 */ + /* E2 */ { register EPNODE *ep1, *ep2; @@ -455,7 +521,7 @@ getE1() /* E1 -> E1 ADDOP E2 */ scan(); addekid(ep2, ep1); addekid(ep2, getE2()); -#ifdef RCONST +#ifdef RCONST if (ep1->type == NUM && ep1->sibling->type == NUM) ep2 = rconst(ep2); #endif @@ -467,7 +533,7 @@ getE1() /* E1 -> E1 ADDOP E2 */ EPNODE * getE2() /* E2 -> E2 MULOP E3 */ - /* E3 */ + /* E3 */ { register EPNODE *ep1, *ep2; @@ -478,7 +544,7 @@ getE2() /* E2 -> E2 MULOP E3 */ scan(); addekid(ep2, ep1); addekid(ep2, getE3()); -#ifdef RCONST +#ifdef RCONST if (ep1->type == NUM && ep1->sibling->type == NUM) ep2 = rconst(ep2); #endif @@ -489,23 +555,23 @@ getE2() /* E2 -> E2 MULOP E3 */ EPNODE * -getE3() /* E3 -> E3 ^ E4 */ - /* E4 */ +getE3() /* E3 -> E4 ^ E3 */ + /* E4 */ { register EPNODE *ep1, *ep2; ep1 = getE4(); - while (nextc == '^') { + if (nextc == '^') { ep2 = newnode(); ep2->type = nextc; scan(); addekid(ep2, ep1); - addekid(ep2, getE4()); -#ifdef RCONST + addekid(ep2, getE3()); +#ifdef RCONST if (ep1->type == NUM && ep1->sibling->type == NUM) ep2 = rconst(ep2); #endif - ep1 = ep2; + return(ep2); } return(ep1); } @@ -513,26 +579,24 @@ getE3() /* E3 -> E3 ^ E4 */ EPNODE * getE4() /* E4 -> ADDOP E5 */ - /* E5 */ + /* E5 */ { - register EPNODE *ep1; + register EPNODE *ep1, *ep2; if (nextc == '-') { scan(); - ep1 = newnode(); -#ifndef RCONST - if (isdecimal(nextc)) { - ep1->type = NUM; - ep1->v.num = -getnum(); - return(ep1); + ep2 = getE5(); + if (ep2->type == NUM) { + ep2->v.num = -ep2->v.num; + return(ep2); } -#endif + if (ep2->type == UMINUS) { /* don't generate -(-E5) */ + efree((char *)ep2); + return(ep2->v.kid); + } + ep1 = newnode(); ep1->type = UMINUS; - addekid(ep1, getE5()); -#ifdef RCONST - if (ep1->v.kid->type == NUM) - ep1 = rconst(ep1); -#endif + addekid(ep1, ep2); return(ep1); } if (nextc == '+') @@ -543,13 +607,14 @@ getE4() /* E4 -> ADDOP E5 */ EPNODE * getE5() /* E5 -> (E1) */ - /* VAR */ - /* NUM */ - /* $N */ - /* FUNC(E1,..) */ - /* ARG */ + /* VAR */ + /* NUM */ + /* $N */ + /* FUNC(E1,..) */ + /* ARG */ { - int i; + int i; + char *nam; register EPNODE *ep1, *ep2; if (nextc == '(') { @@ -561,7 +626,7 @@ getE5() /* E5 -> (E1) */ return(ep1); } -#ifdef INCHAN +#ifdef INCHAN if (nextc == '$') { scan(); ep1 = newnode(); @@ -572,24 +637,27 @@ getE5() /* E5 -> (E1) */ #endif #if defined(VARIABLE) || defined(FUNCTION) - if (isalpha(nextc)) { - ep1 = newnode(); - ep1->type = VAR; - ep1->v.ln = varinsert(getname()); - + if (isalpha(nextc) || nextc == CNTXMARK) { + nam = getname(); #if defined(VARIABLE) && defined(FUNCTION) + ep1 = NULL; if (curfunc != NULL) for (i = 1, ep2 = curfunc->v.kid->sibling; - ep2 != NULL; i++, ep2 = ep2->sibling) - if (!strcmp(ep2->v.name, ep1->v.ln->name)) { - epfree(ep1); + ep2 != NULL; i++, ep2 = ep2->sibling) + if (!strcmp(ep2->v.name, nam)) { ep1 = newnode(); ep1->type = ARG; ep1->v.chan = i; break; } + if (ep1 == NULL) #endif -#ifdef FUNCTION + { + ep1 = newnode(); + ep1->type = VAR; + ep1->v.ln = varinsert(nam); + } +#ifdef FUNCTION if (nextc == '(') { ep2 = newnode(); ep2->type = FUNC; @@ -603,11 +671,15 @@ getE5() /* E5 -> (E1) */ syntax("')' expected"); scan(); } -#ifndef VARIABLE +#ifndef VARIABLE else syntax("'(' expected"); #endif #endif +#ifdef RCONST + if (isconstvar(ep1)) + ep1 = rconst(ep1); +#endif return(ep1); } #endif @@ -622,10 +694,10 @@ getE5() /* E5 -> (E1) */ } -#ifdef RCONST +#ifdef RCONST EPNODE * rconst(epar) /* reduce a constant expression */ -register EPNODE *epar; +register EPNODE *epar; { register EPNODE *ep; @@ -634,9 +706,59 @@ register EPNODE *epar; errno = 0; ep->v.num = evalue(epar); if (errno) - syntax("bad constant expression"); + syntax("bad constant expression"); epfree(epar); return(ep); } + + +isconstvar(ep) /* is ep linked to a constant expression? */ +register EPNODE *ep; +{ +#ifdef VARIABLE + register EPNODE *ep1; +#ifdef FUNCTION + + if (ep->type == FUNC) { + if (!isconstfun(ep->v.kid)) + return(0); + for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling) + if (ep1->type != NUM && !isconstfun(ep1)) + return(0); + return(1); + } +#endif + if (ep->type != VAR) + return(0); + ep1 = ep->v.ln->def; + if (ep1 == NULL || ep1->type != ':') + return(0); +#ifdef FUNCTION + if (ep1->v.kid->type != SYM) + return(0); +#endif + return(1); +#else + return(ep->type == FUNC); +#endif +} + + +#if defined(FUNCTION) && defined(VARIABLE) +isconstfun(ep) /* is ep linked to a constant function? */ +register EPNODE *ep; +{ + register EPNODE *dp; + register LIBR *lp; + + if (ep->type != VAR) + return(0); + if ((dp = ep->v.ln->def) != NULL && dp->v.kid->type == FUNC) + return(dp->type == ':'); + if ((lp = ep->v.ln->lib) != NULL) + return(lp->atyp == ':'); + return(0); +} +#endif #endif
