--- ray/src/common/caldefn.c 1990/07/19 11:15:31 1.5 +++ ray/src/common/caldefn.c 1995/02/16 09:49:27 2.7 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -18,6 +18,10 @@ static char SCCSid[] = "$SunId$ LBL"; * 11/16/88 Added VARDEF structure for hard linking. * * 5/31/90 Added conditional compile (REDEFW) for redefinition warning. + * + * 4/23/91 Added ':' assignment for constant expressions + * + * 8/7/91 Added optional context path to append to variable names */ #include @@ -26,33 +30,37 @@ static char SCCSid[] = "$SunId$ LBL"; #include "calcomp.h" -#ifndef NHASH -#define NHASH 521 /* hash size (a prime!) */ +#ifndef NHASH +#define NHASH 521 /* hash size (a prime!) */ #endif -#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) +#define hash(s) (shash(s)%NHASH) -extern char *ecalloc(), *savestr(); +#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) +extern char *ecalloc(), *emalloc(), *savestr(), *strcpy(); + static double dvalue(); long eclock = -1; /* value storage timer */ +static char context[MAXWORD+1]; /* current context path */ + static VARDEF *hashtbl[NHASH]; /* definition list */ static int htndx; /* index for */ static VARDEF *htpos; /* ...dfirst() and */ -#ifdef OUTCHAN +#ifdef OUTCHAN static EPNODE *ochpos; /* ...dnext */ static EPNODE *outchan; #endif -#ifdef FUNCTION -EPNODE *curfunc; -#define dname(ep) ((ep)->v.kid->type == SYM ? \ +#ifdef FUNCTION +EPNODE *curfunc; +#define dname(ep) ((ep)->v.kid->type == SYM ? \ (ep)->v.kid->v.name : \ (ep)->v.kid->v.kid->v.name) #else -#define dname(ep) ((ep)->v.kid->v.name) +#define dname(ep) ((ep)->v.kid->v.name) #endif @@ -70,7 +78,7 @@ char *fname; } initfile(fp, fname, 0); while (nextc != EOF) - loaddefn(); + getstatement(); if (fname != NULL) fclose(fp); } @@ -83,7 +91,7 @@ int ln; { initstr(str, fn, ln); while (nextc != EOF) - loaddefn(); + getstatement(); } @@ -97,7 +105,7 @@ char *vname; double evariable(ep) /* evaluate a variable */ -EPNODE *ep; +EPNODE *ep; { register VARDEF *dp = ep->v.ln; @@ -105,22 +113,27 @@ EPNODE *ep; } -varset(vname, val) /* set a variable's value */ +varset(vname, assign, val) /* set a variable's value */ char *vname; -double val; +int assign; +double val; { + char *qname; register EPNODE *ep1, *ep2; + /* get qualified name */ + qname = qualname(vname, 0); /* check for quick set */ - if ((ep1 = dlookup(vname)) != NULL && ep1->v.kid->type == SYM) { + if ((ep1 = dlookup(qname)) != NULL && ep1->v.kid->type == SYM) { ep2 = ep1->v.kid->sibling; if (ep2->type == NUM) { ep2->v.num = val; + ep1->type = assign; return; } } /* hand build definition */ ep1 = newnode(); - ep1->type = '='; + ep1->type = assign; ep2 = newnode(); ep2->type = SYM; ep2->v.name = savestr(vname); @@ -129,16 +142,31 @@ double val; ep2->type = NUM; ep2->v.num = val; addekid(ep1, ep2); - dclear(vname); - dpush(ep1); + dremove(qname); + dpush(qname, ep1); } -dclear(name) /* delete all definitions of name */ +dclear(name) /* delete variable definitions of name */ char *name; { register EPNODE *ep; + while ((ep = dpop(name)) != NULL) { + if (ep->type == ':') { + dpush(name, ep); /* don't clear constants */ + return; + } + epfree(ep); + } +} + + +dremove(name) /* delete all definitions of name */ +char *name; +{ + register EPNODE *ep; + while ((ep = dpop(name)) != NULL) epfree(ep); } @@ -153,31 +181,163 @@ char *name; } -#ifdef OUTCHAN -chanout() /* set output channels */ +char * +setcontext(ctx) /* set a new context path */ +register char *ctx; { + register char *cpp; + + if (ctx == NULL) + return(context); /* just asking */ + while (*ctx == CNTXMARK) + ctx++; /* skip past marks */ + if (!*ctx) { + context[0] = '\0'; /* empty means clear context */ + return(context); + } + cpp = context; /* start context with mark */ + *cpp++ = CNTXMARK; + do { /* carefully copy new context */ + if (cpp >= context+MAXWORD) + break; /* just copy what we can */ + if (isid(*ctx)) + *cpp++ = *ctx++; + else { + *cpp++ = '_'; ctx++; + } + } while (*ctx); + while (cpp[-1] == CNTXMARK) /* cannot end in context mark */ + cpp--; + *cpp = '\0'; + return(context); +} + + +char * +pushcontext(ctx) /* push on another context */ +char *ctx; +{ + extern char *strncpy(), *strcpy(); + char oldcontext[MAXWORD+1]; + register int n; + + strcpy(oldcontext, context); /* save old context */ + setcontext(ctx); /* set new context */ + n = strlen(context); /* tack on old */ + if (n+strlen(oldcontext) > MAXWORD) { + strncpy(context+n, oldcontext, MAXWORD-n); + context[MAXWORD] = '\0'; + } else + strcpy(context+n, oldcontext); + return(context); +} + + +char * +popcontext() /* pop off top context */ +{ + register char *cp1, *cp2; + + if (!context[0]) /* nothing left to pop */ + return(context); + cp2 = context; /* find mark */ + while (*++cp2 && *cp2 != CNTXMARK) + ; + cp1 = context; /* copy tail to front */ + while (*cp1++ = *cp2++) + ; + return(context); +} + + +char * +qualname(nam, lvl) /* get qualified name */ +register char *nam; +int lvl; +{ + static char nambuf[MAXWORD+1]; + register char *cp = nambuf, *cpp; + /* check for explicit local */ + if (*nam == CNTXMARK) + if (lvl > 0) /* only action is to refuse search */ + return(NULL); + else + nam++; + else if (nam == nambuf) /* check for repeat call */ + return(lvl > 0 ? NULL : nam); + /* copy name to static buffer */ + while (*nam) { + if (cp >= nambuf+MAXWORD) + goto toolong; + *cp++ = *nam++; + } + /* check for explicit global */ + if (cp > nambuf && cp[-1] == CNTXMARK) { + if (lvl > 0) + return(NULL); + *--cp = '\0'; + return(nambuf); /* already qualified */ + } + cpp = context; /* else skip the requested levels */ + while (lvl-- > 0) { + if (!*cpp) + return(NULL); /* return NULL if past global level */ + while (*++cpp && *cpp != CNTXMARK) + ; + } + while (*cpp) { /* copy context to static buffer */ + if (cp >= nambuf+MAXWORD) + goto toolong; + *cp++ = *cpp++; + } +toolong: + *cp = '\0'; + return(nambuf); /* return qualified name */ +} + + +incontext(qn) /* is qualified name in current context? */ +register char *qn; +{ + while (*qn && *qn != CNTXMARK) /* find context mark */ + qn++; + return(!strcmp(qn, context)); +} + + +#ifdef OUTCHAN +chanout(cs) /* set output channels */ +int (*cs)(); +{ register EPNODE *ep; for (ep = outchan; ep != NULL; ep = ep->sibling) - chanset(ep->v.kid->v.chan, evalue(ep->v.kid->sibling)); + (*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling)); } #endif -dclearall() /* clear all definitions */ +dcleanup(lvl) /* clear definitions (0->vars,1->output,2->consts) */ +int lvl; { register int i; register VARDEF *vp; register EPNODE *ep; - + /* if context is global, clear all */ for (i = 0; i < NHASH; i++) for (vp = hashtbl[i]; vp != NULL; vp = vp->next) - dclear(vp->name); -#ifdef OUTCHAN - for (ep = outchan; ep != NULL; ep = ep->sibling) - epfree(ep); - outchan = NULL; + if (!context[0] || incontext(vp->name)) + if (lvl >= 2) + dremove(vp->name); + else + dclear(vp->name); +#ifdef OUTCHAN + if (lvl >= 1) { + for (ep = outchan; ep != NULL; ep = ep->sibling) + epfree(ep); + outchan = NULL; + } #endif } @@ -189,7 +349,7 @@ char *name; register VARDEF *vp; if ((vp = varlookup(name)) == NULL) - return(NULL); + return(NULL); return(vp->def); } @@ -198,11 +358,14 @@ VARDEF * varlookup(name) /* look up a variable */ char *name; { + int lvl = 0; + register char *qname; register VARDEF *vp; - - for (vp = hashtbl[hash(name)]; vp != NULL; vp = vp->next) - if (!strcmp(vp->name, name)) - return(vp); + /* find most qualified match */ + while ((qname = qualname(name, lvl++)) != NULL) + for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next) + if (!strcmp(vp->name, qname)) + return(vp); return(NULL); } @@ -212,42 +375,62 @@ varinsert(name) /* get a link to a variable */ char *name; { register VARDEF *vp; - int hv; + int hv; - hv = hash(name); - for (vp = hashtbl[hv]; vp != NULL; vp = vp->next) - if (!strcmp(vp->name, name)) { - vp->nlinks++; - return(vp); - } + if ((vp = varlookup(name)) != NULL) { + vp->nlinks++; + return(vp); + } vp = (VARDEF *)emalloc(sizeof(VARDEF)); +#ifdef FUNCTION + vp->lib = liblookup(name); +#else + vp->lib = NULL; +#endif + if (vp->lib == NULL) /* if name not in library */ + name = qualname(name, 0); /* use fully qualified version */ + hv = hash(name); vp->name = savestr(name); vp->nlinks = 1; vp->def = NULL; - vp->lib = NULL; vp->next = hashtbl[hv]; hashtbl[hv] = vp; return(vp); } +#ifdef FUNCTION +libupdate(fn) /* update library links */ +char *fn; +{ + register int i; + register VARDEF *vp; + /* if fn is NULL then relink all */ + for (i = 0; i < NHASH; i++) + for (vp = hashtbl[i]; vp != NULL; vp = vp->next) + if (vp->lib != NULL || fn == NULL || !strcmp(fn, vp->name)) + vp->lib = liblookup(vp->name); +} +#endif + + varfree(ln) /* release link to variable */ -register VARDEF *ln; +register VARDEF *ln; { register VARDEF *vp; - int hv; + int hv; if (--ln->nlinks > 0) - return; /* still active */ + return; /* still active */ hv = hash(ln->name); vp = hashtbl[hv]; if (vp == ln) - hashtbl[hv] = vp->next; + hashtbl[hv] = vp->next; else { - while (vp->next != ln) /* must be in list */ - vp = vp->next; - vp->next = ln->next; + while (vp->next != ln) /* must be in list */ + vp = vp->next; + vp->next = ln->next; } freestr(ln->name); efree((char *)ln); @@ -259,7 +442,7 @@ dfirst() /* return pointer to first definition */ { htndx = 0; htpos = NULL; -#ifdef OUTCHAN +#ifdef OUTCHAN ochpos = outchan; #endif return(dnext()); @@ -270,20 +453,22 @@ EPNODE * dnext() /* return pointer to next definition */ { register EPNODE *ep; + register char *nm; while (htndx < NHASH) { - if (htpos == NULL) - htpos = hashtbl[htndx++]; - while (htpos != NULL) { - ep = htpos->def; - htpos = htpos->next; - if (ep != NULL) - return(ep); - } + if (htpos == NULL) + htpos = hashtbl[htndx++]; + while (htpos != NULL) { + ep = htpos->def; + nm = htpos->name; + htpos = htpos->next; + if (ep != NULL && incontext(nm)) + return(ep); + } } -#ifdef OUTCHAN +#ifdef OUTCHAN if ((ep = ochpos) != NULL) - ochpos = ep->sibling; + ochpos = ep->sibling; return(ep); #else return(NULL); @@ -299,7 +484,7 @@ char *name; register EPNODE *dp; if ((vp = varlookup(name)) == NULL || vp->def == NULL) - return(NULL); + return(NULL); dp = vp->def; vp->def = dp->sibling; varfree(vp); @@ -307,22 +492,23 @@ char *name; } -dpush(ep) /* push on a definition */ -register EPNODE *ep; +dpush(nm, ep) /* push on a definition */ +char *nm; +register EPNODE *ep; { register VARDEF *vp; - vp = varinsert(dname(ep)); + vp = varinsert(nm); ep->sibling = vp->def; vp->def = ep; } -#ifdef OUTCHAN +#ifdef OUTCHAN addchan(sp) /* add an output channel assignment */ -EPNODE *sp; +EPNODE *sp; { - int ch = sp->v.kid->v.chan; + int ch = sp->v.kid->v.chan; register EPNODE *ep, *epl; for (epl = NULL, ep = outchan; ep != NULL; epl = ep, ep = ep->sibling) @@ -349,15 +535,17 @@ EPNODE *sp; #endif -loaddefn() /* load next definition */ +getstatement() /* get next statement */ { register EPNODE *ep; + char *qname; + register VARDEF *vdef; if (nextc == ';') { /* empty statement */ scan(); return; } -#ifdef OUTCHAN +#ifdef OUTCHAN if (nextc == '$') { /* channel assignment */ ep = getchan(); addchan(ep); @@ -365,16 +553,28 @@ loaddefn() /* load next definition */ #endif { /* ordinary definition */ ep = getdefn(); -#ifdef REDEFW - if (dlookup(dname(ep)) != NULL) { - dclear(dname(ep)); - wputs(dname(ep)); - wputs(": redefined\n"); - } -#else - dclear(dname(ep)); + qname = qualname(dname(ep), 0); +#ifdef REDEFW + if ((vdef = varlookup(qname)) != NULL) + if (vdef->def != NULL && epcmp(ep, vdef->def)) { + wputs(qname); + if (vdef->def->type == ':') + wputs(": redefined constant expression\n"); + else + wputs(": redefined\n"); + } +#ifdef FUNCTION + else if (ep->v.kid->type == FUNC && vdef->lib != NULL) { + wputs(qname); + wputs(": definition hides library function\n"); + } #endif - dpush(ep); +#endif + if (ep->type == ':') + dremove(qname); + else + dclear(qname); + dpush(qname, ep); } if (nextc != EOF) { if (nextc != ';') @@ -386,18 +586,20 @@ loaddefn() /* load next definition */ EPNODE * getdefn() /* A -> SYM = E1 */ - /* FUNC(SYM,..) = E1 */ + /* SYM : E1 */ + /* FUNC(SYM,..) = E1 */ + /* FUNC(SYM,..) : E1 */ { register EPNODE *ep1, *ep2; - if (!isalpha(nextc)) + if (!isalpha(nextc) && nextc != CNTXMARK) syntax("illegal variable name"); ep1 = newnode(); ep1->type = SYM; ep1->v.name = savestr(getname()); -#ifdef FUNCTION +#ifdef FUNCTION if (nextc == '(') { ep2 = newnode(); ep2->type = FUNC; @@ -420,19 +622,20 @@ getdefn() /* A -> SYM = E1 */ curfunc = NULL; #endif - if (nextc != '=') - syntax("'=' expected"); - scan(); + if (nextc != '=' && nextc != ':') + syntax("'=' or ':' expected"); ep2 = newnode(); - ep2->type = '='; + ep2->type = nextc; + scan(); addekid(ep2, ep1); addekid(ep2, getE1()); -#ifdef FUNCTION - if (ep1->type == SYM) + if ( +#ifdef FUNCTION + ep1->type == SYM && #endif - { + ep1->sibling->type != NUM) { ep1 = newnode(); ep1->type = TICK; ep1->v.tick = -1; @@ -446,7 +649,7 @@ getdefn() /* A -> SYM = E1 */ } -#ifdef OUTCHAN +#ifdef OUTCHAN EPNODE * getchan() /* A -> $N = E1 */ { @@ -483,7 +686,7 @@ getchan() /* A -> $N = E1 */ static double dvalue(name, d) /* evaluate a variable */ char *name; -EPNODE *d; +EPNODE *d; { register EPNODE *ep1, *ep2; @@ -497,24 +700,11 @@ EPNODE *d; return(ep1->v.num); /* return if number */ ep2 = ep1->sibling; /* check time */ if (ep2->v.tick < 0 || ep2->v.tick < eclock) { - ep2->v.tick = eclock; + ep2->v.tick = d->type == ':' ? 1L<<30 : eclock; ep2 = ep2->sibling; ep2->v.num = evalue(ep1); /* needs new value */ } else ep2 = ep2->sibling; /* else reuse old value */ return(ep2->v.num); -} - - -static int -hash(s) /* hash a string */ -register char *s; -{ - register int rval = 0; - - while (*s) - rval += *s++; - - return(rval % NHASH); }
