root/radiance/ray/src/common/caldefn.c
Revision: 2.19
Committed: Mon Jul 21 22:30:17 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.18: +5 -3 lines
2 static const char RCSid[] = "$Id: caldefn.c,v 2.18 2003/07/17 09:21:29 schorsch Exp $";
5 * Store variable definitions.
6 *
7 * 7/1/85 Greg Ward
8 *
9 * 11/11/85 Added conditional compiles (OUTCHAN) for control output.
10 *
11 * 4/2/86 Added conditional compiles for function definitions (FUNCTION).
12 *
13 * 1/15/88 Added clock for caching of variable values.
14 *
15 * 11/16/88 Added VARDEF structure for hard linking.
16 *
17 * 5/31/90 Added conditional compile (REDEFW) for redefinition warning.
18 *
19 * 4/23/91 Added ':' assignment for constant expressions
20 *
21 * 8/7/91 Added optional context path to append to variable names
22 *
23 * 5/17/2001 Fixed clock counter wrapping behavior
24 *
25 * 2/19/03 Eliminated conditional compiles in favor of esupport extern.
26 */
27
28 #include "copyright.h"
29
30 #include <stdio.h>
31 #include <string.h>
32 #include <ctype.h>
33
34 #include "rterror.h"
35 #include "calcomp.h"
36
37 #ifndef NHASH
38 #define NHASH 521 /* hash size (a prime!) */
39 #endif
40
41 #define hash(s) (shash(s)%NHASH)
42
43 #define newnode() (EPNODE *)ecalloc(1, sizeof(EPNODE))
44
45 static double dvalue(char *name, EPNODE *d);
46
47 #define MAXCLOCK (1L<<31) /* clock wrap value */
48
49 unsigned long eclock = 0; /* value storage timer */
50
51 #define MAXCNTX 1023 /* maximum context length */
52
53 static char context[MAXCNTX+1]; /* current context path */
54
55 static VARDEF *hashtbl[NHASH]; /* definition list */
56 static int htndx; /* index for */
57 static VARDEF *htpos; /* ...dfirst() and */
58 static EPNODE *ochpos; /* ...dnext */
59 static EPNODE *outchan;
60
61 EPNODE *curfunc = NULL;
62 #define dname(ep) ((ep)->v.kid->type == SYM ? \
63 (ep)->v.kid->v.name : \
64 (ep)->v.kid->v.kid->v.name)
65
66
67 void
68 fcompile( /* get definitions from a file */
69 char *fname
70 )
71 {
72 FILE *fp;
73
74 if (fname == NULL)
75 fp = stdin;
76 else if ((fp = fopen(fname, "r")) == NULL) {
77 eputs(fname);
78 eputs(": cannot open\n");
79 quit(1);
80 }
81 initfile(fp, fname, 0);
82 while (nextc != EOF)
83 getstatement();
84 if (fname != NULL)
85 fclose(fp);
86 }
87
88
89 void
90 scompile( /* get definitions from a string */
91 char *str,
92 char *fn,
93 int ln
94 )
95 {
96 initstr(str, fn, ln);
97 while (nextc != EOF)
98 getstatement();
99 }
100
101
102 double
103 varvalue( /* return a variable's value */
104 char *vname
105 )
106 {
107 return(dvalue(vname, dlookup(vname)));
108 }
109
110
111 double
112 evariable( /* evaluate a variable */
113 EPNODE *ep
114 )
115 {
116 register VARDEF *dp = ep->v.ln;
117
118 return(dvalue(dp->name, dp->def));
119 }
120
121
122 void
123 varset( /* set a variable's value */
124 char *vname,
125 int assign,
126 double val
127 )
128 {
129 char *qname;
130 register EPNODE *ep1, *ep2;
131 /* get qualified name */
132 qname = qualname(vname, 0);
133 /* check for quick set */
134 if ((ep1 = dlookup(qname)) != NULL && ep1->v.kid->type == SYM) {
135 ep2 = ep1->v.kid->sibling;
136 if (ep2->type == NUM) {
137 ep2->v.num = val;
138 ep1->type = assign;
139 return;
140 }
141 }
142 /* hand build definition */
143 ep1 = newnode();
144 ep1->type = assign;
145 ep2 = newnode();
146 ep2->type = SYM;
147 ep2->v.name = savestr(vname);
148 addekid(ep1, ep2);
149 ep2 = newnode();
150 ep2->type = NUM;
151 ep2->v.num = val;
152 addekid(ep1, ep2);
153 dremove(qname);
154 dpush(qname, ep1);
155 }
156
157
158 void
159 dclear( /* delete variable definitions of name */
160 char *name
161 )
162 {
163 register EPNODE *ep;
164
165 while ((ep = dpop(name)) != NULL) {
166 if (ep->type == ':') {
167 dpush(name, ep); /* don't clear constants */
168 return;
169 }
170 epfree(ep);
171 }
172 }
173
174
175 void
176 dremove( /* delete all definitions of name */
177 char *name
178 )
179 {
180 register EPNODE *ep;
181
182 while ((ep = dpop(name)) != NULL)
183 epfree(ep);
184 }
185
186
187 int
188 vardefined( /* return non-zero if variable defined */
189 char *name
190 )
191 {
192 register EPNODE *dp;
193
194 return((dp = dlookup(name)) != NULL && dp->v.kid->type == SYM);
195 }
196
197
198 char *
199 setcontext( /* set a new context path */
200 register char *ctx
201 )
202 {
203 register char *cpp;
204
205 if (ctx == NULL)
206 return(context); /* just asking */
207 while (*ctx == CNTXMARK)
208 ctx++; /* skip past marks */
209 if (!*ctx) {
210 context[0] = '\0'; /* empty means clear context */
211 return(context);
212 }
213 cpp = context; /* start context with mark */
214 *cpp++ = CNTXMARK;
215 do { /* carefully copy new context */
216 if (cpp >= context+MAXCNTX)
217 break; /* just copy what we can */
218 if (isid(*ctx))
219 *cpp++ = *ctx++;
220 else {
221 *cpp++ = '_'; ctx++;
222 }
223 } while (*ctx);
224 while (cpp[-1] == CNTXMARK) /* cannot end in context mark */
225 cpp--;
226 *cpp = '\0';
227 return(context);
228 }
229
230
231 char *
232 pushcontext( /* push on another context */
233 char *ctx
234 )
235 {
236 char oldcontext[MAXCNTX+1];
237 register int n;
238
239 strcpy(oldcontext, context); /* save old context */
240 setcontext(ctx); /* set new context */
241 n = strlen(context); /* tack on old */
242 if (n+strlen(oldcontext) > MAXCNTX) {
243 strncpy(context+n, oldcontext, MAXCNTX-n);
244 context[MAXCNTX] = '\0';
245 } else
246 strcpy(context+n, oldcontext);
247 return(context);
248 }
249
250
251 char *
252 popcontext(void) /* pop off top context */
253 {
254 register char *cp1, *cp2;
255
256 if (!context[0]) /* nothing left to pop */
257 return(context);
258 cp2 = context; /* find mark */
259 while (*++cp2 && *cp2 != CNTXMARK)
260 ;
261 cp1 = context; /* copy tail to front */
262 while (*cp1++ = *cp2++)
263 ;
264 return(context);
265 }
266
267
268 char *
269 qualname( /* get qualified name */
270 register char *nam,
271 int lvl
272 )
273 {
274 static char nambuf[RMAXWORD+1];
275 register char *cp = nambuf, *cpp;
276 /* check for explicit local */
277 if (*nam == CNTXMARK)
278 if (lvl > 0) /* only action is to refuse search */
279 return(NULL);
280 else
281 nam++;
282 else if (nam == nambuf) /* check for repeat call */
283 return(lvl > 0 ? NULL : nam);
284 /* copy name to static buffer */
285 while (*nam) {
286 if (cp >= nambuf+RMAXWORD)
287 goto toolong;
288 *cp++ = *nam++;
289 }
290 /* check for explicit global */
291 if (cp > nambuf && cp[-1] == CNTXMARK) {
292 if (lvl > 0)
293 return(NULL);
294 *--cp = '\0';
295 return(nambuf); /* already qualified */
296 }
297 cpp = context; /* else skip the requested levels */
298 while (lvl-- > 0) {
299 if (!*cpp)
300 return(NULL); /* return NULL if past global level */
301 while (*++cpp && *cpp != CNTXMARK)
302 ;
303 }
304 while (*cpp) { /* copy context to static buffer */
305 if (cp >= nambuf+RMAXWORD)
306 goto toolong;
307 *cp++ = *cpp++;
308 }
309 toolong:
310 *cp = '\0';
311 return(nambuf); /* return qualified name */
312 }
313
314
315 int
316 incontext( /* is qualified name in current context? */
317 register char *qn
318 )
319 {
320 if (!context[0]) /* global context accepts all */
321 return(1);
322 while (*qn && *qn != CNTXMARK) /* find context mark */
323 qn++;
324 return(!strcmp(qn, context));
325 }
326
327
328 void
329 chanout( /* set output channels */
330 void (*cs)(int n, double v)
331 )
332 {
333 register EPNODE *ep;
334
335 for (ep = outchan; ep != NULL; ep = ep->sibling)
336 (*cs)(ep->v.kid->v.chan, evalue(ep->v.kid->sibling));
337
338 }
339
340
341 void
342 dcleanup( /* clear definitions (0->vars,1->output,2->consts) */
343 int lvl
344 )
345 {
346 register int i;
347 register VARDEF *vp;
348 register EPNODE *ep;
349 /* if context is global, clear all */
350 for (i = 0; i < NHASH; i++)
351 for (vp = hashtbl[i]; vp != NULL; vp = vp->next)
352 if (incontext(vp->name)) {
353 if (lvl >= 2)
354 dremove(vp->name);
355 else
356 dclear(vp->name);
357 }
358 if (lvl >= 1) {
359 for (ep = outchan; ep != NULL; ep = ep->sibling)
360 epfree(ep);
361 outchan = NULL;
362 }
363 }
364
365
366 EPNODE *
367 dlookup( /* look up a definition */
368 char *name
369 )
370 {
371 register VARDEF *vp;
372
373 if ((vp = varlookup(name)) == NULL)
374 return(NULL);
375 return(vp->def);
376 }
377
378
379 VARDEF *
380 varlookup( /* look up a variable */
381 char *name
382 )
383 {
384 int lvl = 0;
385 register char *qname;
386 register VARDEF *vp;
387 /* find most qualified match */
388 while ((qname = qualname(name, lvl++)) != NULL)
389 for (vp = hashtbl[hash(qname)]; vp != NULL; vp = vp->next)
390 if (!strcmp(vp->name, qname))
391 return(vp);
392 return(NULL);
393 }
394
395
396 VARDEF *
397 varinsert( /* get a link to a variable */
398 char *name
399 )
400 {
401 register VARDEF *vp;
402 int hv;
403
404 if ((vp = varlookup(name)) != NULL) {
405 vp->nlinks++;
406 return(vp);
407 }
408 vp = (VARDEF *)emalloc(sizeof(VARDEF));
409 vp->lib = liblookup(name);
410 if (vp->lib == NULL) /* if name not in library */
411 name = qualname(name, 0); /* use fully qualified version */
412 hv = hash(name);
413 vp->name = savestr(name);
414 vp->nlinks = 1;
415 vp->def = NULL;
416 vp->next = hashtbl[hv];
417 hashtbl[hv] = vp;
418 return(vp);
419 }
420
421
422 void
423 libupdate( /* update library links */
424 char *fn
425 )
426 {
427 register int i;
428 register VARDEF *vp;
429 /* if fn is NULL then relink all */
430 for (i = 0; i < NHASH; i++)
431 for (vp = hashtbl[i]; vp != NULL; vp = vp->next)
432 if (vp->lib != NULL || fn == NULL || !strcmp(fn, vp->name))
433 vp->lib = liblookup(vp->name);
434 }
435
436
437 void
438 varfree( /* release link to variable */
439 register VARDEF *ln
440 )
441 {
442 register VARDEF *vp;
443 int hv;
444
445 if (--ln->nlinks > 0)
446 return; /* still active */
447
448 hv = hash(ln->name);
449 vp = hashtbl[hv];
450 if (vp == ln)
451 hashtbl[hv] = vp->next;
452 else {
453 while (vp->next != ln) /* must be in list */
454 vp = vp->next;
455 vp->next = ln->next;
456 }
457 freestr(ln->name);
458 efree((char *)ln);
459 }
460
461
462 EPNODE *
463 dfirst(void) /* return pointer to first definition */
464 {
465 htndx = 0;
466 htpos = NULL;
467 ochpos = outchan;
468 return(dnext());
469 }
470
471
472 EPNODE *
473 dnext(void) /* return pointer to next definition */
474 {
475 register EPNODE *ep;
476 register char *nm;
477
478 while (htndx < NHASH) {
479 if (htpos == NULL)
480 htpos = hashtbl[htndx++];
481 while (htpos != NULL) {
482 ep = htpos->def;
483 nm = htpos->name;
484 htpos = htpos->next;
485 if (ep != NULL && incontext(nm))
486 return(ep);
487 }
488 }
489 if ((ep = ochpos) != NULL)
490 ochpos = ep->sibling;
491 return(ep);
492 }
493
494
495 EPNODE *
496 dpop( /* pop a definition */
497 char *name
498 )
499 {
500 register VARDEF *vp;
501 register EPNODE *dp;
502
503 if ((vp = varlookup(name)) == NULL || vp->def == NULL)
504 return(NULL);
505 dp = vp->def;
506 vp->def = dp->sibling;
507 varfree(vp);
508 return(dp);
509 }
510
511
512 void
513 dpush( /* push on a definition */
514 char *nm,
515 register EPNODE *ep
516 )
517 {
518 register VARDEF *vp;
519
520 vp = varinsert(nm);
521 ep->sibling = vp->def;
522 vp->def = ep;
523 }
524
525
526 void
527 addchan( /* add an output channel assignment */
528 EPNODE *sp
529 )
530 {
531 int ch = sp->v.kid->v.chan;
532 register EPNODE *ep, *epl;
533
534 for (epl = NULL, ep = outchan; ep != NULL; epl = ep, ep = ep->sibling)
535 if (ep->v.kid->v.chan >= ch) {
536 if (epl != NULL)
537 epl->sibling = sp;
538 else
539 outchan = sp;
540 if (ep->v.kid->v.chan > ch)
541 sp->sibling = ep;
542 else {
543 sp->sibling = ep->sibling;
544 epfree(ep);
545 }
546 return;
547 }
548 if (epl != NULL)
549 epl->sibling = sp;
550 else
551 outchan = sp;
552 sp->sibling = NULL;
553
554 }
555
556
557 void
558 getstatement(void) /* get next statement */
559 {
560 register EPNODE *ep;
561 char *qname;
562 register VARDEF *vdef;
563
564 if (nextc == ';') { /* empty statement */
565 scan();
566 return;
567 }
568 if (esupport&E_OUTCHAN &&
569 nextc == '$') { /* channel assignment */
570 ep = getchan();
571 addchan(ep);
572 } else { /* ordinary definition */
573 ep = getdefn();
574 qname = qualname(dname(ep), 0);
575 if (esupport&E_REDEFW && (vdef = varlookup(qname)) != NULL) {
576 if (vdef->def != NULL && epcmp(ep, vdef->def)) {
577 wputs(qname);
578 if (vdef->def->type == ':')
579 wputs(": redefined constant expression\n");
580 else
581 wputs(": redefined\n");
582 } else if (ep->v.kid->type == FUNC && vdef->lib != NULL) {
583 wputs(qname);
584 wputs(": definition hides library function\n");
585 }
586 }
587 if (ep->type == ':')
588 dremove(qname);
589 else
590 dclear(qname);
591 dpush(qname, ep);
592 }
593 if (nextc != EOF) {
594 if (nextc != ';')
595 syntax("';' expected");
596 scan();
597 }
598 }
599
600
601 EPNODE *
602 getdefn(void)
603 /* A -> SYM = E1 */
604 /* SYM : E1 */
605 /* FUNC(SYM,..) = E1 */
606 /* FUNC(SYM,..) : E1 */
607 {
608 register EPNODE *ep1, *ep2;
609
610 if (!isalpha(nextc) && nextc != CNTXMARK)
611 syntax("illegal variable name");
612
613 ep1 = newnode();
614 ep1->type = SYM;
615 ep1->v.name = savestr(getname());
616
617 if (esupport&E_FUNCTION && nextc == '(') {
618 ep2 = newnode();
619 ep2->type = FUNC;
620 addekid(ep2, ep1);
621 ep1 = ep2;
622 do {
623 scan();
624 if (!isalpha(nextc))
625 syntax("illegal variable name");
626 ep2 = newnode();
627 ep2->type = SYM;
628 ep2->v.name = savestr(getname());
629 addekid(ep1, ep2);
630 } while (nextc == ',');
631 if (nextc != ')')
632 syntax("')' expected");
633 scan();
634 curfunc = ep1;
635 }
636
637 if (nextc != '=' && nextc != ':')
638 syntax("'=' or ':' expected");
639
640 ep2 = newnode();
641 ep2->type = nextc;
642 scan();
643 addekid(ep2, ep1);
644 addekid(ep2, getE1());
645
646 if (ep1->type == SYM && ep1->sibling->type != NUM) {
647 ep1 = newnode();
648 ep1->type = TICK;
649 ep1->v.tick = 0;
650 addekid(ep2, ep1);
651 ep1 = newnode();
652 ep1->type = NUM;
653 addekid(ep2, ep1);
654 }
655 curfunc = NULL;
656
657 return(ep2);
658 }
659
660
661 EPNODE *
662 getchan(void) /* A -> $N = E1 */
663 {
664 register EPNODE *ep1, *ep2;
665
666 if (nextc != '$')
667 syntax("missing '$'");
668 scan();
669
670 ep1 = newnode();
671 ep1->type = CHAN;
672 ep1->v.chan = getinum();
673
674 if (nextc != '=')
675 syntax("'=' expected");
676 scan();
677
678 ep2 = newnode();
679 ep2->type = '=';
680 addekid(ep2, ep1);
681 addekid(ep2, getE1());
682
683 return(ep2);
684 }
685
686
687
688 /*
689 * The following routines are for internal use only:
690 */
691
692
693 static double /* evaluate a variable */
694 dvalue(char *name, EPNODE *d)
695 {
696 register EPNODE *ep1, *ep2;
697
698 if (d == NULL || d->v.kid->type != SYM) {
699 eputs(name);
700 eputs(": undefined variable\n");
701 quit(1);
702 }
703 ep1 = d->v.kid->sibling; /* get expression */
704 if (ep1->type == NUM)
705 return(ep1->v.num); /* return if number */
706 ep2 = ep1->sibling; /* check time */
707 if (eclock >= MAXCLOCK)
708 eclock = 1; /* wrap clock counter */
709 if (ep2->v.tick < MAXCLOCK &&
710 ep2->v.tick == 0 | ep2->v.tick != eclock) {
711 ep2->v.tick = d->type == ':' ? MAXCLOCK : eclock;
712 ep2 = ep2->sibling;
713 ep2->v.num = evalue(ep1); /* needs new value */
714 } else
715 ep2 = ep2->sibling; /* else reuse old value */
716
717 return(ep2->v.num);
718 }
