root/radiance/ray/src/common/calexpr.c
Wed Mar 5 16:16:52 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 2.19 , to selected 1.5
Tue Feb 25 02:47:21 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.18: +1 -56 lines
Diff to previous 2.18 , to selected 1.5
Sat Feb 22 02:07:21 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.17: +97 -84 lines
Diff to previous 2.17 , to selected 1.5
Mon Aug 17 17:57:30 1998 UTC (26 years, 8 months ago) by gwlarson
Changes since 2.16: +8 -4 lines
Diff to previous 2.16 , to selected 1.5
added more careful typing of numbers
Thu Feb 16 09:49:29 1995 UTC (30 years, 2 months ago) by greg
Changes since 2.15: +47 -0 lines
Diff to previous 2.15 , to selected 1.5
made redefinition warnings more intelligent --
won't report new definitions that are equivalent to old
Wed Sep 8 09:12:37 1993 UTC (31 years, 8 months ago) by greg
Changes since 2.14: +4 -0 lines
Diff to previous 2.14 , to selected 1.5
added conditional declaration of atof()
Fri Jun 4 15:04:48 1993 UTC (31 years, 11 months ago) by greg
Diff to previous 2.13 , to selected 1.5
removed conflicting gets() and puts() declarations
Fri Jun 4 14:27:58 1993 UTC (31 years, 11 months ago) by greg
Changes since 2.12: +0 -3 lines
Diff to previous 2.12 , to selected 1.5
Removed unnecessary declaration of atof()
Fri Mar 5 15:14:00 1993 UTC (32 years, 2 months ago) by greg
Changes since 2.11: +4 -1 lines
Diff to previous 2.11 , to selected 1.5
portability improvements
Sun Nov 22 11:53:36 1992 UTC (32 years, 5 months ago) by greg
Diff to previous 2.10 , to selected 1.5
minor change to epfree()
Tue Nov 10 10:29:19 1992 UTC (32 years, 5 months ago) by greg
Diff to previous 2.9 , to selected 1.5
fixed bug for free() routines that touch contents
Tue Oct 6 12:29:36 1992 UTC (32 years, 7 months ago) by greg
Diff to previous 2.8 , to selected 1.5
Changes for 32-bit PC port
Fri Oct 2 15:57:29 1992 UTC (32 years, 7 months ago) by greg
Diff to previous 2.7 , to selected 1.5
Sat Sep 26 08:13:32 1992 UTC (32 years, 7 months ago) by greg
Diff to previous 2.6 , to selected 1.5
minor change to syntax error reporting
Mon Sep 21 12:01:54 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.5: +61 -62 lines
Diff to previous 2.5 , to selected 1.5
Changes for PC port
Tue May 19 20:21:58 1992 UTC (32 years, 11 months ago) by greg
Diff to previous 2.4 , to selected 1.5
removed a couple of unnecessary code segments
Fri May 15 16:38:52 1992 UTC (32 years, 11 months ago) by greg
Diff to previous 2.3 , to selected 1.5
Thu May 7 22:30:41 1992 UTC (33 years ago) by greg
Changes since 2.2: +5 -8 lines
Diff to previous 2.2 , to selected 1.5
simplified and improved logic for testing of constant functions
Thu Dec 19 14:45:47 1991 UTC (33 years, 4 months ago) by greg
Diff to previous 2.1 , to selected 1.5
Tue Nov 12 16:55:21 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 1.16 , to selected 1.5
Wed Aug 14 16:26:31 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.15: +4 -0 lines
Diff to previous 1.15 , to selected 1.5
eliminated possibility of generating -(-E5) parse tree
Wed Aug 14 08:18:14 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.14: +4 -2 lines
Diff to previous 1.14 , to selected 1.5
fixed code for long identifiers
Thu Aug 8 13:40:09 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.13: +10 -6 lines
Diff to previous 1.13 , to selected 1.5
added bug associated with context naming and function arguments
Thu Aug 8 12:11:19 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.12: +13 -0 lines
Diff to previous 1.12 , to selected 1.5
added getscanpos() function
Thu Aug 8 11:22:04 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.11: +36 -30 lines
Diff to previous 1.11 , to selected 1.5
added contexts to definition naming
Tue Apr 23 16:56:39 1991 UTC (34 years ago) by greg
Changes since 1.10: +25 -12 lines
Diff to previous 1.10 , to selected 1.5
added isconstfun() to find constant functions passed as arguments
Tue Apr 23 15:44:41 1991 UTC (34 years ago) by greg
Diff to previous 1.9 , to selected 1.5
Tue Apr 23 15:26:26 1991 UTC (34 years ago) by greg
Changes since 1.8: +45 -1 lines
Diff to previous 1.8 , to selected 1.5
added ':' definitions for constant expressions
Wed Apr 17 10:54:58 1991 UTC (34 years ago) by greg
Diff to previous 1.7 , to selected 1.5
changed exponentiation to right-associative
Sat Aug 18 16:28:52 1990 UTC (34 years, 8 months ago) by greg
Changes since 1.6: +7 -8 lines
Diff to previous 1.6 , to selected 1.5
changed appearance of syntax error reports once more
Thu Jul 19 12:56:50 1990 UTC (34 years, 9 months ago) by greg
Changes since 1.5: +47 -10 lines
Diff to previous 1.5
added line numbers to error reports
Tue Jun 26 09:15:11 1990 UTC (34 years, 10 months ago) by greg
Changes since 1.4: +4 -3 lines
Diff to previous 1.4
Thu Jun 29 09:44:33 1989 UTC (35 years, 10 months ago) by greg
Deleted paranoid test that will never happen in syntax()
Wed Jun 14 22:29:01 1989 UTC (35 years, 10 months ago) by greg
Changes since 1.2: +7 -13 lines
Minor modification of UMINUS compilation
Mon Apr 10 22:06:37 1989 UTC (36 years, 1 month ago) by greg
Fixed conditional compile error in epfree()
Thu Feb 2 10:34:27 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 1.5
