root/radiance/ray/src/common/caldefn.c
Revision: 1.16
Committed: Thu Aug 8 14:38:00 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.15: +22 -14 lines
fixed bug related to contexts and library functions
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Store variable definitions.
9 *
10 * 7/1/85 Greg Ward
11 *
12 * 11/11/85 Added conditional compiles (OUTCHAN) for control output.
13 *
14 * 4/2/86 Added conditional compiles for function definitions (FUNCTION).
15 *
16 * 1/15/88 Added clock for caching of variable values.
17 *
18 * 11/16/88 Added VARDEF structure for hard linking.
19 *
20 * 5/31/90 Added conditional compile (REDEFW) for redefinition warning.
21 *
22 * 4/23/91 Added ':' assignment for constant expressions
23 *
24 * 8/7/91 Added optional context path to append to variable names
25 */
26
27 #include <stdio.h>
28
29 #include <ctype.h>
30
31 #include "calcomp.h"
32
33 #ifndef NHASH
34 #define NHASH 521 /* hash size (a prime!) */
35 #endif
36
37 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
38
39 extern char *ecalloc(), *savestr(), *strcpy();
40
41 static double dvalue();
42
43 long eclock = -1; /* value storage timer */
44
45 static char context[MAXWORD]; /* current context path */
46
47 static VARDEF *hashtbl[NHASH]; /* definition list */
48 static int htndx; /* index for */
49 static VARDEF *htpos; /* ...dfirst() and */
50 #ifdef OUTCHAN
51 static EPNODE *ochpos; /* ...dnext */
52 static EPNODE *outchan;
53 #endif
54
55 #ifdef FUNCTION
56 EPNODE *curfunc;
57 #define dname(ep) ((ep)->v.kid->type == SYM ? \
58 (ep)->v.kid->v.name : \
59 (ep)->v.kid->v.kid->v.name)
60 #else
61 #define dname(ep) ((ep)->v.kid->v.name)
62 #endif
63
64
65 fcompile(fname) /* get definitions from a file */
66 char *fname;
67 {
68 FILE *fp;
69
70 if (fname == NULL)
71 fp = stdin;
72 else if ((fp = fopen(fname, "r")) == NULL) {
73 eputs(fname);
74 eputs(": cannot open\n");
75 quit(1);
76 }
77 initfile(fp, fname, 0);
78 while (nextc != EOF)
79 getstatement();
80 if (fname != NULL)
81 fclose(fp);
82 }
83
84
85 scompile(str, fn, ln) /* get definitions from a string */
86 char *str;
87 char *fn;
88 int ln;
89 {
90 initstr(str, fn, ln);
91 while (nextc != EOF)
92 getstatement();
93 }
94
95
96 double
97 varvalue(vname) /* return a variable's value */
98 char *vname;
99 {
100 return(dvalue(vname, dlookup(vname)));
101 }
102
103
104 double
105 evariable(ep) /* evaluate a variable */
106 EPNODE *ep;
107 {
108 register VARDEF *dp = ep->v.ln;
109
110 return(dvalue(dp->name, dp->def));
111 }
112
113
114 varset(vname, assign, val) /* set a variable's value */
115 char *vname;
116 int assign;
117 double val;
118 {
119 char *qname;
120 register EPNODE *ep1, *ep2;
121 /* get qualified name */
122 qname = qualname(vname, 0);
123 /* check for quick set */
124 if ((ep1 = dlookup(qname)) != NULL && ep1->v.kid->type == SYM) {
125 ep2 = ep1->v.kid->sibling;
126 if (ep2->type == NUM) {
127 ep2->v.num = val;
128 ep1->type = assign;
129 return;
130 }
131 }
132 /* hand build definition */
133 ep1 = newnode();
134 ep1->type = assign;
135 ep2 = newnode();
136 ep2->type = SYM;
137 ep2->v.name = savestr(vname);
138 addekid(ep1, ep2);
139 ep2 = newnode();
140 ep2->type = NUM;
141 ep2->v.num = val;
142 addekid(ep1, ep2);
143 dremove(qname);
144 dpush(qname, ep1);
145 }
146
147
148 dclear(name) /* delete variable definitions of name */
149 char *name;
150 {
151 register EPNODE *ep;
152
153 while ((ep = dpop(name)) != NULL) {
154 if (ep->type == ':') {
155 dpush(name, ep); /* don't clear constants */
156 return;
157 }
158 epfree(ep);
159 }
160 }
161
162
163 dremove(name) /* delete all definitions of name */
164 char *name;
165 {
166 register EPNODE *ep;
167
168 while ((ep = dpop(name)) != NULL)
169 epfree(ep);
170 }
171
172
173 vardefined(name) /* return non-zero if variable defined */
174 char *name;
175 {
176 register EPNODE *dp;
177
178 return((dp = dlookup(name)) != NULL && dp->v.kid->type == SYM);
179 }
180
181
182 char *
183 setcontext(ctx) /* set a new context path */
184 register char *ctx;
185 {
186 register char *cpp;
187
188 if (ctx == NULL)
189 return(context); /* just asking */
190 if (!*ctx) {
191 context[0] = '\0'; /* clear context */
192 return(context);
193 }
194 cpp = context; /* else copy it (carefully!) */
195 if (*ctx != CNTXMARK)
196 *cpp++ = CNTXMARK; /* make sure there's a mark */
197 do {
198 if (cpp >= context+MAXWORD-1) {
199 *cpp = '\0';
200 wputs(context);
201 wputs(": context path too long\n");
202 return(NULL);
203 }
204 if (isid(*ctx))
205 *cpp++ = *ctx++;
206 else {
207 *cpp++ = '_'; ctx++;
208 }
209 } while (*ctx);
210 *cpp = '\0';
211 return(context);
212 }
213
214
215 char *
216 qualname(nam, lvl) /* get qualified name */
217 register char *nam;
218 int lvl;
219 {
220 static char nambuf[MAXWORD];
221 register char *cp = nambuf, *cpp = context;
222 /* check for explicit global */
223 if (*nam == CNTXMARK)
224 return(lvl > 0 ? NULL : nam+1);
225 /* check for repeat call */
226 if (nam == nambuf)
227 return(lvl > 0 ? NULL : nambuf);
228 /* copy name to static buffer */
229 while (*nam) {
230 if (cp >= nambuf+MAXWORD-1)
231 goto toolong;
232 if ((*cp++ = *nam++) == CNTXMARK)
233 cpp = NULL; /* flag a qualified name */
234 }
235 if (cpp == NULL) {
236 if (lvl > 0)
237 return(NULL); /* no higher level */
238 if (cp[-1] == CNTXMARK) {
239 cp--; cpp = context; /* current context explicitly */
240 } else
241 cpp = ""; /* else fully qualified */
242 } else /* else skip the requested levels */
243 while (lvl-- > 0) {
244 if (!*cpp)
245 return(NULL); /* return NULL if past global level */
246 while (*++cpp && *cpp != CNTXMARK)
247 ;
248 }
249 while (*cpp) { /* copy context to static buffer */
250 if (cp >= nambuf+MAXWORD-1)
251 goto toolong;
252 *cp++ = *cpp++;
253 }
254 *cp = '\0';
255 return(nambuf); /* return qualified name */
256 toolong:
257 *cp = '\0';
258 eputs(nambuf);
259 eputs(": name too long\n");
260 quit(1);
261 }
262
263
264 incontext(qn) /* is qualified name in current context? */
265 register char *qn;
266 {
267 while (*qn && *qn != CNTXMARK) /* find context mark */
268 ;
269 return(!strcmp(qn, context));
270 }
271
272
273 #ifdef OUTCHAN
274 chanout(cs) /* set output channels */
275 int (*cs)();
276 {
277 register EPNODE *ep;
278
279 for (ep = outchan; ep != NULL; ep = ep->sibling)
280 (*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling));
281
282 }
283 #endif
284
285
286 dcleanup(lvl) /* clear definitions (0->vars,1->output,2->consts) */
287 int lvl;
288 {
289 register int i;
290 register VARDEF *vp;
291 register EPNODE *ep;
292 /* if context is global, clear all */
293 for (i = 0; i < NHASH; i++)
294 for (vp = hashtbl[i]; vp != NULL; vp = vp->next)
295 if (!context[0] || incontext(vp->name))
296 if (lvl >= 2)
297 dremove(vp->name);
298 else
299 dclear(vp->name);
300 #ifdef OUTCHAN
301 if (lvl >= 1) {
302 for (ep = outchan; ep != NULL; ep = ep->sibling)
303 epfree(ep);
304 outchan = NULL;
305 }
306 #endif
307 }
308
309
310 EPNODE *
311 dlookup(name) /* look up a definition */
312 char *name;
313 {
314 register VARDEF *vp;
315
316 if ((vp = varlookup(name)) == NULL)
317 return(NULL);
318 return(vp->def);
319 }
320
321
322 VARDEF *
323 varlookup(name) /* look up a variable */
324 char *name;
325 {
326 int lvl = 0;
327 register char *qname;
328 register VARDEF *vp;
329 /* find most qualified match */
330 while ((qname = qualname(name, lvl++)) != NULL)
331 for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next)
332 if (!strcmp(vp->name, qname))
333 return(vp);
334 return(NULL);
335 }
336
337
338 VARDEF *
339 varinsert(name) /* get a link to a variable */
340 char *name;
341 {
342 register VARDEF *vp;
343 LIBR *libp;
344 int hv;
345
346 if ((vp = varlookup(name)) != NULL) {
347 vp->nlinks++;
348 return(vp);
349 }
350 #ifdef FUNCTION
351 libp = liblookup(name);
352 #else
353 libp = NULL;
354 #endif
355 if (libp == NULL) /* if name not in library */
356 name = qualname(name, 0); /* use fully qualified version */
357 hv = hash(name);
358 vp = (VARDEF *)emalloc(sizeof(VARDEF));
359 vp->name = savestr(name);
360 vp->nlinks = 1;
361 vp->def = NULL;
362 vp->lib = libp;
363 vp->next = hashtbl[hv];
364 hashtbl[hv] = vp;
365 return(vp);
366 }
367
368
369 varfree(ln) /* release link to variable */
370 register VARDEF *ln;
371 {
372 register VARDEF *vp;
373 int hv;
374
375 if (--ln->nlinks > 0)
376 return; /* still active */
377
378 hv = hash(ln->name);
379 vp = hashtbl[hv];
380 if (vp == ln)
381 hashtbl[hv] = vp->next;
382 else {
383 while (vp->next != ln) /* must be in list */
384 vp = vp->next;
385 vp->next = ln->next;
386 }
387 freestr(ln->name);
388 efree((char *)ln);
389 }
390
391
392 EPNODE *
393 dfirst() /* return pointer to first definition */
394 {
395 htndx = 0;
396 htpos = NULL;
397 #ifdef OUTCHAN
398 ochpos = outchan;
399 #endif
400 return(dnext());
401 }
402
403
404 EPNODE *
405 dnext() /* return pointer to next definition */
406 {
407 register EPNODE *ep;
408
409 while (htndx < NHASH) {
410 if (htpos == NULL)
411 htpos = hashtbl[htndx++];
412 while (htpos != NULL) {
413 ep = htpos->def;
414 htpos = htpos->next;
415 if (ep != NULL)
416 return(ep);
417 }
418 }
419 #ifdef OUTCHAN
420 if ((ep = ochpos) != NULL)
421 ochpos = ep->sibling;
422 return(ep);
423 #else
424 return(NULL);
425 #endif
426 }
427
428
429 EPNODE *
430 dpop(name) /* pop a definition */
431 char *name;
432 {
433 register VARDEF *vp;
434 register EPNODE *dp;
435
436 if ((vp = varlookup(name)) == NULL || vp->def == NULL)
437 return(NULL);
438 dp = vp->def;
439 vp->def = dp->sibling;
440 varfree(vp);
441 return(dp);
442 }
443
444
445 dpush(nm, ep) /* push on a definition */
446 char *nm;
447 register EPNODE *ep;
448 {
449 register VARDEF *vp;
450
451 vp = varinsert(nm);
452 ep->sibling = vp->def;
453 vp->def = ep;
454 }
455
456
457 #ifdef OUTCHAN
458 addchan(sp) /* add an output channel assignment */
459 EPNODE *sp;
460 {
461 int ch = sp->v.kid->v.chan;
462 register EPNODE *ep, *epl;
463
464 for (epl = NULL, ep = outchan; ep != NULL; epl = ep, ep = ep->sibling)
465 if (ep->v.kid->v.chan >= ch) {
466 if (epl != NULL)
467 epl->sibling = sp;
468 else
469 outchan = sp;
470 if (ep->v.kid->v.chan > ch)
471 sp->sibling = ep;
472 else {
473 sp->sibling = ep->sibling;
474 epfree(ep);
475 }
476 return;
477 }
478 if (epl != NULL)
479 epl->sibling = sp;
480 else
481 outchan = sp;
482 sp->sibling = NULL;
483
484 }
485 #endif
486
487
488 getstatement() /* get next statement */
489 {
490 register EPNODE *ep;
491 char *qname;
492 register VARDEF *vdef;
493
494 if (nextc == ';') { /* empty statement */
495 scan();
496 return;
497 }
498 #ifdef OUTCHAN
499 if (nextc == '$') { /* channel assignment */
500 ep = getchan();
501 addchan(ep);
502 } else
503 #endif
504 { /* ordinary definition */
505 ep = getdefn();
506 qname = qualname(dname(ep), 0);
507 #ifdef REDEFW
508 if ((vdef = varlookup(qname)) != NULL)
509 if (vdef->def != NULL) {
510 wputs(qname);
511 if (vdef->def->type == ':')
512 wputs(": redefined constant expression\n");
513 else
514 wputs(": redefined\n");
515 }
516 #ifdef FUNCTION
517 else if (ep->v.kid->type == FUNC && vdef->lib != NULL) {
518 wputs(qname);
519 wputs(": definition hides library function\n");
520 }
521 #endif
522 #endif
523 if (ep->type == ':')
524 dremove(qname);
525 else
526 dclear(qname);
527 dpush(qname, ep);
528 }
529 if (nextc != EOF) {
530 if (nextc != ';')
531 syntax("';' expected");
532 scan();
533 }
534 }
535
536
537 EPNODE *
538 getdefn() /* A -> SYM = E1 */
539 /* SYM : E1 */
540 /* FUNC(SYM,..) = E1 */
541 /* FUNC(SYM,..) : E1 */
542 {
543 register EPNODE *ep1, *ep2;
544
545 if (!isalpha(nextc))
546 syntax("illegal variable name");
547
548 ep1 = newnode();
549 ep1->type = SYM;
550 ep1->v.name = savestr(getname());
551
552 #ifdef FUNCTION
553 if (nextc == '(') {
554 ep2 = newnode();
555 ep2->type = FUNC;
556 addekid(ep2, ep1);
557 ep1 = ep2;
558 do {
559 scan();
560 if (!isalpha(nextc))
561 syntax("illegal variable name");
562 ep2 = newnode();
563 ep2->type = SYM;
564 ep2->v.name = savestr(getname());
565 addekid(ep1, ep2);
566 } while (nextc == ',');
567 if (nextc != ')')
568 syntax("')' expected");
569 scan();
570 curfunc = ep1;
571 } else
572 curfunc = NULL;
573 #endif
574
575 if (nextc != '=' && nextc != ':')
576 syntax("'=' or ':' expected");
577
578 ep2 = newnode();
579 ep2->type = nextc;
580 scan();
581 addekid(ep2, ep1);
582 addekid(ep2, getE1());
583
584 if (
585 #ifdef FUNCTION
586 ep1->type == SYM &&
587 #endif
588 ep1->sibling->type != NUM) {
589 ep1 = newnode();
590 ep1->type = TICK;
591 ep1->v.tick = -1;
592 addekid(ep2, ep1);
593 ep1 = newnode();
594 ep1->type = NUM;
595 addekid(ep2, ep1);
596 }
597
598 return(ep2);
599 }
600
601
602 #ifdef OUTCHAN
603 EPNODE *
604 getchan() /* A -> $N = E1 */
605 {
606 register EPNODE *ep1, *ep2;
607
608 if (nextc != '$')
609 syntax("missing '$'");
610 scan();
611
612 ep1 = newnode();
613 ep1->type = CHAN;
614 ep1->v.chan = getinum();
615
616 if (nextc != '=')
617 syntax("'=' expected");
618 scan();
619
620 ep2 = newnode();
621 ep2->type = '=';
622 addekid(ep2, ep1);
623 addekid(ep2, getE1());
624
625 return(ep2);
626 }
627 #endif
628
629
630
631 /*
632 * The following routines are for internal use only:
633 */
634
635
636 static double
637 dvalue(name, d) /* evaluate a variable */
638 char *name;
639 EPNODE *d;
640 {
641 register EPNODE *ep1, *ep2;
642
643 if (d == NULL || d->v.kid->type != SYM) {
644 eputs(name);
645 eputs(": undefined variable\n");
646 quit(1);
647 }
648 ep1 = d->v.kid->sibling; /* get expression */
649 if (ep1->type == NUM)
650 return(ep1->v.num); /* return if number */
651 ep2 = ep1->sibling; /* check time */
652 if (ep2->v.tick < 0 || ep2->v.tick < eclock) {
653 ep2->v.tick = d->type == ':' ? 1L<<30 : eclock;
654 ep2 = ep2->sibling;
655 ep2->v.num = evalue(ep1); /* needs new value */
656 } else
657 ep2 = ep2->sibling; /* else reuse old value */
658
659 return(ep2->v.num);
660 }
661
662
663 static int
664 hash(s) /* hash a string */
665 register char *s;
666 {
667 register int rval = 0;
668
669 while (*s)
670 rval += *s++;
671
672 return(rval % NHASH);
673 }
