1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: calexpr.c,v 2.45 2024/02/24 19:11:45 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Compute data values using expression parser |
6 |
7 |
* 7/1/85 Greg Ward |
8 |
9 |
* 11/11/85 Made channel input conditional with (INCHAN) compiles. |
10 |
11 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION). |
12 |
13 |
* 1/29/87 Made variables conditional (VARIABLE) |
14 |
15 |
* 5/19/88 Added constant subexpression elimination (RCONST) |
16 |
17 |
* 2/19/03 Eliminated conditional compiles in favor of esupport extern. |
18 |
19 |
20 |
#include "copyright.h" |
21 |
22 |
#include <ctype.h> |
23 |
#include <errno.h> |
24 |
#include <math.h> |
25 |
#include <stdlib.h> |
26 |
27 |
#include "rtmisc.h" |
28 |
#include "rtio.h" |
29 |
#include "rterror.h" |
30 |
#include "calcomp.h" |
31 |
32 |
#define MAXLINE 256 /* maximum line length */ |
33 |
34 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) |
35 |
36 |
#define isdecimal(c) (isdigit(c) | ((c) == '.')) |
37 |
38 |
#define envalue(ep) ((ep)->type==NUM ? (ep)->v.num : evalue(ep)) |
39 |
40 |
static double euminus(EPNODE *), eargument(EPNODE *), enumber(EPNODE *); |
41 |
static double echannel(EPNODE *); |
42 |
static double eadd(EPNODE *), esubtr(EPNODE *), |
43 |
emult(EPNODE *), edivi(EPNODE *), |
44 |
epow(EPNODE *); |
45 |
static double ebotch(EPNODE *); |
46 |
47 |
unsigned int esupport = /* what to support */ |
48 |
E_VARIABLE | E_FUNCTION ; |
49 |
50 |
int eofc = 0; /* optional end-of-file character */ |
51 |
int nextc; /* lookahead character */ |
52 |
53 |
double (*eoper[])(EPNODE *) = { /* expression operations */ |
54 |
ebotch, |
55 |
evariable, |
56 |
enumber, |
57 |
euminus, |
58 |
echannel, |
59 |
efunc, |
60 |
eargument, |
61 |
ebotch, |
62 |
ebotch, |
63 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
64 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
65 |
emult, |
66 |
eadd, |
67 |
0, |
68 |
esubtr, |
69 |
0, |
70 |
edivi, |
71 |
72 |
ebotch, |
73 |
0,0, |
74 |
ebotch, |
75 |
76 |
77 |
epow, |
78 |
79 |
80 |
static FILE *infp; /* input file pointer */ |
81 |
static char *linbuf; /* line buffer */ |
82 |
static char *infile; /* input file name */ |
83 |
static int lineno; /* input line number */ |
84 |
static int linepos; /* position in buffer */ |
85 |
86 |
87 |
EPNODE * |
88 |
eparse( /* parse an expression string */ |
89 |
char *expr |
90 |
91 |
92 |
EPNODE *ep; |
93 |
94 |
initstr(expr, NULL, 0); |
95 |
curfunc = NULL; |
96 |
ep = getE1(); |
97 |
if (nextc != EOF) |
98 |
syntax("unexpected character"); |
99 |
return(ep); |
100 |
101 |
102 |
103 |
double |
104 |
eval( /* evaluate an expression string */ |
105 |
char *expr |
106 |
107 |
108 |
int prev_support = esupport; |
109 |
EPNODE *ep; |
110 |
double rval; |
111 |
112 |
esupport &= ~E_RCONST; /* don't bother reducing constant expr */ |
113 |
ep = eparse(expr); |
114 |
esupport = prev_support; /* as you were */ |
115 |
rval = evalue(ep); |
116 |
epfree(ep,1); |
117 |
return(rval); |
118 |
119 |
120 |
121 |
int |
122 |
epcmp( /* compare two expressions for equivalence */ |
123 |
EPNODE *ep1, |
124 |
EPNODE *ep2 |
125 |
126 |
127 |
double d; |
128 |
129 |
if (ep1->type != ep2->type) |
130 |
return(1); |
131 |
132 |
switch (ep1->type) { |
133 |
134 |
case VAR: |
135 |
return(ep1->v.ln != ep2->v.ln); |
136 |
137 |
case NUM: |
138 |
if (ep2->v.num == 0) |
139 |
return(ep1->v.num != 0); |
140 |
d = ep1->v.num / ep2->v.num; |
141 |
return((d > 1.000000000001) | (d < 0.999999999999)); |
142 |
143 |
case CHAN: |
144 |
case ARG: |
145 |
return(ep1->v.chan != ep2->v.chan); |
146 |
147 |
case '=': |
148 |
case ':': |
149 |
return(epcmp(ep1->v.kid->sibling, ep2->v.kid->sibling)); |
150 |
151 |
case CLKT: |
152 |
case SYM: /* should never get this one */ |
153 |
return(0); |
154 |
155 |
default: |
156 |
ep1 = ep1->v.kid; |
157 |
ep2 = ep2->v.kid; |
158 |
while (ep1 != NULL) { |
159 |
if (ep2 == NULL) |
160 |
return(1); |
161 |
if (epcmp(ep1, ep2)) |
162 |
return(1); |
163 |
ep1 = ep1->sibling; |
164 |
ep2 = ep2->sibling; |
165 |
166 |
return(ep2 != NULL); |
167 |
168 |
169 |
170 |
171 |
void |
172 |
epfree( /* free a parse tree */ |
173 |
EPNODE *epar, |
174 |
int frep |
175 |
176 |
177 |
EPNODE *ep; |
178 |
179 |
switch (epar->type) { |
180 |
181 |
case VAR: |
182 |
varfree(epar->v.ln); |
183 |
break; |
184 |
185 |
case SYM: |
186 |
freestr(epar->v.name); |
187 |
break; |
188 |
189 |
case NUM: |
190 |
case CHAN: |
191 |
case ARG: |
192 |
case CLKT: |
193 |
break; |
194 |
195 |
default: |
196 |
if (epar->nkids < 0) { |
197 |
ep = epar->v.kid - epar->nkids; |
198 |
while (ep > epar->v.kid) |
199 |
epfree(--ep, 0); |
200 |
efree(ep); /* free array space */ |
201 |
} else |
202 |
while ((ep = epar->v.kid) != NULL) { |
203 |
epar->v.kid = ep->sibling; |
204 |
epfree(ep, 1); |
205 |
206 |
break; |
207 |
208 |
209 |
if (frep) |
210 |
efree(epar); |
211 |
212 |
213 |
214 |
static void |
215 |
epflatten( /* flatten hierarchies for '+', '*' */ |
216 |
EPNODE *epar |
217 |
218 |
219 |
EPNODE *ep; |
220 |
221 |
if (epar->nkids < 0) /* we don't really handle this properly */ |
222 |
epar->nkids *= -1; |
223 |
224 |
for (ep = epar->v.kid; ep != NULL; ep = ep->sibling) |
225 |
while (ep->type == epar->type) { |
226 |
EPNODE *ep1 = ep->v.kid; |
227 |
while (ep1->sibling != NULL) |
228 |
229 |
ep1->sibling = ep->sibling; |
230 |
epar->nkids += nekids(ep) - 1; |
231 |
ep1 = ep->v.kid; |
232 |
*ep = *ep1; |
233 |
efree(ep1); /* not epfree()! */ |
234 |
235 |
236 |
237 |
238 |
void |
239 |
epoptimize( /* flatten operations and lists -> arrays */ |
240 |
EPNODE *epar |
241 |
242 |
243 |
EPNODE *ep; |
244 |
245 |
if ((epar->type == '+') | (epar->type == '*')) |
246 |
epflatten(epar); /* commutative & associative */ |
247 |
248 |
if (epar->nkids) /* do children if any */ |
249 |
250 |
epoptimize(ep); |
251 |
252 |
if (epar->nkids > 4) { /* make list into array if > 4 kids */ |
253 |
int n = 1; |
254 |
epar->v.kid = (EPNODE *)erealloc(epar->v.kid, |
255 |
sizeof(EPNODE)*epar->nkids); |
256 |
while (n < epar->nkids) { |
257 |
ep = epar->v.kid[n-1].sibling; |
258 |
epar->v.kid[n] = *ep; |
259 |
efree(ep); /* not epfree()! */ |
260 |
epar->v.kid[n-1].sibling = epar->v.kid + n; |
261 |
n++; |
262 |
263 |
epar->nkids = -n; |
264 |
265 |
266 |
267 |
/* the following used to be a switch */ |
268 |
static double |
269 |
eargument( |
270 |
EPNODE *ep |
271 |
272 |
273 |
return(argument(ep->v.chan)); |
274 |
275 |
276 |
static double |
277 |
enumber( |
278 |
EPNODE *ep |
279 |
280 |
281 |
return(ep->v.num); |
282 |
283 |
284 |
static double |
285 |
euminus( |
286 |
EPNODE *ep |
287 |
288 |
289 |
290 |
291 |
return(-evalue(ep1)); |
292 |
293 |
294 |
static double |
295 |
echannel( |
296 |
EPNODE *ep |
297 |
298 |
299 |
return(chanvalue(ep->v.chan)); |
300 |
301 |
302 |
static double |
303 |
eadd( |
304 |
EPNODE *ep |
305 |
306 |
307 |
double sum = 0; |
308 |
309 |
310 |
do |
311 |
sum += envalue(ep1); |
312 |
while ((ep1 = ep1->sibling) != NULL); |
313 |
314 |
return(sum); |
315 |
316 |
317 |
static double |
318 |
esubtr( |
319 |
EPNODE *ep |
320 |
321 |
322 |
323 |
EPNODE *ep2 = ep1->sibling; |
324 |
325 |
return(envalue(ep1) - envalue(ep2)); |
326 |
327 |
328 |
static double |
329 |
emult( |
330 |
EPNODE *ep |
331 |
332 |
333 |
double prod = 1; |
334 |
335 |
336 |
do |
337 |
prod *= envalue(ep1); |
338 |
339 |
340 |
return(prod); |
341 |
342 |
343 |
static double |
344 |
edivi( |
345 |
EPNODE *ep |
346 |
347 |
348 |
349 |
350 |
double d; |
351 |
352 |
d = evalue(ep2); |
353 |
if (d == 0.0) { |
354 |
wputs("Division by zero\n"); |
355 |
errno = ERANGE; |
356 |
return(0.0); |
357 |
358 |
return(envalue(ep1) / d); |
359 |
360 |
361 |
static double |
362 |
epow( |
363 |
EPNODE *ep |
364 |
365 |
366 |
367 |
double d; |
368 |
int lasterrno; |
369 |
370 |
lasterrno = errno; |
371 |
errno = 0; |
372 |
d = pow(evalue(ep1), evalue(ep1->sibling)); |
373 |
#ifdef isnan |
374 |
if (errno == 0) { |
375 |
if (isnan(d)) |
376 |
errno = EDOM; |
377 |
else if (isinf(d)) |
378 |
errno = ERANGE; |
379 |
380 |
#endif |
381 |
if ((errno == EDOM) | (errno == ERANGE)) { |
382 |
wputs("Illegal power\n"); |
383 |
return(0.0); |
384 |
385 |
errno = lasterrno; |
386 |
return(d); |
387 |
388 |
389 |
static double |
390 |
ebotch( |
391 |
EPNODE *ep |
392 |
393 |
394 |
eputs("Bad expression!\n"); |
395 |
quit(1); |
396 |
return 0.0; /* pro forma return */ |
397 |
398 |
399 |
400 |
EPNODE * |
401 |
ekid( /* return pointer to a node's nth kid */ |
402 |
EPNODE *ep, |
403 |
int n |
404 |
405 |
406 |
if (ep->nkids < 0) { /* allocated array? */ |
407 |
if (n >= -ep->nkids) |
408 |
return(NULL); |
409 |
return(ep->v.kid + n); |
410 |
411 |
ep = ep->v.kid; /* else get from list */ |
412 |
while (n-- > 0) |
413 |
if ((ep = ep->sibling) == NULL) |
414 |
break; |
415 |
return(ep); |
416 |
417 |
418 |
419 |
void |
420 |
initfile( /* prepare input file */ |
421 |
FILE *fp, |
422 |
char *fn, |
423 |
int ln |
424 |
425 |
426 |
static char inpbuf[MAXLINE]; |
427 |
428 |
infp = fp; |
429 |
linbuf = inpbuf; |
430 |
infile = fn; |
431 |
lineno = ln; |
432 |
linepos = 0; |
433 |
inpbuf[0] = '\0'; |
434 |
scan(); |
435 |
436 |
437 |
438 |
void |
439 |
initstr( /* prepare input string */ |
440 |
char *s, |
441 |
char *fn, |
442 |
int ln |
443 |
444 |
445 |
infp = NULL; |
446 |
infile = fn; |
447 |
lineno = ln; |
448 |
linbuf = s; |
449 |
linepos = 0; |
450 |
scan(); |
451 |
452 |
453 |
454 |
void |
455 |
getscanpos( /* return current scan position */ |
456 |
char **fnp, |
457 |
int *lnp, |
458 |
char **spp, |
459 |
FILE **fpp |
460 |
461 |
462 |
if (fnp != NULL) *fnp = infile; |
463 |
if (lnp != NULL) *lnp = lineno; |
464 |
if (spp != NULL) *spp = linbuf+linepos; |
465 |
if (fpp != NULL) *fpp = infp; |
466 |
467 |
468 |
469 |
int |
470 |
scan(void) /* scan next character, return literal next */ |
471 |
472 |
int lnext = 0; |
473 |
474 |
do { |
475 |
if (linbuf[linepos] == '\0') |
476 |
if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL) |
477 |
nextc = EOF; |
478 |
else { |
479 |
nextc = linbuf[0]; |
480 |
lineno++; |
481 |
linepos = 1; |
482 |
483 |
else |
484 |
nextc = linbuf[linepos++]; |
485 |
if (!lnext) |
486 |
lnext = nextc; |
487 |
if (nextc == eofc) { |
488 |
nextc = EOF; |
489 |
break; |
490 |
491 |
if (nextc == '{') { |
492 |
scan(); |
493 |
while (nextc != '}') |
494 |
if (nextc == EOF) |
495 |
syntax("'}' expected"); |
496 |
else |
497 |
scan(); |
498 |
scan(); |
499 |
500 |
} while (isspace(nextc)); |
501 |
return(lnext); |
502 |
503 |
504 |
505 |
char * |
506 |
long2ascii( /* convert long to ascii */ |
507 |
long l |
508 |
509 |
510 |
static char buf[16]; |
511 |
char *cp; |
512 |
int neg = 0; |
513 |
514 |
if (l == 0) |
515 |
return("0"); |
516 |
if (l < 0) { |
517 |
l = -l; |
518 |
neg++; |
519 |
520 |
cp = buf + sizeof(buf); |
521 |
*--cp = '\0'; |
522 |
while (l) { |
523 |
*--cp = l % 10 + '0'; |
524 |
l /= 10; |
525 |
526 |
if (neg) |
527 |
*--cp = '-'; |
528 |
return(cp); |
529 |
530 |
531 |
532 |
void |
533 |
syntax( /* report syntax error and quit */ |
534 |
char *err |
535 |
536 |
537 |
int i; |
538 |
539 |
if ((infile != NULL) | (lineno != 0)) { |
540 |
if (infile != NULL) eputs(infile); |
541 |
if (lineno != 0) { |
542 |
eputs(infile != NULL ? ", line " : "line "); |
543 |
eputs(long2ascii((long)lineno)); |
544 |
545 |
eputs(":\n"); |
546 |
547 |
eputs(linbuf); |
548 |
if (linbuf[strlen(linbuf)-1] != '\n') |
549 |
eputs("\n"); |
550 |
for (i = 0; i < linepos-1; i++) |
551 |
eputs(linbuf[i] == '\t' ? "\t" : " "); |
552 |
eputs("^ "); |
553 |
eputs(err); |
554 |
eputs("\n"); |
555 |
quit(1); |
556 |
557 |
558 |
559 |
void |
560 |
addekid( /* add a child to ep */ |
561 |
EPNODE *ep, |
562 |
EPNODE *ek |
563 |
564 |
565 |
if (ep->nkids < 0) /* we don't really handle this properly */ |
566 |
ep->nkids *= -1; |
567 |
ep->nkids++; |
568 |
if (ep->v.kid == NULL) |
569 |
ep->v.kid = ek; |
570 |
else { |
571 |
for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling) |
572 |
573 |
ep->sibling = ek; |
574 |
575 |
ek->sibling = NULL; /* shouldn't be necessary */ |
576 |
577 |
578 |
579 |
char * |
580 |
getname(void) /* scan an identifier */ |
581 |
582 |
static char str[RMAXWORD+1]; |
583 |
int i, lnext; |
584 |
585 |
lnext = nextc; |
586 |
for (i = 0; i < RMAXWORD && isid(lnext); i++, lnext = scan()) |
587 |
str[i] = lnext; |
588 |
str[i] = '\0'; |
589 |
while (isid(lnext)) /* skip rest of name */ |
590 |
lnext = scan(); |
591 |
592 |
return(str); |
593 |
594 |
595 |
596 |
int |
597 |
getinum(void) /* scan a positive integer */ |
598 |
599 |
int n, lnext; |
600 |
601 |
n = 0; |
602 |
lnext = nextc; |
603 |
while (isdigit(lnext)) { |
604 |
n = n * 10 + lnext - '0'; |
605 |
lnext = scan(); |
606 |
607 |
return(n); |
608 |
609 |
610 |
611 |
double |
612 |
getnum(void) /* scan a positive float */ |
613 |
614 |
int i, lnext; |
615 |
616 |
617 |
i = 0; |
618 |
lnext = nextc; |
619 |
while (isdigit(lnext) && i < RMAXWORD) { |
620 |
str[i++] = lnext; |
621 |
lnext = scan(); |
622 |
623 |
if ((lnext == '.') & (i < RMAXWORD)) { |
624 |
str[i++] = lnext; |
625 |
lnext = scan(); |
626 |
if (i == 1 && !isdigit(lnext)) |
627 |
syntax("badly formed number"); |
628 |
629 |
str[i++] = lnext; |
630 |
lnext = scan(); |
631 |
632 |
633 |
if ((lnext == 'e') | (lnext == 'E') && i < RMAXWORD) { |
634 |
str[i++] = lnext; |
635 |
lnext = scan(); |
636 |
if ((lnext == '-') | (lnext == '+') && i < RMAXWORD) { |
637 |
str[i++] = lnext; |
638 |
lnext = scan(); |
639 |
640 |
if (!isdigit(lnext)) |
641 |
syntax("missing exponent"); |
642 |
643 |
str[i++] = lnext; |
644 |
lnext = scan(); |
645 |
646 |
647 |
str[i] = '\0'; |
648 |
649 |
return(atof(str)); |
650 |
651 |
652 |
653 |
EPNODE * |
654 |
getE1(void) /* E1 -> E1 ADDOP E2 */ |
655 |
/* E2 */ |
656 |
657 |
EPNODE *ep1, *ep2; |
658 |
659 |
ep1 = getE2(); |
660 |
while ((nextc == '+') | (nextc == '-')) { |
661 |
ep2 = newnode(); |
662 |
ep2->type = nextc; |
663 |
scan(); |
664 |
addekid(ep2, ep1); |
665 |
addekid(ep2, getE2()); |
666 |
if (esupport&E_RCONST && |
667 |
(ep1->type == NUM) & (ep1->sibling->type == NUM)) |
668 |
ep2 = rconst(ep2); |
669 |
ep1 = ep2; |
670 |
671 |
return(ep1); |
672 |
673 |
674 |
675 |
EPNODE * |
676 |
getE2(void) /* E2 -> E2 MULOP E3 */ |
677 |
/* E3 */ |
678 |
679 |
680 |
681 |
ep1 = getE3(); |
682 |
while ((nextc == '*') | (nextc == '/')) { |
683 |
ep2 = newnode(); |
684 |
685 |
scan(); |
686 |
687 |
addekid(ep2, getE3()); |
688 |
if (esupport&E_RCONST) { |
689 |
EPNODE *ep3 = ep1->sibling; |
690 |
if ((ep1->type == NUM) & (ep3->type == NUM)) { |
691 |
692 |
} else if (ep3->type == NUM) { |
693 |
if (ep2->type == '/') { |
694 |
if (ep3->v.num == 0) |
695 |
syntax("divide by zero constant"); |
696 |
ep2->type = '*'; /* for speed */ |
697 |
ep3->v.num = 1./ep3->v.num; |
698 |
} else if (ep3->v.num == 0) { |
699 |
ep1->sibling = NULL; /* (E2 * 0) */ |
700 |
epfree(ep2,1); |
701 |
ep2 = ep3; |
702 |
703 |
} else if (ep1->type == NUM && ep1->v.num == 0) { |
704 |
epfree(ep3,1); /* (0 * E3) or (0 / E3) */ |
705 |
ep1->sibling = NULL; |
706 |
efree(ep2); |
707 |
ep2 = ep1; |
708 |
709 |
710 |
ep1 = ep2; |
711 |
712 |
return(ep1); |
713 |
714 |
715 |
716 |
EPNODE * |
717 |
getE3(void) /* E3 -> E4 ^ E3 */ |
718 |
/* E4 */ |
719 |
720 |
721 |
722 |
ep1 = getE4(); |
723 |
if (nextc != '^') |
724 |
return(ep1); |
725 |
ep2 = newnode(); |
726 |
727 |
scan(); |
728 |
729 |
730 |
731 |
732 |
733 |
734 |
735 |
epfree(ep3,1); /* (0 ^ E3) */ |
736 |
737 |
efree(ep2); |
738 |
ep2 = ep1; |
739 |
} else if ((ep3->type == NUM && ep3->v.num == 0) | |
740 |
(ep1->type == NUM && ep1->v.num == 1)) { |
741 |
epfree(ep2,1); /* (E4 ^ 0) or (1 ^ E3) */ |
742 |
ep2 = newnode(); |
743 |
ep2->type = NUM; |
744 |
ep2->v.num = 1; |
745 |
} else if (ep3->type == NUM && ep3->v.num == 1) { |
746 |
efree(ep3); /* (E4 ^ 1) */ |
747 |
748 |
efree(ep2); |
749 |
ep2 = ep1; |
750 |
751 |
752 |
return(ep2); |
753 |
754 |
755 |
756 |
EPNODE * |
757 |
getE4(void) /* E4 -> ADDOP E5 */ |
758 |
/* E5 */ |
759 |
760 |
761 |
762 |
if (nextc == '-') { |
763 |
scan(); |
764 |
ep2 = getE5(); |
765 |
if (ep2->type == NUM) { |
766 |
ep2->v.num = -ep2->v.num; |
767 |
return(ep2); |
768 |
769 |
if (ep2->type == UMINUS) { /* don't generate -(-E5) */ |
770 |
ep1 = ep2->v.kid; |
771 |
efree(ep2); |
772 |
return(ep1); |
773 |
774 |
ep1 = newnode(); |
775 |
ep1->type = UMINUS; |
776 |
addekid(ep1, ep2); |
777 |
return(ep1); |
778 |
779 |
if (nextc == '+') |
780 |
scan(); |
781 |
return(getE5()); |
782 |
783 |
784 |
785 |
EPNODE * |
786 |
getE5(void) /* E5 -> (E1) */ |
787 |
/* VAR */ |
788 |
/* NUM */ |
789 |
/* $N */ |
790 |
/* FUNC(E1,..) */ |
791 |
/* ARG */ |
792 |
793 |
int i; |
794 |
char *nam; |
795 |
796 |
797 |
if (nextc == '(') { |
798 |
scan(); |
799 |
ep1 = getE1(); |
800 |
if (nextc != ')') |
801 |
syntax("')' expected"); |
802 |
scan(); |
803 |
return(ep1); |
804 |
805 |
if (esupport&E_INCHAN && nextc == '$') { |
806 |
scan(); |
807 |
ep1 = newnode(); |
808 |
ep1->type = CHAN; |
809 |
ep1->v.chan = getinum(); |
810 |
return(ep1); |
811 |
812 |
if (esupport&(E_VARIABLE|E_FUNCTION) && |
813 |
(isalpha(nextc) | (nextc == CNTXMARK))) { |
814 |
nam = getname(); |
815 |
ep1 = NULL; |
816 |
if ((esupport&(E_VARIABLE|E_FUNCTION)) == (E_VARIABLE|E_FUNCTION) |
817 |
&& curfunc != NULL) |
818 |
for (i = 1, ep2 = curfunc->v.kid->sibling; |
819 |
ep2 != NULL; i++, ep2 = ep2->sibling) |
820 |
if (!strcmp(ep2->v.name, nam)) { |
821 |
ep1 = newnode(); |
822 |
ep1->type = ARG; |
823 |
ep1->v.chan = i; |
824 |
break; |
825 |
826 |
if (ep1 == NULL) { |
827 |
ep1 = newnode(); |
828 |
ep1->type = VAR; |
829 |
ep1->v.ln = varinsert(nam); |
830 |
831 |
if (esupport&E_FUNCTION && nextc == '(') { |
832 |
ep2 = newnode(); |
833 |
ep2->type = FUNC; |
834 |
835 |
ep1 = ep2; |
836 |
do { |
837 |
scan(); |
838 |
addekid(ep1, getE1()); |
839 |
} while (nextc == ','); |
840 |
if (nextc != ')') |
841 |
842 |
scan(); |
843 |
} else if (!(esupport&E_VARIABLE)) |
844 |
syntax("'(' expected"); |
845 |
if (esupport&E_RCONST && isconstvar(ep1)) |
846 |
ep1 = rconst(ep1); |
847 |
return(ep1); |
848 |
849 |
if (isdecimal(nextc)) { |
850 |
ep1 = newnode(); |
851 |
ep1->type = NUM; |
852 |
ep1->v.num = getnum(); |
853 |
return(ep1); |
854 |
855 |
856 |
return NULL; /* pro forma return */ |
857 |
858 |
859 |
860 |
EPNODE * |
861 |
rconst( /* reduce a constant expression */ |
862 |
EPNODE *epar |
863 |
864 |
865 |
EPNODE *ep; |
866 |
867 |
ep = newnode(); |
868 |
ep->type = NUM; |
869 |
errno = 0; |
870 |
ep->v.num = evalue(epar); |
871 |
if ((errno == EDOM) | (errno == ERANGE)) |
872 |
syntax("bad constant expression"); |
873 |
epfree(epar,1); |
874 |
875 |
return(ep); |
876 |
877 |
878 |
879 |
int |
880 |
isconstvar( /* is ep linked to a constant expression? */ |
881 |
EPNODE *ep |
882 |
883 |
884 |
EPNODE *ep1; |
885 |
886 |
if (esupport&E_FUNCTION && ep->type == FUNC) { |
887 |
if (!isconstfun(ep->v.kid)) |
888 |
return(0); |
889 |
for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling) |
890 |
if (ep1->type != NUM && !isconstfun(ep1)) |
891 |
return(0); |
892 |
return(1); |
893 |
894 |
if (ep->type != VAR) |
895 |
return(0); |
896 |
ep1 = ep->v.ln->def; |
897 |
if (ep1 == NULL || ep1->type != ':') |
898 |
return(0); |
899 |
if (esupport&E_FUNCTION && ep1->v.kid->type != SYM) |
900 |
return(0); |
901 |
return(1); |
902 |
903 |
904 |
905 |
int |
906 |
isconstfun( /* is ep linked to a constant function? */ |
907 |
EPNODE *ep |
908 |
909 |
910 |
EPNODE *dp; |
911 |
LIBR *lp; |
912 |
913 |
914 |
return(0); |
915 |
if ((dp = ep->v.ln->def) != NULL) { |
916 |
if (dp->v.kid->type == FUNC) |
917 |
return(dp->type == ':'); |
918 |
else |
919 |
return(0); /* don't identify masked library functions */ |
920 |
921 |
if ((lp = ep->v.ln->lib) != NULL) |
922 |
return(lp->atyp == ':'); |
923 |
return(0); |
924 |
