--- ray/src/common/caldefn.c 1991/04/29 08:33:13 1.10 +++ ray/src/common/caldefn.c 1991/08/08 11:22:06 1.13 @@ -20,6 +20,8 @@ static char SCCSid[] = "$SunId$ LBL"; * 5/31/90 Added conditional compile (REDEFW) for redefinition warning. * * 4/23/91 Added ':' assignment for constant expressions + * + * 8/7/91 Added optional context path to append to variable names */ #include @@ -34,12 +36,14 @@ static char SCCSid[] = "$SunId$ LBL"; #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) -extern char *ecalloc(), *savestr(); +extern char *ecalloc(), *savestr(), *strcpy(); static double dvalue(); long eclock = -1; /* value storage timer */ +static char context[MAXWORD]; /* current context path */ + static VARDEF *hashtbl[NHASH]; /* definition list */ static int htndx; /* index for */ static VARDEF *htpos; /* ...dfirst() and */ @@ -72,7 +76,7 @@ char *fname; } initfile(fp, fname, 0); while (nextc != EOF) - loaddefn(); + getstatement(); if (fname != NULL) fclose(fp); } @@ -85,7 +89,7 @@ int ln; { initstr(str, fn, ln); while (nextc != EOF) - loaddefn(); + getstatement(); } @@ -112,9 +116,12 @@ char *vname; int assign; double val; { + char *qname; register EPNODE *ep1, *ep2; + /* get qualified name */ + qname = qualname(vname, 0); /* check for quick set */ - if ((ep1 = dlookup(vname)) != NULL && ep1->v.kid->type == SYM) { + if ((ep1 = dlookup(qname)) != NULL && ep1->v.kid->type == SYM) { ep2 = ep1->v.kid->sibling; if (ep2->type == NUM) { ep2->v.num = val; @@ -133,8 +140,8 @@ double val; ep2->type = NUM; ep2->v.num = val; addekid(ep1, ep2); - dremove(vname); - dpush(ep1); + dremove(qname); + dpush(qname, ep1); } @@ -145,7 +152,7 @@ char *name; while ((ep = dpop(name)) != NULL) { if (ep->type == ':') { - dpush(ep); /* don't clear constants */ + dpush(name, ep); /* don't clear constants */ return; } epfree(ep); @@ -172,6 +179,85 @@ char *name; } +char * +setcontext(ctx) /* set a new context path */ +register char *ctx; +{ + register char *cpp; + + if (ctx == NULL) + return(context); /* just asking */ + if (!*ctx) { + context[0] = '\0'; /* clear context */ + return(context); + } + cpp = context; /* else copy it (carefully!) */ + if (*ctx != CNTXMARK) + *cpp++ = CNTXMARK; /* make sure there's a mark */ + do { + if (cpp >= context+MAXWORD-1) { + *cpp = '\0'; + wputs(context); + wputs(": context path too long\n"); + return(NULL); + } + if (isid(*ctx)) + *cpp++ = *ctx++; + else { + *cpp++ = '_'; ctx++; + } + } while (*ctx); + *cpp = '\0'; + return(context); +} + + +char * +qualname(nam, lvl) /* get qualified name */ +register char *nam; +int lvl; +{ + static char nambuf[MAXWORD]; + register char *cp = nambuf, *cpp = context; + /* check for repeat call */ + if (nam == nambuf) + return(lvl > 0 ? NULL : nambuf); + /* copy name to static buffer */ + while (*nam) { + if (cp >= nambuf+MAXWORD-1) + goto toolong; + if ((*cp++ = *nam++) == CNTXMARK) + cpp = NULL; /* flag a qualified name */ + } + if (cpp == NULL) { + if (lvl > 0) + return(NULL); /* no higher level */ + if (cp[-1] == CNTXMARK) { + cp--; cpp = context; /* current context explicitly */ + } else + cpp = ""; /* else fully qualified */ + } else /* else skip the requested levels */ + while (lvl-- > 0) { + if (!*cpp) + return(NULL); /* return NULL if past global level */ + while (*++cpp && *cpp != CNTXMARK) + ; + } + while (*cpp) { /* copy context to static buffer */ + if (cp >= nambuf+MAXWORD-1) + goto toolong; + *cp++ = *cpp++; + } + *cp = '\0'; + return(nambuf); /* return qualified name */ +toolong: + *cp = '\0'; + wputs(nambuf); + wputs(": name too long\n"); + return(NULL); +} + + #ifdef OUTCHAN chanout(cs) /* set output channels */ int (*cs)(); @@ -185,7 +271,7 @@ int (*cs)(); #endif -dcleanup(lvl) /* clear definitions (0->vars,1->consts,2->output) */ +dcleanup(lvl) /* clear definitions (0->vars,1->output,2->consts) */ int lvl; { register int i; @@ -194,12 +280,12 @@ int lvl; for (i = 0; i < NHASH; i++) for (vp = hashtbl[i]; vp != NULL; vp = vp->next) - if (lvl >= 1) + if (lvl >= 2) dremove(vp->name); else dclear(vp->name); #ifdef OUTCHAN - if (lvl >= 2) { + if (lvl >= 1) { for (ep = outchan; ep != NULL; ep = ep->sibling) epfree(ep); outchan = NULL; @@ -224,11 +310,14 @@ VARDEF * varlookup(name) /* look up a variable */ char *name; { + int lvl = 0; + register char *qname; register VARDEF *vp; - - for (vp = hashtbl[hash(name)]; vp != NULL; vp = vp->next) - if (!strcmp(vp->name, name)) - return(vp); + /* find most qualified match */ + while ((qname = qualname(name, lvl++)) != NULL) + for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next) + if (!strcmp(vp->name, qname)) + return(vp); return(NULL); } @@ -240,12 +329,12 @@ char *name; register VARDEF *vp; int hv; + if ((vp = varlookup(name)) != NULL) { + vp->nlinks++; + return(vp); + } + name = qualname(name, 0); /* use fully qualified name */ hv = hash(name); - for (vp = hashtbl[hv]; vp != NULL; vp = vp->next) - if (!strcmp(vp->name, name)) { - vp->nlinks++; - return(vp); - } vp = (VARDEF *)emalloc(sizeof(VARDEF)); vp->name = savestr(name); vp->nlinks = 1; @@ -333,12 +422,13 @@ char *name; } -dpush(ep) /* push on a definition */ +dpush(nm, ep) /* push on a definition */ +char *nm; register EPNODE *ep; { register VARDEF *vp; - vp = varinsert(dname(ep)); + vp = varinsert(nm); ep->sibling = vp->def; vp->def = ep; } @@ -375,9 +465,10 @@ EPNODE *sp; #endif -loaddefn() /* load next definition */ +getstatement() /* get next statement */ { register EPNODE *ep; + char *qname; EPNODE *lastdef; if (nextc == ';') { /* empty statement */ @@ -392,27 +483,27 @@ loaddefn() /* load next definition */ #endif { /* ordinary definition */ ep = getdefn(); + qname = qualname(dname(ep), 0); #ifdef REDEFW - if ((lastdef = dlookup(dname(ep))) != NULL) { - wputs(dname(ep)); + if ((lastdef = dlookup(qname)) != NULL) { + wputs(qname); if (lastdef->type == ':') wputs(": redefined constant expression\n"); else wputs(": redefined\n"); } #ifdef FUNCTION - else if (ep->v.kid->type == FUNC && - liblookup(ep->v.kid->v.kid->v.name) != NULL) { - wputs(ep->v.kid->v.kid->v.name); - wputs(": redefined library function\n"); + else if (ep->v.kid->type == FUNC && liblookup(qname) != NULL) { + wputs(qname); + wputs(": definition hides library function\n"); } #endif #endif if (ep->type == ':') - dremove(dname(ep)); + dremove(qname); else - dclear(dname(ep)); - dpush(ep); + dclear(qname); + dpush(qname, ep); } if (nextc != EOF) { if (nextc != ';')
