root/radiance/ray/src/common/caldefn.c
Wed Jan 1 19:02:08 2025 UTC (3 months, 4 weeks ago) by greg
Changes since 2.40: +4 -4 lines
Diff to previous 2.40
fix: Increased buffer size for qualified variable names to something sensible
Mon Sep 16 17:31:14 2024 UTC (7 months, 2 weeks ago) by greg
Changes since 2.39: +31 -31 lines
Diff to previous 2.39
refactor: Changed too-generic symbol names in calcomp.h
Thu Jun 20 21:21:24 2024 UTC (10 months, 1 week ago) by greg
Changes since 2.38: +5 -3 lines
Diff to previous 2.38
fix: Moved epoptimize() call to where it needs to go for REDEFW to work
Fri Feb 23 03:47:57 2024 UTC (14 months, 1 week ago) by greg
Changes since 2.37: +25 -6 lines
Diff to previous 2.37
Sun Oct 1 18:02:23 2023 UTC (19 months ago) by greg
Changes since 2.36: +9 -9 lines
Diff to previous 2.36
perf: Slight reduction in time for variable clearing
Tue Sep 26 18:33:14 2023 UTC (19 months ago) by greg
Changes since 2.35: +5 -9 lines
Diff to previous 2.35
style: minor code clean-ups
Tue Sep 26 00:14:02 2023 UTC (19 months ago) by greg
Changes since 2.34: +8 -6 lines
Diff to previous 2.34
style: corrected efree() typing and channel free loop
Tue Feb 7 20:28:16 2023 UTC (2 years, 2 months ago) by greg
Changes since 2.33: +9 -2 lines
Diff to previous 2.33
perf: added calls to flockfile()/funlockfile() for more efficient reading
Fri Apr 8 23:32:25 2022 UTC (3 years ago) by greg
Changes since 2.32: +4 -4 lines
Diff to previous 2.32
perf: Removing some conditionals with binary operations
Wed Mar 30 16:00:56 2022 UTC (3 years, 1 month ago) by greg
Diff to previous 2.31
fix: Renamed setcontext() to calcontext() to avoid obscure macOS naming conflict
Sat Mar 12 17:21:10 2022 UTC (3 years, 1 month ago) by greg
Changes since 2.30: +4 -3 lines
Diff to previous 2.30
style: Minor code cleanup
Sat Mar 12 15:50:13 2022 UTC (3 years, 1 month ago) by greg
Changes since 2.29: +5 -3 lines
Diff to previous 2.29
feat(rcalc): Added check for "cond" variable defined as constant
Mon Aug 31 15:06:20 2020 UTC (4 years, 8 months ago) by greg
Diff to previous 2.28
fix: added check for context mark in parameter names
Thu Apr 2 18:00:34 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.27: +6 -2 lines
Diff to previous 2.27
Added warning about assigning non-constant to constant variable
Sat Dec 28 18:05:13 2019 UTC (5 years, 4 months ago) by greg
Changes since 2.26: +1 -3 lines
Diff to previous 2.26
Thu Jul 24 15:41:13 2014 UTC (10 years, 9 months ago) by greg
Changes since 2.25: +8 -1 lines
Diff to previous 2.25
Added warning to varset() for resetting non-numeric definitions
Sun Jul 29 22:10:45 2012 UTC (12 years, 9 months ago) by greg
Changes since 2.24: +43 -39 lines
Diff to previous 2.24
Made varset() behavior identical to loading definition
Fri Mar 5 17:28:46 2010 UTC (15 years, 2 months ago) by greg
CVS Tags: rad4R0, rad4R1
Diff to previous 2.23
Improved syntax error reporting for bad function parameter name
Thu May 1 16:42:05 2008 UTC (17 years ago) by greg
Diff to previous 2.22
Sun Mar 28 20:33:12 2004 UTC (21 years, 1 month ago) by schorsch
Diff to previous 2.21
Mon Oct 27 10:19:31 2003 UTC (21 years, 6 months ago) by schorsch
Diff to previous 2.20
Sun Jul 27 22:12:01 2003 UTC (21 years, 9 months ago) by schorsch
Diff to previous 2.19
Mon Jul 21 22:30:17 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 2.18: +5 -3 lines
Diff to previous 2.18
Thu Jul 17 09:21:29 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 2.17: +5 -9 lines
Diff to previous 2.17
Thu Jul 3 22:41:44 2003 UTC (21 years, 10 months ago) by schorsch
Diff to previous 2.16
Sat Jun 7 12:50:20 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.15: +87 -63 lines
Diff to previous 2.15
Sun Apr 27 06:08:03 2003 UTC (22 years ago) by greg
Diff to previous 2.14
Mon Mar 10 17:13:29 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.13: +1 -2 lines
Diff to previous 2.13
Tue Feb 25 02:47:21 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.12: +1 -56 lines
Diff to previous 2.12
Sat Feb 22 02:07:21 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.11: +92 -57 lines
Wed Feb 12 17:38:03 1997 UTC (28 years, 2 months ago) by greg
Changes since 2.10: +9 -7 lines
fixed it so remembered contexts can be 1023 bytes long
Wed Jan 8 17:10:24 1997 UTC (28 years, 3 months ago) by greg
Changes since 2.9: +6 -3 lines
fixed bug when channel is defined following function
Tue Mar 28 11:18:52 1995 UTC (30 years, 1 month ago) by greg
fixed problem where global context doesn't print everything
Fri Feb 17 18:34:42 1995 UTC (30 years, 2 months ago) by greg
fixed potential bug in eclock tracking
Thu Feb 16 09:49:27 1995 UTC (30 years, 2 months ago) by greg
made redefinition warnings more intelligent --
won't report new definitions that are equivalent to old
Thu Apr 8 16:41:21 1993 UTC (32 years, 1 month ago) by greg
Changes since 2.5: +45 -5 lines
added pushcontext() and popcontext() functions
Sat Nov 21 21:42:42 1992 UTC (32 years, 5 months ago) by greg
Changes since 2.4: +2 -15 lines
changed to better hash function shash()
Mon Sep 21 12:01:44 1992 UTC (32 years, 7 months ago) by greg
Changes since 2.3: +53 -53 lines
Changes for PC port
Mon Aug 10 16:20:43 1992 UTC (32 years, 8 months ago) by greg
Changes since 2.2: +4 -6 lines
minor changes to varinsert()
Fri May 15 16:38:49 1992 UTC (32 years, 11 months ago) by greg
Changes since 2.1: +16 -1 lines
Tue Nov 12 16:55:27 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 1.20
Mon Oct 28 09:47:19 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.19: +2 -0 lines
Diff to previous 1.19
Wed Aug 14 15:50:38 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.18: +4 -2 lines
Diff to previous 1.18
added context testing to dnext()
Wed Aug 14 08:27:56 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.17: +8 -16 lines
Diff to previous 1.17
fixed code relating to long identifiers
Fri Aug 9 08:27:56 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.16: +22 -21 lines
Diff to previous 1.16
changed location of context mark for locals/globals
Thu Aug 8 14:38:00 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.15: +22 -14 lines
Diff to previous 1.15
fixed bug related to contexts and library functions
Thu Aug 8 12:28:30 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.14
added explicit global id's starting with context mark
Thu Aug 8 12:12:16 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.13: +18 -8 lines
Diff to previous 1.13
fixed up dcleanup() routine for working with contexts
Thu Aug 8 11:22:06 1991 UTC (33 years, 9 months ago) by greg
Changes since 1.12: +118 -27 lines
Diff to previous 1.12
added contexts to definition naming
Wed Jul 17 11:12:02 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.11
changed dcleanup levels
Tue Jul 16 10:37:45 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.10
changed wording on library function redefinition warning
Mon Apr 29 08:33:13 1991 UTC (34 years ago) by greg
Changes since 1.9: +14 -21 lines
Diff to previous 1.9
minor changes to ':' assignment code
Wed Apr 24 08:17:22 1991 UTC (34 years ago) by greg
Changes since 1.8: +12 -6 lines
Diff to previous 1.8
changed definition of dclearall() to dclean()
Tue Apr 23 12:59:33 1991 UTC (34 years ago) by greg
Changes since 1.7: +52 -12 lines
Diff to previous 1.7
added ':' definitions for constant expressions
Fri Jul 20 08:30:23 1990 UTC (34 years, 9 months ago) by greg
Diff to previous 1.6
forgot addition for elimination of TICK for numeric def'ns
Thu Jul 19 13:09:22 1990 UTC (34 years, 9 months ago) by greg
Diff to previous 1.5
passed function to chanout()
Thu Jul 19 11:15:31 1990 UTC (34 years, 9 months ago) by greg
Changes since 1.4: +4 -10 lines
Diff to previous 1.4
eliminated cache for numeric definitions
Thu Jul 19 11:06:37 1990 UTC (34 years, 9 months ago) by greg
Changes since 1.3: +5 -4 lines
Diff to previous 1.3
added line numbers to error reports
Tue Jun 26 09:15:08 1990 UTC (34 years, 10 months ago) by greg
Thu May 31 10:24:28 1990 UTC (34 years, 11 months ago) by greg
Changes since 1.1: +10 -0 lines
added conditional compiles for redefinition warning (REDEFW)
Thu Feb 2 10:34:26 1989 UTC (36 years, 3 months ago) by greg
