1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Compute data values using expression parser |
9 |
10 |
* 7/1/85 Greg Ward |
11 |
12 |
* 11/11/85 Made channel input conditional with (INCHAN) compiles. |
13 |
14 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION). |
15 |
16 |
* 1/29/87 Made variables conditional (VARIABLE) |
17 |
18 |
* 5/19/88 Added constant subexpression elimination (RCONST) |
19 |
20 |
21 |
#include <stdio.h> |
22 |
23 |
#include <ctype.h> |
24 |
25 |
#include <errno.h> |
26 |
27 |
#include "calcomp.h" |
28 |
29 |
#define MAXLINE 256 /* maximum line length */ |
30 |
31 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) |
32 |
33 |
#define isdecimal(c) (isdigit(c) || (c) == '.') |
34 |
35 |
extern double atof(), pow(); |
36 |
extern char *fgets(), *savestr(); |
37 |
extern char *emalloc(), *ecalloc(); |
38 |
extern EPNODE *curfunc; |
39 |
extern double efunc(), evariable(); |
40 |
static double euminus(), echannel(), eargument(), enumber(); |
41 |
static double eadd(), esubtr(), emult(), edivi(), epow(); |
42 |
static double ebotch(); |
43 |
extern int errno; |
44 |
45 |
int nextc; /* lookahead character */ |
46 |
47 |
double (*eoper[])() = { /* expression operations */ |
48 |
ebotch, |
49 |
#ifdef VARIABLE |
50 |
evariable, |
51 |
#else |
52 |
ebotch, |
53 |
#endif |
54 |
enumber, |
55 |
euminus, |
56 |
#ifdef INCHAN |
57 |
echannel, |
58 |
#else |
59 |
ebotch, |
60 |
#endif |
61 |
#ifdef FUNCTION |
62 |
efunc, |
63 |
eargument, |
64 |
#else |
65 |
ebotch, |
66 |
ebotch, |
67 |
#endif |
68 |
ebotch, |
69 |
ebotch, |
70 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
71 |
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, |
72 |
emult, |
73 |
eadd, |
74 |
0, |
75 |
esubtr, |
76 |
0, |
77 |
edivi, |
78 |
79 |
ebotch, |
80 |
0,0, |
81 |
ebotch, |
82 |
83 |
84 |
epow, |
85 |
86 |
87 |
static FILE *infp; /* input file pointer */ |
88 |
static char *linbuf; /* line buffer */ |
89 |
static char *infile; /* input file name */ |
90 |
static int lineno; /* input line number */ |
91 |
static int linepos; /* position in buffer */ |
92 |
93 |
94 |
EPNODE * |
95 |
eparse(expr) /* parse an expression string */ |
96 |
char *expr; |
97 |
98 |
EPNODE *ep; |
99 |
100 |
initstr(expr, NULL, 0); |
101 |
#if defined(VARIABLE) && defined(FUNCTION) |
102 |
curfunc = NULL; |
103 |
#endif |
104 |
ep = getE1(); |
105 |
if (nextc != EOF) |
106 |
syntax("unexpected character"); |
107 |
return(ep); |
108 |
109 |
110 |
111 |
double |
112 |
eval(expr) /* evaluate an expression string */ |
113 |
char *expr; |
114 |
115 |
register EPNODE *ep; |
116 |
double rval; |
117 |
118 |
ep = eparse(expr); |
119 |
rval = evalue(ep); |
120 |
epfree(ep); |
121 |
return(rval); |
122 |
123 |
124 |
125 |
epfree(epar) /* free a parse tree */ |
126 |
register EPNODE *epar; |
127 |
128 |
129 |
130 |
switch (epar->type) { |
131 |
132 |
#if defined(VARIABLE) || defined(FUNCTION) |
133 |
case VAR: |
134 |
varfree(epar->v.ln); |
135 |
break; |
136 |
#endif |
137 |
138 |
case SYM: |
139 |
freestr(epar->v.name); |
140 |
break; |
141 |
142 |
case NUM: |
143 |
case CHAN: |
144 |
case ARG: |
145 |
case TICK: |
146 |
break; |
147 |
148 |
default: |
149 |
for (ep = epar->v.kid; ep != NULL; ep = ep->sibling) |
150 |
epfree(ep); |
151 |
break; |
152 |
153 |
154 |
155 |
efree((char *)epar); |
156 |
157 |
158 |
/* the following used to be a switch */ |
159 |
#ifdef FUNCTION |
160 |
static double |
161 |
eargument(ep) |
162 |
EPNODE *ep; |
163 |
164 |
return(argument(ep->v.chan)); |
165 |
166 |
#endif |
167 |
168 |
static double |
169 |
enumber(ep) |
170 |
EPNODE *ep; |
171 |
172 |
return(ep->v.num); |
173 |
174 |
175 |
static double |
176 |
euminus(ep) |
177 |
EPNODE *ep; |
178 |
179 |
register EPNODE *ep1 = ep->v.kid; |
180 |
181 |
return(-evalue(ep1)); |
182 |
183 |
184 |
#ifdef INCHAN |
185 |
static double |
186 |
echannel(ep) |
187 |
EPNODE *ep; |
188 |
189 |
return(chanvalue(ep->v.chan)); |
190 |
191 |
#endif |
192 |
193 |
static double |
194 |
eadd(ep) |
195 |
EPNODE *ep; |
196 |
197 |
198 |
199 |
return(evalue(ep1) + evalue(ep1->sibling)); |
200 |
201 |
202 |
static double |
203 |
esubtr(ep) |
204 |
EPNODE *ep; |
205 |
206 |
207 |
208 |
return(evalue(ep1) - evalue(ep1->sibling)); |
209 |
210 |
211 |
static double |
212 |
emult(ep) |
213 |
EPNODE *ep; |
214 |
215 |
216 |
217 |
return(evalue(ep1) * evalue(ep1->sibling)); |
218 |
219 |
220 |
static double |
221 |
edivi(ep) |
222 |
EPNODE *ep; |
223 |
224 |
225 |
double d; |
226 |
227 |
d = evalue(ep1->sibling); |
228 |
if (d == 0.0) { |
229 |
wputs("Division by zero\n"); |
230 |
errno = ERANGE; |
231 |
return(0.0); |
232 |
233 |
return(evalue(ep1) / d); |
234 |
235 |
236 |
static double |
237 |
epow(ep) |
238 |
EPNODE *ep; |
239 |
240 |
241 |
double d; |
242 |
int lasterrno; |
243 |
244 |
lasterrno = errno; |
245 |
errno = 0; |
246 |
d = pow(evalue(ep1), evalue(ep1->sibling)); |
247 |
#ifdef IEEE |
248 |
if (!finite(d)) |
249 |
errno = EDOM; |
250 |
#endif |
251 |
if (errno) { |
252 |
wputs("Illegal power\n"); |
253 |
return(0.0); |
254 |
255 |
errno = lasterrno; |
256 |
return(d); |
257 |
258 |
259 |
static double |
260 |
ebotch(ep) |
261 |
EPNODE *ep; |
262 |
263 |
eputs("Bad expression!\n"); |
264 |
quit(1); |
265 |
266 |
267 |
268 |
EPNODE * |
269 |
ekid(ep, n) /* return pointer to a node's nth kid */ |
270 |
271 |
register int n; |
272 |
273 |
274 |
for (ep = ep->v.kid; ep != NULL; ep = ep->sibling) |
275 |
if (--n < 0) |
276 |
break; |
277 |
278 |
return(ep); |
279 |
280 |
281 |
282 |
int |
283 |
nekids(ep) /* return # of kids for node ep */ |
284 |
285 |
286 |
register int n = 0; |
287 |
288 |
289 |
n++; |
290 |
291 |
return(n); |
292 |
293 |
294 |
295 |
initfile(fp, fn, ln) /* prepare input file */ |
296 |
FILE *fp; |
297 |
char *fn; |
298 |
int ln; |
299 |
300 |
static char inpbuf[MAXLINE]; |
301 |
302 |
infp = fp; |
303 |
linbuf = inpbuf; |
304 |
infile = fn; |
305 |
lineno = ln; |
306 |
linepos = 0; |
307 |
inpbuf[0] = '\0'; |
308 |
scan(); |
309 |
310 |
311 |
312 |
initstr(s, fn, ln) /* prepare input string */ |
313 |
char *s; |
314 |
char *fn; |
315 |
int ln; |
316 |
317 |
infp = NULL; |
318 |
infile = fn; |
319 |
lineno = ln; |
320 |
linbuf = s; |
321 |
linepos = 0; |
322 |
scan(); |
323 |
324 |
325 |
326 |
getscanpos(fnp, lnp, spp, fpp) /* return current scan position */ |
327 |
char **fnp; |
328 |
int *lnp; |
329 |
char **spp; |
330 |
FILE **fpp; |
331 |
332 |
if (fnp != NULL) *fnp = infile; |
333 |
if (lnp != NULL) *lnp = lineno; |
334 |
if (spp != NULL) *spp = linbuf+linepos; |
335 |
if (fpp != NULL) *fpp = infp; |
336 |
337 |
338 |
339 |
int |
340 |
scan() /* scan next character, return literal next */ |
341 |
342 |
register int lnext = 0; |
343 |
344 |
do { |
345 |
if (linbuf[linepos] == '\0') |
346 |
if (infp == NULL || fgets(linbuf, MAXLINE, infp) == NULL) |
347 |
nextc = EOF; |
348 |
else { |
349 |
nextc = linbuf[0]; |
350 |
lineno++; |
351 |
linepos = 1; |
352 |
353 |
else |
354 |
nextc = linbuf[linepos++]; |
355 |
if (!lnext) |
356 |
lnext = nextc; |
357 |
if (nextc == '{') { |
358 |
scan(); |
359 |
while (nextc != '}') |
360 |
if (nextc == EOF) |
361 |
syntax("'}' expected"); |
362 |
else |
363 |
scan(); |
364 |
scan(); |
365 |
366 |
} while (isspace(nextc)); |
367 |
return(lnext); |
368 |
369 |
370 |
371 |
char * |
372 |
ltoa(l) /* convert long to ascii */ |
373 |
long l; |
374 |
375 |
static char buf[16]; |
376 |
register char *cp; |
377 |
int neg = 0; |
378 |
379 |
if (l == 0) |
380 |
return("0"); |
381 |
if (l < 0) { |
382 |
l = -l; |
383 |
neg++; |
384 |
385 |
cp = buf + sizeof(buf); |
386 |
*--cp = '\0'; |
387 |
while (l) { |
388 |
*--cp = l % 10 + '0'; |
389 |
l /= 10; |
390 |
391 |
if (neg) |
392 |
*--cp = '-'; |
393 |
return(cp); |
394 |
395 |
396 |
397 |
syntax(err) /* report syntax error and quit */ |
398 |
char *err; |
399 |
400 |
register int i; |
401 |
402 |
if (infile != NULL || lineno != 0) { |
403 |
if (infile != NULL) eputs(infile); |
404 |
if (lineno != 0) { |
405 |
eputs(infile != NULL ? ", line " : "line "); |
406 |
eputs(ltoa((long)lineno)); |
407 |
408 |
eputs(": syntax error:\n"); |
409 |
410 |
eputs(linbuf); |
411 |
if (linbuf[strlen(linbuf)-1] != '\n') |
412 |
eputs("\n"); |
413 |
for (i = 0; i < linepos-1; i++) |
414 |
eputs(linbuf[i] == '\t' ? "\t" : " "); |
415 |
eputs("^ "); |
416 |
eputs(err); |
417 |
eputs("\n"); |
418 |
quit(1); |
419 |
420 |
421 |
422 |
addekid(ep, ekid) /* add a child to ep */ |
423 |
424 |
EPNODE *ekid; |
425 |
426 |
if (ep->v.kid == NULL) |
427 |
ep->v.kid = ekid; |
428 |
else { |
429 |
for (ep = ep->v.kid; ep->sibling != NULL; ep = ep->sibling) |
430 |
431 |
ep->sibling = ekid; |
432 |
433 |
ekid->sibling = NULL; |
434 |
435 |
436 |
437 |
char * |
438 |
getname() /* scan an identifier */ |
439 |
440 |
static char str[MAXWORD+1]; |
441 |
register int i, lnext; |
442 |
443 |
lnext = nextc; |
444 |
for (i = 0; i < MAXWORD && isid(lnext); i++, lnext = scan()) |
445 |
str[i] = lnext; |
446 |
str[i] = '\0'; |
447 |
while (isid(lnext)) /* skip rest of name */ |
448 |
lnext = scan(); |
449 |
450 |
return(str); |
451 |
452 |
453 |
454 |
int |
455 |
getinum() /* scan a positive integer */ |
456 |
457 |
register int n, lnext; |
458 |
459 |
n = 0; |
460 |
lnext = nextc; |
461 |
while (isdigit(lnext)) { |
462 |
n = n * 10 + lnext - '0'; |
463 |
lnext = scan(); |
464 |
465 |
return(n); |
466 |
467 |
468 |
469 |
double |
470 |
getnum() /* scan a positive float */ |
471 |
472 |
473 |
474 |
475 |
i = 0; |
476 |
lnext = nextc; |
477 |
while (isdigit(lnext) && i < MAXWORD) { |
478 |
str[i++] = lnext; |
479 |
lnext = scan(); |
480 |
481 |
if (lnext == '.' && i < MAXWORD) { |
482 |
str[i++] = lnext; |
483 |
lnext = scan(); |
484 |
485 |
str[i++] = lnext; |
486 |
lnext = scan(); |
487 |
488 |
489 |
if ((lnext == 'e' || lnext == 'E') && i < MAXWORD) { |
490 |
str[i++] = lnext; |
491 |
lnext = scan(); |
492 |
if ((lnext == '-' || lnext == '+') && i < MAXWORD) { |
493 |
str[i++] = lnext; |
494 |
lnext = scan(); |
495 |
496 |
497 |
str[i++] = lnext; |
498 |
lnext = scan(); |
499 |
500 |
501 |
str[i] = '\0'; |
502 |
503 |
return(atof(str)); |
504 |
505 |
506 |
507 |
EPNODE * |
508 |
getE1() /* E1 -> E1 ADDOP E2 */ |
509 |
/* E2 */ |
510 |
511 |
register EPNODE *ep1, *ep2; |
512 |
513 |
ep1 = getE2(); |
514 |
while (nextc == '+' || nextc == '-') { |
515 |
ep2 = newnode(); |
516 |
ep2->type = nextc; |
517 |
scan(); |
518 |
addekid(ep2, ep1); |
519 |
addekid(ep2, getE2()); |
520 |
#ifdef RCONST |
521 |
if (ep1->type == NUM && ep1->sibling->type == NUM) |
522 |
ep2 = rconst(ep2); |
523 |
#endif |
524 |
ep1 = ep2; |
525 |
526 |
return(ep1); |
527 |
528 |
529 |
530 |
EPNODE * |
531 |
getE2() /* E2 -> E2 MULOP E3 */ |
532 |
/* E3 */ |
533 |
534 |
535 |
536 |
ep1 = getE3(); |
537 |
while (nextc == '*' || nextc == '/') { |
538 |
ep2 = newnode(); |
539 |
540 |
scan(); |
541 |
542 |
addekid(ep2, getE3()); |
543 |
#ifdef RCONST |
544 |
545 |
546 |
#endif |
547 |
ep1 = ep2; |
548 |
549 |
return(ep1); |
550 |
551 |
552 |
553 |
EPNODE * |
554 |
getE3() /* E3 -> E4 ^ E3 */ |
555 |
/* E4 */ |
556 |
557 |
558 |
559 |
ep1 = getE4(); |
560 |
if (nextc == '^') { |
561 |
ep2 = newnode(); |
562 |
563 |
scan(); |
564 |
565 |
566 |
#ifdef RCONST |
567 |
568 |
569 |
#endif |
570 |
return(ep2); |
571 |
572 |
return(ep1); |
573 |
574 |
575 |
576 |
EPNODE * |
577 |
getE4() /* E4 -> ADDOP E5 */ |
578 |
/* E5 */ |
579 |
580 |
581 |
582 |
if (nextc == '-') { |
583 |
scan(); |
584 |
ep2 = getE5(); |
585 |
if (ep2->type == NUM) { |
586 |
ep2->v.num = -ep2->v.num; |
587 |
return(ep2); |
588 |
589 |
if (ep2->type == UMINUS) { /* don't generate -(-E5) */ |
590 |
efree((char *)ep2); |
591 |
return(ep2->v.kid); |
592 |
593 |
ep1 = newnode(); |
594 |
ep1->type = UMINUS; |
595 |
addekid(ep1, ep2); |
596 |
return(ep1); |
597 |
598 |
if (nextc == '+') |
599 |
scan(); |
600 |
return(getE5()); |
601 |
602 |
603 |
604 |
EPNODE * |
605 |
getE5() /* E5 -> (E1) */ |
606 |
/* VAR */ |
607 |
/* NUM */ |
608 |
/* $N */ |
609 |
/* FUNC(E1,..) */ |
610 |
/* ARG */ |
611 |
612 |
int i; |
613 |
char *nam; |
614 |
615 |
616 |
if (nextc == '(') { |
617 |
scan(); |
618 |
ep1 = getE1(); |
619 |
if (nextc != ')') |
620 |
syntax("')' expected"); |
621 |
scan(); |
622 |
return(ep1); |
623 |
624 |
625 |
#ifdef INCHAN |
626 |
if (nextc == '$') { |
627 |
scan(); |
628 |
ep1 = newnode(); |
629 |
ep1->type = CHAN; |
630 |
ep1->v.chan = getinum(); |
631 |
return(ep1); |
632 |
633 |
#endif |
634 |
635 |
636 |
if (isalpha(nextc) || nextc == CNTXMARK) { |
637 |
nam = getname(); |
638 |
639 |
ep1 = NULL; |
640 |
if (curfunc != NULL) |
641 |
for (i = 1, ep2 = curfunc->v.kid->sibling; |
642 |
ep2 != NULL; i++, ep2 = ep2->sibling) |
643 |
if (!strcmp(ep2->v.name, nam)) { |
644 |
ep1 = newnode(); |
645 |
ep1->type = ARG; |
646 |
ep1->v.chan = i; |
647 |
break; |
648 |
649 |
if (ep1 == NULL) |
650 |
#endif |
651 |
652 |
ep1 = newnode(); |
653 |
ep1->type = VAR; |
654 |
ep1->v.ln = varinsert(nam); |
655 |
656 |
#ifdef FUNCTION |
657 |
658 |
ep2 = newnode(); |
659 |
ep2->type = FUNC; |
660 |
661 |
ep1 = ep2; |
662 |
do { |
663 |
scan(); |
664 |
addekid(ep1, getE1()); |
665 |
} while (nextc == ','); |
666 |
if (nextc != ')') |
667 |
668 |
scan(); |
669 |
670 |
#ifndef VARIABLE |
671 |
else |
672 |
syntax("'(' expected"); |
673 |
#endif |
674 |
#endif |
675 |
#ifdef RCONST |
676 |
if (isconstvar(ep1)) |
677 |
ep1 = rconst(ep1); |
678 |
#endif |
679 |
return(ep1); |
680 |
681 |
#endif |
682 |
683 |
if (isdecimal(nextc)) { |
684 |
ep1 = newnode(); |
685 |
ep1->type = NUM; |
686 |
ep1->v.num = getnum(); |
687 |
return(ep1); |
688 |
689 |
690 |
691 |
692 |
693 |
#ifdef RCONST |
694 |
EPNODE * |
695 |
rconst(epar) /* reduce a constant expression */ |
696 |
697 |
698 |
699 |
700 |
ep = newnode(); |
701 |
ep->type = NUM; |
702 |
errno = 0; |
703 |
ep->v.num = evalue(epar); |
704 |
if (errno) |
705 |
syntax("bad constant expression"); |
706 |
epfree(epar); |
707 |
708 |
return(ep); |
709 |
710 |
711 |
712 |
isconstvar(ep) /* is ep linked to a constant expression? */ |
713 |
714 |
715 |
#ifdef VARIABLE |
716 |
register EPNODE *ep1; |
717 |
#ifdef FUNCTION |
718 |
719 |
if (ep->type == FUNC) { |
720 |
if (!isconstfun(ep->v.kid)) |
721 |
return(0); |
722 |
for (ep1 = ep->v.kid->sibling; ep1 != NULL; ep1 = ep1->sibling) |
723 |
if (ep1->type != NUM && !isconstfun(ep1)) |
724 |
return(0); |
725 |
return(1); |
726 |
727 |
#endif |
728 |
if (ep->type != VAR) |
729 |
return(0); |
730 |
ep1 = ep->v.ln->def; |
731 |
if (ep1 == NULL || ep1->type != ':') |
732 |
return(0); |
733 |
#ifdef FUNCTION |
734 |
if (ep1->v.kid->type != SYM) |
735 |
return(0); |
736 |
#endif |
737 |
return(1); |
738 |
#else |
739 |
return(ep->type == FUNC); |
740 |
#endif |
741 |
742 |
743 |
744 |
#if defined(FUNCTION) && defined(VARIABLE) |
745 |
isconstfun(ep) /* is ep linked to a constant function? */ |
746 |
747 |
748 |
register EPNODE *dp; |
749 |
register LIBR *lp; |
750 |
751 |
752 |
return(0); |
753 |
dp = ep->v.ln->def; |
754 |
if (dp != NULL && dp->type != ':') |
755 |
return(0); |
756 |
if ((dp == NULL || dp->v.kid->type != FUNC) |
757 |
&& ((lp = liblookup(ep->v.ln->name)) == NULL |
758 |
|| lp->atyp != ':')) |
759 |
return(0); |
760 |
return(1); |
761 |
762 |
#endif |
763 |
#endif |
