--- ray/src/common/caldefn.c 2003/04/27 06:08:03 2.15 +++ ray/src/common/caldefn.c 2003/07/03 22:41:44 2.17 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: caldefn.c,v 2.15 2003/04/27 06:08:03 greg Exp $"; +static const char RCSid[] = "$Id: caldefn.c,v 2.17 2003/07/03 22:41:44 schorsch Exp $"; #endif /* * Store variable definitions. @@ -66,8 +66,9 @@ EPNODE *curfunc = NULL; void -fcompile(fname) /* get definitions from a file */ -char *fname; +fcompile( /* get definitions from a file */ + char *fname +) { FILE *fp; @@ -87,10 +88,11 @@ char *fname; void -scompile(str, fn, ln) /* get definitions from a string */ -char *str; -char *fn; -int ln; +scompile( /* get definitions from a string */ + char *str, + char *fn, + int ln +) { initstr(str, fn, ln); while (nextc != EOF) @@ -99,16 +101,18 @@ int ln; double -varvalue(vname) /* return a variable's value */ -char *vname; +varvalue( /* return a variable's value */ + char *vname +) { return(dvalue(vname, dlookup(vname))); } double -evariable(ep) /* evaluate a variable */ -EPNODE *ep; +evariable( /* evaluate a variable */ + EPNODE *ep +) { register VARDEF *dp = ep->v.ln; @@ -117,10 +121,11 @@ EPNODE *ep; void -varset(vname, assign, val) /* set a variable's value */ -char *vname; -int assign; -double val; +varset( /* set a variable's value */ + char *vname, + int assign, + double val +) { char *qname; register EPNODE *ep1, *ep2; @@ -152,8 +157,9 @@ double val; void -dclear(name) /* delete variable definitions of name */ -char *name; +dclear( /* delete variable definitions of name */ + char *name +) { register EPNODE *ep; @@ -168,8 +174,9 @@ char *name; void -dremove(name) /* delete all definitions of name */ -char *name; +dremove( /* delete all definitions of name */ + char *name +) { register EPNODE *ep; @@ -179,8 +186,9 @@ char *name; int -vardefined(name) /* return non-zero if variable defined */ -char *name; +vardefined( /* return non-zero if variable defined */ + char *name +) { register EPNODE *dp; @@ -189,8 +197,9 @@ char *name; char * -setcontext(ctx) /* set a new context path */ -register char *ctx; +setcontext( /* set a new context path */ + register char *ctx +) { register char *cpp; @@ -221,8 +230,9 @@ register char *ctx; char * -pushcontext(ctx) /* push on another context */ -char *ctx; +pushcontext( /* push on another context */ + char *ctx +) { char oldcontext[MAXCNTX+1]; register int n; @@ -240,7 +250,7 @@ char *ctx; char * -popcontext() /* pop off top context */ +popcontext(void) /* pop off top context */ { register char *cp1, *cp2; @@ -257,11 +267,12 @@ popcontext() /* pop off top context */ char * -qualname(nam, lvl) /* get qualified name */ -register char *nam; -int lvl; +qualname( /* get qualified name */ + register char *nam, + int lvl +) { - static char nambuf[MAXWORD+1]; + static char nambuf[RMAXWORD+1]; register char *cp = nambuf, *cpp; /* check for explicit local */ if (*nam == CNTXMARK) @@ -273,7 +284,7 @@ int lvl; return(lvl > 0 ? NULL : nam); /* copy name to static buffer */ while (*nam) { - if (cp >= nambuf+MAXWORD) + if (cp >= nambuf+RMAXWORD) goto toolong; *cp++ = *nam++; } @@ -292,7 +303,7 @@ int lvl; ; } while (*cpp) { /* copy context to static buffer */ - if (cp >= nambuf+MAXWORD) + if (cp >= nambuf+RMAXWORD) goto toolong; *cp++ = *cpp++; } @@ -303,8 +314,9 @@ toolong: int -incontext(qn) /* is qualified name in current context? */ -register char *qn; +incontext( /* is qualified name in current context? */ + register char *qn +) { if (!context[0]) /* global context accepts all */ return(1); @@ -315,8 +327,9 @@ register char *qn; void -chanout(cs) /* set output channels */ -void (*cs)(); +chanout( /* set output channels */ + void (*cs)(int n, double v) +) { register EPNODE *ep; @@ -327,8 +340,9 @@ void (*cs)(); void -dcleanup(lvl) /* clear definitions (0->vars,1->output,2->consts) */ -int lvl; +dcleanup( /* clear definitions (0->vars,1->output,2->consts) */ + int lvl +) { register int i; register VARDEF *vp; @@ -350,8 +364,9 @@ int lvl; EPNODE * -dlookup(name) /* look up a definition */ -char *name; +dlookup( /* look up a definition */ + char *name +) { register VARDEF *vp; @@ -362,8 +377,9 @@ char *name; VARDEF * -varlookup(name) /* look up a variable */ -char *name; +varlookup( /* look up a variable */ + char *name +) { int lvl = 0; register char *qname; @@ -378,8 +394,9 @@ char *name; VARDEF * -varinsert(name) /* get a link to a variable */ -char *name; +varinsert( /* get a link to a variable */ + char *name +) { register VARDEF *vp; int hv; @@ -403,8 +420,9 @@ char *name; void -libupdate(fn) /* update library links */ -char *fn; +libupdate( /* update library links */ + char *fn +) { register int i; register VARDEF *vp; @@ -417,8 +435,9 @@ char *fn; void -varfree(ln) /* release link to variable */ -register VARDEF *ln; +varfree( /* release link to variable */ + register VARDEF *ln +) { register VARDEF *vp; int hv; @@ -441,7 +460,7 @@ register VARDEF *ln; EPNODE * -dfirst() /* return pointer to first definition */ +dfirst(void) /* return pointer to first definition */ { htndx = 0; htpos = NULL; @@ -451,7 +470,7 @@ dfirst() /* return pointer to first definition */ EPNODE * -dnext() /* return pointer to next definition */ +dnext(void) /* return pointer to next definition */ { register EPNODE *ep; register char *nm; @@ -474,8 +493,9 @@ dnext() /* return pointer to next definition */ EPNODE * -dpop(name) /* pop a definition */ -char *name; +dpop( /* pop a definition */ + char *name +) { register VARDEF *vp; register EPNODE *dp; @@ -490,9 +510,10 @@ char *name; void -dpush(nm, ep) /* push on a definition */ -char *nm; -register EPNODE *ep; +dpush( /* push on a definition */ + char *nm, + register EPNODE *ep +) { register VARDEF *vp; @@ -503,8 +524,9 @@ register EPNODE *ep; void -addchan(sp) /* add an output channel assignment */ -EPNODE *sp; +addchan( /* add an output channel assignment */ + EPNODE *sp +) { int ch = sp->v.kid->v.chan; register EPNODE *ep, *epl; @@ -533,7 +555,7 @@ EPNODE *sp; void -getstatement() /* get next statement */ +getstatement(void) /* get next statement */ { register EPNODE *ep; char *qname; @@ -576,10 +598,11 @@ getstatement() /* get next statement */ EPNODE * -getdefn() /* A -> SYM = E1 */ - /* SYM : E1 */ - /* FUNC(SYM,..) = E1 */ - /* FUNC(SYM,..) : E1 */ +getdefn(void) + /* A -> SYM = E1 */ + /* SYM : E1 */ + /* FUNC(SYM,..) = E1 */ + /* FUNC(SYM,..) : E1 */ { register EPNODE *ep1, *ep2; @@ -635,7 +658,7 @@ getdefn() /* A -> SYM = E1 */ EPNODE * -getchan() /* A -> $N = E1 */ +getchan(void) /* A -> $N = E1 */ { register EPNODE *ep1, *ep2; @@ -667,9 +690,10 @@ getchan() /* A -> $N = E1 */ static double -dvalue(name, d) /* evaluate a variable */ -char *name; -EPNODE *d; +dvalue( /* evaluate a variable */ +char *name, +EPNODE *d +) { register EPNODE *ep1, *ep2;
