1 |
/* RCSid $Id: calcomp.h,v 2.22 2008/05/01 16:42:05 greg Exp $ */ |
2 |
3 |
* calcomp.h - header file for expression parser. |
4 |
5 |
#ifndef _RAD_CALCOMP_H_ |
6 |
#define _RAD_CALCOMP_H_ |
7 |
8 |
#include <stdio.h> |
9 |
10 |
#ifdef __cplusplus |
11 |
extern "C" { |
12 |
#endif |
13 |
14 |
#define VAR 1 |
15 |
#define NUM 2 |
16 |
#define UMINUS 3 |
17 |
#define CHAN 4 |
18 |
#define FUNC 5 |
19 |
#define ARG 6 |
20 |
#define CLKT 7 |
21 |
#define SYM 8 |
22 |
/* also: '+', '-', '*', '/', '^', '=', ':' */ |
23 |
24 |
typedef struct { |
25 |
char *fname; /* function name */ |
26 |
short nargs; /* # of required arguments */ |
27 |
short atyp; /* assignment type (':' or '=') */ |
28 |
double (*f)(char *); /* pointer to function */ |
29 |
} LIBR; /* a library function */ |
30 |
31 |
typedef struct epnode { |
32 |
union { |
33 |
struct epnode *kid; /* first child */ |
34 |
double num; /* number */ |
35 |
char *name; /* symbol name */ |
36 |
int chan; /* channel number */ |
37 |
unsigned long tick; /* timestamp */ |
38 |
struct vardef { |
39 |
char *name; /* variable name */ |
40 |
int nlinks; /* number of references */ |
41 |
struct epnode *def; /* definition */ |
42 |
LIBR *lib; /* library definition */ |
43 |
struct vardef *next; /* next in hash list */ |
44 |
} *ln; /* link */ |
45 |
} v; /* value */ |
46 |
struct epnode *sibling; /* next child this level */ |
47 |
int type; /* node type */ |
48 |
} EPNODE; /* an expression node */ |
49 |
50 |
typedef struct vardef VARDEF; /* a variable definition */ |
51 |
52 |
#define RMAXWORD 127 /* maximum word/id length */ |
53 |
#define CNTXMARK '`' /* context mark */ |
54 |
55 |
#define isid(c) (isalnum(c) || (c) == '_' || \ |
56 |
(c) == '.' || (c) == CNTXMARK) |
57 |
58 |
#define evalue(ep) (*eoper[(ep)->type])(ep) |
59 |
60 |
/* flags to set in esupport */ |
61 |
#define E_VARIABLE 001 |
62 |
#define E_FUNCTION 002 |
63 |
#define E_INCHAN 004 |
64 |
#define E_OUTCHAN 010 |
65 |
#define E_RCONST 020 |
66 |
#define E_REDEFW 040 |
67 |
68 |
extern double (*eoper[])(EPNODE *); |
69 |
extern unsigned long eclock; |
70 |
extern unsigned int esupport; |
71 |
extern EPNODE *curfunc; |
72 |
extern int nextc; |
73 |
extern int eofc; |
74 |
75 |
/* defined in biggerlib.c */ |
76 |
extern void biggerlib(void); |
77 |
78 |
/* defined in caldefn.c */ |
79 |
extern void fcompile(char *fname); |
80 |
extern void scompile(char *str, char *fname, int ln); |
81 |
extern double varvalue(char *vname); |
82 |
extern double evariable(EPNODE *ep); |
83 |
extern void varset(char *vname, int assign, double val); |
84 |
extern void dclear(char *name); |
85 |
extern void dremove(char *name); |
86 |
extern int vardefined(char *name); |
87 |
extern char *calcontext(char *ctx); |
88 |
extern char *pushcontext(char *ctx); |
89 |
extern char *popcontext(void); |
90 |
extern char *qualname(char *nam, int lvl); |
91 |
extern int incontext(char *qn); |
92 |
extern void chanout(void (*cs)(int n, double v)); |
93 |
extern void dcleanup(int lvl); |
94 |
extern EPNODE *dlookup(char *name); |
95 |
extern VARDEF *varlookup(char *name); |
96 |
extern VARDEF *varinsert(char *name); |
97 |
extern void varfree(VARDEF *ln); |
98 |
extern EPNODE *dfirst(void); |
99 |
extern EPNODE *dnext(void); |
100 |
extern EPNODE *dpop(char *name); |
101 |
extern void dpush(char *nm, EPNODE *ep); |
102 |
extern void addchan(EPNODE *sp); |
103 |
extern void getstatement(void); |
104 |
extern EPNODE *getdefn(void); |
105 |
extern EPNODE *getchan(void); |
106 |
/* defined in calexpr.c */ |
107 |
extern EPNODE *eparse(char *expr); |
108 |
extern double eval(char *expr); |
109 |
extern int epcmp(EPNODE *ep1, EPNODE *ep2); |
110 |
extern void epfree(EPNODE *epar); |
111 |
extern EPNODE *ekid(EPNODE *ep, int n); |
112 |
extern int nekids(EPNODE *ep); |
113 |
extern void initfile(FILE *fp, char *fn, int ln); |
114 |
extern void initstr(char *s, char *fn, int ln); |
115 |
extern void getscanpos(char **fnp, int *lnp, char **spp, FILE **fpp); |
116 |
extern int scan(void); |
117 |
extern char *long2ascii(long l); |
118 |
extern void syntax(char *err); |
119 |
extern void addekid(EPNODE *ep, EPNODE *ekid); |
120 |
extern char *getname(void); |
121 |
extern int getinum(void); |
122 |
extern double getnum(void); |
123 |
extern EPNODE *getE1(void); |
124 |
extern EPNODE *getE2(void); |
125 |
extern EPNODE *getE3(void); |
126 |
extern EPNODE *getE4(void); |
127 |
extern EPNODE *getE5(void); |
128 |
extern EPNODE *rconst(EPNODE *epar); |
129 |
extern int isconstvar(EPNODE *ep); |
130 |
extern int isconstfun(EPNODE *ep); |
131 |
/* defined in calfunc.c */ |
132 |
extern int fundefined(char *fname); |
133 |
extern double funvalue(char *fname, int n, double *a); |
134 |
extern void funset(char *fname, int nargs, int assign, |
135 |
double (*fptr)(char *)); |
136 |
extern int nargum(void); |
137 |
extern double argument(int n); |
138 |
extern VARDEF *argf(int n); |
139 |
extern char *argfun(int n); |
140 |
extern double efunc(EPNODE *ep); |
141 |
extern LIBR *liblookup(char *fname); |
142 |
extern void libupdate(char *fn); |
143 |
/* defined in calprnt.c */ |
144 |
extern void eprint(EPNODE *ep, FILE *fp); |
145 |
extern void dprint(char *name, FILE *fp); |
146 |
/* defined by client */ |
147 |
extern double chanvalue(int n); |
148 |
149 |
150 |
151 |
152 |
#endif |
153 |
#endif /* _RAD_CALCOMP_H_ */ |
154 |
