--- ray/src/common/caldefn.c 1990/05/31 10:24:28 1.2 +++ ray/src/common/caldefn.c 1991/08/14 08:27:56 1.18 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -18,6 +18,10 @@ static char SCCSid[] = "$SunId$ LBL"; * 11/16/88 Added VARDEF structure for hard linking. * * 5/31/90 Added conditional compile (REDEFW) for redefinition warning. + * + * 4/23/91 Added ':' assignment for constant expressions + * + * 8/7/91 Added optional context path to append to variable names */ #include @@ -32,12 +36,14 @@ static char SCCSid[] = "$SunId$ LBL"; #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) -extern char *ecalloc(), *savestr(); +extern char *ecalloc(), *savestr(), *strcpy(); -extern double dvalue(); +static double dvalue(); long eclock = -1; /* value storage timer */ +static char context[MAXWORD+1]; /* current context path */ + static VARDEF *hashtbl[NHASH]; /* definition list */ static int htndx; /* index for */ static VARDEF *htpos; /* ...dfirst() and */ @@ -68,21 +74,22 @@ char *fname; eputs(": cannot open\n"); quit(1); } - initfile(fname, fp); + initfile(fp, fname, 0); while (nextc != EOF) - loaddefn(); + getstatement(); if (fname != NULL) fclose(fp); } -scompile(file, str) /* get definitions from a string */ -char *file; +scompile(str, fn, ln) /* get definitions from a string */ char *str; +char *fn; +int ln; { - initstr(file, str); + initstr(str, fn, ln); while (nextc != EOF) - loaddefn(); + getstatement(); } @@ -104,23 +111,27 @@ EPNODE *ep; } -varset(vname, val) /* set a variable's value */ +varset(vname, assign, val) /* set a variable's value */ char *vname; +int assign; double val; { + char *qname; register EPNODE *ep1, *ep2; + /* get qualified name */ + qname = qualname(vname, 0); /* check for quick set */ - if ((ep1 = dlookup(vname)) != NULL && ep1->v.kid->type == SYM) { + if ((ep1 = dlookup(qname)) != NULL && ep1->v.kid->type == SYM) { ep2 = ep1->v.kid->sibling; if (ep2->type == NUM) { ep2->v.num = val; - ep2->sibling->v.tick = -1; + ep1->type = assign; return; } } /* hand build definition */ ep1 = newnode(); - ep1->type = '='; + ep1->type = assign; ep2 = newnode(); ep2->type = SYM; ep2->v.name = savestr(vname); @@ -129,23 +140,31 @@ double val; ep2->type = NUM; ep2->v.num = val; addekid(ep1, ep2); - ep2 = newnode(); - ep2->type = TICK; - ep2->v.tick = -1; - addekid(ep1, ep2); - ep2 = newnode(); - ep2->type = NUM; - addekid(ep1, ep2); - dclear(vname); - dpush(ep1); + dremove(qname); + dpush(qname, ep1); } -dclear(name) /* delete all definitions of name */ +dclear(name) /* delete variable definitions of name */ char *name; { register EPNODE *ep; + while ((ep = dpop(name)) != NULL) { + if (ep->type == ':') { + dpush(name, ep); /* don't clear constants */ + return; + } + epfree(ep); + } +} + + +dremove(name) /* delete all definitions of name */ +char *name; +{ + register EPNODE *ep; + while ((ep = dpop(name)) != NULL) epfree(ep); } @@ -160,31 +179,123 @@ char *name; } +char * +setcontext(ctx) /* set a new context path */ +register char *ctx; +{ + register char *cpp; + + if (ctx == NULL) + return(context); /* just asking */ + if (!*ctx) { + context[0] = '\0'; /* clear context */ + return(context); + } + cpp = context; /* else copy it (carefully!) */ + if (*ctx != CNTXMARK) + *cpp++ = CNTXMARK; /* make sure there's a mark */ + do { + if (cpp >= context+MAXWORD) + break; /* just copy what we can */ + if (isid(*ctx)) + *cpp++ = *ctx++; + else { + *cpp++ = '_'; ctx++; + } + } while (*ctx); + *cpp = '\0'; + return(context); +} + + +char * +qualname(nam, lvl) /* get qualified name */ +register char *nam; +int lvl; +{ + static char nambuf[MAXWORD+1]; + register char *cp = nambuf, *cpp; + /* check for explicit local */ + if (*nam == CNTXMARK) + if (lvl > 0) /* only action is to refuse search */ + return(NULL); + else + nam++; + else if (nam == nambuf) /* check for repeat call */ + return(lvl > 0 ? NULL : nam); + /* copy name to static buffer */ + while (*nam) { + if (cp >= nambuf+MAXWORD) + goto toolong; + *cp++ = *nam++; + } + /* check for explicit global */ + if (cp > nambuf && cp[-1] == CNTXMARK) { + if (lvl > 0) + return(NULL); + *--cp = '\0'; + return(nambuf); /* already qualified */ + } + cpp = context; /* else skip the requested levels */ + while (lvl-- > 0) { + if (!*cpp) + return(NULL); /* return NULL if past global level */ + while (*++cpp && *cpp != CNTXMARK) + ; + } + while (*cpp) { /* copy context to static buffer */ + if (cp >= nambuf+MAXWORD) + goto toolong; + *cp++ = *cpp++; + } +toolong: + *cp = '\0'; + return(nambuf); /* return qualified name */ +} + + +incontext(qn) /* is qualified name in current context? */ +register char *qn; +{ + while (*qn && *qn != CNTXMARK) /* find context mark */ + ; + return(!strcmp(qn, context)); +} + + #ifdef OUTCHAN -chanout() /* set output channels */ +chanout(cs) /* set output channels */ +int (*cs)(); { register EPNODE *ep; for (ep = outchan; ep != NULL; ep = ep->sibling) - chanset(ep->v.kid->v.chan, evalue(ep->v.kid->sibling)); + (*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling)); } #endif -dclearall() /* clear all definitions */ +dcleanup(lvl) /* clear definitions (0->vars,1->output,2->consts) */ +int lvl; { register int i; register VARDEF *vp; register EPNODE *ep; - + /* if context is global, clear all */ for (i = 0; i < NHASH; i++) for (vp = hashtbl[i]; vp != NULL; vp = vp->next) - dclear(vp->name); + if (!context[0] || incontext(vp->name)) + if (lvl >= 2) + dremove(vp->name); + else + dclear(vp->name); #ifdef OUTCHAN - for (ep = outchan; ep != NULL; ep = ep->sibling) - epfree(ep); - outchan = NULL; + if (lvl >= 1) { + for (ep = outchan; ep != NULL; ep = ep->sibling) + epfree(ep); + outchan = NULL; + } #endif } @@ -205,11 +316,14 @@ VARDEF * varlookup(name) /* look up a variable */ char *name; { + int lvl = 0; + register char *qname; register VARDEF *vp; - - for (vp = hashtbl[hash(name)]; vp != NULL; vp = vp->next) - if (!strcmp(vp->name, name)) - return(vp); + /* find most qualified match */ + while ((qname = qualname(name, lvl++)) != NULL) + for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next) + if (!strcmp(vp->name, qname)) + return(vp); return(NULL); } @@ -219,19 +333,26 @@ varinsert(name) /* get a link to a variable */ char *name; { register VARDEF *vp; + LIBR *libp; int hv; + if ((vp = varlookup(name)) != NULL) { + vp->nlinks++; + return(vp); + } +#ifdef FUNCTION + libp = liblookup(name); +#else + libp = NULL; +#endif + if (libp == NULL) /* if name not in library */ + name = qualname(name, 0); /* use fully qualified version */ hv = hash(name); - for (vp = hashtbl[hv]; vp != NULL; vp = vp->next) - if (!strcmp(vp->name, name)) { - vp->nlinks++; - return(vp); - } vp = (VARDEF *)emalloc(sizeof(VARDEF)); vp->name = savestr(name); vp->nlinks = 1; vp->def = NULL; - vp->lib = NULL; + vp->lib = libp; vp->next = hashtbl[hv]; hashtbl[hv] = vp; return(vp); @@ -314,12 +435,13 @@ char *name; } -dpush(ep) /* push on a definition */ +dpush(nm, ep) /* push on a definition */ +char *nm; register EPNODE *ep; { register VARDEF *vp; - vp = varinsert(dname(ep)); + vp = varinsert(nm); ep->sibling = vp->def; vp->def = ep; } @@ -356,9 +478,11 @@ EPNODE *sp; #endif -loaddefn() /* load next definition */ +getstatement() /* get next statement */ { register EPNODE *ep; + char *qname; + register VARDEF *vdef; if (nextc == ';') { /* empty statement */ scan(); @@ -372,16 +496,28 @@ loaddefn() /* load next definition */ #endif { /* ordinary definition */ ep = getdefn(); + qname = qualname(dname(ep), 0); #ifdef REDEFW - if (dlookup(dname(ep)) != NULL) { - dclear(dname(ep)); - wputs(dname(ep)); - wputs(": redefined\n"); - } -#else - dclear(dname(ep)); + if ((vdef = varlookup(qname)) != NULL) + if (vdef->def != NULL) { + wputs(qname); + if (vdef->def->type == ':') + wputs(": redefined constant expression\n"); + else + wputs(": redefined\n"); + } +#ifdef FUNCTION + else if (ep->v.kid->type == FUNC && vdef->lib != NULL) { + wputs(qname); + wputs(": definition hides library function\n"); + } #endif - dpush(ep); +#endif + if (ep->type == ':') + dremove(qname); + else + dclear(qname); + dpush(qname, ep); } if (nextc != EOF) { if (nextc != ';') @@ -393,11 +529,13 @@ loaddefn() /* load next definition */ EPNODE * getdefn() /* A -> SYM = E1 */ + /* SYM : E1 */ /* FUNC(SYM,..) = E1 */ + /* FUNC(SYM,..) : E1 */ { register EPNODE *ep1, *ep2; - if (!isalpha(nextc)) + if (!isalpha(nextc) && nextc != CNTXMARK) syntax("illegal variable name"); ep1 = newnode(); @@ -427,19 +565,20 @@ getdefn() /* A -> SYM = E1 */ curfunc = NULL; #endif - if (nextc != '=') - syntax("'=' expected"); - scan(); + if (nextc != '=' && nextc != ':') + syntax("'=' or ':' expected"); ep2 = newnode(); - ep2->type = '='; + ep2->type = nextc; + scan(); addekid(ep2, ep1); addekid(ep2, getE1()); + if ( #ifdef FUNCTION - if (ep1->type == SYM) + ep1->type == SYM && #endif - { + ep1->sibling->type != NUM) { ep1 = newnode(); ep1->type = TICK; ep1->v.tick = -1; @@ -500,13 +639,15 @@ EPNODE *d; quit(1); } ep1 = d->v.kid->sibling; /* get expression */ + if (ep1->type == NUM) + return(ep1->v.num); /* return if number */ ep2 = ep1->sibling; /* check time */ if (ep2->v.tick < 0 || ep2->v.tick < eclock) { - ep2->v.tick = eclock; + ep2->v.tick = d->type == ':' ? 1L<<30 : eclock; ep2 = ep2->sibling; - ep2->v.num = evalue(ep1); /* compute new value */ + ep2->v.num = evalue(ep1); /* needs new value */ } else - ep2 = ep2->sibling; /* reuse old value */ + ep2 = ep2->sibling; /* else reuse old value */ return(ep2->v.num); }
