root/radiance/ray/src/common/caldefn.c
Revision: 1.18
Committed: Wed Aug 14 08:27:56 1991 UTC (34 years ago) by greg
Changes since 1.17: +8 -16 lines
fixed code relating to long identifiers
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Store variable definitions.
9 *
10 * 7/1/85 Greg Ward
11 *
12 * 11/11/85 Added conditional compiles (OUTCHAN) for control output.
13 *
14 * 4/2/86 Added conditional compiles for function definitions (FUNCTION).
15 *
16 * 1/15/88 Added clock for caching of variable values.
17 *
18 * 11/16/88 Added VARDEF structure for hard linking.
19 *
20 * 5/31/90 Added conditional compile (REDEFW) for redefinition warning.
21 *
22 * 4/23/91 Added ':' assignment for constant expressions
23 *
24 * 8/7/91 Added optional context path to append to variable names
25 */
26
27 #include <stdio.h>
28
29 #include <ctype.h>
30
31 #include "calcomp.h"
32
33 #ifndef NHASH
34 #define NHASH 521 /* hash size (a prime!) */
35 #endif
36
37 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
38
39 extern char *ecalloc(), *savestr(), *strcpy();
40
41 static double dvalue();
42
43 long eclock = -1; /* value storage timer */
44
45 static char context[MAXWORD+1]; /* current context path */
46
47 static VARDEF *hashtbl[NHASH]; /* definition list */
48 static int htndx; /* index for */
49 static VARDEF *htpos; /* ...dfirst() and */
50 #ifdef OUTCHAN
51 static EPNODE *ochpos; /* ...dnext */
52 static EPNODE *outchan;
53 #endif
54
55 #ifdef FUNCTION
56 EPNODE *curfunc;
57 #define dname(ep) ((ep)->v.kid->type == SYM ? \
58 (ep)->v.kid->v.name : \
59 (ep)->v.kid->v.kid->v.name)
60 #else
61 #define dname(ep) ((ep)->v.kid->v.name)
62 #endif
63
64
65 fcompile(fname) /* get definitions from a file */
66 char *fname;
67 {
68 FILE *fp;
69
70 if (fname == NULL)
71 fp = stdin;
72 else if ((fp = fopen(fname, "r")) == NULL) {
73 eputs(fname);
74 eputs(": cannot open\n");
75 quit(1);
76 }
77 initfile(fp, fname, 0);
78 while (nextc != EOF)
79 getstatement();
80 if (fname != NULL)
81 fclose(fp);
82 }
83
84
85 scompile(str, fn, ln) /* get definitions from a string */
86 char *str;
87 char *fn;
88 int ln;
89 {
90 initstr(str, fn, ln);
91 while (nextc != EOF)
92 getstatement();
93 }
94
95
96 double
97 varvalue(vname) /* return a variable's value */
98 char *vname;
99 {
100 return(dvalue(vname, dlookup(vname)));
101 }
102
103
104 double
105 evariable(ep) /* evaluate a variable */
106 EPNODE *ep;
107 {
108 register VARDEF *dp = ep->v.ln;
109
110 return(dvalue(dp->name, dp->def));
111 }
112
113
114 varset(vname, assign, val) /* set a variable's value */
115 char *vname;
116 int assign;
117 double val;
118 {
119 char *qname;
120 register EPNODE *ep1, *ep2;
121 /* get qualified name */
122 qname = qualname(vname, 0);
123 /* check for quick set */
124 if ((ep1 = dlookup(qname)) != NULL && ep1->v.kid->type == SYM) {
125 ep2 = ep1->v.kid->sibling;
126 if (ep2->type == NUM) {
127 ep2->v.num = val;
128 ep1->type = assign;
129 return;
130 }
131 }
132 /* hand build definition */
133 ep1 = newnode();
134 ep1->type = assign;
135 ep2 = newnode();
136 ep2->type = SYM;
137 ep2->v.name = savestr(vname);
138 addekid(ep1, ep2);
139 ep2 = newnode();
140 ep2->type = NUM;
141 ep2->v.num = val;
142 addekid(ep1, ep2);
143 dremove(qname);
144 dpush(qname, ep1);
145 }
146
147
148 dclear(name) /* delete variable definitions of name */
149 char *name;
150 {
151 register EPNODE *ep;
152
153 while ((ep = dpop(name)) != NULL) {
154 if (ep->type == ':') {
155 dpush(name, ep); /* don't clear constants */
156 return;
157 }
158 epfree(ep);
159 }
160 }
161
162
163 dremove(name) /* delete all definitions of name */
164 char *name;
165 {
166 register EPNODE *ep;
167
168 while ((ep = dpop(name)) != NULL)
169 epfree(ep);
170 }
171
172
173 vardefined(name) /* return non-zero if variable defined */
174 char *name;
175 {
176 register EPNODE *dp;
177
178 return((dp = dlookup(name)) != NULL && dp->v.kid->type == SYM);
179 }
180
181
182 char *
183 setcontext(ctx) /* set a new context path */
184 register char *ctx;
185 {
186 register char *cpp;
187
188 if (ctx == NULL)
189 return(context); /* just asking */
190 if (!*ctx) {
191 context[0] = '\0'; /* clear context */
192 return(context);
193 }
194 cpp = context; /* else copy it (carefully!) */
195 if (*ctx != CNTXMARK)
196 *cpp++ = CNTXMARK; /* make sure there's a mark */
197 do {
198 if (cpp >= context+MAXWORD)
199 break; /* just copy what we can */
200 if (isid(*ctx))
201 *cpp++ = *ctx++;
202 else {
203 *cpp++ = '_'; ctx++;
204 }
205 } while (*ctx);
206 *cpp = '\0';
207 return(context);
208 }
209
210
211 char *
212 qualname(nam, lvl) /* get qualified name */
213 register char *nam;
214 int lvl;
215 {
216 static char nambuf[MAXWORD+1];
217 register char *cp = nambuf, *cpp;
218 /* check for explicit local */
219 if (*nam == CNTXMARK)
220 if (lvl > 0) /* only action is to refuse search */
221 return(NULL);
222 else
223 nam++;
224 else if (nam == nambuf) /* check for repeat call */
225 return(lvl > 0 ? NULL : nam);
226 /* copy name to static buffer */
227 while (*nam) {
228 if (cp >= nambuf+MAXWORD)
229 goto toolong;
230 *cp++ = *nam++;
231 }
232 /* check for explicit global */
233 if (cp > nambuf && cp[-1] == CNTXMARK) {
234 if (lvl > 0)
235 return(NULL);
236 *--cp = '\0';
237 return(nambuf); /* already qualified */
238 }
239 cpp = context; /* else skip the requested levels */
240 while (lvl-- > 0) {
241 if (!*cpp)
242 return(NULL); /* return NULL if past global level */
243 while (*++cpp && *cpp != CNTXMARK)
244 ;
245 }
246 while (*cpp) { /* copy context to static buffer */
247 if (cp >= nambuf+MAXWORD)
248 goto toolong;
249 *cp++ = *cpp++;
250 }
251 toolong:
252 *cp = '\0';
253 return(nambuf); /* return qualified name */
254 }
255
256
257 incontext(qn) /* is qualified name in current context? */
258 register char *qn;
259 {
260 while (*qn && *qn != CNTXMARK) /* find context mark */
261 ;
262 return(!strcmp(qn, context));
263 }
264
265
266 #ifdef OUTCHAN
267 chanout(cs) /* set output channels */
268 int (*cs)();
269 {
270 register EPNODE *ep;
271
272 for (ep = outchan; ep != NULL; ep = ep->sibling)
273 (*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling));
274
275 }
276 #endif
277
278
279 dcleanup(lvl) /* clear definitions (0->vars,1->output,2->consts) */
280 int lvl;
281 {
282 register int i;
283 register VARDEF *vp;
284 register EPNODE *ep;
285 /* if context is global, clear all */
286 for (i = 0; i < NHASH; i++)
287 for (vp = hashtbl[i]; vp != NULL; vp = vp->next)
288 if (!context[0] || incontext(vp->name))
289 if (lvl >= 2)
290 dremove(vp->name);
291 else
292 dclear(vp->name);
293 #ifdef OUTCHAN
294 if (lvl >= 1) {
295 for (ep = outchan; ep != NULL; ep = ep->sibling)
296 epfree(ep);
297 outchan = NULL;
298 }
299 #endif
300 }
301
302
303 EPNODE *
304 dlookup(name) /* look up a definition */
305 char *name;
306 {
307 register VARDEF *vp;
308
309 if ((vp = varlookup(name)) == NULL)
310 return(NULL);
311 return(vp->def);
312 }
313
314
315 VARDEF *
316 varlookup(name) /* look up a variable */
317 char *name;
318 {
319 int lvl = 0;
320 register char *qname;
321 register VARDEF *vp;
322 /* find most qualified match */
323 while ((qname = qualname(name, lvl++)) != NULL)
324 for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next)
325 if (!strcmp(vp->name, qname))
326 return(vp);
327 return(NULL);
328 }
329
330
331 VARDEF *
332 varinsert(name) /* get a link to a variable */
333 char *name;
334 {
335 register VARDEF *vp;
336 LIBR *libp;
337 int hv;
338
339 if ((vp = varlookup(name)) != NULL) {
340 vp->nlinks++;
341 return(vp);
342 }
343 #ifdef FUNCTION
344 libp = liblookup(name);
345 #else
346 libp = NULL;
347 #endif
348 if (libp == NULL) /* if name not in library */
349 name = qualname(name, 0); /* use fully qualified version */
350 hv = hash(name);
351 vp = (VARDEF *)emalloc(sizeof(VARDEF));
352 vp->name = savestr(name);
353 vp->nlinks = 1;
354 vp->def = NULL;
355 vp->lib = libp;
356 vp->next = hashtbl[hv];
357 hashtbl[hv] = vp;
358 return(vp);
359 }
360
361
362 varfree(ln) /* release link to variable */
363 register VARDEF *ln;
364 {
365 register VARDEF *vp;
366 int hv;
367
368 if (--ln->nlinks > 0)
369 return; /* still active */
370
371 hv = hash(ln->name);
372 vp = hashtbl[hv];
373 if (vp == ln)
374 hashtbl[hv] = vp->next;
375 else {
376 while (vp->next != ln) /* must be in list */
377 vp = vp->next;
378 vp->next = ln->next;
379 }
380 freestr(ln->name);
381 efree((char *)ln);
382 }
383
384
385 EPNODE *
386 dfirst() /* return pointer to first definition */
387 {
388 htndx = 0;
389 htpos = NULL;
390 #ifdef OUTCHAN
391 ochpos = outchan;
392 #endif
393 return(dnext());
394 }
395
396
397 EPNODE *
398 dnext() /* return pointer to next definition */
399 {
400 register EPNODE *ep;
401
402 while (htndx < NHASH) {
403 if (htpos == NULL)
404 htpos = hashtbl[htndx++];
405 while (htpos != NULL) {
406 ep = htpos->def;
407 htpos = htpos->next;
408 if (ep != NULL)
409 return(ep);
410 }
411 }
412 #ifdef OUTCHAN
413 if ((ep = ochpos) != NULL)
414 ochpos = ep->sibling;
415 return(ep);
416 #else
417 return(NULL);
418 #endif
419 }
420
421
422 EPNODE *
423 dpop(name) /* pop a definition */
424 char *name;
425 {
426 register VARDEF *vp;
427 register EPNODE *dp;
428
429 if ((vp = varlookup(name)) == NULL || vp->def == NULL)
430 return(NULL);
431 dp = vp->def;
432 vp->def = dp->sibling;
433 varfree(vp);
434 return(dp);
435 }
436
437
438 dpush(nm, ep) /* push on a definition */
439 char *nm;
440 register EPNODE *ep;
441 {
442 register VARDEF *vp;
443
444 vp = varinsert(nm);
445 ep->sibling = vp->def;
446 vp->def = ep;
447 }
448
449
450 #ifdef OUTCHAN
451 addchan(sp) /* add an output channel assignment */
452 EPNODE *sp;
453 {
454 int ch = sp->v.kid->v.chan;
455 register EPNODE *ep, *epl;
456
457 for (epl = NULL, ep = outchan; ep != NULL; epl = ep, ep = ep->sibling)
458 if (ep->v.kid->v.chan >= ch) {
459 if (epl != NULL)
460 epl->sibling = sp;
461 else
462 outchan = sp;
463 if (ep->v.kid->v.chan > ch)
464 sp->sibling = ep;
465 else {
466 sp->sibling = ep->sibling;
467 epfree(ep);
468 }
469 return;
470 }
471 if (epl != NULL)
472 epl->sibling = sp;
473 else
474 outchan = sp;
475 sp->sibling = NULL;
476
477 }
478 #endif
479
480
481 getstatement() /* get next statement */
482 {
483 register EPNODE *ep;
484 char *qname;
485 register VARDEF *vdef;
486
487 if (nextc == ';') { /* empty statement */
488 scan();
489 return;
490 }
491 #ifdef OUTCHAN
492 if (nextc == '$') { /* channel assignment */
493 ep = getchan();
494 addchan(ep);
495 } else
496 #endif
497 { /* ordinary definition */
498 ep = getdefn();
499 qname = qualname(dname(ep), 0);
500 #ifdef REDEFW
501 if ((vdef = varlookup(qname)) != NULL)
502 if (vdef->def != NULL) {
503 wputs(qname);
504 if (vdef->def->type == ':')
505 wputs(": redefined constant expression\n");
506 else
507 wputs(": redefined\n");
508 }
509 #ifdef FUNCTION
510 else if (ep->v.kid->type == FUNC && vdef->lib != NULL) {
511 wputs(qname);
512 wputs(": definition hides library function\n");
513 }
514 #endif
515 #endif
516 if (ep->type == ':')
517 dremove(qname);
518 else
519 dclear(qname);
520 dpush(qname, ep);
521 }
522 if (nextc != EOF) {
523 if (nextc != ';')
524 syntax("';' expected");
525 scan();
526 }
527 }
528
529
530 EPNODE *
531 getdefn() /* A -> SYM = E1 */
532 /* SYM : E1 */
533 /* FUNC(SYM,..) = E1 */
534 /* FUNC(SYM,..) : E1 */
535 {
536 register EPNODE *ep1, *ep2;
537
538 if (!isalpha(nextc) && nextc != CNTXMARK)
539 syntax("illegal variable name");
540
541 ep1 = newnode();
542 ep1->type = SYM;
543 ep1->v.name = savestr(getname());
544
545 #ifdef FUNCTION
546 if (nextc == '(') {
547 ep2 = newnode();
548 ep2->type = FUNC;
549 addekid(ep2, ep1);
550 ep1 = ep2;
551 do {
552 scan();
553 if (!isalpha(nextc))
554 syntax("illegal variable name");
555 ep2 = newnode();
556 ep2->type = SYM;
557 ep2->v.name = savestr(getname());
558 addekid(ep1, ep2);
559 } while (nextc == ',');
560 if (nextc != ')')
561 syntax("')' expected");
562 scan();
563 curfunc = ep1;
564 } else
565 curfunc = NULL;
566 #endif
567
568 if (nextc != '=' && nextc != ':')
569 syntax("'=' or ':' expected");
570
571 ep2 = newnode();
572 ep2->type = nextc;
573 scan();
574 addekid(ep2, ep1);
575 addekid(ep2, getE1());
576
577 if (
578 #ifdef FUNCTION
579 ep1->type == SYM &&
580 #endif
581 ep1->sibling->type != NUM) {
582 ep1 = newnode();
583 ep1->type = TICK;
584 ep1->v.tick = -1;
585 addekid(ep2, ep1);
586 ep1 = newnode();
587 ep1->type = NUM;
588 addekid(ep2, ep1);
589 }
590
591 return(ep2);
592 }
593
594
595 #ifdef OUTCHAN
596 EPNODE *
597 getchan() /* A -> $N = E1 */
598 {
599 register EPNODE *ep1, *ep2;
600
601 if (nextc != '$')
602 syntax("missing '$'");
603 scan();
604
605 ep1 = newnode();
606 ep1->type = CHAN;
607 ep1->v.chan = getinum();
608
609 if (nextc != '=')
610 syntax("'=' expected");
611 scan();
612
613 ep2 = newnode();
614 ep2->type = '=';
615 addekid(ep2, ep1);
616 addekid(ep2, getE1());
617
618 return(ep2);
619 }
620 #endif
621
622
623
624 /*
625 * The following routines are for internal use only:
626 */
627
628
629 static double
630 dvalue(name, d) /* evaluate a variable */
631 char *name;
632 EPNODE *d;
633 {
634 register EPNODE *ep1, *ep2;
635
636 if (d == NULL || d->v.kid->type != SYM) {
637 eputs(name);
638 eputs(": undefined variable\n");
639 quit(1);
640 }
641 ep1 = d->v.kid->sibling; /* get expression */
642 if (ep1->type == NUM)
643 return(ep1->v.num); /* return if number */
644 ep2 = ep1->sibling; /* check time */
645 if (ep2->v.tick < 0 || ep2->v.tick < eclock) {
646 ep2->v.tick = d->type == ':' ? 1L<<30 : eclock;
647 ep2 = ep2->sibling;
648 ep2->v.num = evalue(ep1); /* needs new value */
649 } else
650 ep2 = ep2->sibling; /* else reuse old value */
651
652 return(ep2->v.num);
653 }
654
655
656 static int
657 hash(s) /* hash a string */
658 register char *s;
659 {
660 register int rval = 0;
661
662 while (*s)
663 rval += *s++;
664
665 return(rval % NHASH);
666 }
