root/radiance/ray/src/common/caldefn.c
Revision: 2.2
Committed: Fri May 15 16:38:49 1992 UTC (32 years, 1 month ago) by greg
Changes since 2.1: +16 -1 lines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Store variable definitions.
9 *
10 * 7/1/85 Greg Ward
11 *
12 * 11/11/85 Added conditional compiles (OUTCHAN) for control output.
13 *
14 * 4/2/86 Added conditional compiles for function definitions (FUNCTION).
15 *
16 * 1/15/88 Added clock for caching of variable values.
17 *
18 * 11/16/88 Added VARDEF structure for hard linking.
19 *
20 * 5/31/90 Added conditional compile (REDEFW) for redefinition warning.
21 *
22 * 4/23/91 Added ':' assignment for constant expressions
23 *
24 * 8/7/91 Added optional context path to append to variable names
25 */
26
27 #include <stdio.h>
28
29 #include <ctype.h>
30
31 #include "calcomp.h"
32
33 #ifndef NHASH
34 #define NHASH 521 /* hash size (a prime!) */
35 #endif
36
37 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
38
39 extern char *ecalloc(), *savestr(), *strcpy();
40
41 static int hash();
42
43 static double dvalue();
44
45 long eclock = -1; /* value storage timer */
46
47 static char context[MAXWORD+1]; /* current context path */
48
49 static VARDEF *hashtbl[NHASH]; /* definition list */
50 static int htndx; /* index for */
51 static VARDEF *htpos; /* ...dfirst() and */
52 #ifdef OUTCHAN
53 static EPNODE *ochpos; /* ...dnext */
54 static EPNODE *outchan;
55 #endif
56
57 #ifdef FUNCTION
58 EPNODE *curfunc;
59 #define dname(ep) ((ep)->v.kid->type == SYM ? \
60 (ep)->v.kid->v.name : \
61 (ep)->v.kid->v.kid->v.name)
62 #else
63 #define dname(ep) ((ep)->v.kid->v.name)
64 #endif
65
66
67 fcompile(fname) /* get definitions from a file */
68 char *fname;
69 {
70 FILE *fp;
71
72 if (fname == NULL)
73 fp = stdin;
74 else if ((fp = fopen(fname, "r")) == NULL) {
75 eputs(fname);
76 eputs(": cannot open\n");
77 quit(1);
78 }
79 initfile(fp, fname, 0);
80 while (nextc != EOF)
81 getstatement();
82 if (fname != NULL)
83 fclose(fp);
84 }
85
86
87 scompile(str, fn, ln) /* get definitions from a string */
88 char *str;
89 char *fn;
90 int ln;
91 {
92 initstr(str, fn, ln);
93 while (nextc != EOF)
94 getstatement();
95 }
96
97
98 double
99 varvalue(vname) /* return a variable's value */
100 char *vname;
101 {
102 return(dvalue(vname, dlookup(vname)));
103 }
104
105
106 double
107 evariable(ep) /* evaluate a variable */
108 EPNODE *ep;
109 {
110 register VARDEF *dp = ep->v.ln;
111
112 return(dvalue(dp->name, dp->def));
113 }
114
115
116 varset(vname, assign, val) /* set a variable's value */
117 char *vname;
118 int assign;
119 double val;
120 {
121 char *qname;
122 register EPNODE *ep1, *ep2;
123 /* get qualified name */
124 qname = qualname(vname, 0);
125 /* check for quick set */
126 if ((ep1 = dlookup(qname)) != NULL && ep1->v.kid->type == SYM) {
127 ep2 = ep1->v.kid->sibling;
128 if (ep2->type == NUM) {
129 ep2->v.num = val;
130 ep1->type = assign;
131 return;
132 }
133 }
134 /* hand build definition */
135 ep1 = newnode();
136 ep1->type = assign;
137 ep2 = newnode();
138 ep2->type = SYM;
139 ep2->v.name = savestr(vname);
140 addekid(ep1, ep2);
141 ep2 = newnode();
142 ep2->type = NUM;
143 ep2->v.num = val;
144 addekid(ep1, ep2);
145 dremove(qname);
146 dpush(qname, ep1);
147 }
148
149
150 dclear(name) /* delete variable definitions of name */
151 char *name;
152 {
153 register EPNODE *ep;
154
155 while ((ep = dpop(name)) != NULL) {
156 if (ep->type == ':') {
157 dpush(name, ep); /* don't clear constants */
158 return;
159 }
160 epfree(ep);
161 }
162 }
163
164
165 dremove(name) /* delete all definitions of name */
166 char *name;
167 {
168 register EPNODE *ep;
169
170 while ((ep = dpop(name)) != NULL)
171 epfree(ep);
172 }
173
174
175 vardefined(name) /* return non-zero if variable defined */
176 char *name;
177 {
178 register EPNODE *dp;
179
180 return((dp = dlookup(name)) != NULL && dp->v.kid->type == SYM);
181 }
182
183
184 char *
185 setcontext(ctx) /* set a new context path */
186 register char *ctx;
187 {
188 register char *cpp;
189
190 if (ctx == NULL)
191 return(context); /* just asking */
192 if (!*ctx) {
193 context[0] = '\0'; /* clear context */
194 return(context);
195 }
196 cpp = context; /* else copy it (carefully!) */
197 if (*ctx != CNTXMARK)
198 *cpp++ = CNTXMARK; /* make sure there's a mark */
199 do {
200 if (cpp >= context+MAXWORD)
201 break; /* just copy what we can */
202 if (isid(*ctx))
203 *cpp++ = *ctx++;
204 else {
205 *cpp++ = '_'; ctx++;
206 }
207 } while (*ctx);
208 *cpp = '\0';
209 return(context);
210 }
211
212
213 char *
214 qualname(nam, lvl) /* get qualified name */
215 register char *nam;
216 int lvl;
217 {
218 static char nambuf[MAXWORD+1];
219 register char *cp = nambuf, *cpp;
220 /* check for explicit local */
221 if (*nam == CNTXMARK)
222 if (lvl > 0) /* only action is to refuse search */
223 return(NULL);
224 else
225 nam++;
226 else if (nam == nambuf) /* check for repeat call */
227 return(lvl > 0 ? NULL : nam);
228 /* copy name to static buffer */
229 while (*nam) {
230 if (cp >= nambuf+MAXWORD)
231 goto toolong;
232 *cp++ = *nam++;
233 }
234 /* check for explicit global */
235 if (cp > nambuf && cp[-1] == CNTXMARK) {
236 if (lvl > 0)
237 return(NULL);
238 *--cp = '\0';
239 return(nambuf); /* already qualified */
240 }
241 cpp = context; /* else skip the requested levels */
242 while (lvl-- > 0) {
243 if (!*cpp)
244 return(NULL); /* return NULL if past global level */
245 while (*++cpp && *cpp != CNTXMARK)
246 ;
247 }
248 while (*cpp) { /* copy context to static buffer */
249 if (cp >= nambuf+MAXWORD)
250 goto toolong;
251 *cp++ = *cpp++;
252 }
253 toolong:
254 *cp = '\0';
255 return(nambuf); /* return qualified name */
256 }
257
258
259 incontext(qn) /* is qualified name in current context? */
260 register char *qn;
261 {
262 while (*qn && *qn != CNTXMARK) /* find context mark */
263 qn++;
264 return(!strcmp(qn, context));
265 }
266
267
268 #ifdef OUTCHAN
269 chanout(cs) /* set output channels */
270 int (*cs)();
271 {
272 register EPNODE *ep;
273
274 for (ep = outchan; ep != NULL; ep = ep->sibling)
275 (*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling));
276
277 }
278 #endif
279
280
281 dcleanup(lvl) /* clear definitions (0->vars,1->output,2->consts) */
282 int lvl;
283 {
284 register int i;
285 register VARDEF *vp;
286 register EPNODE *ep;
287 /* if context is global, clear all */
288 for (i = 0; i < NHASH; i++)
289 for (vp = hashtbl[i]; vp != NULL; vp = vp->next)
290 if (!context[0] || incontext(vp->name))
291 if (lvl >= 2)
292 dremove(vp->name);
293 else
294 dclear(vp->name);
295 #ifdef OUTCHAN
296 if (lvl >= 1) {
297 for (ep = outchan; ep != NULL; ep = ep->sibling)
298 epfree(ep);
299 outchan = NULL;
300 }
301 #endif
302 }
303
304
305 EPNODE *
306 dlookup(name) /* look up a definition */
307 char *name;
308 {
309 register VARDEF *vp;
310
311 if ((vp = varlookup(name)) == NULL)
312 return(NULL);
313 return(vp->def);
314 }
315
316
317 VARDEF *
318 varlookup(name) /* look up a variable */
319 char *name;
320 {
321 int lvl = 0;
322 register char *qname;
323 register VARDEF *vp;
324 /* find most qualified match */
325 while ((qname = qualname(name, lvl++)) != NULL)
326 for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next)
327 if (!strcmp(vp->name, qname))
328 return(vp);
329 return(NULL);
330 }
331
332
333 VARDEF *
334 varinsert(name) /* get a link to a variable */
335 char *name;
336 {
337 register VARDEF *vp;
338 register LIBR *libp;
339 int hv;
340
341 if ((vp = varlookup(name)) != NULL) {
342 vp->nlinks++;
343 return(vp);
344 }
345 #ifdef FUNCTION
346 libp = liblookup(name);
347 #else
348 libp = NULL;
349 #endif
350 if (libp == NULL) /* if name not in library */
351 name = qualname(name, 0); /* use fully qualified version */
352 hv = hash(name);
353 vp = (VARDEF *)emalloc(sizeof(VARDEF));
354 vp->name = savestr(name);
355 vp->nlinks = 1;
356 vp->def = NULL;
357 vp->lib = libp;
358 vp->next = hashtbl[hv];
359 hashtbl[hv] = vp;
360 return(vp);
361 }
362
363
364 #ifdef FUNCTION
365 libupdate(fn) /* update library links */
366 char *fn;
367 {
368 register int i;
369 register VARDEF *vp;
370 /* if fn is NULL then relink all */
371 for (i = 0; i < NHASH; i++)
372 for (vp = hashtbl[i]; vp != NULL; vp = vp->next)
373 if (vp->lib != NULL || fn == NULL || !strcmp(fn, vp->name))
374 vp->lib = liblookup(vp->name);
375 }
376 #endif
377
378
379 varfree(ln) /* release link to variable */
380 register VARDEF *ln;
381 {
382 register VARDEF *vp;
383 int hv;
384
385 if (--ln->nlinks > 0)
386 return; /* still active */
387
388 hv = hash(ln->name);
389 vp = hashtbl[hv];
390 if (vp == ln)
391 hashtbl[hv] = vp->next;
392 else {
393 while (vp->next != ln) /* must be in list */
394 vp = vp->next;
395 vp->next = ln->next;
396 }
397 freestr(ln->name);
398 efree((char *)ln);
399 }
400
401
402 EPNODE *
403 dfirst() /* return pointer to first definition */
404 {
405 htndx = 0;
406 htpos = NULL;
407 #ifdef OUTCHAN
408 ochpos = outchan;
409 #endif
410 return(dnext());
411 }
412
413
414 EPNODE *
415 dnext() /* return pointer to next definition */
416 {
417 register EPNODE *ep;
418 register char *nm;
419
420 while (htndx < NHASH) {
421 if (htpos == NULL)
422 htpos = hashtbl[htndx++];
423 while (htpos != NULL) {
424 ep = htpos->def;
425 nm = htpos->name;
426 htpos = htpos->next;
427 if (ep != NULL && incontext(nm))
428 return(ep);
429 }
430 }
431 #ifdef OUTCHAN
432 if ((ep = ochpos) != NULL)
433 ochpos = ep->sibling;
434 return(ep);
435 #else
436 return(NULL);
437 #endif
438 }
439
440
441 EPNODE *
442 dpop(name) /* pop a definition */
443 char *name;
444 {
445 register VARDEF *vp;
446 register EPNODE *dp;
447
448 if ((vp = varlookup(name)) == NULL || vp->def == NULL)
449 return(NULL);
450 dp = vp->def;
451 vp->def = dp->sibling;
452 varfree(vp);
453 return(dp);
454 }
455
456
457 dpush(nm, ep) /* push on a definition */
458 char *nm;
459 register EPNODE *ep;
460 {
461 register VARDEF *vp;
462
463 vp = varinsert(nm);
464 ep->sibling = vp->def;
465 vp->def = ep;
466 }
467
468
469 #ifdef OUTCHAN
470 addchan(sp) /* add an output channel assignment */
471 EPNODE *sp;
472 {
473 int ch = sp->v.kid->v.chan;
474 register EPNODE *ep, *epl;
475
476 for (epl = NULL, ep = outchan; ep != NULL; epl = ep, ep = ep->sibling)
477 if (ep->v.kid->v.chan >= ch) {
478 if (epl != NULL)
479 epl->sibling = sp;
480 else
481 outchan = sp;
482 if (ep->v.kid->v.chan > ch)
483 sp->sibling = ep;
484 else {
485 sp->sibling = ep->sibling;
486 epfree(ep);
487 }
488 return;
489 }
490 if (epl != NULL)
491 epl->sibling = sp;
492 else
493 outchan = sp;
494 sp->sibling = NULL;
495
496 }
497 #endif
498
499
500 getstatement() /* get next statement */
501 {
502 register EPNODE *ep;
503 char *qname;
504 register VARDEF *vdef;
505
506 if (nextc == ';') { /* empty statement */
507 scan();
508 return;
509 }
510 #ifdef OUTCHAN
511 if (nextc == '$') { /* channel assignment */
512 ep = getchan();
513 addchan(ep);
514 } else
515 #endif
516 { /* ordinary definition */
517 ep = getdefn();
518 qname = qualname(dname(ep), 0);
519 #ifdef REDEFW
520 if ((vdef = varlookup(qname)) != NULL)
521 if (vdef->def != NULL) {
522 wputs(qname);
523 if (vdef->def->type == ':')
524 wputs(": redefined constant expression\n");
525 else
526 wputs(": redefined\n");
527 }
528 #ifdef FUNCTION
529 else if (ep->v.kid->type == FUNC && vdef->lib != NULL) {
530 wputs(qname);
531 wputs(": definition hides library function\n");
532 }
533 #endif
534 #endif
535 if (ep->type == ':')
536 dremove(qname);
537 else
538 dclear(qname);
539 dpush(qname, ep);
540 }
541 if (nextc != EOF) {
542 if (nextc != ';')
543 syntax("';' expected");
544 scan();
545 }
546 }
547
548
549 EPNODE *
550 getdefn() /* A -> SYM = E1 */
551 /* SYM : E1 */
552 /* FUNC(SYM,..) = E1 */
553 /* FUNC(SYM,..) : E1 */
554 {
555 register EPNODE *ep1, *ep2;
556
557 if (!isalpha(nextc) && nextc != CNTXMARK)
558 syntax("illegal variable name");
559
560 ep1 = newnode();
561 ep1->type = SYM;
562 ep1->v.name = savestr(getname());
563
564 #ifdef FUNCTION
565 if (nextc == '(') {
566 ep2 = newnode();
567 ep2->type = FUNC;
568 addekid(ep2, ep1);
569 ep1 = ep2;
570 do {
571 scan();
572 if (!isalpha(nextc))
573 syntax("illegal variable name");
574 ep2 = newnode();
575 ep2->type = SYM;
576 ep2->v.name = savestr(getname());
577 addekid(ep1, ep2);
578 } while (nextc == ',');
579 if (nextc != ')')
580 syntax("')' expected");
581 scan();
582 curfunc = ep1;
583 } else
584 curfunc = NULL;
585 #endif
586
587 if (nextc != '=' && nextc != ':')
588 syntax("'=' or ':' expected");
589
590 ep2 = newnode();
591 ep2->type = nextc;
592 scan();
593 addekid(ep2, ep1);
594 addekid(ep2, getE1());
595
596 if (
597 #ifdef FUNCTION
598 ep1->type == SYM &&
599 #endif
600 ep1->sibling->type != NUM) {
601 ep1 = newnode();
602 ep1->type = TICK;
603 ep1->v.tick = -1;
604 addekid(ep2, ep1);
605 ep1 = newnode();
606 ep1->type = NUM;
607 addekid(ep2, ep1);
608 }
609
610 return(ep2);
611 }
612
613
614 #ifdef OUTCHAN
615 EPNODE *
616 getchan() /* A -> $N = E1 */
617 {
618 register EPNODE *ep1, *ep2;
619
620 if (nextc != '$')
621 syntax("missing '$'");
622 scan();
623
624 ep1 = newnode();
625 ep1->type = CHAN;
626 ep1->v.chan = getinum();
627
628 if (nextc != '=')
629 syntax("'=' expected");
630 scan();
631
632 ep2 = newnode();
633 ep2->type = '=';
634 addekid(ep2, ep1);
635 addekid(ep2, getE1());
636
637 return(ep2);
638 }
639 #endif
640
641
642
643 /*
644 * The following routines are for internal use only:
645 */
646
647
648 static double
649 dvalue(name, d) /* evaluate a variable */
650 char *name;
651 EPNODE *d;
652 {
653 register EPNODE *ep1, *ep2;
654
655 if (d == NULL || d->v.kid->type != SYM) {
656 eputs(name);
657 eputs(": undefined variable\n");
658 quit(1);
659 }
660 ep1 = d->v.kid->sibling; /* get expression */
661 if (ep1->type == NUM)
662 return(ep1->v.num); /* return if number */
663 ep2 = ep1->sibling; /* check time */
664 if (ep2->v.tick < 0 || ep2->v.tick < eclock) {
665 ep2->v.tick = d->type == ':' ? 1L<<30 : eclock;
666 ep2 = ep2->sibling;
667 ep2->v.num = evalue(ep1); /* needs new value */
668 } else
669 ep2 = ep2->sibling; /* else reuse old value */
670
671 return(ep2->v.num);
672 }
673
674
675 static int
676 hash(s) /* hash a string */
677 register char *s;
678 {
679 register int rval = 0;
680
681 while (*s)
682 rval += *s++;
683
684 return(rval % NHASH);
685 }
