--- ray/src/common/caldefn.c 1991/08/14 15:50:38 1.19 +++ ray/src/common/caldefn.c 1995/03/28 11:18:52 2.9 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -30,35 +30,37 @@ static char SCCSid[] = "$SunId$ LBL"; #include "calcomp.h" -#ifndef NHASH -#define NHASH 521 /* hash size (a prime!) */ +#ifndef NHASH +#define NHASH 521 /* hash size (a prime!) */ #endif -#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) +#define hash(s) (shash(s)%NHASH) -extern char *ecalloc(), *savestr(), *strcpy(); +#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) +extern char *ecalloc(), *emalloc(), *savestr(), *strcpy(); + static double dvalue(); -long eclock = -1; /* value storage timer */ +unsigned long eclock = 0; /* value storage timer */ static char context[MAXWORD+1]; /* current context path */ static VARDEF *hashtbl[NHASH]; /* definition list */ static int htndx; /* index for */ static VARDEF *htpos; /* ...dfirst() and */ -#ifdef OUTCHAN +#ifdef OUTCHAN static EPNODE *ochpos; /* ...dnext */ static EPNODE *outchan; #endif -#ifdef FUNCTION -EPNODE *curfunc; -#define dname(ep) ((ep)->v.kid->type == SYM ? \ +#ifdef FUNCTION +EPNODE *curfunc; +#define dname(ep) ((ep)->v.kid->type == SYM ? \ (ep)->v.kid->v.name : \ (ep)->v.kid->v.kid->v.name) #else -#define dname(ep) ((ep)->v.kid->v.name) +#define dname(ep) ((ep)->v.kid->v.name) #endif @@ -103,7 +105,7 @@ char *vname; double evariable(ep) /* evaluate a variable */ -EPNODE *ep; +EPNODE *ep; { register VARDEF *dp = ep->v.ln; @@ -114,7 +116,7 @@ EPNODE *ep; varset(vname, assign, val) /* set a variable's value */ char *vname; int assign; -double val; +double val; { char *qname; register EPNODE *ep1, *ep2; @@ -187,14 +189,15 @@ register char *ctx; if (ctx == NULL) return(context); /* just asking */ + while (*ctx == CNTXMARK) + ctx++; /* skip past marks */ if (!*ctx) { - context[0] = '\0'; /* clear context */ + context[0] = '\0'; /* empty means clear context */ return(context); } - cpp = context; /* else copy it (carefully!) */ - if (*ctx != CNTXMARK) - *cpp++ = CNTXMARK; /* make sure there's a mark */ - do { + cpp = context; /* start context with mark */ + *cpp++ = CNTXMARK; + do { /* carefully copy new context */ if (cpp >= context+MAXWORD) break; /* just copy what we can */ if (isid(*ctx)) @@ -203,17 +206,56 @@ register char *ctx; *cpp++ = '_'; ctx++; } } while (*ctx); + while (cpp[-1] == CNTXMARK) /* cannot end in context mark */ + cpp--; *cpp = '\0'; return(context); } char * +pushcontext(ctx) /* push on another context */ +char *ctx; +{ + extern char *strncpy(), *strcpy(); + char oldcontext[MAXWORD+1]; + register int n; + + strcpy(oldcontext, context); /* save old context */ + setcontext(ctx); /* set new context */ + n = strlen(context); /* tack on old */ + if (n+strlen(oldcontext) > MAXWORD) { + strncpy(context+n, oldcontext, MAXWORD-n); + context[MAXWORD] = '\0'; + } else + strcpy(context+n, oldcontext); + return(context); +} + + +char * +popcontext() /* pop off top context */ +{ + register char *cp1, *cp2; + + if (!context[0]) /* nothing left to pop */ + return(context); + cp2 = context; /* find mark */ + while (*++cp2 && *cp2 != CNTXMARK) + ; + cp1 = context; /* copy tail to front */ + while (*cp1++ = *cp2++) + ; + return(context); +} + + +char * qualname(nam, lvl) /* get qualified name */ register char *nam; int lvl; { - static char nambuf[MAXWORD+1]; + static char nambuf[MAXWORD+1]; register char *cp = nambuf, *cpp; /* check for explicit local */ if (*nam == CNTXMARK) @@ -257,13 +299,15 @@ toolong: incontext(qn) /* is qualified name in current context? */ register char *qn; { + if (!context[0]) /* global context accepts all */ + return(1); while (*qn && *qn != CNTXMARK) /* find context mark */ qn++; return(!strcmp(qn, context)); } -#ifdef OUTCHAN +#ifdef OUTCHAN chanout(cs) /* set output channels */ int (*cs)(); { @@ -285,12 +329,12 @@ int lvl; /* if context is global, clear all */ for (i = 0; i < NHASH; i++) for (vp = hashtbl[i]; vp != NULL; vp = vp->next) - if (!context[0] || incontext(vp->name)) + if (incontext(vp->name)) if (lvl >= 2) dremove(vp->name); else dclear(vp->name); -#ifdef OUTCHAN +#ifdef OUTCHAN if (lvl >= 1) { for (ep = outchan; ep != NULL; ep = ep->sibling) epfree(ep); @@ -307,7 +351,7 @@ char *name; register VARDEF *vp; if ((vp = varlookup(name)) == NULL) - return(NULL); + return(NULL); return(vp->def); } @@ -316,10 +360,10 @@ VARDEF * varlookup(name) /* look up a variable */ char *name; { - int lvl = 0; + int lvl = 0; register char *qname; register VARDEF *vp; - /* find most qualified match */ + /* find most qualified match */ while ((qname = qualname(name, lvl++)) != NULL) for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next) if (!strcmp(vp->name, qname)) @@ -333,49 +377,62 @@ varinsert(name) /* get a link to a variable */ char *name; { register VARDEF *vp; - LIBR *libp; - int hv; + int hv; if ((vp = varlookup(name)) != NULL) { vp->nlinks++; return(vp); } -#ifdef FUNCTION - libp = liblookup(name); + vp = (VARDEF *)emalloc(sizeof(VARDEF)); +#ifdef FUNCTION + vp->lib = liblookup(name); #else - libp = NULL; + vp->lib = NULL; #endif - if (libp == NULL) /* if name not in library */ + if (vp->lib == NULL) /* if name not in library */ name = qualname(name, 0); /* use fully qualified version */ hv = hash(name); - vp = (VARDEF *)emalloc(sizeof(VARDEF)); vp->name = savestr(name); vp->nlinks = 1; vp->def = NULL; - vp->lib = libp; vp->next = hashtbl[hv]; hashtbl[hv] = vp; return(vp); } +#ifdef FUNCTION +libupdate(fn) /* update library links */ +char *fn; +{ + register int i; + register VARDEF *vp; + /* if fn is NULL then relink all */ + for (i = 0; i < NHASH; i++) + for (vp = hashtbl[i]; vp != NULL; vp = vp->next) + if (vp->lib != NULL || fn == NULL || !strcmp(fn, vp->name)) + vp->lib = liblookup(vp->name); +} +#endif + + varfree(ln) /* release link to variable */ -register VARDEF *ln; +register VARDEF *ln; { register VARDEF *vp; - int hv; + int hv; if (--ln->nlinks > 0) - return; /* still active */ + return; /* still active */ hv = hash(ln->name); vp = hashtbl[hv]; if (vp == ln) - hashtbl[hv] = vp->next; + hashtbl[hv] = vp->next; else { - while (vp->next != ln) /* must be in list */ - vp = vp->next; - vp->next = ln->next; + while (vp->next != ln) /* must be in list */ + vp = vp->next; + vp->next = ln->next; } freestr(ln->name); efree((char *)ln); @@ -387,7 +444,7 @@ dfirst() /* return pointer to first definition */ { htndx = 0; htpos = NULL; -#ifdef OUTCHAN +#ifdef OUTCHAN ochpos = outchan; #endif return(dnext()); @@ -401,19 +458,19 @@ dnext() /* return pointer to next definition */ register char *nm; while (htndx < NHASH) { - if (htpos == NULL) - htpos = hashtbl[htndx++]; - while (htpos != NULL) { - ep = htpos->def; + if (htpos == NULL) + htpos = hashtbl[htndx++]; + while (htpos != NULL) { + ep = htpos->def; nm = htpos->name; - htpos = htpos->next; - if (ep != NULL && incontext(nm)) - return(ep); - } + htpos = htpos->next; + if (ep != NULL && incontext(nm)) + return(ep); + } } -#ifdef OUTCHAN +#ifdef OUTCHAN if ((ep = ochpos) != NULL) - ochpos = ep->sibling; + ochpos = ep->sibling; return(ep); #else return(NULL); @@ -429,7 +486,7 @@ char *name; register EPNODE *dp; if ((vp = varlookup(name)) == NULL || vp->def == NULL) - return(NULL); + return(NULL); dp = vp->def; vp->def = dp->sibling; varfree(vp); @@ -439,7 +496,7 @@ char *name; dpush(nm, ep) /* push on a definition */ char *nm; -register EPNODE *ep; +register EPNODE *ep; { register VARDEF *vp; @@ -449,11 +506,11 @@ register EPNODE *ep; } -#ifdef OUTCHAN +#ifdef OUTCHAN addchan(sp) /* add an output channel assignment */ -EPNODE *sp; +EPNODE *sp; { - int ch = sp->v.kid->v.chan; + int ch = sp->v.kid->v.chan; register EPNODE *ep, *epl; for (epl = NULL, ep = outchan; ep != NULL; epl = ep, ep = ep->sibling) @@ -490,7 +547,7 @@ getstatement() /* get next statement */ scan(); return; } -#ifdef OUTCHAN +#ifdef OUTCHAN if (nextc == '$') { /* channel assignment */ ep = getchan(); addchan(ep); @@ -499,16 +556,16 @@ getstatement() /* get next statement */ { /* ordinary definition */ ep = getdefn(); qname = qualname(dname(ep), 0); -#ifdef REDEFW +#ifdef REDEFW if ((vdef = varlookup(qname)) != NULL) - if (vdef->def != NULL) { + if (vdef->def != NULL && epcmp(ep, vdef->def)) { wputs(qname); if (vdef->def->type == ':') wputs(": redefined constant expression\n"); else wputs(": redefined\n"); } -#ifdef FUNCTION +#ifdef FUNCTION else if (ep->v.kid->type == FUNC && vdef->lib != NULL) { wputs(qname); wputs(": definition hides library function\n"); @@ -532,7 +589,7 @@ getstatement() /* get next statement */ EPNODE * getdefn() /* A -> SYM = E1 */ /* SYM : E1 */ - /* FUNC(SYM,..) = E1 */ + /* FUNC(SYM,..) = E1 */ /* FUNC(SYM,..) : E1 */ { register EPNODE *ep1, *ep2; @@ -544,7 +601,7 @@ getdefn() /* A -> SYM = E1 */ ep1->type = SYM; ep1->v.name = savestr(getname()); -#ifdef FUNCTION +#ifdef FUNCTION if (nextc == '(') { ep2 = newnode(); ep2->type = FUNC; @@ -577,13 +634,13 @@ getdefn() /* A -> SYM = E1 */ addekid(ep2, getE1()); if ( -#ifdef FUNCTION - ep1->type == SYM && +#ifdef FUNCTION + ep1->type == SYM && #endif ep1->sibling->type != NUM) { ep1 = newnode(); ep1->type = TICK; - ep1->v.tick = -1; + ep1->v.tick = 0; addekid(ep2, ep1); ep1 = newnode(); ep1->type = NUM; @@ -594,7 +651,7 @@ getdefn() /* A -> SYM = E1 */ } -#ifdef OUTCHAN +#ifdef OUTCHAN EPNODE * getchan() /* A -> $N = E1 */ { @@ -631,7 +688,7 @@ getchan() /* A -> $N = E1 */ static double dvalue(name, d) /* evaluate a variable */ char *name; -EPNODE *d; +EPNODE *d; { register EPNODE *ep1, *ep2; @@ -644,25 +701,12 @@ EPNODE *d; if (ep1->type == NUM) return(ep1->v.num); /* return if number */ ep2 = ep1->sibling; /* check time */ - if (ep2->v.tick < 0 || ep2->v.tick < eclock) { - ep2->v.tick = d->type == ':' ? 1L<<30 : eclock; + if (ep2->v.tick == 0 || ep2->v.tick < eclock) { + ep2->v.tick = d->type == ':' ? ~0L : eclock; ep2 = ep2->sibling; ep2->v.num = evalue(ep1); /* needs new value */ } else ep2 = ep2->sibling; /* else reuse old value */ return(ep2->v.num); -} - - -static int -hash(s) /* hash a string */ -register char *s; -{ - register int rval = 0; - - while (*s) - rval += *s++; - - return(rval % NHASH); }
