1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Store variable definitions. |
9 |
10 |
* 7/1/85 Greg Ward |
11 |
12 |
* 11/11/85 Added conditional compiles (OUTCHAN) for control output. |
13 |
14 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION). |
15 |
16 |
* 1/15/88 Added clock for caching of variable values. |
17 |
18 |
* 11/16/88 Added VARDEF structure for hard linking. |
19 |
20 |
* 5/31/90 Added conditional compile (REDEFW) for redefinition warning. |
21 |
22 |
* 4/23/91 Added ':' assignment for constant expressions |
23 |
24 |
* 8/7/91 Added optional context path to append to variable names |
25 |
26 |
27 |
#include <stdio.h> |
28 |
29 |
#include <ctype.h> |
30 |
31 |
#include "calcomp.h" |
32 |
33 |
#ifndef NHASH |
34 |
#define NHASH 521 /* hash size (a prime!) */ |
35 |
#endif |
36 |
37 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) |
38 |
39 |
extern char *ecalloc(), *emalloc(), *savestr(), *strcpy(); |
40 |
41 |
static int hash(); |
42 |
43 |
static double dvalue(); |
44 |
45 |
long eclock = -1; /* value storage timer */ |
46 |
47 |
static char context[MAXWORD+1]; /* current context path */ |
48 |
49 |
static VARDEF *hashtbl[NHASH]; /* definition list */ |
50 |
static int htndx; /* index for */ |
51 |
static VARDEF *htpos; /* ...dfirst() and */ |
52 |
#ifdef OUTCHAN |
53 |
static EPNODE *ochpos; /* ...dnext */ |
54 |
static EPNODE *outchan; |
55 |
#endif |
56 |
57 |
#ifdef FUNCTION |
58 |
EPNODE *curfunc; |
59 |
#define dname(ep) ((ep)->v.kid->type == SYM ? \ |
60 |
(ep)->v.kid->v.name : \ |
61 |
(ep)->v.kid->v.kid->v.name) |
62 |
#else |
63 |
#define dname(ep) ((ep)->v.kid->v.name) |
64 |
#endif |
65 |
66 |
67 |
fcompile(fname) /* get definitions from a file */ |
68 |
char *fname; |
69 |
70 |
FILE *fp; |
71 |
72 |
if (fname == NULL) |
73 |
fp = stdin; |
74 |
else if ((fp = fopen(fname, "r")) == NULL) { |
75 |
eputs(fname); |
76 |
eputs(": cannot open\n"); |
77 |
quit(1); |
78 |
79 |
initfile(fp, fname, 0); |
80 |
while (nextc != EOF) |
81 |
getstatement(); |
82 |
if (fname != NULL) |
83 |
fclose(fp); |
84 |
85 |
86 |
87 |
scompile(str, fn, ln) /* get definitions from a string */ |
88 |
char *str; |
89 |
char *fn; |
90 |
int ln; |
91 |
92 |
initstr(str, fn, ln); |
93 |
94 |
getstatement(); |
95 |
96 |
97 |
98 |
double |
99 |
varvalue(vname) /* return a variable's value */ |
100 |
char *vname; |
101 |
102 |
return(dvalue(vname, dlookup(vname))); |
103 |
104 |
105 |
106 |
double |
107 |
evariable(ep) /* evaluate a variable */ |
108 |
EPNODE *ep; |
109 |
110 |
register VARDEF *dp = ep->v.ln; |
111 |
112 |
return(dvalue(dp->name, dp->def)); |
113 |
114 |
115 |
116 |
varset(vname, assign, val) /* set a variable's value */ |
117 |
char *vname; |
118 |
int assign; |
119 |
double val; |
120 |
121 |
char *qname; |
122 |
register EPNODE *ep1, *ep2; |
123 |
/* get qualified name */ |
124 |
qname = qualname(vname, 0); |
125 |
/* check for quick set */ |
126 |
if ((ep1 = dlookup(qname)) != NULL && ep1->v.kid->type == SYM) { |
127 |
ep2 = ep1->v.kid->sibling; |
128 |
if (ep2->type == NUM) { |
129 |
ep2->v.num = val; |
130 |
ep1->type = assign; |
131 |
return; |
132 |
133 |
134 |
/* hand build definition */ |
135 |
ep1 = newnode(); |
136 |
137 |
ep2 = newnode(); |
138 |
ep2->type = SYM; |
139 |
ep2->v.name = savestr(vname); |
140 |
addekid(ep1, ep2); |
141 |
ep2 = newnode(); |
142 |
ep2->type = NUM; |
143 |
ep2->v.num = val; |
144 |
145 |
dremove(qname); |
146 |
dpush(qname, ep1); |
147 |
148 |
149 |
150 |
dclear(name) /* delete variable definitions of name */ |
151 |
char *name; |
152 |
153 |
register EPNODE *ep; |
154 |
155 |
while ((ep = dpop(name)) != NULL) { |
156 |
if (ep->type == ':') { |
157 |
dpush(name, ep); /* don't clear constants */ |
158 |
return; |
159 |
160 |
epfree(ep); |
161 |
162 |
163 |
164 |
165 |
dremove(name) /* delete all definitions of name */ |
166 |
char *name; |
167 |
168 |
169 |
170 |
while ((ep = dpop(name)) != NULL) |
171 |
epfree(ep); |
172 |
173 |
174 |
175 |
vardefined(name) /* return non-zero if variable defined */ |
176 |
char *name; |
177 |
178 |
register EPNODE *dp; |
179 |
180 |
return((dp = dlookup(name)) != NULL && dp->v.kid->type == SYM); |
181 |
182 |
183 |
184 |
char * |
185 |
setcontext(ctx) /* set a new context path */ |
186 |
register char *ctx; |
187 |
188 |
register char *cpp; |
189 |
190 |
if (ctx == NULL) |
191 |
return(context); /* just asking */ |
192 |
if (!*ctx) { |
193 |
context[0] = '\0'; /* clear context */ |
194 |
return(context); |
195 |
196 |
cpp = context; /* else copy it (carefully!) */ |
197 |
if (*ctx != CNTXMARK) |
198 |
*cpp++ = CNTXMARK; /* make sure there's a mark */ |
199 |
do { |
200 |
if (cpp >= context+MAXWORD) |
201 |
break; /* just copy what we can */ |
202 |
if (isid(*ctx)) |
203 |
*cpp++ = *ctx++; |
204 |
else { |
205 |
*cpp++ = '_'; ctx++; |
206 |
207 |
} while (*ctx); |
208 |
*cpp = '\0'; |
209 |
return(context); |
210 |
211 |
212 |
213 |
char * |
214 |
qualname(nam, lvl) /* get qualified name */ |
215 |
register char *nam; |
216 |
int lvl; |
217 |
218 |
static char nambuf[MAXWORD+1]; |
219 |
register char *cp = nambuf, *cpp; |
220 |
/* check for explicit local */ |
221 |
if (*nam == CNTXMARK) |
222 |
if (lvl > 0) /* only action is to refuse search */ |
223 |
return(NULL); |
224 |
else |
225 |
nam++; |
226 |
else if (nam == nambuf) /* check for repeat call */ |
227 |
return(lvl > 0 ? NULL : nam); |
228 |
/* copy name to static buffer */ |
229 |
while (*nam) { |
230 |
if (cp >= nambuf+MAXWORD) |
231 |
goto toolong; |
232 |
*cp++ = *nam++; |
233 |
234 |
/* check for explicit global */ |
235 |
if (cp > nambuf && cp[-1] == CNTXMARK) { |
236 |
if (lvl > 0) |
237 |
return(NULL); |
238 |
*--cp = '\0'; |
239 |
return(nambuf); /* already qualified */ |
240 |
241 |
cpp = context; /* else skip the requested levels */ |
242 |
while (lvl-- > 0) { |
243 |
if (!*cpp) |
244 |
return(NULL); /* return NULL if past global level */ |
245 |
while (*++cpp && *cpp != CNTXMARK) |
246 |
247 |
248 |
while (*cpp) { /* copy context to static buffer */ |
249 |
250 |
goto toolong; |
251 |
*cp++ = *cpp++; |
252 |
253 |
toolong: |
254 |
*cp = '\0'; |
255 |
return(nambuf); /* return qualified name */ |
256 |
257 |
258 |
259 |
incontext(qn) /* is qualified name in current context? */ |
260 |
register char *qn; |
261 |
262 |
while (*qn && *qn != CNTXMARK) /* find context mark */ |
263 |
qn++; |
264 |
return(!strcmp(qn, context)); |
265 |
266 |
267 |
268 |
#ifdef OUTCHAN |
269 |
chanout(cs) /* set output channels */ |
270 |
int (*cs)(); |
271 |
272 |
273 |
274 |
for (ep = outchan; ep != NULL; ep = ep->sibling) |
275 |
(*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling)); |
276 |
277 |
278 |
#endif |
279 |
280 |
281 |
dcleanup(lvl) /* clear definitions (0->vars,1->output,2->consts) */ |
282 |
int lvl; |
283 |
284 |
register int i; |
285 |
register VARDEF *vp; |
286 |
287 |
/* if context is global, clear all */ |
288 |
for (i = 0; i < NHASH; i++) |
289 |
for (vp = hashtbl[i]; vp != NULL; vp = vp->next) |
290 |
if (!context[0] || incontext(vp->name)) |
291 |
if (lvl >= 2) |
292 |
dremove(vp->name); |
293 |
else |
294 |
dclear(vp->name); |
295 |
#ifdef OUTCHAN |
296 |
if (lvl >= 1) { |
297 |
298 |
epfree(ep); |
299 |
outchan = NULL; |
300 |
301 |
#endif |
302 |
303 |
304 |
305 |
EPNODE * |
306 |
dlookup(name) /* look up a definition */ |
307 |
char *name; |
308 |
309 |
310 |
311 |
if ((vp = varlookup(name)) == NULL) |
312 |
return(NULL); |
313 |
return(vp->def); |
314 |
315 |
316 |
317 |
VARDEF * |
318 |
varlookup(name) /* look up a variable */ |
319 |
char *name; |
320 |
321 |
int lvl = 0; |
322 |
register char *qname; |
323 |
324 |
/* find most qualified match */ |
325 |
while ((qname = qualname(name, lvl++)) != NULL) |
326 |
for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next) |
327 |
if (!strcmp(vp->name, qname)) |
328 |
return(vp); |
329 |
return(NULL); |
330 |
331 |
332 |
333 |
VARDEF * |
334 |
varinsert(name) /* get a link to a variable */ |
335 |
char *name; |
336 |
337 |
338 |
int hv; |
339 |
340 |
if ((vp = varlookup(name)) != NULL) { |
341 |
vp->nlinks++; |
342 |
return(vp); |
343 |
344 |
vp = (VARDEF *)emalloc(sizeof(VARDEF)); |
345 |
#ifdef FUNCTION |
346 |
vp->lib = liblookup(name); |
347 |
#else |
348 |
vp->lib = NULL; |
349 |
#endif |
350 |
if (vp->lib == NULL) /* if name not in library */ |
351 |
name = qualname(name, 0); /* use fully qualified version */ |
352 |
hv = hash(name); |
353 |
vp->name = savestr(name); |
354 |
vp->nlinks = 1; |
355 |
vp->def = NULL; |
356 |
vp->next = hashtbl[hv]; |
357 |
hashtbl[hv] = vp; |
358 |
return(vp); |
359 |
360 |
361 |
362 |
#ifdef FUNCTION |
363 |
libupdate(fn) /* update library links */ |
364 |
char *fn; |
365 |
366 |
register int i; |
367 |
368 |
/* if fn is NULL then relink all */ |
369 |
370 |
371 |
if (vp->lib != NULL || fn == NULL || !strcmp(fn, vp->name)) |
372 |
vp->lib = liblookup(vp->name); |
373 |
374 |
#endif |
375 |
376 |
377 |
varfree(ln) /* release link to variable */ |
378 |
register VARDEF *ln; |
379 |
380 |
381 |
int hv; |
382 |
383 |
if (--ln->nlinks > 0) |
384 |
return; /* still active */ |
385 |
386 |
hv = hash(ln->name); |
387 |
vp = hashtbl[hv]; |
388 |
if (vp == ln) |
389 |
hashtbl[hv] = vp->next; |
390 |
else { |
391 |
while (vp->next != ln) /* must be in list */ |
392 |
vp = vp->next; |
393 |
vp->next = ln->next; |
394 |
395 |
freestr(ln->name); |
396 |
efree((char *)ln); |
397 |
398 |
399 |
400 |
EPNODE * |
401 |
dfirst() /* return pointer to first definition */ |
402 |
403 |
htndx = 0; |
404 |
htpos = NULL; |
405 |
#ifdef OUTCHAN |
406 |
ochpos = outchan; |
407 |
#endif |
408 |
return(dnext()); |
409 |
410 |
411 |
412 |
EPNODE * |
413 |
dnext() /* return pointer to next definition */ |
414 |
415 |
416 |
register char *nm; |
417 |
418 |
while (htndx < NHASH) { |
419 |
if (htpos == NULL) |
420 |
htpos = hashtbl[htndx++]; |
421 |
while (htpos != NULL) { |
422 |
ep = htpos->def; |
423 |
nm = htpos->name; |
424 |
htpos = htpos->next; |
425 |
if (ep != NULL && incontext(nm)) |
426 |
return(ep); |
427 |
428 |
429 |
#ifdef OUTCHAN |
430 |
if ((ep = ochpos) != NULL) |
431 |
ochpos = ep->sibling; |
432 |
return(ep); |
433 |
#else |
434 |
return(NULL); |
435 |
#endif |
436 |
437 |
438 |
439 |
EPNODE * |
440 |
dpop(name) /* pop a definition */ |
441 |
char *name; |
442 |
443 |
444 |
445 |
446 |
if ((vp = varlookup(name)) == NULL || vp->def == NULL) |
447 |
return(NULL); |
448 |
dp = vp->def; |
449 |
vp->def = dp->sibling; |
450 |
varfree(vp); |
451 |
return(dp); |
452 |
453 |
454 |
455 |
dpush(nm, ep) /* push on a definition */ |
456 |
char *nm; |
457 |
458 |
459 |
460 |
461 |
vp = varinsert(nm); |
462 |
ep->sibling = vp->def; |
463 |
vp->def = ep; |
464 |
465 |
466 |
467 |
#ifdef OUTCHAN |
468 |
addchan(sp) /* add an output channel assignment */ |
469 |
EPNODE *sp; |
470 |
471 |
int ch = sp->v.kid->v.chan; |
472 |
register EPNODE *ep, *epl; |
473 |
474 |
for (epl = NULL, ep = outchan; ep != NULL; epl = ep, ep = ep->sibling) |
475 |
if (ep->v.kid->v.chan >= ch) { |
476 |
if (epl != NULL) |
477 |
epl->sibling = sp; |
478 |
else |
479 |
outchan = sp; |
480 |
if (ep->v.kid->v.chan > ch) |
481 |
sp->sibling = ep; |
482 |
else { |
483 |
sp->sibling = ep->sibling; |
484 |
epfree(ep); |
485 |
486 |
return; |
487 |
488 |
if (epl != NULL) |
489 |
490 |
else |
491 |
outchan = sp; |
492 |
sp->sibling = NULL; |
493 |
494 |
495 |
#endif |
496 |
497 |
498 |
getstatement() /* get next statement */ |
499 |
500 |
501 |
char *qname; |
502 |
register VARDEF *vdef; |
503 |
504 |
if (nextc == ';') { /* empty statement */ |
505 |
scan(); |
506 |
return; |
507 |
508 |
#ifdef OUTCHAN |
509 |
if (nextc == '$') { /* channel assignment */ |
510 |
ep = getchan(); |
511 |
addchan(ep); |
512 |
} else |
513 |
#endif |
514 |
{ /* ordinary definition */ |
515 |
ep = getdefn(); |
516 |
qname = qualname(dname(ep), 0); |
517 |
#ifdef REDEFW |
518 |
if ((vdef = varlookup(qname)) != NULL) |
519 |
if (vdef->def != NULL) { |
520 |
wputs(qname); |
521 |
if (vdef->def->type == ':') |
522 |
wputs(": redefined constant expression\n"); |
523 |
else |
524 |
wputs(": redefined\n"); |
525 |
526 |
#ifdef FUNCTION |
527 |
else if (ep->v.kid->type == FUNC && vdef->lib != NULL) { |
528 |
wputs(qname); |
529 |
wputs(": definition hides library function\n"); |
530 |
531 |
#endif |
532 |
#endif |
533 |
if (ep->type == ':') |
534 |
dremove(qname); |
535 |
else |
536 |
dclear(qname); |
537 |
dpush(qname, ep); |
538 |
539 |
if (nextc != EOF) { |
540 |
if (nextc != ';') |
541 |
syntax("';' expected"); |
542 |
scan(); |
543 |
544 |
545 |
546 |
547 |
EPNODE * |
548 |
getdefn() /* A -> SYM = E1 */ |
549 |
/* SYM : E1 */ |
550 |
/* FUNC(SYM,..) = E1 */ |
551 |
/* FUNC(SYM,..) : E1 */ |
552 |
553 |
554 |
555 |
if (!isalpha(nextc) && nextc != CNTXMARK) |
556 |
syntax("illegal variable name"); |
557 |
558 |
ep1 = newnode(); |
559 |
ep1->type = SYM; |
560 |
ep1->v.name = savestr(getname()); |
561 |
562 |
#ifdef FUNCTION |
563 |
if (nextc == '(') { |
564 |
ep2 = newnode(); |
565 |
ep2->type = FUNC; |
566 |
addekid(ep2, ep1); |
567 |
ep1 = ep2; |
568 |
do { |
569 |
scan(); |
570 |
if (!isalpha(nextc)) |
571 |
572 |
ep2 = newnode(); |
573 |
ep2->type = SYM; |
574 |
ep2->v.name = savestr(getname()); |
575 |
576 |
} while (nextc == ','); |
577 |
if (nextc != ')') |
578 |
syntax("')' expected"); |
579 |
scan(); |
580 |
curfunc = ep1; |
581 |
} else |
582 |
curfunc = NULL; |
583 |
#endif |
584 |
585 |
if (nextc != '=' && nextc != ':') |
586 |
syntax("'=' or ':' expected"); |
587 |
588 |
ep2 = newnode(); |
589 |
ep2->type = nextc; |
590 |
scan(); |
591 |
592 |
addekid(ep2, getE1()); |
593 |
594 |
if ( |
595 |
#ifdef FUNCTION |
596 |
ep1->type == SYM && |
597 |
#endif |
598 |
ep1->sibling->type != NUM) { |
599 |
ep1 = newnode(); |
600 |
ep1->type = TICK; |
601 |
ep1->v.tick = -1; |
602 |
603 |
ep1 = newnode(); |
604 |
ep1->type = NUM; |
605 |
606 |
607 |
608 |
return(ep2); |
609 |
610 |
611 |
612 |
#ifdef OUTCHAN |
613 |
EPNODE * |
614 |
getchan() /* A -> $N = E1 */ |
615 |
616 |
617 |
618 |
if (nextc != '$') |
619 |
syntax("missing '$'"); |
620 |
scan(); |
621 |
622 |
ep1 = newnode(); |
623 |
ep1->type = CHAN; |
624 |
ep1->v.chan = getinum(); |
625 |
626 |
if (nextc != '=') |
627 |
syntax("'=' expected"); |
628 |
scan(); |
629 |
630 |
ep2 = newnode(); |
631 |
ep2->type = '='; |
632 |
633 |
634 |
635 |
return(ep2); |
636 |
637 |
#endif |
638 |
639 |
640 |
641 |
642 |
* The following routines are for internal use only: |
643 |
644 |
645 |
646 |
static double |
647 |
dvalue(name, d) /* evaluate a variable */ |
648 |
char *name; |
649 |
EPNODE *d; |
650 |
651 |
652 |
653 |
if (d == NULL || d->v.kid->type != SYM) { |
654 |
eputs(name); |
655 |
eputs(": undefined variable\n"); |
656 |
quit(1); |
657 |
658 |
ep1 = d->v.kid->sibling; /* get expression */ |
659 |
if (ep1->type == NUM) |
660 |
return(ep1->v.num); /* return if number */ |
661 |
ep2 = ep1->sibling; /* check time */ |
662 |
if (ep2->v.tick < 0 || ep2->v.tick < eclock) { |
663 |
ep2->v.tick = d->type == ':' ? 1L<<30 : eclock; |
664 |
ep2 = ep2->sibling; |
665 |
ep2->v.num = evalue(ep1); /* needs new value */ |
666 |
} else |
667 |
ep2 = ep2->sibling; /* else reuse old value */ |
668 |
669 |
return(ep2->v.num); |
670 |
671 |
672 |
673 |
static int |
674 |
hash(s) /* hash a string */ |
675 |
register char *s; |
676 |
677 |
register int rval = 0; |
678 |
679 |
while (*s) |
680 |
rval += *s++; |
681 |
682 |
return(rval % NHASH); |
683 |
