1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Store variable definitions. |
9 |
10 |
* 7/1/85 Greg Ward |
11 |
12 |
* 11/11/85 Added conditional compiles (OUTCHAN) for control output. |
13 |
14 |
* 4/2/86 Added conditional compiles for function definitions (FUNCTION). |
15 |
16 |
* 1/15/88 Added clock for caching of variable values. |
17 |
18 |
* 11/16/88 Added VARDEF structure for hard linking. |
19 |
20 |
* 5/31/90 Added conditional compile (REDEFW) for redefinition warning. |
21 |
22 |
* 4/23/91 Added ':' assignment for constant expressions |
23 |
24 |
* 8/7/91 Added optional context path to append to variable names |
25 |
26 |
27 |
#include <stdio.h> |
28 |
29 |
#include <ctype.h> |
30 |
31 |
#include "calcomp.h" |
32 |
33 |
#ifndef NHASH |
34 |
#define NHASH 521 /* hash size (a prime!) */ |
35 |
#endif |
36 |
37 |
#define hash(s) (shash(s)%NHASH) |
38 |
39 |
#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) |
40 |
41 |
extern char *ecalloc(), *emalloc(), *savestr(), *strcpy(); |
42 |
43 |
static double dvalue(); |
44 |
45 |
unsigned long eclock = 0; /* value storage timer */ |
46 |
47 |
static char context[MAXWORD+1]; /* current context path */ |
48 |
49 |
static VARDEF *hashtbl[NHASH]; /* definition list */ |
50 |
static int htndx; /* index for */ |
51 |
static VARDEF *htpos; /* ...dfirst() and */ |
52 |
#ifdef OUTCHAN |
53 |
static EPNODE *ochpos; /* ...dnext */ |
54 |
static EPNODE *outchan; |
55 |
#endif |
56 |
57 |
#ifdef FUNCTION |
58 |
EPNODE *curfunc; |
59 |
#define dname(ep) ((ep)->v.kid->type == SYM ? \ |
60 |
(ep)->v.kid->v.name : \ |
61 |
(ep)->v.kid->v.kid->v.name) |
62 |
#else |
63 |
#define dname(ep) ((ep)->v.kid->v.name) |
64 |
#endif |
65 |
66 |
67 |
fcompile(fname) /* get definitions from a file */ |
68 |
char *fname; |
69 |
70 |
FILE *fp; |
71 |
72 |
if (fname == NULL) |
73 |
fp = stdin; |
74 |
else if ((fp = fopen(fname, "r")) == NULL) { |
75 |
eputs(fname); |
76 |
eputs(": cannot open\n"); |
77 |
quit(1); |
78 |
79 |
initfile(fp, fname, 0); |
80 |
while (nextc != EOF) |
81 |
getstatement(); |
82 |
if (fname != NULL) |
83 |
fclose(fp); |
84 |
85 |
86 |
87 |
scompile(str, fn, ln) /* get definitions from a string */ |
88 |
char *str; |
89 |
char *fn; |
90 |
int ln; |
91 |
92 |
initstr(str, fn, ln); |
93 |
94 |
getstatement(); |
95 |
96 |
97 |
98 |
double |
99 |
varvalue(vname) /* return a variable's value */ |
100 |
char *vname; |
101 |
102 |
return(dvalue(vname, dlookup(vname))); |
103 |
104 |
105 |
106 |
double |
107 |
evariable(ep) /* evaluate a variable */ |
108 |
EPNODE *ep; |
109 |
110 |
register VARDEF *dp = ep->v.ln; |
111 |
112 |
return(dvalue(dp->name, dp->def)); |
113 |
114 |
115 |
116 |
varset(vname, assign, val) /* set a variable's value */ |
117 |
char *vname; |
118 |
int assign; |
119 |
double val; |
120 |
121 |
char *qname; |
122 |
register EPNODE *ep1, *ep2; |
123 |
/* get qualified name */ |
124 |
qname = qualname(vname, 0); |
125 |
/* check for quick set */ |
126 |
if ((ep1 = dlookup(qname)) != NULL && ep1->v.kid->type == SYM) { |
127 |
ep2 = ep1->v.kid->sibling; |
128 |
if (ep2->type == NUM) { |
129 |
ep2->v.num = val; |
130 |
ep1->type = assign; |
131 |
return; |
132 |
133 |
134 |
/* hand build definition */ |
135 |
ep1 = newnode(); |
136 |
137 |
ep2 = newnode(); |
138 |
ep2->type = SYM; |
139 |
ep2->v.name = savestr(vname); |
140 |
addekid(ep1, ep2); |
141 |
ep2 = newnode(); |
142 |
ep2->type = NUM; |
143 |
ep2->v.num = val; |
144 |
145 |
dremove(qname); |
146 |
dpush(qname, ep1); |
147 |
148 |
149 |
150 |
dclear(name) /* delete variable definitions of name */ |
151 |
char *name; |
152 |
153 |
register EPNODE *ep; |
154 |
155 |
while ((ep = dpop(name)) != NULL) { |
156 |
if (ep->type == ':') { |
157 |
dpush(name, ep); /* don't clear constants */ |
158 |
return; |
159 |
160 |
epfree(ep); |
161 |
162 |
163 |
164 |
165 |
dremove(name) /* delete all definitions of name */ |
166 |
char *name; |
167 |
168 |
169 |
170 |
while ((ep = dpop(name)) != NULL) |
171 |
epfree(ep); |
172 |
173 |
174 |
175 |
vardefined(name) /* return non-zero if variable defined */ |
176 |
char *name; |
177 |
178 |
register EPNODE *dp; |
179 |
180 |
return((dp = dlookup(name)) != NULL && dp->v.kid->type == SYM); |
181 |
182 |
183 |
184 |
char * |
185 |
setcontext(ctx) /* set a new context path */ |
186 |
register char *ctx; |
187 |
188 |
register char *cpp; |
189 |
190 |
if (ctx == NULL) |
191 |
return(context); /* just asking */ |
192 |
while (*ctx == CNTXMARK) |
193 |
ctx++; /* skip past marks */ |
194 |
if (!*ctx) { |
195 |
context[0] = '\0'; /* empty means clear context */ |
196 |
return(context); |
197 |
198 |
cpp = context; /* start context with mark */ |
199 |
*cpp++ = CNTXMARK; |
200 |
do { /* carefully copy new context */ |
201 |
if (cpp >= context+MAXWORD) |
202 |
break; /* just copy what we can */ |
203 |
if (isid(*ctx)) |
204 |
*cpp++ = *ctx++; |
205 |
else { |
206 |
*cpp++ = '_'; ctx++; |
207 |
208 |
} while (*ctx); |
209 |
while (cpp[-1] == CNTXMARK) /* cannot end in context mark */ |
210 |
cpp--; |
211 |
*cpp = '\0'; |
212 |
return(context); |
213 |
214 |
215 |
216 |
char * |
217 |
pushcontext(ctx) /* push on another context */ |
218 |
char *ctx; |
219 |
220 |
extern char *strncpy(), *strcpy(); |
221 |
char oldcontext[MAXWORD+1]; |
222 |
register int n; |
223 |
224 |
strcpy(oldcontext, context); /* save old context */ |
225 |
setcontext(ctx); /* set new context */ |
226 |
n = strlen(context); /* tack on old */ |
227 |
if (n+strlen(oldcontext) > MAXWORD) { |
228 |
strncpy(context+n, oldcontext, MAXWORD-n); |
229 |
context[MAXWORD] = '\0'; |
230 |
} else |
231 |
strcpy(context+n, oldcontext); |
232 |
return(context); |
233 |
234 |
235 |
236 |
char * |
237 |
popcontext() /* pop off top context */ |
238 |
239 |
register char *cp1, *cp2; |
240 |
241 |
if (!context[0]) /* nothing left to pop */ |
242 |
return(context); |
243 |
cp2 = context; /* find mark */ |
244 |
while (*++cp2 && *cp2 != CNTXMARK) |
245 |
246 |
cp1 = context; /* copy tail to front */ |
247 |
while (*cp1++ = *cp2++) |
248 |
249 |
return(context); |
250 |
251 |
252 |
253 |
char * |
254 |
qualname(nam, lvl) /* get qualified name */ |
255 |
register char *nam; |
256 |
int lvl; |
257 |
258 |
static char nambuf[MAXWORD+1]; |
259 |
register char *cp = nambuf, *cpp; |
260 |
/* check for explicit local */ |
261 |
if (*nam == CNTXMARK) |
262 |
if (lvl > 0) /* only action is to refuse search */ |
263 |
return(NULL); |
264 |
else |
265 |
nam++; |
266 |
else if (nam == nambuf) /* check for repeat call */ |
267 |
return(lvl > 0 ? NULL : nam); |
268 |
/* copy name to static buffer */ |
269 |
while (*nam) { |
270 |
if (cp >= nambuf+MAXWORD) |
271 |
goto toolong; |
272 |
*cp++ = *nam++; |
273 |
274 |
/* check for explicit global */ |
275 |
if (cp > nambuf && cp[-1] == CNTXMARK) { |
276 |
if (lvl > 0) |
277 |
return(NULL); |
278 |
*--cp = '\0'; |
279 |
return(nambuf); /* already qualified */ |
280 |
281 |
cpp = context; /* else skip the requested levels */ |
282 |
while (lvl-- > 0) { |
283 |
if (!*cpp) |
284 |
return(NULL); /* return NULL if past global level */ |
285 |
while (*++cpp && *cpp != CNTXMARK) |
286 |
287 |
288 |
while (*cpp) { /* copy context to static buffer */ |
289 |
290 |
goto toolong; |
291 |
*cp++ = *cpp++; |
292 |
293 |
toolong: |
294 |
*cp = '\0'; |
295 |
return(nambuf); /* return qualified name */ |
296 |
297 |
298 |
299 |
incontext(qn) /* is qualified name in current context? */ |
300 |
register char *qn; |
301 |
302 |
if (!context[0]) /* global context accepts all */ |
303 |
return(1); |
304 |
while (*qn && *qn != CNTXMARK) /* find context mark */ |
305 |
qn++; |
306 |
return(!strcmp(qn, context)); |
307 |
308 |
309 |
310 |
#ifdef OUTCHAN |
311 |
chanout(cs) /* set output channels */ |
312 |
int (*cs)(); |
313 |
314 |
315 |
316 |
for (ep = outchan; ep != NULL; ep = ep->sibling) |
317 |
(*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling)); |
318 |
319 |
320 |
#endif |
321 |
322 |
323 |
dcleanup(lvl) /* clear definitions (0->vars,1->output,2->consts) */ |
324 |
int lvl; |
325 |
326 |
register int i; |
327 |
register VARDEF *vp; |
328 |
329 |
/* if context is global, clear all */ |
330 |
for (i = 0; i < NHASH; i++) |
331 |
for (vp = hashtbl[i]; vp != NULL; vp = vp->next) |
332 |
if (incontext(vp->name)) |
333 |
if (lvl >= 2) |
334 |
dremove(vp->name); |
335 |
else |
336 |
dclear(vp->name); |
337 |
#ifdef OUTCHAN |
338 |
if (lvl >= 1) { |
339 |
340 |
epfree(ep); |
341 |
outchan = NULL; |
342 |
343 |
#endif |
344 |
345 |
346 |
347 |
EPNODE * |
348 |
dlookup(name) /* look up a definition */ |
349 |
char *name; |
350 |
351 |
352 |
353 |
if ((vp = varlookup(name)) == NULL) |
354 |
return(NULL); |
355 |
return(vp->def); |
356 |
357 |
358 |
359 |
VARDEF * |
360 |
varlookup(name) /* look up a variable */ |
361 |
char *name; |
362 |
363 |
int lvl = 0; |
364 |
register char *qname; |
365 |
366 |
/* find most qualified match */ |
367 |
while ((qname = qualname(name, lvl++)) != NULL) |
368 |
for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next) |
369 |
if (!strcmp(vp->name, qname)) |
370 |
return(vp); |
371 |
return(NULL); |
372 |
373 |
374 |
375 |
VARDEF * |
376 |
varinsert(name) /* get a link to a variable */ |
377 |
char *name; |
378 |
379 |
380 |
int hv; |
381 |
382 |
if ((vp = varlookup(name)) != NULL) { |
383 |
vp->nlinks++; |
384 |
return(vp); |
385 |
386 |
vp = (VARDEF *)emalloc(sizeof(VARDEF)); |
387 |
#ifdef FUNCTION |
388 |
vp->lib = liblookup(name); |
389 |
#else |
390 |
vp->lib = NULL; |
391 |
#endif |
392 |
if (vp->lib == NULL) /* if name not in library */ |
393 |
name = qualname(name, 0); /* use fully qualified version */ |
394 |
hv = hash(name); |
395 |
vp->name = savestr(name); |
396 |
vp->nlinks = 1; |
397 |
vp->def = NULL; |
398 |
vp->next = hashtbl[hv]; |
399 |
hashtbl[hv] = vp; |
400 |
return(vp); |
401 |
402 |
403 |
404 |
#ifdef FUNCTION |
405 |
libupdate(fn) /* update library links */ |
406 |
char *fn; |
407 |
408 |
register int i; |
409 |
410 |
/* if fn is NULL then relink all */ |
411 |
412 |
413 |
if (vp->lib != NULL || fn == NULL || !strcmp(fn, vp->name)) |
414 |
vp->lib = liblookup(vp->name); |
415 |
416 |
#endif |
417 |
418 |
419 |
varfree(ln) /* release link to variable */ |
420 |
register VARDEF *ln; |
421 |
422 |
423 |
int hv; |
424 |
425 |
if (--ln->nlinks > 0) |
426 |
return; /* still active */ |
427 |
428 |
hv = hash(ln->name); |
429 |
vp = hashtbl[hv]; |
430 |
if (vp == ln) |
431 |
hashtbl[hv] = vp->next; |
432 |
else { |
433 |
while (vp->next != ln) /* must be in list */ |
434 |
vp = vp->next; |
435 |
vp->next = ln->next; |
436 |
437 |
freestr(ln->name); |
438 |
efree((char *)ln); |
439 |
440 |
441 |
442 |
EPNODE * |
443 |
dfirst() /* return pointer to first definition */ |
444 |
445 |
htndx = 0; |
446 |
htpos = NULL; |
447 |
#ifdef OUTCHAN |
448 |
ochpos = outchan; |
449 |
#endif |
450 |
return(dnext()); |
451 |
452 |
453 |
454 |
EPNODE * |
455 |
dnext() /* return pointer to next definition */ |
456 |
457 |
458 |
register char *nm; |
459 |
460 |
while (htndx < NHASH) { |
461 |
if (htpos == NULL) |
462 |
htpos = hashtbl[htndx++]; |
463 |
while (htpos != NULL) { |
464 |
ep = htpos->def; |
465 |
nm = htpos->name; |
466 |
htpos = htpos->next; |
467 |
if (ep != NULL && incontext(nm)) |
468 |
return(ep); |
469 |
470 |
471 |
#ifdef OUTCHAN |
472 |
if ((ep = ochpos) != NULL) |
473 |
ochpos = ep->sibling; |
474 |
return(ep); |
475 |
#else |
476 |
return(NULL); |
477 |
#endif |
478 |
479 |
480 |
481 |
EPNODE * |
482 |
dpop(name) /* pop a definition */ |
483 |
char *name; |
484 |
485 |
486 |
487 |
488 |
if ((vp = varlookup(name)) == NULL || vp->def == NULL) |
489 |
return(NULL); |
490 |
dp = vp->def; |
491 |
vp->def = dp->sibling; |
492 |
varfree(vp); |
493 |
return(dp); |
494 |
495 |
496 |
497 |
dpush(nm, ep) /* push on a definition */ |
498 |
char *nm; |
499 |
500 |
501 |
502 |
503 |
vp = varinsert(nm); |
504 |
ep->sibling = vp->def; |
505 |
vp->def = ep; |
506 |
507 |
508 |
509 |
#ifdef OUTCHAN |
510 |
addchan(sp) /* add an output channel assignment */ |
511 |
EPNODE *sp; |
512 |
513 |
int ch = sp->v.kid->v.chan; |
514 |
register EPNODE *ep, *epl; |
515 |
516 |
for (epl = NULL, ep = outchan; ep != NULL; epl = ep, ep = ep->sibling) |
517 |
if (ep->v.kid->v.chan >= ch) { |
518 |
if (epl != NULL) |
519 |
epl->sibling = sp; |
520 |
else |
521 |
outchan = sp; |
522 |
if (ep->v.kid->v.chan > ch) |
523 |
sp->sibling = ep; |
524 |
else { |
525 |
sp->sibling = ep->sibling; |
526 |
epfree(ep); |
527 |
528 |
return; |
529 |
530 |
if (epl != NULL) |
531 |
532 |
else |
533 |
outchan = sp; |
534 |
sp->sibling = NULL; |
535 |
536 |
537 |
#endif |
538 |
539 |
540 |
getstatement() /* get next statement */ |
541 |
542 |
543 |
char *qname; |
544 |
register VARDEF *vdef; |
545 |
546 |
if (nextc == ';') { /* empty statement */ |
547 |
scan(); |
548 |
return; |
549 |
550 |
#ifdef OUTCHAN |
551 |
if (nextc == '$') { /* channel assignment */ |
552 |
ep = getchan(); |
553 |
addchan(ep); |
554 |
} else |
555 |
#endif |
556 |
{ /* ordinary definition */ |
557 |
ep = getdefn(); |
558 |
qname = qualname(dname(ep), 0); |
559 |
#ifdef REDEFW |
560 |
if ((vdef = varlookup(qname)) != NULL) |
561 |
if (vdef->def != NULL && epcmp(ep, vdef->def)) { |
562 |
wputs(qname); |
563 |
if (vdef->def->type == ':') |
564 |
wputs(": redefined constant expression\n"); |
565 |
else |
566 |
wputs(": redefined\n"); |
567 |
568 |
#ifdef FUNCTION |
569 |
else if (ep->v.kid->type == FUNC && vdef->lib != NULL) { |
570 |
wputs(qname); |
571 |
wputs(": definition hides library function\n"); |
572 |
573 |
#endif |
574 |
#endif |
575 |
if (ep->type == ':') |
576 |
dremove(qname); |
577 |
else |
578 |
dclear(qname); |
579 |
dpush(qname, ep); |
580 |
581 |
if (nextc != EOF) { |
582 |
if (nextc != ';') |
583 |
syntax("';' expected"); |
584 |
scan(); |
585 |
586 |
587 |
588 |
589 |
EPNODE * |
590 |
getdefn() /* A -> SYM = E1 */ |
591 |
/* SYM : E1 */ |
592 |
/* FUNC(SYM,..) = E1 */ |
593 |
/* FUNC(SYM,..) : E1 */ |
594 |
595 |
596 |
597 |
if (!isalpha(nextc) && nextc != CNTXMARK) |
598 |
syntax("illegal variable name"); |
599 |
600 |
ep1 = newnode(); |
601 |
ep1->type = SYM; |
602 |
ep1->v.name = savestr(getname()); |
603 |
604 |
#ifdef FUNCTION |
605 |
if (nextc == '(') { |
606 |
ep2 = newnode(); |
607 |
ep2->type = FUNC; |
608 |
addekid(ep2, ep1); |
609 |
ep1 = ep2; |
610 |
do { |
611 |
scan(); |
612 |
if (!isalpha(nextc)) |
613 |
614 |
ep2 = newnode(); |
615 |
ep2->type = SYM; |
616 |
ep2->v.name = savestr(getname()); |
617 |
618 |
} while (nextc == ','); |
619 |
if (nextc != ')') |
620 |
syntax("')' expected"); |
621 |
scan(); |
622 |
curfunc = ep1; |
623 |
} else |
624 |
curfunc = NULL; |
625 |
#endif |
626 |
627 |
if (nextc != '=' && nextc != ':') |
628 |
syntax("'=' or ':' expected"); |
629 |
630 |
ep2 = newnode(); |
631 |
ep2->type = nextc; |
632 |
scan(); |
633 |
634 |
addekid(ep2, getE1()); |
635 |
636 |
if ( |
637 |
#ifdef FUNCTION |
638 |
ep1->type == SYM && |
639 |
#endif |
640 |
ep1->sibling->type != NUM) { |
641 |
ep1 = newnode(); |
642 |
ep1->type = TICK; |
643 |
ep1->v.tick = 0; |
644 |
645 |
ep1 = newnode(); |
646 |
ep1->type = NUM; |
647 |
648 |
649 |
650 |
return(ep2); |
651 |
652 |
653 |
654 |
#ifdef OUTCHAN |
655 |
EPNODE * |
656 |
getchan() /* A -> $N = E1 */ |
657 |
658 |
659 |
660 |
if (nextc != '$') |
661 |
syntax("missing '$'"); |
662 |
scan(); |
663 |
664 |
ep1 = newnode(); |
665 |
ep1->type = CHAN; |
666 |
ep1->v.chan = getinum(); |
667 |
668 |
if (nextc != '=') |
669 |
syntax("'=' expected"); |
670 |
scan(); |
671 |
672 |
ep2 = newnode(); |
673 |
ep2->type = '='; |
674 |
675 |
676 |
677 |
return(ep2); |
678 |
679 |
#endif |
680 |
681 |
682 |
683 |
684 |
* The following routines are for internal use only: |
685 |
686 |
687 |
688 |
static double |
689 |
dvalue(name, d) /* evaluate a variable */ |
690 |
char *name; |
691 |
EPNODE *d; |
692 |
693 |
694 |
695 |
if (d == NULL || d->v.kid->type != SYM) { |
696 |
eputs(name); |
697 |
eputs(": undefined variable\n"); |
698 |
quit(1); |
699 |
700 |
ep1 = d->v.kid->sibling; /* get expression */ |
701 |
if (ep1->type == NUM) |
702 |
return(ep1->v.num); /* return if number */ |
703 |
ep2 = ep1->sibling; /* check time */ |
704 |
if (ep2->v.tick == 0 || ep2->v.tick < eclock) { |
705 |
ep2->v.tick = d->type == ':' ? ~0L : eclock; |
706 |
ep2 = ep2->sibling; |
707 |
ep2->v.num = evalue(ep1); /* needs new value */ |
708 |
} else |
709 |
ep2 = ep2->sibling; /* else reuse old value */ |
710 |
711 |
return(ep2->v.num); |
712 |
