root/radiance/ray/src/common/caldefn.c
Revision: 2.1
Committed: Tue Nov 12 16:55:27 1991 UTC (33 years, 9 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Store variable definitions.
9 *
10 * 7/1/85 Greg Ward
11 *
12 * 11/11/85 Added conditional compiles (OUTCHAN) for control output.
13 *
14 * 4/2/86 Added conditional compiles for function definitions (FUNCTION).
15 *
16 * 1/15/88 Added clock for caching of variable values.
17 *
18 * 11/16/88 Added VARDEF structure for hard linking.
19 *
20 * 5/31/90 Added conditional compile (REDEFW) for redefinition warning.
21 *
22 * 4/23/91 Added ':' assignment for constant expressions
23 *
24 * 8/7/91 Added optional context path to append to variable names
25 */
26
27 #include <stdio.h>
28
29 #include <ctype.h>
30
31 #include "calcomp.h"
32
33 #ifndef NHASH
34 #define NHASH 521 /* hash size (a prime!) */
35 #endif
36
37 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
38
39 extern char *ecalloc(), *savestr(), *strcpy();
40
41 static int hash();
42
43 static double dvalue();
44
45 long eclock = -1; /* value storage timer */
46
47 static char context[MAXWORD+1]; /* current context path */
48
49 static VARDEF *hashtbl[NHASH]; /* definition list */
50 static int htndx; /* index for */
51 static VARDEF *htpos; /* ...dfirst() and */
52 #ifdef OUTCHAN
53 static EPNODE *ochpos; /* ...dnext */
54 static EPNODE *outchan;
55 #endif
56
57 #ifdef FUNCTION
58 EPNODE *curfunc;
59 #define dname(ep) ((ep)->v.kid->type == SYM ? \
60 (ep)->v.kid->v.name : \
61 (ep)->v.kid->v.kid->v.name)
62 #else
63 #define dname(ep) ((ep)->v.kid->v.name)
64 #endif
65
66
67 fcompile(fname) /* get definitions from a file */
68 char *fname;
69 {
70 FILE *fp;
71
72 if (fname == NULL)
73 fp = stdin;
74 else if ((fp = fopen(fname, "r")) == NULL) {
75 eputs(fname);
76 eputs(": cannot open\n");
77 quit(1);
78 }
79 initfile(fp, fname, 0);
80 while (nextc != EOF)
81 getstatement();
82 if (fname != NULL)
83 fclose(fp);
84 }
85
86
87 scompile(str, fn, ln) /* get definitions from a string */
88 char *str;
89 char *fn;
90 int ln;
91 {
92 initstr(str, fn, ln);
93 while (nextc != EOF)
94 getstatement();
95 }
96
97
98 double
99 varvalue(vname) /* return a variable's value */
100 char *vname;
101 {
102 return(dvalue(vname, dlookup(vname)));
103 }
104
105
106 double
107 evariable(ep) /* evaluate a variable */
108 EPNODE *ep;
109 {
110 register VARDEF *dp = ep->v.ln;
111
112 return(dvalue(dp->name, dp->def));
113 }
114
115
116 varset(vname, assign, val) /* set a variable's value */
117 char *vname;
118 int assign;
119 double val;
120 {
121 char *qname;
122 register EPNODE *ep1, *ep2;
123 /* get qualified name */
124 qname = qualname(vname, 0);
125 /* check for quick set */
126 if ((ep1 = dlookup(qname)) != NULL && ep1->v.kid->type == SYM) {
127 ep2 = ep1->v.kid->sibling;
128 if (ep2->type == NUM) {
129 ep2->v.num = val;
130 ep1->type = assign;
131 return;
132 }
133 }
134 /* hand build definition */
135 ep1 = newnode();
136 ep1->type = assign;
137 ep2 = newnode();
138 ep2->type = SYM;
139 ep2->v.name = savestr(vname);
140 addekid(ep1, ep2);
141 ep2 = newnode();
142 ep2->type = NUM;
143 ep2->v.num = val;
144 addekid(ep1, ep2);
145 dremove(qname);
146 dpush(qname, ep1);
147 }
148
149
150 dclear(name) /* delete variable definitions of name */
151 char *name;
152 {
153 register EPNODE *ep;
154
155 while ((ep = dpop(name)) != NULL) {
156 if (ep->type == ':') {
157 dpush(name, ep); /* don't clear constants */
158 return;
159 }
160 epfree(ep);
161 }
162 }
163
164
165 dremove(name) /* delete all definitions of name */
166 char *name;
167 {
168 register EPNODE *ep;
169
170 while ((ep = dpop(name)) != NULL)
171 epfree(ep);
172 }
173
174
175 vardefined(name) /* return non-zero if variable defined */
176 char *name;
177 {
178 register EPNODE *dp;
179
180 return((dp = dlookup(name)) != NULL && dp->v.kid->type == SYM);
181 }
182
183
184 char *
185 setcontext(ctx) /* set a new context path */
186 register char *ctx;
187 {
188 register char *cpp;
189
190 if (ctx == NULL)
191 return(context); /* just asking */
192 if (!*ctx) {
193 context[0] = '\0'; /* clear context */
194 return(context);
195 }
196 cpp = context; /* else copy it (carefully!) */
197 if (*ctx != CNTXMARK)
198 *cpp++ = CNTXMARK; /* make sure there's a mark */
199 do {
200 if (cpp >= context+MAXWORD)
201 break; /* just copy what we can */
202 if (isid(*ctx))
203 *cpp++ = *ctx++;
204 else {
205 *cpp++ = '_'; ctx++;
206 }
207 } while (*ctx);
208 *cpp = '\0';
209 return(context);
210 }
211
212
213 char *
214 qualname(nam, lvl) /* get qualified name */
215 register char *nam;
216 int lvl;
217 {
218 static char nambuf[MAXWORD+1];
219 register char *cp = nambuf, *cpp;
220 /* check for explicit local */
221 if (*nam == CNTXMARK)
222 if (lvl > 0) /* only action is to refuse search */
223 return(NULL);
224 else
225 nam++;
226 else if (nam == nambuf) /* check for repeat call */
227 return(lvl > 0 ? NULL : nam);
228 /* copy name to static buffer */
229 while (*nam) {
230 if (cp >= nambuf+MAXWORD)
231 goto toolong;
232 *cp++ = *nam++;
233 }
234 /* check for explicit global */
235 if (cp > nambuf && cp[-1] == CNTXMARK) {
236 if (lvl > 0)
237 return(NULL);
238 *--cp = '\0';
239 return(nambuf); /* already qualified */
240 }
241 cpp = context; /* else skip the requested levels */
242 while (lvl-- > 0) {
243 if (!*cpp)
244 return(NULL); /* return NULL if past global level */
245 while (*++cpp && *cpp != CNTXMARK)
246 ;
247 }
248 while (*cpp) { /* copy context to static buffer */
249 if (cp >= nambuf+MAXWORD)
250 goto toolong;
251 *cp++ = *cpp++;
252 }
253 toolong:
254 *cp = '\0';
255 return(nambuf); /* return qualified name */
256 }
257
258
259 incontext(qn) /* is qualified name in current context? */
260 register char *qn;
261 {
262 while (*qn && *qn != CNTXMARK) /* find context mark */
263 qn++;
264 return(!strcmp(qn, context));
265 }
266
267
268 #ifdef OUTCHAN
269 chanout(cs) /* set output channels */
270 int (*cs)();
271 {
272 register EPNODE *ep;
273
274 for (ep = outchan; ep != NULL; ep = ep->sibling)
275 (*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling));
276
277 }
278 #endif
279
280
281 dcleanup(lvl) /* clear definitions (0->vars,1->output,2->consts) */
282 int lvl;
283 {
284 register int i;
285 register VARDEF *vp;
286 register EPNODE *ep;
287 /* if context is global, clear all */
288 for (i = 0; i < NHASH; i++)
289 for (vp = hashtbl[i]; vp != NULL; vp = vp->next)
290 if (!context[0] || incontext(vp->name))
291 if (lvl >= 2)
292 dremove(vp->name);
293 else
294 dclear(vp->name);
295 #ifdef OUTCHAN
296 if (lvl >= 1) {
297 for (ep = outchan; ep != NULL; ep = ep->sibling)
298 epfree(ep);
299 outchan = NULL;
300 }
301 #endif
302 }
303
304
305 EPNODE *
306 dlookup(name) /* look up a definition */
307 char *name;
308 {
309 register VARDEF *vp;
310
311 if ((vp = varlookup(name)) == NULL)
312 return(NULL);
313 return(vp->def);
314 }
315
316
317 VARDEF *
318 varlookup(name) /* look up a variable */
319 char *name;
320 {
321 int lvl = 0;
322 register char *qname;
323 register VARDEF *vp;
324 /* find most qualified match */
325 while ((qname = qualname(name, lvl++)) != NULL)
326 for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next)
327 if (!strcmp(vp->name, qname))
328 return(vp);
329 return(NULL);
330 }
331
332
333 VARDEF *
334 varinsert(name) /* get a link to a variable */
335 char *name;
336 {
337 register VARDEF *vp;
338 LIBR *libp;
339 int hv;
340
341 if ((vp = varlookup(name)) != NULL) {
342 vp->nlinks++;
343 return(vp);
344 }
345 #ifdef FUNCTION
346 libp = liblookup(name);
347 #else
348 libp = NULL;
349 #endif
350 if (libp == NULL) /* if name not in library */
351 name = qualname(name, 0); /* use fully qualified version */
352 hv = hash(name);
353 vp = (VARDEF *)emalloc(sizeof(VARDEF));
354 vp->name = savestr(name);
355 vp->nlinks = 1;
356 vp->def = NULL;
357 vp->lib = libp;
358 vp->next = hashtbl[hv];
359 hashtbl[hv] = vp;
360 return(vp);
361 }
362
363
364 varfree(ln) /* release link to variable */
365 register VARDEF *ln;
366 {
367 register VARDEF *vp;
368 int hv;
369
370 if (--ln->nlinks > 0)
371 return; /* still active */
372
373 hv = hash(ln->name);
374 vp = hashtbl[hv];
375 if (vp == ln)
376 hashtbl[hv] = vp->next;
377 else {
378 while (vp->next != ln) /* must be in list */
379 vp = vp->next;
380 vp->next = ln->next;
381 }
382 freestr(ln->name);
383 efree((char *)ln);
384 }
385
386
387 EPNODE *
388 dfirst() /* return pointer to first definition */
389 {
390 htndx = 0;
391 htpos = NULL;
392 #ifdef OUTCHAN
393 ochpos = outchan;
394 #endif
395 return(dnext());
396 }
397
398
399 EPNODE *
400 dnext() /* return pointer to next definition */
401 {
402 register EPNODE *ep;
403 register char *nm;
404
405 while (htndx < NHASH) {
406 if (htpos == NULL)
407 htpos = hashtbl[htndx++];
408 while (htpos != NULL) {
409 ep = htpos->def;
410 nm = htpos->name;
411 htpos = htpos->next;
412 if (ep != NULL && incontext(nm))
413 return(ep);
414 }
415 }
416 #ifdef OUTCHAN
417 if ((ep = ochpos) != NULL)
418 ochpos = ep->sibling;
419 return(ep);
420 #else
421 return(NULL);
422 #endif
423 }
424
425
426 EPNODE *
427 dpop(name) /* pop a definition */
428 char *name;
429 {
430 register VARDEF *vp;
431 register EPNODE *dp;
432
433 if ((vp = varlookup(name)) == NULL || vp->def == NULL)
434 return(NULL);
435 dp = vp->def;
436 vp->def = dp->sibling;
437 varfree(vp);
438 return(dp);
439 }
440
441
442 dpush(nm, ep) /* push on a definition */
443 char *nm;
444 register EPNODE *ep;
445 {
446 register VARDEF *vp;
447
448 vp = varinsert(nm);
449 ep->sibling = vp->def;
450 vp->def = ep;
451 }
452
453
454 #ifdef OUTCHAN
455 addchan(sp) /* add an output channel assignment */
456 EPNODE *sp;
457 {
458 int ch = sp->v.kid->v.chan;
459 register EPNODE *ep, *epl;
460
461 for (epl = NULL, ep = outchan; ep != NULL; epl = ep, ep = ep->sibling)
462 if (ep->v.kid->v.chan >= ch) {
463 if (epl != NULL)
464 epl->sibling = sp;
465 else
466 outchan = sp;
467 if (ep->v.kid->v.chan > ch)
468 sp->sibling = ep;
469 else {
470 sp->sibling = ep->sibling;
471 epfree(ep);
472 }
473 return;
474 }
475 if (epl != NULL)
476 epl->sibling = sp;
477 else
478 outchan = sp;
479 sp->sibling = NULL;
480
481 }
482 #endif
483
484
485 getstatement() /* get next statement */
486 {
487 register EPNODE *ep;
488 char *qname;
489 register VARDEF *vdef;
490
491 if (nextc == ';') { /* empty statement */
492 scan();
493 return;
494 }
495 #ifdef OUTCHAN
496 if (nextc == '$') { /* channel assignment */
497 ep = getchan();
498 addchan(ep);
499 } else
500 #endif
501 { /* ordinary definition */
502 ep = getdefn();
503 qname = qualname(dname(ep), 0);
504 #ifdef REDEFW
505 if ((vdef = varlookup(qname)) != NULL)
506 if (vdef->def != NULL) {
507 wputs(qname);
508 if (vdef->def->type == ':')
509 wputs(": redefined constant expression\n");
510 else
511 wputs(": redefined\n");
512 }
513 #ifdef FUNCTION
514 else if (ep->v.kid->type == FUNC && vdef->lib != NULL) {
515 wputs(qname);
516 wputs(": definition hides library function\n");
517 }
518 #endif
519 #endif
520 if (ep->type == ':')
521 dremove(qname);
522 else
523 dclear(qname);
524 dpush(qname, ep);
525 }
526 if (nextc != EOF) {
527 if (nextc != ';')
528 syntax("';' expected");
529 scan();
530 }
531 }
532
533
534 EPNODE *
535 getdefn() /* A -> SYM = E1 */
536 /* SYM : E1 */
537 /* FUNC(SYM,..) = E1 */
538 /* FUNC(SYM,..) : E1 */
539 {
540 register EPNODE *ep1, *ep2;
541
542 if (!isalpha(nextc) && nextc != CNTXMARK)
543 syntax("illegal variable name");
544
545 ep1 = newnode();
546 ep1->type = SYM;
547 ep1->v.name = savestr(getname());
548
549 #ifdef FUNCTION
550 if (nextc == '(') {
551 ep2 = newnode();
552 ep2->type = FUNC;
553 addekid(ep2, ep1);
554 ep1 = ep2;
555 do {
556 scan();
557 if (!isalpha(nextc))
558 syntax("illegal variable name");
559 ep2 = newnode();
560 ep2->type = SYM;
561 ep2->v.name = savestr(getname());
562 addekid(ep1, ep2);
563 } while (nextc == ',');
564 if (nextc != ')')
565 syntax("')' expected");
566 scan();
567 curfunc = ep1;
568 } else
569 curfunc = NULL;
570 #endif
571
572 if (nextc != '=' && nextc != ':')
573 syntax("'=' or ':' expected");
574
575 ep2 = newnode();
576 ep2->type = nextc;
577 scan();
578 addekid(ep2, ep1);
579 addekid(ep2, getE1());
580
581 if (
582 #ifdef FUNCTION
583 ep1->type == SYM &&
584 #endif
585 ep1->sibling->type != NUM) {
586 ep1 = newnode();
587 ep1->type = TICK;
588 ep1->v.tick = -1;
589 addekid(ep2, ep1);
590 ep1 = newnode();
591 ep1->type = NUM;
592 addekid(ep2, ep1);
593 }
594
595 return(ep2);
596 }
597
598
599 #ifdef OUTCHAN
600 EPNODE *
601 getchan() /* A -> $N = E1 */
602 {
603 register EPNODE *ep1, *ep2;
604
605 if (nextc != '$')
606 syntax("missing '$'");
607 scan();
608
609 ep1 = newnode();
610 ep1->type = CHAN;
611 ep1->v.chan = getinum();
612
613 if (nextc != '=')
614 syntax("'=' expected");
615 scan();
616
617 ep2 = newnode();
618 ep2->type = '=';
619 addekid(ep2, ep1);
620 addekid(ep2, getE1());
621
622 return(ep2);
623 }
624 #endif
625
626
627
628 /*
629 * The following routines are for internal use only:
630 */
631
632
633 static double
634 dvalue(name, d) /* evaluate a variable */
635 char *name;
636 EPNODE *d;
637 {
638 register EPNODE *ep1, *ep2;
639
640 if (d == NULL || d->v.kid->type != SYM) {
641 eputs(name);
642 eputs(": undefined variable\n");
643 quit(1);
644 }
645 ep1 = d->v.kid->sibling; /* get expression */
646 if (ep1->type == NUM)
647 return(ep1->v.num); /* return if number */
648 ep2 = ep1->sibling; /* check time */
649 if (ep2->v.tick < 0 || ep2->v.tick < eclock) {
650 ep2->v.tick = d->type == ':' ? 1L<<30 : eclock;
651 ep2 = ep2->sibling;
652 ep2->v.num = evalue(ep1); /* needs new value */
653 } else
654 ep2 = ep2->sibling; /* else reuse old value */
655
656 return(ep2->v.num);
657 }
658
659
660 static int
661 hash(s) /* hash a string */
662 register char *s;
663 {
664 register int rval = 0;
665
666 while (*s)
667 rval += *s++;
668
669 return(rval % NHASH);
670 }
