--- ray/src/common/caldefn.c 1991/04/29 08:33:13 1.10 +++ ray/src/common/caldefn.c 2023/09/26 00:14:02 2.35 @@ -1,9 +1,6 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: caldefn.c,v 2.35 2023/09/26 00:14:02 greg Exp $"; #endif - /* * Store variable definitions. * @@ -20,46 +17,57 @@ static char SCCSid[] = "$SunId$ LBL"; * 5/31/90 Added conditional compile (REDEFW) for redefinition warning. * * 4/23/91 Added ':' assignment for constant expressions + * + * 8/7/91 Added optional context path to append to variable names + * + * 5/17/2001 Fixed clock counter wrapping behavior + * + * 2/19/03 Eliminated conditional compiles in favor of esupport extern. */ -#include +#include "copyright.h" #include +#include "rterror.h" +#include "rtio.h" +#include "rtmisc.h" #include "calcomp.h" -#ifndef NHASH -#define NHASH 521 /* hash size (a prime!) */ +#ifndef NHASH +#define NHASH 521 /* hash size (a prime!) */ #endif -#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) +#define hash(s) (shash(s)%NHASH) -extern char *ecalloc(), *savestr(); +#define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE)) -static double dvalue(); +static double dvalue(char *name, EPNODE *d); -long eclock = -1; /* value storage timer */ +#define MAXCLOCK (1L<<31) /* clock wrap value */ +unsigned long eclock = 0; /* value storage timer */ + +#define MAXCNTX 1023 /* maximum context length */ + +static char context[MAXCNTX+1]; /* current context path */ + static VARDEF *hashtbl[NHASH]; /* definition list */ static int htndx; /* index for */ static VARDEF *htpos; /* ...dfirst() and */ -#ifdef OUTCHAN static EPNODE *ochpos; /* ...dnext */ static EPNODE *outchan; -#endif -#ifdef FUNCTION -EPNODE *curfunc; -#define dname(ep) ((ep)->v.kid->type == SYM ? \ +EPNODE *curfunc = NULL; +#define dname(ep) ((ep)->v.kid->type == SYM ? \ (ep)->v.kid->v.name : \ (ep)->v.kid->v.kid->v.name) -#else -#define dname(ep) ((ep)->v.kid->v.name) -#endif -fcompile(fname) /* get definitions from a file */ -char *fname; +void +fcompile( /* get definitions from a file */ + char *fname +) { FILE *fp; @@ -70,51 +78,68 @@ char *fname; eputs(": cannot open\n"); quit(1); } - initfile(fp, fname, 0); +#ifdef getc_unlocked /* avoid stupid semaphores */ + flockfile(fp); +#endif + initfile(fp, fname, 0); while (nextc != EOF) - loaddefn(); + getstatement(); if (fname != NULL) fclose(fp); +#ifdef getc_unlocked + else + funlockfile(fp); +#endif } -scompile(str, fn, ln) /* get definitions from a string */ -char *str; -char *fn; -int ln; +void +scompile( /* get definitions from a string */ + char *str, + char *fn, + int ln +) { initstr(str, fn, ln); while (nextc != EOF) - loaddefn(); + getstatement(); } double -varvalue(vname) /* return a variable's value */ -char *vname; +varvalue( /* return a variable's value */ + char *vname +) { return(dvalue(vname, dlookup(vname))); } double -evariable(ep) /* evaluate a variable */ -EPNODE *ep; +evariable( /* evaluate a variable */ + EPNODE *ep +) { - register VARDEF *dp = ep->v.ln; + VARDEF *dp = ep->v.ln; return(dvalue(dp->name, dp->def)); } -varset(vname, assign, val) /* set a variable's value */ -char *vname; -int assign; -double val; +void +varset( /* set a variable's value */ + char *vname, + int assign, + double val +) { - register EPNODE *ep1, *ep2; + char *qname; + EPNODE *ep1, *ep2; + /* get qualified name */ + qname = qualname(vname, 0); /* check for quick set */ - if ((ep1 = dlookup(vname)) != NULL && ep1->v.kid->type == SYM) { + if ((ep1 = dlookup(qname)) != NULL && ep1->v.kid->type == SYM && + (ep1->type == ':') <= (assign == ':')) { ep2 = ep1->v.kid->sibling; if (ep2->type == NUM) { ep2->v.num = val; @@ -122,6 +147,13 @@ double val; return; } } + if (ep1 != NULL && esupport&E_REDEFW) { + wputs(qname); + if (ep1->type == ':') + wputs(": reset constant expression\n"); + else + wputs(": reset expression\n"); + } /* hand build definition */ ep1 = newnode(); ep1->type = assign; @@ -133,19 +165,24 @@ double val; ep2->type = NUM; ep2->v.num = val; addekid(ep1, ep2); - dremove(vname); - dpush(ep1); + if (assign == ':') + dremove(qname); + else + dclear(qname); + dpush(qname, ep1); } -dclear(name) /* delete variable definitions of name */ -char *name; +void +dclear( /* delete variable definitions of name */ + char *name +) { - register EPNODE *ep; + EPNODE *ep; while ((ep = dpop(name)) != NULL) { if (ep->type == ':') { - dpush(ep); /* don't clear constants */ + dpush(name, ep); /* don't clear constants */ return; } epfree(ep); @@ -153,179 +190,341 @@ char *name; } -dremove(name) /* delete all definitions of name */ -char *name; +void +dremove( /* delete all definitions of name */ + char *name +) { - register EPNODE *ep; + EPNODE *ep; while ((ep = dpop(name)) != NULL) epfree(ep); } -vardefined(name) /* return non-zero if variable defined */ -char *name; +int +vardefined( /* return '=' or ':' if variable/constant defined */ + char *name +) { - register EPNODE *dp; + EPNODE *dp = dlookup(name); - return((dp = dlookup(name)) != NULL && dp->v.kid->type == SYM); + if (dp == NULL || dp->v.kid->type != SYM) + return(0); + + return(dp->type); } -#ifdef OUTCHAN -chanout(cs) /* set output channels */ -int (*cs)(); +char * +calcontext( /* set a new context path */ + char *ctx +) { - register EPNODE *ep; + char *cpp; + if (ctx == NULL) + return(context); /* just asking */ + while (*ctx == CNTXMARK) + ctx++; /* skip past marks */ + if (!*ctx) { + context[0] = '\0'; /* empty means clear context */ + return(context); + } + cpp = context; /* start context with mark */ + *cpp++ = CNTXMARK; + do { /* carefully copy new context */ + if (cpp >= context+MAXCNTX) + break; /* just copy what we can */ + if (isid(*ctx)) + *cpp++ = *ctx++; + else { + *cpp++ = '_'; ctx++; + } + } while (*ctx); + while (cpp[-1] == CNTXMARK) /* cannot end in context mark */ + cpp--; + *cpp = '\0'; + return(context); +} + + +char * +pushcontext( /* push on another context */ + char *ctx +) +{ + char oldcontext[MAXCNTX+1]; + int n; + + strcpy(oldcontext, context); /* save old context */ + calcontext(ctx); /* set new context */ + n = strlen(context); /* tack on old */ + if (n+strlen(oldcontext) > MAXCNTX) { + strncpy(context+n, oldcontext, MAXCNTX-n); + context[MAXCNTX] = '\0'; + } else + strcpy(context+n, oldcontext); + return(context); +} + + +char * +popcontext(void) /* pop off top context */ +{ + char *cp1, *cp2; + + if (!context[0]) /* nothing left to pop */ + return(context); + cp2 = context; /* find mark */ + while (*++cp2 && *cp2 != CNTXMARK) + ; + cp1 = context; /* copy tail to front */ + while ( (*cp1++ = *cp2++) ) + ; + return(context); +} + + +char * +qualname( /* get qualified name */ + char *nam, + int lvl +) +{ + static char nambuf[RMAXWORD+1]; + char *cp = nambuf, *cpp; + /* check for explicit local */ + if (*nam == CNTXMARK) + if (lvl > 0) /* only action is to refuse search */ + return(NULL); + else + nam++; + else if (nam == nambuf) /* check for repeat call */ + return(lvl > 0 ? NULL : nam); + /* copy name to static buffer */ + while (*nam) { + if (cp >= nambuf+RMAXWORD) + goto toolong; + *cp++ = *nam++; + } + /* check for explicit global */ + if (cp > nambuf && cp[-1] == CNTXMARK) { + if (lvl > 0) + return(NULL); + *--cp = '\0'; + return(nambuf); /* already qualified */ + } + cpp = context; /* else skip the requested levels */ + while (lvl-- > 0) { + if (!*cpp) + return(NULL); /* return NULL if past global level */ + while (*++cpp && *cpp != CNTXMARK) + ; + } + while (*cpp) { /* copy context to static buffer */ + if (cp >= nambuf+RMAXWORD) + goto toolong; + *cp++ = *cpp++; + } +toolong: + *cp = '\0'; + return(nambuf); /* return qualified name */ +} + + +int +incontext( /* is qualified name in current context? */ + char *qn +) +{ + if (!context[0]) /* global context accepts all */ + return(1); + while (*qn && *qn != CNTXMARK) /* find context mark */ + qn++; + return(!strcmp(qn, context)); +} + + +void +chanout( /* set output channels */ + void (*cs)(int n, double v) +) +{ + EPNODE *ep; + for (ep = outchan; ep != NULL; ep = ep->sibling) (*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling)); } -#endif -dcleanup(lvl) /* clear definitions (0->vars,1->consts,2->output) */ -int lvl; +void +dcleanup( /* clear definitions (0->vars,1->output,2->consts) */ + int lvl +) { - register int i; - register VARDEF *vp; - register EPNODE *ep; - + int i; + VARDEF *vp; + EPNODE *ep; + /* if context is global, clear all */ for (i = 0; i < NHASH; i++) for (vp = hashtbl[i]; vp != NULL; vp = vp->next) - if (lvl >= 1) - dremove(vp->name); - else - dclear(vp->name); -#ifdef OUTCHAN - if (lvl >= 2) { - for (ep = outchan; ep != NULL; ep = ep->sibling) + if (incontext(vp->name)) { + if (lvl >= 2) + dremove(vp->name); + else + dclear(vp->name); + } + if (lvl >= 1) + while (outchan != NULL) { + ep = outchan; + outchan = ep->sibling; + ep->sibling = NULL; epfree(ep); - outchan = NULL; - } -#endif + } } EPNODE * -dlookup(name) /* look up a definition */ -char *name; +dlookup( /* look up a definition */ + char *name +) { - register VARDEF *vp; + VARDEF *vp; if ((vp = varlookup(name)) == NULL) - return(NULL); + return(NULL); return(vp->def); } VARDEF * -varlookup(name) /* look up a variable */ -char *name; +varlookup( /* look up a variable */ + char *name +) { - register VARDEF *vp; - - for (vp = hashtbl[hash(name)]; vp != NULL; vp = vp->next) - if (!strcmp(vp->name, name)) - return(vp); + int lvl = 0; + char *qname; + VARDEF *vp; + /* find most qualified match */ + while ((qname = qualname(name, lvl++)) != NULL) + for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next) + if (!strcmp(vp->name, qname)) + return(vp); return(NULL); } VARDEF * -varinsert(name) /* get a link to a variable */ -char *name; +varinsert( /* get a link to a variable */ + char *name +) { - register VARDEF *vp; - int hv; + VARDEF *vp; + int hv; - hv = hash(name); - for (vp = hashtbl[hv]; vp != NULL; vp = vp->next) - if (!strcmp(vp->name, name)) { - vp->nlinks++; - return(vp); - } + if ((vp = varlookup(name)) != NULL) { + vp->nlinks++; + return(vp); + } vp = (VARDEF *)emalloc(sizeof(VARDEF)); + vp->lib = liblookup(name); + if (vp->lib == NULL) /* if name not in library */ + name = qualname(name, 0); /* use fully qualified version */ + hv = hash(name); vp->name = savestr(name); vp->nlinks = 1; vp->def = NULL; - vp->lib = NULL; vp->next = hashtbl[hv]; hashtbl[hv] = vp; return(vp); } -varfree(ln) /* release link to variable */ -register VARDEF *ln; +void +libupdate( /* update library links */ + char *fn +) { - register VARDEF *vp; - int hv; + int i; + VARDEF *vp; + /* if fn is NULL then relink all */ + for (i = 0; i < NHASH; i++) + for (vp = hashtbl[i]; vp != NULL; vp = vp->next) + if ((vp->lib != NULL) | (fn == NULL) || !strcmp(fn, vp->name)) + vp->lib = liblookup(vp->name); +} + +void +varfree( /* release link to variable */ + VARDEF *ln +) +{ + VARDEF *vp; + int hv; + if (--ln->nlinks > 0) - return; /* still active */ + return; /* still active */ hv = hash(ln->name); vp = hashtbl[hv]; if (vp == ln) - hashtbl[hv] = vp->next; + hashtbl[hv] = vp->next; else { - while (vp->next != ln) /* must be in list */ - vp = vp->next; - vp->next = ln->next; + while (vp->next != ln) /* must be in list */ + vp = vp->next; + vp->next = ln->next; } freestr(ln->name); - efree((char *)ln); + efree(ln); } EPNODE * -dfirst() /* return pointer to first definition */ +dfirst(void) /* return pointer to first definition */ { htndx = 0; htpos = NULL; -#ifdef OUTCHAN ochpos = outchan; -#endif return(dnext()); } EPNODE * -dnext() /* return pointer to next definition */ +dnext(void) /* return pointer to next definition */ { - register EPNODE *ep; + EPNODE *ep; + char *nm; while (htndx < NHASH) { - if (htpos == NULL) - htpos = hashtbl[htndx++]; - while (htpos != NULL) { - ep = htpos->def; - htpos = htpos->next; - if (ep != NULL) - return(ep); - } + if (htpos == NULL) + htpos = hashtbl[htndx++]; + while (htpos != NULL) { + ep = htpos->def; + nm = htpos->name; + htpos = htpos->next; + if (ep != NULL && incontext(nm)) + return(ep); + } } -#ifdef OUTCHAN if ((ep = ochpos) != NULL) - ochpos = ep->sibling; + ochpos = ep->sibling; return(ep); -#else - return(NULL); -#endif } EPNODE * -dpop(name) /* pop a definition */ -char *name; +dpop( /* pop a definition */ + char *name +) { - register VARDEF *vp; - register EPNODE *dp; + VARDEF *vp; + EPNODE *dp; if ((vp = varlookup(name)) == NULL || vp->def == NULL) - return(NULL); + return(NULL); dp = vp->def; vp->def = dp->sibling; varfree(vp); @@ -333,23 +532,27 @@ char *name; } -dpush(ep) /* push on a definition */ -register EPNODE *ep; +void +dpush( /* push on a definition */ + char *nm, + EPNODE *ep +) { - register VARDEF *vp; + VARDEF *vp; - vp = varinsert(dname(ep)); + vp = varinsert(nm); ep->sibling = vp->def; vp->def = ep; } -#ifdef OUTCHAN -addchan(sp) /* add an output channel assignment */ -EPNODE *sp; +void +addchan( /* add an output channel assignment */ + EPNODE *sp +) { - int ch = sp->v.kid->v.chan; - register EPNODE *ep, *epl; + int ch = sp->v.kid->v.chan; + EPNODE *ep, *epl; for (epl = NULL, ep = outchan; ep != NULL; epl = ep, ep = ep->sibling) if (ep->v.kid->v.chan >= ch) { @@ -372,47 +575,43 @@ EPNODE *sp; sp->sibling = NULL; } -#endif -loaddefn() /* load next definition */ +void +getstatement(void) /* get next statement */ { - register EPNODE *ep; - EPNODE *lastdef; + EPNODE *ep; + char *qname; + VARDEF *vdef; if (nextc == ';') { /* empty statement */ scan(); return; } -#ifdef OUTCHAN - if (nextc == '$') { /* channel assignment */ + if (esupport&E_OUTCHAN && + nextc == '$') { /* channel assignment */ ep = getchan(); addchan(ep); - } else -#endif - { /* ordinary definition */ + } else { /* ordinary definition */ ep = getdefn(); -#ifdef REDEFW - if ((lastdef = dlookup(dname(ep))) != NULL) { - wputs(dname(ep)); - if (lastdef->type == ':') - wputs(": redefined constant expression\n"); - else - wputs(": redefined\n"); + qname = qualname(dname(ep), 0); + if (esupport&E_REDEFW && (vdef = varlookup(qname)) != NULL) { + if (vdef->def != NULL && epcmp(ep, vdef->def)) { + wputs(qname); + if (vdef->def->type == ':') + wputs(": redefined constant expression\n"); + else + wputs(": redefined\n"); + } else if (ep->v.kid->type == FUNC && vdef->lib != NULL) { + wputs(qname); + wputs(": definition hides library function\n"); + } } -#ifdef FUNCTION - else if (ep->v.kid->type == FUNC && - liblookup(ep->v.kid->v.kid->v.name) != NULL) { - wputs(ep->v.kid->v.kid->v.name); - wputs(": redefined library function\n"); - } -#endif -#endif if (ep->type == ':') - dremove(dname(ep)); + dremove(qname); else - dclear(dname(ep)); - dpush(ep); + dclear(qname); + dpush(qname, ep); } if (nextc != EOF) { if (nextc != ';') @@ -423,22 +622,22 @@ loaddefn() /* load next definition */ EPNODE * -getdefn() /* A -> SYM = E1 */ - /* SYM : E1 */ - /* FUNC(SYM,..) = E1 */ - /* FUNC(SYM,..) : E1 */ +getdefn(void) + /* A -> SYM = E1 */ + /* SYM : E1 */ + /* FUNC(SYM,..) = E1 */ + /* FUNC(SYM,..) : E1 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; - if (!isalpha(nextc)) + if (!isalpha(nextc) & (nextc != CNTXMARK)) syntax("illegal variable name"); ep1 = newnode(); ep1->type = SYM; ep1->v.name = savestr(getname()); -#ifdef FUNCTION - if (nextc == '(') { + if (esupport&E_FUNCTION && nextc == '(') { ep2 = newnode(); ep2->type = FUNC; addekid(ep2, ep1); @@ -446,21 +645,21 @@ getdefn() /* A -> SYM = E1 */ do { scan(); if (!isalpha(nextc)) - syntax("illegal variable name"); + syntax("illegal parameter name"); ep2 = newnode(); ep2->type = SYM; ep2->v.name = savestr(getname()); + if (strchr(ep2->v.name, CNTXMARK) != NULL) + syntax("illegal parameter name"); addekid(ep1, ep2); } while (nextc == ','); if (nextc != ')') syntax("')' expected"); scan(); curfunc = ep1; - } else - curfunc = NULL; -#endif + } - if (nextc != '=' && nextc != ':') + if ((nextc != '=') & (nextc != ':')) syntax("'=' or ':' expected"); ep2 = newnode(); @@ -469,29 +668,25 @@ getdefn() /* A -> SYM = E1 */ addekid(ep2, ep1); addekid(ep2, getE1()); - if ( -#ifdef FUNCTION - ep1->type == SYM && -#endif - ep1->sibling->type != NUM) { + if (ep1->type == SYM && ep1->sibling->type != NUM) { ep1 = newnode(); - ep1->type = TICK; - ep1->v.tick = -1; + ep1->type = CLKT; + ep1->v.tick = 0; addekid(ep2, ep1); ep1 = newnode(); ep1->type = NUM; addekid(ep2, ep1); } + curfunc = NULL; return(ep2); } -#ifdef OUTCHAN EPNODE * -getchan() /* A -> $N = E1 */ +getchan(void) /* A -> $N = E1 */ { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; if (nextc != '$') syntax("missing '$'"); @@ -512,7 +707,6 @@ getchan() /* A -> $N = E1 */ return(ep2); } -#endif @@ -521,12 +715,10 @@ getchan() /* A -> $N = E1 */ */ -static double -dvalue(name, d) /* evaluate a variable */ -char *name; -EPNODE *d; +static double /* evaluate a variable */ +dvalue(char *name, EPNODE *d) { - register EPNODE *ep1, *ep2; + EPNODE *ep1, *ep2; if (d == NULL || d->v.kid->type != SYM) { eputs(name); @@ -536,26 +728,20 @@ EPNODE *d; ep1 = d->v.kid->sibling; /* get expression */ if (ep1->type == NUM) return(ep1->v.num); /* return if number */ + if (esupport&E_RCONST && d->type == ':') { + wputs(name); + wputs(": assigned non-constant value\n"); + } ep2 = ep1->sibling; /* check time */ - if (ep2->v.tick < 0 || ep2->v.tick < eclock) { - ep2->v.tick = d->type == ':' ? 1L<<30 : eclock; + if (eclock >= MAXCLOCK) + eclock = 1; /* wrap clock counter */ + if (ep2->v.tick < MAXCLOCK && + (ep2->v.tick == 0) | (ep2->v.tick != eclock)) { + ep2->v.tick = d->type == ':' ? MAXCLOCK : eclock; ep2 = ep2->sibling; ep2->v.num = evalue(ep1); /* needs new value */ } else ep2 = ep2->sibling; /* else reuse old value */ return(ep2->v.num); -} - - -static int -hash(s) /* hash a string */ -register char *s; -{ - register int rval = 0; - - while (*s) - rval += *s++; - - return(rval % NHASH); }
