root/radiance/ray/src/common/caldefn.c
Revision: 2.13
Committed: Tue Feb 25 02:47:21 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.12: +1 -56 lines
5 * Store variable definitions.
6 *
7 * 7/1/85 Greg Ward
8 *
9 * 11/11/85 Added conditional compiles (OUTCHAN) for control output.
10 *
11 * 4/2/86 Added conditional compiles for function definitions (FUNCTION).
12 *
13 * 1/15/88 Added clock for caching of variable values.
14 *
15 * 11/16/88 Added VARDEF structure for hard linking.
16 *
17 * 5/31/90 Added conditional compile (REDEFW) for redefinition warning.
18 *
19 * 4/23/91 Added ':' assignment for constant expressions
20 *
21 * 8/7/91 Added optional context path to append to variable names
22 *
23 * 5/17/2001 Fixed clock counter wrapping behavior
24 *
25 * 2/19/03 Eliminated conditional compiles in favor of esupport extern.
26 */
27
28 #include "copyright.h"
29
30 #include <stdio.h>
31
32 #include <string.h>
33
34 #include <ctype.h>
35
36 #include "calcomp.h"
37
38 #ifndef NHASH
39 #define NHASH 521 /* hash size (a prime!) */
40 #endif
41
42 #define hash(s) (shash(s)%NHASH)
43
44 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
45
46 static double dvalue();
47
48 #define MAXCLOCK (1L<<31) /* clock wrap value */
49
50 unsigned long eclock = 0; /* value storage timer */
51
52 #define MAXCNTX 1023 /* maximum context length */
53
54 static char context[MAXCNTX+1]; /* current context path */
55
56 static VARDEF *hashtbl[NHASH]; /* definition list */
57 static int htndx; /* index for */
58 static VARDEF *htpos; /* ...dfirst() and */
59 static EPNODE *ochpos; /* ...dnext */
60 static EPNODE *outchan;
61
62 EPNODE *curfunc = NULL;
63 #define dname(ep) ((ep)->v.kid->type == SYM ? \
64 (ep)->v.kid->v.name : \
65 (ep)->v.kid->v.kid->v.name)
66
67
68 void
69 fcompile(fname) /* get definitions from a file */
70 char *fname;
71 {
72 FILE *fp;
73
74 if (fname == NULL)
75 fp = stdin;
76 else if ((fp = fopen(fname, "r")) == NULL) {
77 eputs(fname);
78 eputs(": cannot open\n");
79 quit(1);
80 }
81 initfile(fp, fname, 0);
82 while (nextc != EOF)
83 getstatement();
84 if (fname != NULL)
85 fclose(fp);
86 }
87
88
89 void
90 scompile(str, fn, ln) /* get definitions from a string */
91 char *str;
92 char *fn;
93 int ln;
94 {
95 initstr(str, fn, ln);
96 while (nextc != EOF)
97 getstatement();
98 }
99
100
101 double
102 varvalue(vname) /* return a variable's value */
103 char *vname;
104 {
105 return(dvalue(vname, dlookup(vname)));
106 }
107
108
109 double
110 evariable(ep) /* evaluate a variable */
111 EPNODE *ep;
112 {
113 register VARDEF *dp = ep->v.ln;
114
115 return(dvalue(dp->name, dp->def));
116 }
117
118
119 void
120 varset(vname, assign, val) /* set a variable's value */
121 char *vname;
122 int assign;
123 double val;
124 {
125 char *qname;
126 register EPNODE *ep1, *ep2;
127 /* get qualified name */
128 qname = qualname(vname, 0);
129 /* check for quick set */
130 if ((ep1 = dlookup(qname)) != NULL && ep1->v.kid->type == SYM) {
131 ep2 = ep1->v.kid->sibling;
132 if (ep2->type == NUM) {
133 ep2->v.num = val;
134 ep1->type = assign;
135 return;
136 }
137 }
138 /* hand build definition */
139 ep1 = newnode();
140 ep1->type = assign;
141 ep2 = newnode();
142 ep2->type = SYM;
143 ep2->v.name = savestr(vname);
144 addekid(ep1, ep2);
145 ep2 = newnode();
146 ep2->type = NUM;
147 ep2->v.num = val;
148 addekid(ep1, ep2);
149 dremove(qname);
150 dpush(qname, ep1);
151 }
152
153
154 void
155 dclear(name) /* delete variable definitions of name */
156 char *name;
157 {
158 register EPNODE *ep;
159
160 while ((ep = dpop(name)) != NULL) {
161 if (ep->type == ':') {
162 dpush(name, ep); /* don't clear constants */
163 return;
164 }
165 epfree(ep);
166 }
167 }
168
169
170 void
171 dremove(name) /* delete all definitions of name */
172 char *name;
173 {
174 register EPNODE *ep;
175
176 while ((ep = dpop(name)) != NULL)
177 epfree(ep);
178 }
179
180
181 int
182 vardefined(name) /* return non-zero if variable defined */
183 char *name;
184 {
185 register EPNODE *dp;
186
187 return((dp = dlookup(name)) != NULL && dp->v.kid->type == SYM);
188 }
189
190
191 char *
192 setcontext(ctx) /* set a new context path */
193 register char *ctx;
194 {
195 register char *cpp;
196
197 if (ctx == NULL)
198 return(context); /* just asking */
199 while (*ctx == CNTXMARK)
200 ctx++; /* skip past marks */
201 if (!*ctx) {
202 context[0] = '\0'; /* empty means clear context */
203 return(context);
204 }
205 cpp = context; /* start context with mark */
206 *cpp++ = CNTXMARK;
207 do { /* carefully copy new context */
208 if (cpp >= context+MAXCNTX)
209 break; /* just copy what we can */
210 if (isid(*ctx))
211 *cpp++ = *ctx++;
212 else {
213 *cpp++ = '_'; ctx++;
214 }
215 } while (*ctx);
216 while (cpp[-1] == CNTXMARK) /* cannot end in context mark */
217 cpp--;
218 *cpp = '\0';
219 return(context);
220 }
221
222
223 char *
224 pushcontext(ctx) /* push on another context */
225 char *ctx;
226 {
227 extern char *strncpy(), *strcpy();
228 char oldcontext[MAXCNTX+1];
229 register int n;
230
231 strcpy(oldcontext, context); /* save old context */
232 setcontext(ctx); /* set new context */
233 n = strlen(context); /* tack on old */
234 if (n+strlen(oldcontext) > MAXCNTX) {
235 strncpy(context+n, oldcontext, MAXCNTX-n);
236 context[MAXCNTX] = '\0';
237 } else
238 strcpy(context+n, oldcontext);
239 return(context);
240 }
241
242
243 char *
244 popcontext() /* pop off top context */
245 {
246 register char *cp1, *cp2;
247
248 if (!context[0]) /* nothing left to pop */
249 return(context);
250 cp2 = context; /* find mark */
251 while (*++cp2 && *cp2 != CNTXMARK)
252 ;
253 cp1 = context; /* copy tail to front */
254 while (*cp1++ = *cp2++)
255 ;
256 return(context);
257 }
258
259
260 char *
261 qualname(nam, lvl) /* get qualified name */
262 register char *nam;
263 int lvl;
264 {
265 static char nambuf[MAXWORD+1];
266 register char *cp = nambuf, *cpp;
267 /* check for explicit local */
268 if (*nam == CNTXMARK)
269 if (lvl > 0) /* only action is to refuse search */
270 return(NULL);
271 else
272 nam++;
273 else if (nam == nambuf) /* check for repeat call */
274 return(lvl > 0 ? NULL : nam);
275 /* copy name to static buffer */
276 while (*nam) {
277 if (cp >= nambuf+MAXWORD)
278 goto toolong;
279 *cp++ = *nam++;
280 }
281 /* check for explicit global */
282 if (cp > nambuf && cp[-1] == CNTXMARK) {
283 if (lvl > 0)
284 return(NULL);
285 *--cp = '\0';
286 return(nambuf); /* already qualified */
287 }
288 cpp = context; /* else skip the requested levels */
289 while (lvl-- > 0) {
290 if (!*cpp)
291 return(NULL); /* return NULL if past global level */
292 while (*++cpp && *cpp != CNTXMARK)
293 ;
294 }
295 while (*cpp) { /* copy context to static buffer */
296 if (cp >= nambuf+MAXWORD)
297 goto toolong;
298 *cp++ = *cpp++;
299 }
300 toolong:
301 *cp = '\0';
302 return(nambuf); /* return qualified name */
303 }
304
305
306 int
307 incontext(qn) /* is qualified name in current context? */
308 register char *qn;
309 {
310 if (!context[0]) /* global context accepts all */
311 return(1);
312 while (*qn && *qn != CNTXMARK) /* find context mark */
313 qn++;
314 return(!strcmp(qn, context));
315 }
316
317
318 void
319 chanout(cs) /* set output channels */
320 int (*cs)();
321 {
322 register EPNODE *ep;
323
324 for (ep = outchan; ep != NULL; ep = ep->sibling)
325 (*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling));
326
327 }
328
329
330 void
331 dcleanup(lvl) /* clear definitions (0->vars,1->output,2->consts) */
332 int lvl;
333 {
334 register int i;
335 register VARDEF *vp;
336 register EPNODE *ep;
337 /* if context is global, clear all */
338 for (i = 0; i < NHASH; i++)
339 for (vp = hashtbl[i]; vp != NULL; vp = vp->next)
340 if (incontext(vp->name))
341 if (lvl >= 2)
342 dremove(vp->name);
343 else
344 dclear(vp->name);
345 if (lvl >= 1) {
346 for (ep = outchan; ep != NULL; ep = ep->sibling)
347 epfree(ep);
348 outchan = NULL;
349 }
350 }
351
352
353 EPNODE *
354 dlookup(name) /* look up a definition */
355 char *name;
356 {
357 register VARDEF *vp;
358
359 if ((vp = varlookup(name)) == NULL)
360 return(NULL);
361 return(vp->def);
362 }
363
364
365 VARDEF *
366 varlookup(name) /* look up a variable */
367 char *name;
368 {
369 int lvl = 0;
370 register char *qname;
371 register VARDEF *vp;
372 /* find most qualified match */
373 while ((qname = qualname(name, lvl++)) != NULL)
374 for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next)
375 if (!strcmp(vp->name, qname))
376 return(vp);
377 return(NULL);
378 }
379
380
381 VARDEF *
382 varinsert(name) /* get a link to a variable */
383 char *name;
384 {
385 register VARDEF *vp;
386 int hv;
387
388 if ((vp = varlookup(name)) != NULL) {
389 vp->nlinks++;
390 return(vp);
391 }
392 vp = (VARDEF *)emalloc(sizeof(VARDEF));
393 vp->lib = liblookup(name);
394 if (vp->lib == NULL) /* if name not in library */
395 name = qualname(name, 0); /* use fully qualified version */
396 hv = hash(name);
397 vp->name = savestr(name);
398 vp->nlinks = 1;
399 vp->def = NULL;
400 vp->next = hashtbl[hv];
401 hashtbl[hv] = vp;
402 return(vp);
403 }
404
405
406 void
407 libupdate(fn) /* update library links */
408 char *fn;
409 {
410 register int i;
411 register VARDEF *vp;
412 /* if fn is NULL then relink all */
413 for (i = 0; i < NHASH; i++)
414 for (vp = hashtbl[i]; vp != NULL; vp = vp->next)
415 if (vp->lib != NULL || fn == NULL || !strcmp(fn, vp->name))
416 vp->lib = liblookup(vp->name);
417 }
418
419
420 void
421 varfree(ln) /* release link to variable */
422 register VARDEF *ln;
423 {
424 register VARDEF *vp;
425 int hv;
426
427 if (--ln->nlinks > 0)
428 return; /* still active */
429
430 hv = hash(ln->name);
431 vp = hashtbl[hv];
432 if (vp == ln)
433 hashtbl[hv] = vp->next;
434 else {
435 while (vp->next != ln) /* must be in list */
436 vp = vp->next;
437 vp->next = ln->next;
438 }
439 freestr(ln->name);
440 efree((char *)ln);
441 }
442
443
444 EPNODE *
445 dfirst() /* return pointer to first definition */
446 {
447 htndx = 0;
448 htpos = NULL;
449 ochpos = outchan;
450 return(dnext());
451 }
452
453
454 EPNODE *
455 dnext() /* return pointer to next definition */
456 {
457 register EPNODE *ep;
458 register char *nm;
459
460 while (htndx < NHASH) {
461 if (htpos == NULL)
462 htpos = hashtbl[htndx++];
463 while (htpos != NULL) {
464 ep = htpos->def;
465 nm = htpos->name;
466 htpos = htpos->next;
467 if (ep != NULL && incontext(nm))
468 return(ep);
469 }
470 }
471 if ((ep = ochpos) != NULL)
472 ochpos = ep->sibling;
473 return(ep);
474 }
475
476
477 EPNODE *
478 dpop(name) /* pop a definition */
479 char *name;
480 {
481 register VARDEF *vp;
482 register EPNODE *dp;
483
484 if ((vp = varlookup(name)) == NULL || vp->def == NULL)
485 return(NULL);
486 dp = vp->def;
487 vp->def = dp->sibling;
488 varfree(vp);
489 return(dp);
490 }
491
492
493 void
494 dpush(nm, ep) /* push on a definition */
495 char *nm;
496 register EPNODE *ep;
497 {
498 register VARDEF *vp;
499
500 vp = varinsert(nm);
501 ep->sibling = vp->def;
502 vp->def = ep;
503 }
504
505
506 void
507 addchan(sp) /* add an output channel assignment */
508 EPNODE *sp;
509 {
510 int ch = sp->v.kid->v.chan;
511 register EPNODE *ep, *epl;
512
513 for (epl = NULL, ep = outchan; ep != NULL; epl = ep, ep = ep->sibling)
514 if (ep->v.kid->v.chan >= ch) {
515 if (epl != NULL)
516 epl->sibling = sp;
517 else
518 outchan = sp;
519 if (ep->v.kid->v.chan > ch)
520 sp->sibling = ep;
521 else {
522 sp->sibling = ep->sibling;
523 epfree(ep);
524 }
525 return;
526 }
527 if (epl != NULL)
528 epl->sibling = sp;
529 else
530 outchan = sp;
531 sp->sibling = NULL;
532
533 }
534
535
536 void
537 getstatement() /* get next statement */
538 {
539 register EPNODE *ep;
540 char *qname;
541 register VARDEF *vdef;
542
543 if (nextc == ';') { /* empty statement */
544 scan();
545 return;
546 }
547 if (esupport&E_OUTCHAN &&
548 nextc == '$') { /* channel assignment */
549 ep = getchan();
550 addchan(ep);
551 } else { /* ordinary definition */
552 ep = getdefn();
553 qname = qualname(dname(ep), 0);
554 if (esupport&E_REDEFW && (vdef = varlookup(qname)) != NULL)
555 if (vdef->def != NULL && epcmp(ep, vdef->def)) {
556 wputs(qname);
557 if (vdef->def->type == ':')
558 wputs(": redefined constant expression\n");
559 else
560 wputs(": redefined\n");
561 } else if (ep->v.kid->type == FUNC && vdef->lib != NULL) {
562 wputs(qname);
563 wputs(": definition hides library function\n");
564 }
565 if (ep->type == ':')
566 dremove(qname);
567 else
568 dclear(qname);
569 dpush(qname, ep);
570 }
571 if (nextc != EOF) {
572 if (nextc != ';')
573 syntax("';' expected");
574 scan();
575 }
576 }
577
578
579 EPNODE *
580 getdefn() /* A -> SYM = E1 */
581 /* SYM : E1 */
582 /* FUNC(SYM,..) = E1 */
583 /* FUNC(SYM,..) : E1 */
584 {
585 register EPNODE *ep1, *ep2;
586
587 if (!isalpha(nextc) && nextc != CNTXMARK)
588 syntax("illegal variable name");
589
590 ep1 = newnode();
591 ep1->type = SYM;
592 ep1->v.name = savestr(getname());
593
594 if (esupport&E_FUNCTION && nextc == '(') {
595 ep2 = newnode();
596 ep2->type = FUNC;
597 addekid(ep2, ep1);
598 ep1 = ep2;
599 do {
600 scan();
601 if (!isalpha(nextc))
602 syntax("illegal variable name");
603 ep2 = newnode();
604 ep2->type = SYM;
605 ep2->v.name = savestr(getname());
606 addekid(ep1, ep2);
607 } while (nextc == ',');
608 if (nextc != ')')
609 syntax("')' expected");
610 scan();
611 curfunc = ep1;
612 }
613
614 if (nextc != '=' && nextc != ':')
615 syntax("'=' or ':' expected");
616
617 ep2 = newnode();
618 ep2->type = nextc;
619 scan();
620 addekid(ep2, ep1);
621 addekid(ep2, getE1());
622
623 if (ep1->type == SYM && ep1->sibling->type != NUM) {
624 ep1 = newnode();
625 ep1->type = TICK;
626 ep1->v.tick = 0;
627 addekid(ep2, ep1);
628 ep1 = newnode();
629 ep1->type = NUM;
630 addekid(ep2, ep1);
631 }
632 curfunc = NULL;
633
634 return(ep2);
635 }
636
637
638 EPNODE *
639 getchan() /* A -> $N = E1 */
640 {
641 register EPNODE *ep1, *ep2;
642
643 if (nextc != '$')
644 syntax("missing '$'");
645 scan();
646
647 ep1 = newnode();
648 ep1->type = CHAN;
649 ep1->v.chan = getinum();
650
651 if (nextc != '=')
652 syntax("'=' expected");
653 scan();
654
655 ep2 = newnode();
656 ep2->type = '=';
657 addekid(ep2, ep1);
658 addekid(ep2, getE1());
659
660 return(ep2);
661 }
662
663
664
665 /*
666 * The following routines are for internal use only:
667 */
668
669
670 static double
671 dvalue(name, d) /* evaluate a variable */
672 char *name;
673 EPNODE *d;
674 {
675 register EPNODE *ep1, *ep2;
676
677 if (d == NULL || d->v.kid->type != SYM) {
678 eputs(name);
679 eputs(": undefined variable\n");
680 quit(1);
681 }
682 ep1 = d->v.kid->sibling; /* get expression */
683 if (ep1->type == NUM)
684 return(ep1->v.num); /* return if number */
685 ep2 = ep1->sibling; /* check time */
686 if (eclock >= MAXCLOCK)
687 eclock = 1; /* wrap clock counter */
688 if (ep2->v.tick < MAXCLOCK &&
689 ep2->v.tick == 0 | ep2->v.tick != eclock) {
690 ep2->v.tick = d->type == ':' ? MAXCLOCK : eclock;
691 ep2 = ep2->sibling;
692 ep2->v.num = evalue(ep1); /* needs new value */
693 } else
694 ep2 = ep2->sibling; /* else reuse old value */
695
696 return(ep2->v.num);
697 }
