1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: caldefn.c,v 2.32 2022/03/30 16:00:56 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Store variable definitions. |
6 |
7 |
* 7/1/85 Greg Ward |
8 |
9 |
* 11/11/85 Added conditional compiles (OUTCHAN) for control output. |
10 |
11 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION). |
12 |
13 |
* 1/15/88 Added clock for caching of variable values. |
14 |
15 |
* 11/16/88 Added VARDEF structure for hard linking. |
16 |
17 |
* 5/31/90 Added conditional compile (REDEFW) for redefinition warning. |
18 |
19 |
* 4/23/91 Added ':' assignment for constant expressions |
20 |
21 |
* 8/7/91 Added optional context path to append to variable names |
22 |
23 |
* 5/17/2001 Fixed clock counter wrapping behavior |
24 |
25 |
* 2/19/03 Eliminated conditional compiles in favor of esupport extern. |
26 |
27 |
28 |
#include "copyright.h" |
29 |
30 |
#include <ctype.h> |
31 |
32 |
#include "rterror.h" |
33 |
#include "rtio.h" |
34 |
#include "rtmisc.h" |
35 |
#include "calcomp.h" |
36 |
37 |
#ifndef NHASH |
38 |
#define NHASH 521 /* hash size (a prime!) */ |
39 |
#endif |
40 |
41 |
#define hash(s) (shash(s)%NHASH) |
42 |
43 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) |
44 |
45 |
static double dvalue(char *name, EPNODE *d); |
46 |
47 |
#define MAXCLOCK (1L<<31) /* clock wrap value */ |
48 |
49 |
unsigned long eclock = 0; /* value storage timer */ |
50 |
51 |
#define MAXCNTX 1023 /* maximum context length */ |
52 |
53 |
static char context[MAXCNTX+1]; /* current context path */ |
54 |
55 |
static VARDEF *hashtbl[NHASH]; /* definition list */ |
56 |
static int htndx; /* index for */ |
57 |
static VARDEF *htpos; /* ...dfirst() and */ |
58 |
static EPNODE *ochpos; /* ...dnext */ |
59 |
static EPNODE *outchan; |
60 |
61 |
EPNODE *curfunc = NULL; |
62 |
#define dname(ep) ((ep)->v.kid->type == SYM ? \ |
63 |
(ep)->v.kid->v.name : \ |
64 |
(ep)->v.kid->v.kid->v.name) |
65 |
66 |
67 |
void |
68 |
fcompile( /* get definitions from a file */ |
69 |
char *fname |
70 |
71 |
72 |
FILE *fp; |
73 |
74 |
if (fname == NULL) |
75 |
fp = stdin; |
76 |
else if ((fp = fopen(fname, "r")) == NULL) { |
77 |
eputs(fname); |
78 |
eputs(": cannot open\n"); |
79 |
quit(1); |
80 |
81 |
initfile(fp, fname, 0); |
82 |
while (nextc != EOF) |
83 |
getstatement(); |
84 |
if (fname != NULL) |
85 |
fclose(fp); |
86 |
87 |
88 |
89 |
void |
90 |
scompile( /* get definitions from a string */ |
91 |
char *str, |
92 |
char *fn, |
93 |
int ln |
94 |
95 |
96 |
initstr(str, fn, ln); |
97 |
98 |
getstatement(); |
99 |
100 |
101 |
102 |
double |
103 |
varvalue( /* return a variable's value */ |
104 |
char *vname |
105 |
106 |
107 |
return(dvalue(vname, dlookup(vname))); |
108 |
109 |
110 |
111 |
double |
112 |
evariable( /* evaluate a variable */ |
113 |
EPNODE *ep |
114 |
115 |
116 |
VARDEF *dp = ep->v.ln; |
117 |
118 |
return(dvalue(dp->name, dp->def)); |
119 |
120 |
121 |
122 |
void |
123 |
varset( /* set a variable's value */ |
124 |
char *vname, |
125 |
int assign, |
126 |
double val |
127 |
128 |
129 |
char *qname; |
130 |
EPNODE *ep1, *ep2; |
131 |
/* get qualified name */ |
132 |
qname = qualname(vname, 0); |
133 |
/* check for quick set */ |
134 |
if ((ep1 = dlookup(qname)) != NULL && ep1->v.kid->type == SYM && |
135 |
(ep1->type == ':') <= (assign == ':')) { |
136 |
ep2 = ep1->v.kid->sibling; |
137 |
if (ep2->type == NUM) { |
138 |
ep2->v.num = val; |
139 |
ep1->type = assign; |
140 |
return; |
141 |
142 |
143 |
if (ep1 != NULL && esupport&E_REDEFW) { |
144 |
wputs(qname); |
145 |
if (ep1->type == ':') |
146 |
wputs(": reset constant expression\n"); |
147 |
else |
148 |
wputs(": reset expression\n"); |
149 |
150 |
/* hand build definition */ |
151 |
ep1 = newnode(); |
152 |
153 |
ep2 = newnode(); |
154 |
ep2->type = SYM; |
155 |
ep2->v.name = savestr(vname); |
156 |
addekid(ep1, ep2); |
157 |
ep2 = newnode(); |
158 |
ep2->type = NUM; |
159 |
ep2->v.num = val; |
160 |
161 |
if (assign == ':') |
162 |
dremove(qname); |
163 |
else |
164 |
dclear(qname); |
165 |
dpush(qname, ep1); |
166 |
167 |
168 |
169 |
void |
170 |
dclear( /* delete variable definitions of name */ |
171 |
char *name |
172 |
173 |
174 |
EPNODE *ep; |
175 |
176 |
while ((ep = dpop(name)) != NULL) { |
177 |
if (ep->type == ':') { |
178 |
dpush(name, ep); /* don't clear constants */ |
179 |
return; |
180 |
181 |
epfree(ep); |
182 |
183 |
184 |
185 |
186 |
void |
187 |
dremove( /* delete all definitions of name */ |
188 |
char *name |
189 |
190 |
191 |
EPNODE *ep; |
192 |
193 |
while ((ep = dpop(name)) != NULL) |
194 |
epfree(ep); |
195 |
196 |
197 |
198 |
int |
199 |
vardefined( /* return '=' or ':' if variable/constant defined */ |
200 |
char *name |
201 |
202 |
203 |
EPNODE *dp = dlookup(name); |
204 |
205 |
if (dp == NULL || dp->v.kid->type != SYM) |
206 |
return(0); |
207 |
208 |
return(dp->type); |
209 |
210 |
211 |
212 |
char * |
213 |
calcontext( /* set a new context path */ |
214 |
char *ctx |
215 |
216 |
217 |
char *cpp; |
218 |
219 |
if (ctx == NULL) |
220 |
return(context); /* just asking */ |
221 |
while (*ctx == CNTXMARK) |
222 |
ctx++; /* skip past marks */ |
223 |
if (!*ctx) { |
224 |
context[0] = '\0'; /* empty means clear context */ |
225 |
return(context); |
226 |
227 |
cpp = context; /* start context with mark */ |
228 |
*cpp++ = CNTXMARK; |
229 |
do { /* carefully copy new context */ |
230 |
if (cpp >= context+MAXCNTX) |
231 |
break; /* just copy what we can */ |
232 |
if (isid(*ctx)) |
233 |
*cpp++ = *ctx++; |
234 |
else { |
235 |
*cpp++ = '_'; ctx++; |
236 |
237 |
} while (*ctx); |
238 |
while (cpp[-1] == CNTXMARK) /* cannot end in context mark */ |
239 |
cpp--; |
240 |
*cpp = '\0'; |
241 |
return(context); |
242 |
243 |
244 |
245 |
char * |
246 |
pushcontext( /* push on another context */ |
247 |
char *ctx |
248 |
249 |
250 |
char oldcontext[MAXCNTX+1]; |
251 |
int n; |
252 |
253 |
strcpy(oldcontext, context); /* save old context */ |
254 |
calcontext(ctx); /* set new context */ |
255 |
n = strlen(context); /* tack on old */ |
256 |
if (n+strlen(oldcontext) > MAXCNTX) { |
257 |
strncpy(context+n, oldcontext, MAXCNTX-n); |
258 |
context[MAXCNTX] = '\0'; |
259 |
} else |
260 |
strcpy(context+n, oldcontext); |
261 |
return(context); |
262 |
263 |
264 |
265 |
char * |
266 |
popcontext(void) /* pop off top context */ |
267 |
268 |
char *cp1, *cp2; |
269 |
270 |
if (!context[0]) /* nothing left to pop */ |
271 |
return(context); |
272 |
cp2 = context; /* find mark */ |
273 |
while (*++cp2 && *cp2 != CNTXMARK) |
274 |
275 |
cp1 = context; /* copy tail to front */ |
276 |
while ( (*cp1++ = *cp2++) ) |
277 |
278 |
return(context); |
279 |
280 |
281 |
282 |
char * |
283 |
qualname( /* get qualified name */ |
284 |
char *nam, |
285 |
int lvl |
286 |
287 |
288 |
static char nambuf[RMAXWORD+1]; |
289 |
char *cp = nambuf, *cpp; |
290 |
/* check for explicit local */ |
291 |
if (*nam == CNTXMARK) |
292 |
if (lvl > 0) /* only action is to refuse search */ |
293 |
return(NULL); |
294 |
else |
295 |
nam++; |
296 |
else if (nam == nambuf) /* check for repeat call */ |
297 |
return(lvl > 0 ? NULL : nam); |
298 |
/* copy name to static buffer */ |
299 |
while (*nam) { |
300 |
if (cp >= nambuf+RMAXWORD) |
301 |
goto toolong; |
302 |
*cp++ = *nam++; |
303 |
304 |
/* check for explicit global */ |
305 |
if (cp > nambuf && cp[-1] == CNTXMARK) { |
306 |
if (lvl > 0) |
307 |
return(NULL); |
308 |
*--cp = '\0'; |
309 |
return(nambuf); /* already qualified */ |
310 |
311 |
cpp = context; /* else skip the requested levels */ |
312 |
while (lvl-- > 0) { |
313 |
if (!*cpp) |
314 |
return(NULL); /* return NULL if past global level */ |
315 |
while (*++cpp && *cpp != CNTXMARK) |
316 |
317 |
318 |
while (*cpp) { /* copy context to static buffer */ |
319 |
320 |
goto toolong; |
321 |
*cp++ = *cpp++; |
322 |
323 |
toolong: |
324 |
*cp = '\0'; |
325 |
return(nambuf); /* return qualified name */ |
326 |
327 |
328 |
329 |
int |
330 |
incontext( /* is qualified name in current context? */ |
331 |
char *qn |
332 |
333 |
334 |
if (!context[0]) /* global context accepts all */ |
335 |
return(1); |
336 |
while (*qn && *qn != CNTXMARK) /* find context mark */ |
337 |
qn++; |
338 |
return(!strcmp(qn, context)); |
339 |
340 |
341 |
342 |
void |
343 |
chanout( /* set output channels */ |
344 |
void (*cs)(int n, double v) |
345 |
346 |
347 |
EPNODE *ep; |
348 |
349 |
for (ep = outchan; ep != NULL; ep = ep->sibling) |
350 |
(*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling)); |
351 |
352 |
353 |
354 |
355 |
void |
356 |
dcleanup( /* clear definitions (0->vars,1->output,2->consts) */ |
357 |
int lvl |
358 |
359 |
360 |
int i; |
361 |
VARDEF *vp; |
362 |
EPNODE *ep; |
363 |
/* if context is global, clear all */ |
364 |
for (i = 0; i < NHASH; i++) |
365 |
for (vp = hashtbl[i]; vp != NULL; vp = vp->next) |
366 |
if (incontext(vp->name)) { |
367 |
if (lvl >= 2) |
368 |
dremove(vp->name); |
369 |
else |
370 |
dclear(vp->name); |
371 |
372 |
if (lvl >= 1) { |
373 |
374 |
epfree(ep); |
375 |
outchan = NULL; |
376 |
377 |
378 |
379 |
380 |
EPNODE * |
381 |
dlookup( /* look up a definition */ |
382 |
char *name |
383 |
384 |
385 |
VARDEF *vp; |
386 |
387 |
if ((vp = varlookup(name)) == NULL) |
388 |
return(NULL); |
389 |
return(vp->def); |
390 |
391 |
392 |
393 |
VARDEF * |
394 |
varlookup( /* look up a variable */ |
395 |
char *name |
396 |
397 |
398 |
int lvl = 0; |
399 |
char *qname; |
400 |
VARDEF *vp; |
401 |
/* find most qualified match */ |
402 |
while ((qname = qualname(name, lvl++)) != NULL) |
403 |
for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next) |
404 |
if (!strcmp(vp->name, qname)) |
405 |
return(vp); |
406 |
return(NULL); |
407 |
408 |
409 |
410 |
VARDEF * |
411 |
varinsert( /* get a link to a variable */ |
412 |
char *name |
413 |
414 |
415 |
VARDEF *vp; |
416 |
int hv; |
417 |
418 |
if ((vp = varlookup(name)) != NULL) { |
419 |
vp->nlinks++; |
420 |
return(vp); |
421 |
422 |
vp = (VARDEF *)emalloc(sizeof(VARDEF)); |
423 |
vp->lib = liblookup(name); |
424 |
if (vp->lib == NULL) /* if name not in library */ |
425 |
name = qualname(name, 0); /* use fully qualified version */ |
426 |
hv = hash(name); |
427 |
vp->name = savestr(name); |
428 |
vp->nlinks = 1; |
429 |
vp->def = NULL; |
430 |
vp->next = hashtbl[hv]; |
431 |
hashtbl[hv] = vp; |
432 |
return(vp); |
433 |
434 |
435 |
436 |
void |
437 |
libupdate( /* update library links */ |
438 |
char *fn |
439 |
440 |
441 |
int i; |
442 |
VARDEF *vp; |
443 |
/* if fn is NULL then relink all */ |
444 |
445 |
446 |
if ((vp->lib != NULL) | (fn == NULL) || !strcmp(fn, vp->name)) |
447 |
vp->lib = liblookup(vp->name); |
448 |
449 |
450 |
451 |
void |
452 |
varfree( /* release link to variable */ |
453 |
VARDEF *ln |
454 |
455 |
456 |
VARDEF *vp; |
457 |
int hv; |
458 |
459 |
if (--ln->nlinks > 0) |
460 |
return; /* still active */ |
461 |
462 |
hv = hash(ln->name); |
463 |
vp = hashtbl[hv]; |
464 |
if (vp == ln) |
465 |
hashtbl[hv] = vp->next; |
466 |
else { |
467 |
while (vp->next != ln) /* must be in list */ |
468 |
vp = vp->next; |
469 |
vp->next = ln->next; |
470 |
471 |
freestr(ln->name); |
472 |
efree((char *)ln); |
473 |
474 |
475 |
476 |
EPNODE * |
477 |
dfirst(void) /* return pointer to first definition */ |
478 |
479 |
htndx = 0; |
480 |
htpos = NULL; |
481 |
ochpos = outchan; |
482 |
return(dnext()); |
483 |
484 |
485 |
486 |
EPNODE * |
487 |
dnext(void) /* return pointer to next definition */ |
488 |
489 |
EPNODE *ep; |
490 |
char *nm; |
491 |
492 |
while (htndx < NHASH) { |
493 |
if (htpos == NULL) |
494 |
htpos = hashtbl[htndx++]; |
495 |
while (htpos != NULL) { |
496 |
ep = htpos->def; |
497 |
nm = htpos->name; |
498 |
htpos = htpos->next; |
499 |
if (ep != NULL && incontext(nm)) |
500 |
return(ep); |
501 |
502 |
503 |
if ((ep = ochpos) != NULL) |
504 |
ochpos = ep->sibling; |
505 |
return(ep); |
506 |
507 |
508 |
509 |
EPNODE * |
510 |
dpop( /* pop a definition */ |
511 |
char *name |
512 |
513 |
514 |
VARDEF *vp; |
515 |
EPNODE *dp; |
516 |
517 |
if ((vp = varlookup(name)) == NULL || vp->def == NULL) |
518 |
return(NULL); |
519 |
dp = vp->def; |
520 |
vp->def = dp->sibling; |
521 |
varfree(vp); |
522 |
return(dp); |
523 |
524 |
525 |
526 |
void |
527 |
dpush( /* push on a definition */ |
528 |
char *nm, |
529 |
EPNODE *ep |
530 |
531 |
532 |
VARDEF *vp; |
533 |
534 |
vp = varinsert(nm); |
535 |
ep->sibling = vp->def; |
536 |
vp->def = ep; |
537 |
538 |
539 |
540 |
void |
541 |
addchan( /* add an output channel assignment */ |
542 |
EPNODE *sp |
543 |
544 |
545 |
int ch = sp->v.kid->v.chan; |
546 |
EPNODE *ep, *epl; |
547 |
548 |
for (epl = NULL, ep = outchan; ep != NULL; epl = ep, ep = ep->sibling) |
549 |
if (ep->v.kid->v.chan >= ch) { |
550 |
if (epl != NULL) |
551 |
epl->sibling = sp; |
552 |
else |
553 |
outchan = sp; |
554 |
if (ep->v.kid->v.chan > ch) |
555 |
sp->sibling = ep; |
556 |
else { |
557 |
sp->sibling = ep->sibling; |
558 |
epfree(ep); |
559 |
560 |
return; |
561 |
562 |
if (epl != NULL) |
563 |
564 |
else |
565 |
outchan = sp; |
566 |
sp->sibling = NULL; |
567 |
568 |
569 |
570 |
571 |
void |
572 |
getstatement(void) /* get next statement */ |
573 |
574 |
EPNODE *ep; |
575 |
char *qname; |
576 |
VARDEF *vdef; |
577 |
578 |
if (nextc == ';') { /* empty statement */ |
579 |
scan(); |
580 |
return; |
581 |
582 |
if (esupport&E_OUTCHAN && |
583 |
nextc == '$') { /* channel assignment */ |
584 |
ep = getchan(); |
585 |
addchan(ep); |
586 |
} else { /* ordinary definition */ |
587 |
ep = getdefn(); |
588 |
qname = qualname(dname(ep), 0); |
589 |
if (esupport&E_REDEFW && (vdef = varlookup(qname)) != NULL) { |
590 |
if (vdef->def != NULL && epcmp(ep, vdef->def)) { |
591 |
wputs(qname); |
592 |
if (vdef->def->type == ':') |
593 |
wputs(": redefined constant expression\n"); |
594 |
else |
595 |
wputs(": redefined\n"); |
596 |
} else if (ep->v.kid->type == FUNC && vdef->lib != NULL) { |
597 |
wputs(qname); |
598 |
wputs(": definition hides library function\n"); |
599 |
600 |
601 |
if (ep->type == ':') |
602 |
dremove(qname); |
603 |
else |
604 |
dclear(qname); |
605 |
dpush(qname, ep); |
606 |
607 |
if (nextc != EOF) { |
608 |
if (nextc != ';') |
609 |
syntax("';' expected"); |
610 |
scan(); |
611 |
612 |
613 |
614 |
615 |
EPNODE * |
616 |
getdefn(void) |
617 |
/* A -> SYM = E1 */ |
618 |
/* SYM : E1 */ |
619 |
/* FUNC(SYM,..) = E1 */ |
620 |
/* FUNC(SYM,..) : E1 */ |
621 |
622 |
623 |
624 |
if (!isalpha(nextc) & (nextc != CNTXMARK)) |
625 |
syntax("illegal variable name"); |
626 |
627 |
ep1 = newnode(); |
628 |
ep1->type = SYM; |
629 |
ep1->v.name = savestr(getname()); |
630 |
631 |
if (esupport&E_FUNCTION && nextc == '(') { |
632 |
ep2 = newnode(); |
633 |
ep2->type = FUNC; |
634 |
addekid(ep2, ep1); |
635 |
ep1 = ep2; |
636 |
do { |
637 |
scan(); |
638 |
if (!isalpha(nextc)) |
639 |
syntax("illegal parameter name"); |
640 |
ep2 = newnode(); |
641 |
ep2->type = SYM; |
642 |
ep2->v.name = savestr(getname()); |
643 |
if (strchr(ep2->v.name, CNTXMARK) != NULL) |
644 |
645 |
646 |
} while (nextc == ','); |
647 |
if (nextc != ')') |
648 |
syntax("')' expected"); |
649 |
scan(); |
650 |
curfunc = ep1; |
651 |
652 |
653 |
if ((nextc != '=') & (nextc != ':')) |
654 |
syntax("'=' or ':' expected"); |
655 |
656 |
ep2 = newnode(); |
657 |
ep2->type = nextc; |
658 |
scan(); |
659 |
660 |
addekid(ep2, getE1()); |
661 |
662 |
if (ep1->type == SYM && ep1->sibling->type != NUM) { |
663 |
ep1 = newnode(); |
664 |
ep1->type = CLKT; |
665 |
ep1->v.tick = 0; |
666 |
667 |
ep1 = newnode(); |
668 |
ep1->type = NUM; |
669 |
670 |
671 |
curfunc = NULL; |
672 |
673 |
return(ep2); |
674 |
675 |
676 |
677 |
EPNODE * |
678 |
getchan(void) /* A -> $N = E1 */ |
679 |
680 |
681 |
682 |
if (nextc != '$') |
683 |
syntax("missing '$'"); |
684 |
scan(); |
685 |
686 |
ep1 = newnode(); |
687 |
ep1->type = CHAN; |
688 |
ep1->v.chan = getinum(); |
689 |
690 |
if (nextc != '=') |
691 |
syntax("'=' expected"); |
692 |
scan(); |
693 |
694 |
ep2 = newnode(); |
695 |
ep2->type = '='; |
696 |
697 |
698 |
699 |
return(ep2); |
700 |
701 |
702 |
703 |
704 |
705 |
* The following routines are for internal use only: |
706 |
707 |
708 |
709 |
static double /* evaluate a variable */ |
710 |
dvalue(char *name, EPNODE *d) |
711 |
712 |
713 |
714 |
if (d == NULL || d->v.kid->type != SYM) { |
715 |
eputs(name); |
716 |
eputs(": undefined variable\n"); |
717 |
quit(1); |
718 |
719 |
ep1 = d->v.kid->sibling; /* get expression */ |
720 |
if (ep1->type == NUM) |
721 |
return(ep1->v.num); /* return if number */ |
722 |
if (esupport&E_RCONST && d->type == ':') { |
723 |
wputs(name); |
724 |
wputs(": assigned non-constant value\n"); |
725 |
726 |
ep2 = ep1->sibling; /* check time */ |
727 |
if (eclock >= MAXCLOCK) |
728 |
eclock = 1; /* wrap clock counter */ |
729 |
if (ep2->v.tick < MAXCLOCK && |
730 |
(ep2->v.tick == 0) | (ep2->v.tick != eclock)) { |
731 |
ep2->v.tick = d->type == ':' ? MAXCLOCK : eclock; |
732 |
ep2 = ep2->sibling; |
733 |
ep2->v.num = evalue(ep1); /* needs new value */ |
734 |
} else |
735 |
ep2 = ep2->sibling; /* else reuse old value */ |
736 |
737 |
return(ep2->v.num); |
738 |
