--- ray/src/common/caldefn.c 2003/02/25 02:47:21 2.13 +++ ray/src/common/caldefn.c 2003/07/21 22:30:17 2.19 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: caldefn.c,v 2.13 2003/02/25 02:47:21 greg Exp $"; +static const char RCSid[] = "$Id: caldefn.c,v 2.19 2003/07/21 22:30:17 schorsch Exp $"; #endif /* * Store variable definitions. @@ -28,11 +28,10 @@ static const char RCSid[] = "$Id: caldefn.c,v 2.13 200 #include "copyright.h" #include - #include - #include +#include "rterror.h" #include "calcomp.h" #ifndef NHASH @@ -43,7 +42,7 @@ static const char RCSid[] = "$Id: caldefn.c,v 2.13 200 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) -static double dvalue(); +static double dvalue(char *name, EPNODE *d); #define MAXCLOCK (1L<<31) /* clock wrap value */ @@ -66,8 +65,9 @@ EPNODE *curfunc = NULL; void -fcompile(fname) /* get definitions from a file */ -char *fname; +fcompile( /* get definitions from a file */ + char *fname +) { FILE *fp; @@ -87,10 +87,11 @@ char *fname; void -scompile(str, fn, ln) /* get definitions from a string */ -char *str; -char *fn; -int ln; +scompile( /* get definitions from a string */ + char *str, + char *fn, + int ln +) { initstr(str, fn, ln); while (nextc != EOF) @@ -99,16 +100,18 @@ int ln; double -varvalue(vname) /* return a variable's value */ -char *vname; +varvalue( /* return a variable's value */ + char *vname +) { return(dvalue(vname, dlookup(vname))); } double -evariable(ep) /* evaluate a variable */ -EPNODE *ep; +evariable( /* evaluate a variable */ + EPNODE *ep +) { register VARDEF *dp = ep->v.ln; @@ -117,10 +120,11 @@ EPNODE *ep; void -varset(vname, assign, val) /* set a variable's value */ -char *vname; -int assign; -double val; +varset( /* set a variable's value */ + char *vname, + int assign, + double val +) { char *qname; register EPNODE *ep1, *ep2; @@ -152,8 +156,9 @@ double val; void -dclear(name) /* delete variable definitions of name */ -char *name; +dclear( /* delete variable definitions of name */ + char *name +) { register EPNODE *ep; @@ -168,8 +173,9 @@ char *name; void -dremove(name) /* delete all definitions of name */ -char *name; +dremove( /* delete all definitions of name */ + char *name +) { register EPNODE *ep; @@ -179,8 +185,9 @@ char *name; int -vardefined(name) /* return non-zero if variable defined */ -char *name; +vardefined( /* return non-zero if variable defined */ + char *name +) { register EPNODE *dp; @@ -189,8 +196,9 @@ char *name; char * -setcontext(ctx) /* set a new context path */ -register char *ctx; +setcontext( /* set a new context path */ + register char *ctx +) { register char *cpp; @@ -221,10 +229,10 @@ register char *ctx; char * -pushcontext(ctx) /* push on another context */ -char *ctx; +pushcontext( /* push on another context */ + char *ctx +) { - extern char *strncpy(), *strcpy(); char oldcontext[MAXCNTX+1]; register int n; @@ -241,7 +249,7 @@ char *ctx; char * -popcontext() /* pop off top context */ +popcontext(void) /* pop off top context */ { register char *cp1, *cp2; @@ -258,11 +266,12 @@ popcontext() /* pop off top context */ char * -qualname(nam, lvl) /* get qualified name */ -register char *nam; -int lvl; +qualname( /* get qualified name */ + register char *nam, + int lvl +) { - static char nambuf[MAXWORD+1]; + static char nambuf[RMAXWORD+1]; register char *cp = nambuf, *cpp; /* check for explicit local */ if (*nam == CNTXMARK) @@ -274,7 +283,7 @@ int lvl; return(lvl > 0 ? NULL : nam); /* copy name to static buffer */ while (*nam) { - if (cp >= nambuf+MAXWORD) + if (cp >= nambuf+RMAXWORD) goto toolong; *cp++ = *nam++; } @@ -293,7 +302,7 @@ int lvl; ; } while (*cpp) { /* copy context to static buffer */ - if (cp >= nambuf+MAXWORD) + if (cp >= nambuf+RMAXWORD) goto toolong; *cp++ = *cpp++; } @@ -304,8 +313,9 @@ toolong: int -incontext(qn) /* is qualified name in current context? */ -register char *qn; +incontext( /* is qualified name in current context? */ + register char *qn +) { if (!context[0]) /* global context accepts all */ return(1); @@ -316,8 +326,9 @@ register char *qn; void -chanout(cs) /* set output channels */ -int (*cs)(); +chanout( /* set output channels */ + void (*cs)(int n, double v) +) { register EPNODE *ep; @@ -328,8 +339,9 @@ int (*cs)(); void -dcleanup(lvl) /* clear definitions (0->vars,1->output,2->consts) */ -int lvl; +dcleanup( /* clear definitions (0->vars,1->output,2->consts) */ + int lvl +) { register int i; register VARDEF *vp; @@ -337,11 +349,12 @@ int lvl; /* if context is global, clear all */ for (i = 0; i < NHASH; i++) for (vp = hashtbl[i]; vp != NULL; vp = vp->next) - if (incontext(vp->name)) + if (incontext(vp->name)) { if (lvl >= 2) dremove(vp->name); else dclear(vp->name); + } if (lvl >= 1) { for (ep = outchan; ep != NULL; ep = ep->sibling) epfree(ep); @@ -351,8 +364,9 @@ int lvl; EPNODE * -dlookup(name) /* look up a definition */ -char *name; +dlookup( /* look up a definition */ + char *name +) { register VARDEF *vp; @@ -363,8 +377,9 @@ char *name; VARDEF * -varlookup(name) /* look up a variable */ -char *name; +varlookup( /* look up a variable */ + char *name +) { int lvl = 0; register char *qname; @@ -379,8 +394,9 @@ char *name; VARDEF * -varinsert(name) /* get a link to a variable */ -char *name; +varinsert( /* get a link to a variable */ + char *name +) { register VARDEF *vp; int hv; @@ -404,8 +420,9 @@ char *name; void -libupdate(fn) /* update library links */ -char *fn; +libupdate( /* update library links */ + char *fn +) { register int i; register VARDEF *vp; @@ -418,8 +435,9 @@ char *fn; void -varfree(ln) /* release link to variable */ -register VARDEF *ln; +varfree( /* release link to variable */ + register VARDEF *ln +) { register VARDEF *vp; int hv; @@ -442,7 +460,7 @@ register VARDEF *ln; EPNODE * -dfirst() /* return pointer to first definition */ +dfirst(void) /* return pointer to first definition */ { htndx = 0; htpos = NULL; @@ -452,7 +470,7 @@ dfirst() /* return pointer to first definition */ EPNODE * -dnext() /* return pointer to next definition */ +dnext(void) /* return pointer to next definition */ { register EPNODE *ep; register char *nm; @@ -475,8 +493,9 @@ dnext() /* return pointer to next definition */ EPNODE * -dpop(name) /* pop a definition */ -char *name; +dpop( /* pop a definition */ + char *name +) { register VARDEF *vp; register EPNODE *dp; @@ -491,9 +510,10 @@ char *name; void -dpush(nm, ep) /* push on a definition */ -char *nm; -register EPNODE *ep; +dpush( /* push on a definition */ + char *nm, + register EPNODE *ep +) { register VARDEF *vp; @@ -504,8 +524,9 @@ register EPNODE *ep; void -addchan(sp) /* add an output channel assignment */ -EPNODE *sp; +addchan( /* add an output channel assignment */ + EPNODE *sp +) { int ch = sp->v.kid->v.chan; register EPNODE *ep, *epl; @@ -534,7 +555,7 @@ EPNODE *sp; void -getstatement() /* get next statement */ +getstatement(void) /* get next statement */ { register EPNODE *ep; char *qname; @@ -551,7 +572,7 @@ getstatement() /* get next statement */ } else { /* ordinary definition */ ep = getdefn(); qname = qualname(dname(ep), 0); - if (esupport&E_REDEFW && (vdef = varlookup(qname)) != NULL) + if (esupport&E_REDEFW && (vdef = varlookup(qname)) != NULL) { if (vdef->def != NULL && epcmp(ep, vdef->def)) { wputs(qname); if (vdef->def->type == ':') @@ -562,6 +583,7 @@ getstatement() /* get next statement */ wputs(qname); wputs(": definition hides library function\n"); } + } if (ep->type == ':') dremove(qname); else @@ -577,10 +599,11 @@ getstatement() /* get next statement */ EPNODE * -getdefn() /* A -> SYM = E1 */ - /* SYM : E1 */ - /* FUNC(SYM,..) = E1 */ - /* FUNC(SYM,..) : E1 */ +getdefn(void) + /* A -> SYM = E1 */ + /* SYM : E1 */ + /* FUNC(SYM,..) = E1 */ + /* FUNC(SYM,..) : E1 */ { register EPNODE *ep1, *ep2; @@ -636,7 +659,7 @@ getdefn() /* A -> SYM = E1 */ EPNODE * -getchan() /* A -> $N = E1 */ +getchan(void) /* A -> $N = E1 */ { register EPNODE *ep1, *ep2; @@ -667,10 +690,8 @@ getchan() /* A -> $N = E1 */ */ -static double -dvalue(name, d) /* evaluate a variable */ -char *name; -EPNODE *d; +static double /* evaluate a variable */ +dvalue(char *name, EPNODE *d) { register EPNODE *ep1, *ep2;
