--- ray/src/common/caldefn.c 1995/03/28 11:18:52 2.9
+++ ray/src/common/caldefn.c 2003/02/22 02:07:21 2.12
@@ -1,9 +1,6 @@
-/* Copyright (c) 1992 Regents of the University of California */
#ifndef lint
-static char SCCSid[] = "$SunId$ LBL";
+static const char RCSid[] = "$Id: caldefn.c,v 2.12 2003/02/22 02:07:21 greg Exp $";
#endif
* Store variable definitions.
@@ -22,10 +19,73 @@ static char SCCSid[] = "$SunId$ LBL";
* 4/23/91 Added ':' assignment for constant expressions
* 8/7/91 Added optional context path to append to variable names
+ * 5/17/2001 Fixed clock counter wrapping behavior
+ * 2/19/03 Eliminated conditional compiles in favor of esupport extern.
+ * The Radiance Software License, Version 1.0
+ * Copyright (c) 1990 - 2002 The Regents of the University of California,
+ * through Lawrence Berkeley National Laboratory. All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * 3. The end-user documentation included with the redistribution,
+ * if any, must include the following acknowledgment:
+ * "This product includes Radiance software
+ * (http://radsite.lbl.gov/)
+ * developed by the Lawrence Berkeley National Laboratory
+ * (http://www.lbl.gov/)."
+ * Alternately, this acknowledgment may appear in the software itself,
+ * if and wherever such third-party acknowledgments normally appear.
+ * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
+ * and "The Regents of the University of California" must
+ * not be used to endorse or promote products derived from this
+ * software without prior written permission. For written
+ * permission, please contact radiance@radsite.lbl.gov.
+ * 5. Products derived from this software may not be called "Radiance",
+ * nor may "Radiance" appear in their name, without prior written
+ * permission of Lawrence Berkeley National Laboratory.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
+ * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This software consists of voluntary contributions made by many
+ * individuals on behalf of Lawrence Berkeley National Laboratory. For more
+ * information on Lawrence Berkeley National Laboratory, please see
#include
+#include
#include
#include "calcomp.h"
@@ -38,32 +98,29 @@ static char SCCSid[] = "$SunId$ LBL";
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
-extern char *ecalloc(), *emalloc(), *savestr(), *strcpy();
static double dvalue();
+#define MAXCLOCK (1L<<31) /* clock wrap value */
unsigned long eclock = 0; /* value storage timer */
-static char context[MAXWORD+1]; /* current context path */
+#define MAXCNTX 1023 /* maximum context length */
+static char context[MAXCNTX+1]; /* current context path */
static VARDEF *hashtbl[NHASH]; /* definition list */
static int htndx; /* index for */
static VARDEF *htpos; /* ...dfirst() and */
-#ifdef OUTCHAN
static EPNODE *ochpos; /* ...dnext */
static EPNODE *outchan;
-#endif
-#ifdef FUNCTION
-EPNODE *curfunc;
+EPNODE *curfunc = NULL;
#define dname(ep) ((ep)->v.kid->type == SYM ? \
(ep)->v.kid->v.name : \
(ep)->v.kid->v.kid->v.name)
-#else
-#define dname(ep) ((ep)->v.kid->v.name)
-#endif
+void
fcompile(fname) /* get definitions from a file */
char *fname;
@@ -84,6 +141,7 @@ char *fname;
+void
scompile(str, fn, ln) /* get definitions from a string */
char *str;
char *fn;
@@ -113,6 +171,7 @@ EPNODE *ep;
+void
varset(vname, assign, val) /* set a variable's value */
char *vname;
int assign;
@@ -147,6 +206,7 @@ double val;
+void
dclear(name) /* delete variable definitions of name */
char *name;
@@ -162,6 +222,7 @@ char *name;
+void
dremove(name) /* delete all definitions of name */
char *name;
@@ -172,6 +233,7 @@ char *name;
+int
vardefined(name) /* return non-zero if variable defined */
char *name;
@@ -198,7 +260,7 @@ register char *ctx;
cpp = context; /* start context with mark */
*cpp++ = CNTXMARK;
do { /* carefully copy new context */
- if (cpp >= context+MAXWORD)
+ if (cpp >= context+MAXCNTX)
break; /* just copy what we can */
if (isid(*ctx))
*cpp++ = *ctx++;
@@ -218,15 +280,15 @@ pushcontext(ctx) /* push on another context */
char *ctx;
extern char *strncpy(), *strcpy();
- char oldcontext[MAXWORD+1];
+ char oldcontext[MAXCNTX+1];
register int n;
strcpy(oldcontext, context); /* save old context */
setcontext(ctx); /* set new context */
n = strlen(context); /* tack on old */
- if (n+strlen(oldcontext) > MAXWORD) {
- strncpy(context+n, oldcontext, MAXWORD-n);
- context[MAXWORD] = '\0';
+ if (n+strlen(oldcontext) > MAXCNTX) {
+ strncpy(context+n, oldcontext, MAXCNTX-n);
+ context[MAXCNTX] = '\0';
} else
strcpy(context+n, oldcontext);
return(context);
@@ -296,6 +358,7 @@ toolong:
+int
incontext(qn) /* is qualified name in current context? */
register char *qn;
@@ -307,7 +370,7 @@ register char *qn;
-#ifdef OUTCHAN
+void
chanout(cs) /* set output channels */
int (*cs)();
@@ -317,9 +380,9 @@ int (*cs)();
(*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling));
-#endif
+void
dcleanup(lvl) /* clear definitions (0->vars,1->output,2->consts) */
int lvl;
@@ -334,13 +397,11 @@ int lvl;
dremove(vp->name);
else
dclear(vp->name);
-#ifdef OUTCHAN
if (lvl >= 1) {
for (ep = outchan; ep != NULL; ep = ep->sibling)
epfree(ep);
outchan = NULL;
-#endif
@@ -384,11 +445,7 @@ char *name;
return(vp);
vp = (VARDEF *)emalloc(sizeof(VARDEF));
-#ifdef FUNCTION
vp->lib = liblookup(name);
-#else
- vp->lib = NULL;
-#endif
if (vp->lib == NULL) /* if name not in library */
name = qualname(name, 0); /* use fully qualified version */
hv = hash(name);
@@ -401,7 +458,7 @@ char *name;
-#ifdef FUNCTION
+void
libupdate(fn) /* update library links */
char *fn;
@@ -413,9 +470,9 @@ char *fn;
if (vp->lib != NULL || fn == NULL || !strcmp(fn, vp->name))
vp->lib = liblookup(vp->name);
-#endif
+void
varfree(ln) /* release link to variable */
register VARDEF *ln;
@@ -444,9 +501,7 @@ dfirst() /* return pointer to first definition */
htndx = 0;
htpos = NULL;
-#ifdef OUTCHAN
ochpos = outchan;
-#endif
return(dnext());
@@ -468,13 +523,9 @@ dnext() /* return pointer to next definition */
return(ep);
-#ifdef OUTCHAN
if ((ep = ochpos) != NULL)
ochpos = ep->sibling;
return(ep);
-#else
- return(NULL);
-#endif
@@ -494,6 +545,7 @@ char *name;
+void
dpush(nm, ep) /* push on a definition */
char *nm;
register EPNODE *ep;
@@ -506,7 +558,7 @@ register EPNODE *ep;
-#ifdef OUTCHAN
+void
addchan(sp) /* add an output channel assignment */
EPNODE *sp;
@@ -534,9 +586,9 @@ EPNODE *sp;
sp->sibling = NULL;
-#endif
+void
getstatement() /* get next statement */
@@ -547,31 +599,24 @@ getstatement() /* get next statement */
scan();
return;
-#ifdef OUTCHAN
- if (nextc == '$') { /* channel assignment */
+ if (esupport&E_OUTCHAN &&
+ nextc == '$') { /* channel assignment */
ep = getchan();
addchan(ep);
- } else
-#endif
- { /* ordinary definition */
+ } else { /* ordinary definition */
ep = getdefn();
qname = qualname(dname(ep), 0);
-#ifdef REDEFW
- if ((vdef = varlookup(qname)) != NULL)
+ if (esupport&E_REDEFW && (vdef = varlookup(qname)) != NULL)
if (vdef->def != NULL && epcmp(ep, vdef->def)) {
wputs(qname);
if (vdef->def->type == ':')
wputs(": redefined constant expression\n");
else
wputs(": redefined\n");
-#ifdef FUNCTION
- else if (ep->v.kid->type == FUNC && vdef->lib != NULL) {
+ } else if (ep->v.kid->type == FUNC && vdef->lib != NULL) {
wputs(qname);
wputs(": definition hides library function\n");
-#endif
-#endif
if (ep->type == ':')
dremove(qname);
else
@@ -601,8 +646,7 @@ getdefn() /* A -> SYM = E1 */
ep1->type = SYM;
ep1->v.name = savestr(getname());
-#ifdef FUNCTION
- if (nextc == '(') {
+ if (esupport&E_FUNCTION && nextc == '(') {
ep2 = newnode();
ep2->type = FUNC;
addekid(ep2, ep1);
@@ -620,9 +664,7 @@ getdefn() /* A -> SYM = E1 */
syntax("')' expected");
scan();
curfunc = ep1;
- } else
- curfunc = NULL;
-#endif
if (nextc != '=' && nextc != ':')
syntax("'=' or ':' expected");
@@ -633,11 +675,7 @@ getdefn() /* A -> SYM = E1 */
addekid(ep2, ep1);
addekid(ep2, getE1());
- if (
-#ifdef FUNCTION
- ep1->type == SYM &&
-#endif
- ep1->sibling->type != NUM) {
+ if (ep1->type == SYM && ep1->sibling->type != NUM) {
ep1 = newnode();
ep1->type = TICK;
ep1->v.tick = 0;
@@ -646,12 +684,12 @@ getdefn() /* A -> SYM = E1 */
ep1->type = NUM;
addekid(ep2, ep1);
+ curfunc = NULL;
return(ep2);
-#ifdef OUTCHAN
EPNODE *
getchan() /* A -> $N = E1 */
@@ -676,7 +714,6 @@ getchan() /* A -> $N = E1 */
return(ep2);
-#endif
@@ -701,8 +738,11 @@ EPNODE *d;
if (ep1->type == NUM)
return(ep1->v.num); /* return if number */
ep2 = ep1->sibling; /* check time */
- if (ep2->v.tick == 0 || ep2->v.tick < eclock) {
- ep2->v.tick = d->type == ':' ? ~0L : eclock;
+ if (eclock >= MAXCLOCK)
+ eclock = 1; /* wrap clock counter */
+ if (ep2->v.tick < MAXCLOCK &&
+ ep2->v.tick == 0 | ep2->v.tick != eclock) {
+ ep2->v.tick = d->type == ':' ? MAXCLOCK : eclock;
ep2 = ep2->sibling;
ep2->v.num = evalue(ep1); /* needs new value */
} else
