--- ray/src/common/caldefn.c 1989/02/02 10:34:26 1.1 +++ ray/src/common/caldefn.c 1990/07/19 13:09:22 1.6 @@ -16,6 +16,8 @@ static char SCCSid[] = "$SunId$ LBL"; * 1/15/88 Added clock for caching of variable values. * * 11/16/88 Added VARDEF structure for hard linking. + * + * 5/31/90 Added conditional compile (REDEFW) for redefinition warning. */ #include @@ -32,7 +34,7 @@ static char SCCSid[] = "$SunId$ LBL"; extern char *ecalloc(), *savestr(); -extern double dvalue(); +static double dvalue(); long eclock = -1; /* value storage timer */ @@ -66,7 +68,7 @@ char *fname; eputs(": cannot open\n"); quit(1); } - initfile(fname, fp); + initfile(fp, fname, 0); while (nextc != EOF) loaddefn(); if (fname != NULL) @@ -74,11 +76,12 @@ char *fname; } -scompile(file, str) /* get definitions from a string */ -char *file; +scompile(str, fn, ln) /* get definitions from a string */ char *str; +char *fn; +int ln; { - initstr(file, str); + initstr(str, fn, ln); while (nextc != EOF) loaddefn(); } @@ -112,7 +115,6 @@ double val; ep2 = ep1->v.kid->sibling; if (ep2->type == NUM) { ep2->v.num = val; - ep2->sibling->v.tick = -1; return; } } @@ -127,13 +129,6 @@ double val; ep2->type = NUM; ep2->v.num = val; addekid(ep1, ep2); - ep2 = newnode(); - ep2->type = TICK; - ep2->v.tick = -1; - addekid(ep1, ep2); - ep2 = newnode(); - ep2->type = NUM; - addekid(ep1, ep2); dclear(vname); dpush(ep1); } @@ -159,12 +154,13 @@ char *name; #ifdef OUTCHAN -chanout() /* set output channels */ +chanout(cs) /* set output channels */ +int (*cs)(); { register EPNODE *ep; for (ep = outchan; ep != NULL; ep = ep->sibling) - chanset(ep->v.kid->v.chan, evalue(ep->v.kid->sibling)); + (*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling)); } #endif @@ -370,7 +366,15 @@ loaddefn() /* load next definition */ #endif { /* ordinary definition */ ep = getdefn(); +#ifdef REDEFW + if (dlookup(dname(ep)) != NULL) { + dclear(dname(ep)); + wputs(dname(ep)); + wputs(": redefined\n"); + } +#else dclear(dname(ep)); +#endif dpush(ep); } if (nextc != EOF) { @@ -490,13 +494,15 @@ EPNODE *d; quit(1); } ep1 = d->v.kid->sibling; /* get expression */ + if (ep1->type == NUM) + return(ep1->v.num); /* return if number */ ep2 = ep1->sibling; /* check time */ if (ep2->v.tick < 0 || ep2->v.tick < eclock) { ep2->v.tick = eclock; ep2 = ep2->sibling; - ep2->v.num = evalue(ep1); /* compute new value */ + ep2->v.num = evalue(ep1); /* needs new value */ } else - ep2 = ep2->sibling; /* reuse old value */ + ep2 = ep2->sibling; /* else reuse old value */ return(ep2->v.num); }
