| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: caldefn.c,v 2.42 2025/11/15 17:22:03 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Store variable definitions.
| 6 |
| 7 |
* 7/1/85 Greg Ward
| 8 |
| 9 |
* 11/11/85 Added conditional compiles (OUTCHAN) for control output.
| 10 |
| 11 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION).
| 12 |
| 13 |
* 1/15/88 Added clock for caching of variable values.
| 14 |
| 15 |
* 11/16/88 Added VARDEF structure for hard linking.
| 16 |
| 17 |
* 5/31/90 Added conditional compile (REDEFW) for redefinition warning.
| 18 |
| 19 |
* 4/23/91 Added ':' assignment for constant expressions
| 20 |
| 21 |
* 8/7/91 Added optional context path to append to variable names
| 22 |
| 23 |
* 5/17/2001 Fixed clock counter wrapping behavior
| 24 |
| 25 |
* 2/19/03 Eliminated conditional compiles in favor of esupport extern.
| 26 |
| 27 |
| 28 |
#include "copyright.h"
| 29 |
| 30 |
#include <ctype.h>
| 31 |
| 32 |
#include "rterror.h"
| 33 |
#include "rtio.h"
| 34 |
#include "rtmisc.h"
| 35 |
#include "calcomp.h"
| 36 |
| 37 |
#ifndef NHASH
| 38 |
#define NHASH 521 /* hash size (a prime!) */
| 39 |
#endif
| 40 |
| 41 |
#define hash(s) (shash(s)%NHASH)
| 42 |
| 43 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
| 44 |
| 45 |
static double dvalue(char *name, EPNODE *d);
| 46 |
| 47 |
#define MAXCLOCK (1L<<31) /* clock wrap value */
| 48 |
| 49 |
unsigned long eclock = 0; /* value storage timer */
| 50 |
| 51 |
#define MAXCNTX 1023 /* maximum context length */
| 52 |
| 53 |
static char context[MAXCNTX+1]; /* current context path */
| 54 |
| 55 |
static VARDEF *hashtbl[NHASH]; /* definition list */
| 56 |
static int htndx; /* index for */
| 57 |
static VARDEF *htpos; /* ...dfirst() and */
| 58 |
static EPNODE *ochpos; /* ...dnext */
| 59 |
static EPNODE *outchan;
| 60 |
| 61 |
static int optimized = 0; /* are we optimized? */
| 62 |
| 63 |
EPNODE *ecurfunc = NULL;
| 64 |
| 65 |
| 66 |
void
| 67 |
fcompile( /* get definitions from a file */
| 68 |
char *fname
| 69 |
| 70 |
| 71 |
FILE *fp;
| 72 |
| 73 |
if (fname == NULL)
| 74 |
fp = stdin;
| 75 |
else if ((fp = fopen(fname, "r")) == NULL) {
| 76 |
eputs(fname);
| 77 |
eputs(": cannot open\n");
| 78 |
quit(1);
| 79 |
| 80 |
#ifdef getc_unlocked /* avoid stupid semaphores */
| 81 |
flockfile(fp);
| 82 |
#endif
| 83 |
initfile(fp, fname, 0);
| 84 |
while (nextc != EOF)
| 85 |
egetstatement();
| 86 |
if (fname != NULL)
| 87 |
fclose(fp);
| 88 |
| 89 |
else
| 90 |
funlockfile(fp);
| 91 |
#endif
| 92 |
| 93 |
| 94 |
| 95 |
void
| 96 |
scompile( /* get definitions from a string */
| 97 |
char *str,
| 98 |
char *fn,
| 99 |
int ln
| 100 |
| 101 |
| 102 |
initstr(str, fn, ln);
| 103 |
| 104 |
egetstatement();
| 105 |
| 106 |
| 107 |
| 108 |
double
| 109 |
varvalue( /* return a variable's value */
| 110 |
char *vname
| 111 |
| 112 |
| 113 |
return(dvalue(vname, dlookup(vname)));
| 114 |
| 115 |
| 116 |
| 117 |
double
| 118 |
evariable( /* evaluate a variable */
| 119 |
EPNODE *ep
| 120 |
| 121 |
| 122 |
VARDEF *dp = ep->v.ln;
| 123 |
| 124 |
return(dvalue(dp->name, dp->def));
| 125 |
| 126 |
| 127 |
| 128 |
void
| 129 |
varset( /* set a variable's value */
| 130 |
char *vname,
| 131 |
int assign,
| 132 |
double val
| 133 |
| 134 |
| 135 |
char *qname;
| 136 |
EPNODE *ep1, *ep2;
| 137 |
/* get qualified name */
| 138 |
qname = qualname(vname, 0);
| 139 |
/* check for quick set */
| 140 |
if ((ep1 = dlookup(qname)) != NULL && ep1->type == '=' &&
| 141 |
ep1->v.kid->type == SYM) {
| 142 |
ep2 = ep1->v.kid->sibling;
| 143 |
if (ep2->type == NUM) {
| 144 |
ep2->v.num = val;
| 145 |
ep1->type = assign;
| 146 |
return;
| 147 |
} /* else, redefine vname */
| 148 |
| 149 |
if (ep1 != NULL && esupport&(E_REDEFW | (ep1->type==':')*E_RCONST)) {
| 150 |
wputs(qname);
| 151 |
if (ep1->type == ':')
| 152 |
wputs(": reset constant\n");
| 153 |
else
| 154 |
wputs(": reset expression\n");
| 155 |
| 156 |
/* hand build definition */
| 157 |
ep1 = newnode();
| 158 |
ep1->type = assign;
| 159 |
ep2 = newnode();
| 160 |
ep2->type = SYM;
| 161 |
ep2->v.name = savestr(vname);
| 162 |
addekid(ep1, ep2);
| 163 |
ep2 = newnode();
| 164 |
ep2->type = NUM;
| 165 |
ep2->v.num = val;
| 166 |
addekid(ep1, ep2);
| 167 |
if (assign == ':')
| 168 |
dremove(qname);
| 169 |
else
| 170 |
dclear(qname);
| 171 |
dpush(qname, ep1);
| 172 |
| 173 |
| 174 |
| 175 |
void
| 176 |
dclear( /* delete variable definitions of name */
| 177 |
char *name
| 178 |
| 179 |
| 180 |
VARDEF *vp;
| 181 |
EPNODE *dp;
| 182 |
| 183 |
while ((vp = varlookup(name)) != NULL &&
| 184 |
(dp = vp->def) != NULL && dp->type == '=') {
| 185 |
vp->def = dp->sibling;
| 186 |
epfree(dp,1);
| 187 |
varfree(vp);
| 188 |
| 189 |
| 190 |
| 191 |
| 192 |
void
| 193 |
dremove( /* delete all definitions of name */
| 194 |
char *name
| 195 |
| 196 |
| 197 |
EPNODE *ep;
| 198 |
| 199 |
while ((ep = dpop(name)) != NULL)
| 200 |
epfree(ep,1);
| 201 |
| 202 |
| 203 |
| 204 |
int
| 205 |
vardefined( /* return '=' or ':' if variable/constant defined */
| 206 |
char *name
| 207 |
| 208 |
| 209 |
EPNODE *dp = dlookup(name);
| 210 |
| 211 |
if (dp == NULL || dp->v.kid->type != SYM)
| 212 |
return(0);
| 213 |
| 214 |
return(dp->type);
| 215 |
| 216 |
| 217 |
| 218 |
char *
| 219 |
calcontext( /* set a new context path */
| 220 |
char *ctx
| 221 |
| 222 |
| 223 |
char *cpp;
| 224 |
| 225 |
if (ctx == NULL)
| 226 |
return(context); /* just asking */
| 227 |
while (*ctx == CNTXMARK)
| 228 |
ctx++; /* skip past marks */
| 229 |
if (!*ctx) {
| 230 |
context[0] = '\0'; /* empty means clear context */
| 231 |
return(context);
| 232 |
| 233 |
cpp = context; /* start context with mark */
| 234 |
*cpp++ = CNTXMARK;
| 235 |
do { /* carefully copy new context */
| 236 |
if (cpp >= context+MAXCNTX)
| 237 |
break; /* just copy what we can */
| 238 |
if (isid(*ctx))
| 239 |
*cpp++ = *ctx++;
| 240 |
else {
| 241 |
*cpp++ = '_'; ctx++;
| 242 |
| 243 |
} while (*ctx);
| 244 |
while (cpp[-1] == CNTXMARK) /* cannot end in context mark */
| 245 |
cpp--;
| 246 |
*cpp = '\0';
| 247 |
return(context);
| 248 |
| 249 |
| 250 |
| 251 |
char *
| 252 |
pushcontext( /* push on another context */
| 253 |
char *ctx
| 254 |
| 255 |
| 256 |
char oldcontext[MAXCNTX+1];
| 257 |
int n;
| 258 |
| 259 |
strcpy(oldcontext, context); /* save old context */
| 260 |
calcontext(ctx); /* set new context */
| 261 |
n = strlen(context); /* tack on old */
| 262 |
if (n+strlen(oldcontext) > MAXCNTX) {
| 263 |
strncpy(context+n, oldcontext, MAXCNTX-n);
| 264 |
context[MAXCNTX] = '\0';
| 265 |
} else
| 266 |
strcpy(context+n, oldcontext);
| 267 |
return(context);
| 268 |
| 269 |
| 270 |
| 271 |
char *
| 272 |
popcontext(void) /* pop off top context */
| 273 |
| 274 |
char *cp1, *cp2;
| 275 |
| 276 |
if (!context[0]) /* nothing left to pop */
| 277 |
return(context);
| 278 |
cp2 = context; /* find mark */
| 279 |
while (*++cp2 && *cp2 != CNTXMARK)
| 280 |
| 281 |
cp1 = context; /* copy tail to front */
| 282 |
while ( (*cp1++ = *cp2++) )
| 283 |
| 284 |
return(context);
| 285 |
| 286 |
| 287 |
| 288 |
char *
| 289 |
qualname( /* get qualified name */
| 290 |
char *nam,
| 291 |
int lvl
| 292 |
| 293 |
| 294 |
static char nambuf[MAXCNTX+RMAXWORD+1];
| 295 |
char *cp = nambuf, *cpp;
| 296 |
/* check for explicit local */
| 297 |
if (*nam == CNTXMARK) {
| 298 |
if (lvl > 0) /* only action is to refuse search */
| 299 |
return(NULL);
| 300 |
nam++;
| 301 |
} else if (nam == nambuf) /* check for repeat call */
| 302 |
return(lvl > 0 ? NULL : nam);
| 303 |
/* copy name to static buffer */
| 304 |
while (*nam) {
| 305 |
if (cp >= nambuf+(MAXCNTX+RMAXWORD))
| 306 |
goto toolong;
| 307 |
*cp++ = *nam++;
| 308 |
| 309 |
/* check for explicit global */
| 310 |
if (cp > nambuf && cp[-1] == CNTXMARK) {
| 311 |
if (lvl > 0)
| 312 |
return(NULL);
| 313 |
*--cp = '\0';
| 314 |
return(nambuf); /* already qualified */
| 315 |
| 316 |
cpp = context; /* else skip the requested levels */
| 317 |
while (lvl-- > 0) {
| 318 |
if (!*cpp)
| 319 |
return(NULL); /* return NULL if past global level */
| 320 |
while (*++cpp && *cpp != CNTXMARK)
| 321 |
| 322 |
| 323 |
while (*cpp) { /* add remaining context to name */
| 324 |
| 325 |
goto toolong;
| 326 |
*cp++ = *cpp++;
| 327 |
| 328 |
toolong:
| 329 |
*cp = '\0';
| 330 |
return(nambuf); /* return qualified name */
| 331 |
| 332 |
| 333 |
| 334 |
int
| 335 |
incontext( /* is qualified name in current context? */
| 336 |
char *qn
| 337 |
| 338 |
| 339 |
if (!context[0]) /* global context accepts all */
| 340 |
return(1);
| 341 |
while (*qn && *qn != CNTXMARK) /* find context mark */
| 342 |
qn++;
| 343 |
return(!strcmp(qn, context));
| 344 |
| 345 |
| 346 |
| 347 |
void
| 348 |
chanout( /* set output channels */
| 349 |
void (*cs)(int n, double v)
| 350 |
| 351 |
| 352 |
EPNODE *ep;
| 353 |
| 354 |
for (ep = outchan; ep != NULL; ep = ep->sibling)
| 355 |
(*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling));
| 356 |
| 357 |
| 358 |
| 359 |
| 360 |
void
| 361 |
doptimize(int activate) /* optimize current and future definitions? */
| 362 |
| 363 |
EPNODE *ep;
| 364 |
| 365 |
if (activate && optimized)
| 366 |
return; /* already going */
| 367 |
| 368 |
if (!(optimized = activate))
| 369 |
return; /* switching off */
| 370 |
| 371 |
for (ep = dfirst(); ep != NULL; ep = dnext())
| 372 |
epoptimize(ep);
| 373 |
| 374 |
| 375 |
| 376 |
void
| 377 |
dcleanup( /* clear definitions (0->vars,1->output,2->consts) */
| 378 |
int lvl
| 379 |
| 380 |
| 381 |
int i;
| 382 |
VARDEF *vp;
| 383 |
EPNODE *ep;
| 384 |
/* if context is global, clear all */
| 385 |
for (i = 0; i < NHASH; i++)
| 386 |
for (vp = hashtbl[i]; vp != NULL; vp = vp->next)
| 387 |
if (incontext(vp->name)) {
| 388 |
if (lvl >= 2)
| 389 |
dremove(vp->name);
| 390 |
else
| 391 |
dclear(vp->name);
| 392 |
| 393 |
if (lvl >= 1)
| 394 |
while (outchan != NULL) {
| 395 |
ep = outchan;
| 396 |
outchan = ep->sibling;
| 397 |
epfree(ep,1);
| 398 |
| 399 |
| 400 |
| 401 |
| 402 |
EPNODE *
| 403 |
dlookup( /* look up a definition */
| 404 |
char *name
| 405 |
| 406 |
| 407 |
VARDEF *vp;
| 408 |
| 409 |
if ((vp = varlookup(name)) == NULL)
| 410 |
return(NULL);
| 411 |
return(vp->def);
| 412 |
| 413 |
| 414 |
| 415 |
VARDEF *
| 416 |
varlookup( /* look up a variable */
| 417 |
char *name
| 418 |
| 419 |
| 420 |
int lvl = 0;
| 421 |
char *qname;
| 422 |
VARDEF *vp;
| 423 |
/* find most qualified match */
| 424 |
while ((qname = qualname(name, lvl++)) != NULL)
| 425 |
for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next)
| 426 |
if (!strcmp(vp->name, qname))
| 427 |
return(vp);
| 428 |
return(NULL);
| 429 |
| 430 |
| 431 |
| 432 |
VARDEF *
| 433 |
varinsert( /* get a link to a variable */
| 434 |
char *name
| 435 |
| 436 |
| 437 |
VARDEF *vp;
| 438 |
int hv;
| 439 |
| 440 |
if ((vp = varlookup(name)) != NULL) {
| 441 |
vp->nlinks++;
| 442 |
return(vp);
| 443 |
| 444 |
vp = (VARDEF *)emalloc(sizeof(VARDEF));
| 445 |
vp->lib = eliblookup(name);
| 446 |
if (vp->lib == NULL) /* if name not in library */
| 447 |
name = qualname(name, 0); /* use fully qualified version */
| 448 |
hv = hash(name);
| 449 |
vp->name = savestr(name);
| 450 |
vp->nlinks = 1;
| 451 |
vp->def = NULL;
| 452 |
vp->next = hashtbl[hv];
| 453 |
hashtbl[hv] = vp;
| 454 |
return(vp);
| 455 |
| 456 |
| 457 |
| 458 |
void
| 459 |
elibupdate( /* update library links */
| 460 |
char *fn
| 461 |
| 462 |
| 463 |
int i;
| 464 |
VARDEF *vp;
| 465 |
/* if fn is NULL then relink all */
| 466 |
| 467 |
| 468 |
if ((vp->lib != NULL) | (fn == NULL) || !strcmp(fn, vp->name))
| 469 |
vp->lib = eliblookup(vp->name);
| 470 |
| 471 |
| 472 |
| 473 |
void
| 474 |
varfree( /* release link to variable */
| 475 |
VARDEF *ln
| 476 |
| 477 |
| 478 |
VARDEF *vp;
| 479 |
int hv;
| 480 |
| 481 |
if (--ln->nlinks > 0)
| 482 |
return; /* still active */
| 483 |
| 484 |
hv = hash(ln->name);
| 485 |
vp = hashtbl[hv];
| 486 |
if (vp == ln)
| 487 |
hashtbl[hv] = vp->next;
| 488 |
else {
| 489 |
while (vp->next != ln) /* must be in list */
| 490 |
vp = vp->next;
| 491 |
vp->next = ln->next;
| 492 |
| 493 |
freestr(ln->name);
| 494 |
efree(ln);
| 495 |
| 496 |
| 497 |
| 498 |
EPNODE *
| 499 |
dfirst(void) /* return pointer to first definition */
| 500 |
| 501 |
htndx = 0;
| 502 |
htpos = NULL;
| 503 |
ochpos = outchan;
| 504 |
return(dnext());
| 505 |
| 506 |
| 507 |
| 508 |
EPNODE *
| 509 |
dnext(void) /* return pointer to next definition */
| 510 |
| 511 |
EPNODE *ep;
| 512 |
char *nm;
| 513 |
| 514 |
while (htndx < NHASH) {
| 515 |
if (htpos == NULL)
| 516 |
htpos = hashtbl[htndx++];
| 517 |
while (htpos != NULL) {
| 518 |
ep = htpos->def;
| 519 |
nm = htpos->name;
| 520 |
htpos = htpos->next;
| 521 |
if (ep != NULL && incontext(nm))
| 522 |
return(ep);
| 523 |
| 524 |
| 525 |
if ((ep = ochpos) != NULL)
| 526 |
ochpos = ep->sibling;
| 527 |
return(ep);
| 528 |
| 529 |
| 530 |
| 531 |
EPNODE *
| 532 |
dpop( /* pop a definition */
| 533 |
char *name
| 534 |
| 535 |
| 536 |
VARDEF *vp;
| 537 |
EPNODE *dp;
| 538 |
| 539 |
if ((vp = varlookup(name)) == NULL || vp->def == NULL)
| 540 |
return(NULL);
| 541 |
dp = vp->def;
| 542 |
| 543 |
varfree(vp);
| 544 |
return(dp);
| 545 |
| 546 |
| 547 |
| 548 |
void
| 549 |
dpush( /* push on a definition */
| 550 |
char *nm,
| 551 |
EPNODE *ep
| 552 |
| 553 |
| 554 |
VARDEF *vp;
| 555 |
| 556 |
vp = varinsert(nm);
| 557 |
ep->sibling = vp->def;
| 558 |
vp->def = ep;
| 559 |
| 560 |
| 561 |
| 562 |
void
| 563 |
eaddchan( /* add an output channel assignment */
| 564 |
EPNODE *sp
| 565 |
| 566 |
| 567 |
int ch = sp->v.kid->v.chan;
| 568 |
EPNODE *ep, *epl;
| 569 |
| 570 |
for (epl = NULL, ep = outchan; ep != NULL; epl = ep, ep = ep->sibling)
| 571 |
if (ep->v.kid->v.chan >= ch) {
| 572 |
if (epl != NULL)
| 573 |
epl->sibling = sp;
| 574 |
else
| 575 |
outchan = sp;
| 576 |
if (ep->v.kid->v.chan > ch)
| 577 |
sp->sibling = ep;
| 578 |
else {
| 579 |
sp->sibling = ep->sibling;
| 580 |
epfree(ep,1);
| 581 |
| 582 |
return;
| 583 |
| 584 |
if (epl != NULL)
| 585 |
epl->sibling = sp;
| 586 |
else
| 587 |
outchan = sp;
| 588 |
sp->sibling = NULL;
| 589 |
| 590 |
| 591 |
| 592 |
| 593 |
void
| 594 |
egetstatement(void) /* get next statement */
| 595 |
| 596 |
EPNODE *ep;
| 597 |
char *qname;
| 598 |
VARDEF *vdef;
| 599 |
| 600 |
if (nextc == ';') { /* empty statement */
| 601 |
escan();
| 602 |
return;
| 603 |
| 604 |
if (esupport&E_OUTCHAN &&
| 605 |
nextc == '$') { /* channel assignment */
| 606 |
ep = egetchan();
| 607 |
if (optimized)
| 608 |
epoptimize(ep); /* optimize new chan expr */
| 609 |
eaddchan(ep);
| 610 |
} else { /* ordinary definition */
| 611 |
ep = egetdefn();
| 612 |
if (optimized)
| 613 |
epoptimize(ep); /* optimize new statement */
| 614 |
qname = qualname(dfn_name(ep), 0);
| 615 |
if (esupport&(E_REDEFW|E_RCONST) &&
| 616 |
(vdef = varlookup(qname)) != NULL) {
| 617 |
if (vdef->def != NULL && epcmp(ep, vdef->def)) {
| 618 |
if (vdef->def->type == ':') {
| 619 |
wputs(qname);
| 620 |
wputs(": constant redefined\n");
| 621 |
} else if (esupport&E_REDEFW) {
| 622 |
wputs(qname);
| 623 |
wputs(": redefined\n");
| 624 |
| 625 |
} else if ((ep->v.kid->type == FUNC) & (vdef->lib != NULL)) {
| 626 |
wputs(qname);
| 627 |
wputs(": definition hides library function\n");
| 628 |
| 629 |
| 630 |
if (ep->type == ':')
| 631 |
dremove(qname);
| 632 |
else
| 633 |
dclear(qname);
| 634 |
dpush(qname, ep);
| 635 |
| 636 |
if (nextc != EOF) {
| 637 |
if (nextc != ';')
| 638 |
esyntax("';' expected");
| 639 |
escan();
| 640 |
| 641 |
| 642 |
| 643 |
| 644 |
EPNODE *
| 645 |
egetdefn(void)
| 646 |
/* A -> SYM = E1 */
| 647 |
/* SYM : E1 */
| 648 |
/* FUNC(SYM,..) = E1 */
| 649 |
/* FUNC(SYM,..) : E1 */
| 650 |
| 651 |
EPNODE *ep1, *ep2;
| 652 |
| 653 |
if (!isalpha(nextc) & (nextc != CNTXMARK))
| 654 |
esyntax("illegal variable name");
| 655 |
| 656 |
ep1 = newnode();
| 657 |
ep1->type = SYM;
| 658 |
ep1->v.name = savestr(getname());
| 659 |
| 660 |
if (esupport&E_FUNCTION && nextc == '(') {
| 661 |
ep2 = newnode();
| 662 |
ep2->type = FUNC;
| 663 |
addekid(ep2, ep1);
| 664 |
ep1 = ep2;
| 665 |
do {
| 666 |
escan();
| 667 |
if (!isalpha(nextc))
| 668 |
esyntax("illegal parameter name");
| 669 |
ep2 = newnode();
| 670 |
ep2->type = SYM;
| 671 |
ep2->v.name = savestr(getname());
| 672 |
if (strchr(ep2->v.name, CNTXMARK) != NULL)
| 673 |
| 674 |
addekid(ep1, ep2);
| 675 |
} while (nextc == ',');
| 676 |
if (nextc != ')')
| 677 |
esyntax("')' expected");
| 678 |
escan();
| 679 |
ecurfunc = ep1;
| 680 |
| 681 |
| 682 |
if ((nextc != '=') & (nextc != ':'))
| 683 |
esyntax("'=' or ':' expected");
| 684 |
| 685 |
ep2 = newnode();
| 686 |
ep2->type = nextc;
| 687 |
escan();
| 688 |
addekid(ep2, ep1);
| 689 |
addekid(ep2, getE1());
| 690 |
| 691 |
if (ep1->type == SYM && ep1->sibling->type != NUM) {
| 692 |
ep1 = newnode();
| 693 |
ep1->type = CLKT;
| 694 |
ep1->v.tick = 0;
| 695 |
addekid(ep2, ep1);
| 696 |
ep1 = newnode();
| 697 |
ep1->type = NUM;
| 698 |
addekid(ep2, ep1);
| 699 |
| 700 |
ecurfunc = NULL;
| 701 |
| 702 |
return(ep2);
| 703 |
| 704 |
| 705 |
| 706 |
EPNODE *
| 707 |
egetchan(void) /* A -> $N = E1 */
| 708 |
| 709 |
EPNODE *ep1, *ep2;
| 710 |
| 711 |
if (nextc != '$')
| 712 |
esyntax("missing '$'");
| 713 |
escan();
| 714 |
| 715 |
ep1 = newnode();
| 716 |
ep1->type = CHAN;
| 717 |
ep1->v.chan = getinum();
| 718 |
| 719 |
if (nextc != '=')
| 720 |
esyntax("'=' expected");
| 721 |
escan();
| 722 |
| 723 |
ep2 = newnode();
| 724 |
ep2->type = '=';
| 725 |
addekid(ep2, ep1);
| 726 |
| 727 |
| 728 |
return(ep2);
| 729 |
| 730 |
| 731 |
| 732 |
| 733 |
| 734 |
* The following routines are for internal use only:
| 735 |
| 736 |
| 737 |
| 738 |
static double /* evaluate a variable */
| 739 |
| 740 |
| 741 |
EPNODE *ep1, *ep2;
| 742 |
| 743 |
if (d == NULL || d->v.kid->type != SYM) {
| 744 |
eputs(name);
| 745 |
eputs(": undefined variable\n");
| 746 |
quit(1);
| 747 |
| 748 |
ep1 = d->v.kid->sibling; /* get expression */
| 749 |
if (ep1->type == NUM)
| 750 |
return(ep1->v.num); /* return if number */
| 751 |
if (esupport&E_RCONST && d->type == ':') {
| 752 |
wputs(name);
| 753 |
wputs(": assigned non-constant value\n");
| 754 |
| 755 |
ep2 = ep1->sibling; /* check time */
| 756 |
if (eclock >= MAXCLOCK)
| 757 |
eclock = 1; /* wrap clock counter */
| 758 |
if (ep2->v.tick < MAXCLOCK &&
| 759 |
(ep2->v.tick == 0) | (ep2->v.tick != eclock)) {
| 760 |
ep2->v.tick = d->type == ':' ? MAXCLOCK : eclock;
| 761 |
ep2 = ep2->sibling;
| 762 |
ep2->v.num = evalue(ep1); /* needs new value */
| 763 |
} else
| 764 |
ep2 = ep2->sibling; /* else reuse old value */
| 765 |
| 766 |
return(ep2->v.num);
| 767 |
