root/Development/ray/src/common/calexpr.c
Revision: 2.56
Committed: Sat Dec 6 16:39:20 2025 UTC (3 weeks, 6 days ago) by greg
Changes since 2.55: +8 -3 lines
perf: Enabled more constant reductions with '-' operator
2 static const char RCSid[] = "$Id: calexpr.c,v 2.55 2025/12/06 04:07:05 greg Exp $";
5 * Compute data values using expression parser
6 *
7 * 7/1/85 Greg Ward
8 *
9 * 11/11/85 Made channel input conditional with (INCHAN) compiles.
10 *
11 * 4/2/86 Added conditional compiles for function definitions (FUNCTION).
12 *
13 * 1/29/87 Made variables conditional (VARIABLE)
14 *
15 * 5/19/88 Added constant subexpression elimination (RCONST)
16 *
17 * 2/19/03 Eliminated conditional compiles in favor of esupport extern.
18 */
19
20 #include "copyright.h"
21
22 #include <ctype.h>
23 #include <errno.h>
24 #include <math.h>
25 #include <stdlib.h>
26
27 #include "rtmisc.h"
28 #include "rtio.h"
29 #include "rterror.h"
30 #include "calcomp.h"
31
32 #define MAXLINE 256 /* maximum line length */
33
34 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
35
36 #define isdecimal(c) (isdigit(c) | ((c) == '.'))
37
38 #define envalue(ep) ((ep)->type==NUM ? (ep)->v.num : evalue(ep))
39
40 static double euminus(EPNODE *), enumber(EPNODE *);
41 static double echannel(EPNODE *);
42 static double eadd(EPNODE *), esubtr(EPNODE *),
43 emult(EPNODE *), edivi(EPNODE *),
44 epow(EPNODE *);
45 static double ebotch(EPNODE *);
46
47 unsigned int esupport = /* what to support */
48 E_VARIABLE | E_FUNCTION ;
49
50 int eofc = 0; /* optional end-of-file character */
51 int nextc; /* lookahead character */
52
53 double (*eoper[])(EPNODE *) = { /* expression operations */
54 ebotch,
55 evariable,
56 enumber,
57 euminus,
58 echannel,
59 efunc,
60 eargument,
61 ebotch,
62 ebotch,
63 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
64 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
65 emult,
66 eadd,
67 0,
68 esubtr,
69 0,
70 edivi,
71 0,0,0,0,0,0,0,0,0,0,
72 ebotch,
73 0,0,
74 ebotch,
75 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
76 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
77 epow,
78 };
79
80 static FILE *infp; /* input file pointer */
81 static char *linbuf; /* line buffer */
82 static char *infile; /* input file name */
83 static int lineno; /* input line number */
84 static int linepos; /* position in buffer */
85
86
87 EPNODE *
88 eparse( /* parse an expression string */
89 char *expr
90 )
91 {
92 EPNODE *ep;
93
94 initstr(expr, NULL, 0);
95 ecurfunc = NULL;
96 ep = getE1();
97 if (nextc != EOF)
98 esyntax("unexpected character");
99 return(ep);
100 }
101
102
103 double
104 eval( /* evaluate an expression string */
105 char *expr
106 )
107 {
108 int prev_support = esupport;
109 EPNODE *ep;
110 double rval;
111
112 esupport &= ~E_RCONST; /* don't bother reducing constant expr */
113 ep = eparse(expr);
114 esupport = prev_support; /* as you were */
115 rval = evalue(ep);
116 epfree(ep,1);
117 return(rval);
118 }
119
120
121 int
122 epcmp( /* compare two expressions for equivalence */
123 EPNODE *ep1,
124 EPNODE *ep2
125 )
126 {
127 double d;
128
129 if (ep1->type != ep2->type)
130 return(1);
131
132 switch (ep1->type) {
133
134 case VAR:
135 return(ep1->v.ln != ep2->v.ln);
136
137 case NUM:
138 if (ep2->v.num == 0)
139 return(ep1->v.num != 0);
140 d = ep1->v.num / ep2->v.num;
141 return((d > 1.000000000001) | (d < 0.999999999999));
142
143 case CHAN:
144 case ARG:
145 return(ep1->v.chan != ep2->v.chan);
146
147 case '=':
148 case ':':
149 return(epcmp(ep1->v.kid->sibling, ep2->v.kid->sibling));
150
151 case CLKT:
152 case SYM: /* should never get this one */
153 return(0);
154
155 default:
156 ep1 = ep1->v.kid;
157 ep2 = ep2->v.kid;
158 while (ep1 != NULL) {
159 if (ep2 == NULL)
160 return(1);
161 if (epcmp(ep1, ep2))
162 return(1);
163 ep1 = ep1->sibling;
164 ep2 = ep2->sibling;
165 }
166 return(ep2 != NULL);
167 }
168 }
169
170
171 void
172 epfree( /* free a parse tree */
173 EPNODE *epar,
174 int frep
175 )
176 {
177 EPNODE *ep;
178
179 switch (epar->type) {
180
181 case VAR:
182 varfree(epar->v.ln);
183 break;
184
185 case SYM:
186 freestr(epar->v.name);
187 break;
188
189 case NUM:
190 case CHAN:
191 case ARG:
192 case CLKT:
193 break;
194
195 default:
196 if (epar->nkids < 0) {
197 ep = epar->v.kid - epar->nkids;
198 while (ep > epar->v.kid)
199 epfree(--ep, 0);
200 efree(ep); /* free array space */
201 } else
202 while ((ep = epar->v.kid) != NULL) {
203 epar->v.kid = ep->sibling;
204 epfree(ep, 1);
205 }
206 break;
207
208 }
209 if (frep)
210 efree(epar);
211 else
212 memset(epar, 0, sizeof(EPNODE));
213 }
214
215
216 static void
217 epflatten( /* flatten hierarchies for '+', '*' */
218 EPNODE *epar
219 )
220 {
221 EPNODE *ep, *ep1;
222 double combined;
223
224 if (epar->nkids <= 0) /* can't handle array allocations */
225 return;
226
227 for (ep = epar->v.kid; ep != NULL; ep = ep->sibling)
228 while ((ep->type == epar->type) & (ep->nkids > 0)) {
229 ep1 = ep->v.kid;
230 while (ep1->sibling != NULL)
231 ep1 = ep1->sibling;
232 ep1->sibling = ep->sibling;
233 epar->nkids += ep->nkids - 1;
234 ep1 = ep->v.kid;
235 *ep = *ep1;
236 efree(ep1); /* not epfree()! */
237 }
238 if (!(esupport & E_RCONST))
239 return;
240 ep1 = NULL; /* combine constants in sum/product */
241 for (ep = epar->v.kid; ep != NULL; ep = ep->sibling)
242 if (ep->type == NUM) {
243 if (ep1 == NULL) combined = (ep1 = ep)->v.num;
244 else if (epar->type == '+') combined += ep->v.num;
245 else /* epar->type=='*' */ combined *= ep->v.num;
246 }
247 if (ep1 == NULL)
248 return;
249 ep1->v.num = combined; /* assumes commutative property, also */
250 while (ep1->sibling != NULL)
251 if (ep1->sibling->type == NUM) {
252 ep = ep1->sibling;
253 ep1->sibling = ep->sibling;
254 epar->nkids--;
255 efree(ep); /* drop subsumed constant */
256 } else
257 ep1 = ep1->sibling;
258
259 if (epar->nkids == 1) { /* late constant expression? */
260 ep = epar->v.kid;
261 *epar = *ep;
262 efree(ep);
263 }
264 }
265
266
267 void
268 epoptimize( /* flatten operations, lists -> arrays */
269 EPNODE *epar
270 )
271 {
272 EPNODE *ep;
273
274 if ((epar->type == '+') | (epar->type == '*'))
275 epflatten(epar); /* flatten associative operations */
276
277 if (epar->nkids) /* do children if any */
278 for (ep = epar->v.kid; ep != NULL; ep = ep->sibling)
279 epoptimize(ep);
280
281 if (epar->nkids > 4) { /* make list into array if > 4 kids */
282 int n = 1;
283 epar->v.kid = (EPNODE *)erealloc(epar->v.kid,
284 sizeof(EPNODE)*epar->nkids);
285 while (n < epar->nkids) {
286 ep = epar->v.kid[n-1].sibling;
287 epar->v.kid[n] = *ep;
288 efree(ep); /* not epfree()! */
289 epar->v.kid[n-1].sibling = epar->v.kid + n;
290 n++;
291 }
292 epar->nkids = -n;
293 }
294 }
295
296 /* the following used to be a switch */
297 static double
298 enumber(
299 EPNODE *ep
300 )
301 {
302 return(ep->v.num);
303 }
304
305 static double
306 euminus(
307 EPNODE *ep
308 )
309 {
310 EPNODE *ep1 = ep->v.kid;
311
312 return(-evalue(ep1));
313 }
314
315 static double
316 echannel(
317 EPNODE *ep
318 )
319 {
320 return(chanvalue(ep->v.chan));
321 }
322
323 static double
324 eadd(
325 EPNODE *ep
326 )
327 {
328 double sum = 0;
329 EPNODE *ep1 = ep->v.kid;
330
331 do
332 sum += envalue(ep1);
333 while ((ep1 = ep1->sibling) != NULL);
334
335 return(sum);
336 }
337
338 static double
339 esubtr(
340 EPNODE *ep
341 )
342 {
343 EPNODE *ep1 = ep->v.kid;
344 EPNODE *ep2 = ep1->sibling;
345
346 return(envalue(ep1) - envalue(ep2));
347 }
348
349 static double
350 emult(
351 EPNODE *ep
352 )
353 {
354 double prod = 1;
355 EPNODE *ep1 = ep->v.kid;
356
357 do
358 prod *= envalue(ep1);
359 while ((ep1 = ep1->sibling) != NULL);
360
361 return(prod);
362 }
363
364 static double
365 edivi(
366 EPNODE *ep
367 )
368 {
369 EPNODE *ep1 = ep->v.kid;
370 double den = evalue(ep1->sibling);
371
372 if (den == 0.0) {
373 wputs("Division by zero\n");
374 errno = ERANGE;
375 return(0.0);
376 }
377 return(envalue(ep1) / den);
378 }
379
380 static double
381 epow(
382 EPNODE *ep
383 )
384 {
385 EPNODE *ep1 = ep->v.kid;
386 double d;
387 int lasterrno;
388
389 lasterrno = errno;
390 errno = 0;
391 d = pow(evalue(ep1), evalue(ep1->sibling));
392 #ifdef isnan
393 if (errno == 0) {
394 if (isnan(d))
395 errno = EDOM;
396 else if (isinf(d))
397 errno = ERANGE;
398 }
399 #endif
400 if ((errno == EDOM) | (errno == ERANGE)) {
401 wputs("Illegal power\n");
402 return(0.0);
403 }
404 errno = lasterrno;
405 return(d);
406 }
407
408 static double
409 ebotch(
410 EPNODE *ep
411 )
412 {
413 eputs("Bad expression!\n");
414 quit(1);
415 return 0.0; /* pro forma return */
416 }
417
418
419 EPNODE *
420 ekid( /* return pointer to a node's nth kid */
421 EPNODE *ep,
422 int n
423 )
424 {
425 if (ep->nkids < 0) { /* allocated array? */
426 if (n >= -ep->nkids)
427 return(NULL);
428 return(ep->v.kid + n);
429 }
430 ep = ep->v.kid; /* else get from list */
431 while (n-- > 0)
432 if ((ep = ep->sibling) == NULL)
433 break;
434 return(ep);
435 }
436
437
438 void
439 initfile( /* prepare input file */
440 FILE *fp,
441 char *fn,
442 int ln
443 )
444 {
445 static char inpbuf[MAXLINE];
446
447 infp = fp;
448 linbuf = inpbuf;
449 infile = fn;
450 lineno = ln;
451 linepos = 0;
452 inpbuf[0] = '\0';
453 escan();
454 }
455
456
457 void
458 initstr( /* prepare input string */
459 char *s,
460 char *fn,
461 int ln
462 )
463 {
464 infp = NULL;
465 infile = fn;
466 lineno = ln;
467 linbuf = s;
468 linepos = 0;
469 escan();
470 }
471
472
473 void
474 getscanpos( /* return current scan position */
475 char **fnp,
476 int *lnp,
477 char **spp,
478 FILE **fpp
479 )
480 {
481 if (fnp != NULL) *fnp = infile;
482 if (lnp != NULL) *lnp = lineno;
483 if (spp != NULL) *spp = linbuf+linepos;
484 if (fpp != NULL) *fpp = infp;
485 }
486
487
488 int
489 escan(void) /* scan next character, return literal next */
490 {
491 int lnext = 0;
492
493 do {
494 if (linbuf[linepos] == '\0')
495 if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL)
496 nextc = EOF;
497 else {
498 nextc = linbuf[0];
499 lineno++;
500 linepos = 1;
501 }
502 else
503 nextc = linbuf[linepos++];
504 if (!lnext)
505 lnext = nextc;
506 if (nextc == eofc) {
507 nextc = EOF;
508 break;
509 }
510 if (nextc == '{') {
511 escan();
512 while (nextc != '}')
513 if (nextc == EOF)
514 esyntax("'}' expected");
515 else
516 escan();
517 escan();
518 }
519 } while (isspace(nextc));
520 return(lnext);
521 }
522
523
524 char *
525 long2ascii( /* convert long to ascii */
526 long l
527 )
528 {
529 static char buf[16];
530 char *cp;
531 int neg = 0;
532
533 if (l == 0)
534 return("0");
535 if (l < 0) {
536 l = -l;
537 neg++;
538 }
539 cp = buf + sizeof(buf);
540 *--cp = '\0';
541 while (l) {
542 *--cp = l % 10 + '0';
543 l /= 10;
544 }
545 if (neg)
546 *--cp = '-';
547 return(cp);
548 }
549
550
551 void
552 esyntax( /* report syntax error and quit */
553 char *err
554 )
555 {
556 int i;
557
558 if ((infile != NULL) | (lineno != 0)) {
559 if (infile != NULL) eputs(infile);
560 if (lineno != 0) {
561 eputs(infile != NULL ? ", line " : "line ");
562 eputs(long2ascii((long)lineno));
563 }
564 eputs(":\n");
565 }
566 eputs(linbuf);
567 if (linbuf[strlen(linbuf)-1] != '\n')
568 eputs("\n");
569 for (i = 0; i < linepos-1; i++)
570 eputs(linbuf[i] == '\t' ? "\t" : " ");
571 eputs("^ ");
572 eputs(err);
573 eputs("\n");
574 quit(1);
575 }
576
577
578 void
579 addekid( /* add a child to ep */
580 EPNODE *ep,
581 EPNODE *ek
582 )
583 {
584 if (ep->nkids < 0) {
585 eputs("Cannot add kid to EPNODE array\n");
586 quit(1);
587 }
588 ep->nkids++;
589 if (ep->v.kid == NULL)
590 ep->v.kid = ek;
591 else {
592 for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling)
593 ;
594 ep->sibling = ek;
595 }
596 ek->sibling = NULL; /* shouldn't be necessary */
597 }
598
599
600 char *
601 getname(void) /* scan an identifier */
602 {
603 static char str[RMAXWORD+1];
604 int i, lnext;
605
606 lnext = nextc;
607 for (i = 0; i < RMAXWORD && isid(lnext); i++, lnext = escan())
608 str[i] = lnext;
609 str[i] = '\0';
610 while (isid(lnext)) /* skip rest of name */
611 lnext = escan();
612
613 return(str);
614 }
615
616
617 int
618 getinum(void) /* scan a positive integer */
619 {
620 int n, lnext;
621
622 n = 0;
623 lnext = nextc;
624 while (isdigit(lnext)) {
625 n = n * 10 + lnext - '0';
626 lnext = escan();
627 }
628 return(n);
629 }
630
631
632 double
633 getnum(void) /* scan a positive float */
634 {
635 int i, lnext;
636 char str[RMAXWORD+1];
637
638 i = 0;
639 lnext = nextc;
640 while (isdigit(lnext) && i < RMAXWORD) {
641 str[i++] = lnext;
642 lnext = escan();
643 }
644 if ((lnext == '.') & (i < RMAXWORD)) {
645 str[i++] = lnext;
646 lnext = escan();
647 if (i == 1 && !isdigit(lnext))
648 esyntax("badly formed number");
649 while (isdigit(lnext) && i < RMAXWORD) {
650 str[i++] = lnext;
651 lnext = escan();
652 }
653 }
654 if ((lnext == 'e') | (lnext == 'E') && i < RMAXWORD) {
655 str[i++] = lnext;
656 lnext = escan();
657 if ((lnext == '-') | (lnext == '+') && i < RMAXWORD) {
658 str[i++] = lnext;
659 lnext = escan();
660 }
661 if (!isdigit(lnext))
662 esyntax("missing exponent");
663 while (isdigit(lnext) && i < RMAXWORD) {
664 str[i++] = lnext;
665 lnext = escan();
666 }
667 }
668 str[i] = '\0';
669
670 return(atof(str));
671 }
672
673
674 EPNODE *
675 getE1(void) /* E1 -> E1 ADDOP E2 */
676 /* E2 */
677 {
678 EPNODE *ep1, *ep2;
679
680 ep1 = getE2();
681 while ((nextc == '+') | (nextc == '-')) {
682 ep2 = newnode();
683 ep2->type = nextc;
684 escan();
685 addekid(ep2, ep1);
686 addekid(ep2, getE2());
687 if (esupport&E_RCONST && ep1->sibling->type == NUM) {
688 if (ep1->type == NUM) {
689 ep2 = rconst(ep2);
690 } else if (ep2->type == '-') {
691 ep1->sibling->v.num *= -1;
692 ep2->type = '+'; /* associative&commutative */
693 }
694 }
695 ep1 = ep2;
696 }
697 return(ep1);
698 }
699
700
701 EPNODE *
702 getE2(void) /* E2 -> E2 MULOP E3 */
703 /* E3 */
704 {
705 EPNODE *ep1, *ep2;
706
707 ep1 = getE3();
708 while ((nextc == '*') | (nextc == '/')) {
709 ep2 = newnode();
710 ep2->type = nextc;
711 escan();
712 addekid(ep2, ep1);
713 addekid(ep2, getE3());
714 if (esupport&E_RCONST) {
715 EPNODE *ep3 = ep1->sibling;
716 if ((ep1->type == NUM) & (ep3->type == NUM)) {
717 ep2 = rconst(ep2);
718 } else if (ep3->type == NUM) {
719 if (ep2->type == '/') {
720 if (ep3->v.num == 0)
721 esyntax("divide by zero constant");
722 ep2->type = '*'; /* for speed */
723 ep3->v.num = 1./ep3->v.num;
724 } else if (ep3->v.num == 0) {
725 ep1->sibling = NULL; /* (E2 * 0) */
726 epfree(ep2,1);
727 ep2 = ep3;
728 }
729 } else if (ep1->type == NUM && ep1->v.num == 0) {
730 epfree(ep3,1); /* (0 * E3) or (0 / E3) */
731 ep1->sibling = NULL;
732 efree(ep2);
733 ep2 = ep1;
734 }
735 }
736 ep1 = ep2;
737 }
738 return(ep1);
739 }
740
741
742 EPNODE *
743 getE3(void) /* E3 -> E4 ^ E3 */
744 /* E4 */
745 {
746 EPNODE *ep1, *ep2;
747
748 ep1 = getE4();
749 if (nextc != '^')
750 return(ep1);
751 ep2 = newnode();
752 ep2->type = nextc;
753 escan();
754 addekid(ep2, ep1);
755 addekid(ep2, getE3());
756 if (esupport&E_RCONST) {
757 EPNODE *ep3 = ep1->sibling;
758 if ((ep1->type == NUM) & (ep3->type == NUM)) {
759 ep2 = rconst(ep2);
760 } else if (ep1->type == NUM && ep1->v.num == 0) {
761 epfree(ep3,1); /* (0 ^ E3) */
762 ep1->sibling = NULL;
763 efree(ep2);
764 ep2 = ep1;
765 } else if ((ep3->type == NUM && ep3->v.num == 0) |
766 (ep1->type == NUM && ep1->v.num == 1)) {
767 epfree(ep2,0); /* (E4 ^ 0) or (1 ^ E3) */
768 ep2->type = NUM;
769 ep2->v.num = 1;
770 } else if (ep3->type == NUM && ep3->v.num == 1) {
771 efree(ep3); /* (E4 ^ 1) */
772 ep1->sibling = NULL;
773 efree(ep2);
774 ep2 = ep1;
775 }
776 }
777 return(ep2);
778 }
779
780
781 EPNODE *
782 getE4(void) /* E4 -> ADDOP E5 */
783 /* E5 */
784 {
785 EPNODE *ep1, *ep2;
786
787 if (nextc == '-') {
788 escan();
789 ep2 = getE5();
790 if (ep2->type == NUM) {
791 ep2->v.num = -ep2->v.num;
792 return(ep2);
793 }
794 if (ep2->type == UMINUS) { /* don't generate -(-E5) */
795 ep1 = ep2->v.kid;
796 efree(ep2);
797 return(ep1);
798 }
799 ep1 = newnode();
800 ep1->type = UMINUS;
801 addekid(ep1, ep2);
802 return(ep1);
803 }
804 if (nextc == '+')
805 escan();
806 return(getE5());
807 }
808
809
810 EPNODE *
811 getE5(void) /* E5 -> (E1) */
812 /* VAR */
813 /* NUM */
814 /* $N */
815 /* FUNC(E1,..) */
816 /* ARG */
817 {
818 int i;
819 char *nam;
820 EPNODE *ep1, *ep2;
821
822 if (nextc == '(') {
823 escan();
824 ep1 = getE1();
825 if (nextc != ')')
826 esyntax("')' expected");
827 escan();
828 return(ep1);
829 }
830 if (esupport&E_INCHAN && nextc == '$') {
831 escan();
832 ep1 = newnode();
833 ep1->type = CHAN;
834 ep1->v.chan = getinum();
835 return(ep1);
836 }
837 if (esupport&(E_VARIABLE|E_FUNCTION) &&
838 (isalpha(nextc) | (nextc == CNTXMARK))) {
839 nam = getname();
840 ep1 = NULL;
841 if ((esupport&(E_VARIABLE|E_FUNCTION)) == (E_VARIABLE|E_FUNCTION)
842 && ecurfunc != NULL)
843 for (i = 1, ep2 = ecurfunc->v.kid->sibling;
844 ep2 != NULL; i++, ep2 = ep2->sibling)
845 if (!strcmp(ep2->v.name, nam)) {
846 ep1 = newnode();
847 ep1->type = ARG;
848 ep1->v.chan = i;
849 break;
850 }
851 if (ep1 == NULL) {
852 ep1 = newnode();
853 ep1->type = VAR;
854 ep1->v.ln = varinsert(nam);
855 }
856 if (esupport&E_FUNCTION && nextc == '(') {
857 ep2 = newnode();
858 ep2->type = FUNC;
859 addekid(ep2, ep1);
860 ep1 = ep2;
861 do {
862 escan();
863 addekid(ep1, getE1());
864 } while (nextc == ',');
865 if (nextc != ')')
866 esyntax("')' expected");
867 escan();
868 } else if (!(esupport&E_VARIABLE))
869 esyntax("'(' expected");
870 if (esupport&E_RCONST && isconstvar(ep1))
871 ep1 = rconst(ep1);
872 return(ep1);
873 }
874 if (isdecimal(nextc)) {
875 ep1 = newnode();
876 ep1->type = NUM;
877 ep1->v.num = getnum();
878 return(ep1);
879 }
880 esyntax("unexpected character");
881 return NULL; /* pro forma return */
882 }
883
884
885 EPNODE *
886 rconst( /* reduce a constant expression */
887 EPNODE *epar
888 )
889 {
890 EPNODE *ep;
891
892 ep = newnode();
893 ep->type = NUM;
894 errno = 0;
895 ep->v.num = evalue(epar);
896 if ((errno == EDOM) | (errno == ERANGE))
897 esyntax("bad constant expression");
898 epfree(epar,1);
899
900 return(ep);
901 }
902
903
904 int
905 isconstvar( /* is ep linked to a constant expression? */
906 EPNODE *ep
907 )
908 {
909 EPNODE *ep1;
910
911 if (esupport&E_FUNCTION && ep->type == FUNC) {
912 if (!isconstfun(ep->v.kid))
913 return(0);
914 for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling)
915 if (ep1->type != NUM && !isconstfun(ep1))
916 return(0);
917 return(1);
918 }
919 if (ep->type != VAR)
920 return(0);
921 ep1 = ep->v.ln->def;
922 if (ep1 == NULL || ep1->type != ':')
923 return(0);
924 if (esupport&E_FUNCTION && ep1->v.kid->type != SYM)
925 return(0);
926 return(1);
927 }
928
929
930 int
931 isconstfun( /* is ep linked to a constant function? */
932 EPNODE *ep
933 )
934 {
935 EPNODE *dp;
936 ELIBR *lp;
937
938 if (ep->type != VAR)
939 return(0);
940 if ((dp = ep->v.ln->def) != NULL) {
941 if (dp->v.kid->type == FUNC)
942 return(dp->type == ':');
943 else
944 return(0); /* don't identify masked library functions */
945 }
946 if ((lp = ep->v.ln->lib) != NULL)
947 return(lp->atyp == ':');
948 return(0);
949 }
