--- ray/src/common/calexpr.c 2003/03/05 16:16:52 2.20 +++ ray/src/common/calexpr.c 2003/07/27 22:12:01 2.26 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: calexpr.c,v 2.20 2003/03/05 16:16:52 greg Exp $"; +static const char RCSid[] = "$Id: calexpr.c,v 2.26 2003/07/27 22:12:01 schorsch Exp $"; #endif /* * Compute data values using expression parser @@ -20,15 +20,13 @@ static const char RCSid[] = "$Id: calexpr.c,v 2.20 200 #include "copyright.h" #include - +#include #include - #include - #include - #include +#include "rterror.h" #include "calcomp.h" #define MAXLINE 256 /* maximum line length */ @@ -37,13 +35,15 @@ static const char RCSid[] = "$Id: calexpr.c,v 2.20 200 #define isdecimal(c) (isdigit(c) || (c) == '.') -static double euminus(), eargument(), enumber(); -static double echannel(); -static double eadd(), esubtr(), emult(), edivi(), epow(); -static double ebotch(); +static double euminus(EPNODE *), eargument(EPNODE *), enumber(EPNODE *); +static double echannel(EPNODE *); +static double eadd(EPNODE *), esubtr(EPNODE *), + emult(EPNODE *), edivi(EPNODE *), + epow(EPNODE *); +static double ebotch(EPNODE *); unsigned int esupport = /* what to support */ - E_VARIABLE | E_FUNCTION | E_REDEFW; + E_VARIABLE | E_FUNCTION ; int nextc; /* lookahead character */ @@ -128,7 +128,7 @@ register EPNODE *ep1, *ep2; if (ep2->v.num == 0) return(ep1->v.num != 0); d = ep1->v.num / ep2->v.num; - return(d > 1.000000000001 | d < 0.999999999999); + return((d > 1.000000000001) | (d < 0.999999999999)); case CHAN: case ARG: @@ -295,6 +295,7 @@ EPNODE *ep; { eputs("Bad expression!\n"); quit(1); + return 0.0; /* pro forma return */ } @@ -475,11 +476,11 @@ EPNODE *ekid; char * getname() /* scan an identifier */ { - static char str[MAXWORD+1]; + static char str[RMAXWORD+1]; register int i, lnext; lnext = nextc; - for (i = 0; i < MAXWORD && isid(lnext); i++, lnext = scan()) + for (i = 0; i < RMAXWORD && isid(lnext); i++, lnext = scan()) str[i] = lnext; str[i] = '\0'; while (isid(lnext)) /* skip rest of name */ @@ -508,34 +509,34 @@ double getnum() /* scan a positive float */ { register int i, lnext; - char str[MAXWORD+1]; + char str[RMAXWORD+1]; i = 0; lnext = nextc; - while (isdigit(lnext) && i < MAXWORD) { + while (isdigit(lnext) && i < RMAXWORD) { str[i++] = lnext; lnext = scan(); } - if (lnext == '.' && i < MAXWORD) { + if (lnext == '.' && i < RMAXWORD) { str[i++] = lnext; lnext = scan(); if (i == 1 && !isdigit(lnext)) syntax("badly formed number"); - while (isdigit(lnext) && i < MAXWORD) { + while (isdigit(lnext) && i < RMAXWORD) { str[i++] = lnext; lnext = scan(); } } - if ((lnext == 'e' | lnext == 'E') && i < MAXWORD) { + if ((lnext == 'e') | (lnext == 'E') && i < RMAXWORD) { str[i++] = lnext; lnext = scan(); - if ((lnext == '-' | lnext == '+') && i < MAXWORD) { + if ((lnext == '-') | (lnext == '+') && i < RMAXWORD) { str[i++] = lnext; lnext = scan(); } if (!isdigit(lnext)) syntax("missing exponent"); - while (isdigit(lnext) && i < MAXWORD) { + while (isdigit(lnext) && i < RMAXWORD) { str[i++] = lnext; lnext = scan(); } @@ -648,72 +649,73 @@ getE5() /* E5 -> (E1) */ /* FUNC(E1,..) */ /* ARG */ { - int i; - char *nam; - register EPNODE *ep1, *ep2; + int i; + char *nam; + register EPNODE *ep1, *ep2; - if (nextc == '(') { - scan(); - ep1 = getE1(); - if (nextc != ')') - syntax("')' expected"); - scan(); - return(ep1); - } + if (nextc == '(') { + scan(); + ep1 = getE1(); + if (nextc != ')') + syntax("')' expected"); + scan(); + return(ep1); + } - if (esupport&E_INCHAN && nextc == '$') { - scan(); - ep1 = newnode(); - ep1->type = CHAN; - ep1->v.chan = getinum(); - return(ep1); - } + if (esupport&E_INCHAN && nextc == '$') { + scan(); + ep1 = newnode(); + ep1->type = CHAN; + ep1->v.chan = getinum(); + return(ep1); + } - if (esupport&(E_VARIABLE|E_FUNCTION) && - (isalpha(nextc) || nextc == CNTXMARK)) { - nam = getname(); - ep1 = NULL; - if ((esupport&(E_VARIABLE|E_FUNCTION)) == (E_VARIABLE|E_FUNCTION) - && curfunc != NULL) - for (i = 1, ep2 = curfunc->v.kid->sibling; - ep2 != NULL; i++, ep2 = ep2->sibling) - if (!strcmp(ep2->v.name, nam)) { - ep1 = newnode(); - ep1->type = ARG; - ep1->v.chan = i; - break; + if (esupport&(E_VARIABLE|E_FUNCTION) && + (isalpha(nextc) || nextc == CNTXMARK)) { + nam = getname(); + ep1 = NULL; + if ((esupport&(E_VARIABLE|E_FUNCTION)) == (E_VARIABLE|E_FUNCTION) + && curfunc != NULL) + for (i = 1, ep2 = curfunc->v.kid->sibling; + ep2 != NULL; i++, ep2 = ep2->sibling) + if (!strcmp(ep2->v.name, nam)) { + ep1 = newnode(); + ep1->type = ARG; + ep1->v.chan = i; + break; + } + if (ep1 == NULL) { + ep1 = newnode(); + ep1->type = VAR; + ep1->v.ln = varinsert(nam); } - if (ep1 == NULL) { - ep1 = newnode(); - ep1->type = VAR; - ep1->v.ln = varinsert(nam); + if (esupport&E_FUNCTION && nextc == '(') { + ep2 = newnode(); + ep2->type = FUNC; + addekid(ep2, ep1); + ep1 = ep2; + do { + scan(); + addekid(ep1, getE1()); + } while (nextc == ','); + if (nextc != ')') + syntax("')' expected"); + scan(); + } else if (!(esupport&E_VARIABLE)) + syntax("'(' expected"); + if (esupport&E_RCONST && isconstvar(ep1)) + ep1 = rconst(ep1); + return(ep1); } - if (esupport&E_FUNCTION && nextc == '(') { - ep2 = newnode(); - ep2->type = FUNC; - addekid(ep2, ep1); - ep1 = ep2; - do { - scan(); - addekid(ep1, getE1()); - } while (nextc == ','); - if (nextc != ')') - syntax("')' expected"); - scan(); - } else if (!(esupport&E_VARIABLE)) - syntax("'(' expected"); - if (esupport&E_RCONST && isconstvar(ep1)) - ep1 = rconst(ep1); - return(ep1); - } - if (isdecimal(nextc)) { - ep1 = newnode(); - ep1->type = NUM; - ep1->v.num = getnum(); - return(ep1); - } - syntax("unexpected character"); + if (isdecimal(nextc)) { + ep1 = newnode(); + ep1->type = NUM; + ep1->v.num = getnum(); + return(ep1); + } + syntax("unexpected character"); + return NULL; /* pro forma return */ } @@ -769,11 +771,12 @@ register EPNODE *ep; if (ep->type != VAR) return(0); - if ((dp = ep->v.ln->def) != NULL) + if ((dp = ep->v.ln->def) != NULL) { if (dp->v.kid->type == FUNC) return(dp->type == ':'); else return(0); /* don't identify masked library functions */ + } if ((lp = ep->v.ln->lib) != NULL) return(lp->atyp == ':'); return(0);
